  4. Kann nicht backitup installieren
    1.0k
    6.1k
backupbackitup fehler updatebackitup backup
17 Beiträge 8 Kommentatoren 2.2k Aufrufe 6 Beobachtet
  • C Chris777
    host.iOBrocker
    	2024-08-02 19:02:04.827	info	iobroker exit 25
    host.iOBrocker
    	2024-08-02 19:02:03.808	error	iobroker host.iOBrocker Cannot install iobroker.backitup@2.11.0: 1
    host.iOBrocker
    	2024-08-02 19:02:03.807	error	iobroker npm error code EBADENGINEnpm error engine Unsupported enginenpm error engine Not compatible with your version of node/npm: minimatch@10.0.1npm error notsup Not compatible with your version of node/npm: minimatch@10.0.1npm error notsup Required: {"node":"20 || >=22"}npm error notsup Actual: {"npm":"10.8.2","node":"v18.20.4"}npm error A complete log of this run can be found in: /opt/iobroker/.npm/_logs/2024-08-02T17_01_57_111Z-debug-0.log
    host.iOBrocker
    	2024-08-02 19:02:03.783	info	iobroker npm error A complete log of this run can be found in: /opt/iobroker/.npm/_logs/2024-08-02T17_01_57_111Z-debug-0.log
    host.iOBrocker
    	2024-08-02 19:02:03.782	info	iobroker npm error engine Not compatible with your version of node/npm: minimatch@10.0.1npm error notsup Not compatible with your version of node/npm: minimatch@10.0.1npm error notsup Required: {"node":"20 || >=22"}npm error notsup Actual: {"npm":"10.8.2","node":"v18.20.4"}
    host.iOBrocker
    	2024-08-02 19:02:03.781	info	iobroker npm error engine Unsupported engine
    host.iOBrocker
    	2024-08-02 19:02:03.780	info	iobroker npm error code EBADENGINE
    host.iOBrocker
    	2024-08-02 19:01:56.983	info	iobroker Installing iobroker.backitup@2.11.0... (System call)
    host.iOBrocker
    	2024-08-02 19:01:56.982	info	iobroker NPM version: 10.8.2
    host.iOBrocker
    	2024-08-02 19:01:55.406	info	iobroker add backitup auto --host iOBrocker --debug
    Habe Version
    Plattform: docker (official image - v9.1.2)
    RAM: 11.5 GB
    Node.js: v18.20.4(20.16.0)
    NPM: 10.8.2
    Kann mir jemand helfen?
    Auch wenn der Thread schon 2 Jahre alt ist:
    @chris777 sagte in Kann nicht backitup installieren:
    Node.js: v18.20.4(
    • C Offline
      Chris777
      schrieb am zuletzt editiert von Chris777
      wie kann ich denn auf node 20 kommen?
      Bin jetzt nicht der Profi mit SSH
      Kann ich den Container aktualisieren?
      Habe iobrocker im Container in einer Synology
      • C Chris777
        Das wäre der bevorzugte Weg. Soweit ich weiß gibt es aber noch keinen stabilen Docker-Container mit eingebackenem nodejs@20.
        • C Offline
          Chris777
          Habe es erstmal wieder hinbekommen und er zeigt auch beim Host etwas an, aber es geht erstmal.
          Danke!
          Node.js: v20.15.0(20.16.0)
          NPM: 10.7.0(10.8.1)
          W 1 Antwort Letzte Antwort
          • C Chris777
            Danke!
            NPM: 10.7.0(10.8.1)
            W Offline
            W Offline
            wodkab
            schrieb am zuletzt editiert von wodkab
            @chris777
            Wie hast du Node.js im Container upgedated ... stehe vor dem gleichen Problem?
            Ich habe das Problem "gefixed" in dem ich auf die neuste Version des Backitup-Adapter (3.0.15) ging ... dieser lässt nämlich V18 wieder als Abhängigkeit zu:
            ioBroker.backitup commit
            C simatecS 2 Antworten Letzte Antwort
            • W wodkab
              @chris777
              Chris777
              @wodkab Ich habe in meiner Synology im Containermanager die entsprechende Version von buanet des Image genommen und dann den Container neu aufgesetzt und dann das Backup wieder hergestellt.
              Wo hast du denn die 3er Version von backitup her direkt bei Github?
              • C Chris777
                W Offline
                W Offline
                wodkab
                Spannend habe ich auch ... dort ist bei mir aber node.js:
                Und die 3er Version habe direkt aus Github installieren lassen.
                Das spannende ist ja, das im Container backitup installiert ist, beim bzw. nach dem restore dann aber alle Adapter neu installiert werden, halt auch der backitup ... und der schlägt dann fehl wegen falsche node.js Version.
                da_WoodyD haselchenH 2 Antworten Letzte Antwort
                • W wodkab
                  da_WoodyD Offline
                  da_WoodyD Offline
                  @wodkab versautes backup? logischer weise bekommst du beim backup die alten versionen.
                  • W wodkab
                    haselchenH Offline
                    haselchenH Offline
                    haselchen
                    @wodkab
                    @Chris777
                    Wie man im Container auf die Node20 updatet habe ich hier beschrieben
                    https://forum.iobroker.net/topic/73909/node-js-update-im-docker/28?_=1722771085943
                    • W wodkab
                      @chris777
                      simatecS Offline
                      simatecS Offline
                      simatec
                      @wodkab sagte in Kann nicht backitup installieren:
                      Es war nicht Backitup, sondern eine Abhängkeit, die Node 18 nicht zugelassen hat.
                      Dies betraf aber nur Backitup v3.0.14.
                      • Besuche meine Github Seite
                      • HowTo Restore ioBroker
                      • C Offline
                        Chris777
                        wenn du latest gewählt hast bei buanet, dann ist es die 18er und nicht die 20er. Die 20er gibt es extra auszuwählen.
                        Ich denke bei latest ist es die 18er, da diese ohne Probleme läuft.
                        Weiß einer wann die 20er kommt ohne Probleme?
