  4. [gelöst] Fehler VIS & Javascript in pro
21 Beiträge 4 Kommentatoren 4.4k Aufrufe
    schittl
    habe iobroker testweise neu aufgesetzt und bekomme über iobroker.pro keine Verbindung zu VIS bzw. den Scripts hin.
    Versionen:
    web -> 2.1.9
    js-controller -> 1.2.3
    javascript -> 3.5.1
    admin -> 2.0.9
    cloud -> 2.1.1
    node -> 6.12.2
    npm -> 3.10.10
    Konfiguration:
    Adapter web und cloud sind auf grün und ich komme in die Adminoberfläche. Nur VIS und Bearbeitung der Skripte funktioniert nicht.
    Skript-Bearbeitung:
    "Default ACL": {"en": "Default ACL", "de": "Default ACL", "ru": "Default ACL"},
    translate.js:24 "Access control list": {"en": "Access control list", "de": "Access control list", "ru": "Access control list"},
    translate.js:24 "File rights": {"en": "File rights", "de": "File rights", "ru": "File rights"},
    translate.js:24 "Default ACL": {"en": "Default ACL", "de": "Default ACL", "ru": "Default ACL"},
    js/translate.js:24 "Login timeout(sec):": {"en": "Login timeout(sec):", "de": "Login timeout(sec):", "ru": "Login timeout(sec):"},
    js/translate.js:24 "Enabled:": {"en": "Enabled:", "de": "Enabled:", "ru": "Enabled:"},
    js/translate.js:24 "IP": {"en": "IP", "de": "IP", "ru": "IP"},
    js/translate.js:24 "Use system settings:": {"en": "Use system settings:", "de": "Use system settings:", "ru": "Use system settings:"},
    tab.html:10 GET https://iobroker.pro/css/admin.css net::ERR_ABORTED
    tab.html:13 GET https://iobroker.pro/lib/js/jquery-ui.min.js 404 (Not Found)
    tab.html:21 GET https://iobroker.pro/lib/js/colResizable-1.6.min.js net::ERR_ABORTED
    jquery-1.11.2.min.js:2 Uncaught Error: Fancytree assertion failed: Fancytree requires jQuery UI (http://jqueryui.com)
    at Function.error (jquery-1.11.2.min.js:2)
    at e (jquery.fancytree-all.min.js:12)
    at jquery.fancytree-all.min.js:12
    at jquery.fancytree-all.min.js:13
    at jquery.fancytree-all.min.js:8
    at jquery.fancytree-all.min.js:10
    error @ jquery-1.11.2.min.js:2
    e @ jquery.fancytree-all.min.js:12
    (anonymous) @ jquery.fancytree-all.min.js:12
    (anonymous) @ jquery.fancytree-all.min.js:13
    (anonymous) @ jquery.fancytree-all.min.js:8
    (anonymous) @ jquery.fancytree-all.min.js:10
    tab.html:21 GET https://iobroker.pro/lib/js/colResizable-1.6.min.js 404 (Not Found)
    tab.js:2938 Uncaught TypeError: $dialogMessage.dialog is not a function
    at n. <anonymous>(tab.js:2938)
    at n.onack (universalModuleDefinition:3)
    at n.onpacket (universalModuleDefinition:3)
    at n. <anonymous>(universalModuleDefinition:3)
    at n.emit (universalModuleDefinition:2)
    at n.ondecoded (universalModuleDefinition:1)
    at s. <anonymous>(universalModuleDefinition:3)
    at s.r.emit (universalModuleDefinition:1)
    at s.add (universalModuleDefinition:1)
    at n.ondata (universalModuleDefinition:1)
    (anonymous) @ tab.js:2938
    n.onack @ universalModuleDefinition:3
    n.onpacket @ universalModuleDefinition:3
    (anonymous) @ universalModuleDefinition:3
    n.emit @ universalModuleDefinition:2
    n.ondecoded @ universalModuleDefinition:1
    r.emit @ universalModuleDefinition:1
    s.add @ universalModuleDefinition:1
    n.ondata @ universalModuleDefinition:1
    n.onPacket @ universalModuleDefinition:2
    (anonymous) @ universalModuleDefinition:2
    r @ universalModuleDefinition:2
    e.decodePayloadAsBinary @ universalModuleDefinition:2
    e.decodePayload @ universalModuleDefinition:2
    n.onData @ universalModuleDefinition:2
    i.onData @ universalModuleDefinition:2
    i.onLoad @ universalModuleDefinition:2
    hasXDR.r.onreadystatechange @ universalModuleDefinition:2
    XMLHttpRequest.send (async)
    i.create @ universalModuleDefinition:2
    i @ universalModuleDefinition:2
    o.request @ universalModuleDefinition:2
    o.doPoll @ universalModuleDefinition:2
    n.poll @ universalModuleDefinition:2
    n.doOpen @ universalModuleDefinition:2
    n.open @ universalModuleDefinition:2
    n @ universalModuleDefinition:1
    n.open.n.connect @ universalModuleDefinition:1
    (anonymous) @ tab.js:2675</anonymous></anonymous></anonymous>
    ****Anzeige VIS:****
     ![3116_error_vis.jpg](/assets/uploads/files/3116_error_vis.jpg)
    Document was loaded from Application Cache with manifest https://iobroker.pro/vis/cache.manifest
    edit.html:1 Application Cache Checking event
    edit.html:3846 Version vis-jqui-mfd: 1.0.5
    justgage.js:114 Version justgage: 1.0.0
    edit.html:9339 Version vis-canvas-gauges: 1.0.5
    edit.html:1 Application Cache NoUpdate event
    2socket.io.js:1456 GET https://iobroker.pro:8084/socket.io/?key=nokey&EIO=3&transport=polling&t=M2Xnx8X 403 (Target service not allowed)
    Request.create @ socket.io.js:1456
    Request @ socket.io.js:1369
    XHR.request @ socket.io.js:1297
    XHR.doPoll @ socket.io.js:1327
    Polling.poll @ socket.io.js:1740
    Polling.doOpen @ socket.io.js:1684
    Transport.open @ socket.io.js:827
    Socket.open @ socket.io.js:248
    Socket @ socket.io.js:129
    Socket @ socket.io.js:55
    Manager.open.Manager.connect @ socket.io.js:4549
    Manager @ socket.io.js:4403
    Manager @ socket.io.js:4372
    lookup @ socket.io.js:4301
    init @ conn.js:234
    main @ vis.js:3556
    (anonymous) @ vis.js:3818
    j @ jquery-1.11.2.min.js:2
    fireWith @ jquery-1.11.2.min.js:2
    ready @ jquery-1.11.2.min.js:2
    J @ jquery-1.11.2.min.js:2
    edit.html:1 Failed to load https://iobroker.pro:8084/socket.io/?key=nokey&EIO=3&transport=polling&t=M2Xnx8X: No 'Access-Control-Allow-Origin' header is present on the requested resource. Origin 'https://iobroker.pro' is therefore not allowed access. The response had HTTP status code 403.
    conn.js:141 Trying connect...
    2socket.io.js:1456 GET https://iobroker.pro:8084/socket.io/?key=nokey&EIO=3&transport=polling&t=M2Xnzjp 403 (Target service not allowed)
    Socket.open.Socket.connect @ socket.io.js:5022
    (anonymous) @ conn.js:142
    setInterval (async)
    reconnect @ conn.js:140
    (anonymous) @ conn.js:323
    Emitter.emit @ socket.io.js:5657
    Socket.emit @ socket.io.js:5053
    Manager.emitAll @ socket.io.js:4416
    (anonymous) @ socket.io.js:4566
    Emitter.emit @ socket.io.js:2556
    Socket.onError @ socket.io.js:688
    (anonymous) @ socket.io.js:279
    Transport.onError @ socket.io.js:814
    (anonymous) @ socket.io.js:1333
    Request.onError @ socket.io.js:1502
    (anonymous) @ socket.io.js:1449
    setTimeout (async)
    xhr.onreadystatechange @ socket.io.js:1448
    init @ conn.js:234
    main @ vis.js:3556
    edit.html:1 Failed to load https://iobroker.pro:8084/socket.io/?key=nokey&EIO=3&transport=polling&t=M2Xnzjp: No 'Access-Control-Allow-Origin' header is present on the requested resource. Origin 'https://iobroker.pro' is therefore not allowed access. The response had HTTP status code 403.
    Was mich stutzig macht, ist dass im Log steht das socketio auf 8082 gestartet wird aber er auf 8084 nachschaut.
    web.0 2017-12-29 10:11:31.289 info http server listening on port 8082
    web.0 2017-12-29 10:11:31.282 info socket.io server listening on port 8082
    web.0 2017-12-29 10:11:30.844 info Allow states only when user is owner: false
    web.0 2017-12-29 10:11:30.840 info simpleAPI server listening on port 8082
    web.0 2017-12-29 10:11:30.594 info starting. Version 2.1.9 in /opt/iobroker/node_modules/iobroker.web, node: v6.12.2
    Auch die Installation vom Adapter socket.io und Anpassung der Einstellungen brachte keine Verbesserung.
    Habt Ihr vielleicht eine Idee woran das liegt? Wie habt Ihr das eingestellt? Als Browser habe ich Chrome/FF/IE ausprobiert, nutze aber hauptsächlich Chrome.
    vg
    Falk
    HW: Lenovo M920q (Proxmox, ioBroker, RaspMatic & Z2M), QNAP (Docker, Influx), Arduino Mega 2560 R3 (I2C DS18B20 + LED)
    SW: CT IoBroker, VM RaspMatic(v3.79.6.20241122)
      schittl
      Hat keiner das gleiche Problem bzw. eine Lösung parat? Es funktioniert immer noch nicht.
      Im lokalen Netz funktioniert alles wunderbar.
      vg
      Falk
        schittl
        Keine Unterstützung/Reaktion. So was kenne ich doch so nicht vom Forum :( :( :(
        Ist das Problem überhaupt vakant? Ist es zu wenig dokumentiert? Woran scheitern eventuelle Hilfestellungen? Sollte ich woanders melden bei Problemen mit iobroker.pro?
        vg
        Falk
        • ? Offline
          Hallo schittl,
          ich habe zur Zeit auch viel zu Kämpfen mit VIS und der cloud.pro.
          Deine Probleme hatte ich so jedoch noch nicht.
          In den meisten Fällen hat bei mir ein löschen aller möglichen Caches geholfen.
          Welchen Browser nutzt du? Chrome ist bei mir leider am anfälligsten.
            In den letzten Tagen wurde viel an den Servern geschraubt um diverse Probleme, die auch nicht immer nachvollziehbar waren zu vermeiden.
            Ist dein Problem aktuell noch existent?
            • BluefoxB Offline
              BluefoxB Offline
              @schittl:
              Versionen:
              web -> 2.1.9
              javascript -> 3.5.1
              admin -> 2.0.9
              cloud -> 2.1.1
              node -> 6.12.2
              npm -> 3.10.10
              Konfiguration:
              Skript-Bearbeitung:
              init @ conn.js:234
              main @ vis.js:3556
              setInterval (async)
              setTimeout (async)
              init @ conn.js:234
              main @ vis.js:3556
              vg
              Falk `
              8082 und 8084 sind falsch. So sieht es bei mir aus:
              https://iobroker.pro/socket.io/?key=nokey&EIO=3&transport=polling
              Kannst du eingebaute Socket.io Ausprobieren?
                schittl
                @Homoran:
                Ist dein Problem aktuell noch existent? ` Das Problem besteht leider immer noch.
                @Bluefox:
                Kannst du eingebaute Socket.io Ausprobieren? ` lt. 1. Screenshot nutze ich diesen doch schon…
                @nisio:
                Welchen Browser nutzt du? Chrome ist bei mir leider am anfälligsten. ` Habe mehrere versucht (FF,Chrome,IE)
                Danke für Eure Anmerkungen.
                Vg Falk
                • BluefoxB Offline
                  BluefoxB Offline
                  Wie sieht bei dir die erste Konfig-Seite für cloud? Welche web Instanz?
                    schittl
                    @Bluefox:
                    Wie sieht bei dir die erste Konfig-Seite für cloud? Welche web Instanz? ` 3116_cloud2.jpg
                    Habt Ihr irgendetwas verändert? Ich jedenfalls nicht. VIS funktioniert auf einmal aber js funktioniert immer noch nicht heul. Hier der Fehler: 3116_js2.jpg
                    ! ` > "Default ACL": {"en": "Default ACL", "de": "Default ACL", "ru": "Default ACL"},
                    adminHosts.js:282 Timeout for repository
                    (anonymous) @ adminHosts.js:282
                    admin.css Failed to load resource: the server responded with a status of 404 (Not Found)
                    jquery-ui.min.js Failed to load resource: the server responded with a status of 404 (Not Found)
                    colResizable-1.6.min.js Failed to load resource: the server responded with a status of 404 (Not Found)
                    at n.onack (socket.io.js:3)
                    at n.onpacket (socket.io.js:3)
                    at n. <anonymous>(socket.io.js:3)
                    at n.emit (socket.io.js:2)
                    at n.ondecoded (socket.io.js:1)
                    at s. <anonymous>(socket.io.js:3)
                    at s.r.emit (socket.io.js:1)
                    at s.add (socket.io.js:1)
                    at n.ondata (socket.io.js:1)
                    js/translate.js:24 "IP": {"en": "IP", "de": "IP", "ru": "IP"},</anonymous></anonymous></anonymous> `
                    Danke für Eure Mühen. Aber sehr seltsam das wenigstens VIS nun wie von Geisterhand funktioniert.
                    • BluefoxB Offline
                      BluefoxB Offline
                      Downgrade bitte JavaScript auf stable version
                        schittl
                        @Bluefox:
                        Downgrade bitte JavaScript auf stable version ` Auf 3.4.0? Falls ja wie mache ich das am besten/einfachsten? Habe ein Downgrade leider noch nicht durchgeführt…
                        vg
                        Falk
                        • BluefoxB Offline
                          BluefoxB Offline
                          @schittl:
                          @Bluefox:
                          vg
                          Falk `
                          http://www.iobroker.net/docu/?page_id=1 … en_Version
                          Oder experten Modus einschalten und dann über Adapters-Seite Downgraden
                            schittl
                            Nach einem Browser-Cache leeren funktioniert es nun wieder. :D Vielen Dank für Eure Mühen.
                            Kleine Zusatzfrage:
                            Kann mir jemand erklären was die Einstellung zum JavaScript Adapter "Nicht auf alle Zustände beim Start abonnieren" genau bedeutet? Ich glaube in 3.4. hatte ich diese gesetzt aber in 3.5.1 musste ich diese deaktivieren, damit überhaupt eins meiner Scripte funktionierte.
                            vg
                            Falk
                            • BluefoxB Offline
                              BluefoxB Offline
                              @schittl:
                              Kleine Zusatzfrage:
                              vg
                              Falk `
                              Das ist für die advanced Anwender.
                              Defaultmäßig abonniert JS alle States (auch 100.000) und falls das System sehr dynamisch ist, dass kann JS zum Abstürz bringen und unnötig das System mit Updates (die keine braucht) belasten.
                              Um das Problem zu Lösen, kann man sagen, dass nur die States, die wirklich benutzt werden abonniert werden müssen.
                              Es gibt aber kleines Nachteil, dass man getState nicht synchron benutzen darf, sondern immer asynchron wie:
                              getState('stateId', function (err, state) {
                              	console('Value: ' + state.val);
                              Damit wird das System drastisch entlastet, dass nicht alle States noch im JS adapter dupliziert werden müssen.
                              Dafür existiert: "Nicht auf alle Zustände beim Start abonnieren"
                                schittl
                                Es hat zwischenzeitlich funktioniert, aber aktuell funktioniert VIS (1.0.4) über iobroker.pro nicht mehr. Veränderungen wurden nicht vorgenommen. Es wurde lediglich hqwidgets(1.1.1) installiert. Es erscheint folgender Fehler:
                                Uncaught ReferenceError: getUsedObjectIDs is not defined
                                at Object.getUsedObjectIDs (vis.js:316)
                                at vis.js:1725
                                at conn.js:521
                                Folgendes habe ich schon ausprobiert, aber leider ohne Erfolg:
                                  • iobroker upload all bzw. iobroker upload vis
                                - Neustart iobroker
                                Was könnte die Ursache sein? Danke im voraus.
                                vg
                                Falk
                                  schittl
                                  Hat keiner eine Idee was man noch unternehmen könnte?
                                  • ? Offline
                                    probiere mal die hqwidgets wieder zu löschen.
                                    Ich hatte glaube ich Mal die gleiche Meldung und der Grund waren unsauber installierte Widgets.
                                      schittl
                                      Hat geholfen, Danke Dir.
                                        schittl
                                        Wollte nun heute von extern anfangen meine VIS zu modifizieren, aber der Fehler erscheint nun wieder :oops: . Am Wochenende funktionierte es. Kann es sein, dass es am Browser/OS/NW liegt?
                                        Am WE mit Safari am IPad im Heimnetzwerk (wo ich auch direkt ohne Cloud Zugriff habe) funktionierte es und nun mit Chrome/FF in Windows ohne direkten Zugriff (Hotspot) funktioniert es nicht.
                                        Browser-Cache wurde natürlich mehrmals gelöscht…
                                        Von extern hat es aber schon mal funktioniert. Ich glaube aber da war iobroker noch auf RPi3(Stretch). Es ist nun umgezogen auf einen Rock64 mit Armbian.
                                        vg
                                        Falk
                                        • BluefoxB Offline
                                          BluefoxB Offline
                                          @schittl:
                                          vg
                                          Falk `
                                          Es liegt an dem Browsecache. Bitte löschen.
