  4. Test Adapter Hoover hON
184 Beiträge 34 Kommentatoren 49.2k Aufrufe 31 Beobachtet
  • E e-i-k-e
    @jkalver sagte in Test Adapter Hoover hON:
    Hallo @tombox ,
    Ich habe den Adapter (v0.0.6) installiert.
    Beim Starten bekomme ich folgende Fehler:
    Missing step1 url
    "*/{"event":{"descriptor":"markup://aura:systemError","attributes":{"values":{"message":"[AuraClientInputException from server] Unexpected request input. Expected input format: \"Data in a request must be a valid JSON Object and must be in the expected format.\".","showOverride":false}},"eventDef":{"descriptor":"markup://aura:systemError","t":"APPLICATION","xs":"G","a":{"message":["message","aura://String","G",false],"error":["error","aura://String","G",false],"auraError":["auraError","aura://Object","I",false,null],"timestamp":["timestamp","aura://Integer","I",false],"showOverride":["showOverride","aura://Boolean","I",false,false]}}},"exceptionMessage":"[AuraClientInputException from server] Unexpected request input. Expected input format: \"Data in a request must be a valid JSON Object and must be in the expected format.\".","exceptionEvent":true}/ERROR/"
    Meine Konfig:
    aarch64
    /usr/bin/nodejs
    /usr/bin/node
    /usr/bin/npm
    v18.15.0
    v18.15.0
    9.5.0
    4.0.23
    Was mache ich falsch?
    Gruss
    Jens
    Ich habe das gleiche Problem.
    Was läuft hier falsch?
    Den Weinkühlschrank habe ich in der h0n entfernt und zwei Klimaanlagen hinzugefügt.
    hoover.0
    2023-05-05 22:21:18.153	error	"*/{\"event\":{\"descriptor\":\"markup://aura:systemError\",\"attributes\":{\"values\":{\"message\":\"[AuraClientInputException from server] Unexpected request input. Expected input format: \\\"Data in a request must be a valid JSON Object and must be in the expected format.\\\".\",\"showOverride\":false}},\"eventDef\":{\"descriptor\":\"markup://aura:systemError\",\"t\":\"APPLICATION\",\"xs\":\"G\",\"a\":{\"message\":[\"message\",\"aura://String\",\"G\",false],\"error\":[\"error\",\"aura://String\",\"G\",false],\"auraError\":[\"auraError\",\"aura://Object\",\"I\",false,null],\"timestamp\":[\"timestamp\",\"aura://Integer\",\"I\",false],\"showOverride\":[\"showOverride\",\"aura://Boolean\",\"I\",false,false]}}},\"exceptionMessage\":\"[AuraClientInputException from server] Unexpected request input. Expected input format: \\\"Data in a request must be a valid JSON Object and must be in the expected format.\\\".\",\"exceptionEvent\":true}/*ERROR*/"
    hoover.0
    2023-05-05 22:21:18.152	error	Missing step1 url
    hoover.0
    2023-05-05 22:21:16.200	info	starting login
    hoover.0
    2023-05-05 22:21:16.134	info	starting. Version 0.0.7 in /opt/iobroker/node_modules/iobroker.hoover, node: v18.16.0, js-controller: 5.0.1-alpha.0-20230418-efa3e809
    e-i-k-e
    #151
    @e-i-k-e sagte in Test Adapter Hoover hON:
    Hallo @tombox ,
    Missing step1 url
    Meine Konfig:
    aarch64
    /usr/bin/nodejs
    /usr/bin/node
    /usr/bin/npm
    v18.15.0
    v18.15.0
    9.5.0
    4.0.23
    Gruss
    Jens
    hoover.0
    hoover.0
    hoover.0
    hoover.0
    @tombox Ich habe wieder genau die gleichen Probleme.
    Eine Idee, was es sein könnte?
    • von.cartmanV Offline
      von.cartman
      schrieb am zuletzt editiert von von.cartman
      #152
      @tombox Hallo Tombox,
      sein geraume Zeit versuche ich den Status von Haier AC abzugreifen, vor allem ob es An ider Aus ist.
      Ich habe diese 5 Objekte gefunden die eventuel in Frage kommen wurden:
      • .context.activity.attributes.power
      • Listenpunkt.context.commandHistory.command.parameters.onOffStatus
      • Listenpunkt.context.shadow.parameters.onOffStatus.parNewVal
      • Listenpunkt.context.shadow.parameters.power.parNewVal
      • Listenpunkt.stream.onOffStatus.parNewVal
      Leider keiner von diesen liefert mir Zuverlässig Daten.
      Entweder ist der eine oder der andere Objekt, oder die Werte ändern sich garnicht.
      Matten MattenM 1 Antwort Letzte Antwort
      • von.cartmanV von.cartman
        Matten MattenM Offline
        Matten Matten
        #153
        Moin,
        gibt es schon jemanden der erfolgreich eine Hoover oder Haier Waschmaschiene zum laufen gebracht hat,
        also Programme gestartet oder auch Programme Pausiert oder gestopt?
        Ich hab mir eine Haier WM gekauft und wollte die Maschiene gerne einbinden.
        MattenMatten
        ioBroker auf Beelink mit WIN10 home|CCU3 (Raspberrymatic)|Neato BotVac D3|HYPERION Ambilight auf RPI3 und RPI ZeroW|HA-Bridge|Milight LED|Nodered&Redmatic|VU Duo2 & Solo se V2
        • C Offline
          cacherwolf
          #154
          ich habe das Problem das ich mich nicht mehr einloggen kann:
          Im App funktioniert alles nur hier im Adapter bekomme ich immer diese Fehlermeldungen.
          Hat jemand eine Lösung?
          Danke und Gruß
          • C cacherwolf
            Danke und Gruß
            Matten Matten
            schrieb am zuletzt editiert von Matten Matten
            #155
            @cacherwolf
            Bei meinem Adapter das selbe
            • H Offline
              hahne
              #156
              Hab das gleiche Problem.
              • F Offline
                Fabian1
                #157
                Bei mir auch das selbe. Ich habe die Vermutung, dass irgendwas an der Login Prozedur der hon app geändert wurde. Kurz bevor es nicht mehr ging, hat nämlich die IPhone app ein update bekommen.
                R 1 Antwort Letzte Antwort
                • F Fabian1
                  Radi
                  #158
                  Auch bei mir die selbe Fehlermeldung.
                  • Horst BöttcherH Offline
                    Horst Böttcher
                    schrieb am zuletzt editiert von Horst Böttcher
                    #159
                    Adapter bleibt Gelb
                    hoover.0
                    2024-11-16 14:39:40.918	error	""
                    hoover.0
                    2024-11-16 14:39:40.917	error	AxiosError: Request failed with status code 301
                    hoover.0
                    2024-11-16 14:39:02.391	error	""
                    hoover.0
                    2024-11-16 14:39:02.389	error	AxiosError: Request failed with status code 301
                    hoover.0
                    2024-11-16 14:38:24.538	error	""
                    hoover.0
                    2024-11-16 14:38:24.537	error	AxiosError: Request failed with status code 301
                    hoover.0
                    2024-11-16 14:38:07.388	error	Please set username and password in the instance settings
                    ioBroker auf Proxmox (Debian) auf LENOVO PC Thinkcentre als Produktivsystem
                    Ro75R 1 Antwort Letzte Antwort
                    • Horst BöttcherH Horst Böttcher
                      Adapter bleibt Gelb
                      hoover.0
                      hoover.0
                      hoover.0
                      hoover.0
                      hoover.0
                      hoover.0
                      hoover.0
                      Ro75R Offline
                      Ro75R Offline
                      Ro75
                      #160
                      @horst-böttcher sagte in Test Adapter Hoover hON:
                      hoover.0 2024-11-16 14:38:07.388 error Please set username and password in the instance settings
                      was ist damit?
                      Ro75.
                      Horst BöttcherH 1 Antwort Letzte Antwort
                      • Ro75R Ro75
                        was ist damit?
                        Ro75.
                        Horst Böttcher
                        #161
                        @ro75 sagte in Test Adapter Hoover hON:
                        was ist damit?
                        Ro75.
                        da hatte ich einmal das passwort falsch eingegeben da steht aber jetzt das richtige drin
                          was ist damit?
                          Ro75.
                          Ro75R Offline
                          Ro75R Offline
                          Ro75
                          #162
                          @horst-böttcher dann neues Log mit dem
                          Ro75.
                          • Ro75R Ro75
                            Ro75.
                            Horst Böttcher
                            #163
                            @ro75
                            hoover.0
                            2024-11-16 15:16:57.040	error	""
                            hoover.0
                            2024-11-16 15:16:57.039	error	AxiosError: Request failed with status code 301
                            hoover.0
                            2024-11-16 15:16:56.315	info	starting login
                            hoover.0
                            2024-11-16 15:16:56.283	info	starting. Version 0.0.7 in /opt/iobroker/node_modules/iobroker.hoover, node: v20.18.0, js-controller: 7.0.2
                              @ro75
                              hoover.0
                              hoover.0
                              hoover.0
                              hoover.0
                              Ro75R Offline
                              Ro75R Offline
                              Ro75
                              #164
                              vielleicht liegt es ja am
                              Dieser ist doch beta und nicht stable?!
                              Ro75.
                              • Ro75R Ro75
                                Ro75.
                                Horst Böttcher
                                #165
                                @ro75 kann mann das zurücksetzen
                                  Ro75R Offline
                                  Ro75R Offline
                                  Ro75
                                  #166
                                  @horst-böttcher sicher.
                                  Ro75
                                  • Ro75R Ro75
                                    Ro75
                                    Horst Böttcher
                                    #167
                                    @ro75
                                    Hab jetzt mal neu gemacht und nein es hat nix gehlfen :-(
                                    hoover.0
                                    2024-11-16 19:46:22.505	error	""
                                    hoover.0
                                    2024-11-16 19:46:22.504	error	AxiosError: Request failed with status code 301
                                    hoover.0
                                    2024-11-16 19:46:21.964	info	starting login
                                    hoover.0
                                    2024-11-16 19:46:21.926	info	starting. Version 0.0.7 in /opt/iobroker/node_modules/iobroker.hoover, node: v20.18.0, js-controller: 6.0.11
                                    hoover.0
                                    2024-11-16 19:46:15.605	info	terminating
                                    hoover.0
                                    2024-11-16 19:46:15.103	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    hoover.0
                                    2024-11-16 19:46:15.098	info	terminating
                                    hoover.0
                                    2024-11-16 19:46:15.091	info	Got terminate signal TERMINATE_YOURSELF
                                      @ro75
                                      hoover.0
                                      hoover.0
                                      hoover.0
                                      hoover.0
                                      hoover.0
                                      hoover.0
                                      hoover.0
                                      hoover.0
                                      tombox
                                      #168
                                      @horst-böttcher # Für die aktuelle Version bitte das latest Repo auswählen:
                                      • Matten MattenM Offline
                                        Matten Matten
                                        #169
                                        Moin,
                                        bei mir verbindet sich der Adapter nicht mehr.
                                        Fehlermeldung:
                                        hoover.0 2025-02-09 09:37:58.568	error	Error: unable to verify the first certificate
                                        • Matten MattenM Matten Matten
                                          Moin,
                                          Fehlermeldung:
                                          tombox
                                          #170
                                          @matten-matten Bitte 0.1.4 testen
