  4. Update geht nicht mehr
10 Beiträge 4 Kommentatoren 1.1k Aufrufe 3 Beobachtet
  • E Offline
    eubecker
    Moin, ioBroker meinte, ich solle js-controller updaten (6.0.9 auf 6.0.11) auf raspi
    1. Versuch über die Admin-Oberfläche liefert ein
      "SyntaxError: JSON.parse: unexpected character at line 1 column 1 of the JSON data"
    2. Versuch für komplettes Update auf der Console
    cd /opt/iobroker;iob backup;iob stop;iob update;iob fix;iob upgrade self;iob start
    Läuft bis zum update, aber bei fix nicht mehr:
    me@pi:/opt/iobroker $iob fix
    library: loaded
    Library version=2024-10-22
        Welcome to the ioBroker installation fixer!
        Script version: 2024-10-22
        You might need to enter your password a couple of times.
        Installing prerequisites (1/5)
    Hit:1 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:2 http://deb.debian.org/debian bookworm InRelease
    Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists... Done
        Checking ioBroker user and directory permissions (2/5)
    chown: cannot read directory '/home/iobroker/.npm/_cacache/content-v2/sha512/ea/0b': Bad message
    chown: cannot read directory '/home/iobroker/.npm/_cacache/content-v2/sha512/3d/1a': Bad message
    chown: cannot read directory '/home/iobroker/.npm/_cacache/content-v2/sha512/3b/ae': Bad message
    This system does not support setting default permissions.
    Do not use npm to manually install adapters unless you know what you are doing!
        Check and cleanup npm temporary directories (3/5)
    Done.
        Database maintenance (4/5)
    Checking for uncompressed JSONL databases... This might take a while!
    /usr/lib/node_modules/npm/lib/cli/validate-engines.js:31
        throw err
    Error: Cannot find module 'graceful-fs'
    Require stack:
    - /usr/lib/node_modules/npm/lib/cli/entry.js
    - /usr/lib/node_modules/npm/lib/cli.js
    - /usr/lib/node_modules/npm/bin/npm-cli.js
        at Module._resolveFilename (node:internal/modules/cjs/loader:1225:15)
        at Module._load (node:internal/modules/cjs/loader:1051:27)
        at Module.require (node:internal/modules/cjs/loader:1311:19)
        at require (node:internal/modules/helpers:179:18)
        at module.exports (/usr/lib/node_modules/npm/lib/cli/entry.js:15:3)
        at module.exports (/usr/lib/node_modules/npm/lib/cli/validate-engines.js:39:10)
        at module.exports (/usr/lib/node_modules/npm/lib/cli.js:4:31)
        at Object.<anonymous> (/usr/lib/node_modules/npm/bin/npm-cli.js:2:25)
        at Module._compile (node:internal/modules/cjs/loader:1469:14)
        at Module._extensions..js (node:internal/modules/cjs/loader:1548:10) {
      code: 'MODULE_NOT_FOUND',
      requireStack: [
        '/usr/lib/node_modules/npm/lib/cli/entry.js',
        '/usr/lib/node_modules/npm/lib/cli.js',
        '/usr/lib/node_modules/npm/bin/npm-cli.js'
    Node.js v20.17.0
    /home/iobroker/.fix.sh: line 14: [: -lt: unary operator expected
        throw err
    Require stack:
      requireStack: [
    Node.js v20.17.0
        Checking autostart (5/5)
    ==== AUTHENTICATING FOR org.freedesktop.systemd1.manage-units ====
    Authentication is required to stop 'iobroker.service'.
    Authenticating as: ,,, (me)
    Password: polkit-agent-helper-1: pam_authenticate failed: Authentication failure
    Enabling autostart...
    Autostart enabled!
        Your installation was fixed successfully
        Run iobroker start to start ioBroker again!
    Wenn ich den Tipp versuche, der angezeigt wird:
    npm install -g npm@latest
    Bekomme ich auch nur den Fehler:
        throw err
    Require stack:
      requireStack: [
    Node.js v20.17.0
    Jemand ne Idee, was hier los ist? ioBroker läuft augenscheinlich noch, nur Updaten is nicht und das macht mir Angst.
    wendy2702W Thomas BraunT 2 Antworten Letzte Antwort
    • E eubecker
      library: loaded
      Done.
          throw err
      Require stack:
        requireStack: [
      Node.js v20.17.0
          throw err
      Require stack:
        requireStack: [
      Node.js v20.17.0
      Autostart enabled!
          throw err
      Require stack:
        requireStack: [
      Node.js v20.17.0
      wendy2702W Online
      wendy2702W Online
      @eubecker poste mal die Ausgabe von
      iob diag
      • E eubecker
        library: loaded
        Done.
            throw err
        Require stack:
          requireStack: [
        Node.js v20.17.0
            throw err
        Require stack:
          requireStack: [
        Node.js v20.17.0
        Autostart enabled!
            throw err
        Require stack:
          requireStack: [
        Node.js v20.17.0
        @eubecker
        iob stop
        sudo apt update
        sudo apt full-upgrade
        iob nodejs-update
        E 1 Antwort Letzte Antwort
          @eubecker
          iob stop
          sudo apt update
          iob nodejs-update
          eubecker
          So, einen Schritt weiter. SD-Karte hatten einen Schlag weg.
          Neue Karte Backup drauf, nun bekomme ich immerhin eine neue Meldung, wenn ich über die Admin-Oberfläche JS updaten will:
          npm error code MODULE_NOT_FOUND
          npm error Cannot find module '@isaacs/string-locale-compare'
          npm error Require stack:
          npm error - /usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/add-rm-pkg-deps.js
          npm error - /usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/index.js
          npm error - /usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/index.js
          npm error - /usr/lib/node_modules/npm/node_modules/libnpmfund/lib/index.js
          npm error - /usr/lib/node_modules/npm/lib/utils/reify-output.js
          npm error - /usr/lib/node_modules/npm/lib/utils/reify-finish.js
          npm error - /usr/lib/node_modules/npm/lib/commands/install.js
          npm error - /usr/lib/node_modules/npm/lib/npm.js
          npm error - /usr/lib/node_modules/npm/lib/cli/entry.js
          npm error - /usr/lib/node_modules/npm/lib/cli.js
          npm error - /usr/lib/node_modules/npm/bin/npm-cli.js
          npm error A complete log of this run can be found in: /root/.npm/_logs/2024-11-09T22_30_55_108Z-debug-0.log
          Could not install js-controller@6.0.11
          Und das erwähnte Log:
           verbose cli /usr/bin/node /usr/bin/npm
          1 info using npm@10.8.2
          2 info using node@v20.17.0
          3 silly config load:file:/usr/lib/node_modules/npm/npmrc
          4 silly config load:file:/opt/iobroker/.npmrc
          5 silly config load:file:/root/.npmrc
          6 silly config load:file:/usr/etc/npmrc
          7 verbose title npm install iobroker.js-controller@6.0.11
          8 verbose argv "install" "--save-exact" "iobroker.js-controller@6.0.11" "--foreground-scripts"
          9 verbose logfile logs-max:10 dir:/root/.npm/_logs/2024-11-09T22_30_55_108Z-
          10 verbose logfile /root/.npm/_logs/2024-11-09T22_30_55_108Z-debug-0.log
          11 silly logfile done cleaning log files
          12 verbose stack Error: Cannot find module '@isaacs/string-locale-compare'
          12 verbose stack Require stack:
          12 verbose stack - /usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/add-rm-pkg-deps.js
          12 verbose stack - /usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/index.js
          12 verbose stack - /usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/index.js
          12 verbose stack - /usr/lib/node_modules/npm/node_modules/libnpmfund/lib/index.js
          12 verbose stack - /usr/lib/node_modules/npm/lib/utils/reify-output.js
          12 verbose stack - /usr/lib/node_modules/npm/lib/utils/reify-finish.js
          12 verbose stack - /usr/lib/node_modules/npm/lib/commands/install.js
          12 verbose stack - /usr/lib/node_modules/npm/lib/npm.js
          12 verbose stack - /usr/lib/node_modules/npm/lib/cli/entry.js
          12 verbose stack - /usr/lib/node_modules/npm/lib/cli.js
          12 verbose stack - /usr/lib/node_modules/npm/bin/npm-cli.js
          12 verbose stack     at Module._resolveFilename (node:internal/modules/cjs/loader:1225:15)
          12 verbose stack     at Module._load (node:internal/modules/cjs/loader:1051:27)
          12 verbose stack     at Module.require (node:internal/modules/cjs/loader:1311:19)
          12 verbose stack     at require (node:internal/modules/helpers:179:18)
          12 verbose stack     at Object.<anonymous> (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/add-rm-pkg-deps.js:4:23)
          12 verbose stack     at Module._compile (node:internal/modules/cjs/loader:1469:14)
          12 verbose stack     at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
          12 verbose stack     at Module.load (node:internal/modules/cjs/loader:1288:32)
          12 verbose stack     at Module._load (node:internal/modules/cjs/loader:1104:12)
          13 error code MODULE_NOT_FOUND
          14 error Cannot find module '@isaacs/string-locale-compare'
          14 error Require stack:
          14 error - /usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/add-rm-pkg-deps.js
          14 error - /usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/index.js
          14 error - /usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/index.js
          14 error - /usr/lib/node_modules/npm/node_modules/libnpmfund/lib/index.js
          14 error - /usr/lib/node_modules/npm/lib/utils/reify-output.js
          14 error - /usr/lib/node_modules/npm/lib/utils/reify-finish.js
          14 error - /usr/lib/node_modules/npm/lib/commands/install.js
          14 error - /usr/lib/node_modules/npm/lib/npm.js
          14 error - /usr/lib/node_modules/npm/lib/cli/entry.js
          14 error - /usr/lib/node_modules/npm/lib/cli.js
          14 error - /usr/lib/node_modules/npm/bin/npm-cli.js
          15 verbose cwd /opt/iobroker
          16 verbose os Linux 6.6.31+rpt-rpi-v8
          17 verbose node v20.17.0
          18 verbose npm  v10.8.2
          19 verbose exit 1
          20 verbose code 1
          21 error A complete log of this run can be found in: /root/.npm/_logs/2024-11-09T22_30_55_108Z-debug-0.log
          Jemand Vorschläge? Doch auf der Console updaten?
          • E eubecker
            19 verbose exit 1
            20 verbose code 1
            @eubecker sagte in Update geht nicht mehr:
            Das sowieso. Und HAMPEL da nicht als root umher...
            iob stop
            iob fix
            iob start
            Und die Langfassung von
            iob diag
              iob stop
              iob fix
              iob start
              iob diag
              eubecker
              @thomas-braun said in Update geht nicht mehr:
              Hab ich bisher vermieden :-)
              iob diag
              Mach ich. Steht da eigentlich was "geheimes" drin, was man nicht posten sollte?
              • E eubecker
                iob diag
                HomoranH Offline
                HomoranH Offline
                höchstens in den letzten Zeilen im log.
                Dort bitte persönliche Daten entfernen.
                Dazu gehören nicht interne IPs
                • E eubecker
                  iob diag
                  Kannst es ja vor dem posten lesen...
                  Im letzten Block mit den 25 letzten Zeilen aus dem iobroker.log könnten schon mal persönliche Daten stehen. Alles andere bezieht sich auf die Konfiguration des Rechners bzw. des ioBrokers, das ist nichts 'geheimes'.
                  Auch IP-Adressen sind nicht 'geheim'. Auf lokale/private IPs kann von außen nicht zugegriffen werden und öffentliche IPs sind eh öffentlich.
                    eubecker
                    schrieb am zuletzt editiert von eubecker
                    So iob fix liefer die gleichen Meckermeldung bzgl.
                    wie über die Oberfläche.
                    diag liefert:
                    Script v.2024-10-19
                    *** BASE SYSTEM ***
                     Static hostname: pi4wz
                           Icon name: computer
                              Kernel: Linux 6.6.31+rpt-rpi-v8
                        Architecture: arm64
                    OS is similar to:
                    Model           : Raspberry Pi 4 Model B Rev 1.5
                    Docker          : false
                    Virtualization  : none
                    Kernel          : aarch64
                    Userland        : 64 bit
                    Systemuptime and Load:
                     10:49:41 up 11:22,  2 users,  load average: 0.17, 0.25, 0.32
                    CPU threads: 4
                    *** LIFE CYCLE STATUS ***
                    Operating System is the current Debian stable version codenamed 'bookworm'!
                    *** RASPBERRY THROTTLING ***
                    Current issues:
                    Previously detected issues:
                    *** TIME AND TIMEZONES ***
                                   Local time: Sun 2024-11-10 10:49:41 CET
                               Universal time: Sun 2024-11-10 09:49:41 UTC
                                     RTC time: n/a
                                  NTP service: active
                              RTC in local TZ: no
                    *** Users and Groups ***
                    User that called 'iob diag':
                    eckhard
                    HOME=/home/eckhard
                    GROUPS=eckhard adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                    iobroker
                    HOME=/home/iobroker
                    *** DISPLAY-SERVER SETUP ***
                    Display-Server: false
                    Desktop:
                    Terminal:       tty
                    *** MEMORY ***
                    Mem:            4.0G        1.7G        849M         11M        1.6G        2.3G
                    Swap:           209M          0B        209M
                    Total:          4.2G        1.7G        1.1G
                    Active iob-Instances:   26
                             3792 M total memory
                             1579 M used memory
                             1675 M active memory
                             1067 M inactive memory
                              810 M free memory
                              113 M buffer memory
                             1376 M swap cache
                              199 M total swap
                                0 M used swap
                              199 M free swap
                    top - 10:49:42 up 11:22,  2 users,  load average: 0.17, 0.25, 0.32
                    Tasks: 213 total,   1 running, 212 sleeping,   0 stopped,   0 zombie
                    %Cpu(s):  0.0 us, 25.0 sy,  0.0 ni, 75.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                    MiB Mem :   3792.1 total,    809.6 free,   1580.0 used,   1489.5 buff/cache
                    MiB Swap:    200.0 total,    200.0 free,      0.0 used.   2212.1 avail Mem
                    *** FAILED SERVICES ***
                    0 loaded units listed.
                    *** DMESG CRITICAL ERRORS ***
                    50 CRITICAL ERRORS DETECTED!
                    Check 'sudo dmesg --level=emerg,alert,crit -T' for details
                    *** FILESYSTEM ***
                    Filesystem                        Type      Size  Used Avail Use% Mounted on
                    udev                              devtmpfs  1.6G     0  1.6G   0% /dev
                    tmpfs                             tmpfs     380M  1.3M  378M   1% /run
                    /dev/mmcblk0p2                    ext4       14G  9.8G  3.3G  75% /
                    tmpfs                             tmpfs     1.9G  7.7M  1.9G   1% /dev/shm
                    tmpfs                             tmpfs     5.0M   16K  5.0M   1% /run/lock
                    tmpfs                             tmpfs     250M     0  250M   0% /mnt/ramdisk
                    /dev/mmcblk0p1                    vfat      510M   75M  436M  15% /boot/firmware
                    192.168.178.20:/volume1/NetBackup nfs        11T  4.9T  5.7T  46% /NetBackup
                    tmpfs                             tmpfs     380M   36K  380M   1% /run/user/1000
                    [Sat Nov  9 23:27:17 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:B8:81:3E vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=c5609fe2-02 rootfstype=ext4 fsck.repair=yes rootwait
                    [Sat Nov  9 23:27:24 2024] EXT4-fs (mmcblk0p2): mounted filesystem 12974fe2-889e-4060-b497-1d6ac3fbbb4b ro with ordered data mode. Quota mode: none.
                    [Sat Nov  9 23:27:28 2024] EXT4-fs (mmcblk0p2): re-mounted 12974fe2-889e-4060-b497-1d6ac3fbbb4b r/w. Quota mode: none.
                    [Sat Nov  9 23:29:28 2024] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1693: inode #261468: comm npm install @io: checksumming directory block 0
                    [Sat Nov  9 23:29:32 2024] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1693: inode #261468: comm npm install @io: checksumming directory block 0
                    [Sat Nov  9 23:30:54 2024] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1693: inode #261468: comm npm install iob: checksumming directory block 0
                    [Sat Nov  9 23:31:20 2024] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1693: inode #261468: comm npm install @io: checksumming directory block 0
                    [Sat Nov  9 23:31:21 2024] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1693: inode #261468: comm npm install @io: checksumming directory block 0
                    [Sun Nov 10 09:59:32 2024] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1693: inode #261468: comm npm x @iobroker: checksumming directory block 0
                    [Sun Nov 10 10:10:51 2024] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1693: inode #261468: comm npm ls: checksumming directory block 0
                    [Sun Nov 10 10:13:59 2024] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1693: inode #261468: comm npm install @io: checksumming directory block 0
                    [Sun Nov 10 10:14:00 2024] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1693: inode #261468: comm npm install @io: checksumming directory block 0
                    [Sun Nov 10 10:16:13 2024] EXT4-fs error (device mmcblk0p2): __ext4_find_entry:1693: inode #261468: comm npm ls: checksumming directory block 0
                    Show mounted filesystems:
                    TARGET           SOURCE                            FSTYPE OPTIONS
                    /                /dev/mmcblk0p2                    ext4   rw,noatime,commit=600
                    |-/boot/firmware /dev/mmcblk0p1                    vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                    `-/NetBackup     192.168.178.20:/volume1/NetBackup nfs    rw,relatime,vers=3,rsize=131072,wsize=131072,namlen=255,hard,proto=tcp,timeo=600,retrans=2,sec=sys,mountaddr=192.168.178.20,mountvers=3,mountport=892,mountproto=udp,local_lock=none,addr=192.168.178.20
                    /var:
                    1.2G    /var/
                    611M    /var/cache
                    604M    /var/cache/apt
                    492M    /var/cache/apt/archives
                    194M    /var/lib
                    Archived and active journals take up 131.6M in the file system.
                    /opt/iobroker/backups:
                    70M     /opt/iobroker/backups/
                    /opt/iobroker/iobroker-data:
                    1.2G    /opt/iobroker/iobroker-data/
                    1.1G    /opt/iobroker/iobroker-data/files
                    617M    /opt/iobroker/iobroker-data/files/javascript.admin
                    560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                    558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                    38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
                    26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
                    26M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
                    25M     /opt/iobroker/iobroker-data/objects.jsonl
                    24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                    USB-Devices by-id:
                    No Devices found 'by-id'
                    *** NodeJS-Installation ***
                    /usr/bin/nodejs         v20.17.0
                    /usr/bin/node           v20.17.0
                    /usr/bin/npm            10.8.2
                    /usr/bin/npx            10.8.2
                    /usr/bin/corepack       0.29.3
                    nodejs:
                      Installed: 20.17.0-1nodesource1
                      Candidate: 20.18.0-1nodesource1
                      Version table:
                         20.18.0-1nodesource1 600
                            500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                     *** 20.17.0-1nodesource1 600
                         20.16.0-1nodesource1 600
                         20.15.1-1nodesource1 600
                         20.15.0-1nodesource1 600
                         20.14.0-1nodesource1 600
                         20.13.1-1nodesource1 600
                         20.13.0-1nodesource1 600
                         20.12.2-1nodesource1 600
                         20.12.1-1nodesource1 600
                         20.12.0-1nodesource1 600
                         20.11.1-1nodesource1 600
                         20.11.0-1nodesource1 600
                         20.10.0-1nodesource1 600
                         20.9.0-1nodesource1 600
                         20.8.1-1nodesource1 600
                         20.8.0-1nodesource1 600
                         20.7.0-1nodesource1 600
                         20.6.1-1nodesource1 600
                         20.6.0-1nodesource1 600
                         20.5.1-1nodesource1 600
                         20.5.0-1nodesource1 600
                         20.4.0-1nodesource1 600
                         20.3.1-1nodesource1 600
                         20.3.0-1nodesource1 600
                         20.2.0-1nodesource1 600
                         20.1.0-1nodesource1 600
                         20.0.0-1nodesource1 600
                         18.19.0+dfsg-6~deb12u2 500
                            500 http://deb.debian.org/debian bookworm/main arm64 Packages
                         18.19.0+dfsg-6~deb12u1 500
                            500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
                    No problems detected
                    Errors in npm tree: 0
                    *** ioBroker-Installation ***
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    Hosts:
                    pi4wz               pi4wz (version: 6.0.9, hostname: pi4wz         , alive, uptime: 2163)
                    Core adapters versions
                    js-controller:  6.0.9
                    admin:          7.1.5
                    javascript:     8.8.3
                    nodejs modules from github:     0
                    Adapter State
                    + system.adapter.admin.0                  : admin                 : pi4wz                                    -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                    + system.adapter.admin.1                  : admin                 : pi4wz                                    -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                    + system.adapter.alexa2.0                 : alexa2                : pi4wz                                    -  enabled
                      system.adapter.alias-manager.0          : alias-manager         : pi4wz                                    - disabled
                    + system.adapter.backitup.0               : backitup              : pi4wz                                    -  enabled
                    + system.adapter.discovery.0              : discovery             : pi4wz                                    -  enabled
                    + system.adapter.echarts.0                : echarts               : pi4wz                                    -  enabled
                    + system.adapter.email.0                  : email                 : pi4wz                                    -  enabled
                    + system.adapter.fb-checkpresence.0       : fb-checkpresence      : pi4wz                                    -  enabled
                    + system.adapter.history.0                : history               : pi4wz                                    -  enabled
                    + system.adapter.hm-rega.0                : hm-rega               : pi4wz                                    -  enabled
                    + system.adapter.hm-rpc.0                 : hm-rpc                : pi4wz                                    -  enabled, port: 0
                    + system.adapter.hm-rpc.1                 : hm-rpc                : pi4wz                                    -  enabled, port: 0
                      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : pi4wz                                    - disabled
                      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : pi4wz                                    - disabled
                    + system.adapter.iot.0                    : iot                   : pi4wz                                    -  enabled
                    + system.adapter.javascript.0             : javascript            : pi4wz                                    -  enabled
                    + system.adapter.mqtt.0                   : mqtt                  : pi4wz                                    -  enabled, port: 1882, bind: 0.0.0.0
                    + system.adapter.parser.0                 : parser                : pi4wz                                    -  enabled
                    + system.adapter.ping.0                   : ping                  : pi4wz                                    -  enabled
                    + system.adapter.radar2.0                 : radar2                : pi4wz                                    -  enabled
                    + system.adapter.rpi2.0                   : rpi2                  : pi4wz                                    -  enabled
                      system.adapter.shelly.0                 : shelly                : pi4wz                                    - disabled, port: 1882, bind: 0.0.0.0
                    + system.adapter.signal-cmb.0             : signal-cmb            : pi4wz                                    -  enabled
                    + system.adapter.simple-api.0             : simple-api            : pi4wz                                    -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                    + system.adapter.socketio.0               : socketio              : pi4wz                                    -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                    + system.adapter.sonoff.0                 : sonoff                : pi4wz                                    -  enabled, port: 64972, bind: 192.168.178.45
                    + system.adapter.vis-2.0                  : vis-2                 : pi4wz                                    -  enabled
                      system.adapter.vis-history.0            : vis-history           : pi4wz                                    - disabled
                      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : pi4wz                                    - disabled
                      system.adapter.vis-material-advanced.0  : vis-material-advanced : pi4wz                                    - disabled
                      system.adapter.vis.0                    : vis                   : pi4wz                                    - disabled
                    + system.adapter.web.0                    : web                   : pi4wz                                    -  enabled, port: 8083, bind: 0.0.0.0, run as: admin
                    + instance is alive
                    ioBroker-Repositories
                    │ (index) │ name               │ url        │ auto upgrade │
                    │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'                                            │ false        │
                    │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json'                                     │ false        │
                    │ 2       │ 'sources'          │ 'conf/sources-dist.json'        │ false        │
                    │ 3       │ 'online'           │ 'https://raw.githubusercontent.com/ioBroker/ioBroker.repositories/master/sources-dist.json' │ false        │
                    │ 4       │ 'vuplus'           │ 'https://github.com/vader722/ioBroker.vuplus'                                               │ false        │
                    Upgrade policy: none
                    Installed ioBroker-Instances
                    Adapter    "admin"        : 7.1.5    , installed 7.1.5
                    Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
                    Adapter    "alias-manager": 1.2.6    , installed 1.2.6
                    Adapter    "backitup"     : 3.0.25   , installed 3.0.25
                    Adapter    "echarts"      : 1.9.2    , installed 1.9.2
                    Adapter    "email"        : 1.3.1    , installed 1.3.1
                    Adapter    "fb-checkpresence": 1.2.5 , installed 1.2.5
                    Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
                    Adapter    "iot"          : 3.3.0    , installed 3.3.0
                    Adapter    "javascript"   : 8.8.3    , installed 8.8.3
                    Controller "js-controller": 6.0.11   , installed 6.0.9  [Updatable]
                    Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
                    Adapter    "parser"       : 2.2.4    , installed 2.2.4
                    Adapter    "radar2"       : 2.2.0    , installed 2.2.0
                    Adapter    "rpi2"         : 2.2.1    , installed 1.3.2  [Updatable]
                    Adapter    "shelly"       : 8.2.1    , installed 8.2.1
                    Adapter    "signal-cmb"   : 0.3.0    , installed 0.3.0
                    Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
                    Adapter    "vis-2"        : 2.9.64   , installed 2.9.32 [Updatable]
                    Adapter    "web"          : 6.2.5    , installed 6.2.5
                    Objects and States
                    Objects:        7578
                    States:         5803
                    Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
                    Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
                    Pending Updates: 138
                    *** Listening Ports ***
                    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          6607       1/init
                    tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          7844       881/lighttpd
                    tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      999        8472       854/pihole-FTL
                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          2615       755/sshd: /usr/sbin
                    tcp        0      0 127.0.0.1:6010          0.0.0.0:*               LISTEN      1000       361740     43946/sshd: eckhard
                    tcp        0      0 0.0.0.0:58523           0.0.0.0:*               LISTEN      103        8384       858/rpc.statd
                    tcp        0      0 192.168.178.45:2001     0.0.0.0:*               LISTEN      1001       377030     46699/io.hm-rpc.0
                    tcp        0      0 0.0.0.0:34207           0.0.0.0:*               LISTEN      0          2732       -
                    tcp        0      0 192.168.178.45:42010    0.0.0.0:*               LISTEN      1001       378082     46716/io.hm-rpc.1
                    tcp        0      0 127.0.0.1:4711          0.0.0.0:*               LISTEN      999        8478       854/pihole-FTL
                    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          46166      5166/cupsd
                    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       378103     46734/io.mqtt.0
                    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       375633     46461/iobroker.js-c
                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       375628     46461/iobroker.js-c
                    tcp        0      0 192.168.178.45:64972    0.0.0.0:*               LISTEN      1001       378286     46863/io.sonoff.0
                    tcp6       0      0 :::111                  :::*                    LISTEN      0          7776       1/init
                    tcp6       0      0 :::80                   :::*                    LISTEN      0          7843       881/lighttpd
                    tcp6       0      0 :::53                   :::*                    LISTEN      999        8474       854/pihole-FTL
                    tcp6       0      0 :::22                   :::*                    LISTEN      0          2617       755/sshd: /usr/sbin
                    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          46165      5166/cupsd
                    tcp6       0      0 ::1:4711                :::*                    LISTEN      999        8479       854/pihole-FTL
                    tcp6       0      0 :::44085                :::*                    LISTEN      0          2735       -
                    tcp6       0      0 :::50311                :::*                    LISTEN      103        8390       858/rpc.statd
                    tcp6       0      0 ::1:6010                :::*                    LISTEN      1000       361739     43946/sshd: eckhard
                    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       375690     46481/io.admin.0
                    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       376368     46506/io.admin.1
                    tcp6       0      0 :::8083                 :::*                    LISTEN      1001       378513     47055/io.web.0
                    tcp6       0      0 :::8084                 :::*                    LISTEN      1001       377353     47021/io.socketio.0
                    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       379416     47004/io.simple-api
                    udp        0      0 0.0.0.0:53              0.0.0.0:*                           999        8471       854/pihole-FTL
                    udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       376637     46769/io.radar2.0
                    udp        0      0 0.0.0.0:34923           0.0.0.0:*                           104        7662       580/avahi-daemon: r
                    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          8350       1/init
                    udp        0      0 0.0.0.0:37102           0.0.0.0:*                           103        8381       858/rpc.statd
                    udp        0      0 127.0.0.1:610           0.0.0.0:*                           0          8377       858/rpc.statd
                    udp        0      0 0.0.0.0:37522           0.0.0.0:*                           0          2731       -
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        7660       580/avahi-daemon: r
                    udp6       0      0 :::53                   :::*                                999        8473       854/pihole-FTL
                    udp6       0      0 :::111                  :::*                                0          6609       1/init
                    udp6       0      0 :::47227                :::*                                103        8387       858/rpc.statd
                    udp6       0      0 :::47827                :::*                                104        7663       580/avahi-daemon: r
                    udp6       0      0 :::43952                :::*                                0          2733       -
                    udp6       0      0 :::5353                 :::*                                104        7661       580/avahi-daemon: r
                    2024-11-10 10:15:05.918  - info: simple-api.0 (47004) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                    2024-11-10 10:15:06.112  - info: simple-api.0 (47004) starting. Version 2.8.0 in /opt/iobroker/node_modules/iobroker.simple-api, node: v20.17.0, js-controller: 6.0.9
                    2024-11-10 10:15:06.152  - info: simple-api.0 (47004) simpleAPI server listening on port 8087
                    2024-11-10 10:15:06.153  - info: simple-api.0 (47004) Allow states only when user is owner: false
                    2024-11-10 10:15:06.177  - info: simple-api.0 (47004) http server listening on port 8087
                    2024-11-10 10:15:07.188  - info: host.pi4wz instance system.adapter.socketio.0 in version "6.7.1" started with pid 47021
                    2024-11-10 10:15:09.785  - info: socketio.0 (47021) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                    2024-11-10 10:15:10.063  - info: socketio.0 (47021) starting. Version 6.7.1 in /opt/iobroker/node_modules/iobroker.socketio, node: v20.17.0, js-controller: 6.0.9
                    2024-11-10 10:15:10.164  - info: socketio.0 (47021) socket.io server listening on port 8084
                    2024-11-10 10:15:11.219  - info: host.pi4wz instance system.adapter.vis-2.0 in version "2.9.32" started with pid 47038
                    2024-11-10 10:15:13.186  - info: vis-2.0 (47038) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                    2024-11-10 10:15:13.477  - info: vis-2.0 (47038) starting. Version 2.9.32 in /opt/iobroker/node_modules/iobroker.vis-2, node: v20.17.0, js-controller: 6.0.9
                    2024-11-10 10:15:13.842  - info: vis-2.0 (47038) vis-2 license is OK.
                    2024-11-10 10:15:15.155  - info: host.pi4wz instance system.adapter.web.0 in version "6.2.5" started with pid 47055
                    2024-11-10 10:15:17.758  - info: web.0 (47055) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                    2024-11-10 10:15:17.968  - info: web.0 (47055) starting. Version 6.2.5 in /opt/iobroker/node_modules/iobroker.web, node: v20.17.0, js-controller: 6.0.9
                    2024-11-10 10:15:18.220  - info: web.0 (47055) socket.io server listening on port 8083
                    2024-11-10 10:15:18.227  - info: web.0 (47055) simpleAPI server listening on port 8083
                    2024-11-10 10:15:18.228  - info: web.0 (47055) Allow states only when user is owner: false
                    2024-11-10 10:15:18.236  - info: web.0 (47055) http server listening on port 8083
                    2024-11-10 10:15:24.846  - info: alexa2.0 (46660) No smart home devices to query
                    2024-11-10 10:15:25.813  - info: alexa2.0 (46660) Subscribing to states...
                    2024-11-10 10:15:25.821  - info: alexa2.0 (46660) Deleting the following states: ...
                    2024-11-10 10:15:27.297  - info: alexa2.0 (46660) Alexa-Push-Connection (macDms = true) established. Disable Polling
                    2024-11-10 10:15:48.634  - info: alexa2.0 (46660) Initialization Done ...
                    Das Einzige, was mir ins Auge springt:
                    Immer noch defekte SD-Karte?
                    Kann man das korrigieren, da ich vermute, dass das so im Backupimage drin stand und die aktuelle Karte nicht defekt ist. Falls ja, wie? Scheint ja nur eine Stelle zu sein.
                    • E eubecker
                      diag liefert:
                      Script v.2024-10-19
                      *** BASE SYSTEM ***
                             Icon name: computer
                          Architecture: arm64
                      OS is similar to:
                      Docker          : false
                      Kernel          : aarch64
                      Userland        : 64 bit
                      CPU threads: 4
                      Current issues:
                                       RTC time: n/a
                                    NTP service: active
                                RTC in local TZ: no
                      eckhard
                      HOME=/home/eckhard
                      iobroker
                      HOME=/home/iobroker
                      Desktop:
                      Terminal:       tty
                      *** MEMORY ***
                      Swap:           209M          0B        209M
                               3792 M total memory
                               1579 M used memory
                                810 M free memory
                                113 M buffer memory
                               1376 M swap cache
                                199 M total swap
                                  0 M used swap
                                199 M free swap
                      *** FILESYSTEM ***
                      /var:
                      1.2G    /var/
                      611M    /var/cache
                      604M    /var/cache/apt
                      194M    /var/lib
                      USB-Devices by-id:
                      /usr/bin/npm            10.8.2
                      /usr/bin/npx            10.8.2
                      nodejs:
                        Version table:
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      Hosts:
                      admin:          7.1.5
                      javascript:     8.8.3
                      Adapter State
                      + instance is alive
                      Objects and States
                      Objects:        7578
                      States:         5803
                      Edit:
                      Zu schnell gewesen....
