  4. Kann nicht backitup installieren
    1.0k
    6.1k
backupbackitup fehler updatebackitup backup
17 Beiträge 8 Kommentatoren 2.2k Aufrufe 6 Beobachtet
  • C Offline
    Chris777
    schrieb am zuletzt editiert von Chris777
    host.iOBrocker
    	2024-08-02 19:02:04.827	info	iobroker exit 25
    host.iOBrocker
    	2024-08-02 19:02:03.808	error	iobroker host.iOBrocker Cannot install iobroker.backitup@2.11.0: 1
    host.iOBrocker
    	2024-08-02 19:02:03.807	error	iobroker npm error code EBADENGINEnpm error engine Unsupported enginenpm error engine Not compatible with your version of node/npm: minimatch@10.0.1npm error notsup Not compatible with your version of node/npm: minimatch@10.0.1npm error notsup Required: {"node":"20 || >=22"}npm error notsup Actual: {"npm":"10.8.2","node":"v18.20.4"}npm error A complete log of this run can be found in: /opt/iobroker/.npm/_logs/2024-08-02T17_01_57_111Z-debug-0.log
    host.iOBrocker
    	2024-08-02 19:02:03.783	info	iobroker npm error A complete log of this run can be found in: /opt/iobroker/.npm/_logs/2024-08-02T17_01_57_111Z-debug-0.log
    host.iOBrocker
    	2024-08-02 19:02:03.782	info	iobroker npm error engine Not compatible with your version of node/npm: minimatch@10.0.1npm error notsup Not compatible with your version of node/npm: minimatch@10.0.1npm error notsup Required: {"node":"20 || >=22"}npm error notsup Actual: {"npm":"10.8.2","node":"v18.20.4"}
    host.iOBrocker
    	2024-08-02 19:02:03.781	info	iobroker npm error engine Unsupported engine
    host.iOBrocker
    	2024-08-02 19:02:03.780	info	iobroker npm error code EBADENGINE
    host.iOBrocker
    	2024-08-02 19:01:56.983	info	iobroker Installing iobroker.backitup@2.11.0... (System call)
    host.iOBrocker
    	2024-08-02 19:01:56.982	info	iobroker NPM version: 10.8.2
    host.iOBrocker
    	2024-08-02 19:01:55.406	info	iobroker add backitup auto --host iOBrocker --debug
    Habe Version
    Plattform: docker (official image - v9.1.2)
    RAM: 11.5 GB
    Node.js: v18.20.4(20.16.0)
    NPM: 10.8.2
    Kann mir jemand helfen?
    • C Chris777
      host.iOBrocker
      host.iOBrocker
      host.iOBrocker
      host.iOBrocker
      host.iOBrocker
      host.iOBrocker
      host.iOBrocker
      host.iOBrocker
      host.iOBrocker
      host.iOBrocker
      Habe Version
      RAM: 11.5 GB
      NPM: 10.8.2
      Auch wenn der Thread schon 2 Jahre alt ist:
      @chris777 sagte in Kann nicht backitup installieren:
      Node.js: v18.20.4(
      • C Offline
        Chris777
        wie kann ich denn auf node 20 kommen?
        Bin jetzt nicht der Profi mit SSH
        Kann ich den Container aktualisieren?
        Habe iobrocker im Container in einer Synology
        • C Chris777
          Das wäre der bevorzugte Weg. Soweit ich weiß gibt es aber noch keinen stabilen Docker-Container mit eingebackenem nodejs@20.
          • C Offline
            Chris777
            Habe es erstmal wieder hinbekommen und er zeigt auch beim Host etwas an, aber es geht erstmal.
            Danke!
            Node.js: v20.15.0(20.16.0)
            NPM: 10.7.0(10.8.1)
            W 1 Antwort Letzte Antwort
            • C Chris777
              Danke!
              NPM: 10.7.0(10.8.1)
              W Offline
              W Offline
              wodkab
              schrieb am zuletzt editiert von wodkab
              @chris777
              Wie hast du Node.js im Container upgedated ... stehe vor dem gleichen Problem?
              Ich habe das Problem "gefixed" in dem ich auf die neuste Version des Backitup-Adapter (3.0.15) ging ... dieser lässt nämlich V18 wieder als Abhängigkeit zu:
              ioBroker.backitup commit
              C simatecS 2 Antworten Letzte Antwort
              • W wodkab
                @chris777
                Chris777
                @wodkab Ich habe in meiner Synology im Containermanager die entsprechende Version von buanet des Image genommen und dann den Container neu aufgesetzt und dann das Backup wieder hergestellt.
                Wo hast du denn die 3er Version von backitup her direkt bei Github?
                • C Chris777
                  W Offline
                  W Offline
                  wodkab
                  Spannend habe ich auch ... dort ist bei mir aber node.js:
                  Und die 3er Version habe direkt aus Github installieren lassen.
                  Das spannende ist ja, das im Container backitup installiert ist, beim bzw. nach dem restore dann aber alle Adapter neu installiert werden, halt auch der backitup ... und der schlägt dann fehl wegen falsche node.js Version.
                  da_WoodyD haselchenH 2 Antworten Letzte Antwort
                  • W wodkab
                    da_WoodyD Offline
                    da_WoodyD Offline
                    @wodkab versautes backup? logischer weise bekommst du beim backup die alten versionen.
                    • W wodkab
                      haselchenH Offline
                      haselchenH Offline
                      haselchen
                      @wodkab
                      @Chris777
                      Wie man im Container auf die Node20 updatet habe ich hier beschrieben
                      https://forum.iobroker.net/topic/73909/node-js-update-im-docker/28?_=1722771085943
                      • W wodkab
                        @chris777
                        simatecS Offline
                        simatecS Offline
                        simatec
                        @wodkab sagte in Kann nicht backitup installieren:
                        Es war nicht Backitup, sondern eine Abhängkeit, die Node 18 nicht zugelassen hat.
                        Dies betraf aber nur Backitup v3.0.14.
                        • Besuche meine Github Seite
                        • HowTo Restore ioBroker
                        • C Offline
                          Chris777
                          wenn du latest gewählt hast bei buanet, dann ist es die 18er und nicht die 20er. Die 20er gibt es extra auszuwählen.
                          Ich denke bei latest ist es die 18er, da diese ohne Probleme läuft.
                          Weiß einer wann die 20er kommt ohne Probleme?
