  4. [gelöst] Performance nach Systemcrash problematisch
11 Beiträge 3 Kommentatoren 665 Aufrufe 2 Beobachtet
  • M m.schalk
    Halo zusammen
    nach einem Systemabsturz ist mein iob total langsam, ich ich bekomme diese Fehlermeldungen:
     Cannot read system.config: undefined (OK when migrating or restoring)
    Server Configured backup period 7200000 is larger than the supported maximum of 35791 minutes. Defaulting to 120 minutes.
    /opt/iobroker/node_modules/standard-as-callback/built/index.js:6
            throw e;
    Error: Connection is closed.
        at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
        at Redis.scan (/opt/iobroker/node_modules/ioredis/built/commander.js:122:25)
        at ScanStream._read (/opt/iobroker/node_modules/ioredis/built/ScanStream.js:36:41)
        at Readable.read (node:internal/streams/readable:737:12)
        at resume_ (node:internal/streams/readable:1255:12)
        at process.processTicksAndRejections (node:internal/process/task_queues:82:21)
    Emitted 'error' event on ScanStream instance at:
        at /opt/iobroker/node_modules/ioredis/built/ScanStream.js:38:22
        at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:12:23)
        at /opt/iobroker/node_modules/standard-as-callback/built/index.js:33:51
        at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
    Node.js v20.16.0
    @m-schalk
    Schau dir per
    iob diag
    an, wo es da vielleicht klemmt.
    M 2 Antworten Letzte Antwort
    • M m.schalk
      Halo zusammen
              throw e;
      Node.js v20.16.0
      @m-schalk sagte in Performance nach Systemcrash problematisch:
      heisst was genau??
      Du hattest ja auch bisher schon ständige reboots
        @m-schalk
        Schau dir per
        iob diag
        m.schalk
        @thomas-braun hier die Ausgabe:
        Skript v.2024-05-22
        *** BASE SYSTEM ***
         Static hostname: BU02SMART02-iobroker
               Icon name: computer-container
                 Chassis: container
          Virtualization: lxc
        Operating System: Ubuntu 22.04.4 LTS
                  Kernel: Linux 6.8.8-3-pve
            Architecture: x86-64
        model name      : Intel(R) Core(TM) i3-5010U CPU @ 2.10GHz
        Docker          : false
        Virtualization  : lxc
        Kernel          : x86_64
        Userland        : 64 bit
        Systemuptime and Load:
         18:48:52 up  2:02,  3 users,  load average: 5.50, 7.11, 7.09
        CPU threads: 4
        *** Time and Time Zones ***
                       Local time: Sat 2024-08-03 18:48:52 CEST
                   Universal time: Sat 2024-08-03 16:48:52 UTC
                         RTC time: n/a
                      NTP service: inactive
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        mario
        HOME=/home/mario
        GROUPS=mario sudo iobroker
        iobroker
        HOME=/home/iobroker
        GROUPS=iobroker tty dialout audio video plugdev redis
        *** Display-Server-Setup ***
        Display-Server: false
        Desktop:
        Terminal:       tty
        Boot Target:    multi-user.target
        *** MEMORY ***
        Mem:            8.2G        5.3G        1.2G        0.0K        1.8G        2.9G
        Swap:           7.8G        684M        7.1G
        Total:           15G        5.9G        8.2G
        Active iob-Instances:   41
                 8192 M total memory
                 5257 M used memory
                 3861 M active memory
                 2647 M inactive memory
                 1155 M free memory
                    0 M buffer memory
                 1779 M swap cache
                 7759 M total swap
                  684 M used swap
                 7075 M free swap
        top - 18:48:53 up  2:02,  3 users,  load average: 5.50, 7.11, 7.09
        Tasks:  78 total,   6 running,  72 sleeping,   0 stopped,   0 zombie
        %Cpu(s): 75.8 us, 12.1 sy,  0.0 ni,  6.1 id,  0.0 wa,  0.0 hi,  6.1 si,  0.0 st
        MiB Mem :   8192.0 total,   1154.5 free,   5257.7 used,   1779.7 buff/cache
        MiB Swap:   7760.0 total,   7075.2 free,    684.8 used.   2934.2 avail Mem
        *** FAILED SERVICES ***
          UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
        * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
        1 loaded units listed.
        *** FILESYSTEM ***
        Filesystem     Type   Size  Used Avail Use% Mounted on
        /dev/loop0     ext4    36G   24G   11G  69% /
        none           tmpfs  492K  4.0K  488K   1% /dev
        tmpfs          tmpfs  7.8G     0  7.8G   0% /dev/shm
        tmpfs          tmpfs  3.1G  152K  3.1G   1% /run
        tmpfs          tmpfs  5.0M     0  5.0M   0% /run/lock
        tmpfs          tmpfs  1.6G     0  1.6G   0% /run/user/1001
        dmesg: read kernel buffer failed: Operation not permitted
        Show mounted filesystems:
        TARGET                                        SOURCE                         FSTYPE      OPTIONS
        /                                             /dev/loop0                     ext4        rw,relatime
        |-/run                                        tmpfs                          tmpfs       rw,nosuid,nodev,size=3240840k,nr_inodes=819200,mode=755,uid=100000,gid=100000,inode64
        | |-/run/lock                                 tmpfs                          tmpfs       rw,nosuid,nodev,noexec,relatime,size=5120k,uid=100000,gid=100000,inode64
        | |-/run/credentials/systemd-sysusers.service ramfs                          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
        | `-/run/user/1001                            tmpfs                          tmpfs       rw,nosuid,nodev,relatime,size=1620416k,nr_inodes=405104,mode=700,uid=101001,gid=101001,inode64
        |-/dev                                        none                           tmpfs       rw,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
        | |-/dev/shm                                  tmpfs                          tmpfs       rw,nosuid,nodev,uid=100000,gid=100000,inode64
        | |-/dev/mqueue                               mqueue                         mqueue      rw,relatime
        | |-/dev/ttyUSB0                              udev[/ttyUSB0]                 devtmpfs    rw,nosuid,relatime,size=8068256k,nr_inodes=2017064,mode=755,inode64
        | | `-/dev/ttyUSB0                            udev[/ttyUSB0]                 devtmpfs    rw,nosuid,relatime,size=8068256k,nr_inodes=2017064,mode=755,inode64
        | |-/dev/.lxc/proc                            proc                           proc        rw,relatime
        | |-/dev/.lxc/sys                             sys                            sysfs       rw,relatime
        | |-/dev/full                                 udev[/full]                    devtmpfs    rw,nosuid,relatime,size=8068256k,nr_inodes=2017064,mode=755,inode64
        | |-/dev/null                                 udev[/null]                    devtmpfs    rw,nosuid,relatime,size=8068256k,nr_inodes=2017064,mode=755,inode64
        | |-/dev/random                               udev[/random]                  devtmpfs    rw,nosuid,relatime,size=8068256k,nr_inodes=2017064,mode=755,inode64
        | |-/dev/tty                                  udev[/tty]                     devtmpfs    rw,nosuid,relatime,size=8068256k,nr_inodes=2017064,mode=755,inode64
        | |-/dev/urandom                              udev[/urandom]                 devtmpfs    rw,nosuid,relatime,size=8068256k,nr_inodes=2017064,mode=755,inode64
        | |-/dev/zero                                 udev[/zero]                    devtmpfs    rw,nosuid,relatime,size=8068256k,nr_inodes=2017064,mode=755,inode64
        | |-/dev/pts                                  devpts                         devpts      rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
        | |-/dev/ptmx                                 devpts[/ptmx]                  devpts      rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
        | |-/dev/console                              devpts[/0]                     devpts      rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
        | |-/dev/tty1                                 devpts[/1]                     devpts      rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
        | `-/dev/tty2                                 devpts[/2]                     devpts      rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
        |-/proc                                       proc                           proc        rw,nosuid,nodev,noexec,relatime
        | |-/proc/sys                                 proc[/sys]                     proc        ro,relatime
        | | |-/proc/sys/net                           proc[/sys/net]                 proc        rw,nosuid,nodev,noexec,relatime
        | | |-/proc/sys/fs/binfmt_misc                binfmt_misc                    binfmt_misc rw,nosuid,nodev,noexec,relatime
        | | `-/proc/sys/kernel/random/boot_id         none[/.lxc-boot-id]            tmpfs       ro,nosuid,nodev,noexec,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
        | |-/proc/sysrq-trigger                       proc[/sysrq-trigger]           proc        ro,relatime
        | |-/proc/cpuinfo                             lxcfs[/proc/cpuinfo]           fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
        | |-/proc/diskstats                           lxcfs[/proc/diskstats]         fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
        | |-/proc/loadavg                             lxcfs[/proc/loadavg]           fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
        | |-/proc/meminfo                             lxcfs[/proc/meminfo]           fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
        | |-/proc/slabinfo                            lxcfs[/proc/slabinfo]          fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
        | |-/proc/stat                                lxcfs[/proc/stat]              fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
        | |-/proc/swaps                               lxcfs[/proc/swaps]             fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
        | `-/proc/uptime                              lxcfs[/proc/uptime]            fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
        `-/sys                                        sysfs                          sysfs       ro,nosuid,nodev,noexec,relatime
          |-/sys/fs/fuse/connections                  fusectl                        fusectl     rw,nosuid,nodev,noexec,relatime
          |-/sys/devices/virtual/net                  sysfs[/devices/virtual/net]    sysfs       rw,nosuid,nodev,noexec,relatime
          |-/sys/kernel/debug                         debugfs                        debugfs     rw,nosuid,nodev,noexec,relatime
          |-/sys/kernel/security                      securityfs                     securityfs  rw,nosuid,nodev,noexec,relatime
          |-/sys/fs/pstore                            pstore                         pstore      rw,nosuid,nodev,noexec,relatime
          |-/sys/fs/cgroup                            none                           cgroup2     rw,nosuid,nodev,noexec,relatime
          `-/sys/devices/system/cpu                   lxcfs[/sys/devices/system/cpu] fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
        /var:
        5.2G    /var/
        3.7G    /var/log
        3.6G    /var/log/journal/a4cc250a83fe4944adccd8462a307fa7
        807M    /var/lib
        Archived and active journals take up 8.0M in the file system.
        /opt/iobroker/backups:
        777M    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        9.3G    /opt/iobroker/iobroker-data/
        7.3G    /opt/iobroker/iobroker-data/history
        737M    /opt/iobroker/iobroker-data/files
        487M    /opt/iobroker/iobroker-data/esphome.0/.esphome/build
        136M    /opt/iobroker/iobroker-data/objects.jsonl
        98M     /opt/iobroker/iobroker-data/objects.json.migrated
        98M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
        97M     /opt/iobroker/iobroker-data/objects.json.broken
        41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
        USB-Devices by-id:
        /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_d653ffa49dc9eb11ade6914f1d69213e-if00-port0
        HINT:
        Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
        /dev/ttyUSB0
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v20.16.0
        /usr/bin/node           v20.16.0
        /usr/bin/npm            10.8.1
        /usr/bin/npx            10.8.1
        /usr/bin/corepack       0.28.2
        nodejs:
          Installed: 20.16.0-1nodesource1
          Candidate: 20.16.0-1nodesource1
          Version table:
         *** 20.16.0-1nodesource1 1001
                500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
             20.15.1-1nodesource1 1001
             20.15.0-1nodesource1 1001
             20.14.0-1nodesource1 1001
             20.13.1-1nodesource1 1001
             20.13.0-1nodesource1 1001
             20.12.2-1nodesource1 1001
             20.12.1-1nodesource1 1001
             20.12.0-1nodesource1 1001
             20.11.1-1nodesource1 1001
             20.11.0-1nodesource1 1001
             20.10.0-1nodesource1 1001
             20.9.0-1nodesource1 1001
             20.8.1-1nodesource1 1001
             20.8.0-1nodesource1 1001
             20.7.0-1nodesource1 1001
             20.6.1-1nodesource1 1001
             20.6.0-1nodesource1 1001
             20.5.1-1nodesource1 1001
             20.5.0-1nodesource1 1001
             20.4.0-1nodesource1 1001
             20.3.1-1nodesource1 1001
             20.3.0-1nodesource1 1001
             20.2.0-1nodesource1 1001
             20.1.0-1nodesource1 1001
             20.0.0-1nodesource1 1001
             12.22.9~dfsg-1ubuntu3.6 500
                500 http://archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages
                500 http://archive.ubuntu.com/ubuntu jammy-security/universe amd64 Packages
             12.22.9~dfsg-1ubuntu3 500
                500 http://archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: redis
        Core adapters versions
        js-controller:  6.0.9
        admin:          6.17.14
        javascript:     8.3.1
        nodejs modules from github:     1
        | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550)
        Adapter State
        + system.adapter.admin.0                  : admin                 : BU02SMART02-iobroker                     -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.alarm.0                  : alarm                 : BU02SMART02-iobroker                     -  enabled
        + system.adapter.alexa2.0                 : alexa2                : BU02SMART02-iobroker                     -  enabled
          system.adapter.bosesoundtouch.0         : bosesoundtouch        : BU02SMART02-iobroker                     - disabled
        + system.adapter.daikin.0                 : daikin                : BU02SMART02-iobroker                     -  enabled
        + system.adapter.device-reminder.0        : device-reminder       : BU02SMART02-iobroker                     -  enabled
        + system.adapter.device-watcher.1         : device-watcher        : BU02SMART02-iobroker                     -  enabled
        + system.adapter.discovery.0              : discovery             : BU02SMART02-iobroker                     -  enabled
          system.adapter.dwd.0                    : dwd                   : BU02SMART02-iobroker                     -  enabled
          system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : BU02SMART02-iobroker                     - disabled
        + system.adapter.ems-esp.0                : ems-esp               : BU02SMART02-iobroker                     -  enabled
        + system.adapter.energiefluss.0           : energiefluss          : BU02SMART02-iobroker                     -  enabled
        + system.adapter.energiefluss.1           : energiefluss          : BU02SMART02-iobroker                     -  enabled
          system.adapter.feiertage.0              : feiertage             : BU02SMART02-iobroker                     -  enabled
          system.adapter.flot.0                   : flot                  : BU02SMART02-iobroker                     -  enabled
        + system.adapter.followthesun.0           : followthesun          : BU02SMART02-iobroker                     -  enabled
        + system.adapter.ford.0                   : ford                  : BU02SMART02-iobroker                     -  enabled
          system.adapter.hass-mqtt.0              : hass-mqtt             : BU02SMART02-iobroker                     -  enabled
        + system.adapter.history.0                : history               : BU02SMART02-iobroker                     -  enabled
        + system.adapter.homeconnect.0            : homeconnect           : BU02SMART02-iobroker                     -  enabled
          system.adapter.ical.0                   : ical                  : BU02SMART02-iobroker                     -  enabled
          system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: BU02SMART02-iobroker                     -  enabled
          system.adapter.icons-icons8.0           : icons-icons8          : BU02SMART02-iobroker                     -  enabled
          system.adapter.icons-material-png.0     : icons-material-png    : BU02SMART02-iobroker                     -  enabled
          system.adapter.icons-material-svg.0     : icons-material-svg    : BU02SMART02-iobroker                     -  enabled
          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : BU02SMART02-iobroker                     -  enabled
          system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: BU02SMART02-iobroker                     -  enabled
          system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : BU02SMART02-iobroker                     -  enabled
        + system.adapter.influxdb.0               : influxdb              : BU02SMART02-iobroker                     -  enabled, port: 8086
        + system.adapter.info.0                   : info                  : BU02SMART02-iobroker                     -  enabled
        + system.adapter.iot.0                    : iot                   : BU02SMART02-iobroker                     -  enabled
          system.adapter.iwg-vpn.0                : iwg-vpn               : BU02SMART02-iobroker                     - disabled
        + system.adapter.javascript.0             : javascript            : BU02SMART02-iobroker                     -  enabled
        + system.adapter.linkeddevices.0          : linkeddevices         : BU02SMART02-iobroker                     -  enabled
          system.adapter.material.0               : material              : BU02SMART02-iobroker                     -  enabled
        + system.adapter.mercedesme.0             : mercedesme            : BU02SMART02-iobroker                     -  enabled
          system.adapter.mqtt-client.0            : mqtt-client           : BU02SMART02-iobroker                     - disabled, port: 1892
        + system.adapter.mqtt.0                   : mqtt                  : BU02SMART02-iobroker                     -  enabled, port: 1886, bind: 0.0.0.0
        + system.adapter.mqtt.1                   : mqtt                  : BU02SMART02-iobroker                     -  enabled, port: 1891, bind: 192.168.2.166
        + system.adapter.net-tools.0              : net-tools             : BU02SMART02-iobroker                     -  enabled
          system.adapter.netatmo-crawler.0        : netatmo-crawler       : BU02SMART02-iobroker                     -  enabled
          system.adapter.openweathermap.0         : openweathermap        : BU02SMART02-iobroker                     -  enabled
          system.adapter.pi-hole.0                : pi-hole               : BU02SMART02-iobroker                     - disabled
        + system.adapter.ping.0                   : ping                  : BU02SMART02-iobroker                     -  enabled
        + system.adapter.pvforecast.0             : pvforecast            : BU02SMART02-iobroker                     -  enabled
        + system.adapter.ring.0                   : ring                  : BU02SMART02-iobroker                     -  enabled
        + system.adapter.samsung.0                : samsung               : BU02SMART02-iobroker                     -  enabled
        + system.adapter.shelly.0                 : shelly                : BU02SMART02-iobroker                     -  enabled, port: 1890, bind: 0.0.0.0
        + system.adapter.shelly.1                 : shelly                : BU02SMART02-iobroker                     -  enabled, port: 1890, bind: 192.168.2.166
          system.adapter.shuttercontrol.0         : shuttercontrol        : BU02SMART02-iobroker                     - disabled
        + system.adapter.slideshow.0              : slideshow             : BU02SMART02-iobroker                     -  enabled
        + system.adapter.smartthings.0            : smartthings           : BU02SMART02-iobroker                     -  enabled
          system.adapter.snmp.0                   : snmp                  : BU02SMART02-iobroker                     - disabled
          system.adapter.socketio.0               : socketio              : BU02SMART02-iobroker                     - disabled, port: 8084, bind: 192.168.2.166, run as: admin
        + system.adapter.sourceanalytix.0         : sourceanalytix        : BU02SMART02-iobroker                     -  enabled
        + system.adapter.telegram.0               : telegram              : BU02SMART02-iobroker                     -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.tuya.0                   : tuya                  : BU02SMART02-iobroker                     -  enabled
          system.adapter.tuya.1                   : tuya                  : BU02SMART02-iobroker                     - disabled
        + system.adapter.unifi.0                  : unifi                 : BU02SMART02-iobroker                     -  enabled
        + system.adapter.virtualpowermeter.0      : virtualpowermeter     : BU02SMART02-iobroker                     -  enabled
          system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : BU02SMART02-iobroker                     -  enabled
          system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : BU02SMART02-iobroker                     -  enabled
          system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: BU02SMART02-iobroker                     -  enabled
          system.adapter.vis-2.0                  : vis-2                 : BU02SMART02-iobroker                     - disabled
          system.adapter.vis-bars.0               : vis-bars              : BU02SMART02-iobroker                     -  enabled
          system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : BU02SMART02-iobroker                     -  enabled
          system.adapter.vis-colorpicker.0        : vis-colorpicker       : BU02SMART02-iobroker                     -  enabled
          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : BU02SMART02-iobroker                     -  enabled
          system.adapter.vis-history.0            : vis-history           : BU02SMART02-iobroker                     -  enabled
          system.adapter.vis-homekittiles.0       : vis-homekittiles      : BU02SMART02-iobroker                     -  enabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : BU02SMART02-iobroker                     -  enabled
          system.adapter.vis-icontwo.0            : vis-icontwo           : BU02SMART02-iobroker                     -  enabled
        + system.adapter.vis-inventwo.0           : vis-inventwo          : BU02SMART02-iobroker                     -  enabled
          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : BU02SMART02-iobroker                     -  enabled
          system.adapter.vis-justgage.0           : vis-justgage          : BU02SMART02-iobroker                     -  enabled
          system.adapter.vis-lcars.0              : vis-lcars             : BU02SMART02-iobroker                     -  enabled
          system.adapter.vis-material-advanced.0  : vis-material-advanced : BU02SMART02-iobroker                     -  enabled
          system.adapter.vis-material.0           : vis-material          : BU02SMART02-iobroker                     -  enabled
          system.adapter.vis-materialdesign.0     : vis-materialdesign    : BU02SMART02-iobroker                     -  enabled
          system.adapter.vis-plumb.0              : vis-plumb             : BU02SMART02-iobroker                     -  enabled
          system.adapter.vis-rgraph.0             : vis-rgraph            : BU02SMART02-iobroker                     -  enabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : BU02SMART02-iobroker                     -  enabled
          system.adapter.vis-weather.0            : vis-weather           : BU02SMART02-iobroker                     -  enabled
          system.adapter.vis.0                    : vis                   : BU02SMART02-iobroker                     -  enabled
        + system.adapter.web.0                    : web                   : BU02SMART02-iobroker                     -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          system.adapter.ws.0                     : ws                    : BU02SMART02-iobroker                     - disabled, port: 8087, bind: 192.168.2.166, run as: admin
        + system.adapter.yahka.0                  : yahka                 : BU02SMART02-iobroker                     -  enabled
          system.adapter.yahka.1                  : yahka                 : BU02SMART02-iobroker                     - disabled
        + system.adapter.zigbee.0                 : zigbee                : BU02SMART02-iobroker                     -  enabled, port: /dev/ttyUSB0
        + instance is alive
        ioBroker-Repositories
        │ (index) │ name               │ url                                                     │ auto upgrade │
        │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
        │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
        Upgrade policy: none
        Installed ioBroker-Instances
        Adapter    "admin"        : 7.0.22   , installed 6.17.14 [Updatable]
        Adapter    "alarm"        : 3.6.1    , installed 3.6.0  [Updatable]
        Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
        Adapter    "bosesoundtouch": 0.11.1  , installed 0.11.1
        Adapter    "daikin"       : 1.4.2    , installed 1.4.2
        Adapter    "device-reminder": 3.1.2  , installed 3.1.2
        Adapter    "device-watcher": 2.12.1  , installed 2.12.1
        Adapter    "discovery"    : 4.5.0    , installed 4.5.0
        Adapter    "ecovacs-deebot": 1.4.15  , installed 1.4.15
        Adapter    "ems-esp"      : 3.5.0    , installed 3.5.0
        Adapter    "energiefluss" : 3.6.0    , installed 3.6.0
        Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
        Adapter    "followthesun" : 0.5.0    , installed 0.5.0
        Adapter    "ford"         : 1.0.2    , installed 1.0.4
        Adapter    "homeconnect"  : 1.4.1    , installed 1.4.0  [Updatable]
        Adapter    "ical"         : 1.15.0   , installed 1.15.0
        Adapter    "iot"          : 3.3.0    , installed 3.3.0
        Adapter    "iwg-vpn"      : 3.0.0    , installed 3.0.0
        Adapter    "javascript"   : 8.7.6    , installed 8.3.1  [Updatable]
        Controller "js-controller": 6.0.9    , installed 6.0.9
        Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
        Adapter    "material"     : 1.3.1    , installed 1.3.1
        Adapter    "megaesp"      : 0.1.0    , installed 0.1.0
        Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
        Adapter    "mqtt-client"  : 2.0.0    , installed 1.8.0  [Updatable]
        Adapter    "net-tools"    : 1.0.11   , installed 1.0.11
        Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
        Adapter    "openweathermap": 1.0.4   , installed 1.0.4
        Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
        Adapter    "pvforecast"   : 3.0.0    , installed 2.9.1  [Updatable]
        Adapter    "ring"         : 5.1.0    , installed 5.0.10 [Updatable]
        Adapter    "samsung"      : 0.6.0    , installed 0.6.0
        Adapter    "shelly"       : 7.0.0    , installed 7.0.0
        Adapter    "shuttercontrol": 1.7.3   , installed 1.7.0  [Updatable]
        Adapter    "snmp"         : 3.2.0    , installed 3.2.0
        Adapter    "socketio"     : 6.7.0    , installed 6.7.0
        Adapter    "statistics"   : 2.4.0    , installed 2.4.0
        Adapter    "telegram"     : 3.3.2    , installed 3.3.2
        Adapter    "tuya"         : 3.15.0   , installed 3.15.0
        Adapter    "unifi"        : 0.7.0    , installed 0.7.0
        Adapter    "virtualpowermeter": 1.4.6, installed 1.4.6
        Adapter    "vis-2"        : 2.9.32   , installed 2.9.51
        Adapter    "vis-2-widgets-energy": 0.3.11, installed 0.3.11
        Adapter    "vis-2-widgets-gauges": 1.0.3, installed 1.0.3
        Adapter    "vis-2-widgets-material": 1.3.32, installed 1.3.32
        Adapter    "vis-homekittiles": 0.3.1 , installed 0.0.13 [Updatable]
        Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
        Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
        Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
        Adapter    "vis-material" : 0.1.3    , installed 0.1.3
        Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
        Adapter    "web"          : 6.2.5    , installed 6.2.5
        Adapter    "ws"           : 2.6.1    , installed 2.6.1
        Adapter    "yahka"        : 1.0.3    , installed 1.0.3
        Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
        Objects and States
        Objects:        187587
        States:         143163
        Hit:1 http://archive.ubuntu.com/ubuntu jammy InRelease
        Hit:2 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
        Hit:3 https://apt.grafana.com stable InRelease
        Hit:4 http://archive.ubuntu.com/ubuntu jammy-security InRelease
        Hit:5 https://repos.influxdata.com/debian stable InRelease
        Hit:6 https://deb.nodesource.com/node_20.x nodistro InRelease
        Hit:7 https://packagecloud.io/ookla/speedtest-cli/ubuntu jammy InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       882653     18458/iobroker.js-c
        tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1000       901411     18626/io.mqtt.0
        tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          255566     281/master
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          254112     1/systemd
        tcp        0      0 192.168.2.166:1890      0.0.0.0:*               LISTEN      1000       911405     18716/io.shelly.1
        tcp        0      0 192.168.2.166:1891      0.0.0.0:*               LISTEN      1000       900734     18643/io.mqtt.1
        tcp        0      0 0.0.0.0:43187           0.0.0.0:*               LISTEN      1000       907056     19010/io.yahka.0
        tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      106        253717     100/systemd-resolve
        tcp        0      0 127.0.0.1:6010          0.0.0.0:*               LISTEN      1001       500980     8227/sshd: mario@pt
        tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      113        254487     116/redis-server 12
        tcp6       0      0 ::1:25                  :::*                    LISTEN      0          255567     281/master
        tcp6       0      0 :::22                   :::*                    LISTEN      0          580349     1/systemd
        tcp6       0      0 :::111                  :::*                    LISTEN      0          254114     1/systemd
        tcp6       0      0 :::3000                 :::*                    LISTEN      112        581673     11836/grafana
        tcp6       0      0 ::1:6010                :::*                    LISTEN      1001       500979     8227/sshd: mario@pt
        tcp6       0      0 :::8082                 :::*                    LISTEN      1000       915640     19139/io.web.0
        tcp6       0      0 :::8081                 :::*                    LISTEN      1000       889125     18477/io.admin.0
        tcp6       0      0 ::1:6379                :::*                    LISTEN      113        254488     116/redis-server 12
        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       918452     18710/io.shelly.0
        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       917833     18681/io.tuya.0
        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       917834     18681/io.tuya.0
        udp        0      0 127.0.0.53:53           0.0.0.0:*                           106        253716     100/systemd-resolve
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          254113     1/systemd
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       907053     19010/io.yahka.0
        udp6       0      0 :::111                  :::*                                0          254115     1/systemd
        2024-08-03 18:49:59.641  - error: host.BU02SMART02-iobroker instance system.adapter.hass-mqtt.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2024-08-03 18:50:24.054  - error: unifi.0 (18695) Error site default (data): {"meta":{"rc":"error","msg":"api.err.LoginRequired"},"data":[]}
        2024-08-03 18:50:24.055  - error: unifi.0 (18695) [updateUnifiData site default] error: Request failed with status code 401, stack: AxiosError: Request failed with status code 401
            at settle (/opt/iobroker/node_modules/axios/lib/core/settle.js:19:12)
            at IncomingMessage.handleStreamEnd (/opt/iobroker/node_modules/axios/lib/adapters/http.js:585:11)
            at IncomingMessage.emit (node:events:531:35)
            at IncomingMessage.emit (node:domain:488:12)
            at endReadableNT (node:internal/streams/readable:1696:12)
            at processTicksAndRejections (node:internal/process/task_queues:82:21)
        2024-08-03 18:51:00.180  - warn: dwd.0 (22516) slow connection to objects DB. Still waiting ...
        2024-08-03 18:51:06.143  - warn: netatmo-crawler.0 (22533) slow connection to objects DB. Still waiting ...
        2024-08-03 18:51:06.972  - error: host.BU02SMART02-iobroker Caught by controller[0]: /opt/iobroker/node_modules/iobroker.hass-mqtt/build/main.js:18
        2024-08-03 18:51:06.975  - error: host.BU02SMART02-iobroker Caught by controller[0]: class HassMqtt extends utils.Adapter {
        2024-08-03 18:51:06.976  - error: host.BU02SMART02-iobroker Caught by controller[0]:                              ^
        2024-08-03 18:51:06.976  - error: host.BU02SMART02-iobroker Caught by controller[0]: TypeError: Class extends value #<Object> is not a constructor or null
        2024-08-03 18:51:06.976  - error: host.BU02SMART02-iobroker Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.hass-mqtt/build/main.js:18:30)
        2024-08-03 18:51:06.976  - error: host.BU02SMART02-iobroker Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1358:14)
        2024-08-03 18:51:06.976  - error: host.BU02SMART02-iobroker Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
        2024-08-03 18:51:06.976  - error: host.BU02SMART02-iobroker Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1208:32)
        2024-08-03 18:51:06.976  - error: host.BU02SMART02-iobroker Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1024:12)
        2024-08-03 18:51:06.976  - error: host.BU02SMART02-iobroker Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:174:12)
        2024-08-03 18:51:06.976  - error: host.BU02SMART02-iobroker Caught by controller[0]:     at node:internal/main/run_main_module:28:49
        2024-08-03 18:51:06.976  - error: host.BU02SMART02-iobroker Caught by controller[0]: Node.js v20.16.0
        2024-08-03 18:51:06.976  - error: host.BU02SMART02-iobroker instance system.adapter.hass-mqtt.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2024-08-03 18:51:34.454  - warn: zigbee.0 (18736) DeviceAvailability:Failed to ping 0x5c0272fffe6e55ea TRADFRI Signal Repeater
          heisst was genau??
          m.schalk
          schrieb am zuletzt editiert von m.schalk
          @homoran das Problem konnte ich fixen.
            @m-schalk
            Schau dir per
            iob diag
            m.schalk
            hier die Log Ausgabe:
            Zeit
            info
            Nachricht
            2024-08-03 18:55:16.662	error	instance system.adapter.hass-mqtt.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
            2024-08-03 18:55:16.662	error	Caught by controller[0]: Node.js v20.16.0
            2024-08-03 18:55:16.662	error	Caught by controller[0]: at node:internal/main/run_main_module:28:49
            2024-08-03 18:55:16.662	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:174:12)
            2024-08-03 18:55:16.662	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1024:12)
            2024-08-03 18:55:16.662	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1208:32)
            2024-08-03 18:55:16.662	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
            2024-08-03 18:55:16.661	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1358:14)
            2024-08-03 18:55:16.661	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.hass-mqtt/build/main.js:18:30)
            2024-08-03 18:55:16.661	error	Caught by controller[0]: TypeError: Class extends value #<Object> is not a constructor or null
            2024-08-03 18:55:16.661	error	Caught by controller[0]: ^
            2024-08-03 18:55:16.661	error	Caught by controller[0]: class HassMqtt extends utils.Adapter {
            2024-08-03 18:55:16.661	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.hass-mqtt/build/main.js:18
            • M m.schalk
              sicher?
              sieht nicht wirklich besser aus.
              schade, wäre höchst interessant
              • M m.schalk
                Zeit
                info
                Nachricht
                @m-schalk
                Roll da halt einen frischen Container rein.
                Dafür sind die Dinger doch da.
                  sicher?
                  m.schalk
                  @homoran said in Performance nach Systemcrash problematisch:
                  sicher?
                  @Homoran bis vor 120 min war alles ok, ich kann hat nicht sagen woher die hohe Last kommt
                  @Homoran keine Ahnung warum es nicht funktioniert
                    @m-schalk
                    m.schalk
                    @thomas-braun said in Performance nach Systemcrash problematisch:
                    @m-schalk
                    @Thomas-Braun
                    schade ich dachte ich kann was retten
                    • M m.schalk
                      @m-schalk
                      @Thomas-Braun
                      @m-schalk
                      Was willste denn retten? Du hast doch ein Backup für sowas.
                      Bist du eigentlich sicher, das nicht das Host-System einen Schaden hat?
