  4. Nach Node JS updat kein Login mehr
    1.0k
    6.1k
52 Beiträge 5 Kommentatoren 5.2k Aufrufe 4 Beobachtet
  • M mike-eg6
    @thomas-braun said in Nach Node JS updat kein Login mehr:
    iob diag
    Copy text starting here:
                            v.2024-05-22
       Static hostname: raspberrypi
             Icon name: computer
      Operating System: Raspbian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    Kernel:                 aarch64
    Userland:               32 bit
    Timezone:               Europe/Vienna (CEST, +0200)
    User-ID:                1000
    Display-Server:         false
    Pending OS-Updates:     0
    Pending iob updates:    20
    Nodejs-Installation:
    /usr/bin/nodejs         v22.4.1
    /usr/bin/node           v22.4.1
    /usr/bin/npm            10.8.1
    /usr/bin/npx            10.8.1
    /usr/bin/corepack       0.28.2
    Recommended versions are nodejs  and npm
    MEMORY:
    Mem:            7.8G         80M        7.2G        0.0K        490M        7.6G
    Swap:            99M          0B         99M
    Total:          7.9G         80M        7.3G
    Active iob-Instances:   1
    Active repo(s): stable
    ioBroker Core:          js-controller           5.0.19
                            admin                   6.2.22
    ioBroker Status:        iobroker is not running on this host.
    Objects type: jsonl
    States  type: jsonl
      system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    Objects:                2121
    States:                 1725
    Size of iob-Database:
    12M     /opt/iobroker/iobroker-data/objects.jsonl
    4.2M    /opt/iobroker/iobroker-data/objects.json.migrated
    4.2M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
    0       /opt/iobroker/iobroker-data/objects.json.broken
    1.7M    /opt/iobroker/iobroker-data/states.jsonl
    292K    /opt/iobroker/iobroker-data/states.json.bak.migrated
    288K    /opt/iobroker/iobroker-data/states.json.migrated
    0       /opt/iobroker/iobroker-data/states.json.broken
    === Mark text until here for copying ===
    pi@raspberrypi:/opt/iobroker $ pt/iobroker Static hostname: raspberrypi
    Icon name: computer
    Architecture: arm64
    Kernel: aarch64
    Userland: 32 bit
    User-ID: 1000
    Boot Target: graphical.target
    /usr/bin/npm 10.8.1
    /usr/bin/npx 10.8.1
    MEMORY:
    total used free shared buff/cache available
    Swap: 99M 0B 99M
    admin 6.2.22
    Objects type: jsonl
    States type: jsonl
    Objects: 2121
    States: 1725
    @mike-eg6 sagte in Nach Node JS updat kein Login mehr:
    Kernel: aarch64
    Userland: 32 bit
    Bei Gelegenheit mal komplett NEUINSTALLIEREN.
    Diesmal als reine 64Bit-Version.
    iob nodejs-update 20
    ausführen.
    • M mike-eg6
      iob diag
                              v.2024-05-22
               Icon name: computer
            Architecture: arm64
      Kernel:                 aarch64
      Userland:               32 bit
      User-ID:                1000
      /usr/bin/npm            10.8.1
      /usr/bin/npx            10.8.1
      MEMORY:
      Swap:            99M          0B         99M
                              admin                   6.2.22
      Objects type: jsonl
      States  type: jsonl
      Objects:                2121
      States:                 1725
      Icon name: computer
      Architecture: arm64
      Kernel: aarch64
      Userland: 32 bit
      User-ID: 1000
      /usr/bin/npm 10.8.1
      /usr/bin/npx 10.8.1
      MEMORY:
      Swap: 99M 0B 99M
      admin 6.2.22
      Objects type: jsonl
      States type: jsonl
      Objects: 2121
      States: 1725
      @mike-eg6
      Wenn nodejs@20 installiert ist, nochmal
      iob diag
      aber diesmal die Langfassung.
        @mike-eg6
        iob diag
        mike-eg6
        iob diag
        Skript v.2024-05-22
        *** BASE SYSTEM ***
                 Icon name: computer
              Architecture: arm64
        Model           : Raspberry Pi 4 Model B Rev 1.4
        Docker          : false
        Virtualization  : none
        Kernel          : aarch64
        Userland        : 32 bit
        Systemuptime and Load:
         20:56:11 up  1:32,  1 user,  load average: 0.21, 0.36, 1.20
        CPU threads: 4
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** Time and Time Zones ***
                       Local time: Sun 2024-07-14 20:56:11 CEST
                   Universal time: Sun 2024-07-14 18:56:11 UTC
                         RTC time: n/a
                        Time zone: Europe/Vienna (CEST, +0200)
                      NTP service: active
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        pi
        HOME=/home/pi
        GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
        iobroker
        HOME=/home/iobroker
        *** Display-Server-Setup ***
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:            7.8G        440M        6.5G        0.0K        875M        7.2G
        Swap:            99M          0B         99M
        Total:          7.9G        440M        6.6G
        Active iob-Instances:   9
                 7812 M total memory
                  440 M used memory
                  473 M active memory
                  669 M inactive memory
                 6496 M free memory
                  148 M buffer memory
                  726 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        top - 20:56:11 up  1:32,  1 user,  load average: 0.21, 0.36, 1.20
        Tasks: 164 total,   1 running, 163 sleeping,   0 stopped,   0 zombie
        %Cpu(s): 26.1 us,  4.3 sy,  0.0 ni, 68.1 id,  0.0 wa,  0.0 hi,  1.4 si,  0.0 st
        MiB Mem :   7812.3 total,   6495.4 free,    441.3 used,    875.6 buff/cache
        MiB Swap:    100.0 total,    100.0 free,      0.0 used.   7248.4 avail Mem
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** FILESYSTEM ***
        /dev/root      ext4       29G  4.5G   23G  17% /
        devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
        tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
        tmpfs          tmpfs     1.6G  840K  1.6G   1% /run
        /dev/mmcblk0p1 vfat      253M   51M  202M  20% /boot
        /dev/sda1      fuseblk   7.5G   24M  7.5G   1% /media/usbstick
        tmpfs          tmpfs     782M     0  782M   0% /run/user/1000
        [Sun Jul 14 19:23:34 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:D5:EA:5E vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=bd5a9205-02 rootfstype=ext4 fsck.repair=yes rootwait
        [Sun Jul 14 19:23:35 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
        [Sun Jul 14 19:23:35 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
        [Sun Jul 14 19:23:38 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
        Show mounted filesystems:
        TARGET                       SOURCE         FSTYPE     OPTIONS
        /                            /dev/mmcblk0p2 ext4       rw,noatime
        |-/dev                       devtmpfs       devtmpfs   rw,relatime,size=3735680k,nr_inodes=933920,mode=755
        | |-/dev/shm                 tmpfs          tmpfs      rw,nosuid,nodev
        | |-/dev/pts                 devpts         devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
        | `-/dev/mqueue              mqueue         mqueue     rw,nosuid,nodev,noexec,relatime
        |-/proc                      proc           proc       rw,relatime
        | `-/proc/sys/fs/binfmt_misc systemd-1      autofs     rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
        |-/sys                       sysfs          sysfs      rw,nosuid,nodev,noexec,relatime
        | |-/sys/kernel/security     securityfs     securityfs rw,nosuid,nodev,noexec,relatime
        | |-/sys/fs/cgroup           cgroup2        cgroup2    rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
        | |-/sys/fs/pstore           pstore         pstore     rw,nosuid,nodev,noexec,relatime
        | |-/sys/fs/bpf              bpf            bpf        rw,nosuid,nodev,noexec,relatime,mode=700
        | |-/sys/kernel/debug        debugfs        debugfs    rw,nosuid,nodev,noexec,relatime
        | |-/sys/kernel/tracing      tracefs        tracefs    rw,nosuid,nodev,noexec,relatime
        | |-/sys/kernel/config       configfs       configfs   rw,nosuid,nodev,noexec,relatime
        | `-/sys/fs/fuse/connections fusectl        fusectl    rw,nosuid,nodev,noexec,relatime
        |-/run                       tmpfs          tmpfs      rw,nosuid,nodev,size=1599964k,nr_inodes=819200,mode=755
        | |-/run/lock                tmpfs          tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k
        | |-/run/rpc_pipefs          sunrpc         rpc_pipefs rw,relatime
        | `-/run/user/1000           tmpfs          tmpfs      rw,nosuid,nodev,relatime,size=799980k,nr_inodes=199995,mode=700,uid=1000,gid=1000
        |-/boot                      /dev/mmcblk0p1 vfat       rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        `-/media/usbstick            /dev/sda1      fuseblk    rw,relatime,user_id=0,group_id=0,allow_other,blksize=4096
        /var:
        1.5G    /var/
        1.2G    /var/log/journal/ce513f1a44ff4c9dbd382eb66e08c51e
        1.2G    /var/log
        153M    /var/cache
        Archived and active journals take up 1.1G in the file system.
        /opt/iobroker/backups:
        39M     /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        213M    /opt/iobroker/iobroker-data/
        119M    /opt/iobroker/iobroker-data/files
        71M     /opt/iobroker/iobroker-data/backup-objects
        48M     /opt/iobroker/iobroker-data/files/javascript.admin
        32M     /opt/iobroker/iobroker-data/files/javascript.admin/static
        13M     /opt/iobroker/iobroker-data/objects.jsonl
        12M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js/790.1eb1f33b.chunk.js.map
        6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
        6.2M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/790.1eb1f33b.chunk.js
        4.6M    /opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescript/tsWorker.js
        USB-Devices by-id:
        /dev/serial/by-id/usb-1a86_USB2.0-Ser_-if00-port0
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v20.15.1
        /usr/bin/node           v20.15.1
        /usr/bin/npm            10.7.0
        /usr/bin/npx            10.7.0
        /usr/bin/corepack       0.28.1
        nodejs:
          Installed: 20.15.1-1nodesource1
          Candidate: 20.15.1-1nodesource1
          Version table:
         *** 20.15.1-1nodesource1 600
                500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
             20.15.0-1nodesource1 600
             20.14.0-1nodesource1 600
             20.13.1-1nodesource1 600
             20.13.0-1nodesource1 600
             20.12.2-1nodesource1 600
             20.12.1-1nodesource1 600
             20.12.0-1nodesource1 600
             20.11.1-1nodesource1 600
             20.11.0-1nodesource1 600
             20.10.0-1nodesource1 600
             20.9.0-1nodesource1 600
             20.8.1-1nodesource1 600
             20.8.0-1nodesource1 600
             20.7.0-1nodesource1 600
             20.6.1-1nodesource1 600
             20.6.0-1nodesource1 600
             20.5.1-1nodesource1 600
             20.5.0-1nodesource1 600
             20.4.0-1nodesource1 600
             20.3.1-1nodesource1 600
             20.3.0-1nodesource1 600
             20.2.0-1nodesource1 600
             20.1.0-1nodesource1 600
             20.0.0-1nodesource1 600
             12.22.12~dfsg-1~deb11u4 500
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:  5.0.19
        admin:          6.2.22
        javascript:     6.0.3
        nodejs modules from github:     0
        Adapter State
        + system.adapter.daikin.0                 : daikin                : raspberrypi                              -  enabled
          system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
          system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
        + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
        + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
        + system.adapter.hmip.0                   : hmip                  : raspberrypi                              -  enabled
          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
          system.adapter.vis-map.0                : vis-map               : raspberrypi                              - disabled
          system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              - disabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
          system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
        + system.adapter.wled.0                   : wled                  : raspberrypi                              -  enabled
        + system.adapter.yahka.0                  : yahka                 : raspberrypi                              -  enabled
        + instance is alive
        ioBroker-Repositories
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "admin"        : 6.17.14  , installed 6.2.22 [Updatable]
        Adapter    "backitup"     : 2.11.0   , installed 2.4.10 [Updatable]
        Adapter    "daikin"       : 1.4.2    , installed 1.4.2
        Adapter    "daswetter"    : 3.1.15   , installed 3.1.3  [Updatable]
        Adapter    "discovery"    : 4.5.0    , installed 3.0.5  [Updatable]
        Adapter    "hm-rega"      : 4.0.0    , installed 3.0.40 [Updatable]
        Adapter    "hm-rpc"       : 1.17.0   , installed 1.15.12 [Updatable]
        Adapter    "hmip"         : 1.23.3   , installed 1.18.0 [Updatable]
        Adapter    "icons-mfd-svg": 1.2.0    , installed 1.1.0  [Updatable]
        Adapter    "javascript"   : 8.3.1    , installed 6.0.3  [Updatable]
        Controller "js-controller": 5.0.19   , installed 5.0.19
        Adapter    "simple-api"   : 2.8.0    , installed 2.7.1  [Updatable]
        Adapter    "socketio"     : 6.7.0    , installed 4.2.0  [Updatable]
        Adapter    "vis"          : 1.5.6    , installed 1.4.15 [Updatable]
        Adapter    "vis-hqwidgets": 1.5.1    , installed 1.3.0  [Updatable]
        Adapter    "vis-map"      : 1.0.5    , installed 1.0.4  [Updatable]
        Adapter    "vis-material-advanced": 1.7.4, installed 1.7.2 [Updatable]
        Adapter    "weatherunderground": 3.7.0, installed 3.4.2 [Updatable]
        Adapter    "web"          : 6.2.5    , installed 4.3.0  [Updatable]
        Adapter    "wled"         : 0.7.2    , installed 0.6.7  [Updatable]
        Adapter    "ws"           : 2.6.1    , installed 1.3.0  [Updatable]
        Adapter    "yahka"        : 1.0.3    , installed 0.13.1 [Updatable]
        Objects and States
        Objects:        2121
        States:         1796
        Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
        Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:3 https://deb.nodesource.com/node_20.x nodistro InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       32622      4352/iobroker.js-co
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       32617      4352/iobroker.js-co
        tcp        0      0 127.0.0.1:39021         0.0.0.0:*               LISTEN      1001       35385      4730/io.yahka.0
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12213      540/sshd: /usr/sbin
        tcp6       0      0 :::38887                :::*                    LISTEN      1001       35194      4730/io.yahka.0
        tcp6       0      0 :::22                   :::*                    LISTEN      0          12215      540/sshd: /usr/sbin
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15378      669/dhcpcd
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       35195      4730/io.yahka.0
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       35957      4671/io.wled.0
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12144      401/avahi-daemon: r
        udp        0      0 0.0.0.0:34991           0.0.0.0:*                           108        12146      401/avahi-daemon: r
        udp6       0      0 :::5353                 :::*                                108        12145      401/avahi-daemon: r
        udp6       0      0 :::51278                :::*                                108        12147      401/avahi-daemon: r
        2024-07-14 20:55:39.030  - info: hm-rpc.0 (5519) Terminated (NO_ERROR): Without reason
        2024-07-14 20:55:39.657  - info: host.raspberrypi instance system.adapter.hm-rpc.0 terminated with code 0 (NO_ERROR)
        2024-07-14 20:55:39.658  - info: host.raspberrypi Restart adapter system.adapter.hm-rpc.0 because enabled
        2024-07-14 20:56:06.044  - error: hm-rega.0 (4410) CCU 10.0.0.3 unreachable
        2024-07-14 20:56:09.786  - info: host.raspberrypi instance system.adapter.hm-rpc.0 started with pid 5537
        2024-07-14 20:56:12.537  - info: hm-rpc.0 (5537) starting. Version 1.15.12 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v20.15.1, js-controller: 5.0.19
        2024-07-14 20:56:12.682  - info: hm-rpc.0 (5537) xmlrpc server is trying to listen on 10.0.0.10:2001
        2024-07-14 20:56:12.683  - info: hm-rpc.0 (5537) xmlrpc client is trying to connect to 10.0.0.3:2001/ with ["http://10.0.0.10:2001","raspberrypi:hm-rpc.0:055bf09dd9b483c029ffa58fca3d6c16"]
        2024-07-14 20:56:12.714  - error: hm-rpc.0 (5537) Init not possible, going to stop: connect ECONNREFUSED 10.0.0.3:2001
        2024-07-14 20:56:36.049  - error: hm-rega.0 (4410) CCU 10.0.0.3 unreachable
        2024-07-14 20:56:36.278  - info: daikin.0 (4409) Daikin Device initialized with Error :Cannot parse response: <html>
        <body>
        <h1>File is not found.</h1>
        please enter correct url.
        </body>
        </html>
        2024-07-14 20:56:36.278  - info: daikin.0 (4409) Retry init in 60 seconds
        2024-07-14 20:56:42.711  - error: hm-rpc.0 (5537) Init not possible, going to stop: connect ECONNREFUSED 10.0.0.3:2001
        2024-07-14 20:56:42.717  - info: hm-rpc.0 (5537) xmlrpc -> 10.0.0.3:2001/ init ["http://10.0.0.10:2001",""]
        2024-07-14 20:56:42.723  - error: hm-rpc.0 (5537) Cannot call init: [http://10.0.0.10:2001, ""] connect ECONNREFUSED 10.0.0.3:2001
        2024-07-14 20:56:42.729  - info: hm-rpc.0 (5537) terminating
        2024-07-14 20:56:42.730  - info: hm-rpc.0 (5537) Terminated (NO_ERROR): Without reason
        2024-07-14 20:56:43.288  - info: host.raspberrypi instance system.adapter.hm-rpc.0 terminated with code 0 (NO_ERROR)
        2024-07-14 20:56:43.289  - info: host.raspberrypi Restart adapter system.adapter.hm-rpc.0 because enabled
        iob diag has finished.
        Press any key for a summary
        die V20 ist oben danke schonmal für eure hilfe
        M HomoranH 2 Antworten Letzte Antwort
        • M mike-eg6
          iob diag
          Skript v.2024-05-22
          *** BASE SYSTEM ***
                   Icon name: computer
                Architecture: arm64
          Docker          : false
          Kernel          : aarch64
          Userland        : 32 bit
          CPU threads: 4
          Current issues:
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          pi
          HOME=/home/pi
          iobroker
          HOME=/home/iobroker
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Swap:            99M          0B         99M
                   7812 M total memory
                    440 M used memory
                    473 M active memory
                   6496 M free memory
                    148 M buffer memory
                    726 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          *** FILESYSTEM ***
          /var:
          1.5G    /var/
          1.2G    /var/log
          153M    /var/cache
          USB-Devices by-id:
          /usr/bin/npm            10.7.0
          /usr/bin/npx            10.7.0
          nodejs:
            Version table:
          Errors in npm tree:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin:          6.2.22
          javascript:     6.0.3
          Adapter State
          + instance is alive
          Objects and States
          Objects:        2121
          States:         1796
          Pending Updates: 0
          <body>
          </body>
          </html>
          mike-eg6
          aber login geht noch nicht
          • M mike-eg6
            iob diag
            Skript v.2024-05-22
            *** BASE SYSTEM ***
                     Icon name: computer
                  Architecture: arm64
            Docker          : false
            Kernel          : aarch64
            Userland        : 32 bit
            CPU threads: 4
            Current issues:
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            pi
            HOME=/home/pi
            iobroker
            HOME=/home/iobroker
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Swap:            99M          0B         99M
                     7812 M total memory
                      440 M used memory
                      473 M active memory
                     6496 M free memory
                      148 M buffer memory
                      726 M swap cache
                       99 M total swap
                        0 M used swap
                       99 M free swap
            *** FILESYSTEM ***
            /var:
            1.5G    /var/
            1.2G    /var/log
            153M    /var/cache
            USB-Devices by-id:
            /usr/bin/npm            10.7.0
            /usr/bin/npx            10.7.0
            nodejs:
              Version table:
            Errors in npm tree:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            admin:          6.2.22
            javascript:     6.0.3
            Adapter State
            + instance is alive
            Objects and States
            Objects:        2121
            States:         1796
            Pending Updates: 0
            <body>
            </body>
            </html>
            der läuft auch nicht
            versuch mal iob start admin.0
            • M mike-eg6
              @mike-eg6
              sudo systemctl set-default multi-user.target
              Dann ein
              iob start admin
              Und dann den ganzen Stau bei den updates auflösen...
              iob update
              iob upgrade all -y
                @mike-eg6
                Dann ein
                iob start admin
                iob update
                iob upgrade all -y
                mike-eg6
                @thomas-braun puhh gerettet
                1000 Dank jetzt läuft er wieder danke vielmals
                lg mike
                • M mike-eg6
                  lg mike
                  @mike-eg6
                  Hast du die Updates eingespielt? Sonst kippt dir das früher oder später wieder weg.
                    @mike-eg6
                    mike-eg6
                    ja hab ich gemacht dank dir
                    lg mike
                    • M mike-eg6
                      lg mike
                      mike-eg6
                      @mike-eg6 hab schon wieder ein problem jetzt komm ich schon wieder nicht rein das komische ist wenn ich den Befehl ausführe passiert nix
                      iob diag
                      lg mike
                      • M mike-eg6
                        iob diag
                        lg mike
                        @mike-eg6
                        systemctl status iobroker.service
                        sagt?
                        • M mike-eg6
                          Hallo , hab auf meinem Raspberry pi nach langer Zeit ein Update vom IO Broker gemacht und den Node JS von 14 auf 22 geupdatet und jetzt funktioniert der IO broker nichtmehr Bzw, wenn ich den IO Broker über das Webfenster aufrufen will mit der IP kommt immer ein Seiten _ Ladenfehler.
                          wenn ich über Putty den befehl Iobroker fix starte findet er auch keine fehler
                          was soll ich jetzt machen?
                          lg mike
                          ist vielleicht die Karte mittlerweile in die Knie gegangen?
                          • M mike-eg6
                            iob diag
                            lg mike
                            @mike-eg6
                            curl -L -o diag.sh https://iobroker.net/diag.sh && bash diag.sh
                            sagt?
                              @mike-eg6
                              sagt?
                              mike-eg6
                              pi@raspberrypi:~ $ systemctl status iobroker.service
                              ● iobroker.service - ioBroker Server
                                   Loaded: loaded (/lib/systemd/system/iobroker.service; enabled; vendor pres>
                                   Active: inactive (dead) (Result: exit-code) since Tue 2024-07-23 17:46:53 >
                                     Docs: http://iobroker.net
                                 Main PID: 5849 (code=exited, status=1/FAILURE)
                                      CPU: 2.279s
                              Jul 23 17:46:53 raspberrypi systemd[1]: Stopped ioBroker Server.
                              Jul 23 17:46:53 raspberrypi systemd[1]: iobroker.service: Consumed 2.279s CPU t>
                              ...skipping...
                                      CPU: 2.279s
                              ...skipping...
                                      CPU: 2.279s
                              ...skipping...
                                      CPU: 2.279s
                              ...skipping...
                                      CPU: 2.279s
                              set mark: ...skipping...
                                      CPU: 2.279s
                              ...skipping...
                                      CPU: 2.279s
                              ...skipping...
                                      CPU: 2.279s
                              Log file is already in use  (press RETURN)
                              • M mike-eg6
                                        CPU: 2.279s
                                ...skipping...
                                        CPU: 2.279s
                                ...skipping...
                                        CPU: 2.279s
                                ...skipping...
                                        CPU: 2.279s
                                ...skipping...
                                        CPU: 2.279s
                                        CPU: 2.279s
                                ...skipping...
                                        CPU: 2.279s
                                ...skipping...
                                        CPU: 2.279s
                                Da läuft halt nix.
                                sudo systemctl start iobroker.service
                                oder mal ordentlich neustarten.
                                  @mike-eg6
                                  sagt?
                                  mike-eg6
                                  pi@raspberrypi:~ $ curl -L -o diag.sh https://iobroker.net/diag.sh && bash diag.sh
                                    % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
        Dload  Upload   Total   Spent    Left  Speed
                                  100   169  100   169    0     0    366      0 --:--:-- --:--:-- --:--:--   366
                                   69 23302   69 16126    0     0  10859      0  0:00:02  0:00:01  0:00:01  174k
                                  curl: (23) Failure writing output to destination
                                  pi@raspberrypi:~ $
                                    Da läuft halt nix.
                                    mike-eg6
                                    der Befehl ändert nix
                                    • M mike-eg6
                                      @mike-eg6 dann nochmal die Frage
                                      @homoran sagte in Nach Node JS updat kein Login mehr:
                                        mcm1957M Online
                                        mcm1957M Online
                                        mcm1957
                                        Schau auch mal ob die Karte ev. nur rammelvoll ist.
                                        df
                                        Und ob sie lesbar / schreibbar ist.
                                        Support Repositoryverwaltung.
                                        LESEN - gute Forenbeitrage
                                        • M mike-eg6
                                          pi@raspberrypi:~ $
                                          Vermutlich ist das Dateisystem rappelvoll.
                                          df -h
                                          sagt?
