    apollon77A
lovelace uinspanelsonoff
8.1k Beiträge 281 Kommentatoren 9.7m Aufrufe 260 Beobachtet
  • T TT-Tom
    @lustig29
    Ja richtig und ein neues Script anlegen dafür.
    L
    L
    lustig29
    #6244
    @tt-tom
    Habe ein neues Script angelegt. Seit dem ich die Cars eingefügt habe, bekomme ich diese Fehler...
    avascript.0	19:49:58.595	info	script.js.NSPanelTs_Gross: Desired TFT Firmware: 53 / v4.4.0
    javascript.0	19:49:58.595	info	script.js.NSPanelTs_Gross: Desired TFT Firmware: 53 / v4.4.0
    javascript.0	19:49:58.595	info	script.js.NSPanelTs_Gross: Installed TFT Firmware: 53 / v4.4.0
    javascript.0	19:50:04.483	warn	at GenerateMediaPage (script.js.NSPanelTs_Gross:6345:26)
    javascript.0	19:50:04.483	warn	at GeneratePage (script.js.NSPanelTs_Gross:4256:29)
    javascript.0	19:50:04.483	warn	at HandleMessage (script.js.NSPanelTs_Gross:4140:21)
    javascript.0	19:50:04.483	warn	at script.js.NSPanelTs_Gross:3915:21
    javascript.0	19:50:04.483	warn	at step (script.js.NSPanelTs_Gross:33:23)
    javascript.0	19:50:04.483	warn	at Object.next (script.js.NSPanelTs_Gross:14:53)
    javascript.0	19:50:04.483	warn	at fulfilled (script.js.NSPanelTs_Gross:5:58)
    javascript.0	19:50:04.483	warn	at GenerateMediaPage (script.js.NSPanelTs_Gross:6346:25)
    javascript.0	19:50:04.484	warn	at HandleMessage (script.js.NSPanelTs_Gross:4140:21)
    javascript.0	19:50:04.484	warn	at script.js.NSPanelTs_Gross:3915:21
    javascript.0	19:50:04.484	warn	at step (script.js.NSPanelTs_Gross:33:23)
    javascript.0	19:50:04.484	warn	at Object.next (script.js.NSPanelTs_Gross:14:53)
    javascript.0	19:50:04.484	warn	at fulfilled (script.js.NSPanelTs_Gross:5:58)
    javascript.0	19:50:04.485	warn	script.js.NSPanelTs_Gross: error at function GenerateMediaPage: Cannot read properties of null (reading 'length')
    javascript.0	19:50:04.579	info	script.js.NSPanelTs_Gross: Desired TFT Firmware: 53 / v4.4.0
    javascript.0	19:50:04.579	info	script.js.NSPanelTs_Gross: Installed TFT Firmware: 53 / v4.4.0
    javascript.0	19:50:10.395	warn	at GenerateMediaPage (script.js.NSPanelTs_Gross:6345:26)
    javascript.0	19:50:10.395	warn	at GeneratePage (script.js.NSPanelTs_Gross:4256:29)
    javascript.0	19:50:10.395	warn	at HandleMessage (script.js.NSPanelTs_Gross:4140:21)
    javascript.0	19:50:10.395	warn	at script.js.NSPanelTs_Gross:3915:21
    javascript.0	19:50:10.395	warn	at step (script.js.NSPanelTs_Gross:33:23)
    javascript.0	19:50:10.395	warn	at Object.next (script.js.NSPanelTs_Gross:14:53)
    javascript.0	19:50:10.395	warn	at fulfilled (script.js.NSPanelTs_Gross:5:58)
    javascript.0	19:50:10.395	warn	at GenerateMediaPage (script.js.NSPanelTs_Gross:6346:25)
    javascript.0	19:50:10.396	warn	at script.js.NSPanelTs_Gross:3915:21
    javascript.0	19:50:10.396	warn	at step (script.js.NSPanelTs_Gross:33:23)
    javascript.0	19:50:10.396	warn	at Object.next (script.js.NSPanelTs_Gross:14:53)
    javascript.0	19:50:10.396	warn	at fulfilled (script.js.NSPanelTs_Gross:5:58)
    javascript.0	19:50:10.397	warn	script.js.NSPanelTs_Gross: error at function GenerateMediaPage: Cannot read properties of null (reading 'length')
    • L lustig29
      @tt-tom
      T
      T
      TT-Tom
      #6245
      @lustig29
      Warum hast du für das neue Panel ein neues Script angelegt. Das alte Bad Script sollte eigentlich funktionieren, wenn du die Einstellungen in Tasmota übernommen hast.
      Das ist ein Problem mit der MediaPage. Da bin ich nicht ganz so sicher drin.
      Die alias Ordner stimmen alle? Und sind auch mit Daten gefüllt??
      EDIT: ich habe mir den Code nochmal angesehen, irgendein alias hat keine Daten bzw null. könnte Autor, Titel oder so sein.
      Gruß Tom
      Public Transport
      NSPanel Adapter Wiki
      L GregorSG 2 Antworten Letzte Antwort
      • T TT-Tom
        @lustig29
        L
        L
        lustig29
        schrieb am zuletzt editiert von lustig29
        #6246
        @tt-tom
        Das Panel hat gar keinen Ordner bekommen unter den Alias.
        Edit: Jetzt geht es. Panel läuft und die Ordner unter Alias sind auch da.😆
        • T TT-Tom
          @lustig29
          GregorSG
          GregorSG
          GregorS
          schrieb am zuletzt editiert von GregorS
          #6247
          Problem erkannt und behoben.
          Auf dem alten nicht mehr funktionierenden NSPanel lief immer noch Tasmota.
          Es hatte zwar eine andere IP-Adresse aber die Namen waren gleich dem neuen Panel
          NSPanel_1.
          Da gab es wohl Konflikte mit dem mqtt.
          Nachdem ich die Namen geändert hatte, ließ sich das neue Panel flüssig bedienen.
          Das alte Panel habe ich auch wieder laufen.
          Nachdem die Updates von Nextion immer mit ERROR System Data geändet haben und keine
          Anzeige zu sehen war, habe ich das Panal via Konsole mit folgendem Befehl neu geflasht.
          FlashNextionAdv1 http://nspanel.pky.eu/lui-release.tft
          Panel läuft jetzt auch wieder einwandfrei.
          INTEL NUC i7, Sonoff, hmIP, AVM, Jeelink, T-Link, Alexa, Saia-Burgess, uvm.
          GregorSG 1 Antwort Letzte Antwort
          • GregorSG GregorS
            NSPanel_1.
            GregorSG
            GregorSG
            GregorS
            #6248
            Ist es möglich das Alarm-Icon aus "cardAlarm" in den Screensaver anstatt der Indikatoren zu bringen?
            Auch mit blinken und entsprechenden Farben.
            T 2 Antworten Letzte Antwort
            • GregorSG GregorS
              T
              T
              TT-Tom
              #6249
              @gregors
              das Icon ist nicht das Problem, Farben wird schon schwieriger, blinken ich sag mal nö. Lass mir mal ein paar Tage nach denken, was mann umsetzen kann. Melde mich dann
              Gruß Tom
              Public Transport
              • ArmilarA Armilar
                @kuckuckmann
                So könnte das Blockly zur Steuerung mit den Tasten aussehen... 😊
                Ich habe es eben getestet und es macht was es soll...
                • Mit beiden Tasten (kurzer Druck) lässt sich der Switch ein- bzw. ausschalten.
                • Mit der linken Taste (halten) wird runtergedimmt (bis Level=5)
                • Mit der rechten Taste (halten) wird hochgedimmt (bis Level=100)
                Rule2 0
                setOption1 1
                setOption73 1
                setOption32 10
                Im Script alle Objekt-ID's zu den Shelly-Datenpunkten ändern und das richtige NSPanel oben natürlich auch anpassen....
                 <variables>
                   <variable id="l*j7Q.FxcE:lZ69x}G;^">actionValue</variable>
                   <variable id="Nb^92:ch0cC^j(j+t33F">valueDimmer</variable>
                   <variable type="interval" id="Interval_Dec">Interval_Dec</variable>
                   <variable type="interval" id="Interval_Inc">Interval_Inc</variable>
                 </variables>
                 <block type="comment" id="rWWRT_~08.nzIw/|fxM-" x="88" y="13">
                   <field name="COMMENT">Rule2 0</field>
                   <next>
                     <block type="comment" id="r%BQ/rK4R-Nl!Uj{f!1{">
                       <field name="COMMENT">setOption1 1&amp;#10;setOption73 1&amp;#10;setOption32 10</field>
                       <next>
                         <block type="comment" id="C)zd^dECENBhpK;SoTsx">
                           <field name="COMMENT">Achtung Objekt ID's anpassen!!!</field>
                           <next>
                             <block type="on_ext" id="Z*WW:Hq=V/0/+D.7sBGj">
                               <value name="OID0">
                                 <shadow type="field_oid" id="s?5LPlVoKvrW,Gf/,d6(">
                                 </shadow>
                                 <block type="field_oid" id=";VZs-nq`+#GL`5jVspo^">
                                   <field name="oid">mqtt.3.SmartHome.NSPanel_4.stat.RESULT</field>
                                 </block>
                               </value>
                               <statement name="STATEMENT">
                                 <block type="controls_if" id="1}vMU$?UKa4@0}B{fqKn">
                                   <value name="IF0">
                                     <block type="logic_compare" id="mTm#*=hyYX*)CJYL5{NT">
                                       <field name="OP">NEQ</field>
                                       <value name="A">
                                         <block type="get_attr" id="1Q!)MR6PliD8`wkY]7S/">
                                           <value name="PATH">
                                             <shadow type="text" id="K~f`:N`cq25E%3ryi2nU">
                                               <field name="TEXT">Button1.Action</field>
                                             </shadow>
                                           </value>
                                           <value name="OBJECT">
                                             <shadow type="get_object" id="8r]C+[oZpG=:z);{T:[p">
                                             </shadow>
                                             <block type="convert_json2object" id="fehyG;p`!1tx0T1W%pV~">
                                               <value name="VALUE">
                                                 <block type="on_source" id=",3=zkk#_^9O$V_f5O:Nm">
                                                 </block>
                                               </value>
                                             </block>
                                           </value>
                                         </block>
                                       </value>
                                       <value name="B">
                                         <block type="logic_null" id="|tA/`.J:b`g@.BLam0$4"></block>
                                       </value>
                                     </block>
                                   </value>
                                   <statement name="DO0">
                                     <block type="variables_set" id="jcJo!w:@}mbbZBL$Stq,">
                                       <field name="VAR" id="l*j7Q.FxcE:lZ69x}G;^">actionValue</field>
                                         <block type="get_attr" id="P+@Cy[pN9B`cqe+4.oPg">
                                           <value name="PATH">
                                             <shadow type="text" id="9U){xFv714N6#}S1LA:f">
                                             </shadow>
                                           </value>
                                             </shadow>
                                             <block type="convert_json2object" id="Y4Q)D{,D=Q:jv^Y:M}l{">
                                                 <block type="on_source" id="MB[hr+aR(]]QaUTDND^X">
                                                 </block>
                                               </value>
                                             </block>
                                           </value>
                                         </block>
                                       </value>
                                       <next>
                                         <block type="logic_switch_case" id="Ts$Zu%1v#ulw4BT}V@u6">
                                           <mutation xmlns="http://www.w3.org/1999/xhtml" case="1" default="1"></mutation>
                                           <value name="CONDITION">
                                             <block type="variables_get" id="=EX$cP2O|R3AkvRY)F@=">
                                             </block>
                                           </value>
                                           <value name="CASECONDITION0">
                                             <block type="text" id="d7pS{i/+zm[D}lNnAzvO">
                                               <field name="TEXT">HOLD</field>
                                             </block>
                                           </value>
                                           <statement name="CASE0">
                                             <block type="variables_set" id="=-Tt;EP|Hk!S[.qyb@$j">
                                               <field name="VAR" id="Nb^92:ch0cC^j(j+t33F">valueDimmer</field>
                                                 <block type="get_value" id="8,cvJwAtPy3n_*{GG+~8">
                                                   <field name="OID">deconz.0.Lights.38.level</field>
                                                 </block>
                                               </value>
                                               <next>
                                                 <block type="timeouts_clearinterval" id="DYiz40:;%K-x]/9}p7Q~">
                                                   <field name="NAME">Interval_Dec</field>
                                                   <next>
                                                     <block type="timeouts_setinterval" id="KComhhdpWduW@}Fiq0D5">
                                                       <field name="INTERVAL">20</field>
                                                       <field name="UNIT">ms</field>
                                                         <block type="variables_set" id="@Z#kb=PS0u11Hw4IE`7l">
                                                             <block type="math_arithmetic" id="J84CCq2A7aJ1Z=n?@0.A">
                                                               <value name="A">
        <shadow type="math_number" id="h0{UJO#M$[KE.b6,eSgV">
        <field name="NUM">1</field>
        </shadow>
        <block type="variables_get" id="cgiD`BkqRK.Iwx=tYN$M">
        </block>
                                                               </value>
                                                               <value name="B">
        <shadow type="math_number" id="AF3wNi[)IvX!}3;U5%W2">
        </shadow>
                                                               </value>
                                                             </block>
                                                           </value>
                                                           <next>
                                                             <block type="controls_if" id="agzjdvFYg(%]ZGU8h$Fa">
                                                               <value name="IF0">
        <block type="logic_compare" id="D}R|i!t0?r8$Qo^Ae{Pj">
        <field name="OP">GTE</field>
        <value name="A">
        <block type="variables_get" id=")5gncF$Wj$4xoa2S.H[l">
        </block>
        </value>
        <value name="B">
        <block type="math_number" id="YSU(~@5K_Oi8%16EG3Ps">
        <field name="NUM">5</field>
        </block>
        </value>
        </block>
                                                               </value>
        <block type="control" id="rww|kMC@cjy2NSN-GbSx">
        <block type="variables_get" id="nZ@M@-MmCIL)dG]B92W%">
        </block>
        </value>
        </block>
                                                               </statement>
                                                               <statement name="ELSE">
        <block type="variables_set" id="AKN,tJI[[S{R3e3WWecd">
        <block type="math_number" id=":9sQp13_tt{lDh^fD(oo">
        </block>
        </value>
        </block>
                                                               </statement>
                                                               <next>
        <block type="debug" id="[?5*_^821;z,.5~{/1kV">
        <field name="Severity">info</field>
        <value name="TEXT">
        <shadow type="text" id="ujO^`MJxA~f).3%lCLc%">
        </shadow>
        <block type="variables_get" id="k]h%z|g:JxbIF{CJx[M#">
        </block>
        </value>
        </block>
                                                               </next>
                                                             </block>
                                                           </next>
                                                         </block>
                                                       </statement>
                                                     </block>
                                                   </next>
                                                 </block>
                                               </next>
                                             </block>
                                           </statement>
                                           <value name="CASECONDITION1">
                                             <block type="text" id="L,//,7QC{=diw/jam,O-">
                                               <field name="TEXT">CLEAR</field>
                                             </block>
                                           </value>
                                           <statement name="CASE1">
                                             <block type="timeouts_clearinterval" id="Em#7bEE#wh,p!u1KOIu(">
                                             </block>
                                           </statement>
                                           <statement name="ONDEFAULT">
                                             <block type="toggle" id="^xLW-e6*gen2(wEm+-rv">
                                               <field name="OID">deconz.0.Lights.38.on</field>
                                             </block>
                                           </statement>
                                           <next>
                                             <block type="debug" id="lQGMUPlZMUqXC]g[@dMs">
                                               <value name="TEXT">
                                                 <shadow type="text" id="pyJotej]:7d$r+/JHoKH">
                                                   <field name="TEXT"></field>
                                                 </shadow>
                                                 <block type="variables_get" id="Lg87dPo-/mhLDKG/7xKN">
                                                 </block>
                                               </value>
                                             </block>
                                           </next>
                                         </block>
                                       </next>
                                     </block>
                                   </statement>
                                   <value name="IF1">
                                     <block type="logic_compare" id="[,~/Bj#ydFCn=cwVU,1%">
                                       <value name="A">
                                         <block type="get_attr" id="^s8B*$@/ql1jOJ~t_!eY">
                                           <value name="PATH">
                                             <shadow type="text" id="ZC=L;@)dR+k`O9}`Gl1-">
                                               <field name="TEXT">Button2.Action</field>
                                             </shadow>
                                           </value>
                                             </shadow>
                                             <block type="convert_json2object" id="9yY(:$40q-ooJ-qg7B7q">
                                                 <block type="on_source" id="gRZ|`e7XWk!pj1:[+`#3">
                                                 </block>
                                               </value>
                                             </block>
                                           </value>
                                         </block>
                                       </value>
                                       <value name="B">
                                         <block type="logic_null" id="[,dS7}4(c9v}iwmmlSm}"></block>
                                       </value>
                                     </block>
                                   </value>
                                   <statement name="DO1">
                                     <block type="variables_set" id="3_ONTZ^LR-+|CpbsafME">
                                         <block type="get_attr" id="m9{a;/I-E(%9z==NLo+v">
                                           <value name="PATH">
                                             <shadow type="text" id="wpy3)J|o1ITOqf,)/PY^">
                                             </shadow>
                                           </value>
                                             </shadow>
                                             <block type="convert_json2object" id="Q.bKt5;Qp+c+Mx#FOm`V">
                                                 <block type="on_source" id="l~O(I:9W^H;e1yFQ9jRM">
                                                 </block>
                                               </value>
                                             </block>
                                           </value>
                                         </block>
                                       </value>
                                       <next>
                                         <block type="logic_switch_case" id="uC.OLA+zsEibh:0P.g4~">
                                             <block type="variables_get" id="%95o%]Whf6VG)]3RVf_F">
                                             </block>
                                           </value>
                                             <block type="text" id="wl.gaT75q@4,^E~_Rc3)">
                                             </block>
                                           </value>
                                             <block type="variables_set" id="u-rt-85(L[r~2z(cNp~^">
                                                 <block type="get_value" id="Yh};XYzcem,EFZw07(b)">
                                                 </block>
                                               </value>
                                               <next>
                                                 <block type="timeouts_clearinterval" id="?@NH3@i!g,s.r:,N0_cO">
                                                   <field name="NAME">Interval_Inc</field>
                                                   <next>
                                                     <block type="timeouts_setinterval" id="acO^L3Z1^z|#OnILeYAC">
                                                         <block type="variables_set" id="-{RUj-XS}Tg_tTag]av;">
                                                             <block type="math_arithmetic" id="{S]fnTBqe;:D^gMQP_jV">
                                                               <field name="OP">ADD</field>
                                                               <value name="A">
        </shadow>
        <block type="variables_get" id=";W33JEQYL6ZG/B+F=nSq">
        </block>
                                                               </value>
                                                               <value name="B">
        <shadow type="math_number" id="%Dg4pyifW:Ddg/_WI{hQ">
        </shadow>
                                                               </value>
                                                             </block>
                                                           </value>
                                                           <next>
                                                             <block type="controls_if" id="A[awWI,/)@2_`mycDqN)">
                                                               <value name="IF0">
        <block type="logic_compare" id="P[GHBPwIZj#No$O2$/jc">
        <field name="OP">LTE</field>
        <value name="A">
        <block type="variables_get" id="=N#lxK,4X`:MKjcS,c]U">
        </block>
        </value>
        <value name="B">
        <block type="math_number" id="EzI`ZO]e^D^v{.Cc[DZH">
        <field name="NUM">100</field>
        </block>
        </value>
        </block>
                                                               </value>
        <block type="control" id="(.51~l5|92Rw|mf@fM;d">
        <block type="variables_get" id="zs)9,~y|nv/#gBJwp,r*">
        </block>
        </value>
        </block>
                                                               </statement>
        <block type="variables_set" id="9b2dZ!#$m}0]re6~nf0/">
        <block type="math_number" id="3NBC$iZ)CXf|BxFb+^h1">
        </block>
        </value>
        </block>
                                                               </statement>
                                                               <next>
        <block type="debug" id="Z=}Fo*FJP9J#.Jmz]CTG">
        <value name="TEXT">
        </shadow>
        <block type="variables_get" id="8[K2z1~=}p}^?j%wu[GQ">
        </block>
        </value>
        </block>
                                                               </next>
                                                             </block>
                                                           </next>
                                                         </block>
                                                       </statement>
                                                     </block>
                                                   </next>
                                                 </block>
                                               </next>
                                             </block>
                                           </statement>
                                             <block type="text" id="?6m~HShM~h./{Kgs6kdP">
                                             </block>
                                           </value>
                                             <block type="timeouts_clearinterval" id="d|@HJ%={DTpMf#-x^]%D">
                                             </block>
                                           </statement>
                                             <block type="toggle" id="5d2!Bbz)FJ;Y$6yvcka2">
                                             </block>
                                           </statement>
                                           <next>
                                             <block type="debug" id="9{k8FDr3$3p1KpkN;J$:">
                                               <value name="TEXT">
                                                 </shadow>
                                                 <block type="variables_get" id="+aCgdAz{qlYKtN%ZeBmB">
                                                 </block>
                                               </value>
                                             </block>
                                           </next>
                                         </block>
                                       </next>
                                     </block>
                                   </statement>
                                 </block>
                               </statement>
                             </block>
                           </next>
                         </block>
                       </next>
                     </block>
                   </next>
                 </block>
                </xml>
                EDIT:
                Na wenn es ins Wiki kommt.... habe das Bild noch schöner gemacht ;-)
                EDIT2:
                Man kann natürlich auch das Netz etwas entlasten in dem man in größeren Schritten inkrementiert/dekrementiert (hier im Beispiel in 5er Schritten) oder auch das Intervall anpassen, damit der Dimmer langsamer reagiert... Einfach ausprobieren.
                Des Weiteren kann jedes Leuchtmittel mit Dimmfunktion (HUE, deCONZ, Shelly-DUO, etc.) damit ebenso gesteuert werden. Muss kein Shelly-Dimmer sein... Wichtig sind die Datenpunkte zum An-/Ausschalten und zum Dimmen
                L
                L
                lustig29
                #6250
                @armilar said in SONOFF NSPanel mit Lovelace UI:
                Copy to ClipboardRule2 0
                setOption1 1
                setOption73 1
                setOption32 10
                Das eine Panel soll ja dann ins Esszimmer und die Tasten als normaler Lichtschalter funktionieren. Reicht es um es rückgängig zu mache, dass einfache die Vorlage neu rein lade und das Panel aus dem Blockly entferne. Oder muss ich noch was machen?
                • L lustig29
                  setOption1 1
                  setOption73 1
                  setOption32 10
                  ArmilarA
                  ArmilarA
                  Armilar
                  Most Active Forum Testing
                  #6251
                  @lustig29
                  Standard-Vorlage und wenn es ein normaler Lichtschalter ist, das heißt keine smarten Leuchtmittel, dann ohne Rule 2 und die Lampen am NSPanel über die beiden externen Ausgänge „L Out“ anschließen. Danach laufen die die NSPanel über die internen Relais.Lassen sich dann auch über die Relay-Datenpunkte unter 0_userdata… steuern
                  L 1 Antwort Letzte Antwort
                  • ArmilarA Armilar
                    @lustig29
                    L
                    L
                    lustig29
                    #6252
                    @armilar
                    Also muss ich in der Console dann nochmal Rule 2 0 ausführen?
                    • L lustig29
                      @armilar
                      ArmilarA
                      ArmilarA
                      Armilar
                      #6253
                      @lustig29
                      Ja, dann sollten die Relais klicken
                      Rule2 0
                      • ArmilarA Armilar
                        @lustig29
                        Rule2 0
                        L
                        L
                        lustig29
                        #6254
                        @armilar
                        Da klickt leider nichts...
                        • GregorSG GregorS
                          T
                          T
                          TT-Tom
                          #6255
                          @gregors
                          Ich habe eine Lösung gefunden, musst aber etwas Code schreiben entwerder Blockly oder JS.
                          Blinken geht nicht.
                          Du legst dir diese drei Datenpunkte an mit diesen Typen.
                          0_userdata.0.example_boolean wird als Trigger genutzt
                          0_userdata.0.example_string wird der Iconname gesetzt
                          0_userdata.0.example_number wird der Farbwert gesetzt. Die Nummer kannst du von dieser Seite ermitteln. https://nodtem66.github.io/nextion-hmi-color-convert/index.html
                          Im Code musst du zuerst die Farbe setzen, dann das Icon und zum Schluss den boolean neu setzen. Kann der selbe Wert sein, muss nur bestätigt werden (aktualisieren).
                          Der Code für den indikator
                                  ScreensaverEntity: '0_userdata.0.example_boolean',
                                  ScreensaverEntityFactor: 1,
                                  ScreensaverEntityDecimalPlaces: 0,
                                  ScreensaverEntityIconOn: '0_userdata.0.example_string',
                                  ScreensaverEntityIconOff: null,
                                  ScreensaverEntityText: 'Alarm',
                                  ScreensaverEntityUnitText: '%',
                                  ScreensaverEntityIconColor: '0_userdata.0.example_number',
                                  ScreensaverEntityNaviToPage: Alarmseite, // name der Alarmpage
                          Beispiel für Blockly
                          Gruß Tom
                          Public Transport
                          • L lustig29
                            @armilar
                            ArmilarA
                            ArmilarA
                            Armilar
                            #6256
                            @lustig29
                            Ist ganz normaler Auslieferungszustand ohne SetOption x
                            Das heißt SetOption73 und SetOption114 sind auch aus. Was Du auch in der Tasmota-Konsole eingestellt hast, mach es rückgängig und du hörst die Relais auch schalten…
                            • GregorSG
                              GregorSG
                              GregorS
                              #6257
                              @tt-tom
                              Habe das Blockly erstellt, aber es wird nur das Shild-off in blau angezeigt.
                              Die Variablen werden entsprechend gefüllt.
                              Was muss ich im NSPanel Script noch anpassen?
                              • GregorSG GregorS
                                @tt-tom
                                T
                                T
                                TT-Tom
                                #6258
                                @gregors
                                Zeig mal dein Blockly und den Auszug vom Script/indikator.
                                Welche Script Version hast du???
                                Gruß Tom
                                Public Transport
                                • T TT-Tom
                                  @gregors
                                  GregorSG
                                  GregorSG
                                  GregorS
                                  #6259
                                  @tt-tom
                                  indicatorScreensaverEntity: [
                                          ScreensaverEntityNaviToPage: Buero_Alarm, // name der Alarmpage
                                  Bekomme jetzt auch Fehler beim Speichern
                                  script.js.NSPanel_2_V4_4_0_1: TypeScript compilation failed: export const config: Config = { ^ ERROR: Property 'button2' is missing in type '{ pages: (NSPanel.PageEntities | NSPanel.PageGrid | NSPanel.PageAlarm)[]; subPages: (NSPanel.PageEntities | NSPanel.PageGrid)[]; leftScreensaverEntity: []; ... 11 more ...; defaultBackgroundColor: any; }' but required in type 'Config'.
                                  • GregorSG GregorS
                                    @tt-tom
                                    T
                                    T
                                    TT-Tom
                                    #6260
                                    @gregors
                                    da hast du eine Klamme zuviel gesetzt oder eine zuviel gelöscht. Kontrolliere mal dein Bereich Config.
                                    Tausche mal bei boolean von aktualisieren auf steuern.
                                    Gruß Tom
                                    Public Transport
                                    • T TT-Tom
                                      @gregors
                                      GregorSG
                                      GregorSG
                                      GregorS
                                      #6261
                                      @tt-tom
                                      Fehler habe ich gefunden, hatte eine Klammer auskommentiert.
                                      Variablen werden gefüllt, aber im Screensaver stehen oben immer noch die beiden
                                      "Bulbs" für die Tasten.
                                      die Var "example_boolean" ist jetzt auf steuern geändert.
                                      Das Alarmsymbol wird nirgend angezeigt.
                                      Ich nutze den Standard Screensaver.
                                      Muss ich hier nicht die Zeilen löschen bzw. auskommentieren, da er dort doch die Symbole anzeigt?
                                      // Status Icon
                                          mrIcon1ScreensaverEntity: {
                                              ScreensaverEntity: NSPanel_Path + 'Relay.1',
                                              ScreensaverEntityIconOn: 'lightbulb',
                                              ScreensaverEntityValue: null,
                                              ScreensaverEntityValueDecimalPlace: 0,
                                              ScreensaverEntityValueUnit: null,
                                              ScreensaverEntityOnColor: On,
                                              ScreensaverEntityOffColor: HMIOff
                                          mrIcon2ScreensaverEntity: {
                                             ScreensaverEntity: NSPanel_Path + 'Relay.2',
                                      • GregorSG GregorS
                                        @tt-tom
                                        // Status Icon
                                        T
                                        T
                                        TT-Tom
                                        #6262
                                        @gregors
                                        Okay das du den Standard nutzt war mir nicht bekannt. Ich bin vom Advanced ausgegangen, weil Du Indikatoren schriebst.
                                        Wenn Du beim Standard bleiben willst, nutzt du die mrIcon1 und 2. dann muss ich das nochmal anpassen. Welcher soll es sein 1 oder 2??
                                        Gruß Tom
                                        Public Transport
                                        • GregorSG
                                          GregorSG
                                          GregorS
                                          #6263
                                          @tt-tom
                                          2 wäre gut.
                                          Habe jetzt mal testweise die Icons ausgeblendet. Funktioniert.
                                          So funktioniert es leider nicht
                                                  ScreensaverEntityOnColor: HMIOn,
                                          Es wird kein Icon angezeigt.
                                          Setze im Blockly "true" und "false"
                                          Resultat:
                                          Passt erstmal alles
                                          83.9k
