  4. Aktuell Probleme , oder nur bei mir ?
    5.8k
44 Beiträge 5 Kommentatoren 3.1k Aufrufe
    Wenn der Prozess doppelt liefe käme ein code 7 error.
    Ich tippe da eher auf Konfigurationsfehler der Instanz.
    Gruß Rainer
    • wendy2702W Online
      wendy2702W Online
      @Rainer:
      kommt bzw. kam doch
      2018-01-07 17:26:15.115  - error: host.raspberrypi instance system.adapter.fhem.0 terminated with code 7 (Adapter already running)
        mameier1234
        so… Wasserbett deaktiviert :-)
        neustart: wieder hänger.... aber diesmal keine Fehler im Log...
        2018-01-07 17:44:54.250  - info: host.raspberrypi  inMem-states listening on port 9000
        2018-01-07 17:44:55.481  - info: host.raspberrypi  inMem-objects listening on port 9001
        2018-01-07 17:44:55.514  - info: host.raspberrypi InMemoryDB connected
        2018-01-07 17:44:55.617  - info: host.raspberrypi 10 instances found
        2018-01-07 17:44:55.650  - info: host.raspberrypi starting 10 instances
        2018-01-07 17:44:55.758  - info: host.raspberrypi instance system.adapter.admin.0 started with pid 576
        2018-01-07 17:44:59.673  - info: host.raspberrypi instance system.adapter.discovery.0 started with pid 582
        2018-01-07 17:44:59.893  - info: admin.0 starting. Version 2.0.9 in /opt/iobroker/node_modules/iobroker.admin, node: v6.12.3
        2018-01-07 17:44:59.977  - info: admin.0 requesting all states
        2018-01-07 17:44:59.983  - info: admin.0 requesting all objects
        2018-01-07 17:45:03.777  - info: host.raspberrypi instance system.adapter.cloud.0 started with pid 593
        2018-01-07 17:45:03.838  - info: discovery.0 starting. Version 1.0.1 in /opt/iobroker/node_modules/iobroker.discovery, node: v6.12.3
        2018-01-07 17:45:04.744  - info: admin.0 received all states
        2018-01-07 17:45:07.226  - info: admin.0 received all objects
        2018-01-07 17:45:07.160  - info: cloud.0 starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.cloud, node: v6.12.3
        2018-01-07 17:45:07.211  - info: cloud.0 Connecting with https://iobroker.net:10555 with "@pro_martin@familie-meier.de_eb9c9f70-ee3f-11e7-86ee-214f5496d63"
        2018-01-07 17:45:07.568  - info: admin.0 http server listening on port 8081
        2018-01-07 17:45:07.569  - info: admin.0 Use link "http://localhost:8081" to configure.
        2018-01-07 17:45:07.907  - info: admin.0 Request actual repository...
        2018-01-07 17:45:08.088  - info: cloud.0 Connection changed: CONNECTED1
        2018-01-07 17:45:08.310  - info: host.raspberrypi instance system.adapter.web.0 started with pid 607
        2018-01-07 17:45:08.374  - info: admin.0 Change log subscriber state: true
        2018-01-07 17:45:08.388  - info: discovery.0 system.adapter.admin.0: logging true
        2018-01-07 17:45:08.400  - info: cloud.0 system.adapter.admin.0: logging true
        2018-01-07 17:45:08.501  - info: admin.0 system.adapter.admin.0: logging true
        2018-01-07 17:45:08.635  - info: host.raspberrypi Update repository "default" under "http://download.iobroker.net/sources-dist.json"
        2018-01-07 17:45:10.643  - info: admin.0 Repository received successfully.
        2018-01-07 17:45:10.948  - info: web.0 starting. Version 2.1.9 in /opt/iobroker/node_modules/iobroker.web, node: v6.12.3
        2018-01-07 17:45:11.756  - info: host.raspberrypi instance system.adapter.xs1.0 started with pid 619
        2018-01-07 17:45:12.009  - info: web.0 socket.io server listening on port 8082
        2018-01-07 17:45:12.015  - info: cloud.0 2018-01-07T16:45:12.014Z Connected system.user.admin
        2018-01-07 17:45:12.019  - info: web.0 http server listening on port 8082
        2018-01-07 17:45:20.932  - info: xs1.0 starting. Version 1.0.2 in /opt/iobroker/node_modules/iobroker.xs1, node: v6.12.3
        2018-01-07 17:45:20.962  - info: xs1.0 config XS1 Addresse: http://192.168.160.250
        2018-01-07 17:45:20.970  - info: xs1.0 CopyList = {}
        2018-01-07 17:45:25.470  - info: vis.0 starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.vis, node: v6.12.3
        2018-01-07 17:45:25.745  - info: vis.0 vis license is OK.
        2018-01-07 17:45:25.863  - info: xs1.0 Finished state creation. Added totally 43 actuators or sensors
        2018-01-07 17:45:27.182  - info: host.raspberrypi instance system.adapter.hm-rpc.0 started with pid 643
        2018-01-07 17:45:27.689  - info: host.raspberrypi instance system.adapter.vis.0 terminated while should be started once
        2018-01-07 17:45:29.037  - info: hm-rpc.0 starting. Version 1.4.14 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v6.12.3
        2018-01-07 17:45:29.540  - info: hm-rpc.0 binrpc server is trying to listen on 192.168.160.160:2001
        2018-01-07 17:45:29.543  - info: hm-rpc.0 binrpc client is trying to connect to 192.168.160.4:2001 with ["xmlrpc_bin://192.168.160.160:2001","hm-rpc.0"]
        2018-01-07 17:45:29.781  - info: hm-rpc.0 binrpc <- system.listMethods ["hm-rpc.0"]
        2018-01-07 17:45:29.799  - info: hm-rpc.0 binrpc <- listDevices ["hm-rpc.0"]
        2018-01-07 17:45:30.053  - info: hm-rpc.0 binrpc -> 278 devices
        2018-01-07 17:45:30.401  - info: hm-rpc.0 Connected
        2018-01-07 17:45:31.106  - info: host.raspberrypi instance system.adapter.fhem.0 started with pid 653
        2018-01-07 17:45:32.646  - info: fhem.0 starting. Version 0.4.1 in /opt/iobroker/node_modules/iobroker.fhem, node: v6.12.3
        2018-01-07 17:45:35.067  - info: host.raspberrypi instance system.adapter.javascript.0 started with pid 663
        2018-01-07 17:45:39.072  - info: host.raspberrypi instance system.adapter.hm-rega.0 started with pid 669
        2018-01-07 17:45:40.841  - info: javascript.0 starting. Version 3.5.1 in /opt/iobroker/node_modules/iobroker.javascript, node: v6.12.3
        2018-01-07 17:45:40.877  - info: javascript.0 requesting all states
        2018-01-07 17:45:40.882  - info: javascript.0 requesting all objects
        2018-01-07 17:45:47.577  - info: javascript.0 received all states
        2018-01-07 17:45:46.549  - info: hm-rega.0 starting. Version 1.6.6 in /opt/iobroker/node_modules/iobroker.hm-rega, node: v6.12.3
        2018-01-07 17:45:46.575  - info: hm-rega.0 subscribe hm-rpc.0.BidCoS-RF.50.PRESS_SHORT
        2018-01-07 17:45:49.267  - info: hm-rega.0 ReGaHSS 192.168.160.4 up
        2018-01-07 17:45:49.316  - info: hm-rega.0 time difference local-ccu 0s
        2018-01-07 17:45:49.448  - info: hm-rega.0 added/updated 1 favorites to enum.favorites
        2018-01-07 17:45:49.534  - info: hm-rega.0 added/updated functions to enum.functions
        2018-01-07 17:45:49.590  - info: hm-rega.0 added/updated rooms to enum.rooms
        2018-01-07 17:45:50.309  - info: hm-rega.0 renamed hm-rpc.0.OEQ0261402.0.UNREACH_ALARM to "Leinwand:0.UNREACH_ALARM"
        2018-01-07 17:45:50.370  - info: hm-rega.0 got 0 programs
        2018-01-07 17:45:50.400  - info: hm-rega.0 added/updated 0 programs
        2018-01-07 17:45:50.410  - info: javascript.0 received all objects
        2018-01-07 17:45:50.403  - info: hm-rega.0 deleted 0 programs
        2018-01-07 17:45:50.535  - info: hm-rega.0 got 4 variables
        2018-01-07 17:45:50.556  - info: javascript.0 Start javascript script.js.common.Leinwand
        2018-01-07 17:45:50.600  - info: hm-rega.0 added/updated 4 variables
        2018-01-07 17:45:50.623  - info: javascript.0 script.js.common.Leinwand: registered 2 subscriptions and 0 schedules
        2018-01-07 17:45:50.603  - info: hm-rega.0 deleted 0 variables
        2018-01-07 17:45:50.608  - info: hm-rega.0 request state values
        2018-01-07 17:45:51.066  - info: hm-rega.0 got state values
        Grüße,
        Martin
        • wendy2702W Online
          wendy2702W Online
          @mameier1234:
          ich habe in der Zwischenzeit versucht über Github den Fhem - Adapter zu erneuern…
          danach: gleiche Version.
          Dann habe ich die Instanz wieder gestartet.. sieht gut aus... Allerdings noch kein kompletter pi-neustart.
          2018-01-07 17:40:14.868  - info: host.raspberrypi Update repository "default" under "http://download.iobroker.net/sources-dist.json"
          2018-01-07 17:40:33.191  - info: host.raspberrypi object change system.adapter.fhem.0
          2018-01-07 17:40:33.247  - info: host.raspberrypi instance system.adapter.fhem.0 started with pid 792
          2018-01-07 17:40:34.860  - info: fhem.0 starting. Version 0.4.1 in /opt/iobroker/node_modules/iobroker.fhem, node: v6.12.3
          2018-01-07 17:41:44.547  - info: fhem.0 Synchronised!
          So wie ich das in Git sehe ist das auch die aktuellste Version
            http://download.iobroker.net/list.html# … ot-systems
            Überall die gleiche
            • wendy2702W Online
              wendy2702W Online
              @mameier1234:
              neustart: wieder hänger.... aber diesmal keine Fehler im Log... `
              Wie lange hast du nach dem PI restart gewartet?
              Hast du mal eine andere SD Karte zum testen?
              Wie ist der PI denn mit Strom versorgt?
              Bleibt das logfile dann auch hängen?
              Was sagt denn das Linux System log –> Eventuell steht da noch etwas brauchbares drin?
              Wie sieht denn "TOP" jetzt aus oder geht keine Eingabe mehr?
                mameier1234
                @wendy2702:
                @mameier1234:
                Wie sieht denn "TOP" jetzt aus oder geht keine Eingabe mehr? `
                Pi neustart: so ca 5 sek… (sollte reichen)
                Strom: USB-Netzteil
                Logfile und in 2.er ssh Session Top... alles bleibt hängen...
                In /var/log/messages sieht alles smooth aus..
                Ich habe jetzt nochmal die Fhem Instanz angehalten... dann den pi neugestartet: Alles ok !!!!
                Wenn ich dann dien Fhem Adapter erst später starte, ist auch alles ok..
                Grüße,
                Martin
                • wendy2702W Online
                  wendy2702W Online
                  Hm,
                  weiß nicht was der FHEM Adapter dann macht. Nutze ich nicht und würde dann eventuell auch auf ein Konfig Problem tippen.
                    mameier1234
                    gibt es die möglichkeit eine Instanz (in dem Fall Fhem) beim Neustart nicht automatisch zu starten ?
                    Grüße,
                    Martin
                    • wendy2702W Online
                      wendy2702W Online
                      Das kann Ich dir leider nicht beantworten.
                      Würde aber mal vermuten das dein Problem irgendwo anders liegt.
                      Mach doch wegen dem FHEM Adapter Problem besser ein neues Thema auf oder ändere hier die Überschrift. Dann schaut sich das eventuell ein anderer FHEM User auch an und hat eine Idee.
                        mameier1234
                        mach ich…. jetzt ist ja erstmal klar, was das Problem grundsätzlich ist...
                        Grüße,
                        Martin
                        • DutchmanD Offline
                          DutchmanD Offline
                          Dutchman
                          @mameier1234:
                          gibt es die möglichkeit eine Instanz (in dem Fall Fhem) beim Neustart nicht automatisch zu starten ? `
                          Ja, entweder du Schaltest manuell aus vier Neustart oder wird machen dafür ein Script das beim Ausschalten des Systems den Adapter ausschaltet
                          Send from mobile device
                          Das schöne ios hat Auto Korrektur zum k****
                          Wer Schreibfehler findet darf sie behalten oder auf eBay verkaufen, mindest Umsatz 10% für die community
                          • paul53P Offline
                            @Dutchman:
                            oder wird machen dafür ein Script das beim Ausschalten des Systems den Adapter ausschaltet `
                            Das wird nur funktionieren, wenn die FHEM-Instanz nicht vor der JS-Instanz gekillt wird.
                            • DutchmanD Offline
                              DutchmanD Offline
                              Dutchman
                              @paul53:
                              @Dutchman:
                              oder wird machen dafür ein Script das beim Ausschalten des Systems den Adapter ausschaltet Das wird nur funktionieren, wenn die FHEM-Instanz nicht vor der JS-Instanz gekillt wird.
                              Wieso? Es geht ja darum den Wert "enabled" auf false zu setzen..
                              Wird der Adapter gestoppt ist er immer noch enabled aber nicht running ;-)
                              • paul53P Offline
                                @Dutchman:
                                Wird der Adapter gestoppt ist er immer noch enabled aber nicht running `
                                Hast recht :o
                                  mameier1234
                                  aeh… Ja!!
                                  (vergesst bitte nicht, ich bin neu in der Materie...)
                                  Grüße,
                                  Martin
                                  • DutchmanD Offline
                                    DutchmanD Offline
                                    Dutchman
                                    @paul53 legst du den code noch ich müsste Forum stöbern :P
                                    • paul53P Offline
                                      @Dutchman:
                                      ich müsste Forum stöbern `
                                      …und ich in der Doku des JS-Adapters, sollte aber so funktionieren.
                                      onStop(function() {
                                         var obj = getObject('system.adapter.fhem.0');
                                         obj.common.enabled = false;
                                         setObject('system.adapter.fhem.0', obj);
                                      }, 0);
                                      function startFHEM() {
                                         obj.common.enabled = true;
                                      // FHEM verzögert starten
                                      setTimeout(startFHEM, 20000);  // 20 s nach Skriptstart
                                        mameier1234
                                        Wow… OK...
                                        wenn ich das richtig verstehe, mache ich ein neues Script und paste das da rein ?
                                        Grüße,
                                        Martin
                                        • paul53P Offline
                                          @mameier1234:
                                          wenn ich das richtig verstehe, mache ich ein neues Script und paste das da rein ? `
                                          Richtig. Die Funktion setObject() muss in der Konfiguration der JS-Instanz freigegeben sein.
