  4. Aktuell Probleme , oder nur bei mir ?
    5.8k
44 Beiträge 5 Kommentatoren 3.1k Aufrufe
    mameier1234
    so… Wasserbett deaktiviert :-)
    neustart: wieder hänger.... aber diesmal keine Fehler im Log...
    2018-01-07 17:44:54.250  - info: host.raspberrypi  inMem-states listening on port 9000
    2018-01-07 17:44:55.481  - info: host.raspberrypi  inMem-objects listening on port 9001
    2018-01-07 17:44:55.514  - info: host.raspberrypi InMemoryDB connected
    2018-01-07 17:44:55.617  - info: host.raspberrypi 10 instances found
    2018-01-07 17:44:55.650  - info: host.raspberrypi starting 10 instances
    2018-01-07 17:44:55.758  - info: host.raspberrypi instance system.adapter.admin.0 started with pid 576
    2018-01-07 17:44:59.673  - info: host.raspberrypi instance system.adapter.discovery.0 started with pid 582
    2018-01-07 17:44:59.893  - info: admin.0 starting. Version 2.0.9 in /opt/iobroker/node_modules/iobroker.admin, node: v6.12.3
    2018-01-07 17:44:59.977  - info: admin.0 requesting all states
    2018-01-07 17:44:59.983  - info: admin.0 requesting all objects
    2018-01-07 17:45:03.777  - info: host.raspberrypi instance system.adapter.cloud.0 started with pid 593
    2018-01-07 17:45:03.838  - info: discovery.0 starting. Version 1.0.1 in /opt/iobroker/node_modules/iobroker.discovery, node: v6.12.3
    2018-01-07 17:45:04.744  - info: admin.0 received all states
    2018-01-07 17:45:07.226  - info: admin.0 received all objects
    2018-01-07 17:45:07.160  - info: cloud.0 starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.cloud, node: v6.12.3
    2018-01-07 17:45:07.211  - info: cloud.0 Connecting with https://iobroker.net:10555 with "@pro_martin@familie-meier.de_eb9c9f70-ee3f-11e7-86ee-214f5496d63"
    2018-01-07 17:45:07.568  - info: admin.0 http server listening on port 8081
    2018-01-07 17:45:07.569  - info: admin.0 Use link "http://localhost:8081" to configure.
    2018-01-07 17:45:07.907  - info: admin.0 Request actual repository...
    2018-01-07 17:45:08.088  - info: cloud.0 Connection changed: CONNECTED1
    2018-01-07 17:45:08.310  - info: host.raspberrypi instance system.adapter.web.0 started with pid 607
    2018-01-07 17:45:08.374  - info: admin.0 Change log subscriber state: true
    2018-01-07 17:45:08.388  - info: discovery.0 system.adapter.admin.0: logging true
    2018-01-07 17:45:08.400  - info: cloud.0 system.adapter.admin.0: logging true
    2018-01-07 17:45:08.501  - info: admin.0 system.adapter.admin.0: logging true
    2018-01-07 17:45:08.635  - info: host.raspberrypi Update repository "default" under "http://download.iobroker.net/sources-dist.json"
    2018-01-07 17:45:10.643  - info: admin.0 Repository received successfully.
    2018-01-07 17:45:10.948  - info: web.0 starting. Version 2.1.9 in /opt/iobroker/node_modules/iobroker.web, node: v6.12.3
    2018-01-07 17:45:11.756  - info: host.raspberrypi instance system.adapter.xs1.0 started with pid 619
    2018-01-07 17:45:12.009  - info: web.0 socket.io server listening on port 8082
    2018-01-07 17:45:12.015  - info: cloud.0 2018-01-07T16:45:12.014Z Connected system.user.admin
    2018-01-07 17:45:12.019  - info: web.0 http server listening on port 8082
    2018-01-07 17:45:20.932  - info: xs1.0 starting. Version 1.0.2 in /opt/iobroker/node_modules/iobroker.xs1, node: v6.12.3
    2018-01-07 17:45:20.962  - info: xs1.0 config XS1 Addresse: http://192.168.160.250
    2018-01-07 17:45:20.970  - info: xs1.0 CopyList = {}
    2018-01-07 17:45:25.470  - info: vis.0 starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.vis, node: v6.12.3
    2018-01-07 17:45:25.745  - info: vis.0 vis license is OK.
    2018-01-07 17:45:25.863  - info: xs1.0 Finished state creation. Added totally 43 actuators or sensors
    2018-01-07 17:45:27.182  - info: host.raspberrypi instance system.adapter.hm-rpc.0 started with pid 643
    2018-01-07 17:45:27.689  - info: host.raspberrypi instance system.adapter.vis.0 terminated while should be started once
    2018-01-07 17:45:29.037  - info: hm-rpc.0 starting. Version 1.4.14 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v6.12.3
    2018-01-07 17:45:29.540  - info: hm-rpc.0 binrpc server is trying to listen on 192.168.160.160:2001
    2018-01-07 17:45:29.543  - info: hm-rpc.0 binrpc client is trying to connect to 192.168.160.4:2001 with ["xmlrpc_bin://192.168.160.160:2001","hm-rpc.0"]
    2018-01-07 17:45:29.781  - info: hm-rpc.0 binrpc <- system.listMethods ["hm-rpc.0"]
    2018-01-07 17:45:29.799  - info: hm-rpc.0 binrpc <- listDevices ["hm-rpc.0"]
    2018-01-07 17:45:30.053  - info: hm-rpc.0 binrpc -> 278 devices
    2018-01-07 17:45:30.401  - info: hm-rpc.0 Connected
    2018-01-07 17:45:31.106  - info: host.raspberrypi instance system.adapter.fhem.0 started with pid 653
    2018-01-07 17:45:32.646  - info: fhem.0 starting. Version 0.4.1 in /opt/iobroker/node_modules/iobroker.fhem, node: v6.12.3
    2018-01-07 17:45:35.067  - info: host.raspberrypi instance system.adapter.javascript.0 started with pid 663
    2018-01-07 17:45:39.072  - info: host.raspberrypi instance system.adapter.hm-rega.0 started with pid 669
    2018-01-07 17:45:40.841  - info: javascript.0 starting. Version 3.5.1 in /opt/iobroker/node_modules/iobroker.javascript, node: v6.12.3
    2018-01-07 17:45:40.877  - info: javascript.0 requesting all states
    2018-01-07 17:45:40.882  - info: javascript.0 requesting all objects
    2018-01-07 17:45:47.577  - info: javascript.0 received all states
    2018-01-07 17:45:46.549  - info: hm-rega.0 starting. Version 1.6.6 in /opt/iobroker/node_modules/iobroker.hm-rega, node: v6.12.3
    2018-01-07 17:45:46.575  - info: hm-rega.0 subscribe hm-rpc.0.BidCoS-RF.50.PRESS_SHORT
    2018-01-07 17:45:49.267  - info: hm-rega.0 ReGaHSS 192.168.160.4 up
    2018-01-07 17:45:49.316  - info: hm-rega.0 time difference local-ccu 0s
    2018-01-07 17:45:49.448  - info: hm-rega.0 added/updated 1 favorites to enum.favorites
    2018-01-07 17:45:49.534  - info: hm-rega.0 added/updated functions to enum.functions
    2018-01-07 17:45:49.590  - info: hm-rega.0 added/updated rooms to enum.rooms
    2018-01-07 17:45:50.309  - info: hm-rega.0 renamed hm-rpc.0.OEQ0261402.0.UNREACH_ALARM to "Leinwand:0.UNREACH_ALARM"
    2018-01-07 17:45:50.370  - info: hm-rega.0 got 0 programs
    2018-01-07 17:45:50.400  - info: hm-rega.0 added/updated 0 programs
    2018-01-07 17:45:50.410  - info: javascript.0 received all objects
    2018-01-07 17:45:50.403  - info: hm-rega.0 deleted 0 programs
    2018-01-07 17:45:50.535  - info: hm-rega.0 got 4 variables
    2018-01-07 17:45:50.556  - info: javascript.0 Start javascript script.js.common.Leinwand
    2018-01-07 17:45:50.600  - info: hm-rega.0 added/updated 4 variables
    2018-01-07 17:45:50.623  - info: javascript.0 script.js.common.Leinwand: registered 2 subscriptions and 0 schedules
    2018-01-07 17:45:50.603  - info: hm-rega.0 deleted 0 variables
    2018-01-07 17:45:50.608  - info: hm-rega.0 request state values
    2018-01-07 17:45:51.066  - info: hm-rega.0 got state values
    Grüße,
    Martin
    • wendy2702W Online
      wendy2702W Online
      @mameier1234:
      ich habe in der Zwischenzeit versucht über Github den Fhem - Adapter zu erneuern…
      danach: gleiche Version.
      Dann habe ich die Instanz wieder gestartet.. sieht gut aus... Allerdings noch kein kompletter pi-neustart.
      2018-01-07 17:40:14.868  - info: host.raspberrypi Update repository "default" under "http://download.iobroker.net/sources-dist.json"
      2018-01-07 17:40:33.191  - info: host.raspberrypi object change system.adapter.fhem.0
      2018-01-07 17:40:33.247  - info: host.raspberrypi instance system.adapter.fhem.0 started with pid 792
      2018-01-07 17:40:34.860  - info: fhem.0 starting. Version 0.4.1 in /opt/iobroker/node_modules/iobroker.fhem, node: v6.12.3
      2018-01-07 17:41:44.547  - info: fhem.0 Synchronised!
      So wie ich das in Git sehe ist das auch die aktuellste Version
        http://download.iobroker.net/list.html# … ot-systems
        Überall die gleiche
        • wendy2702W Online
          wendy2702W Online
          @mameier1234:
          neustart: wieder hänger.... aber diesmal keine Fehler im Log... `
          Wie lange hast du nach dem PI restart gewartet?
          Hast du mal eine andere SD Karte zum testen?
          Wie ist der PI denn mit Strom versorgt?
          Bleibt das logfile dann auch hängen?
          Was sagt denn das Linux System log –> Eventuell steht da noch etwas brauchbares drin?
          Wie sieht denn "TOP" jetzt aus oder geht keine Eingabe mehr?
            mameier1234
            @wendy2702:
            @mameier1234:
            Wie sieht denn "TOP" jetzt aus oder geht keine Eingabe mehr? `
            Pi neustart: so ca 5 sek… (sollte reichen)
            Strom: USB-Netzteil
            Logfile und in 2.er ssh Session Top... alles bleibt hängen...
            In /var/log/messages sieht alles smooth aus..
            Ich habe jetzt nochmal die Fhem Instanz angehalten... dann den pi neugestartet: Alles ok !!!!
            Wenn ich dann dien Fhem Adapter erst später starte, ist auch alles ok..
            Grüße,
            Martin
            • wendy2702W Online
              wendy2702W Online
              Hm,
              weiß nicht was der FHEM Adapter dann macht. Nutze ich nicht und würde dann eventuell auch auf ein Konfig Problem tippen.
                mameier1234
                gibt es die möglichkeit eine Instanz (in dem Fall Fhem) beim Neustart nicht automatisch zu starten ?
                Grüße,
                Martin
                • wendy2702W Online
                  wendy2702W Online
                  Das kann Ich dir leider nicht beantworten.
                  Würde aber mal vermuten das dein Problem irgendwo anders liegt.
                  Mach doch wegen dem FHEM Adapter Problem besser ein neues Thema auf oder ändere hier die Überschrift. Dann schaut sich das eventuell ein anderer FHEM User auch an und hat eine Idee.
                    mameier1234
                    mach ich…. jetzt ist ja erstmal klar, was das Problem grundsätzlich ist...
                    Grüße,
                    Martin
                    • DutchmanD Offline
                      DutchmanD Offline
                      Dutchman
                      @mameier1234:
                      gibt es die möglichkeit eine Instanz (in dem Fall Fhem) beim Neustart nicht automatisch zu starten ? `
                      Ja, entweder du Schaltest manuell aus vier Neustart oder wird machen dafür ein Script das beim Ausschalten des Systems den Adapter ausschaltet
                      Send from mobile device
                      Das schöne ios hat Auto Korrektur zum k****
                      Wer Schreibfehler findet darf sie behalten oder auf eBay verkaufen, mindest Umsatz 10% für die community
                      • paul53P Offline
                        @Dutchman:
                        oder wird machen dafür ein Script das beim Ausschalten des Systems den Adapter ausschaltet `
                        Das wird nur funktionieren, wenn die FHEM-Instanz nicht vor der JS-Instanz gekillt wird.
                        • DutchmanD Offline
                          DutchmanD Offline
                          Dutchman
                          @paul53:
                          @Dutchman:
                          oder wird machen dafür ein Script das beim Ausschalten des Systems den Adapter ausschaltet Das wird nur funktionieren, wenn die FHEM-Instanz nicht vor der JS-Instanz gekillt wird.
                          Wieso? Es geht ja darum den Wert "enabled" auf false zu setzen..
                          Wird der Adapter gestoppt ist er immer noch enabled aber nicht running ;-)
                          • paul53P Offline
                            @Dutchman:
                            Wird der Adapter gestoppt ist er immer noch enabled aber nicht running `
                            Hast recht :o
                              mameier1234
                              aeh… Ja!!
                              (vergesst bitte nicht, ich bin neu in der Materie...)
                              Grüße,
                              Martin
                              • DutchmanD Offline
                                DutchmanD Offline
                                Dutchman
                                @paul53 legst du den code noch ich müsste Forum stöbern :P
                                • paul53P Offline
                                  @Dutchman:
                                  ich müsste Forum stöbern `
                                  …und ich in der Doku des JS-Adapters, sollte aber so funktionieren.
                                  onStop(function() {
                                     var obj = getObject('system.adapter.fhem.0');
                                     obj.common.enabled = false;
                                     setObject('system.adapter.fhem.0', obj);
                                  }, 0);
                                  function startFHEM() {
                                     obj.common.enabled = true;
                                  // FHEM verzögert starten
                                  setTimeout(startFHEM, 20000);  // 20 s nach Skriptstart
                                    mameier1234
                                    Wow… OK...
                                    wenn ich das richtig verstehe, mache ich ein neues Script und paste das da rein ?
                                    Grüße,
                                    Martin
                                    • paul53P Offline
                                      @mameier1234:
                                      wenn ich das richtig verstehe, mache ich ein neues Script und paste das da rein ? `
                                      Richtig. Die Funktion setObject() muss in der Konfiguration der JS-Instanz freigegeben sein.
                                        mameier1234
                                        ok..
                                        Script erstellt…
                                        sudo iobroker stop (zum testen)
                                        Wird das bei einem sudo reboot ausgeführt ?? Denn damit wird ja, wenn ich das verstehe das fhem auf disabled gestellt...
                                        Dann sudo iobroker start... hing sofort wieder..kein reaktion im ssh mehr...
                                        Hardreset... schnell in die Instanzen, fhem deaktiviert und er hängt nicht...
                                        Achja... und im Log kommt: javascript.0 2018-01-07 20:58:23.978 error Function "setObject" is not allowed. Use adapter settings to allow it.
                                        Grüße,
                                        Martin
                                        • paul53P Offline
                                          Zum Testen genügt es erst einmal, das Skript zu stoppen, zu schauen, ob fhem.0 gestoppt ist, dann das Skript wieder zu starten und im Reiter "Log" zu schauen (ein bischen warten).
