Bose Soundtouch steuern
Der Adapter stellt doch Links zu senderbildern für die presets bereit. Nimm doch die einfach als Image Source … oder verstehe ich was falsch? `
Danke für den Wink.
Es funktioniert leider nicht überall
Habe mal ein Bild eingefügt von "bosesoundtouch.0.nowPlaying.art"
[{"tpl":"tplValueStringImg","data":{"oid":"bosesoundtouch.0.nowPlaying.art","g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0},"style":{"left":"110px","top":"24px","width":"140px","height":"140px"},"widgetSet":"basic"}]Dort wird jedoch nicht immer die URL aus "iconURL" rein geschrieben. Bei "INTERNET_RADIO" = OK Bei "TUNEIN" = nicht OK –-> hier wird auch der Name nicht in Station geschrieben Gruß Jürgen -
…Dort wird jedoch nicht immer die URL aus "iconURL" rein geschrieben.
Bei "TUNEIN" = nicht OK ---> hier wird auch der Name nicht in Station geschrieben `
Die fehlenden Infos für TuneIn sind in der neuen Version 0.1.5 behoben!Darin hab ich auch den state 'playEverywhere' dahingehend geändert, dass nach dem Aktivieren automatisch der Haken wieder entfernt wird. Ich hoffe, das vereinfacht die Verwendung.
Da meine Presets in 2 Jahren nicht geändert wurden passt das für mich.
Aber die Icon auslesen wäre auch interessant.
Da werd ich mich mal dran setzen
Hallo zusammen. Habe folgendes Problem.
Ich kann den Adapter leider nicht installieren. Ich hoffe mir kann jemand helfen? Vielen Dank voraus
Hallo Ben aus Hamburg.
Geht’s a bisserl genauer? Ohne Problembeschreibung ist die Hilfestellung denkbar einfach: gelöst :lol:
Taucht der Adapter in der Liste (ioBroker.admin / Adapter) auf? Wenn nicht, in den Einstellungen (Haupteinstellungen / Aktiver Verwahrungsort) auf latest bzw. online umstellen und Liste aktualisieren.
Ansonsten bitte ein paar Zeilen Prosa, dann 'wirst du geholfen' ;)
Danke für die Antwort. Nach mehreren Anläufen hat es geklappt.Kann mir jemand sagen wie ich ein Track weiter/ zurück schalten kann und wie man Bluetooth aktiviren kann? anbei Ansicht meiner View.
Grüße Ben
Kann mir jemand sagen wie ich ein Track weiter/ zurück schalten kann und wie man Bluetooth aktiviren kann? `
Track vor/zurück funktioniert durch schreiben der Strings "PREV_TRACK" bzw. "NEXT_TRACK" in den Datenpunkt "key".Für das Umschalten auf Quelle Bluetooth bzw. auch andere (TV…) hab ich leider nichts gefunden. Da das aber auch mit der Bose SoundTouch App nicht geht, vermute ich mal, dass das nicht vorgesehen ist. Genau das wollte ich aber eh schon bei Bose nachfragen...
Sollte per Webservice über /select" gehen. Dort kannst Du auch "BLUETOOTH" und "AUX" senden. Webservices Doku 6.2 :) … wenn /sources diese enthält das Sie da sind `
In der neuen online-Doku ist das alles wesentlich übersichtlicher beschrieben. Hab mir das im alten PDF wohl zu schlampig durchgelesen.Nach ein wenig herumprobieren in meinem Restlet Client mit /sources und /select kann ich jetzt tatsächlich die Quellen umschalten - auch auf TV!
Werde das demnächst in den Adapter einbauen, bin aber noch unschlüssig, wie ich das am besten umsetzen kann.
Eine Frage dazu: wie kann ich am besten die Quellen, die mit /sources empfangen werden im ioBroker auflisten und event mit einem state 'play' versehen?
Leg doch alle zurückgelieferten sources als States typ "Button" an :-)
sources.TV, sources.BLUETOOTH und so …
Hallo zusammen.
Vorab, ich hoffe es ist OK wenn ich etwas bezüglich Alexa und dem Bose Adapter frage. Wenn dem nicht so sein sollte bitte löschen.
Komme irgendwie nicht weiter.
Ich habe zur Zeit meine Multimedia Kram ( Samsung Fernseher, VU+ Satbox und eine Bose Soundtouch) über den Harmony Adapter laufen. Da dieser aber gefühlt jede halbe Stunde die Verbindung verliert und nicht mehr das macht was er eigentlich soll möchte ich gern davon weg. Für den Samsung Fernseher gibt es ja den entsprechenden Adapter worüber man ein und ausschalten kann. Genau so sieht es bei der VU+ aus. Da geht es problemlos mit dem Enigma 2 Adapter.
Jedoch weiß ich nicht wie ich das bei dem Bose Soundtouch Adapter machen soll.
Mit einfach ein und ausschalten ist es ja nicht getan. Es muss ja auch die Quelle gewählt werden. Und genau da weiß ich nicht wie ich das in Kombination mit Alexa machen kann / soll. Morgens hören wir Internet Radio und nachmittags läuft der Ton von dem Fernseher drüber. Daher ist ein einfaches ein und ausschalten nicht möglich.
Danke im voraus für eure Hilfe.
Gruß Markus
Getippt von unterwegs mit Tapatalk Pro.
Hallo allerseits,
verzeiht bitte meine nachstehende Frage, da ich mir nicht sicher bin, ob ich hier im richtigen Tread bin, um einen Ratschlag zu bekommen.
Ich habe zuvor das JavaScript zu Steuern des Soundtouch genutzt. Funktionierte super, allerdings war das mit der Alexa-Steuerung etwas blöd, da ich in den Geräten für jede Funktion ein Gerät eintragen musste. (Bin einfach zu blöd um in einem Gerät darzustellen. Gerätenamen zur Steuerung waren:
Nun habe ich den hier genannten Adapter installier und das läuft völlig fehlerfrei (COOLE SACHE, DANKE AN DEN/DIE ENTWICKLER!) und hatte erhofft, dass ich nun in Alexa ein Gerät hinzufüge, welches auf An/Aus und Kanal x reagiert. Hier ist genau mein Problem… wie und was müsste ich einstellen, damit das mit Alexa und einem Gerät klappt?
Wenn ich hier falsch bin, dann sorry dafür!!!
Andy
Hallo Andy,
ich habe das über den Szenen Adapter gelöst.
In der Szene Sender 1 dann bosesoundtouch.0.key den Wert PRESET_1.
Habe auf 1 z.B. Amazon Music Charts.
Im Cloud Adapter dann die Szene mit dem Namen Charts versehen.
Alexa schalte Charts ein, funktioniert so wunderbar.
Bin leider gerade auf dem Sprung zur Arbeit, aber vielleicht hilft Dir das ja schon weiter.
Nanouk
Hallo Andy,
Nanouk ` Wenn ich fragen darf, wie schaltest du dann über Alexa wieder aus? Damit ich meinen Harmony Adapter in Rente schicken kann, würde ich auch gern mit dem Szene Adapter und mit dem Cloud Adapters das ganze umsetzen, aber mit der erstellten Szene kann man ja nur anschalten nicht ausschalten. Richtig?
Gruß Markus
Naja,
ich habe zwar eine separate Szene "Bose" zum ein und ausschalten,
aber wenn Du bei "Setzen bei False" den Haken setzt und statt PRESET_2 dort dann POWER einträgst, schaltest Du auch damit aus.
Zumindest hat es eben auf die schnelle funktioniert.
Nanouk
