  4. Adapter: ebus
    6.7k
Adapter: ebus
ebus adapter
712 Beiträge 73 Kommentatoren 332.7k Aufrufe 60 Beobachtet
  • Thomas BraunT Online
    #614
    @thiozinc
    Das sieht schon mal gut aus. Die Langfassung verrät?
      @thiozinc
      thiozinc
      #615
      Skript v.2024-05-22
      *** BASE SYSTEM ***
       Static hostname: raspberrypi
             Icon name: computer
                Kernel: Linux 6.6.31+rpt-rpi-v8
          Architecture: arm64
      Model		: Raspberry Pi 4 Model B Rev 1.1
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : 64 bit
      Systemuptime and Load:
       23:01:46 up 14 days,  3:14,  2 users,  load average: 1.05, 1.34, 1.15
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Thu 2024-08-22 23:01:46 CEST
                 Universal time: Thu 2024-08-22 21:01:46 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      pi
      HOME=/home/pi
      GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout sudo audio video bluetooth gpio i2c
      *** Display-Server-Setup ***
      Display-Server: false
      Desktop:
      Terminal: 	tty
      Boot Target: 	multi-user.target
      *** MEMORY ***
      Mem:            4.0G        2.8G        541M        135K        679M        1.2G
      Swap:           209M        195M         13M
      Total:          4.2G        3.0G        555M
      Active iob-Instances: 	29
               3792 M total memory
               2689 M used memory
               2254 M active memory
                833 M inactive memory
                516 M free memory
                 75 M buffer memory
                572 M swap cache
                199 M total swap
                186 M used swap
                 13 M free swap
      top - 23:01:46 up 14 days,  3:14,  2 users,  load average: 1.05, 1.34, 1.15
      Tasks: 216 total,   1 running, 215 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  0.0 us, 40.0 sy,  0.0 ni, 60.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   3792.1 total,    515.9 free,   2689.6 used,    647.8 buff/cache
      MiB Swap:    200.0 total,     13.1 free,    186.9 used.   1102.5 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** FILESYSTEM ***
      udev           devtmpfs  1.6G     0  1.6G   0% /dev
      tmpfs          tmpfs     380M  1.3M  378M   1% /run
      /dev/mmcblk0p2 ext4       29G  9.5G   18G  35% /
      tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
      /dev/mmcblk0p1 vfat      510M   64M  447M  13% /boot/firmware
      /dev/sda1      ext4      116G  1.7G  109G   2% /media/usbdisk
      tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
      [Thu Aug  8 19:47:22 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:30:B4:93 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=68b36b16-02 rootfstype=ext4 fsck.repair=yes rootwait
      [Thu Aug  8 19:47:26 2024] EXT4-fs (mmcblk0p2): mounted filesystem 3b614a3f-4a65-4480-876a-8a998e01ac9b ro with ordered data mode. Quota mode: none.
      [Thu Aug  8 19:47:29 2024] EXT4-fs (mmcblk0p2): re-mounted 3b614a3f-4a65-4480-876a-8a998e01ac9b r/w. Quota mode: none.
      [Thu Aug  8 19:47:32 2024] EXT4-fs (sda1): warning: mounting fs with errors, running e2fsck is recommended
      [Thu Aug  8 19:47:32 2024] EXT4-fs (sda1): mounted filesystem 3d241c43-2bbf-49ce-a4f9-270fcb182309 r/w with ordered data mode. Quota mode: none.
      [Thu Aug  8 19:47:36 2024] EXT4-fs error (device sda1): ext4_validate_block_bitmap:421: comm ext4lazyinit: bg 122: bad block bitmap checksum
      [Thu Aug  8 19:47:36 2024] EXT4-fs error (device sda1): ext4_validate_block_bitmap:421: comm ext4lazyinit: bg 203: bad block bitmap checksum
      [Thu Aug  8 19:52:38 2024] EXT4-fs (sda1): error count since last fsck: 71
      [Thu Aug  8 19:52:38 2024] EXT4-fs (sda1): initial error at time 1668261680: ext4_validate_block_bitmap:390
      [Thu Aug  8 19:52:38 2024] EXT4-fs (sda1): last error at time 1723139237: ext4_validate_block_bitmap:421
      [Fri Aug  9 21:30:18 2024] EXT4-fs (sda1): error count since last fsck: 71
      [Fri Aug  9 21:30:18 2024] EXT4-fs (sda1): initial error at time 1668261680: ext4_validate_block_bitmap:390
      [Fri Aug  9 21:30:18 2024] EXT4-fs (sda1): last error at time 1723139237: ext4_validate_block_bitmap:421
      [Sat Aug 10 23:08:14 2024] EXT4-fs (sda1): error count since last fsck: 71
      [Sat Aug 10 23:08:14 2024] EXT4-fs (sda1): initial error at time 1668261680: ext4_validate_block_bitmap:390
      [Sat Aug 10 23:08:14 2024] EXT4-fs (sda1): last error at time 1723139237: ext4_validate_block_bitmap:421
      [Mon Aug 12 00:46:11 2024] EXT4-fs (sda1): error count since last fsck: 71
      [Mon Aug 12 00:46:11 2024] EXT4-fs (sda1): initial error at time 1668261680: ext4_validate_block_bitmap:390
      [Mon Aug 12 00:46:11 2024] EXT4-fs (sda1): last error at time 1723139237: ext4_validate_block_bitmap:421
      [Tue Aug 13 02:24:07 2024] EXT4-fs (sda1): error count since last fsck: 71
      [Tue Aug 13 02:24:07 2024] EXT4-fs (sda1): initial error at time 1668261680: ext4_validate_block_bitmap:390
      [Tue Aug 13 02:24:07 2024] EXT4-fs (sda1): last error at time 1723139237: ext4_validate_block_bitmap:421
      [Wed Aug 14 04:02:04 2024] EXT4-fs (sda1): error count since last fsck: 71
      [Wed Aug 14 04:02:04 2024] EXT4-fs (sda1): initial error at time 1668261680: ext4_validate_block_bitmap:390
      [Wed Aug 14 04:02:04 2024] EXT4-fs (sda1): last error at time 1723139237: ext4_validate_block_bitmap:421
      [Thu Aug 15 05:40:00 2024] EXT4-fs (sda1): error count since last fsck: 71
      [Thu Aug 15 05:40:00 2024] EXT4-fs (sda1): initial error at time 1668261680: ext4_validate_block_bitmap:390
      [Thu Aug 15 05:40:00 2024] EXT4-fs (sda1): last error at time 1723139237: ext4_validate_block_bitmap:421
      [Fri Aug 16 07:17:57 2024] EXT4-fs (sda1): error count since last fsck: 71
      [Fri Aug 16 07:17:57 2024] EXT4-fs (sda1): initial error at time 1668261680: ext4_validate_block_bitmap:390
      [Fri Aug 16 07:17:57 2024] EXT4-fs (sda1): last error at time 1723139237: ext4_validate_block_bitmap:421
      [Sat Aug 17 08:55:53 2024] EXT4-fs (sda1): error count since last fsck: 71
      [Sat Aug 17 08:55:53 2024] EXT4-fs (sda1): initial error at time 1668261680: ext4_validate_block_bitmap:390
      [Sat Aug 17 08:55:53 2024] EXT4-fs (sda1): last error at time 1723139237: ext4_validate_block_bitmap:421
      [Sun Aug 18 10:33:50 2024] EXT4-fs (sda1): error count since last fsck: 71
      [Sun Aug 18 10:33:50 2024] EXT4-fs (sda1): initial error at time 1668261680: ext4_validate_block_bitmap:390
      [Sun Aug 18 10:33:50 2024] EXT4-fs (sda1): last error at time 1723139237: ext4_validate_block_bitmap:421
      [Mon Aug 19 12:11:46 2024] EXT4-fs (sda1): error count since last fsck: 71
      [Mon Aug 19 12:11:46 2024] EXT4-fs (sda1): initial error at time 1668261680: ext4_validate_block_bitmap:390
      [Mon Aug 19 12:11:46 2024] EXT4-fs (sda1): last error at time 1723139237: ext4_validate_block_bitmap:421
      [Tue Aug 20 13:49:43 2024] EXT4-fs (sda1): error count since last fsck: 71
      [Tue Aug 20 13:49:43 2024] EXT4-fs (sda1): initial error at time 1668261680: ext4_validate_block_bitmap:390
      [Tue Aug 20 13:49:43 2024] EXT4-fs (sda1): last error at time 1723139237: ext4_validate_block_bitmap:421
      [Wed Aug 21 15:27:39 2024] EXT4-fs (sda1): error count since last fsck: 71
      [Wed Aug 21 15:27:39 2024] EXT4-fs (sda1): initial error at time 1668261680: ext4_validate_block_bitmap:390
      [Wed Aug 21 15:27:39 2024] EXT4-fs (sda1): last error at time 1723139237: ext4_validate_block_bitmap:421
      [Thu Aug 22 17:05:36 2024] EXT4-fs (sda1): error count since last fsck: 71
      [Thu Aug 22 17:05:36 2024] EXT4-fs (sda1): initial error at time 1668261680: ext4_validate_block_bitmap:390
      [Thu Aug 22 17:05:36 2024] EXT4-fs (sda1): last error at time 1723139237: ext4_validate_block_bitmap:421
      Show mounted filesystems:
      TARGET                                                  SOURCE         FSTYPE      OPTIONS
      /                                                       /dev/mmcblk0p2 ext4        rw,noatime
      |-/sys                                                  sysfs          sysfs       rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/security                                securityfs     securityfs  rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/cgroup                                      cgroup2        cgroup2     rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
      | |-/sys/fs/pstore                                      pstore         pstore      rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/bpf                                         bpf            bpf         rw,nosuid,nodev,noexec,relatime,mode=700
      | |-/sys/kernel/debug                                   debugfs        debugfs     rw,nosuid,nodev,noexec,relatime
      | | `-/sys/kernel/debug/tracing                         tracefs        tracefs     rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/tracing                                 tracefs        tracefs     rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/fuse/connections                            fusectl        fusectl     rw,nosuid,nodev,noexec,relatime
      | `-/sys/kernel/config                                  configfs       configfs    rw,nosuid,nodev,noexec,relatime
      |-/proc                                                 proc           proc        rw,relatime
      | `-/proc/sys/fs/binfmt_misc                            systemd-1      autofs      rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=143
      |   `-/proc/sys/fs/binfmt_misc                          binfmt_misc    binfmt_misc rw,nosuid,nodev,noexec,relatime
      |-/dev                                                  udev           devtmpfs    rw,nosuid,relatime,size=1671304k,nr_inodes=417826,mode=755
      | |-/dev/pts                                            devpts         devpts      rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
      | |-/dev/shm                                            tmpfs          tmpfs       rw,nosuid,nodev
      | `-/dev/mqueue                                         mqueue         mqueue      rw,nosuid,nodev,noexec,relatime
      |-/run                                                  tmpfs          tmpfs       rw,nosuid,nodev,noexec,relatime,size=388308k,mode=755
      | |-/run/lock                                           tmpfs          tmpfs       rw,nosuid,nodev,noexec,relatime,size=5120k
      | |-/run/credentials/systemd-sysctl.service             ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
      | |-/run/credentials/systemd-sysusers.service           ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
      | |-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
      | |-/run/rpc_pipefs                                     sunrpc         rpc_pipefs  rw,relatime
      | |-/run/credentials/systemd-tmpfiles-setup.service     ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
      | `-/run/user/1000                                      tmpfs          tmpfs       rw,nosuid,nodev,relatime,size=388304k,nr_inodes=97076,mode=700,uid=1000,gid=1000
      |-/boot/firmware                                        /dev/mmcblk0p1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      `-/media/usbdisk                                        /dev/sda1      ext4        rw,nosuid,nodev,noexec,noatime
      /var:
      3.6G	/var/
      1.9G	/var/log/journal/1c963a2d6f5d49798d662b895e4632cd
      1.9G	/var/log
      1.3G	/var/lib
      Archived and active journals take up 1.8G in the file system.
      /opt/iobroker/backups:
      384M	/opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      894M	/opt/iobroker/iobroker-data/
      700M	/opt/iobroker/iobroker-data/files
      441M	/opt/iobroker/iobroker-data/files/javascript.admin
      409M	/opt/iobroker/iobroker-data/files/javascript.admin/static
      408M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js
      42M	/opt/iobroker/iobroker-data/files/telegram-menu.admin/build/index.js.map
      30M	/opt/iobroker/iobroker-data/objects.jsonl
      24M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
      22M	/opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.18496c94.js.map
      19M	/opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.02fc3820.js.map
      USB-Devices by-id:
      /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A50285BI-if00-port0
      /dev/serial/by-id/usb-Silicon_Labs_CP2102N_USB_to_UART_Bridge_Controller_d2fcfed44da0ea1184b05dcbfe9faf31-if00-port0
      /dev/serial/by-id/usb-Espressif_USB_JTAG_serial_debug_unit_80:65:99:99:A8:30-if00
      *** NodeJS-Installation ***
      /usr/bin/nodejs 	v18.20.4
      /usr/bin/node 		v18.20.4
      /usr/bin/npm 		10.7.0
      /usr/bin/npx 		10.7.0
      /usr/bin/corepack 	0.28.0
      nodejs:
        Installed: 18.20.4-1nodesource1
        Candidate: 18.20.4-1nodesource1
        Version table:
       *** 18.20.4-1nodesource1 1001
              500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
           18.20.3-1nodesource1 1001
           18.20.2-1nodesource1 1001
           18.20.1-1nodesource1 1001
           18.20.0-1nodesource1 1001
           18.19.1-1nodesource1 1001
           18.19.0+dfsg-6~deb12u2 500
              500 http://deb.debian.org/debian bookworm/main arm64 Packages
           18.19.0+dfsg-6~deb12u1 500
              500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
           18.19.0-1nodesource1 1001
           18.18.2-1nodesource1 1001
           18.18.1-1nodesource1 1001
           18.18.0-1nodesource1 1001
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller: 	6.0.9
      admin: 		7.0.23
      javascript: 	8.7.6
      nodejs modules from github: 	3
      +-- iobroker.robonect@1.3.6 (git+ssh://git@github.com/Grizzelbee/ioBroker.robonect.git#b3e15ba3ceda35dbc6688cc5431da2493a4c2f62)
      +-- iobroker.vw-connect@0.5.1 (git+ssh://git@github.com/ta2k/ioBroker.vw-connect.git#29ef72ba0568014661f431d5fc0908619fff89c2)
      +-- iobroker.wireless-mbus@0.9.2 (git+ssh://git@github.com/lvogt/ioBroker.wireless-mbus.git#de09e441e4c88799ada3abd396f04fad74f80325)
      Adapter State
        system.adapter.ble.0                    : ble                   : raspberrypi                              - disabled
      + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
        system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
        system.adapter.discovery.0              : discovery             : raspberrypi                              - disabled
      + system.adapter.drag-indicator.0         : drag-indicator        : raspberrypi                              -  enabled
      + system.adapter.ebus.0                   : ebus                  : raspberrypi                              -  enabled
        system.adapter.feiertage.0              : feiertage             : raspberrypi                              -  enabled
      + system.adapter.followthesun.0           : followthesun          : raspberrypi                              -  enabled
      + system.adapter.history.0                : history               : raspberrypi                              -  enabled
      + system.adapter.kecontact.0              : kecontact             : raspberrypi                              -  enabled
      + system.adapter.modbus.0                 : modbus                : raspberrypi                              -  enabled
      + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
        system.adapter.openligadb.0             : openligadb            : raspberrypi                              - disabled
      + system.adapter.parser.1                 : parser                : raspberrypi                              -  enabled
      + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
        system.adapter.psa.0                    : psa                   : raspberrypi                              - disabled
      + system.adapter.pushover.1               : pushover              : raspberrypi                              -  enabled
      + system.adapter.pushover.2               : pushover              : raspberrypi                              -  enabled
      + system.adapter.robonect.0               : robonect              : raspberrypi                              -  enabled
        system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              - disabled
        system.adapter.schoolfree.0             : schoolfree            : raspberrypi                              -  enabled
      + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1886, bind: 0.0.0.0
      + system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      + system.adapter.smartmeter.0             : smartmeter            : raspberrypi                              -  enabled
      + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1884, bind: 0.0.0.0
      + system.adapter.sql.0                    : sql                   : raspberrypi                              -  enabled, port: 3306
        system.adapter.telegram-menu.0          : telegram-menu         : raspberrypi                              - disabled
      + system.adapter.text2command.0           : text2command          : raspberrypi                              -  enabled
        system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              - disabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              - disabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              - disabled
        system.adapter.vis-history.0            : vis-history           : raspberrypi                              - disabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              - disabled
        system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi                              - disabled
        system.adapter.vis-lcars.0              : vis-lcars             : raspberrypi                              - disabled
        system.adapter.vis-plumb.0              : vis-plumb             : raspberrypi                              - disabled
        system.adapter.vis-rgraph.0             : vis-rgraph            : raspberrypi                              - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
        system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              - disabled
      + system.adapter.vw-connect.0             : vw-connect            : raspberrypi                              -  enabled
      + system.adapter.webuntis.0               : webuntis              : raspberrypi                              -  enabled
        system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              - disabled
      + system.adapter.wireless-mbus.0          : wireless-mbus         : raspberrypi                              -  enabled
      + instance is alive
      ioBroker-Repositories
      │ (index) │   name   │                           url                           │ auto upgrade │
      │    0    │ 'stable' │    'http://download.iobroker.net/sources-dist.json'     │    false     │
      │    1    │  'beta'  │ 'http://download.iobroker.net/sources-dist-latest.json' │    false     │
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 7.0.23   , installed 7.0.23
      Adapter    "backitup"     : 3.0.19   , installed 3.0.19
      Adapter    "ble"          : 0.14.0   , installed 0.14.0
      Adapter    "daswetter"    : 3.1.15   , installed 3.1.15
      Adapter    "discovery"    : 4.5.0    , installed 4.5.0
      Adapter    "drag-indicator": 2.1.4   , installed 2.1.4
      Adapter    "ebus"         : 3.3.4    , installed 3.3.4
      Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
      Adapter    "followthesun" : 0.5.0    , installed 0.5.0
      Adapter    "javascript"   : 8.7.6    , installed 8.7.6
      Controller "js-controller": 6.0.9    , installed 6.0.9
      Adapter    "kecontact"    : 2.2.0    , installed 2.2.0
      Adapter    "modbus"       : 6.2.3    , installed 6.2.3
      Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
      Adapter    "openligadb"   : 1.4.9    , installed 1.4.9
      Adapter    "parser"       : 2.2.2    , installed 2.2.2
      Adapter    "pushover"     : 3.0.6    , installed 3.0.6
      Adapter    "robonect"     : 1.3.6    , installed 1.3.6
      Adapter    "schoolfree"   : 1.1.4    , installed 1.1.4
      Adapter    "shelly"       : 7.0.0    , installed 7.0.0
      Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
      Adapter    "sonoff"       : 3.1.0    , installed 3.1.0
      Adapter    "sql"          : 3.0.1    , installed 3.0.1
      Adapter    "telegram"     : 3.9.0    , installed 3.9.0
      Adapter    "telegram-menu": 1.7.4    , installed 1.7.4
      Adapter    "text2command" : 3.0.3    , installed 3.0.3
      Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
      Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
      Adapter    "web"          : 6.2.5    , installed 6.2.5
      Adapter    "webuntis"     : 0.3.4    , installed 0.3.4
      Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
      Adapter    "wireless-mbus": 0.9.1    , installed 0.9.2
      Objects and States
      Objects: 	12368
      States: 	11091
      Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
      Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
      Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
      Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          674        787/sshd: /usr/sbin
      tcp        0      0 127.0.0.1:3306          0.0.0.0:*               LISTEN      106        6015       847/mariadbd
      tcp        0      0 0.0.0.0:8888            0.0.0.0:*               LISTEN      0          50950559   1469294/ebusd
      tcp        0      0 0.0.0.0:8889            0.0.0.0:*               LISTEN      0          50950560   1469294/ebusd
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       66105371   2118966/iobroker.js
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       66105364   2118966/iobroker.js
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       66109578   2119230/io.mqtt.0
      tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       66108352   2119342/io.sonoff.0
      tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       66106731   2119302/io.shelly.0
      tcp6       0      0 :::22                   :::*                    LISTEN      0          676        787/sshd: /usr/sbin
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       66105455   2118992/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       66107057   2119380/io.web.0
      tcp6       0      0 :::8087                 :::*                    LISTEN      1001       66110036   2119540/io.simple-a
      udp        0      0 0.0.0.0:7090            0.0.0.0:*                           1001       66108612   2119189/io.kecontac
      udp        0      0 0.0.0.0:7092            0.0.0.0:*                           1001       66108613   2119189/io.kecontac
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        4020       625/avahi-daemon: r
      udp        0      0 0.0.0.0:56809           0.0.0.0:*                           1001       66108614   2119189/io.kecontac
      udp        0      0 0.0.0.0:59006           0.0.0.0:*                           104        4022       625/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                104        4021       625/avahi-daemon: r
      udp6       0      0 :::44356                :::*                                104        4023       625/avahi-daemon: r
      udp6       0      0 fe80::79ca:2591:a72:546 :::*                                0          6377       700/NetworkManager
      2024-08-22 22:59:56.774  - warn: ebus.0 (2254253) no update since 21/08/2024, 21:41:21 uih.messages.TempIncrease.lastup
      2024-08-22 22:59:56.792  - warn: ebus.0 (2254253) no update since 21/08/2024, 21:41:22 uih.messages.YieldLastYear.lastup
      2024-08-22 22:59:57.019  - warn: ebus.0 (2254253) no update since 21/08/2024, 21:41:22 uih.messages.YieldOld.lastup
      2024-08-22 22:59:57.041  - warn: ebus.0 (2254253) no update since 21/08/2024, 21:41:22 uih.messages.YieldSum.lastup
      2024-08-22 22:59:57.241  - info: ebus.0 (2254253) installed ebusd version is 23.3
      2024-08-22 22:59:57.321  - info: ebus.0 (2254253) all http done
      2024-08-22 23:00:00.610  - info: smartmeter.0 (2119319) Received 10 values, 3 updated
      2024-08-22 23:00:05.555  - info: webuntis.0 (2119585) Cannot read Inbox - possible block by scool
      2024-08-22 23:00:07.395  - info: javascript.0 (2119026) script.js.Garten.Robbie: Robbi Temp i.O.!
      2024-08-22 23:00:11.397  - info: smartmeter.0 (2119319) Received 10 values, 3 updated
      2024-08-22 23:00:22.384  - info: smartmeter.0 (2119319) Received 10 values, 3 updated
      2024-08-22 23:00:33.313  - info: smartmeter.0 (2119319) Received 10 values, 3 updated
      2024-08-22 23:00:40.529  - info: shelly.0 (2119302) [MQTT] Device with client id "shellydw2-D73F3F" connected!
      2024-08-22 23:00:44.334  - info: smartmeter.0 (2119319) Received 10 values, 3 updated
      2024-08-22 23:00:55.332  - info: smartmeter.0 (2119319) Received 10 values, 3 updated
      2024-08-22 23:01:06.287  - info: smartmeter.0 (2119319) Received 10 values, 3 updated
      2024-08-22 23:01:17.337  - info: smartmeter.0 (2119319) Received 10 values, 2 updated
      2024-08-22 23:01:28.334  - info: smartmeter.0 (2119319) Received 10 values, 3 updated
      2024-08-22 23:01:39.341  - info: smartmeter.0 (2119319) Received 10 values, 3 updated
      2024-08-22 23:01:50.331  - info: smartmeter.0 (2119319) Received 10 values, 3 updated
      2024-08-22 23:02:01.342  - info: smartmeter.0 (2119319) Received 10 values, 3 updated
      2024-08-22 23:02:04.457  - info: javascript.0 (2119026) script.js.Garten.Robbie: Robbi Temp i.O.!
      2024-08-22 23:02:12.379  - info: smartmeter.0 (2119319) Received 10 values, 3 updated
      2024-08-22 23:02:23.371  - info: smartmeter.0 (2119319) Received 10 values, 3 updated
      2024-08-22 23:02:34.426  - info: smartmeter.0 (2119319) Received 10 values, 3 updated
      • T thiozinc
        Skript v.2024-05-22
        *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm64
        Docker          : false
        Kernel          : aarch64
        Userland        : 64 bit
        CPU threads: 4
        Current issues:
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        pi
        HOME=/home/pi
        iobroker
        HOME=/home/iobroker
        Desktop:
        Terminal: 	tty
        *** MEMORY ***
        Swap:           209M        195M         13M
                 3792 M total memory
                 2689 M used memory
                  516 M free memory
                   75 M buffer memory
                  572 M swap cache
                  199 M total swap
                  186 M used swap
                   13 M free swap
        *** FILESYSTEM ***
        /var:
        3.6G	/var/
        1.9G	/var/log
        1.3G	/var/lib
        USB-Devices by-id:
        /usr/bin/npm 		10.7.0
        /usr/bin/npx 		10.7.0
        nodejs:
          Version table:
        Errors in npm tree:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin: 		7.0.23
        javascript: 	8.7.6
        Adapter State
        + instance is alive
        Objects and States
        Objects: 	12368
        States: 	11091
        Pending Updates: 0
        #616
        @thiozinc
        Dein Dateisystem auf /dev/sda1 (/media/usbdisk) hat Einschläge.
        Bring nodejs auf Version 20
        iob nodejs-update
        Ansonsten nix auffälliges.
          @thiozinc
          iob nodejs-update
          thiozinc
          schrieb am zuletzt editiert von thiozinc
          #617
          @thomas-braun said in Adapter: ebus:
          iob nodejs-update
          Danke für den Tipp, aber das Update hat leider auch keine Verbesserung gebracht.
          • T thiozinc
            iob nodejs-update
            #618
            @thiozinc
            Das hab ich auch nicht behauptet.
            • T thiozinc
              iob nodejs-update
              #619
              @thiozinc
              iob upload all
              mal ausführen.
                @thiozinc
                iob upload all
                mal ausführen.
                thiozinc
                #620
                Danke, jetzt läuft's wieder!
                  megamacy
                  schrieb am zuletzt editiert von megamacy
                  #621
                  kann mir evtl jemand weiterhelfen und sagen, wie ich die Abfrage von bestimmten Datenpunkten deaktivieren kann?
                  Es gibt einen Datenpunkt "broadcast.messages.signoflife.lastup" , der wird bei start des von Ebusd einmal gesetzt und dann während der Laufzeit nicht mehr. Das generiert im Abfrageintervall Warnmeldungen im LOG
                  ebus.0	2024-10-11 17:41:41.958	info	all http done
                  ebus.0	2024-10-11 17:41:39.794	info	installed ebusd version is 23.3
                  ebus.0	2024-10-11 17:41:37.203	warn	no update since 11.10.2024, 15:57:40 broadcast.messages.signoflife.lastup
                  ebus.0	2024-10-11 17:40:45.099	info	all http done
                  ebus.0	2024-10-11 17:40:44.949	info	installed ebusd version is 23.3
                  ebus.0	2024-10-11 17:40:40.321	warn	no update since 11.10.2024, 15:57:40 broadcast.messages.signoflife.lastup
                  ebus.0	2024-10-11 17:39:42.654	info	all http done
                  ebus.0	2024-10-11 17:39:42.488	info	installed ebusd version is 23.3
                  ebus.0	2024-10-11 17:39:38.709	warn	no update since 11.10.2024, 15:57:40 broadcast.messages.signoflife.lastup
                  ebus.0	2024-10-11 17:38:46.079	info	all http done
                  ebus.0	2024-10-11 17:38:45.948	info	installed ebusd version is 23.3
                  ebus.0	2024-10-11 17:38:37.850	warn	no update since 11.10.2024, 15:57:40 broadcast.messages.signoflife.lastup
                  Rene_HMR 1 Antwort Letzte Antwort
                    saskathex
                    #622
                    gestern habe ich auf ebusd 24.1 geupdatet. Leider läuft der iobroker Adapter nun nicht mehr und meldet die Fehlermeldung:
                    "unsupported ebusd version found (too new) .... "
                    Wie ist der Weg des Issue reporting? Eher hier (da habe ich mal angefangen) oder über das github repo.
                    • S saskathex
                      Rene_HMR Offline
                      Rene_HMR Offline
                      Rene_HM
                      #623
                      @saskathex sagte in Adapter: ebus:
                      Das ist eigentlich nur eine Warnung. Geht sonst irgendetwas nicht mehr?
                      ideal wäre ein ticket im github...
                      • Rene_HMR Rene_HM
                        saskathex
                        #624
                        @rene_hm Nachdem ich nachher den Code mir angeschaut habe, hab ich es selbst gemerkt mit der Warnung. Ansonsten geht alles!
                        Nur die ebus Nachrichten von meiner Vaillant Heizung haben ihre Struktur geändert. Musste ich nur meine Datenpunkte anpassen. Das liegt eher nicht an dem iobroker Adapter, als mehr an dem ebusd, welche diese anders liefert. Stört mich persönlich aber nicht.
                        Kurz: Name und Value kommen jetzt in unterschiedlichen Zweigen anstatt in einem Zweig.
                        • S saskathex
                          Kanumouse
                          #625
                          Ich habe ebusd auch auf die Version 24.1 umgestellt. Läuft soweit alles.
                          Nur fehlen mir 4 Datenpunkte für meine an eine vaillant 470 angeschlossene Solarthermieanlage:
                          SBTemp, SolBackTemp, CollTemp, SolPump
                          Bei der vorherigen 23-iger Version waren diese Datenpunkte noch da.
                          • M megamacy
                            Rene_HMR Offline
                            Rene_HMR Offline
                            Rene_HM
                            #626
                            @megamacy Etwas spät, aber vielleicht hilft es noch:
                            Das liegt normalerweise weder am Adapter noch am ebusd. Das Problem ist, dass manche Werte nach einem Reboot mit Scan einmalig auf dem Bus auftauchen. Der ebusd packt diese Werte in die Datenstruktur und damit tauchen sie im Adapter auf. Wenn nun dieser Wert nie wieder auf dem Bus auftaucht, bleibt natürlich der Zeitstempel beim ersten Auftauchen stehen und der Adapter loggt, dass es kein update gibt, was ja auch richtig ist.
                            Man wird diese Werte los, indem man den ebusd neu bootet. Dabei darf natürlich der Scan nicht aktiv sein. Dadurch baut der ebusd seine interne Datenstruktur neu auf. Danach löscht man im iobroker einmalig den kompletten Baum der Daten vom ebus-Adapter (oder alternativ manuell die Datenpunkte, die nicht aktualisiert werden)
                            • HasontH Offline
                              HasontH Offline
                              Hasont
                              schrieb am zuletzt editiert von Hasont
                              #627
                              Hallo, ich brauch mal wieder eure Hilfe.
                              eBus Adapter ist 3.3.6 und ebusd die 23.3
                              Ich hatte jetzt längere Zeit meine Heizung über VIS nicht mehr im Blick und stelle grad fest, dass das ebus-history-widget unten im Bild komplett verschwunden ist.
                              Der Platz wo das war ist jetzt komplett frei
                              und links im VIS Editor ist das ebus-history-Widget auch nicht mehr zu finden.
                              Da das ebus-history-widget doch aus dem ebus-Adapter kommt hier mal die Frage wie ich das wieder in meine VIS integrieren kann.
                              Danke schon mal für eure Hilfe.
                              LG Horst
                              • HasontH Hasont
                                LG Horst
                                Rene_HMR Offline
                                Rene_HMR Offline
                                Rene_HM
                                #628
                                @hasont ich würde zunächst ein upload für den Adapter und die vis versuchen.
                                Du könntest auch im Konsolen-Fenster deines browsers nach Fehlermeldungen schauen...
                                HasontH 1 Antwort Letzte Antwort
                                • Rene_HMR Rene_HM
                                  HasontH Offline
                                  HasontH Offline
                                  Hasont
                                  #629
                                  @rene_hm
                                  Hallo Rene, danke für die schnelle Antwort.
                                  Ich hab den upload gemacht was leider nix gebracht hat. Das Widget ist noch immer weg. Hab dann deinstalliert und es ging gar nichts mehr. Dann Backup vom 15.11 zurück gespielt. Leider war es da scheinbar auch schon.
                                  In Firefox hab ich unter Wekzeug das gefunden. Wäre das die Ausgabe der Konsole?
                                  Hast du ev. sonst noch eine Idee. Braucht man für das ebus Widget ev. noch andere Widgets auf das du aufbaust und das ich ev. mal beim Aufräumen deinstalliert habe.
                                  1732359221042	addons.xpi	WARN	Checking C:\Program Files (x86)\Mozilla Firefox\distribution\extensions for addons
                                  Attempt to override an existing message: "urlbar-searchmode-dropmarker". preview/enUS-searchFeatures.ftl
                                  Attempt to override an existing message: "urlbar-searchmode-bookmarks". preview/enUS-searchFeatures.ftl
                                  Attempt to override an existing message: "urlbar-searchmode-tabs". preview/enUS-searchFeatures.ftl
                                  Attempt to override an existing message: "urlbar-searchmode-history". preview/enUS-searchFeatures.ftl
                                  Attempt to override an existing message: "urlbar-searchmode-actions". preview/enUS-searchFeatures.ftl
                                  Attempt to override an existing message: "urlbar-searchmode-exit-button". preview/enUS-searchFeatures.ftl
                                  Attempt to override an existing message: "urlbar-searchmode-popup-description". preview/enUS-searchFeatures.ftl
                                  Attempt to override an existing message: "urlbar-searchmode-popup-search-settings". preview/enUS-searchFeatures.ftl
                                  Attempt to override an existing message: "appmenu-manage-profiles". preview/profiles.ftl
                                  Attempt to override an existing message: "appmenu-create-profile". preview/profiles.ftl
                                  Warning: attempting to write 5672 bytes to preference browser.topsites.contile.cachedTiles. This is bad for general performance and memory usage. Such an amount of data should rather be written to an external file.
                                  QM_TRY failure (WARNING): 'Unavailable, storage-origin http://192.168.1.75:8082, context dom::quota::FirstInitializationAttempt::TemporaryStorage', file dom/quota/ActorsParent.cpp:2779
                                  Experiment add-an-image-to-pdf-with-alt-text-rollout has unknown featureId: addAnImageInPDF RemoteSettingsExperimentLoader.sys.mjs:709:21
                                  Experiment tab-hover-preview-release-rollout has unknown featureId: tabPreview RemoteSettingsExperimentLoader.sys.mjs:709:21
                                  Danke schon mal
                                  Horst
                                  • HasontH Hasont
                                    @rene_hm
                                    Danke schon mal
                                    Horst
                                    Rene_HMR Offline
                                    Rene_HMR Offline
                                    Rene_HM
                                    #630
                                    @hasont Ich habe jetzt gerade bei mir nochmal geschaut. Im Edit-Mode sind meine vis-widgets (ebus, weather und sbfspot) nicht mehr sichtbar. Muss ich mir anschauen...
                                    Ich hatte mich in den letzten Monaten mit vis-2 beschäftigt, habe wohl hier irgendetwas übersehen....
                                    • Rene_HMR Rene_HM
                                      HasontH Offline
                                      HasontH Offline
                                      Hasont
                                      #631
                                      @rene_hm
                                      Vielen Dank für die Info, dann kann ich ja jetzt aufhören zu suchen:-)
                                      LG Horst
                                      • HasontH Hasont
                                        @rene_hm
                                        LG Horst
                                        Rene_HMR Offline
                                        Rene_HMR Offline
                                        Rene_HM
                                        #632
                                        @hasont mit der v3.3.8 sollte es wieder funktionieren. Ein upload der vis ist wahrscheinlich nach Installation des Adapters notwendig.
                                        • Rene_HMR Rene_HM
                                          HasontH Offline
                                          HasontH Offline
                                          Hasont
                                          #633
                                          @rene_hm
                                          Vielen vielen Dank, hab über github die v3.3.8 installiert und danach Upload von Vis gemacht. War sofort wieder in aller schönheit da.
                                          LG Horst
