  4. Adapter: ebus
    6.7k
Adapter: ebus
ebus adapter
712 Beiträge 73 Kommentatoren 332.8k Aufrufe 60 Beobachtet
  • T thiozinc
    Skript v.2024-05-22
    *** BASE SYSTEM ***
     Static hostname: raspberrypi
           Icon name: computer
              Kernel: Linux 6.6.31+rpt-rpi-v8
        Architecture: arm64
    Model		: Raspberry Pi 4 Model B Rev 1.1
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     23:01:46 up 14 days,  3:14,  2 users,  load average: 1.05, 1.34, 1.15
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Thu 2024-08-22 23:01:46 CEST
               Universal time: Thu 2024-08-22 21:01:46 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    pi
    HOME=/home/pi
    GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout sudo audio video bluetooth gpio i2c
    *** Display-Server-Setup ***
    Display-Server: false
    Desktop:
    Terminal: 	tty
    Boot Target: 	multi-user.target
    *** MEMORY ***
    Mem:            4.0G        2.8G        541M        135K        679M        1.2G
    Swap:           209M        195M         13M
    Total:          4.2G        3.0G        555M
    Active iob-Instances: 	29
             3792 M total memory
             2689 M used memory
             2254 M active memory
              833 M inactive memory
              516 M free memory
               75 M buffer memory
              572 M swap cache
              199 M total swap
              186 M used swap
               13 M free swap
    top - 23:01:46 up 14 days,  3:14,  2 users,  load average: 1.05, 1.34, 1.15
    Tasks: 216 total,   1 running, 215 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us, 40.0 sy,  0.0 ni, 60.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   3792.1 total,    515.9 free,   2689.6 used,    647.8 buff/cache
    MiB Swap:    200.0 total,     13.1 free,    186.9 used.   1102.5 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    udev           devtmpfs  1.6G     0  1.6G   0% /dev
    tmpfs          tmpfs     380M  1.3M  378M   1% /run
    /dev/mmcblk0p2 ext4       29G  9.5G   18G  35% /
    tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
    /dev/mmcblk0p1 vfat      510M   64M  447M  13% /boot/firmware
    /dev/sda1      ext4      116G  1.7G  109G   2% /media/usbdisk
    tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
    [Thu Aug  8 19:47:22 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:30:B4:93 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=68b36b16-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Thu Aug  8 19:47:26 2024] EXT4-fs (mmcblk0p2): mounted filesystem 3b614a3f-4a65-4480-876a-8a998e01ac9b ro with ordered data mode. Quota mode: none.
    [Thu Aug  8 19:47:29 2024] EXT4-fs (mmcblk0p2): re-mounted 3b614a3f-4a65-4480-876a-8a998e01ac9b r/w. Quota mode: none.
    [Thu Aug  8 19:47:32 2024] EXT4-fs (sda1): warning: mounting fs with errors, running e2fsck is recommended
    [Thu Aug  8 19:47:32 2024] EXT4-fs (sda1): mounted filesystem 3d241c43-2bbf-49ce-a4f9-270fcb182309 r/w with ordered data mode. Quota mode: none.
    [Thu Aug  8 19:47:36 2024] EXT4-fs error (device sda1): ext4_validate_block_bitmap:421: comm ext4lazyinit: bg 122: bad block bitmap checksum
    [Thu Aug  8 19:47:36 2024] EXT4-fs error (device sda1): ext4_validate_block_bitmap:421: comm ext4lazyinit: bg 203: bad block bitmap checksum
    [Thu Aug  8 19:52:38 2024] EXT4-fs (sda1): error count since last fsck: 71
    [Thu Aug  8 19:52:38 2024] EXT4-fs (sda1): initial error at time 1668261680: ext4_validate_block_bitmap:390
    [Thu Aug  8 19:52:38 2024] EXT4-fs (sda1): last error at time 1723139237: ext4_validate_block_bitmap:421
    [Fri Aug  9 21:30:18 2024] EXT4-fs (sda1): error count since last fsck: 71
    [Fri Aug  9 21:30:18 2024] EXT4-fs (sda1): initial error at time 1668261680: ext4_validate_block_bitmap:390
    [Fri Aug  9 21:30:18 2024] EXT4-fs (sda1): last error at time 1723139237: ext4_validate_block_bitmap:421
    [Sat Aug 10 23:08:14 2024] EXT4-fs (sda1): error count since last fsck: 71
    [Sat Aug 10 23:08:14 2024] EXT4-fs (sda1): initial error at time 1668261680: ext4_validate_block_bitmap:390
    [Sat Aug 10 23:08:14 2024] EXT4-fs (sda1): last error at time 1723139237: ext4_validate_block_bitmap:421
    [Mon Aug 12 00:46:11 2024] EXT4-fs (sda1): error count since last fsck: 71
    [Mon Aug 12 00:46:11 2024] EXT4-fs (sda1): initial error at time 1668261680: ext4_validate_block_bitmap:390
    [Mon Aug 12 00:46:11 2024] EXT4-fs (sda1): last error at time 1723139237: ext4_validate_block_bitmap:421
    [Tue Aug 13 02:24:07 2024] EXT4-fs (sda1): error count since last fsck: 71
    [Tue Aug 13 02:24:07 2024] EXT4-fs (sda1): initial error at time 1668261680: ext4_validate_block_bitmap:390
    [Tue Aug 13 02:24:07 2024] EXT4-fs (sda1): last error at time 1723139237: ext4_validate_block_bitmap:421
    [Wed Aug 14 04:02:04 2024] EXT4-fs (sda1): error count since last fsck: 71
    [Wed Aug 14 04:02:04 2024] EXT4-fs (sda1): initial error at time 1668261680: ext4_validate_block_bitmap:390
    [Wed Aug 14 04:02:04 2024] EXT4-fs (sda1): last error at time 1723139237: ext4_validate_block_bitmap:421
    [Thu Aug 15 05:40:00 2024] EXT4-fs (sda1): error count since last fsck: 71
    [Thu Aug 15 05:40:00 2024] EXT4-fs (sda1): initial error at time 1668261680: ext4_validate_block_bitmap:390
    [Thu Aug 15 05:40:00 2024] EXT4-fs (sda1): last error at time 1723139237: ext4_validate_block_bitmap:421
    [Fri Aug 16 07:17:57 2024] EXT4-fs (sda1): error count since last fsck: 71
    [Fri Aug 16 07:17:57 2024] EXT4-fs (sda1): initial error at time 1668261680: ext4_validate_block_bitmap:390
    [Fri Aug 16 07:17:57 2024] EXT4-fs (sda1): last error at time 1723139237: ext4_validate_block_bitmap:421
    [Sat Aug 17 08:55:53 2024] EXT4-fs (sda1): error count since last fsck: 71
    [Sat Aug 17 08:55:53 2024] EXT4-fs (sda1): initial error at time 1668261680: ext4_validate_block_bitmap:390
    [Sat Aug 17 08:55:53 2024] EXT4-fs (sda1): last error at time 1723139237: ext4_validate_block_bitmap:421
    [Sun Aug 18 10:33:50 2024] EXT4-fs (sda1): error count since last fsck: 71
    [Sun Aug 18 10:33:50 2024] EXT4-fs (sda1): initial error at time 1668261680: ext4_validate_block_bitmap:390
    [Sun Aug 18 10:33:50 2024] EXT4-fs (sda1): last error at time 1723139237: ext4_validate_block_bitmap:421
    [Mon Aug 19 12:11:46 2024] EXT4-fs (sda1): error count since last fsck: 71
    [Mon Aug 19 12:11:46 2024] EXT4-fs (sda1): initial error at time 1668261680: ext4_validate_block_bitmap:390
    [Mon Aug 19 12:11:46 2024] EXT4-fs (sda1): last error at time 1723139237: ext4_validate_block_bitmap:421
    [Tue Aug 20 13:49:43 2024] EXT4-fs (sda1): error count since last fsck: 71
    [Tue Aug 20 13:49:43 2024] EXT4-fs (sda1): initial error at time 1668261680: ext4_validate_block_bitmap:390
    [Tue Aug 20 13:49:43 2024] EXT4-fs (sda1): last error at time 1723139237: ext4_validate_block_bitmap:421
    [Wed Aug 21 15:27:39 2024] EXT4-fs (sda1): error count since last fsck: 71
    [Wed Aug 21 15:27:39 2024] EXT4-fs (sda1): initial error at time 1668261680: ext4_validate_block_bitmap:390
    [Wed Aug 21 15:27:39 2024] EXT4-fs (sda1): last error at time 1723139237: ext4_validate_block_bitmap:421
    [Thu Aug 22 17:05:36 2024] EXT4-fs (sda1): error count since last fsck: 71
    [Thu Aug 22 17:05:36 2024] EXT4-fs (sda1): initial error at time 1668261680: ext4_validate_block_bitmap:390
    [Thu Aug 22 17:05:36 2024] EXT4-fs (sda1): last error at time 1723139237: ext4_validate_block_bitmap:421
    Show mounted filesystems:
    TARGET                                                  SOURCE         FSTYPE      OPTIONS
    /                                                       /dev/mmcblk0p2 ext4        rw,noatime
    |-/sys                                                  sysfs          sysfs       rw,nosuid,nodev,noexec,relatime
    | |-/sys/kernel/security                                securityfs     securityfs  rw,nosuid,nodev,noexec,relatime
    | |-/sys/fs/cgroup                                      cgroup2        cgroup2     rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
    | |-/sys/fs/pstore                                      pstore         pstore      rw,nosuid,nodev,noexec,relatime
    | |-/sys/fs/bpf                                         bpf            bpf         rw,nosuid,nodev,noexec,relatime,mode=700
    | |-/sys/kernel/debug                                   debugfs        debugfs     rw,nosuid,nodev,noexec,relatime
    | | `-/sys/kernel/debug/tracing                         tracefs        tracefs     rw,nosuid,nodev,noexec,relatime
    | |-/sys/kernel/tracing                                 tracefs        tracefs     rw,nosuid,nodev,noexec,relatime
    | |-/sys/fs/fuse/connections                            fusectl        fusectl     rw,nosuid,nodev,noexec,relatime
    | `-/sys/kernel/config                                  configfs       configfs    rw,nosuid,nodev,noexec,relatime
    |-/proc                                                 proc           proc        rw,relatime
    | `-/proc/sys/fs/binfmt_misc                            systemd-1      autofs      rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=143
    |   `-/proc/sys/fs/binfmt_misc                          binfmt_misc    binfmt_misc rw,nosuid,nodev,noexec,relatime
    |-/dev                                                  udev           devtmpfs    rw,nosuid,relatime,size=1671304k,nr_inodes=417826,mode=755
    | |-/dev/pts                                            devpts         devpts      rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
    | |-/dev/shm                                            tmpfs          tmpfs       rw,nosuid,nodev
    | `-/dev/mqueue                                         mqueue         mqueue      rw,nosuid,nodev,noexec,relatime
    |-/run                                                  tmpfs          tmpfs       rw,nosuid,nodev,noexec,relatime,size=388308k,mode=755
    | |-/run/lock                                           tmpfs          tmpfs       rw,nosuid,nodev,noexec,relatime,size=5120k
    | |-/run/credentials/systemd-sysctl.service             ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
    | |-/run/credentials/systemd-sysusers.service           ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
    | |-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
    | |-/run/rpc_pipefs                                     sunrpc         rpc_pipefs  rw,relatime
    | |-/run/credentials/systemd-tmpfiles-setup.service     ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
    | `-/run/user/1000                                      tmpfs          tmpfs       rw,nosuid,nodev,relatime,size=388304k,nr_inodes=97076,mode=700,uid=1000,gid=1000
    |-/boot/firmware                                        /dev/mmcblk0p1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    `-/media/usbdisk                                        /dev/sda1      ext4        rw,nosuid,nodev,noexec,noatime
    /var:
    3.6G	/var/
    1.9G	/var/log/journal/1c963a2d6f5d49798d662b895e4632cd
    1.9G	/var/log
    1.3G	/var/lib
    Archived and active journals take up 1.8G in the file system.
    /opt/iobroker/backups:
    384M	/opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    894M	/opt/iobroker/iobroker-data/
    700M	/opt/iobroker/iobroker-data/files
    441M	/opt/iobroker/iobroker-data/files/javascript.admin
    409M	/opt/iobroker/iobroker-data/files/javascript.admin/static
    408M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js
    42M	/opt/iobroker/iobroker-data/files/telegram-menu.admin/build/index.js.map
    30M	/opt/iobroker/iobroker-data/objects.jsonl
    24M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
    22M	/opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.18496c94.js.map
    19M	/opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.02fc3820.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A50285BI-if00-port0
    /dev/serial/by-id/usb-Silicon_Labs_CP2102N_USB_to_UART_Bridge_Controller_d2fcfed44da0ea1184b05dcbfe9faf31-if00-port0
    /dev/serial/by-id/usb-Espressif_USB_JTAG_serial_debug_unit_80:65:99:99:A8:30-if00
    *** NodeJS-Installation ***
    /usr/bin/nodejs 	v18.20.4
    /usr/bin/node 		v18.20.4
    /usr/bin/npm 		10.7.0
    /usr/bin/npx 		10.7.0
    /usr/bin/corepack 	0.28.0
    nodejs:
      Installed: 18.20.4-1nodesource1
      Candidate: 18.20.4-1nodesource1
      Version table:
     *** 18.20.4-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
         18.20.3-1nodesource1 1001
         18.20.2-1nodesource1 1001
         18.20.1-1nodesource1 1001
         18.20.0-1nodesource1 1001
         18.19.1-1nodesource1 1001
         18.19.0+dfsg-6~deb12u2 500
            500 http://deb.debian.org/debian bookworm/main arm64 Packages
         18.19.0+dfsg-6~deb12u1 500
            500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
         18.19.0-1nodesource1 1001
         18.18.2-1nodesource1 1001
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller: 	6.0.9
    admin: 		7.0.23
    javascript: 	8.7.6
    nodejs modules from github: 	3
    +-- iobroker.robonect@1.3.6 (git+ssh://git@github.com/Grizzelbee/ioBroker.robonect.git#b3e15ba3ceda35dbc6688cc5431da2493a4c2f62)
    +-- iobroker.vw-connect@0.5.1 (git+ssh://git@github.com/ta2k/ioBroker.vw-connect.git#29ef72ba0568014661f431d5fc0908619fff89c2)
    +-- iobroker.wireless-mbus@0.9.2 (git+ssh://git@github.com/lvogt/ioBroker.wireless-mbus.git#de09e441e4c88799ada3abd396f04fad74f80325)
    Adapter State
      system.adapter.ble.0                    : ble                   : raspberrypi                              - disabled
    + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
      system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
      system.adapter.discovery.0              : discovery             : raspberrypi                              - disabled
    + system.adapter.drag-indicator.0         : drag-indicator        : raspberrypi                              -  enabled
    + system.adapter.ebus.0                   : ebus                  : raspberrypi                              -  enabled
      system.adapter.feiertage.0              : feiertage             : raspberrypi                              -  enabled
    + system.adapter.followthesun.0           : followthesun          : raspberrypi                              -  enabled
    + system.adapter.history.0                : history               : raspberrypi                              -  enabled
    + system.adapter.kecontact.0              : kecontact             : raspberrypi                              -  enabled
    + system.adapter.modbus.0                 : modbus                : raspberrypi                              -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
      system.adapter.openligadb.0             : openligadb            : raspberrypi                              - disabled
    + system.adapter.parser.1                 : parser                : raspberrypi                              -  enabled
    + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
      system.adapter.psa.0                    : psa                   : raspberrypi                              - disabled
    + system.adapter.pushover.1               : pushover              : raspberrypi                              -  enabled
    + system.adapter.pushover.2               : pushover              : raspberrypi                              -  enabled
    + system.adapter.robonect.0               : robonect              : raspberrypi                              -  enabled
      system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              - disabled
      system.adapter.schoolfree.0             : schoolfree            : raspberrypi                              -  enabled
    + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1886, bind: 0.0.0.0
    + system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.smartmeter.0             : smartmeter            : raspberrypi                              -  enabled
    + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1884, bind: 0.0.0.0
    + system.adapter.sql.0                    : sql                   : raspberrypi                              -  enabled, port: 3306
      system.adapter.telegram-menu.0          : telegram-menu         : raspberrypi                              - disabled
    + system.adapter.text2command.0           : text2command          : raspberrypi                              -  enabled
      system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              - disabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              - disabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              - disabled
      system.adapter.vis-history.0            : vis-history           : raspberrypi                              - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              - disabled
      system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi                              - disabled
      system.adapter.vis-lcars.0              : vis-lcars             : raspberrypi                              - disabled
      system.adapter.vis-plumb.0              : vis-plumb             : raspberrypi                              - disabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : raspberrypi                              - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
      system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              - disabled
    + system.adapter.vw-connect.0             : vw-connect            : raspberrypi                              -  enabled
    + system.adapter.webuntis.0               : webuntis              : raspberrypi                              -  enabled
      system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              - disabled
    + system.adapter.wireless-mbus.0          : wireless-mbus         : raspberrypi                              -  enabled
    + instance is alive
    ioBroker-Repositories
    │ (index) │   name   │                           url                           │ auto upgrade │
    │    0    │ 'stable' │    'http://download.iobroker.net/sources-dist.json'     │    false     │
    │    1    │  'beta'  │ 'http://download.iobroker.net/sources-dist-latest.json' │    false     │
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 7.0.23   , installed 7.0.23
    Adapter    "backitup"     : 3.0.19   , installed 3.0.19
    Adapter    "ble"          : 0.14.0   , installed 0.14.0
    Adapter    "daswetter"    : 3.1.15   , installed 3.1.15
    Adapter    "discovery"    : 4.5.0    , installed 4.5.0
    Adapter    "drag-indicator": 2.1.4   , installed 2.1.4
    Adapter    "ebus"         : 3.3.4    , installed 3.3.4
    Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
    Adapter    "followthesun" : 0.5.0    , installed 0.5.0
    Adapter    "javascript"   : 8.7.6    , installed 8.7.6
    Controller "js-controller": 6.0.9    , installed 6.0.9
    Adapter    "kecontact"    : 2.2.0    , installed 2.2.0
    Adapter    "modbus"       : 6.2.3    , installed 6.2.3
    Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
    Adapter    "openligadb"   : 1.4.9    , installed 1.4.9
    Adapter    "parser"       : 2.2.2    , installed 2.2.2
    Adapter    "pushover"     : 3.0.6    , installed 3.0.6
    Adapter    "robonect"     : 1.3.6    , installed 1.3.6
    Adapter    "schoolfree"   : 1.1.4    , installed 1.1.4
    Adapter    "shelly"       : 7.0.0    , installed 7.0.0
    Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
    Adapter    "sonoff"       : 3.1.0    , installed 3.1.0
    Adapter    "sql"          : 3.0.1    , installed 3.0.1
    Adapter    "telegram"     : 3.9.0    , installed 3.9.0
    Adapter    "telegram-menu": 1.7.4    , installed 1.7.4
    Adapter    "text2command" : 3.0.3    , installed 3.0.3
    Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
    Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
    Adapter    "web"          : 6.2.5    , installed 6.2.5
    Adapter    "webuntis"     : 0.3.4    , installed 0.3.4
    Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
    Adapter    "wireless-mbus": 0.9.1    , installed 0.9.2
    Objects and States
    Objects: 	12368
    States: 	11091
    Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          674        787/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:3306          0.0.0.0:*               LISTEN      106        6015       847/mariadbd
    tcp        0      0 0.0.0.0:8888            0.0.0.0:*               LISTEN      0          50950559   1469294/ebusd
    tcp        0      0 0.0.0.0:8889            0.0.0.0:*               LISTEN      0          50950560   1469294/ebusd
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       66105371   2118966/iobroker.js
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       66105364   2118966/iobroker.js
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       66109578   2119230/io.mqtt.0
    tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       66108352   2119342/io.sonoff.0
    tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       66106731   2119302/io.shelly.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          676        787/sshd: /usr/sbin
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       66105455   2118992/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       66107057   2119380/io.web.0
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       66110036   2119540/io.simple-a
    udp        0      0 0.0.0.0:7090            0.0.0.0:*                           1001       66108612   2119189/io.kecontac
    udp        0      0 0.0.0.0:7092            0.0.0.0:*                           1001       66108613   2119189/io.kecontac
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        4020       625/avahi-daemon: r
    udp        0      0 0.0.0.0:56809           0.0.0.0:*                           1001       66108614   2119189/io.kecontac
    udp        0      0 0.0.0.0:59006           0.0.0.0:*                           104        4022       625/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                104        4021       625/avahi-daemon: r
    udp6       0      0 :::44356                :::*                                104        4023       625/avahi-daemon: r
    udp6       0      0 fe80::79ca:2591:a72:546 :::*                                0          6377       700/NetworkManager
    2024-08-22 22:59:56.774  - warn: ebus.0 (2254253) no update since 21/08/2024, 21:41:21 uih.messages.TempIncrease.lastup
    2024-08-22 22:59:56.792  - warn: ebus.0 (2254253) no update since 21/08/2024, 21:41:22 uih.messages.YieldLastYear.lastup
    2024-08-22 22:59:57.019  - warn: ebus.0 (2254253) no update since 21/08/2024, 21:41:22 uih.messages.YieldOld.lastup
    2024-08-22 22:59:57.041  - warn: ebus.0 (2254253) no update since 21/08/2024, 21:41:22 uih.messages.YieldSum.lastup
    2024-08-22 22:59:57.241  - info: ebus.0 (2254253) installed ebusd version is 23.3
    2024-08-22 22:59:57.321  - info: ebus.0 (2254253) all http done
    2024-08-22 23:00:00.610  - info: smartmeter.0 (2119319) Received 10 values, 3 updated
    2024-08-22 23:00:05.555  - info: webuntis.0 (2119585) Cannot read Inbox - possible block by scool
    2024-08-22 23:00:07.395  - info: javascript.0 (2119026) script.js.Garten.Robbie: Robbi Temp i.O.!
    2024-08-22 23:00:11.397  - info: smartmeter.0 (2119319) Received 10 values, 3 updated
    2024-08-22 23:00:22.384  - info: smartmeter.0 (2119319) Received 10 values, 3 updated
    2024-08-22 23:00:33.313  - info: smartmeter.0 (2119319) Received 10 values, 3 updated
    2024-08-22 23:00:40.529  - info: shelly.0 (2119302) [MQTT] Device with client id "shellydw2-D73F3F" connected!
    2024-08-22 23:00:44.334  - info: smartmeter.0 (2119319) Received 10 values, 3 updated
    2024-08-22 23:00:55.332  - info: smartmeter.0 (2119319) Received 10 values, 3 updated
    2024-08-22 23:01:06.287  - info: smartmeter.0 (2119319) Received 10 values, 3 updated
    2024-08-22 23:01:17.337  - info: smartmeter.0 (2119319) Received 10 values, 2 updated
    2024-08-22 23:01:28.334  - info: smartmeter.0 (2119319) Received 10 values, 3 updated
    2024-08-22 23:01:39.341  - info: smartmeter.0 (2119319) Received 10 values, 3 updated
    2024-08-22 23:01:50.331  - info: smartmeter.0 (2119319) Received 10 values, 3 updated
    2024-08-22 23:02:01.342  - info: smartmeter.0 (2119319) Received 10 values, 3 updated
    2024-08-22 23:02:04.457  - info: javascript.0 (2119026) script.js.Garten.Robbie: Robbi Temp i.O.!
    2024-08-22 23:02:12.379  - info: smartmeter.0 (2119319) Received 10 values, 3 updated
    2024-08-22 23:02:23.371  - info: smartmeter.0 (2119319) Received 10 values, 3 updated
    2024-08-22 23:02:34.426  - info: smartmeter.0 (2119319) Received 10 values, 3 updated
    #616
    @thiozinc
    Dein Dateisystem auf /dev/sda1 (/media/usbdisk) hat Einschläge.
    Bring nodejs auf Version 20
    iob nodejs-update
    Ansonsten nix auffälliges.
      @thiozinc
      iob nodejs-update
      thiozinc
      schrieb am zuletzt editiert von thiozinc
      #617
      @thomas-braun said in Adapter: ebus:
      iob nodejs-update
      Danke für den Tipp, aber das Update hat leider auch keine Verbesserung gebracht.
      • T thiozinc
        iob nodejs-update
        #618
        @thiozinc
        Das hab ich auch nicht behauptet.
        • T thiozinc
          iob nodejs-update
          #619
          @thiozinc
          iob upload all
          mal ausführen.
            @thiozinc
            iob upload all
            mal ausführen.
            thiozinc
            #620
            Danke, jetzt läuft's wieder!
              megamacy
              schrieb am zuletzt editiert von megamacy
              #621
              kann mir evtl jemand weiterhelfen und sagen, wie ich die Abfrage von bestimmten Datenpunkten deaktivieren kann?
              Es gibt einen Datenpunkt "broadcast.messages.signoflife.lastup" , der wird bei start des von Ebusd einmal gesetzt und dann während der Laufzeit nicht mehr. Das generiert im Abfrageintervall Warnmeldungen im LOG
              ebus.0	2024-10-11 17:41:41.958	info	all http done
              ebus.0	2024-10-11 17:41:39.794	info	installed ebusd version is 23.3
              ebus.0	2024-10-11 17:41:37.203	warn	no update since 11.10.2024, 15:57:40 broadcast.messages.signoflife.lastup
              ebus.0	2024-10-11 17:40:45.099	info	all http done
              ebus.0	2024-10-11 17:40:44.949	info	installed ebusd version is 23.3
              ebus.0	2024-10-11 17:40:40.321	warn	no update since 11.10.2024, 15:57:40 broadcast.messages.signoflife.lastup
              ebus.0	2024-10-11 17:39:42.654	info	all http done
              ebus.0	2024-10-11 17:39:42.488	info	installed ebusd version is 23.3
              ebus.0	2024-10-11 17:39:38.709	warn	no update since 11.10.2024, 15:57:40 broadcast.messages.signoflife.lastup
              ebus.0	2024-10-11 17:38:46.079	info	all http done
              ebus.0	2024-10-11 17:38:45.948	info	installed ebusd version is 23.3
              ebus.0	2024-10-11 17:38:37.850	warn	no update since 11.10.2024, 15:57:40 broadcast.messages.signoflife.lastup
              Rene_HMR 1 Antwort Letzte Antwort
                saskathex
                #622
                gestern habe ich auf ebusd 24.1 geupdatet. Leider läuft der iobroker Adapter nun nicht mehr und meldet die Fehlermeldung:
                "unsupported ebusd version found (too new) .... "
                Wie ist der Weg des Issue reporting? Eher hier (da habe ich mal angefangen) oder über das github repo.
                • S saskathex
                  Rene_HMR Offline
                  Rene_HMR Offline
                  Rene_HM
                  #623
                  @saskathex sagte in Adapter: ebus:
                  Das ist eigentlich nur eine Warnung. Geht sonst irgendetwas nicht mehr?
                  ideal wäre ein ticket im github...
                  • Rene_HMR Rene_HM
                    saskathex
                    #624
                    @rene_hm Nachdem ich nachher den Code mir angeschaut habe, hab ich es selbst gemerkt mit der Warnung. Ansonsten geht alles!
                    Nur die ebus Nachrichten von meiner Vaillant Heizung haben ihre Struktur geändert. Musste ich nur meine Datenpunkte anpassen. Das liegt eher nicht an dem iobroker Adapter, als mehr an dem ebusd, welche diese anders liefert. Stört mich persönlich aber nicht.
                    Kurz: Name und Value kommen jetzt in unterschiedlichen Zweigen anstatt in einem Zweig.
                    • S saskathex
                      Kanumouse
                      #625
                      Ich habe ebusd auch auf die Version 24.1 umgestellt. Läuft soweit alles.
                      Nur fehlen mir 4 Datenpunkte für meine an eine vaillant 470 angeschlossene Solarthermieanlage:
                      SBTemp, SolBackTemp, CollTemp, SolPump
                      Bei der vorherigen 23-iger Version waren diese Datenpunkte noch da.
                      • M megamacy
                        Rene_HMR Offline
                        Rene_HMR Offline
                        Rene_HM
                        #626
                        @megamacy Etwas spät, aber vielleicht hilft es noch:
                        Das liegt normalerweise weder am Adapter noch am ebusd. Das Problem ist, dass manche Werte nach einem Reboot mit Scan einmalig auf dem Bus auftauchen. Der ebusd packt diese Werte in die Datenstruktur und damit tauchen sie im Adapter auf. Wenn nun dieser Wert nie wieder auf dem Bus auftaucht, bleibt natürlich der Zeitstempel beim ersten Auftauchen stehen und der Adapter loggt, dass es kein update gibt, was ja auch richtig ist.
                        Man wird diese Werte los, indem man den ebusd neu bootet. Dabei darf natürlich der Scan nicht aktiv sein. Dadurch baut der ebusd seine interne Datenstruktur neu auf. Danach löscht man im iobroker einmalig den kompletten Baum der Daten vom ebus-Adapter (oder alternativ manuell die Datenpunkte, die nicht aktualisiert werden)
                        • HasontH Offline
                          HasontH Offline
                          Hasont
                          schrieb am zuletzt editiert von Hasont
                          #627
                          Hallo, ich brauch mal wieder eure Hilfe.
                          eBus Adapter ist 3.3.6 und ebusd die 23.3
                          Ich hatte jetzt längere Zeit meine Heizung über VIS nicht mehr im Blick und stelle grad fest, dass das ebus-history-widget unten im Bild komplett verschwunden ist.
                          Der Platz wo das war ist jetzt komplett frei
                          und links im VIS Editor ist das ebus-history-Widget auch nicht mehr zu finden.
                          Da das ebus-history-widget doch aus dem ebus-Adapter kommt hier mal die Frage wie ich das wieder in meine VIS integrieren kann.
                          Danke schon mal für eure Hilfe.
                          LG Horst
                          • HasontH Hasont
                            LG Horst
                            Rene_HMR Offline
                            Rene_HMR Offline
                            Rene_HM
                            #628
                            @hasont ich würde zunächst ein upload für den Adapter und die vis versuchen.
                            Du könntest auch im Konsolen-Fenster deines browsers nach Fehlermeldungen schauen...
                            HasontH 1 Antwort Letzte Antwort
                            • Rene_HMR Rene_HM
                              HasontH Offline
                              HasontH Offline
                              Hasont
                              #629
                              @rene_hm
                              Hallo Rene, danke für die schnelle Antwort.
                              Ich hab den upload gemacht was leider nix gebracht hat. Das Widget ist noch immer weg. Hab dann deinstalliert und es ging gar nichts mehr. Dann Backup vom 15.11 zurück gespielt. Leider war es da scheinbar auch schon.
                              In Firefox hab ich unter Wekzeug das gefunden. Wäre das die Ausgabe der Konsole?
                              Hast du ev. sonst noch eine Idee. Braucht man für das ebus Widget ev. noch andere Widgets auf das du aufbaust und das ich ev. mal beim Aufräumen deinstalliert habe.
                              1732359221042	addons.xpi	WARN	Checking C:\Program Files (x86)\Mozilla Firefox\distribution\extensions for addons
                              Attempt to override an existing message: "urlbar-searchmode-dropmarker". preview/enUS-searchFeatures.ftl
                              Attempt to override an existing message: "urlbar-searchmode-bookmarks". preview/enUS-searchFeatures.ftl
                              Attempt to override an existing message: "urlbar-searchmode-tabs". preview/enUS-searchFeatures.ftl
                              Attempt to override an existing message: "urlbar-searchmode-history". preview/enUS-searchFeatures.ftl
                              Attempt to override an existing message: "urlbar-searchmode-actions". preview/enUS-searchFeatures.ftl
                              Attempt to override an existing message: "urlbar-searchmode-exit-button". preview/enUS-searchFeatures.ftl
                              Attempt to override an existing message: "urlbar-searchmode-popup-description". preview/enUS-searchFeatures.ftl
                              Attempt to override an existing message: "urlbar-searchmode-popup-search-settings". preview/enUS-searchFeatures.ftl
                              Attempt to override an existing message: "appmenu-manage-profiles". preview/profiles.ftl
                              Attempt to override an existing message: "appmenu-create-profile". preview/profiles.ftl
                              Warning: attempting to write 5672 bytes to preference browser.topsites.contile.cachedTiles. This is bad for general performance and memory usage. Such an amount of data should rather be written to an external file.
                              QM_TRY failure (WARNING): 'Unavailable, storage-origin http://192.168.1.75:8082, context dom::quota::FirstInitializationAttempt::TemporaryStorage', file dom/quota/ActorsParent.cpp:2779
                              Experiment add-an-image-to-pdf-with-alt-text-rollout has unknown featureId: addAnImageInPDF RemoteSettingsExperimentLoader.sys.mjs:709:21
                              Experiment tab-hover-preview-release-rollout has unknown featureId: tabPreview RemoteSettingsExperimentLoader.sys.mjs:709:21
                              Danke schon mal
                              Horst
                              • HasontH Hasont
                                @rene_hm
                                Danke schon mal
                                Horst
                                Rene_HMR Offline
                                Rene_HMR Offline
                                Rene_HM
                                #630
                                @hasont Ich habe jetzt gerade bei mir nochmal geschaut. Im Edit-Mode sind meine vis-widgets (ebus, weather und sbfspot) nicht mehr sichtbar. Muss ich mir anschauen...
                                Ich hatte mich in den letzten Monaten mit vis-2 beschäftigt, habe wohl hier irgendetwas übersehen....
                                • Rene_HMR Rene_HM
                                  HasontH Offline
                                  HasontH Offline
                                  Hasont
                                  #631
                                  @rene_hm
                                  Vielen Dank für die Info, dann kann ich ja jetzt aufhören zu suchen:-)
                                  LG Horst
                                  • HasontH Hasont
                                    @rene_hm
                                    LG Horst
                                    Rene_HMR Offline
                                    Rene_HMR Offline
                                    Rene_HM
                                    #632
                                    @hasont mit der v3.3.8 sollte es wieder funktionieren. Ein upload der vis ist wahrscheinlich nach Installation des Adapters notwendig.
                                    • Rene_HMR Rene_HM
                                      HasontH Offline
                                      HasontH Offline
                                      Hasont
                                      #633
                                      @rene_hm
                                      Vielen vielen Dank, hab über github die v3.3.8 installiert und danach Upload von Vis gemacht. War sofort wieder in aller schönheit da.
                                      LG Horst
                                      • HasontH Offline
                                        HasontH Offline
                                        Hasont
                                        #634
                                        Hallo, wollte vorgestern auf Bookworm updaten und hab dabei gesehen, dass die Grafik nichts mehr anzeigt.
                                        Hab dann ein Update vom 25.11, wo ja alles ging, eingespielt und der Graph war wieder da. Gestern aber wieder das gleiche Bild. Daten finde ich sehen aber doch OK aus, oder?
                                        ebus.0
                                        	2024-11-30 16:15:08.650	debug	DisplayedRoomTemp 20.75 30.11.2024, 16:15:00
                                        ebus.0
                                        	2024-11-30 16:15:08.649	debug	history.value4 got [[{"DisplayedRoomTemp":"21.19"}],[{"DisplayedRoomTemp":"21.06"}],[{"DisplayedRoomTemp":"21.19"}],[{"DisplayedRoomTemp":"21.06"}],[{"DisplayedRoomTemp":"21.06"}],[{"DisplayedRoomTemp":"21.06"}],[{"DisplayedRoomTemp":"21.06"}],[{"DisplayedRoomTemp":"21.06"}],[{"DisplayedRoomTemp":"21.06"}],[{"DisplayedRoomTemp":"21.06"}],[{"DisplayedRoomTemp":"21"}],[{"DisplayedRoomTemp":"21"}],[{"DisplayedRoomTemp":"21"}],[{"DisplayedRoomTemp":"21"}],[{"DisplayedRoomTemp":"21"}],[{"DisplayedRoomTemp":"21"}],[{"DisplayedRoomTemp":"21"}],[{"DisplayedRoomTemp":"21"}],[{"DisplayedRoomTemp":"21"}],[{"DisplayedRoomTemp":"20.94"}],[{"DisplayedRoomTemp":"21"}],[{"DisplayedRoomTemp":"21"}],[{"DisplayedRoomTemp":"20.94"}],[{"DisplayedRoomTemp":"21"}],[{"DisplayedRoomTemp":"20.94"}],[{"DisplayedRoomTemp":"20.94"}],[{"DisplayedRoomTemp":"20.94"}],[{"DisplayedRoomTemp":"20.94"}],[{"DisplayedRoomTemp":"20.94"}],[{"DisplayedRoomTemp":"20.94"}],[{"DisplayedRoomTemp":"20.94"}],[{"DisplayedRoomTemp":"20.81"}],[{"DisplayedRoomTemp":"20.81"}],[{"DisplayedRoomTemp":"20.81"}],[{"DisplayedRoomTemp":"20.81"}],[{"DisplayedRoomTemp":"20.81"}],[{"DisplayedRoomTemp":"20.81"}],[{"DisplayedRoomTemp":"20.81"}],[{"DisplayedRoomTemp":"20.81"}],[{"DisplayedRoomTemp":"20.81"}],[{"DisplayedRoomTemp":"20.81"}],[{"DisplayedRoomTemp":"20.81"}],[{"DisplayedRoomTemp":"20.81"}],[{"DisplayedRoomTemp":"20.75"}],[{"DisplayedRoomTemp":"20.75"}],[{"DisplayedRoomTemp":"20.75"}],[{"DisplayedRoomTemp":"20.75"}],[{"DisplayedRoomTemp":"20.75"}],[{"DisplayedRoomTemp":"20.75"}],[{"DisplayedRoomTemp":"20.81"}],[{"DisplayedRoomTemp":"20.81"}],[{"DisplayedRoomTemp":"20.81"}],[{"DisplayedRoomTemp":"20.94"}],[{"DisplayedRoomTemp":"20.94"}],[{"DisplayedRoomTemp":"21"}],[{"DisplayedRoomTemp":"20.94"}],[{"DisplayedRoomTemp":"21"}],[{"DisplayedRoomTemp":"21"}],[{"DisplayedRoomTemp":"21.06"}],[{"DisplayedRoomTemp":"21"}],[{"DisplayedRoomTemp":"21.06"}],[{"DisplayedRoomTemp":"21.06"}],[{"DisplayedRoomTemp":"21.19"}],[{"DisplayedRoomTemp":"21.25"}],[{"DisplayedRoomTemp":"21.25"}],[{"DisplayedRoomTemp":"21.19"}],[{"DisplayedRoomTemp":"21.19"}],[{"DisplayedRoomTemp":"21.19"}],[{"DisplayedRoomTemp":"21.19"}],[{"DisplayedRoomTemp":"21.19"}],[{"DisplayedRoomTemp":"21.06"}],[{"DisplayedRoomTemp":"21.06"}],[{"DisplayedRoomTemp":"20.12"}],[{"DisplayedRoomTemp":"20.31"}],[{"DisplayedRoomTemp":"20.44"}],[{"DisplayedRoomTemp":"20.62"}],[{"DisplayedRoomTemp":"20.75"}],[{"DisplayedRoomTemp":"21"}],[{"DisplayedRoomTemp":"20.94"}],[{"DisplayedRoomTemp":"21.06"}],[{"DisplayedRoomTemp":"21.06"}],[{"DisplayedRoomTemp":"21.19"}],[{"DisplayedRoomTemp":"21.19"}],[{"DisplayedRoomTemp":"21.19"}],[{"DisplayedRoomTemp":"21.25"}],[{"DisplayedRoomTemp":"21.25"}],[{"DisplayedRoomTemp":"21.44"}],[{"DisplayedRoomTemp":"21.38"}],[{"DisplayedRoomTemp":"21.38"}],[{"DisplayedRoomTemp":"21.25"}],[{"DisplayedRoomTemp":"21.19"}],[{"DisplayedRoomTemp":"21.19"}],[{"DisplayedRoomTemp":"21.19"}],[{"DisplayedRoomTemp":"21.06"}],[{"DisplayedRoomTemp":"21.06"}],[{"DisplayedRoomTemp":"21"}],[{"DisplayedRoomTemp":"21.06"}],[{"DisplayedRoomTemp":"21"}],[{"DisplayedRoomTemp":"21.25"}],[{"DisplayedRoomTemp":"21.25"}],[{"DisplayedRoomTemp":"21.19"}],[{"DisplayedRoomTemp":"21.19"}],[{"DisplayedRoomTemp":"21.06"}],[{"DisplayedRoomTemp":"21.06"}],[{"DisplayedRoomTemp":"21"}],[{"DisplayedRoomTemp":"21"}],[{"DisplayedRoomTemp":"21.06"}],[{"DisplayedRoomTemp":"21"}],[{"DisplayedRoomTemp":"21"}],[{"DisplayedRoomTemp":"21"}],["2024-11-30T07:45:00.000Z","20.19"],["2024-11-30T07:50:00.000Z","20.19"],["2024-11-30T07:55:00.000Z","20.31"],["2024-11-30T08:00:00.000Z","20.31"],["2024-11-30T08:05:00.000Z","20.31"],["2024-11-30T08:10:00.000Z","20.31"],["2024-11-30T08:15:00.000Z","20.38"],["2024-11-30T08:20:00.000Z","20.38"],["2024-11-30T08:25:00.000Z","20.44"],["2024-11-30T08:30:00.000Z","20.56"],["2024-11-30T08:35:00.000Z","20.56"],["2024-11-30T08:40:00.000Z","20.56"],["2024-11-30T08:45:00.000Z","20.56"],["2024-11-30T08:50:00.000Z","20.62"],["2024-11-30T08:55:00.000Z","20.62"],["2024-11-30T09:00:00.000Z","20.75"],["2024-11-30T09:05:00.000Z","20.75"],["2024-11-30T09:10:00.000Z","20.75"],["2024-11-30T09:15:00.000Z","20.75"],["2024-11-30T09:20:00.000Z","20.81"],["2024-11-30T09:25:00.000Z","20.81"],["2024-11-30T09:30:00.000Z","20.81"],["2024-11-30T09:35:00.000Z","20.81"],["2024-11-30T09:40:00.000Z","20.81"],["2024-11-30T09:45:00.000Z","20.94"],["2024-11-30T09:50:00.000Z","20.94"],["2024-11-30T09:55:00.000Z","20.94"],["2024-11-30T10:00:00.000Z","21"],["2024-11-30T10:05:00.000Z","21"],["2024-11-30T10:10:00.000Z","21"],["2024-11-30T10:15:00.000Z","21"],["2024-11-30T10:20:00.000Z","21"],["2024-11-30T10:25:00.000Z","21.06"],["2024-11-30T10:30:00.000Z","21.06"],["2024-11-30T10:35:00.000Z","21"],["2024-11-30T10:40:00.000Z","21.06"],["2024-11-30T10:45:00.000Z","21.19"],["2024-11-30T10:50:00.000Z","21.19"],["2024-11-30T10:55:00.000Z","21.19"],["2024-11-30T11:00:00.000Z","21.38"],["2024-11-30T11:05:00.000Z","21.5"],["2024-11-30T11:10:00.000Z","21.5"],["2024-11-30T11:15:00.000Z","21.62"],["2024-11-30T11:20:00.000Z","21.81"],["2024-11-30T11:25:00.000Z","21.88"],["2024-11-30T11:30:00.000Z","22"],["2024-11-30T11:35:00.000Z","21"],["2024-11-30T11:40:00.000Z","20"],["2024-11-30T11:45:00.000Z","19.56"],["2024-11-30T11:50:00.000Z","20.38"],["2024-11-30T11:55:00.000Z","20.94"],["2024-11-30T12:00:00.000Z","21.19"],["2024-11-30T12:05:00.000Z","20.19"],["2024-11-30T12:10:00.000Z","20.31"],["2024-11-30T12:15:00.000Z","20.94"],["2024-11-30T12:20:00.000Z","21.38"],["2024-11-30T12:25:00.000Z","21.62"],["2024-11-30T12:30:00.000Z","21.81"],["2024-11-30T12:35:00.000Z","21.88"],["2024-11-30T12:40:00.000Z","21.88"],["2024-11-30T12:45:00.000Z","21.88"],["2024-11-30T12:50:00.000Z","21.88"],["2024-11-30T12:55:00.000Z","21.88"],["2024-11-30T13:00:00.000Z","21.88"],["2024-11-30T13:05:00.000Z","22"],["2024-11-30T13:10:00.000Z","22"],["2024-11-30T13:15:00.000Z","22"],["2024-11-30T13:20:00.000Z","22"],["2024-11-30T13:25:00.000Z","21.88"],["2024-11-30T13:30:00.000Z","21.69"],["2024-11-30T13:35:00.000Z","21.5"],["2024-11-30T13:40:00.000Z","21.5"],["2024-11-30T13:45:00.000Z","21.38"],["2024-11-30T13:50:00.000Z","21.25"],["2024-11-30T13:55:00.000Z","21.25"],["2024-11-30T14:00:00.000Z","21.19"],["2024-11-30T14:05:00.000Z","21.06"],["2024-11-30T14:10:00.000Z","21"],["2024-11-30T14:15:00.000Z","21"],["2024-11-30T14:20:00.000Z","20.94"],["2024-11-30T14:25:00.000Z","20.81"],["2024-11-30T14:30:00.000Z","20.81"],["2024-11-30T14:35:00.000Z","20.81"],["2024-11-30T14:40:00.000Z","20.81"],["2024-11-30T14:45:00.000Z","20.81"],["2024-11-30T14:50:00.000Z","20.94"],["2024-11-30T14:55:00.000Z","20.81"],["2024-11-30T15:00:00.000Z","20.75"],["2024-11-30T15:05:00.000Z","20.81"],["2024-11-30T15:10:00.000Z","20.81"]]
                                        ebus.0
                                        	2024-11-30 16:15:08.639	debug	ReturnTemp 56.06 30.11.2024, 16:15:00
                                        ebus.0
                                        	2024-11-30 16:15:08.639	debug	history.value3 got [[{"ReturnTemp":"24.25"}],[{"ReturnTemp":"24.12"}],[{"ReturnTemp":"24.12"}],[{"ReturnTemp":"24.12"}],[{"ReturnTemp":"24.12"}],[{"ReturnTemp":"24.12"}],[{"ReturnTemp":"24.12"}],[{"ReturnTemp":"24.12"}],[{"ReturnTemp":"24"}],[{"ReturnTemp":"24"}],[{"ReturnTemp":"24"}],[{"ReturnTemp":"24"}],[{"ReturnTemp":"24"}],[{"ReturnTemp":"24"}],[{"ReturnTemp":"24"}],[{"ReturnTemp":"23.88"}],[{"ReturnTemp":"23.88"}],[{"ReturnTemp":"23.88"}],[{"ReturnTemp":"23.88"}],[{"ReturnTemp":"23.88"}],[{"ReturnTemp":"23.88"}],[{"ReturnTemp":"23.88"}],[{"ReturnTemp":"23.75"}],[{"ReturnTemp":"23.75"}],[{"ReturnTemp":"23.75"}],[{"ReturnTemp":"23.75"}],[{"ReturnTemp":"23.75"}],[{"ReturnTemp":"23.75"}],[{"ReturnTemp":"23.75"}],[{"ReturnTemp":"23.75"}],[{"ReturnTemp":"23.75"}],[{"ReturnTemp":"23.75"}],[{"ReturnTemp":"23.75"}],[{"ReturnTemp":"23.75"}],[{"ReturnTemp":"23.62"}],[{"ReturnTemp":"23.62"}],[{"ReturnTemp":"23.62"}],[{"ReturnTemp":"23.62"}],[{"ReturnTemp":"26"}],[{"ReturnTemp":"49.75"}],[{"ReturnTemp":"54.38"}],[{"ReturnTemp":"24.38"}],[{"ReturnTemp":"33"}],[{"ReturnTemp":"40"}],[{"ReturnTemp":"43.44"}],[{"ReturnTemp":"45.75"}],[{"ReturnTemp":"42.62"}],[{"ReturnTemp":"40.12"}],[{"ReturnTemp":"41.44"}],[{"ReturnTemp":"43.94"}],[{"ReturnTemp":"44.56"}],[{"ReturnTemp":"41.5"}],[{"ReturnTemp":"38.88"}],[{"ReturnTemp":"42.94"}],[{"ReturnTemp":"45.75"}],[{"ReturnTemp":"41.75"}],[{"ReturnTemp":"39.06"}],[{"ReturnTemp":"36.88"}],[{"ReturnTemp":"35.88"}],[{"ReturnTemp":"34.94"}],[{"ReturnTemp":"34.19"}],[{"ReturnTemp":"33.75"}],[{"ReturnTemp":"33.44"}],[{"ReturnTemp":"33.12"}],[{"ReturnTemp":"32.69"}],[{"ReturnTemp":"32.25"}],[{"ReturnTemp":"31.88"}],[{"ReturnTemp":"31.44"}],[{"ReturnTemp":"31.12"}],[{"ReturnTemp":"30.69"}],[{"ReturnTemp":"30.25"}],[{"ReturnTemp":"29.88"}],[{"ReturnTemp":"30.31"}],[{"ReturnTemp":"37.31"}],[{"ReturnTemp":"41.62"}],[{"ReturnTemp":"41.44"}],[{"ReturnTemp":"39"}],[{"ReturnTemp":"36.81"}],[{"ReturnTemp":"41.81"}],[{"ReturnTemp":"39.38"}],[{"ReturnTemp":"37.19"}],[{"ReturnTemp":"32.25"}],[{"ReturnTemp":"31.62"}],[{"ReturnTemp":"31.12"}],[{"ReturnTemp":"30.69"}],[{"ReturnTemp":"30.69"}],[{"ReturnTemp":"30.56"}],[{"ReturnTemp":"30.25"}],[{"ReturnTemp":"29.88"}],[{"ReturnTemp":"29.56"}],[{"ReturnTemp":"29.12"}],[{"ReturnTemp":"28.81"}],[{"ReturnTemp":"28.5"}],[{"ReturnTemp":"28.25"}],[{"ReturnTemp":"27.94"}],[{"ReturnTemp":"27.69"}],[{"ReturnTemp":"27.5"}],[{"ReturnTemp":"27.12"}],[{"ReturnTemp":"26.88"}],[{"ReturnTemp":"26.69"}],[{"ReturnTemp":"26.44"}],[{"ReturnTemp":"26.31"}],[{"ReturnTemp":"26.06"}],[{"ReturnTemp":"26"}],[{"ReturnTemp":"25.75"}],[{"ReturnTemp":"25.5"}],[{"ReturnTemp":"25.31"}],[{"ReturnTemp":"25.06"}],[{"ReturnTemp":"24.94"}],[{"ReturnTemp":"24.69"}],["2024-11-30T07:45:00.000Z","24"],["2024-11-30T07:50:00.000Z","35"],["2024-11-30T07:55:00.000Z","45.56"],["2024-11-30T08:00:00.000Z","50.75"],["2024-11-30T08:05:00.000Z","52"],["2024-11-30T08:10:00.000Z","52.31"],["2024-11-30T08:15:00.000Z","52.62"],["2024-11-30T08:20:00.000Z","52.88"],["2024-11-30T08:25:00.000Z","53.31"],["2024-11-30T08:30:00.000Z","53.69"],["2024-11-30T08:35:00.000Z","54.38"],["2024-11-30T08:40:00.000Z","49.25"],["2024-11-30T08:45:00.000Z","47.38"],["2024-11-30T08:50:00.000Z","50.44"],["2024-11-30T08:55:00.000Z","46.25"],["2024-11-30T09:00:00.000Z","42.94"],["2024-11-30T09:05:00.000Z","46.5"],["2024-11-30T09:10:00.000Z","49.56"],["2024-11-30T09:15:00.000Z","49.88"],["2024-11-30T09:20:00.000Z","45.56"],["2024-11-30T09:25:00.000Z","44.25"],["2024-11-30T09:30:00.000Z","45.44"],["2024-11-30T09:35:00.000Z","41.81"],["2024-11-30T09:40:00.000Z","40.12"],["2024-11-30T09:45:00.000Z","43.25"],["2024-11-30T09:50:00.000Z","39.25"],["2024-11-30T09:55:00.000Z","36.88"],["2024-11-30T10:00:00.000Z","35.44"],["2024-11-30T10:05:00.000Z","33.69"],["2024-11-30T10:10:00.000Z","33.56"],["2024-11-30T10:15:00.000Z","37.94"],["2024-11-30T10:20:00.000Z","34.5"],["2024-11-30T10:25:00.000Z","32.81"],["2024-11-30T10:30:00.000Z","32.19"],["2024-11-30T10:35:00.000Z","29.56"],["2024-11-30T10:40:00.000Z","28.81"],["2024-11-30T10:45:00.000Z","32.06"],["2024-11-30T10:50:00.000Z","30.25"],["2024-11-30T10:55:00.000Z","29.25"],["2024-11-30T11:00:00.000Z","27"],["2024-11-30T11:05:00.000Z","26.81"],["2024-11-30T11:10:00.000Z","26.88"],["2024-11-30T11:15:00.000Z","27.12"],["2024-11-30T11:20:00.000Z","27.12"],["2024-11-30T11:25:00.000Z","27"],["2024-11-30T11:30:00.000Z","26.88"],["2024-11-30T11:35:00.000Z","26.81"],["2024-11-30T11:40:00.000Z","28.69"],["2024-11-30T11:45:00.000Z","35"],["2024-11-30T11:50:00.000Z","39.25"],["2024-11-30T11:55:00.000Z","40.62"],["2024-11-30T12:00:00.000Z","37.81"],["2024-11-30T12:05:00.000Z","36.69"],["2024-11-30T12:10:00.000Z","34.31"],["2024-11-30T12:15:00.000Z","32.69"],["2024-11-30T12:20:00.000Z","35"],["2024-11-30T12:25:00.000Z","32.69"],["2024-11-30T12:30:00.000Z","31.56"],["2024-11-30T12:35:00.000Z","30.69"],["2024-11-30T12:40:00.000Z","30.44"],["2024-11-30T12:45:00.000Z","30.12"],["2024-11-30T12:50:00.000Z","29.88"],["2024-11-30T12:55:00.000Z","29.88"],["2024-11-30T13:00:00.000Z","29.88"],["2024-11-30T13:05:00.000Z","29.81"],["2024-11-30T13:10:00.000Z","29.56"],["2024-11-30T13:15:00.000Z","29.44"],["2024-11-30T13:20:00.000Z","29.25"],["2024-11-30T13:25:00.000Z","29"],["2024-11-30T13:30:00.000Z","28.69"],["2024-11-30T13:35:00.000Z","28.5"],["2024-11-30T13:40:00.000Z","28.25"],["2024-11-30T13:45:00.000Z","28.06"],["2024-11-30T13:50:00.000Z","27.81"],["2024-11-30T13:55:00.000Z","27.56"],["2024-11-30T14:00:00.000Z","27.38"],["2024-11-30T14:05:00.000Z","27.12"],["2024-11-30T14:10:00.000Z","26.88"],["2024-11-30T14:15:00.000Z","26.69"],["2024-11-30T14:20:00.000Z","26.44"],["2024-11-30T14:25:00.000Z","26.06"],["2024-11-30T14:30:00.000Z","24.81"],["2024-11-30T14:35:00.000Z","31.75"],["2024-11-30T14:40:00.000Z","37.81"],["2024-11-30T14:45:00.000Z","41.31"],["2024-11-30T14:50:00.000Z","42.44"],["2024-11-30T14:55:00.000Z","39.25"],["2024-11-30T15:00:00.000Z","37.12"],["2024-11-30T15:05:00.000Z","50.56"],["2024-11-30T15:10:00.000Z","50.75"]]
                                        ebus.0
                                        	2024-11-30 16:15:08.628	debug	FlowTemp 60.5 30.11.2024, 16:15:00
                                        ebus.0
                                        	2024-11-30 16:15:08.628	debug	history.value2 got [[{"FlowTemp":"23.5"}],[{"FlowTemp":"23.38"}],[{"FlowTemp":"23.38"}],[{"FlowTemp":"23.38"}],[{"FlowTemp":"23.38"}],[{"FlowTemp":"23.38"}],[{"FlowTemp":"23.38"}],[{"FlowTemp":"23.25"}],[{"FlowTemp":"23.25"}],[{"FlowTemp":"23.25"}],[{"FlowTemp":"23.25"}],[{"FlowTemp":"23.25"}],[{"FlowTemp":"23.25"}],[{"FlowTemp":"23.12"}],[{"FlowTemp":"23.12"}],[{"FlowTemp":"23.12"}],[{"FlowTemp":"23.12"}],[{"FlowTemp":"23.12"}],[{"FlowTemp":"23.12"}],[{"FlowTemp":"23.12"}],[{"FlowTemp":"23"}],[{"FlowTemp":"23"}],[{"FlowTemp":"23"}],[{"FlowTemp":"23"}],[{"FlowTemp":"23"}],[{"FlowTemp":"23"}],[{"FlowTemp":"23"}],[{"FlowTemp":"22.88"}],[{"FlowTemp":"22.88"}],[{"FlowTemp":"22.88"}],[{"FlowTemp":"22.88"}],[{"FlowTemp":"22.88"}],[{"FlowTemp":"22.88"}],[{"FlowTemp":"22.88"}],[{"FlowTemp":"22.88"}],[{"FlowTemp":"22.88"}],[{"FlowTemp":"22.88"}],[{"FlowTemp":"22.88"}],[{"FlowTemp":"22.88"}],[{"FlowTemp":"56.06"}],[{"FlowTemp":"58.69"}],[{"FlowTemp":"35.12"}],[{"FlowTemp":"45.38"}],[{"FlowTemp":"48.62"}],[{"FlowTemp":"49.62"}],[{"FlowTemp":"51.81"}],[{"FlowTemp":"42.56"}],[{"FlowTemp":"39.88"}],[{"FlowTemp":"47.5"}],[{"FlowTemp":"49.94"}],[{"FlowTemp":"44.75"}],[{"FlowTemp":"41.31"}],[{"FlowTemp":"46.88"}],[{"FlowTemp":"49.06"}],[{"FlowTemp":"46.06"}],[{"FlowTemp":"41.5"}],[{"FlowTemp":"38.88"}],[{"FlowTemp":"36.69"}],[{"FlowTemp":"35.88"}],[{"FlowTemp":"35.44"}],[{"FlowTemp":"34.81"}],[{"FlowTemp":"34.19"}],[{"FlowTemp":"33.56"}],[{"FlowTemp":"33"}],[{"FlowTemp":"32.62"}],[{"FlowTemp":"32.19"}],[{"FlowTemp":"31.88"}],[{"FlowTemp":"31.44"}],[{"FlowTemp":"31"}],[{"FlowTemp":"30.69"}],[{"FlowTemp":"30.25"}],[{"FlowTemp":"29.88"}],[{"FlowTemp":"36.81"}],[{"FlowTemp":"45.25"}],[{"FlowTemp":"47.81"}],[{"FlowTemp":"41.5"}],[{"FlowTemp":"38.75"}],[{"FlowTemp":"36.56"}],[{"FlowTemp":"47.81"}],[{"FlowTemp":"39.25"}],[{"FlowTemp":"37"}],[{"FlowTemp":"32.06"}],[{"FlowTemp":"31.56"}],[{"FlowTemp":"31.31"}],[{"FlowTemp":"31"}],[{"FlowTemp":"30.56"}],[{"FlowTemp":"30.31"}],[{"FlowTemp":"30.12"}],[{"FlowTemp":"29.88"}],[{"FlowTemp":"29.56"}],[{"FlowTemp":"29.25"}],[{"FlowTemp":"28.94"}],[{"FlowTemp":"28.56"}],[{"FlowTemp":"28.25"}],[{"FlowTemp":"28.06"}],[{"FlowTemp":"27.69"}],[{"FlowTemp":"27.5"}],[{"FlowTemp":"27.25"}],[{"FlowTemp":"27"}],[{"FlowTemp":"26.81"}],[{"FlowTemp":"26.56"}],[{"FlowTemp":"26.69"}],[{"FlowTemp":"27.12"}],[{"FlowTemp":"27"}],[{"FlowTemp":"27"}],[{"FlowTemp":"26.88"}],[{"FlowTemp":"26.69"}],[{"FlowTemp":"26.44"}],[{"FlowTemp":"26.19"}],[{"FlowTemp":"26"}],["2024-11-30T07:45:00.000Z","31.56"],["2024-11-30T07:50:00.000Z","50.88"],["2024-11-30T07:55:00.000Z","57.44"],["2024-11-30T08:00:00.000Z","58.25"],["2024-11-30T08:05:00.000Z","57.75"],["2024-11-30T08:10:00.000Z","58.06"],["2024-11-30T08:15:00.000Z","58.38"],["2024-11-30T08:20:00.000Z","58.56"],["2024-11-30T08:25:00.000Z","58.94"],["2024-11-30T08:30:00.000Z","59.38"],["2024-11-30T08:35:00.000Z","54.75"],["2024-11-30T08:40:00.000Z","49.06"],["2024-11-30T08:45:00.000Z","53"],["2024-11-30T08:50:00.000Z","56.12"],["2024-11-30T08:55:00.000Z","46.19"],["2024-11-30T09:00:00.000Z","42.75"],["2024-11-30T09:05:00.000Z","52.25"],["2024-11-30T09:10:00.000Z","55.44"],["2024-11-30T09:15:00.000Z","49.94"],["2024-11-30T09:20:00.000Z","45.38"],["2024-11-30T09:25:00.000Z","49.88"],["2024-11-30T09:30:00.000Z","45.69"],["2024-11-30T09:35:00.000Z","41.62"],["2024-11-30T09:40:00.000Z","45.25"],["2024-11-30T09:45:00.000Z","43.25"],["2024-11-30T09:50:00.000Z","39.06"],["2024-11-30T09:55:00.000Z","36.69"],["2024-11-30T10:00:00.000Z","35.25"],["2024-11-30T10:05:00.000Z","33.44"],["2024-11-30T10:10:00.000Z","39.5"],["2024-11-30T10:15:00.000Z","37.94"],["2024-11-30T10:20:00.000Z","34.31"],["2024-11-30T10:25:00.000Z","32.62"],["2024-11-30T10:30:00.000Z","31.88"],["2024-11-30T10:35:00.000Z","29.38"],["2024-11-30T10:40:00.000Z","28.56"],["2024-11-30T10:45:00.000Z","31.94"],["2024-11-30T10:50:00.000Z","30.12"],["2024-11-30T10:55:00.000Z","29"],["2024-11-30T11:00:00.000Z","26.88"],["2024-11-30T11:05:00.000Z","26.81"],["2024-11-30T11:10:00.000Z","26.81"],["2024-11-30T11:15:00.000Z","26.69"],["2024-11-30T11:20:00.000Z","26.69"],["2024-11-30T11:25:00.000Z","26.69"],["2024-11-30T11:30:00.000Z","26.69"],["2024-11-30T11:35:00.000Z","26.56"],["2024-11-30T11:40:00.000Z","35.25"],["2024-11-30T11:45:00.000Z","43.56"],["2024-11-30T11:50:00.000Z","45.56"],["2024-11-30T11:55:00.000Z","40.62"],["2024-11-30T12:00:00.000Z","37.62"],["2024-11-30T12:05:00.000Z","36.56"],["2024-11-30T12:10:00.000Z","34.06"],["2024-11-30T12:15:00.000Z","32.5"],["2024-11-30T12:20:00.000Z","35.12"],["2024-11-30T12:25:00.000Z","32.62"],["2024-11-30T12:30:00.000Z","31.31"],["2024-11-30T12:35:00.000Z","30.56"],["2024-11-30T12:40:00.000Z","30.31"],["2024-11-30T12:45:00.000Z","30.25"],["2024-11-30T12:50:00.000Z","29.88"],["2024-11-30T12:55:00.000Z","29.69"],["2024-11-30T13:00:00.000Z","29.38"],["2024-11-30T13:05:00.000Z","29.25"],["2024-11-30T13:10:00.000Z","29"],["2024-11-30T13:15:00.000Z","28.94"],["2024-11-30T13:20:00.000Z","28.81"],["2024-11-30T13:25:00.000Z","28.69"],["2024-11-30T13:30:00.000Z","28.5"],["2024-11-30T13:35:00.000Z","28.25"],["2024-11-30T13:40:00.000Z","28.06"],["2024-11-30T13:45:00.000Z","27.81"],["2024-11-30T13:50:00.000Z","27.69"],["2024-11-30T13:55:00.000Z","27.5"],["2024-11-30T14:00:00.000Z","27.25"],["2024-11-30T14:05:00.000Z","27.25"],["2024-11-30T14:10:00.000Z","27.38"],["2024-11-30T14:15:00.000Z","27.12"],["2024-11-30T14:20:00.000Z","27.25"],["2024-11-30T14:25:00.000Z","26.88"],["2024-11-30T14:30:00.000Z","31.19"],["2024-11-30T14:35:00.000Z","40.94"],["2024-11-30T14:40:00.000Z","45.06"],["2024-11-30T14:45:00.000Z","47.5"],["2024-11-30T14:50:00.000Z","42.56"],["2024-11-30T14:55:00.000Z","39.06"],["2024-11-30T15:00:00.000Z","43.25"],["2024-11-30T15:05:00.000Z","60.5"],["2024-11-30T15:10:00.000Z","55.44"]]
                                        ebus.0
                                        	2024-11-30 16:15:08.618	debug	OutsideTemp 6.69 30.11.2024, 16:15:00
                                        ebus.0
                                        	2024-11-30 16:15:08.618	debug	history.value1 got [[{"OutsideTemp":"7.75"}],[{"OutsideTemp":"7.75"}],[{"OutsideTemp":"7.56"}],[{"OutsideTemp":"7.56"}],[{"OutsideTemp":"7.31"}],[{"OutsideTemp":"7.31"}],[{"OutsideTemp":"7.31"}],[{"OutsideTemp":"7.12"}],[{"OutsideTemp":"7.12"}],[{"OutsideTemp":"7.12"}],[{"OutsideTemp":"7.12"}],[{"OutsideTemp":"6.88"}],[{"OutsideTemp":"6.88"}],[{"OutsideTemp":"6.88"}],[{"OutsideTemp":"6.88"}],[{"OutsideTemp":"6.69"}],[{"OutsideTemp":"6.69"}],[{"OutsideTemp":"6.69"}],[{"OutsideTemp":"6.44"}],[{"OutsideTemp":"6.44"}],[{"OutsideTemp":"6.44"}],[{"OutsideTemp":"6.44"}],[{"OutsideTemp":"6.44"}],[{"OutsideTemp":"6.25"}],[{"OutsideTemp":"6.25"}],[{"OutsideTemp":"6.25"}],[{"OutsideTemp":"6.25"}],[{"OutsideTemp":"6"}],[{"OutsideTemp":"6"}],[{"OutsideTemp":"6"}],[{"OutsideTemp":"6"}],[{"OutsideTemp":"6"}],[{"OutsideTemp":"6"}],[{"OutsideTemp":"6"}],[{"OutsideTemp":"6"}],[{"OutsideTemp":"6"}],[{"OutsideTemp":"6"}],[{"OutsideTemp":"6"}],[{"OutsideTemp":"6"}],[{"OutsideTemp":"6"}],[{"OutsideTemp":"6"}],[{"OutsideTemp":"6"}],[{"OutsideTemp":"6"}],[{"OutsideTemp":"6"}],[{"OutsideTemp":"6"}],[{"OutsideTemp":"6"}],[{"OutsideTemp":"6"}],[{"OutsideTemp":"6"}],[{"OutsideTemp":"6"}],[{"OutsideTemp":"6.25"}],[{"OutsideTemp":"6.25"}],[{"OutsideTemp":"6.25"}],[{"OutsideTemp":"6.44"}],[{"OutsideTemp":"6.44"}],[{"OutsideTemp":"6.44"}],[{"OutsideTemp":"6.44"}],[{"OutsideTemp":"6.69"}],[{"OutsideTemp":"6.69"}],[{"OutsideTemp":"6.88"}],[{"OutsideTemp":"6.88"}],[{"OutsideTemp":"7.12"}],[{"OutsideTemp":"7.75"}],[{"OutsideTemp":"8.38"}],[{"OutsideTemp":"8.62"}],[{"OutsideTemp":"8.19"}],[{"OutsideTemp":"8"}],[{"OutsideTemp":"7.56"}],[{"OutsideTemp":"7.31"}],[{"OutsideTemp":"7.31"}],[{"OutsideTemp":"7.31"}],[{"OutsideTemp":"7.31"}],[{"OutsideTemp":"7.31"}],[{"OutsideTemp":"7.31"}],[{"OutsideTemp":"7.12"}],[{"OutsideTemp":"7.56"}],[{"OutsideTemp":"7.56"}],[{"OutsideTemp":"7.75"}],[{"OutsideTemp":"8"}],[{"OutsideTemp":"8"}],[{"OutsideTemp":"8"}],[{"OutsideTemp":"8"}],[{"OutsideTemp":"8"}],[{"OutsideTemp":"8"}],[{"OutsideTemp":"8"}],[{"OutsideTemp":"8"}],[{"OutsideTemp":"8"}],[{"OutsideTemp":"8"}],[{"OutsideTemp":"8"}],[{"OutsideTemp":"8"}],[{"OutsideTemp":"8"}],[{"OutsideTemp":"7.75"}],[{"OutsideTemp":"7.75"}],[{"OutsideTemp":"7.75"}],[{"OutsideTemp":"7.75"}],[{"OutsideTemp":"7.56"}],[{"OutsideTemp":"7.56"}],[{"OutsideTemp":"7.75"}],[{"OutsideTemp":"7.56"}],[{"OutsideTemp":"7.75"}],[{"OutsideTemp":"7.75"}],[{"OutsideTemp":"7.75"}],[{"OutsideTemp":"7.75"}],[{"OutsideTemp":"7.75"}],[{"OutsideTemp":"7.56"}],[{"OutsideTemp":"7.56"}],[{"OutsideTemp":"7.56"}],[{"OutsideTemp":"7.56"}],[{"OutsideTemp":"7.56"}],[{"OutsideTemp":"7.56"}],[{"OutsideTemp":"7.56"}],["2024-11-30T07:45:00.000Z","-0.88"],["2024-11-30T07:50:00.000Z","-0.88"],["2024-11-30T07:55:00.000Z","-0.88"],["2024-11-30T08:00:00.000Z","-0.88"],["2024-11-30T08:05:00.000Z","-0.88"],["2024-11-30T08:10:00.000Z","-0.62"],["2024-11-30T08:15:00.000Z","-0.62"],["2024-11-30T08:20:00.000Z","-0.62"],["2024-11-30T08:25:00.000Z","-0.44"],["2024-11-30T08:30:00.000Z","-0.44"],["2024-11-30T08:35:00.000Z","-0.44"],["2024-11-30T08:40:00.000Z","-0.19"],["2024-11-30T08:45:00.000Z","-0.19"],["2024-11-30T08:50:00.000Z","0.06"],["2024-11-30T08:55:00.000Z","0.31"],["2024-11-30T09:00:00.000Z","0.56"],["2024-11-30T09:05:00.000Z","1.06"],["2024-11-30T09:10:00.000Z","1.56"],["2024-11-30T09:15:00.000Z","2.5"],["2024-11-30T09:20:00.000Z","3.75"],["2024-11-30T09:25:00.000Z","4.94"],["2024-11-30T09:30:00.000Z","5.56"],["2024-11-30T09:35:00.000Z","6.25"],["2024-11-30T09:40:00.000Z","7.12"],["2024-11-30T09:45:00.000Z","7.75"],["2024-11-30T09:50:00.000Z","8.19"],["2024-11-30T09:55:00.000Z","8.81"],["2024-11-30T10:00:00.000Z","9.5"],["2024-11-30T10:05:00.000Z","9.94"],["2024-11-30T10:10:00.000Z","10.56"],["2024-11-30T10:15:00.000Z","11"],["2024-11-30T10:20:00.000Z","11.44"],["2024-11-30T10:25:00.000Z","12.06"],["2024-11-30T10:30:00.000Z","12.25"],["2024-11-30T10:35:00.000Z","12.5"],["2024-11-30T10:40:00.000Z","11.88"],["2024-11-30T10:45:00.000Z","11.25"],["2024-11-30T10:50:00.000Z","10.81"],["2024-11-30T10:55:00.000Z","10.38"],["2024-11-30T11:00:00.000Z","10.12"],["2024-11-30T11:05:00.000Z","9.94"],["2024-11-30T11:10:00.000Z","9.69"],["2024-11-30T11:15:00.000Z","9.5"],["2024-11-30T11:20:00.000Z","9.25"],["2024-11-30T11:25:00.000Z","9.06"],["2024-11-30T11:30:00.000Z","9.06"],["2024-11-30T11:35:00.000Z","9.06"],["2024-11-30T11:40:00.000Z","9.06"],["2024-11-30T11:45:00.000Z","9.06"],["2024-11-30T11:50:00.000Z","9.06"],["2024-11-30T11:55:00.000Z","9.06"],["2024-11-30T12:00:00.000Z","9.06"],["2024-11-30T12:05:00.000Z","9.06"],["2024-11-30T12:10:00.000Z","9.25"],["2024-11-30T12:15:00.000Z","9.06"],["2024-11-30T12:20:00.000Z","9.06"],["2024-11-30T12:25:00.000Z","9.06"],["2024-11-30T12:30:00.000Z","9.06"],["2024-11-30T12:35:00.000Z","9.06"],["2024-11-30T12:40:00.000Z","9.06"],["2024-11-30T12:45:00.000Z","9.25"],["2024-11-30T12:50:00.000Z","9.25"],["2024-11-30T12:55:00.000Z","9.25"],["2024-11-30T13:00:00.000Z","9.25"],["2024-11-30T13:05:00.000Z","9.25"],["2024-11-30T13:10:00.000Z","9.25"],["2024-11-30T13:15:00.000Z","9.25"],["2024-11-30T13:20:00.000Z","9.25"],["2024-11-30T13:25:00.000Z","9.06"],["2024-11-30T13:30:00.000Z","9.06"],["2024-11-30T13:35:00.000Z","8.81"],["2024-11-30T13:40:00.000Z","8.81"],["2024-11-30T13:45:00.000Z","8.62"],["2024-11-30T13:50:00.000Z","8.38"],["2024-11-30T13:55:00.000Z","8.19"],["2024-11-30T14:00:00.000Z","8.19"],["2024-11-30T14:05:00.000Z","8"],["2024-11-30T14:10:00.000Z","8"],["2024-11-30T14:15:00.000Z","7.75"],["2024-11-30T14:20:00.000Z","7.75"],["2024-11-30T14:25:00.000Z","7.56"],["2024-11-30T14:30:00.000Z","7.56"],["2024-11-30T14:35:00.000Z","7.31"],["2024-11-30T14:40:00.000Z","7.31"],["2024-11-30T14:45:00.000Z","7.31"],["2024-11-30T14:50:00.000Z","7.31"],["2024-11-30T14:55:00.000Z","7.12"],["2024-11-30T15:00:00.000Z","7.12"],["2024-11-30T15:05:00.000Z","6.88"],["2024-11-30T15:10:00.000Z","6.88"]]
                                        ebus.0
                                        	2024-11-30 16:15:08.566	debug	start history 4 VIS-2 [[{"OutsideTemp":"6.69"}],[{"FlowTemp":"60.5"}],[{"ReturnTemp":"56.06"}],[{"DisplayedRoomTemp":"20.75"}]] [{"date":"30.11.2024","time":"16:15:7"}]
                                        ebus.0
                                        	2024-11-30 16:15:08.566	info	all http done
                                        ebus.0
                                        	2024-11-30 16:15:08.559	debug	updateObject global.lastup : 30.11.2024, 16:15:07
                                        ebus.0
                                        	2024-11-30 16:15:08.554	debug	updateObject global.messages : 424
                                        ebus.0
                                        	2024-11-30 16:15:08.548	debug	updateObject global.masters : 3
                                        ebus.0
                                        	2024-11-30 16:15:08.543	debug	updateObject global.reconnects : 0
                                        ebus.0
                                        	2024-11-30 16:15:08.538	debug	updateObject global.qq : 49
                                        ebus.0
                                        	2024-11-30 16:15:08.533	debug	updateObject global.maxsymbollatency : 6
                                        ebus.0
                                        	2024-11-30 16:15:08.528	debug	updateObject global.minsymbollatency : 4
                                        ebus.0
                                        	2024-11-30 16:15:08.523	debug	updateObject global.maxarbitrationmicros : 166
                                        ebus.0
                                        	2024-11-30 16:15:08.518	debug	updateObject global.minarbitrationmicros : 2
                                        ebus.0
                                        	2024-11-30 16:15:08.513	debug	updateObject global.maxsymbolrate : 146
                                        ebus.0
                                        	2024-11-30 16:15:08.508	debug	updateObject global.symbolrate : 128
                                        ebus.0
                                        	2024-11-30 16:15:08.503	debug	updateObject global.signal : true
                                        ebus.0
                                        	2024-11-30 16:15:08.498	debug	updateObject global.updatecheck : version 24.1 available
                                        ebus.0
                                        	2024-11-30 16:15:08.496	info	please update ebusd, old version found: 23.3 supported version is 24.1
                                        ebus.0
                                        	2024-11-30 16:15:08.496	info	found ebusd update version version 24.1
                                        ebus.0
                                        	2024-11-30 16:15:08.451	debug	updateObject global.version : 23.3.23.3
                                        ebus.0
                                        	2024-11-30 16:15:08.449	info	please update ebusd, old version found: 23.3 supported version is 24.1
                                        ebus.0
                                        	2024-11-30 16:15:08.448	info	installed ebusd version is 23.3
                                        ebus.0
                                        	2024-11-30 16:15:08.444	debug	updateObject scan.26.messages.id.fields.suffix.name : id
                                        ebus.0
                                        	2024-11-30 16:15:08.439	debug	updateObject scan.26.messages.id.fields.suffix.value : N7
                                        ebus.0
                                        	2024-11-30 16:15:08.435	debug	updateObject scan.26.messages.id.fields.counter.name : id
                                        ebus.0
                                        	2024-11-30 16:15:08.430	debug	updateObject scan.26.messages.id.fields.counter.value : 010914
                                        ebus.0
                                        	2024-11-30 16:15:08.425	debug	updateObject scan.26.messages.id.fields.supplier.name : id
                                        ebus.0
                                        	2024-11-30 16:15:08.420	debug	updateObject scan.26.messages.id.fields.supplier.value : 0907
                                        ebus.0
                                        	2024-11-30 16:15:08.415	debug	updateObject scan.26.messages.id.fields.product.name : id
                                        ebus.0
                                        	2024-11-30 16:15:08.410	debug	updateObject scan.26.messages.id.fields.product.value : 0020028515
                                        ebus.0
                                        	2024-11-30 16:15:08.405	debug	updateObject scan.26.messages.id.fields.week.name : id
                                        ebus.0
                                        	2024-11-30 16:15:08.400	debug	updateObject scan.26.messages.id.fields.week.value : 47
                                        ebus.0
                                        	2024-11-30 16:15:08.394	debug	updateObject scan.26.messages.id.fields.year.name : id
                                        ebus.0
                                        	2024-11-30 16:15:08.388	debug	updateObject scan.26.messages.id.fields.year.value : 10
                                        ebus.0
                                        	2024-11-30 16:15:08.383	debug	updateObject scan.26.messages.id.fields.prefix.name : id
                                        ebus.0
                                        	2024-11-30 16:15:08.378	debug	updateObject scan.26.messages.id.fields.prefix.value : 21
                                        ebus.0
                                        	2024-11-30 16:15:08.373	debug	updateObject scan.26.messages.id.lastup : 30.11.2024, 08:39:57
                                        ebus.0
                                        	2024-11-30 16:15:08.367	debug	updateObject scan.26.messages..fields.HW.name :
                                        ebus.0
                                        	2024-11-30 16:15:08.361	debug	updateObject scan.26.messages..fields.HW.value : 2002
                                        ebus.0
                                        	2024-11-30 16:15:08.356	debug	updateObject scan.26.messages..fields.SW.name :
                                        ebus.0
                                        	2024-11-30 16:15:08.351	debug	updateObject scan.26.messages..fields.SW.value : 0215
                                        ebus.0
                                        	2024-11-30 16:15:08.347	debug	updateObject scan.26.messages..fields.ID.name :
                                        ebus.0
                                        	2024-11-30 16:15:08.342	debug	updateObject scan.26.messages..fields.ID.value : 43000
                                        ebus.0
                                        	2024-11-30 16:15:08.337	debug	updateObject scan.26.messages..fields.MF.name :
                                        ebus.0
                                        	2024-11-30 16:15:08.332	debug	updateObject scan.26.messages..fields.MF.value : Vaillantcode_text
                                        Allerdings habe ich das noch
                                        host.raspberrypi
                                        	2024-11-30 16:20:00.030	warn	instance system.adapter.ebus.0 already running with pid 1108code_text
                                        Das habe ich aber schon seit ewig und auch hier schon mal gepostet.
                                        Bin mal gespannt was das wieder ist. Mit dem Update kann es nichts zu tun haben weil ich auch die SD Karte mit komplettem Backup gestern gewechselt habe. Auch da ging es sofort wieder und heute morgen nicht mehr. Da ich nur alle 10min die Daten abfrage könnte das beim ersten mal auch noch ein alter Stand sein.
                                        Für was ist das Häckchen bei VIS-2-Widget, mach es jetzt mal raus.
                                        In Putty unter service ebusd status steht:
                                        pi@raspberrypi:~ $ pi@raspberrypi:~ $ sudo service ebusd status
                                        ● ebusd.service - ebusd, the daemon for communication with eBUS heating systems.
                                             Loaded: loaded (/etc/systemd/system/ebusd.service; enabled; vendor preset: enabled)
                                             Active: active (running) since Sat 2024-11-30 17:04:47 CET; 48s ago
                                            Process: 2042 ExecStart=/usr/bin/ebusd $EBUSD_OPTS (code=exited, status=0/SUCCESS)
                                           Main PID: 2043 (ebusd)
                                              Tasks: 4 (limit: 4915)
                                                CPU: 282ms
                                             CGroup: /system.slice/ebusd.service
                                                     └─2043 /usr/bin/ebusd -d /dev/ttyUSB0 --port=8888 --httpport=8891 --configpath=http://cfg.ebusd.eu/ --scanconfig=full
                                        Nov 30 17:04:47 raspberrypi systemd[1]: Starting ebusd, the daemon for communication with eBUS heating systems....
                                        Nov 30 17:04:47 raspberrypi systemd[1]: Started ebusd, the daemon for communication with eBUS heating systems..code_text
                                        LG Horst
                                        • Rene_HMR Offline
                                          Rene_HMR Offline
                                          Rene_HM
                                          #635
                                          @hasont Im ersten Bild steht "exception in parse data". Das heisst, das widget kommt mit den Daten, die geliefert werden, nicht zurecht. Hier wäre es interssant, ein log aus der Browser-Konsole zu sehen (STRG-Umschalt-J im firefox)
                                          Es gibt ein widget für vis-2, wenn du noch die alte vis verwendest, muss der Haken raus...
