  4. Ersatz für sayit-Adapter zur Sprachausgabe auf Sonos
    6.5k
40 Beiträge 9 Kommentatoren 6.5k Aufrufe 7 Beobachtet
  • mickymM mickym
    @david-g Ich hab den curl Befehl selbst in die exec Node verfrachtet - kann man aber auch in der Template Node belassen.
    Deshalb siehst Du ihn in der Debugausgabe nicht.
    Also der Befehl würde dann vollständig so heißen:
    curl -d \ <play_info><app_key>xxxxxxx</app_key><url>http://192.168.99.33:8083/proxy.0/nodetts/f47f65d4ae122e0003d1f51977b47d71.mp3</url><service>service text</service><reason>reason text</reason><message>message text</message><volume>50</volume></play_info>" http://192.168.99.24:8090/speaker
    Hier der Flow:
    und hier der Export:
           "id": "ea4ec0a982311ad6",
           "type": "ttsultimate",
           "z": "fec1825aaae0effe",
           "name": "TTS-Ultimate",
           "voice": "de-DE",
           "ssml": false,
           "sonosipaddress": "",
           "sonosvolume": "20",
           "sonoshailing": "0",
           "config": "35ab450e7c673246",
           "property": "payload",
           "propertyType": {},
           "rules": [],
           "playertype": "noplayer",
           "speakingrate": "1",
           "speakingpitch": "0",
           "unmuteIfMuted": true,
           "elevenlabsStability": "0.5",
           "elevenlabsSimilarity_boost": "0.5",
           "x": 390,
           "y": 200,
           "wires": [
                   "2806f509e602fe63",
                   "5e8ec1239a8adc51"
           "id": "2806f509e602fe63",
           "type": "debug",
           "name": "tts output",
           "active": true,
           "tosidebar": true,
           "console": false,
           "tostatus": false,
           "complete": "true",
           "targetType": "full",
           "statusVal": "",
           "statusType": "auto",
           "x": 680,
           "y": 100,
           "wires": []
           "id": "491be7923b8a7632",
           "type": "debug",
           "name": "Befehl",
           "active": true,
           "tosidebar": true,
           "console": false,
           "tostatus": false,
           "complete": "payload",
           "targetType": "msg",
           "statusVal": "",
           "x": 1370,
           "y": 100,
           "wires": []
           "id": "f33f16b8963a9bac",
           "type": "template",
           "name": "",
           "field": "payload",
           "fieldType": "msg",
           "format": "handlebars",
           "syntax": "mustache",
           "template": "\"<play_info><app_key>xxxxxxx</app_key><url>http://192.168.99.33:8083/proxy.0/nodetts/{{payload}}</url><service>service text</service><reason>reason text</reason><message>message text</message><volume>{{volume}}</volume></play_info>\" http://192.168.99.24:8090/speaker",
           "output": "str",
           "x": 1200,
           "y": 180,
           "wires": [
                   "491be7923b8a7632",
                   "7aaa60cfd020f3ca"
           "id": "28729562ca781877",
           "type": "ioBroker in",
           "name": "",
           "attrname": "payload",
           "topic": "0_userdata.0.tts",
           "payloadType": "value",
           "onlyack": "",
           "func": "all",
           "gap": "",
           "fireOnStart": "false",
           "outFormat": "MQTT",
           "x": 180,
           "y": 200,
           "wires": [
                   "ea4ec0a982311ad6"
           "id": "9828506682942416",
           "type": "ioBroker get",
           "name": "",
           "topic": "0_userdata.0.vol",
           "attrname": "volume",
           "errOnInvalidState": "nothing",
           "x": 760,
           "y": 180,
           "wires": [
                   "38820d3ffb950c33"
           "id": "5e8ec1239a8adc51",
           "type": "switch",
           "name": "fertig ?",
           "propertyType": "msg",
           "rules": [
                   "t": "true"
           "checkall": "true",
           "repair": false,
           "outputs": 1,
           "x": 590,
           "y": 180,
           "wires": [
                   "9828506682942416"
           "id": "7aaa60cfd020f3ca",
           "type": "exec",
           "command": "curl -d \\ ",
           "addpay": "payload",
           "append": "",
           "useSpawn": "false",
           "timer": "5",
           "winHide": false,
           "oldrc": false,
           "name": "",
           "x": 1380,
           "y": 180,
           "wires": [
                   "9a11f7b2222a6304"
                   "b24feb9e68406c99"
           "id": "9a11f7b2222a6304",
           "type": "debug",
           "name": "stdout",
           "active": true,
           "tosidebar": true,
           "console": false,
           "tostatus": false,
           "statusVal": "",
           "x": 1530,
           "y": 140,
           "wires": []
           "id": "38820d3ffb950c33",
           "type": "change",
           "name": "payload nur Dateiname",
           "rules": [
                   "t": "set",
                   "p": "payload",
                   "pt": "msg",
                   "to": "filesArray.0.file",
                   "tot": "msg"
                   "t": "change",
                   "p": "payload",
                   "pt": "msg",
                   "from": ".*/ttsfiles/(.*)$",
                   "fromt": "re",
                   "to": "$1",
                   "tot": "str"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 990,
           "y": 180,
           "wires": [
                   "f33f16b8963a9bac"
           "id": "b24feb9e68406c99",
           "type": "debug",
           "name": "stderr",
           "active": true,
           "tosidebar": true,
           "console": false,
           "tostatus": false,
           "statusVal": "",
           "x": 1530,
           "y": 180,
           "wires": []
           "id": "35ab450e7c673246",
           "type": "ttsultimate-config",
           "name": "TTS Service",
           "noderedipaddress": "192.168.178.69",
           "noderedport": "1980",
           "purgediratrestart": "leave",
           "ttsservice": "googletranslate",
           "TTSRootFolderPath": "/home/iobroker/tts"
    Die Debug Nodes kannst ja dann alle wieder entfernen bzw. deaktivieren.
    Wie gesagt, Du kannst die Ablage der mp3 s auch woanders hinlegen, Du musst das halt im Root tts Verzeichnis festlegen und der User iobroker muss halt Schreib- und Leserechte auf den Ordner haben.
    Wenn Du diese Jingle also das Hailing noch davor haben willst - dann kann das nacheinander abgespielt werden, dann musst Du Deinen Proxy auf das Verzeichnis vorher definieren.
    Wenn das direkte Sonos Lautsprecher sind, kannst Du das aber doch auch direkt ausgeben, dann brauchst Du nicht mit curl arbeiten. Das ist doch viel eleganter?
    David G.D Online
    David G.D Online
    David G.
    @mickym
    Passt auf Anhieb (bis ich dran gedacht habe den API-Key wieder einzutragen).
    Danke.
    Wenn ich vor und nach den Text der gesprochen werden soll mache ich das mit einer template Node an zweiter Stelle?
    • David G.D David G.
      @mickym
      Danke.
      mickymM Offline
      mickymM Offline
      mickym
      @david-g Wie gesagt, ich versteh zwar nicht, warum Du Deine Lautsprecher nicht direkt über die Node ansteuerst?
      Nein Du nimmst ein Array - zum Beispiel mit dem Hailing und gibst halt dann mehrere mp3 in den Flow - oder in die Template Node ein.
      Aber wie gesagt, warum nutzt Du die Node nicht direkt zur Ausgabe?
      • mickymM mickym
        David G.D Online
        David G.D Online
        David G.
        @mickym sagte in Ersatz für sayit-Adapter zur Sprachausgabe auf Sonos:
        Ich habe eine Bose Soundtouch.
        Da gibt es keinen Adapter bzw Node um diese anzusteuern. Über den curl Befehl kann man aber Dinge an die Box senden.
        Für vor und nach den Text geht es nicht um mp3s.
        Ich möchte vor den Text noch SSML Kommandos setzen.
        Hab das jetzt erfolgreich mit der template Node umgesetzt.
          mickymM Offline
          mickymM Offline
          mickym
          @david-g sagte in Ersatz für sayit-Adapter zur Sprachausgabe auf Sonos:
          ok
          • mickymM mickym
            ok
            David G.D Online
            David G.D Online
            David G.
            @mickym
            Kann ich irgendwie rausfinden, was er in der Node zu bemängeln hat?
            Habe alle Settings doppelt geprüft, klappt auch alles.
            Screenshot_20240623_200509_Chrome.jpg Screenshot_20240623_200521_Chrome.jpg Screenshot_20240623_200928_Photos.jpg
            Das erste popup kommt bei jedem Speichern.
              @mickym
              mickymM Offline
              mickymM Offline
              mickym
              @david-g Na klick halt auf suche nach unbenutzen Konfigurationsnode und lösche diese. Also entweder hast Du meine Konfig übernommen TTS Service oder Deine - aber halt nur eine verwendest Du in Deiner tts node. Sieht aber so aus dass Du die TTS Service mit dem Import übernommen hast und nicht verwendest.
              Also die TTS Service Node in den Konfigurationsnodes löschen.
              • FeuersturmF Offline
                FeuersturmF Offline
                Feuersturm
                @surfer09 sagte in Ersatz für sayit-Adapter zur Sprachausgabe auf Sonos:
                Was mache ich denn, wenn er den Lautsprecher nicht findet? Ich habe den Symfonisk von IKEA, im Prinzip Sonos. Er sucht schon eine ganze Zeit und findet scheinbar nichts...
                Hast du hierfür eine Lösung gefunden? Ich hab gerade node-red installiert und das Paket installiert und versuche auch gerade das System zu konfigurieren, sehe bei mir aber auch das "Discovering...waiting" und habe auch den IKEA Sonos Lautsprecher.
                surfer09S 1 Antwort Letzte Antwort
                • FeuersturmF Feuersturm
                  surfer09S Offline
                  surfer09S Offline
                  surfer09
                  @feuersturm Nein, leider nicht. Ich nutze wieder die HTTP API Schnittstelle.
                  • surfer09S surfer09
                    FeuersturmF Offline
                    FeuersturmF Offline
                    Feuersturm
                    @surfer09 Nachdem ich zwischendurch mal auf "deploy" geklickt hatte und das Objekt dann nochmal geöffnet hatte kam danach ein grüner Punkt und der Lautsprecher wurde gefunden. Ich kann nur leider gerade nicht weiter testen, da ansonsten das Kind wach wir, da in dem Zimmer die Box steht ;-)
                      kptkip
                      schrieb am zuletzt editiert von kptkip
                      @surfer09
                      Ich hab hier schon lange nicht mehr reingeschaut, sorry dafür..😇
                      Meine Vermutung ist, dass da ein Netzwerk-Problem vorliegen könnte. Wenn der IOBroker - also auch der Node-Red im gleichen Netz wie die SONOS-Lautsprecher ist, dann sollte es klappen. Meine Ikea-Boxen werden wie der SONOS-Rest gleichermaßen gefunden.
                      Check vlt auch mal in der TTS-Ultimate-Config, ob die IOBroker-IP hier eingetragen ist:
                      • wendy2702W wendy2702
                        Bin über diesen Thread gestolpert da auch Sayit bei mir nicht mehr funktioniert.
                        Könntet ihr mir dennoch den Gefallen tun entweder ein entsprechendes Issue auf GitHub zu öffnen oder z.b. hier
                        https://github.com/ioBroker/ioBroker.sayit/issues/320
                        Oder hier https://github.com/ioBroker/ioBroker.sayit/issues/269
                        Oder hier https://github.com/ioBroker/ioBroker.sayit/issues/278
                        Zu kommentieren.
                        kptkip
                        @wendy2702
                        Ich glaube mich erinnern zu können, dass ich sowohl hier im sayIt-Thread im Forum als auch auf Github die Problem reportet habe.
                        Es kam entweder keine Antwort, oder dass ich irgendwelche Probleme in meiner IoBroker-Installation und nodejs-Versionskonflikte o.Ä. hätte und erstmal meine Installation prüfen sollte. Vor allem das Upload-der-Gong-Mp3s-Problem wurde völlig runter gespielt - auch das Nicht-Finden der SONOS-Geräte (waren von einem Tag auf den anderen weg) wurde mal wieder als "mein" Problem abgetan. Hilfe ist beim Maintainer des sayIt-Adapters nicht zu erwarten.
                        Ganz zu schweigen vom Feature, mehrere SONOS-Geräte anzusprechen. Das kann nur durch eine dementsprechende Anzahl von zu installierenden Adaptern gelöst werden mit dementsprechenden RAM-Verbrauch.:man-facepalming:
                        • K kptkip
                          @wendy2702
                          wendy2702W Online
                          wendy2702W Online
                          @kptkip hi,
                          Hast du mich oder den Thread vielleicht irgendwie verwechselt?
                            @kptkip hi,
                            kptkip
                            @wendy2702
                            1. Nein, da ich diesen thread eröffnet habe und andere Personen Off-Topic weiter geführt haben, ohne einen eigenen aufzumachen.
                            2. Nein, da es eine direkte Antwort auf Deinen ersten Beitrag (Nr. 7 hier im Thread) ist.
                            Im Gegensatz zu anderen Personen hier bin ich wieder beim Thema des Threads.
                            Es wäre also schön, wenn für das Thema mit der "location von mp3 -Files" etc. ein eigener Thread aufgemacht würde. Dann könnten wir uns hier wieder ungestört über das Original-Thema unterhalten.
                            • wendy2702W Online
                              wendy2702W Online
                              @kptkip mein Post ist von Juni und ich habe damals hauptsächlich auf die Github issues aufmerksam gemacht und gebeten diese zu unterstützen.
                              In Summe gab es dann 4 Posts die „Off Topic“ waren.
                              Weiß nicht wo jetzt aktuell dein Problem damit herkommt.
                                kptkip
                                @wendy2702
                                Welches Problem? Du kontst etwas nicht zuordnen. Ob das nun ein halbes Jahr her ist oder gestern erfolgt ist, ist m.E. völlig irelevant.
                                Ich habe lediglich eingeordnet, dass mein Post zu meinem Thread gehört, was du angezweifelt hast. Also von Problem weit entfernt.
                                • K kptkip
                                  @wendy2702
                                  wendy2702W Online
                                  wendy2702W Online
                                  @kptkip Ich werde deinen Thread nicht weiter behelligen.
                                  Schönen Sonntag
