  4. modbus Socket Error / Client in Error State
11 Beiträge 2 Kommentatoren 1.1k Aufrufe 1 Beobachtet
  • G Offline
    guitardoc
    schrieb am zuletzt editiert von guitardoc
    Seit Monaten bekomme ich folgende Fehlermeldung:
    2024-11-03 04:50:16.392	error	Client in error state.
    2024-11-03 04:50:16.392	error	Socket Error
    Im wesentlichen jeden Tag weitgehend zur gleichen Zeit.
    iob diag:
    Script v.2024-10-19
    *** BASE SYSTEM ***
     Static hostname: iobroker
           Icon name: computer-container
             Chassis: container ☐
      Virtualization: lxc
              Kernel: Linux 6.8.12-2-pve
        Architecture: x86-64
    OS is similar to:
    model name	: Intel(R) Core(TM) i5-10210U CPU @ 1.60GHz
    Docker          : false
    Virtualization  : lxc
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     10:46:21 up 2 days, 17:32,  3 users,  load average: 2.81, 1.66, 1.00
    CPU threads: 2
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'bookworm'!
    *** TIME AND TIMEZONES ***
                   Local time: Sun 2024-11-03 10:46:21 CET
               Universal time: Sun 2024-11-03 09:46:21 UTC
                     RTC time: n/a
                  NTP service: inactive
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    mn
    HOME=/home/mn
    GROUPS=mn adm dialout sudo users iobroker
    iobroker
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout audio video plugdev
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal: 	tty
    System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
    *** MEMORY ***
    Mem:            8.6G        2.7G        3.7G        143K        2.0G        5.8G
    Swap:           536M          0B        536M
    Total:          9.1G        2.7G        4.2G
    Active iob-Instances: 	19
             8192 M total memory
             2615 M used memory
             2526 M active memory
             1855 M inactive memory
             3528 M free memory
                0 M buffer memory
             1922 M swap cache
              512 M total swap
                0 M used swap
              512 M free swap
    top - 10:46:21 up 2 days, 17:32,  3 users,  load average: 2.81, 1.66, 1.00
    Tasks:  65 total,   2 running,  63 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   8192.0 total,   3526.4 free,   2617.3 used,   1922.4 buff/cache
    MiB Swap:    512.0 total,    512.0 free,      0.0 used.   5574.7 avail Mem
    *** FAILED SERVICES ***
      UNIT                    LOAD   ACTIVE SUB    DESCRIPTION
    * run-rpc_pipefs.mount    loaded failed failed RPC Pipe File System
    * sys-kernel-config.mount loaded failed failed Kernel Configuration File System
    2 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    dmesg: read kernel buffer failed: Operation not permitted
    No critical errors detected
    *** FILESYSTEM ***
    Filesystem                       Type      Size  Used Avail Use% Mounted on
    /dev/mapper/pve-vm--101--disk--1 ext4       32G   14G   17G  45% /
    none                             tmpfs     492K  4.0K  488K   1% /dev
    /dev/mapper/pve-root             ext4       94G   83G  7.0G  93% /dev/ttyACM0
    udev                             devtmpfs   32G     0   32G   0% /dev/tty
    tmpfs                            tmpfs      32G     0   32G   0% /dev/shm
    tmpfs                            tmpfs      13G  132K   13G   1% /run
    tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs                            tmpfs     6.3G     0  6.3G   0% /run/user/1001
    Show mounted filesystems:
    TARGET         SOURCE                                                 FSTYPE OPTIONS
    /              /dev/mapper/pve-vm--101--disk--1                       ext4   rw,relatime,stripe=16
    `-/dev/ttyACM0 /dev/mapper/pve-root[/var/lib/lxc/101/devices/ttyACM0] ext4   rw,relatime,errors=remount-ro
    /var:
    3.6G	/var/
    2.2G	/var/lib
    2.1G	/var/lib/mysql
    1.9G	/var/lib/mysql/DBioBroker
    742M	/var/cache
    Archived and active journals take up 668.7M in the file system.
    /opt/iobroker/backups:
    2.1G	/opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.4G	/opt/iobroker/iobroker-data/
    1.3G	/opt/iobroker/iobroker-data/files
    617M	/opt/iobroker/iobroker-data/files/javascript.admin
    560M	/opt/iobroker/iobroker-data/files/javascript.admin/static
    558M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js
    31M	/opt/iobroker/iobroker-data/objects.jsonl
    26M	/opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
    26M	/opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
    24M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
    24M	/opt/iobroker/iobroker-data/files/vis-2/static/js/main.f305bc29.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2285504-if00
    HINT:
    Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
    /dev/ttyACM0
    *** NodeJS-Installation ***
    /usr/bin/nodejs 	v20.18.0
    /usr/bin/node 		v20.18.0
    /usr/bin/npm 		10.8.2
    /usr/bin/npx 		10.8.2
    /usr/bin/corepack 	0.29.3
    nodejs:
      Installed: 20.18.0-1nodesource1
      Candidate: 20.18.0-1nodesource1
      Version table:
     *** 20.18.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         18.19.0+dfsg-6~deb12u2 500
            500 http://deb.debian.org/debian bookworm/main amd64 Packages
         18.19.0+dfsg-6~deb12u1 500
            500 http://security.debian.org bookworm-security/main amd64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    iobroker            iobroker (version: 6.0.11, hostname: iobroker      , alive, uptime: 151)
    Core adapters versions
    js-controller: 	6.0.11
    admin: 		7.2.6
    javascript: 	8.8.3
    nodejs modules from github: 	0
    Adapter State
      system.adapter.alias-manager.0          : alias-manager         : iobroker                                 -  enabled
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
    + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
      system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
      system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
      system.adapter.eusec.0                  : eusec                 : iobroker                                 -  enabled
      system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
      system.adapter.followthesun.0           : followthesun          : iobroker                                 -  enabled
    + system.adapter.homeconnect.0            : homeconnect           : iobroker                                 -  enabled
      system.adapter.hydrawise.0              : hydrawise             : iobroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
    + system.adapter.javascript.1             : javascript            : iobroker                                 -  enabled
      system.adapter.logparser.0              : logparser             : iobroker                                 -  enabled
    + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1886, bind: 0.0.0.0
      system.adapter.notification-manager.0   : notification-manager  : iobroker                                 -  enabled
      system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
    + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.shelly.1                 : shelly                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
    + system.adapter.shuttercontrol.1         : shuttercontrol        : iobroker                                 -  enabled
    + system.adapter.shuttercontrol.2         : shuttercontrol        : iobroker                                 -  enabled
      system.adapter.solaredge.0              : solaredge             : iobroker                                 -  enabled
      system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1888, bind: 0.0.0.0
    + system.adapter.sql.0                    : sql                   : iobroker                                 -  enabled, port: 3306
    + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
      system.adapter.uv-protect.0             : uv-protect            : iobroker                                 -  enabled
      system.adapter.viessmannapi.0           : viessmannapi          : iobroker                                 -  enabled
      system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker                                 -  enabled
      system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled
      system.adapter.vis-map.0                : vis-map               : iobroker                                 - disabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 - disabled
      system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
      system.adapter.vw-connect.0             : vw-connect            : iobroker                                 -  enabled
    + system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled
      system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.yahka.0                  : yahka                 : iobroker                                 -  enabled
    + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyACM0
    + instance is alive
    ioBroker-Repositories
    │ (index) │ name          │ url                                                      │ auto upgrade │
    │ 0       │ 'stable'      │ 'https://download.iobroker.net/sources-dist.json'        │ false        │
    │ 1       │ 'beta'        │ 'https://download.iobroker.net/sources-dist-latest.json' │ false        │
    │ 2       │ 'live-stable' │ 'http://iobroker.live/repo/sources-dist.json'            │ false        │
    │ 3       │ 'live-beta'   │ 'http://iobroker.live/repo/sources-dist-latest.json'     │ false        │
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 7.1.5    , installed 7.2.6
    Adapter    "alias-manager": 1.2.6    , installed 1.2.6
    Adapter    "backitup"     : 3.0.25   , installed 3.0.25
    Adapter    "echarts"      : 1.9.2    , installed 1.9.2
    Adapter    "eusec"        : 1.3.3    , installed 1.3.3
    Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
    Adapter    "followthesun" : 0.5.1    , installed 0.5.1
    Adapter    "homeconnect"  : 1.4.1    , installed 1.4.1
    Adapter    "hydrawise"    : 1.0.2    , installed 1.0.2
    Adapter    "javascript"   : 8.8.3    , installed 8.8.3
    Controller "js-controller": 6.0.11   , installed 6.0.11
    Adapter    "logparser"    : 2.2.2    , installed 2.2.2
    Adapter    "modbus"       : 6.3.2    , installed 6.3.2
    Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
    Adapter    "notification-manager": 1.2.1, installed 1.2.1
    Adapter    "pvforecast"   : 3.0.0    , installed 4.0.0
    Adapter    "shelly"       : 8.2.1    , installed 8.2.1
    Adapter    "shuttercontrol": 1.8.3   , installed 1.8.3
    Adapter    "solaredge"    : 1.4.1    , installed 1.4.1
    Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
    Adapter    "sql"          : 3.0.1    , installed 3.0.1
    Adapter    "telegram"     : 3.9.0    , installed 3.9.0
    Adapter    "tuya"         : 3.16.0   , installed 3.16.0
    Adapter    "uv-protect"   : 0.6.3    , installed 0.6.3
    Adapter    "viessmannapi" : 2.3.0    , installed 2.3.0
    Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
    Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
    Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
    Adapter    "weatherunderground": 3.7.0, installed 3.7.0
    Adapter    "web"          : 6.2.5    , installed 6.2.5
    Adapter    "yahka"        : 1.0.3    , installed 1.0.3
    Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
    Objects and States
    Objects: 	21426
    States: 	16853
    Hit:2 http://security.debian.org bookworm-security InRelease
    Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:39193         0.0.0.0:*               LISTEN      1000       24897227   17606/io.yahka.0
    tcp        0      0 127.0.0.1:3306          0.0.0.0:*               LISTEN      105        14522      202/mariadbd
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          13189      372/master
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       24877930   15754/iobroker.js-c
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       24877925   15754/iobroker.js-c
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          12629      1/init
    tcp        0      0 0.0.0.0:1888            0.0.0.0:*               LISTEN      1000       24893189   17395/io.sonoff.0
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       24889189   17037/io.shelly.1
    tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1000       24886749   16396/io.mqtt.0
    tcp        0      0 0.0.0.0:1887            0.0.0.0:*               LISTEN      1000       24886750   16396/io.mqtt.0
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          13190      372/master
    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       24880176   15772/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1000       24895066   17531/io.web.0
    tcp6       0      0 :::111                  :::*                    LISTEN      0          12631      1/init
    tcp6       0      0 :::22                   :::*                    LISTEN      0          11236      1/init
    tcp6       0      0 :::1984                 :::*                    LISTEN      1000       24894725   17509/go2rtc
    tcp6       0      0 :::43993                :::*                    LISTEN      1000       24897191   17606/io.yahka.0
    tcp6       0      0 :::8554                 :::*                    LISTEN      1000       24894718   17509/go2rtc
    tcp6       0      0 :::8555                 :::*                    LISTEN      1000       24894719   17509/go2rtc
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          12630      1/init
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       24897192   17606/io.yahka.0
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       24889132   17011/io.shelly.0
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       24891021   17117/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       24891022   17117/io.tuya.0
    udp        0      0 0.0.0.0:43675           0.0.0.0:*                           1000       24894745   17479/io.eusec.0
    udp        0      0 0.0.0.0:46041           0.0.0.0:*                           1000       24894753   17479/io.eusec.0
    udp6       0      0 :::111                  :::*                                0          12632      1/init
    udp6       0      0 :::8555                 :::*                                1000       24894720   17509/go2rtc
    2024-11-03 10:45:44.029  - info: yahka.0 (17606) adding Bresser Bodenfeuchte with UUID: 4703a9aa-8572-44a5-b6e5-3baf35a133aa
    2024-11-03 10:45:44.029  - info: yahka.0 (17606) adding Bresser Bodentemperatur with UUID: 30b70e34-ac7e-4999-9d1d-7538f0f6debe
    2024-11-03 10:45:44.030  - info: yahka.0 (17606) adding Manuelle Bewässerung with UUID: 09b7e90a-e067-4f34-a1dc-e5966e5997cf
    2024-11-03 10:45:44.030  - info: yahka.0 (17606) adding Fensterputzmodus with UUID: 616febab-744f-4652-aa61-2ab267ba632a
    2024-11-03 10:45:44.030  - info: yahka.0 (17606) adding Bierversteck schließen Impuls with UUID: 6a246646-97b9-4c54-bcbd-e771539ef6e3
    2024-11-03 10:45:44.031  - info: yahka.0 (17606) adding Kontakt Schiebetor with UUID: 129d92a4-870e-443c-84bc-10ba7356359d
    2024-11-03 10:45:44.031  - info: yahka.0 (17606) adding Touareg Schloss with UUID: 86edc9cf-4e94-4db7-9376-6f035a19d2b4
    2024-11-03 10:45:44.031  - info: yahka.0 (17606) adding Szene Gute Nacht ausführen with UUID: 321259e0-a59d-4c0d-829d-ed59431c82ce
    2024-11-03 10:45:44.032  - info: yahka.0 (17606) adding Partymodus with UUID: 7989e14b-c1db-40ec-a040-643e7b746b05
    2024-11-03 10:45:44.032  - info: yahka.0 (17606) publishing bridge Yahka-0 on 0.0.0.0 using avahi
    2024-11-03 10:45:47.784  - info: viessmannapi.0 (17621) starting. Version 2.3.0 in /opt/iobroker/node_modules/iobroker.viessmannapi, node: v20.18.0, js-controller: 6.0.11
    2024-11-03 10:45:50.270  - info: viessmannapi.0 (17621) 1 installations found.
    2024-11-03 10:45:50.374  - info: viessmannapi.0 (17621) State value to set for "viessmannapi.0.2457409.gateways01.devices01.id" has to be type "number" but received type "string"
    2024-11-03 10:45:50.375  - info: viessmannapi.0 (17621) State value to set for "viessmannapi.0.2457409.gateways01.devices04.id" has to be type "string" but received type "number"
    2024-11-03 10:45:50.395  - debug: javascript.1 (15971) Could not parse value for id viessmannapi.0.2457409.gateways01.devices04.boilerSerialEditor into object: Unexpected token 'D', "DeviceCommunication" is not valid JSON
    2024-11-03 10:45:50.396  - debug: javascript.1 (15971) Could not parse value for id viessmannapi.0.2457409.gateways01.devices04.boilerSerialEditor into object: Unexpected token 'D', "DeviceCommunication" is not valid JSON
    2024-11-03 10:45:52.621  - info: echarts.0 (17636) starting. Version 1.9.2 in /opt/iobroker/node_modules/iobroker.echarts, node: v20.18.0, js-controller: 6.0.11
    2024-11-03 10:45:52.686  - info: sonoff.0 (17395) Client [Stromzähler] connected with secret 1730627152683_9462
    2024-11-03 10:45:59.787  - info: pvforecast.0 (17666) starting. Version 4.0.0 in /opt/iobroker/node_modules/iobroker.pvforecast, node: v20.18.0, js-controller: 6.0.11
    2024-11-03 10:45:59.795  - info: pvforecast.0 (17666) using system latitude: 51.278486150000006 longitude: 12.507069799527972
    2024-11-03 10:46:02.901  - info: pvforecast.0 (17666) Starting internal update cron (every 15 Minutes) for timezone: Europe/Berlin
    2024-11-03 10:46:04.154  - info: hydrawise.0 (17707) starting. Version 1.0.2 in /opt/iobroker/node_modules/iobroker.hydrawise, node: v20.18.0, js-controller: 6.0.11
    2024-11-03 10:46:07.822  - info: vis-2.0 (17722) starting. Version 2.9.64 in /opt/iobroker/node_modules/iobroker.vis-2, node: v20.18.0, js-controller: 6.0.11
    2024-11-03 10:46:07.983  - info: vis-2.0 (17722) vis-2 license is OK.
    2024-11-03 10:46:08.099  - info: vis-2.0 (17722) config.js changed. Upload.
    Hat jemand eine Idee, wie man das beheben kann? Danke schon mal im Voraus für die Hilfe.
    • G guitardoc
      iob diag:
      Script v.2024-10-19
      *** BASE SYSTEM ***
        Virtualization: lxc
      OS is similar to:
      Docker          : false
      Kernel          : x86_64
      Userland        : 64 bit
      CPU threads: 2
                       RTC time: n/a
                RTC in local TZ: no
      mn
      HOME=/home/mn
      iobroker
      HOME=/home/iobroker
      Desktop:
      Terminal: 	tty
      *** MEMORY ***
      Swap:           536M          0B        536M
               8192 M total memory
               2615 M used memory
               3528 M free memory
                  0 M buffer memory
               1922 M swap cache
                512 M total swap
                  0 M used swap
                512 M free swap
      *** FILESYSTEM ***
      /var:
      3.6G	/var/
      2.2G	/var/lib
      2.1G	/var/lib/mysql
      742M	/var/cache
      USB-Devices by-id:
      HINT:
      /dev/ttyACM0
      /usr/bin/npm 		10.8.2
      /usr/bin/npx 		10.8.2
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      admin: 		7.2.6
      javascript: 	8.8.3
      Adapter State
      + instance is alive
      Objects and States
      Objects: 	21426
      States: 	16853
      Pending Updates: 0
      @guitardoc sagte in modbus Socket Error / Client in Error State:
      was für ein Gerät?
      wie angebunden/konfiguriert?
      wann läuft dein Backup?
      • G Offline
        guitardoc
        Angebunden ist ein Solar Edge Wechselrichter...
        ...über folgende Holding Register:
        _address	name	description	unit	type	len	factor	offset	formula	role	room	poll	wp	cw	isScale
        97709	Batt1_Avg_T	Batterie 1 Average Temperature °C		floatsw	2	1	0		level		true	false	false	false
        101697	CommitSettings	Commit Power Control Settings		uint16be	1	1	0		level		true	false	false	false
        101698	Restore Power Control Default Settings	Restore Power Control Default Settings		uint16be	1	1	0		level		true	false	false	false
        101699	PwrFrqDeratingConfig	PwrFrqDeratingConfig		uint32sw	2	1	0		level		true	false	false	false
        101701	ReactivePwrConfig	ReactivePwrConfig		uint32sw	2	1	0		level		true	false	false	false
        101761	PowerReduce	PowerReduce		floatsw	2	1	0		level		true	false	false	false
        101763	AdvancedPwrControlEn	AdvancedPwrControlEn		uint32sw	2	1	0		level		true	false	false	false
        102209	Enable Dynamic Power Control	Enable Dynamic Power Control		uint16be	1	1	0		level		true	false	false	false
        102221	Active Power Limit	Active Power Limit	W	floatsw	2	1	0		level		true	false	false	false
        102223	Reactive Power Limit	Reactive Power Limit	W	floatsw	2	1	0		level		true	false	false	false
        102225	Command Timeout	Command Timeout	s	uint32sw	2	1	0		level		true	false	false	false
        102721	Battery 1 Manufacturer Name	Battery 1 Manufacturer Name		string	8	1	0		level		true	false	false	false
        102737	Battery 1 Model	Battery 1 Model		string	16	1	0		level		true	false	false	false
        102753	Battery 1 Firmware Version	Battery 1 Firmware Version		string	16	1	0		level		true	false	false	false
        102769	Battery 1 Serial Number	Battery 1 Serial Number		string	16	1	0		level		true	false	false	false
        102787	Batt Rated Energy	Batt Rated Energy	Wh	floatsw	2	1	0		level		true	false	false	false
        102789	Battery 1 Max Charge Continues Power	Battery 1 Max Charge Continues Power	W	floatsw	2	1	0		level		true	false	false	false
        102791	Battery 1 Max Discharge Continues Power	Battery 1 Max Discharge Continues Power	W	floatsw	2	1	0		level		true	false	false	false
        102829	Batt1_Avg_T	Batterie 1 Average Temperature °C	°C	floatsw	2	1	0		level		true	false	false	false
        102837	Speicher_Ladung	Speicher Ladeleistung	W	floatsw	2	1	0		level		true	false	false	false
        102839	xBattery 1 Lifetime Export Energy Counter	Battery 1 Lifetime Export Energy Counter	Wh	uint64le	4	1	0		value		true	false	false	false
        102843	xBattery 1 Lifetime Import Energy Counter	Battery 1 Lifetime Import Energy Counter	Wh	uint64le	4	1	0		value		true	false	false	false
        102847	Battery 1 Max Energy	Battery 1 Max Energy	Wh	floatsw	2	1	0		level		true	false	false	false
        102849	Battery 1 Available Energy	Battery 1 Available Energy	Wh	floatsw	2	1	0		level		true	false	false	false
        102851	Speicher_SoH	Batterie Alterung	%	floatsw	2	1	0		level		true	false	false	false
        102853	Speicher_SoC	Batterieladung	%	floatsw	2	1	0		level		true	false	false	false
        102855	Speicher_Betriebszustand	1: Aus, 3: Laden, 4: Entladen, 6: Erhaltungsladen		uint32sw	2	1	0		level		true	false	false	false
        102857	Battery 1 Status Internal	Battery 1 Status Internal		uint32sw	2	1	0		level		true	false	false	false
        102859	Battery 1 Events Log	Battery 1 Events Log		uint32sw	2	1	0		level		true	false	false	false
        102867	Battery 1 Events Log Internal	Battery 1 Events Log Internal		uint32sw	2	1	0		level		true	false	false	false
        103233	Export Control Mode	Export Control Mode		uint16be	1	1	0		level		true	false	false	false
        103234	Export Control Limit Mode	Export Control Limit Mode		uint16be	1	1	0		level		true	false	false	false
        103235	Export Control Site Limit	Export Control Site Limit		floatsw	2	1	0		level		true	false	false	false
        103237	Str	Storage control mode		uint16be	1	1	0		level		true	false	false	false
        103238	Storage_AC_Charge_Policy_RW	0: Disable, 1: Always allowed , 2: Fixed Energy Limit		uint16be	1	1	0		level		true	false	false	false
        103239	Storage AC Charge Limit	Storage AC Charge Limit	%	floatsw	2	1	0		level		true	false	false	false
        103241	Storage_Backup_Reserved_Setting	Storage Backup Reserved Setting	%	floatsw	2	1	0		level		true	false	false	false
        103243	StChDisChMode	Storage Charge/Discharge Mode		uint16be	1	1	0		level		true	false	false	false
        103244	Timeout	Timout	sec	uint32sw	2	1	0		level		true	false	false	false
        103246	Remote Control Command Mode RW	Remote Control Command Mode RW		uint16be	1	1	0		level		true	false	false	false
        103247	Remote Control Charge Limit	Remote Control Charge Limit	W	floatsw	2	1	0		level		true	false	false	false
        103249	Remote Control Command Discharge Limit	Remote Control Command Discharge Limit	W	floatsw	2	1	0		level		true	false	false	false
        40001	C_SunSpec_ID	"Wert = ""SunS"" (0x53756e53). Identifiziert dies eindeutig als eine SunSpec Modbus-Karte"		uint32be	2	1	0				true	false	false	false
        40003	C_SunSpec_DID	Wert = 0x0001. Identifiziert dies eindeutig als einen SunSpec “Common Block“		uint16be	1	1	0				true	false	false	false
        40004	C_SunSpec_Länge	65 = Länge eines Blocks in 16-bit Registern		uint16be	1	1	0				true	false	false	false
        40005	C_Hersteller	"Bei SunSpec eingetragener Wert = ""SolarEdge"""		string	16	1	0				true	false	false	false
        40021	C_Modell	Spezifischer SolarEdge Wert		string	16	1	0				true	false	false	false
        40045	C_Version	Spezifischer SolarEdge Wert		string	8	1	0				true	false	false	false
        40053	C_Seriennummer	Eindeutiger SolarEdge Wert		string	16	1	0				true	false	false	false
        40069	C_DeviceAddress 	MODBUS Unit ID		uint16be	1	1	0				true	false	false	false
        40070	C_SunSpec_DID	101 = Einphasig, 102 = Spaltphase, 103 = Dreiphasig		uint16be	1	1	0				true	false	false	false
        40072	I_AC_Strom	AC-Gesamtstromwert	A	uint16be	1	1	0	x * Math.pow(10, sf['40076'])			true	false	false	false
        40073	I_AC_StromA	AC-Phase A (L1) Stromwert	A	uint16be	1	1	0	x * Math.pow(10, sf['40076'])			true	false	false	false
        40074	I_AC_StromB	AC-Phase B (L2) Stromwert	A	uint16be	1	1	0	x * Math.pow(10, sf['40076'])			true	false	false	false
        40075	I_AC_StromC	AC-Phase C (L3) Stromwert	A	uint16be	1	1	0	x * Math.pow(10, sf['40076'])			true	false	false	false
        40076	I_AC_Strom_SF	AC-Strom Skalierungsfaktor	SF	int16be	1	1	0				true	false	false	true
        40084	I_AC_Leistung	AC-Leistungswert	W	uint16be	1	1	0	x * Math.pow(10, sf['40085'])			true	false	false	false
        40085	I_AC_Leistung_SF	AC-Leistung Skalierungsfaktor	SF	int16be	1	1	0				true	false	false	true
        40088	I_AC_VA	Scheinleistung	VA	uint16be	1	1	0	x * Math.pow(10, sf['40089'])			true	false	false	false
        40089	I_AC_VA_SF	Scheinleistung Skalierungsfaktor	SF	int16be	1	1	0				true	false	false	true
        40090	I_AC_VAR	Blindleistung	VAR	uint16be	1	1	0	x * Math.pow(10, sf['40091'])			true	false	false	false
        40091	I_AC_VAR_SF	Blindleistung Skalierungsfaktor	SF	int16be	1	1	0				true	false	false	true
        40092	I_AC_PF	Leistungsfaktor	%	uint16be	1	1	0	x * Math.pow(10, sf['40093'])			true	false	false	false
        40093	I_AC_PF_SF	Leistungsfaktor Skalierungsfaktor	SF	int16be	1	1	0				true	false	false	true
        40094	I_AC_Energie_WH	AC Gesamt-Energieproduktion	kWh	uint32be	2	1	0	x * Math.pow(10, sf['40096'] - 3)			true	false	false	false
        40096	I_AC_Energie_WH_SF	AC Gesamtenergie Skalierungsfaktor	SF	uint16be	1	1	0				true	false	false	true
        40097	I_DC_Strom	DC-Stromwert	A	uint16be	1	1	0	x * Math.pow(10, sf['40098'])			true	false	false	false
        40098	I_DC_Strom_SF	DC-Strom Skalierungsfaktor	SF	int16be	1	1	0				true	false	false	true
        40099	I_DC_Spannung	DC-Spannungswert	V	uint16be	1	1	0	x * Math.pow(10, sf['40100'])			true	false	false	false
        40100	I_DC_Spannung_SF	DC-Spannung Skalierungsfaktor	SF	int16be	1	1	0				true	false	false	true
        40101	I_DC_Leistung	DC-Leistungswert	W	uint16be	1	1	0	x * Math.pow(10, sf['40102'])			true	false	false	false
        40102	I_DC_Leistung_SF	DC-Leistung Skalierungsfaktor	SF	int16be	1	1	0				true	false	false	true
        40104	I_Temp_Kühler	Kühlkörpertemperatur	°C	uint16be	1	1	0	x * Math.pow(10, sf['40107'])			true	false	false	false
        40107	I_Temp_SF	Kühlkörpertemperatur Skalierungsfaktor	SF	int16be	1	1	0				true	false	false	true
        40108	I_Status	Betriebszustand (1 = Aus, 2 = Schlafen (Automatisches Herunterfahren) – Nachtmodus, 3 = Aufwachen/Starten, 4 = Wechselrichter ist AN und wandelt Energie, 5 = Begrenzte Produktion, 6 = Herunterfahren, 7 = Fehler, 8 = Wartung/Setup)		uint16be	1	1	0				true	false	false	false
        40109	I_Status_Anbieter	Anbieter-spezifischer Betriebszustand sowie Fehlercodes: 1 = Aus, 2 = Schlafen (Automatisches Herunterfahren) – Nachtmodus, 3 = Aufwachen/Starten, 4 = Wechselrichter ist AN und wandelt Energie, 5 = Begrenzte Produktion, 6 = Herunterfahren, 7 = Fehler, 8 = Wartung/Setup		uint16be	1	1	0				true	false	false	false
        40124	C_Manufacturer	Meter manufacturer		string	32	1	0				true	false	false	false
        40140	C_Model	Meter model		string	32	1	0				true	false	false	false
        40156	C_Option	Export + Import, Production, consumption		string	16	1	0				true	false	false	false
        40191	M_AC_Current	AC Current (sum of active phases)	A	uint16be	1	1	0	x * Math.pow(10, sf['40195'])			true	false	false	false
        40192	M_AC_Current_A	Phase A AC Current	A	uint16be	1	1	0	x * Math.pow(10, sf['40195'])			true	false	false	false
        40193	M_AC_Current_B	Phase B AC Current	A	uint16be	1	1	0	x * Math.pow(10, sf['40195'])			true	false	false	false
        40194	M_AC_Current_C	Phase C AC Current	A	uint16be	1	1	0	x * Math.pow(10, sf['40195'])			true	false	false	false
        40195	M_AC_Current_S F	AC Current Scale Factor	SF	int16be	1	1	0				true	false	false	true
        40207	M_AC_Power	Total Real Power (sum of active phases)	W	int16be	1	1	0	x * Math.pow(10, sf['40211'])			true	false	false	false
        40211	M_AC_Power_SF	AC Real Power Scale Factor	SF	int16be	1	1	0				true	false	false	true
        40221	M_AC_PF	Average Power Factor (average of active phases)	%	uint16be	1	1	0	x * Math.pow(10, sf['40226'])			true	false	false	false
        40226	M_AC_PF_SF	AC Power Factor Scale Factor	SF	int16be	1	1	0				true	false	false	true
        40227	M_Exported	Total Exported Real Energy	kWh	uint32be	2	1	0	x * Math.pow(10, sf['40243'] - 3)			true	false	false	false
        40235	M_Imported	Total Imported Real Energy	kWh	uint32be	2	1	0	x * Math.pow(10, sf['40243'] - 3)			true	false	false	false
        40243	M_Energy_W_SF	Real Energy Scale Factor	SF	int16be	1	1	0				true	false	false	true
        Backup läuft täglich 02:00 Uhr.
        • G guitardoc
          ...über
          Modbus TCP, also Netzwerk.
          Passiert da irgendwas im Netzwerk?
          Oder mit dem WR?
          Die andere Vermutung war, dass der Rechner gerade mit Backup überfordert war, aber da passt die Zeit nicht.
          G 1 Antwort Letzte Antwort
            ...über
            Oder mit dem WR?
            guitardoc
            @homoran Mir ist nicht bewusst, was 04:50 Uhr im Netzwerk laufen könnte. Ob der Wechselrichter da was macht, kann ich auch nicht sagen - keine Ahnung, wo man dazu was herausfinden könnte…
            Ich dachte erst, dass es zu viele holding Register sind welche ausgelesen werden, daher auch die hohen eingestellten Werte im Adapter abweichend von den Default-Werten. Der Fehler bleibt aber bestehen.
            • G guitardoc
              @guitardoc ich habe so eine Meldung auch immer mal wieder, ab nie zu festen Zeiten.
              Außerdem gehören dann da noch weitete Informationen im log dazu, die du aber anscheinend nicht hast.
                guitardoc
                @homoran Sind das im Log auch Errors die du noch bekommst? Ich habe nur die beiden, nach Warnungen hab ich nicht geschaut - mache ich aber morgen früh mal.
                • G guitardoc
                  nein!
                  Das sind warn!
                  bei Error sollte man immer im Umfeld nach weiteren Informationen suchen.
                  Diese müssen nicht unbedingt vom selben Adapter sein, der den Error wirft.
                  (in diesem Fall schon)
                    nein!
                    Das sind warn!
                    guitardoc
                    @homoran Habe tatsächlich noch was dazu gefunden:
                    modbus.0
                    2024-11-05 04:49:25.563	info	Connected to slave 192.168.188.90
                    modbus.0
                    2024-11-05 04:48:24.553	warn	On error: {"errno":-111,"code":"ECONNREFUSED","syscall":"connect","address":"192.168.188.90","port":1502}
                    modbus.0
                    2024-11-05 04:48:24.552	error	Client in error state.
                    modbus.0
                    2024-11-05 04:48:24.552	error	Socket Error
                    modbus.0
                    2024-11-05 04:47:24.537	info	Disconnected from slave 192.168.188.90
                    Wenn der Modbus die Verbindung unterbricht, dann ist es natürlich kein Wunder, dass dann ein Fehler kommt. Daraus ergibt sich gleich die nächste Frage: Warum wird die Verbindung beendet und zwei Minuten später wieder hergestellt?
                    • G guitardoc
                      modbus.0
                      modbus.0
                      modbus.0
                      modbus.0
                      modbus.0
                      etwas davor wäre noch interessant!
                      (log ist falsch herum sortiert!)
                      oder das Netzwerk/ der WR grundsätzlich
                      • G Offline
                        guitardoc
                        @homoran Davor und danach passiert nichts. Auch nicht in anderen Adaptern...
