modbus Socket Error / Client in Error State
Seit Monaten bekomme ich folgende Fehlermeldung:
2024-11-03 04:50:16.392 error Client in error state. 2024-11-03 04:50:16.392 error Socket ErrorIm wesentlichen jeden Tag weitgehend zur gleichen Zeit.
iob diag:
Script v.2024-10-19 *** BASE SYSTEM *** Static hostname: iobroker Icon name: computer-container Chassis: container ☐ Virtualization: lxc Operating System: Debian GNU/Linux 12 (bookworm) Kernel: Linux 6.8.12-2-pve Architecture: x86-64 OS is similar to: model name : Intel(R) Core(TM) i5-10210U CPU @ 1.60GHz Docker : false Virtualization : lxc Kernel : x86_64 Userland : 64 bit Systemuptime and Load: 10:46:21 up 2 days, 17:32, 3 users, load average: 2.81, 1.66, 1.00 CPU threads: 2 *** LIFE CYCLE STATUS *** Operating System is the current Debian stable version codenamed 'bookworm'! *** TIME AND TIMEZONES *** Local time: Sun 2024-11-03 10:46:21 CET Universal time: Sun 2024-11-03 09:46:21 UTC RTC time: n/a Time zone: Europe/Berlin (CET, +0100) System clock synchronized: yes NTP service: inactive RTC in local TZ: no *** Users and Groups *** User that called 'iob diag': mn HOME=/home/mn GROUPS=mn adm dialout sudo users iobroker User that is running 'js-controller': iobroker HOME=/home/iobroker GROUPS=iobroker tty dialout audio video plugdev *** DISPLAY-SERVER SETUP *** Display-Server: false Desktop: Terminal: tty System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix' *** MEMORY *** total used free shared buff/cache available Mem: 8.6G 2.7G 3.7G 143K 2.0G 5.8G Swap: 536M 0B 536M Total: 9.1G 2.7G 4.2G Active iob-Instances: 19 8192 M total memory 2615 M used memory 2526 M active memory 1855 M inactive memory 3528 M free memory 0 M buffer memory 1922 M swap cache 512 M total swap 0 M used swap 512 M free swap *** top - Table Of Processes *** top - 10:46:21 up 2 days, 17:32, 3 users, load average: 2.81, 1.66, 1.00 Tasks: 65 total, 2 running, 63 sleeping, 0 stopped, 0 zombie %Cpu(s): 0.0 us, 0.0 sy, 0.0 ni,100.0 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st MiB Mem : 8192.0 total, 3526.4 free, 2617.3 used, 1922.4 buff/cache MiB Swap: 512.0 total, 512.0 free, 0.0 used. 5574.7 avail Mem *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System * sys-kernel-config.mount loaded failed failed Kernel Configuration File System LOAD = Reflects whether the unit definition was properly loaded. ACTIVE = The high-level unit activation state, i.e. generalization of SUB. SUB = The low-level unit activation state, values depend on unit type. 2 loaded units listed. *** DMESG CRITICAL ERRORS *** dmesg: read kernel buffer failed: Operation not permitted No critical errors detected *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on /dev/mapper/pve-vm--101--disk--1 ext4 32G 14G 17G 45% / none tmpfs 492K 4.0K 488K 1% /dev /dev/mapper/pve-root ext4 94G 83G 7.0G 93% /dev/ttyACM0 udev devtmpfs 32G 0 32G 0% /dev/tty tmpfs tmpfs 32G 0 32G 0% /dev/shm tmpfs tmpfs 13G 132K 13G 1% /run tmpfs tmpfs 5.0M 0 5.0M 0% /run/lock tmpfs tmpfs 6.3G 0 6.3G 0% /run/user/1001 Messages concerning ext4 filesystem in dmesg: dmesg: read kernel buffer failed: Operation not permitted Show mounted filesystems: TARGET SOURCE FSTYPE OPTIONS / /dev/mapper/pve-vm--101--disk--1 ext4 rw,relatime,stripe=16 `-/dev/ttyACM0 /dev/mapper/pve-root[/var/lib/lxc/101/devices/ttyACM0] ext4 rw,relatime,errors=remount-ro Files in neuralgic directories: /var: 3.6G /var/ 2.2G /var/lib 2.1G /var/lib/mysql 1.9G /var/lib/mysql/DBioBroker 742M /var/cache Archived and active journals take up 668.7M in the file system. /opt/iobroker/backups: 2.1G /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 1.4G /opt/iobroker/iobroker-data/ 1.3G /opt/iobroker/iobroker-data/files 617M /opt/iobroker/iobroker-data/files/javascript.admin 560M /opt/iobroker/iobroker-data/files/javascript.admin/static 558M /opt/iobroker/iobroker-data/files/javascript.admin/static/js The five largest files in iobroker-data are: 31M /opt/iobroker/iobroker-data/objects.jsonl 26M /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map 26M /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map 24M /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map 24M /opt/iobroker/iobroker-data/files/vis-2/static/js/main.f305bc29.js.map USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups, please always prefer the links 'by-id': /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2285504-if00 HINT: Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting: /dev/ttyACM0 *** NodeJS-Installation *** /usr/bin/nodejs v20.18.0 /usr/bin/node v20.18.0 /usr/bin/npm 10.8.2 /usr/bin/npx 10.8.2 /usr/bin/corepack 0.29.3 nodejs: Installed: 20.18.0-1nodesource1 Candidate: 20.18.0-1nodesource1 Version table: *** 20.18.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 100 /var/lib/dpkg/status 20.17.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.16.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.15.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.15.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.14.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.13.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.13.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.12.2-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.12.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.12.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.11.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.11.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.10.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.9.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.8.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.8.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.7.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.6.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.6.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.5.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.5.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.4.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.3.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.3.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.2.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.1.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.0.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 18.19.0+dfsg-6~deb12u2 500 500 http://deb.debian.org/debian bookworm/main amd64 Packages 18.19.0+dfsg-6~deb12u1 500 500 http://security.debian.org bookworm-security/main amd64 Packages Temp directories causing deletion problem: 0 No problems detected Errors in npm tree: 0 No problems detected *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: jsonl Hosts: iobroker iobroker (version: 6.0.11, hostname: iobroker , alive, uptime: 151) Core adapters versions js-controller: 6.0.11 admin: 7.2.6 javascript: 8.8.3 nodejs modules from github: 0 Adapter State + system.adapter.admin.0 : admin : iobroker - enabled, port: 8081, bind: 0.0.0.0, run as: admin system.adapter.alias-manager.0 : alias-manager : iobroker - enabled + system.adapter.backitup.0 : backitup : iobroker - enabled + system.adapter.cloud.0 : cloud : iobroker - enabled system.adapter.discovery.0 : discovery : iobroker - enabled system.adapter.echarts.0 : echarts : iobroker - enabled system.adapter.eusec.0 : eusec : iobroker - enabled system.adapter.feiertage.0 : feiertage : iobroker - enabled system.adapter.followthesun.0 : followthesun : iobroker - enabled + system.adapter.homeconnect.0 : homeconnect : iobroker - enabled system.adapter.hydrawise.0 : hydrawise : iobroker - enabled + system.adapter.javascript.0 : javascript : iobroker - enabled + system.adapter.javascript.1 : javascript : iobroker - enabled system.adapter.logparser.0 : logparser : iobroker - enabled + system.adapter.modbus.0 : modbus : iobroker - enabled + system.adapter.mqtt.0 : mqtt : iobroker - enabled, port: 1886, bind: 0.0.0.0 system.adapter.notification-manager.0 : notification-manager : iobroker - enabled system.adapter.pvforecast.0 : pvforecast : iobroker - enabled + system.adapter.shelly.0 : shelly : iobroker - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.shelly.1 : shelly : iobroker - enabled, port: 1883, bind: 0.0.0.0 + system.adapter.shuttercontrol.0 : shuttercontrol : iobroker - enabled + system.adapter.shuttercontrol.1 : shuttercontrol : iobroker - enabled + system.adapter.shuttercontrol.2 : shuttercontrol : iobroker - enabled system.adapter.solaredge.0 : solaredge : iobroker - enabled system.adapter.sonoff.0 : sonoff : iobroker - enabled, port: 1888, bind: 0.0.0.0 + system.adapter.sql.0 : sql : iobroker - enabled, port: 3306 + system.adapter.telegram.0 : telegram : iobroker - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.tuya.0 : tuya : iobroker - enabled system.adapter.uv-protect.0 : uv-protect : iobroker - enabled system.adapter.viessmannapi.0 : viessmannapi : iobroker - enabled system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker - enabled system.adapter.vis-2.0 : vis-2 : iobroker - enabled system.adapter.vis-map.0 : vis-map : iobroker - disabled system.adapter.vis-materialdesign.0 : vis-materialdesign : iobroker - disabled system.adapter.vis.0 : vis : iobroker - enabled system.adapter.vw-connect.0 : vw-connect : iobroker - enabled + system.adapter.weatherunderground.0 : weatherunderground : iobroker - enabled system.adapter.web.0 : web : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin system.adapter.yahka.0 : yahka : iobroker - enabled + system.adapter.zigbee.0 : zigbee : iobroker - enabled, port: /dev/ttyACM0 + instance is alive Enabled adapters with bindings + system.adapter.admin.0 : admin : iobroker - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.mqtt.0 : mqtt : iobroker - enabled, port: 1886, bind: 0.0.0.0 + system.adapter.shelly.0 : shelly : iobroker - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.shelly.1 : shelly : iobroker - enabled, port: 1883, bind: 0.0.0.0 system.adapter.sonoff.0 : sonoff : iobroker - enabled, port: 1888, bind: 0.0.0.0 + system.adapter.sql.0 : sql : iobroker - enabled, port: 3306 + system.adapter.telegram.0 : telegram : iobroker - enabled, port: 8443, bind: 0.0.0.0 system.adapter.web.0 : web : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.zigbee.0 : zigbee : iobroker - enabled, port: /dev/ttyACM0 ioBroker-Repositories ┌─────────┬───────────────┬──────────────────────────────────────────────────────────┬──────────────┐ │ (index) │ name │ url │ auto upgrade │ ├─────────┼───────────────┼──────────────────────────────────────────────────────────┼──────────────┤ │ 0 │ 'stable' │ 'https://download.iobroker.net/sources-dist.json' │ false │ │ 1 │ 'beta' │ 'https://download.iobroker.net/sources-dist-latest.json' │ false │ │ 2 │ 'live-stable' │ 'http://iobroker.live/repo/sources-dist.json' │ false │ │ 3 │ 'live-beta' │ 'http://iobroker.live/repo/sources-dist-latest.json' │ false │ └─────────┴───────────────┴──────────────────────────────────────────────────────────┴──────────────┘ Active repo(s): stable Upgrade policy: none Installed ioBroker-Instances Used repository: stable Adapter "admin" : 7.1.5 , installed 7.2.6 Adapter "alias-manager": 1.2.6 , installed 1.2.6 Adapter "backitup" : 3.0.25 , installed 3.0.25 Adapter "cloud" : 5.0.1 , installed 5.0.1 Adapter "discovery" : 5.0.0 , installed 5.0.0 Adapter "echarts" : 1.9.2 , installed 1.9.2 Adapter "eusec" : 1.3.3 , installed 1.3.3 Adapter "feiertage" : 1.2.0 , installed 1.2.0 Adapter "followthesun" : 0.5.1 , installed 0.5.1 Adapter "homeconnect" : 1.4.1 , installed 1.4.1 Adapter "hydrawise" : 1.0.2 , installed 1.0.2 Adapter "javascript" : 8.8.3 , installed 8.8.3 Controller "js-controller": 6.0.11 , installed 6.0.11 Adapter "logparser" : 2.2.2 , installed 2.2.2 Adapter "modbus" : 6.3.2 , installed 6.3.2 Adapter "mqtt" : 6.1.2 , installed 6.1.2 Adapter "notification-manager": 1.2.1, installed 1.2.1 Adapter "pvforecast" : 3.0.0 , installed 4.0.0 Adapter "shelly" : 8.2.1 , installed 8.2.1 Adapter "shuttercontrol": 1.8.3 , installed 1.8.3 Adapter "simple-api" : 2.8.0 , installed 2.8.0 Adapter "socketio" : 6.7.1 , installed 6.7.1 Adapter "solaredge" : 1.4.1 , installed 1.4.1 Adapter "sonoff" : 3.1.2 , installed 3.1.2 Adapter "sql" : 3.0.1 , installed 3.0.1 Adapter "telegram" : 3.9.0 , installed 3.9.0 Adapter "tuya" : 3.16.0 , installed 3.16.0 Adapter "uv-protect" : 0.6.3 , installed 0.6.3 Adapter "viessmannapi" : 2.3.0 , installed 2.3.0 Adapter "vis" : 1.5.6 , installed 1.5.6 Adapter "vis-2" : 2.9.64 , installed 2.9.64 Adapter "vis-2-widgets-material": 1.4.10, installed 1.4.10 Adapter "vis-map" : 1.1.2 , installed 1.1.2 Adapter "vis-materialdesign": 0.5.9, installed 0.5.9 Adapter "weatherunderground": 3.7.0, installed 3.7.0 Adapter "web" : 6.2.5 , installed 6.2.5 Adapter "ws" : 2.6.2 , installed 2.6.2 Adapter "yahka" : 1.0.3 , installed 1.0.3 Adapter "zigbee" : 1.10.3 , installed 1.10.3 Objects and States Please stand by - This may take a while Objects: 21426 States: 16853 *** OS-Repositories and Updates *** Hit:1 http://deb.debian.org/debian bookworm InRelease Hit:2 http://security.debian.org bookworm-security InRelease Hit:3 http://deb.debian.org/debian bookworm-updates InRelease Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease Reading package lists... Pending Updates: 0 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 127.0.0.1:39193 0.0.0.0:* LISTEN 1000 24897227 17606/io.yahka.0 tcp 0 0 127.0.0.1:3306 0.0.0.0:* LISTEN 105 14522 202/mariadbd tcp 0 0 127.0.0.1:25 0.0.0.0:* LISTEN 0 13189 372/master tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 1000 24877930 15754/iobroker.js-c tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1000 24877925 15754/iobroker.js-c tcp 0 0 0.0.0.0:111 0.0.0.0:* LISTEN 0 12629 1/init tcp 0 0 0.0.0.0:1888 0.0.0.0:* LISTEN 1000 24893189 17395/io.sonoff.0 tcp 0 0 0.0.0.0:1883 0.0.0.0:* LISTEN 1000 24889189 17037/io.shelly.1 tcp 0 0 0.0.0.0:1886 0.0.0.0:* LISTEN 1000 24886749 16396/io.mqtt.0 tcp 0 0 0.0.0.0:1887 0.0.0.0:* LISTEN 1000 24886750 16396/io.mqtt.0 tcp6 0 0 ::1:25 :::* LISTEN 0 13190 372/master tcp6 0 0 :::8081 :::* LISTEN 1000 24880176 15772/io.admin.0 tcp6 0 0 :::8082 :::* LISTEN 1000 24895066 17531/io.web.0 tcp6 0 0 :::111 :::* LISTEN 0 12631 1/init tcp6 0 0 :::22 :::* LISTEN 0 11236 1/init tcp6 0 0 :::1984 :::* LISTEN 1000 24894725 17509/go2rtc tcp6 0 0 :::43993 :::* LISTEN 1000 24897191 17606/io.yahka.0 tcp6 0 0 :::8554 :::* LISTEN 1000 24894718 17509/go2rtc tcp6 0 0 :::8555 :::* LISTEN 1000 24894719 17509/go2rtc udp 0 0 0.0.0.0:111 0.0.0.0:* 0 12630 1/init udp 0 0 0.0.0.0:5353 0.0.0.0:* 1000 24897192 17606/io.yahka.0 udp 0 0 0.0.0.0:5683 0.0.0.0:* 1000 24889132 17011/io.shelly.0 udp 0 0 0.0.0.0:6666 0.0.0.0:* 1000 24891021 17117/io.tuya.0 udp 0 0 0.0.0.0:6667 0.0.0.0:* 1000 24891022 17117/io.tuya.0 udp 0 0 0.0.0.0:43675 0.0.0.0:* 1000 24894745 17479/io.eusec.0 udp 0 0 0.0.0.0:46041 0.0.0.0:* 1000 24894753 17479/io.eusec.0 udp6 0 0 :::111 :::* 0 12632 1/init udp6 0 0 :::8555 :::* 1000 24894720 17509/go2rtc *** Log File - Last 25 Lines *** 2024-11-03 10:45:44.029 - info: yahka.0 (17606) adding Bresser Bodenfeuchte with UUID: 4703a9aa-8572-44a5-b6e5-3baf35a133aa 2024-11-03 10:45:44.029 - info: yahka.0 (17606) adding Bresser Bodentemperatur with UUID: 30b70e34-ac7e-4999-9d1d-7538f0f6debe 2024-11-03 10:45:44.030 - info: yahka.0 (17606) adding Manuelle Bewässerung with UUID: 09b7e90a-e067-4f34-a1dc-e5966e5997cf 2024-11-03 10:45:44.030 - info: yahka.0 (17606) adding Fensterputzmodus with UUID: 616febab-744f-4652-aa61-2ab267ba632a 2024-11-03 10:45:44.030 - info: yahka.0 (17606) adding Bierversteck schließen Impuls with UUID: 6a246646-97b9-4c54-bcbd-e771539ef6e3 2024-11-03 10:45:44.031 - info: yahka.0 (17606) adding Kontakt Schiebetor with UUID: 129d92a4-870e-443c-84bc-10ba7356359d 2024-11-03 10:45:44.031 - info: yahka.0 (17606) adding Touareg Schloss with UUID: 86edc9cf-4e94-4db7-9376-6f035a19d2b4 2024-11-03 10:45:44.031 - info: yahka.0 (17606) adding Szene Gute Nacht ausführen with UUID: 321259e0-a59d-4c0d-829d-ed59431c82ce 2024-11-03 10:45:44.032 - info: yahka.0 (17606) adding Partymodus with UUID: 7989e14b-c1db-40ec-a040-643e7b746b05 2024-11-03 10:45:44.032 - info: yahka.0 (17606) publishing bridge Yahka-0 on 0.0.0.0 using avahi 2024-11-03 10:45:47.784 - info: viessmannapi.0 (17621) starting. Version 2.3.0 in /opt/iobroker/node_modules/iobroker.viessmannapi, node: v20.18.0, js-controller: 6.0.11 2024-11-03 10:45:50.270 - info: viessmannapi.0 (17621) 1 installations found. 2024-11-03 10:45:50.374 - info: viessmannapi.0 (17621) State value to set for "viessmannapi.0.2457409.gateways01.devices01.id" has to be type "number" but received type "string" 2024-11-03 10:45:50.375 - info: viessmannapi.0 (17621) State value to set for "viessmannapi.0.2457409.gateways01.devices04.id" has to be type "string" but received type "number" 2024-11-03 10:45:50.395 - debug: javascript.1 (15971) Could not parse value for id viessmannapi.0.2457409.gateways01.devices04.boilerSerialEditor into object: Unexpected token 'D', "DeviceCommunication" is not valid JSON 2024-11-03 10:45:50.396 - debug: javascript.1 (15971) Could not parse value for id viessmannapi.0.2457409.gateways01.devices04.boilerSerialEditor into object: Unexpected token 'D', "DeviceCommunication" is not valid JSON 2024-11-03 10:45:52.621 - info: echarts.0 (17636) starting. Version 1.9.2 in /opt/iobroker/node_modules/iobroker.echarts, node: v20.18.0, js-controller: 6.0.11 2024-11-03 10:45:52.686 - info: sonoff.0 (17395) Client [Stromzähler] connected with secret 1730627152683_9462 2024-11-03 10:45:59.787 - info: pvforecast.0 (17666) starting. Version 4.0.0 in /opt/iobroker/node_modules/iobroker.pvforecast, node: v20.18.0, js-controller: 6.0.11 2024-11-03 10:45:59.795 - info: pvforecast.0 (17666) using system latitude: 51.278486150000006 longitude: 12.507069799527972 2024-11-03 10:46:02.901 - info: pvforecast.0 (17666) Starting internal update cron (every 15 Minutes) for timezone: Europe/Berlin 2024-11-03 10:46:04.154 - info: hydrawise.0 (17707) starting. Version 1.0.2 in /opt/iobroker/node_modules/iobroker.hydrawise, node: v20.18.0, js-controller: 6.0.11 2024-11-03 10:46:07.822 - info: vis-2.0 (17722) starting. Version 2.9.64 in /opt/iobroker/node_modules/iobroker.vis-2, node: v20.18.0, js-controller: 6.0.11 2024-11-03 10:46:07.983 - info: vis-2.0 (17722) vis-2 license is OK. 2024-11-03 10:46:08.099 - info: vis-2.0 (17722) config.js changed. Upload.Hat jemand eine Idee, wie man das beheben kann? Danke schon mal im Voraus für die Hilfe.
iob diag:
@guitardoc sagte in modbus Socket Error / Client in Error State:
was für ein Gerät?
wie angebunden/konfiguriert?
wann läuft dein Backup? -
Angebunden ist ein Solar Edge Wechselrichter...
...über folgende Holding Register:
_address name description unit type len factor offset formula role room poll wp cw isScale 97709 Batt1_Avg_T Batterie 1 Average Temperature °C floatsw 2 1 0 level true false false false 101697 CommitSettings Commit Power Control Settings uint16be 1 1 0 level true false false false 101698 Restore Power Control Default Settings Restore Power Control Default Settings uint16be 1 1 0 level true false false false 101699 PwrFrqDeratingConfig PwrFrqDeratingConfig uint32sw 2 1 0 level true false false false 101701 ReactivePwrConfig ReactivePwrConfig uint32sw 2 1 0 level true false false false 101761 PowerReduce PowerReduce floatsw 2 1 0 level true false false false 101763 AdvancedPwrControlEn AdvancedPwrControlEn uint32sw 2 1 0 level true false false false 102209 Enable Dynamic Power Control Enable Dynamic Power Control uint16be 1 1 0 level true false false false 102221 Active Power Limit Active Power Limit W floatsw 2 1 0 level true false false false 102223 Reactive Power Limit Reactive Power Limit W floatsw 2 1 0 level true false false false 102225 Command Timeout Command Timeout s uint32sw 2 1 0 level true false false false 102721 Battery 1 Manufacturer Name Battery 1 Manufacturer Name string 8 1 0 level true false false false 102737 Battery 1 Model Battery 1 Model string 16 1 0 level true false false false 102753 Battery 1 Firmware Version Battery 1 Firmware Version string 16 1 0 level true false false false 102769 Battery 1 Serial Number Battery 1 Serial Number string 16 1 0 level true false false false 102787 Batt Rated Energy Batt Rated Energy Wh floatsw 2 1 0 level true false false false 102789 Battery 1 Max Charge Continues Power Battery 1 Max Charge Continues Power W floatsw 2 1 0 level true false false false 102791 Battery 1 Max Discharge Continues Power Battery 1 Max Discharge Continues Power W floatsw 2 1 0 level true false false false 102829 Batt1_Avg_T Batterie 1 Average Temperature °C °C floatsw 2 1 0 level true false false false 102837 Speicher_Ladung Speicher Ladeleistung W floatsw 2 1 0 level true false false false 102839 xBattery 1 Lifetime Export Energy Counter Battery 1 Lifetime Export Energy Counter Wh uint64le 4 1 0 value true false false false 102843 xBattery 1 Lifetime Import Energy Counter Battery 1 Lifetime Import Energy Counter Wh uint64le 4 1 0 value true false false false 102847 Battery 1 Max Energy Battery 1 Max Energy Wh floatsw 2 1 0 level true false false false 102849 Battery 1 Available Energy Battery 1 Available Energy Wh floatsw 2 1 0 level true false false false 102851 Speicher_SoH Batterie Alterung % floatsw 2 1 0 level true false false false 102853 Speicher_SoC Batterieladung % floatsw 2 1 0 level true false false false 102855 Speicher_Betriebszustand 1: Aus, 3: Laden, 4: Entladen, 6: Erhaltungsladen uint32sw 2 1 0 level true false false false 102857 Battery 1 Status Internal Battery 1 Status Internal uint32sw 2 1 0 level true false false false 102859 Battery 1 Events Log Battery 1 Events Log uint32sw 2 1 0 level true false false false 102867 Battery 1 Events Log Internal Battery 1 Events Log Internal uint32sw 2 1 0 level true false false false 103233 Export Control Mode Export Control Mode uint16be 1 1 0 level true false false false 103234 Export Control Limit Mode Export Control Limit Mode uint16be 1 1 0 level true false false false 103235 Export Control Site Limit Export Control Site Limit floatsw 2 1 0 level true false false false 103237 Str Storage control mode uint16be 1 1 0 level true false false false 103238 Storage_AC_Charge_Policy_RW 0: Disable, 1: Always allowed , 2: Fixed Energy Limit uint16be 1 1 0 level true false false false 103239 Storage AC Charge Limit Storage AC Charge Limit % floatsw 2 1 0 level true false false false 103241 Storage_Backup_Reserved_Setting Storage Backup Reserved Setting % floatsw 2 1 0 level true false false false 103243 StChDisChMode Storage Charge/Discharge Mode uint16be 1 1 0 level true false false false 103244 Timeout Timout sec uint32sw 2 1 0 level true false false false 103246 Remote Control Command Mode RW Remote Control Command Mode RW uint16be 1 1 0 level true false false false 103247 Remote Control Charge Limit Remote Control Charge Limit W floatsw 2 1 0 level true false false false 103249 Remote Control Command Discharge Limit Remote Control Command Discharge Limit W floatsw 2 1 0 level true false false false 40001 C_SunSpec_ID "Wert = ""SunS"" (0x53756e53). Identifiziert dies eindeutig als eine SunSpec Modbus-Karte" uint32be 2 1 0 true false false false 40003 C_SunSpec_DID Wert = 0x0001. Identifiziert dies eindeutig als einen SunSpec “Common Block“ uint16be 1 1 0 true false false false 40004 C_SunSpec_Länge 65 = Länge eines Blocks in 16-bit Registern uint16be 1 1 0 true false false false 40005 C_Hersteller "Bei SunSpec eingetragener Wert = ""SolarEdge""" string 16 1 0 true false false false 40021 C_Modell Spezifischer SolarEdge Wert string 16 1 0 true false false false 40045 C_Version Spezifischer SolarEdge Wert string 8 1 0 true false false false 40053 C_Seriennummer Eindeutiger SolarEdge Wert string 16 1 0 true false false false 40069 C_DeviceAddress MODBUS Unit ID uint16be 1 1 0 true false false false 40070 C_SunSpec_DID 101 = Einphasig, 102 = Spaltphase, 103 = Dreiphasig uint16be 1 1 0 true false false false 40072 I_AC_Strom AC-Gesamtstromwert A uint16be 1 1 0 x * Math.pow(10, sf['40076']) true false false false 40073 I_AC_StromA AC-Phase A (L1) Stromwert A uint16be 1 1 0 x * Math.pow(10, sf['40076']) true false false false 40074 I_AC_StromB AC-Phase B (L2) Stromwert A uint16be 1 1 0 x * Math.pow(10, sf['40076']) true false false false 40075 I_AC_StromC AC-Phase C (L3) Stromwert A uint16be 1 1 0 x * Math.pow(10, sf['40076']) true false false false 40076 I_AC_Strom_SF AC-Strom Skalierungsfaktor SF int16be 1 1 0 true false false true 40084 I_AC_Leistung AC-Leistungswert W uint16be 1 1 0 x * Math.pow(10, sf['40085']) true false false false 40085 I_AC_Leistung_SF AC-Leistung Skalierungsfaktor SF int16be 1 1 0 true false false true 40088 I_AC_VA Scheinleistung VA uint16be 1 1 0 x * Math.pow(10, sf['40089']) true false false false 40089 I_AC_VA_SF Scheinleistung Skalierungsfaktor SF int16be 1 1 0 true false false true 40090 I_AC_VAR Blindleistung VAR uint16be 1 1 0 x * Math.pow(10, sf['40091']) true false false false 40091 I_AC_VAR_SF Blindleistung Skalierungsfaktor SF int16be 1 1 0 true false false true 40092 I_AC_PF Leistungsfaktor % uint16be 1 1 0 x * Math.pow(10, sf['40093']) true false false false 40093 I_AC_PF_SF Leistungsfaktor Skalierungsfaktor SF int16be 1 1 0 true false false true 40094 I_AC_Energie_WH AC Gesamt-Energieproduktion kWh uint32be 2 1 0 x * Math.pow(10, sf['40096'] - 3) true false false false 40096 I_AC_Energie_WH_SF AC Gesamtenergie Skalierungsfaktor SF uint16be 1 1 0 true false false true 40097 I_DC_Strom DC-Stromwert A uint16be 1 1 0 x * Math.pow(10, sf['40098']) true false false false 40098 I_DC_Strom_SF DC-Strom Skalierungsfaktor SF int16be 1 1 0 true false false true 40099 I_DC_Spannung DC-Spannungswert V uint16be 1 1 0 x * Math.pow(10, sf['40100']) true false false false 40100 I_DC_Spannung_SF DC-Spannung Skalierungsfaktor SF int16be 1 1 0 true false false true 40101 I_DC_Leistung DC-Leistungswert W uint16be 1 1 0 x * Math.pow(10, sf['40102']) true false false false 40102 I_DC_Leistung_SF DC-Leistung Skalierungsfaktor SF int16be 1 1 0 true false false true 40104 I_Temp_Kühler Kühlkörpertemperatur °C uint16be 1 1 0 x * Math.pow(10, sf['40107']) true false false false 40107 I_Temp_SF Kühlkörpertemperatur Skalierungsfaktor SF int16be 1 1 0 true false false true 40108 I_Status Betriebszustand (1 = Aus, 2 = Schlafen (Automatisches Herunterfahren) – Nachtmodus, 3 = Aufwachen/Starten, 4 = Wechselrichter ist AN und wandelt Energie, 5 = Begrenzte Produktion, 6 = Herunterfahren, 7 = Fehler, 8 = Wartung/Setup) uint16be 1 1 0 true false false false 40109 I_Status_Anbieter Anbieter-spezifischer Betriebszustand sowie Fehlercodes: 1 = Aus, 2 = Schlafen (Automatisches Herunterfahren) – Nachtmodus, 3 = Aufwachen/Starten, 4 = Wechselrichter ist AN und wandelt Energie, 5 = Begrenzte Produktion, 6 = Herunterfahren, 7 = Fehler, 8 = Wartung/Setup uint16be 1 1 0 true false false false 40124 C_Manufacturer Meter manufacturer string 32 1 0 true false false false 40140 C_Model Meter model string 32 1 0 true false false false 40156 C_Option Export + Import, Production, consumption string 16 1 0 true false false false 40191 M_AC_Current AC Current (sum of active phases) A uint16be 1 1 0 x * Math.pow(10, sf['40195']) true false false false 40192 M_AC_Current_A Phase A AC Current A uint16be 1 1 0 x * Math.pow(10, sf['40195']) true false false false 40193 M_AC_Current_B Phase B AC Current A uint16be 1 1 0 x * Math.pow(10, sf['40195']) true false false false 40194 M_AC_Current_C Phase C AC Current A uint16be 1 1 0 x * Math.pow(10, sf['40195']) true false false false 40195 M_AC_Current_S F AC Current Scale Factor SF int16be 1 1 0 true false false true 40207 M_AC_Power Total Real Power (sum of active phases) W int16be 1 1 0 x * Math.pow(10, sf['40211']) true false false false 40211 M_AC_Power_SF AC Real Power Scale Factor SF int16be 1 1 0 true false false true 40221 M_AC_PF Average Power Factor (average of active phases) % uint16be 1 1 0 x * Math.pow(10, sf['40226']) true false false false 40226 M_AC_PF_SF AC Power Factor Scale Factor SF int16be 1 1 0 true false false true 40227 M_Exported Total Exported Real Energy kWh uint32be 2 1 0 x * Math.pow(10, sf['40243'] - 3) true false false false 40235 M_Imported Total Imported Real Energy kWh uint32be 2 1 0 x * Math.pow(10, sf['40243'] - 3) true false false false 40243 M_Energy_W_SF Real Energy Scale Factor SF int16be 1 1 0 true false false trueBackup läuft täglich 02:00 Uhr.
...über
Modbus TCP, also Netzwerk.
Passiert da irgendwas im Netzwerk?
Oder mit dem WR?Die andere Vermutung war, dass der Rechner gerade mit Backup überfordert war, aber da passt die Zeit nicht.
...über
@homoran Mir ist nicht bewusst, was 04:50 Uhr im Netzwerk laufen könnte. Ob der Wechselrichter da was macht, kann ich auch nicht sagen - keine Ahnung, wo man dazu was herausfinden könnte…
Ich dachte erst, dass es zu viele holding Register sind welche ausgelesen werden, daher auch die hohen eingestellten Werte im Adapter abweichend von den Default-Werten. Der Fehler bleibt aber bestehen. -
Ich dachte erst, dass es zu viele holding Register sind welche ausgelesen werden, daher auch die hohen eingestellten Werte im Adapter abweichend von den Default-Werten. Der Fehler bleibt aber bestehen.@guitardoc ich habe so eine Meldung auch immer mal wieder, ab nie zu festen Zeiten.
Außerdem gehören dann da noch weitete Informationen im log dazu, die du aber anscheinend nicht hast. -
@homoran Sind das im Log auch Errors die du noch bekommst? Ich habe nur die beiden, nach Warnungen hab ich nicht geschaut - mache ich aber morgen früh mal.
nein!
Das sind warn!@guitardoc sagte in modbus Socket Error / Client in Error State:
bei Error sollte man immer im Umfeld nach weiteren Informationen suchen.
Diese müssen nicht unbedingt vom selben Adapter sein, der den Error wirft.
(in diesem Fall schon) -
nein!
(in diesem Fall schon)@homoran Habe tatsächlich noch was dazu gefunden:
modbus.0 2024-11-05 04:49:25.563 info Connected to slave 192.168.188.90 modbus.0 2024-11-05 04:48:24.553 warn On error: {"errno":-111,"code":"ECONNREFUSED","syscall":"connect","address":"192.168.188.90","port":1502} modbus.0 2024-11-05 04:48:24.552 error Client in error state. modbus.0 2024-11-05 04:48:24.552 error Socket Error modbus.0 2024-11-05 04:47:24.537 info Disconnected from slave 192.168.188.90Wenn der Modbus die Verbindung unterbricht, dann ist es natürlich kein Wunder, dass dann ein Fehler kommt. Daraus ergibt sich gleich die nächste Frage: Warum wird die Verbindung beendet und zwei Minuten später wieder hergestellt?
etwas davor wäre noch interessant!
(log ist falsch herum sortiert!)@guitardoc sagte in modbus Socket Error / Client in Error State:
oder das Netzwerk/ der WR grundsätzlich
