  4. FBPresence Adapter - Fehlermeldung bei Update
    1.7k
10 Beiträge 2 Kommentatoren 816 Aufrufe 2 Beobachtet
    Bielefelder81
    Hi zusammen,
    ich versuche seit einiger Zeit meinen fbpresence Adapter zu uppen. Bekomme aber ständige folgende Fehlermeldung und versteh sie nicht.
    $ iobroker upgrade fb-checkpresence@1.2.5
    Update fb-checkpresence from @1.2.4 to @1.2.5
    host.ioBroker Adapter "system.adapter.fb-checkpresence.0" is stopped.
    NPM version: 10.2.4Installing iobroker.fb-checkpresence@1.2.5... (System call)
    Try to solve ENOTEMPTY error automatically
    Could not handle ENOTEMPTY, because no deletable files were foundnpm ERR! code ENOTEMPTYnpm ERR! syscall renamenpm ERR! path /opt/iobroker/node_modules/@types/nodenpm ERR! dest /opt/iobroker/node_modules/@types/.node-Bd1x5fmznpm ERR! errno -39npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/@types/node' -> '/opt/iobroker/node_modules/@types/.node-Bd1x5fmz'npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-11-10T14_35_37_794Z-debug-0.loghost.ioBroker Cannot install iobroker.fb-checkpresence@1.2.5: 217
    ERROR: Process exited with code 25
    • B Bielefelder81
      Hi zusammen,
      @bielefelder81
      iob stop
      iob fix
      iob start
      iob update
      iob upgrade
        @bielefelder81
        iob stop
        iob fix
        iob start
        iob update
        iob upgrade
        Bielefelder81
        Funktioniert trotzdem nicht
        This upgrade of "fb-checkpresence" will introduce the following changes:
        -> 1.2.5:
        new filter function implemented (experimental)
        node >=18
        dependencies updated
        repository checker issues fixed
        issue fixed [#294](https://github.com/afuerhoff/ioBroker.fb-checkpresence/issues/294)
        'devicename' as state added [#299](https://github.com/afuerhoff/ioBroker.fb-checkpresence/issues/299)
        Would you like to upgrade fb-checkpresence from @1.2.4 to @1.2.5 now? [(y)es, (n)o]: y
        NPM version: 10.2.4
        host.ioBroker deleted npm temp directory: ".iobroker.javascript-5NZ432mn")
        npm ERR! errno -39
        npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-11-10T14_54_26_247Z-debug-0.log
        • B Bielefelder81
          -> 1.2.5:
          node >=18
          NPM version: 10.2.4
          npm ERR! errno -39
          @bielefelder81 sagte in FBPresence Adapter - Fehlermeldung bei Update:
          Dann mehr Input...
          Die Langfassung von
          iob diag
          sagt?
          Und den Fix kannst du nochmal ausführen. Muss man ggfls. mehrfach tun.
            Dann mehr Input...
            Die Langfassung von
            iob diag
            sagt?
            Bielefelder81
                                    v.2024-10-19
               Static hostname: ioBroker
                     Icon name: computer-container
                       Chassis: container
                Virtualization: lxc
              Operating System: Ubuntu 20.04.6 LTS
                        Kernel: Linux 5.4.55-1-pve
                  Architecture: x86-64
            Installation:           lxc
            Kernel:                 x86_64
            Userland:               64 bit
            oTimezone:              Europe/Berlin (CET, +0100)
            User-ID:                1000
            Display-Server:         false
            Pending OS-Updates:     0
            Pending iob updates:    1
            Nodejs-Installation:
            /usr/bin/nodejs         v18.20.4
            /usr/bin/node           v18.20.4
            /usr/bin/npm            10.7.0
            /usr/bin/npx            10.7.0
            /usr/bin/corepack       0.28.0
            Recommended versions are nodejs 20.18.0 and npm 10.8.2
            nodeJS installation is correct
            MEMORY:
            Mem:           4.1G        1.6G        1.4G        0.0K        1.1G        2.5G
            Swap:          512M          0B        512M
            Total:         4.6G        1.6G        1.9G
            Active iob-Instances:   18
            Upgrade policy: none
            ioBroker Core:          js-controller           6.0.11
                                    admin                   7.1.5
            Objects type: jsonl
            States  type: jsonl
            + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
            + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
            Objects:                5443
            States:                 4491
            Size of iob-Database:
            40M     /opt/iobroker/iobroker-data/objects.jsonl
            6.9M    /opt/iobroker/iobroker-data/objects.json.migrated
            6.9M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
            5.7M    /opt/iobroker/iobroker-data/states.jsonl
            640K    /opt/iobroker/iobroker-data/states.json.migrated
            640K    /opt/iobroker/iobroker-data/states.json.bak.migrated
            Some problems detected, please run iob fix and try to have them fixed
            Operating System codenamed 'focal' is an aging Ubuntu release! Please upgrade to the latest LTS release 'noble' in due time!
            === Mark text until here for copying ===
            • B Bielefelder81
                                      v.2024-10-19
                         Chassis: container
                  Virtualization: lxc
              Installation:           lxc
              Kernel:                 x86_64
              Userland:               64 bit
              User-ID:                1000
              /usr/bin/npm            10.7.0
              /usr/bin/npx            10.7.0
              MEMORY:
              Swap:          512M          0B        512M
                                      admin                   7.1.5
              Objects type: jsonl
              States  type: jsonl
              Objects:                5443
              States:                 4491
              @bielefelder81
              Das ist nicht die Langfassung.
              Bring aber schon mal nodejs auf die empfohlene Version 20.
              iob nodejs-update
              B 2 Antworten Letzte Antwort
                @bielefelder81
                iob nodejs-update
                Bielefelder81
                schrieb am zuletzt editiert von Bielefelder81
                @thomas-braun Update auf nodejs läuft. Hatte zwischendurch gesehen, dass angeblich zu wenig Speicher frei war... Noch 600MB oder so. Hab dann per Proxmoxx von 10 GB auf 30 GB erhöht.
                  @bielefelder81
                  iob nodejs-update
                  Bielefelder81
                  @thomas-braun ```
                  Script v.2024-10-19
                  *** BASE SYSTEM ***
                             Chassis: container
                      Virtualization: lxc
                  OS is similar to: debian
                  model name      : Intel(R) Core(TM) i3-8109U CPU @ 3.00GHz
                  Docker          : false
                  Virtualization  : lxc
                  Kernel          : x86_64
                  Userland        : 64 bit
                  Systemuptime and Load:
                   16:10:05 up 13 min,  1 user,  load average: 0.61, 0.97, 0.84
                  CPU threads: 1
                  *** LIFE CYCLE STATUS ***
                  *** TIME AND TIMEZONES ***
                                 Local time: Sun 2024-11-10 16:10:06 CET
                             Universal time: Sun 2024-11-10 15:10:06 UTC
                                   RTC time: n/a
                                NTP service: inactive
                            RTC in local TZ: no
                  *** Users and Groups ***
                  User that called 'iob diag':
                  christian
                  HOME=/home/christian
                  GROUPS=christian sudo iobroker
                  js-controller is not running
                  *** DISPLAY-SERVER SETUP ***
                  Desktop:
                  Terminal:
                  System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
                  *** MEMORY ***
                  Mem:           4.1G        262M        1.8G        0.0K        2.1G        3.8G
                  Swap:          512M        0.0K        511M
                  Total:         4.6G        262M        2.3G
                           4096 M total memory
                            262 M used memory
                            620 M active memory
                           1472 M inactive memory
                           1771 M free memory
                              0 M buffer memory
                           2062 M swap cache
                            512 M total swap
                              0 M used swap
                            511 M free swap
                  top - 16:10:06 up 13 min,  1 user,  load average: 0.61, 0.97, 0.84
                  Tasks:  28 total,   1 running,  27 sleeping,   0 stopped,   0 zombie
                  %Cpu(s):  5.3 us,  0.0 sy,  0.0 ni, 94.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                  MiB Mem :   4096.0 total,   1771.1 free,    262.3 used,   2062.6 buff/cache
                  MiB Swap:    512.0 total,    511.9 free,      0.1 used.   3833.7 avail Mem
                  *** FAILED SERVICES ***
                    UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
                  * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
                  * iobroker.service     loaded failed failed ioBroker Server
                  2 loaded units listed.
                  *** DMESG CRITICAL ERRORS ***
                  No critical errors detected
                  *** FILESYSTEM ***
                  Filesystem                       Type      Size  Used Avail Use% Mounted on
                  /dev/mapper/pve-vm--103--disk--0 ext4       30G  9.8G   19G  35% /
                  none                             tmpfs     492K  4.0K  488K   1% /dev
                  udev                             devtmpfs  7.8G     0  7.8G   0% /dev/tty
                  tmpfs                            tmpfs     7.8G     0  7.8G   0% /dev/shm
                  tmpfs                            tmpfs     1.6G  120K  1.6G   1% /run
                  tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
                  tmpfs                            tmpfs     7.8G     0  7.8G   0% /sys/fs/cgroup
                  [Fri Aug 23 12:19:21 2024] EXT4-fs (dm-1): mounted filesystem with ordered data mode. Opts: (null)
                  [Fri Aug 23 12:19:21 2024] EXT4-fs (dm-1): re-mounted. Opts: errors=remount-ro
                  [Fri Aug 23 12:19:33 2024] EXT4-fs warning (device dm-7): ext4_multi_mount_protect:322: MMP interval 42 higher than expected, please wait.
                  [Fri Aug 23 12:20:17 2024] EXT4-fs (dm-7): 4 orphan inodes deleted
                  [Fri Aug 23 12:20:17 2024] EXT4-fs (dm-7): recovery complete
                  [Fri Aug 23 12:20:17 2024] EXT4-fs (dm-7): mounted filesystem with ordered data mode. Opts: (null)
                  [Sun Nov 10 15:49:00 2024] EXT4-fs (dm-7): resizing filesystem from 2621440 to 7864320 blocks
                  [Sun Nov 10 15:49:00 2024] EXT4-fs (dm-7): resized filesystem to 7864320
                  [Sun Nov 10 15:52:09 2024] EXT4-fs (dm-7): mounted filesystem with ordered data mode. Opts: (null)
                  Show mounted filesystems:
                  TARGET                           SOURCE                                FSTYPE     OPTIONS
                  /                                /dev/mapper/pve-vm--103--disk--0      ext4       rw,relatime,stripe=16
                  |-/proc/cpuinfo                  lxcfs[/proc/cpuinfo]                  fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                  |-/proc/diskstats                lxcfs[/proc/diskstats]                fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                  |-/proc/loadavg                  lxcfs[/proc/loadavg]                  fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                  |-/proc/meminfo                  lxcfs[/proc/meminfo]                  fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                  |-/proc/stat                     lxcfs[/proc/stat]                     fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                  |-/proc/swaps                    lxcfs[/proc/swaps]                    fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                  |-/proc/uptime                   lxcfs[/proc/uptime]                   fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                  `-/sys/devices/system/cpu/online lxcfs[/sys/devices/system/cpu/online] fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                  /var:
                  1.8G    /var/
                  994M    /var/log
                  993M    /var/log/journal/b354c482f7cc342776f020ee5ea440c3
                  469M    /var/cache
                  Archived and active journals take up 8.0M in the file system.
                  /opt/iobroker/backups:
                  4.0K    /opt/iobroker/backups/
                  /opt/iobroker/iobroker-data:
                  775M    /opt/iobroker/iobroker-data/
                  617M    /opt/iobroker/iobroker-data/files
                  442M    /opt/iobroker/iobroker-data/files/javascript.admin
                  409M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                  408M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                  38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
                  27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
                  24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                  13M     /opt/iobroker/iobroker-data/objects.jsonl
                  9.2M    /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js
                  USB-Devices by-id:
                  No Devices found 'by-id'
                  *** NodeJS-Installation ***
                  /usr/bin/nodejs         v20.18.0
                  /usr/bin/node           v20.18.0
                  /usr/bin/npm            10.8.2
                  /usr/bin/npx            10.8.2
                  /usr/bin/corepack       0.29.3
                  nodejs:
                    Installed: 20.18.0-1nodesource1
                    Candidate: 20.18.0-1nodesource1
                    Version table:
                   *** 20.18.0-1nodesource1 1001
                          500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                       20.17.0-1nodesource1 1001
                       20.16.0-1nodesource1 1001
                       20.15.1-1nodesource1 1001
                       20.15.0-1nodesource1 1001
                       20.14.0-1nodesource1 1001
                       20.13.1-1nodesource1 1001
                       20.13.0-1nodesource1 1001
                       20.12.2-1nodesource1 1001
                       20.12.1-1nodesource1 1001
                       20.12.0-1nodesource1 1001
                       20.11.1-1nodesource1 1001
                       20.11.0-1nodesource1 1001
                       20.10.0-1nodesource1 1001
                       20.9.0-1nodesource1 1001
                       20.8.1-1nodesource1 1001
                       20.8.0-1nodesource1 1001
                       20.7.0-1nodesource1 1001
                       20.6.1-1nodesource1 1001
                       20.6.0-1nodesource1 1001
                       20.5.1-1nodesource1 1001
                       20.5.0-1nodesource1 1001
                       20.4.0-1nodesource1 1001
                       20.3.1-1nodesource1 1001
                       20.3.0-1nodesource1 1001
                       20.2.0-1nodesource1 1001
                       20.1.0-1nodesource1 1001
                       20.0.0-1nodesource1 1001
                       10.19.0~dfsg-3ubuntu1.6 500
                          500 http://archive.ubuntu.com/ubuntu focal-updates/universe amd64 Packages
                          500 http://archive.ubuntu.com/ubuntu focal-security/universe amd64 Packages
                       10.19.0~dfsg-3ubuntu1 500
                          500 http://archive.ubuntu.com/ubuntu focal/universe amd64 Packages
                  Temp directories causing deletion problem: 2
                  Errors in npm tree: 0
                  No problems detected
                  *** ioBroker-Installation ***
                  ioBroker Status
                  iobroker is not running on this host.
                  Objects type: jsonl
                  States  type: jsonl
                  Hosts:
                  ioBroker            ioBroker (version: 6.0.11, hostname: ioBroker      , alive, uptime: 76)
                  Core adapters versions
                  js-controller:  6.0.11
                  admin:          7.1.5
                  javascript:     8.8.3
                  nodejs modules from github:     0
                  Adapter State
                    system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
                    system.adapter.deconz.0                 : deconz                : ioBroker                                 -  enabled, port: 80
                    system.adapter.discovery.0              : discovery             : ioBroker                                 -  enabled
                    system.adapter.fb-checkpresence.0       : fb-checkpresence      : ioBroker                                 - disabled
                    system.adapter.history.0                : history               : ioBroker                                 -  enabled
                    system.adapter.ical.0                   : ical                  : ioBroker                                 -  enabled
                    system.adapter.info.0                   : info                  : ioBroker                                 -  enabled
                    system.adapter.iot.0                    : iot                   : ioBroker                                 -  enabled
                    system.adapter.jarvis.0                 : jarvis                : ioBroker                                 -  enabled
                    system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
                    system.adapter.mihome-vacuum.0          : mihome-vacuum         : ioBroker                                 -  enabled, port: 54321
                    system.adapter.sonoff.0                 : sonoff                : ioBroker                                 - disabled, port: 1883, bind: 0.0.0.0
                    system.adapter.spritmonitor.0           : spritmonitor          : ioBroker                                 -  enabled
                    system.adapter.tankerkoenig.0           : tankerkoenig          : ioBroker                                 -  enabled
                    system.adapter.telegram.0               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                    system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
                    system.adapter.wled.0                   : wled                  : ioBroker                                 -  enabled
                    system.adapter.yeelight-2.0             : yeelight-2            : ioBroker                                 -  enabled
                  + instance is alive
                  ioBroker-Repositories
                  Active repo(s): stable
                  Installed ioBroker-Instances
                  Used repository: stable
                  Adapter    "admin"        : 7.1.5    , installed 7.1.5
                  Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
                  Adapter    "deconz"       : 1.4.1    , installed 2.0.5
                  Adapter    "fb-checkpresence": 1.2.5 , installed 1.2.4  [Updatable]
                  Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
                  Adapter    "ical"         : 1.15.0   , installed 1.15.0
                  Adapter    "iot"          : 3.3.0    , installed 3.3.0
                  Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
                  Adapter    "javascript"   : 8.8.3    , installed 8.8.3
                  Controller "js-controller": 6.0.11   , installed 6.0.11
                  Adapter    "mihome-vacuum": 4.2.0    , installed 4.2.0
                  Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
                  Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
                  Adapter    "telegram"     : 3.9.0    , installed 3.9.0
                  Adapter    "trashschedule": 3.3.0    , installed 3.3.0
                  Adapter    "web"          : 6.2.5    , installed 6.2.5
                  Adapter    "wled"         : 0.7.2    , installed 0.7.2
                  Adapter    "yeelight-2"   : 1.4.0    , installed 1.4.0
                  Objects and States
                  Objects:        5443
                  States:         4330
                  Hit:1 http://archive.ubuntu.com/ubuntu focal InRelease
                  Hit:2 http://archive.ubuntu.com/ubuntu focal-updates InRelease
                  Hit:3 http://archive.ubuntu.com/ubuntu focal-security InRelease
                  Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
                  Reading package lists...
                  Pending Updates: 0
                  *** Listening Ports ***
                  tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          145815074  301/master
                  tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          145808348  1/systemd
                  tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      106        145837324  9263/systemd-resolv
                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          145814728  133/sshd: /usr/sbin
                  tcp6       0      0 ::1:25                  :::*                    LISTEN      0          145815075  301/master
                  tcp6       0      0 :::111                  :::*                    LISTEN      0          145808350  1/systemd
                  tcp6       0      0 :::22                   :::*                    LISTEN      0          145814739  133/sshd: /usr/sbin
                  udp        0      0 127.0.0.53:53           0.0.0.0:*                           106        145837323  9263/systemd-resolv
                  udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          145808349  1/systemd
                  udp6       0      0 :::111                  :::*                                0          145808351  1/systemd
                  2024-11-10 16:07:35.028  - info: host.ioBroker instance system.adapter.wled.0 terminated with code 0 (NO_ERROR)
                  2024-11-10 16:07:35.028  - info: host.ioBroker instance system.adapter.spritmonitor.0 terminated with code 0 (NO_ERROR)
                  2024-11-10 16:07:35.107  - info: host.ioBroker instance system.adapter.yeelight-2.0 terminated with code 0 (NO_ERROR)
                  2024-11-10 16:07:35.107  - error: host.ioBroker Caught by controller[0]: /bin/sh: 1: hcitool: not found
                  2024-11-10 16:07:35.107  - info: host.ioBroker instance system.adapter.info.0 terminated with code 0 (NO_ERROR)
                  2024-11-10 16:07:35.108  - info: host.ioBroker instance system.adapter.jarvis.0 terminated with code 0 (NO_ERROR)
                  2024-11-10 16:07:35.108  - info: host.ioBroker stopInstance timeout system.adapter.telegram.0 killing pid 17273
                  2024-11-10 16:07:35.112  - info: host.ioBroker stopInstance timeout system.adapter.web.0 killing pid 17549
                  2024-11-10 16:07:35.137  - error: host.ioBroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                  2024-11-10 16:07:35.137  - error: host.ioBroker Caught by controller[0]: Error: Model yeelink.light.color2 is not supported
                  2024-11-10 16:07:35.137  - error: host.ioBroker Caught by controller[0]:     at Object.createDevice [as device] (/opt/iobroker/node_modules/@iobroker-javascript.0/node-mihome/lib/device.js:8:11)
                  2024-11-10 16:07:35.137  - error: host.ioBroker Caught by controller[0]:     at CreateDevices (script.js.Sonstiges.AllMyMi:936:36)
                  2024-11-10 16:07:35.137  - error: host.ioBroker Caught by controller[0]:     at runNextTicks (node:internal/process/task_queues:60:5)
                  2024-11-10 16:07:35.137  - error: host.ioBroker Caught by controller[0]:     at listOnTimeout (node:internal/timers:538:9)
                  2024-11-10 16:07:35.137  - error: host.ioBroker Caught by controller[0]:     at processTimers (node:internal/timers:512:7)
                  2024-11-10 16:07:35.137  - error: host.ioBroker Caught by controller[0]:     at main (script.js.Sonstiges.AllMyMi:868:5)
                  2024-11-10 16:07:35.137  - info: host.ioBroker instance system.adapter.javascript.0 terminated with code 0 (NO_ERROR)
                  2024-11-10 16:07:35.137  - info: host.ioBroker All instances are stopped.
                  2024-11-10 16:07:35.178  - warn: host.ioBroker instance system.adapter.telegram.0 terminated due to SIGKILL
                  2024-11-10 16:07:35.178  - info: host.ioBroker instance system.adapter.telegram.0 terminated with code null ()
                  2024-11-10 16:07:35.178  - info: host.ioBroker All instances are stopped.
                  2024-11-10 16:07:35.178  - warn: host.ioBroker instance system.adapter.web.0 terminated due to SIGKILL
                  2024-11-10 16:07:35.178  - info: host.ioBroker instance system.adapter.web.0 terminated with code null ()
                  2024-11-10 16:07:35.373  - info: host.ioBroker terminated
                  • B Bielefelder81
                    @thomas-braun ```
                    Script v.2024-10-19
                    *** BASE SYSTEM ***
                               Chassis: container
                        Virtualization: lxc
                    Docker          : false
                    Kernel          : x86_64
                    Userland        : 64 bit
                    CPU threads: 1
                                     RTC time: n/a
                              RTC in local TZ: no
                    christian
                    Desktop:
                    Terminal:
                    *** MEMORY ***
                             4096 M total memory
                              262 M used memory
                              620 M active memory
                             1771 M free memory
                                0 M buffer memory
                             2062 M swap cache
                              512 M total swap
                                0 M used swap
                              511 M free swap
                    *** FILESYSTEM ***
                    /var:
                    1.8G    /var/
                    994M    /var/log
                    469M    /var/cache
                    USB-Devices by-id:
                    /usr/bin/npm            10.8.2
                    /usr/bin/npx            10.8.2
                    nodejs:
                      Version table:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    Hosts:
                    admin:          7.1.5
                    javascript:     8.8.3
                    Adapter State
                    + instance is alive
                    Objects and States
                    Objects:        5443
                    States:         4330
                    Pending Updates: 0
                    • iobroker.service loaded failed failed ioBroker Server
                    Da wird der Service nicht gestartet.
                    systemctl status iobroker.service
                    anschauen.
                    Auf dem Dateisystem ist auch was schief:
                    Da 'focal' ohnehin in absehbarer Zeit abgekündigt werden wird: Pack ein Backup ein und zieh damit in ein frisches System um.
                      anschauen.
                      Bielefelder81
                      christian@ioBroker:~$ iob start
                      christian@ioBroker:~$ systemctl status iobroker.service
                      * iobroker.service - ioBroker Server
                           Loaded: loaded (/lib/systemd/system/iobroker.service; enabled; vendor preset: enabled)
                           Active: active (running) since Sun 2024-11-10 16:13:56 CET; 9min ago
                             Docs: http://iobroker.net
                         Main PID: 20605 (iobroker.js-con)
                            Tasks: 209 (limit: 4915)
                           Memory: 1.2G
                           CGroup: /system.slice/iobroker.service
                                   |-20605 iobroker.js-controller
                                   |-20626 io.admin.0
                                   |-20681 io.javascript.0
                                   |-20706 io.telegram.0
                                   |-20747 io.history.0
                                   |-20773 io.alexa2.0
                                   |-20803 io.mihome-vacuum.0
                                   |-20818 io.yeelight-2.0
                                   |-20833 io.deconz.0
                                   |-20872 io.discovery.0
                                   |-20887 io.info.0
                                   |-21235 io.iot.0
                                   |-21250 io.tankerkoenig.0
                                   |-21265 io.web.0
                                   |-21280 io.jarvis.0
                                   |-21295 io.trashschedule.0
                                   |-21310 io.wled.0
                                   |-21325 io.spritmonitor.0
                                   `-21406 io.fb-checkpresence.0
                      christian@ioBroker:~$ iob fix
                      Your system is booting into 'graphical.target', which means that a user interface or desktop is available. Usually a server is running without a desktop to have more RAM available. Do you want to switch to 'multi-user.target'? (y/N)
                      library: loaded
                      Library version=2024-10-22
                          Welcome to the ioBroker installation fixer!
                          Script version: 2024-10-22
                          You might need to enter your password a couple of times.
                          Installing prerequisites (1/5)
                      0% [Working]
                      Hit:1 https://deb.nodesource.com/node_20.x nodistro InRelease
                      Hit:2 http://archive.ubuntu.com/ubuntu focal InRelease
                      Hit:3 http://archive.ubuntu.com/ubuntu focal-updates InRelease
                      Hit:4 http://archive.ubuntu.com/ubuntu focal-security InRelease
                      Reading package lists... Done
                      E: Unable to locate package polkitd
                      Installed polkitd
                          Checking ioBroker user and directory permissions (2/5)
                          Check and cleanup npm temporary directories (3/5)
                      Done.
                          Database maintenance (4/5)
                      Checking for uncompressed JSONL databases... This might take a while!
                      Compressing /opt/iobroker/iobroker-data/states.jsonl
                      Compressing /opt/iobroker/iobroker-data/objects.jsonl
                      Compressed 2 JSONL files. Done
                          Checking autostart (5/5)
                      Enabling autostart...
                      Autostart enabled!
                          Your installation was fixed successfully
                          Run iobroker start to start ioBroker again!
