  4. Homekit Adapter lässt sich nicht installieren
    1.0k
    6.1k
20 Beiträge 4 Kommentatoren 2.0k Aufrufe 2 Beobachtet
  • M Maddog-1
    Skript v.2024-05-22
    *** BASE SYSTEM ***
       Static hostname: pIOBroker
             Icon name: computer-container
               Chassis: container
        Virtualization: lxc
      Operating System: Debian GNU/Linux 10 (buster)
                Kernel: Linux 6.8.8-3-pve
          Architecture: x86-64
    model name      : Intel(R) Celeron(R) N5095 @ 2.00GHz
    Docker          : false
    Virtualization  : lxc
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     13:20:54 up  1:16,  1 user,  load average: 0.42, 0.57, 0.39
    CPU threads: 2
    *** Time and Time Zones ***
                   Local time: Fri 2024-07-19 13:20:54 UTC
               Universal time: Fri 2024-07-19 13:20:54 UTC
                     RTC time: n/a
                    Time zone: Etc/UTC (UTC, +0000)
                  NTP service: inactive
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    manuel
    HOME=/home/manuel
    GROUPS=manuel sudo
    iobroker
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout audio video plugdev
    *** Display-Server-Setup ***
    Display-Server: false
    Desktop:
    Terminal:
    *** MEMORY ***
    Mem:           4.1G        1.5G        1.7G        8.0M        902M        2.6G
    Swap:          4.1G          0B        4.1G
    Total:         8.2G        1.5G        5.8G
    Active iob-Instances:   26
             4096 M total memory
             1524 M used memory
             1419 M active memory
              813 M inactive memory
             1668 M free memory
                0 M buffer memory
              902 M swap cache
             4096 M total swap
                0 M used swap
             4096 M free swap
    top - 13:20:55 up  1:16,  1 user,  load average: 0.42, 0.57, 0.39
    Tasks:  52 total,   1 running,  51 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  3.1 us,  3.1 sy,  0.0 ni, 93.8 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   4096.0 total,   1668.5 free,   1525.0 used,    902.5 buff/cache
    MiB Swap:   4096.0 total,   4096.0 free,      0.0 used.   2562.9 avail Mem
    *** FAILED SERVICES ***
      UNIT                          LOAD   ACTIVE SUB    DESCRIPTION
    * run-rpc_pipefs.mount          loaded failed failed RPC Pipe File System
    * sys-kernel-config.mount       loaded failed failed Kernel Configuration File System
    * systemd-journald-audit.socket loaded failed failed Journal Audit Socket
    3 loaded units listed. Pass --all to see loaded but inactive units, too.
    To show all installed unit files use 'systemctl list-unit-files'.
    *** FILESYSTEM ***
    Filesystem                       Type      Size  Used Avail Use% Mounted on
    /dev/mapper/pve-vm--101--disk--0 ext4       32G  5.1G   25G  18% /
    none                             tmpfs     492K  4.0K  488K   1% /dev
    udev                             devtmpfs  7.7G     0  7.7G   0% /dev/tty
    tmpfs                            tmpfs     7.8G     0  7.8G   0% /dev/shm
    tmpfs                            tmpfs     7.8G  8.1M  7.7G   1% /run
    tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
    dmesg: read kernel buffer failed: Operation not permitted
    Show mounted filesystems:
    TARGET                                SOURCE                           FSTYPE     OPTIONS
    /                                     /dev/mapper/pve-vm--101--disk--0 ext4       rw,relatime,stripe=16
    |-/run                                tmpfs                            tmpfs      rw,nosuid,nodev,mode=755,uid=100000,gid=100000,inode64
    | `-/run/lock                         tmpfs                            tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k,uid=100000,gid=100000,inode64
    |-/dev                                none                             tmpfs      rw,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
    | |-/dev/shm                          tmpfs                            tmpfs      rw,nosuid,nodev,uid=100000,gid=100000,inode64
    | |-/dev/mqueue                       mqueue                           mqueue     rw,relatime
    | |-/dev/ttyUSB0                      udev[/ttyUSB0]                   devtmpfs   rw,nosuid,relatime,size=8043388k,nr_inodes=2010847,mode=755,inode64
    | |-/dev/.lxc/proc                    proc                             proc       rw,relatime
    | |-/dev/.lxc/sys                     sys                              sysfs      rw,relatime
    | |-/dev/full                         udev[/full]                      devtmpfs   rw,nosuid,relatime,size=8043388k,nr_inodes=2010847,mode=755,inode64
    | |-/dev/null                         udev[/null]                      devtmpfs   rw,nosuid,relatime,size=8043388k,nr_inodes=2010847,mode=755,inode64
    | |-/dev/random                       udev[/random]                    devtmpfs   rw,nosuid,relatime,size=8043388k,nr_inodes=2010847,mode=755,inode64
    | |-/dev/tty                          udev[/tty]                       devtmpfs   rw,nosuid,relatime,size=8043388k,nr_inodes=2010847,mode=755,inode64
    | |-/dev/urandom                      udev[/urandom]                   devtmpfs   rw,nosuid,relatime,size=8043388k,nr_inodes=2010847,mode=755,inode64
    | |-/dev/zero                         udev[/zero]                      devtmpfs   rw,nosuid,relatime,size=8043388k,nr_inodes=2010847,mode=755,inode64
    | |-/dev/pts                          devpts                           devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
    | |-/dev/ptmx                         devpts[/ptmx]                    devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
    | |-/dev/console                      devpts[/0]                       devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
    | |-/dev/tty1                         devpts[/1]                       devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
    | `-/dev/tty2                         devpts[/2]                       devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
    |-/proc                               proc                             proc       rw,nosuid,nodev,noexec,relatime
    | |-/proc/sys                         proc[/sys]                       proc       ro,relatime
    | | |-/proc/sys/net                   proc[/sys/net]                   proc       rw,nosuid,nodev,noexec,relatime
    | | `-/proc/sys/kernel/random/boot_id none[/.lxc-boot-id]              tmpfs      ro,nosuid,nodev,noexec,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
    | |-/proc/sysrq-trigger               proc[/sysrq-trigger]             proc       ro,relatime
    | |-/proc/cpuinfo                     lxcfs[/proc/cpuinfo]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    | |-/proc/diskstats                   lxcfs[/proc/diskstats]           fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    | |-/proc/loadavg                     lxcfs[/proc/loadavg]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    | |-/proc/meminfo                     lxcfs[/proc/meminfo]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    | |-/proc/slabinfo                    lxcfs[/proc/slabinfo]            fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    | |-/proc/stat                        lxcfs[/proc/stat]                fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    | |-/proc/swaps                       lxcfs[/proc/swaps]               fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    | `-/proc/uptime                      lxcfs[/proc/uptime]              fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    `-/sys                                sysfs                            sysfs      ro,nosuid,nodev,noexec,relatime
      |-/sys/fs/fuse/connections          fusectl                          fusectl    rw,nosuid,nodev,noexec,relatime
      |-/sys/devices/virtual/net          sysfs[/devices/virtual/net]      sysfs      rw,nosuid,nodev,noexec,relatime
      |-/sys/fs/cgroup                    none                             cgroup2    rw,nosuid,nodev,noexec,relatime
      `-/sys/devices/system/cpu           lxcfs[/sys/devices/system/cpu]   fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    /var:
    419M    /var/
    235M    /var/cache
    231M    /var/cache/apt
    181M    /var/lib
    169M    /var/cache/apt/archives
          Users in the 'systemd-journal' group can see all messages. Pass -q to
          turn off this notice.
    No journal files were opened due to insufficient permissions.
    /opt/iobroker/backups:
    34M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    705M    /opt/iobroker/iobroker-data/
    568M    /opt/iobroker/iobroker-data/files
    149M    /opt/iobroker/iobroker-data/files/vis-2
    138M    /opt/iobroker/iobroker-data/files/javascript.admin
    118M    /opt/iobroker/iobroker-data/files/javascript.admin/static
    33M     /opt/iobroker/iobroker-data/files/meteoalarm.admin/geocodes.json
    27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
    24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
    24M     /opt/iobroker/iobroker-data/files/eventlist/static/js/main.bf7d9efc.js.map
    24M     /opt/iobroker/iobroker-data/files/eventlist.admin/static/js/main.bf7d9efc.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_22559e53cd9ded11af12dca5a7669f5d-if00-port0
    HINT:
    Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
    /dev/ttyUSB0
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.15.1
    /usr/bin/node           v20.15.1
    /usr/bin/npm            10.7.0
    /usr/bin/npx            10.7.0
    /usr/bin/corepack       0.28.1
    nodejs:
      Installed: 20.15.1-1nodesource1
      Candidate: 20.15.1-1nodesource1
      Version table:
     *** 20.15.1-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         10.24.0~dfsg-1~deb10u4 500
            500 http://security.debian.org buster/updates/main amd64 Packages
         10.24.0~dfsg-1~deb10u1 500
            500 http://ftp.debian.org/debian buster/main amd64 Packages
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.19
    admin:          6.17.14
    javascript:     8.3.1
    nodejs modules from github:     2
    +-- iobroker.gotify@0.2.0 (git+ssh://git@github.com/ThomasPohl/ioBroker.gotify.git#c20ff9a8867b6b452a30b947c005fd7b6f42b41d)
    | +-- syno@3.0.0 (git+ssh://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
    Adapter State
    + system.adapter.admin.0                  : admin                 : pIOBroker                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : pIOBroker                                -  enabled
    + system.adapter.backitup.0               : backitup              : pIOBroker                                -  enabled
      system.adapter.daswetter.0              : daswetter             : pIOBroker                                -  enabled
      system.adapter.discovery.0              : discovery             : pIOBroker                                - disabled
      system.adapter.dwd.0                    : dwd                   : pIOBroker                                -  enabled
    + system.adapter.eventlist.0              : eventlist             : pIOBroker                                -  enabled
    + system.adapter.firetv.0                 : firetv                : pIOBroker                                -  enabled
    + system.adapter.fritzbox.0               : fritzbox              : pIOBroker                                -  enabled
    + system.adapter.gotify.0                 : gotify                : pIOBroker                                -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : pIOBroker                                -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : pIOBroker                                -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : pIOBroker                                -  enabled, port: 0
      system.adapter.ical.0                   : ical                  : pIOBroker                                -  enabled
      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: pIOBroker                                -  enabled
      system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : pIOBroker                                -  enabled
      system.adapter.icons-icons8.0           : icons-icons8          : pIOBroker                                - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : pIOBroker                                - disabled
    + system.adapter.javascript.0             : javascript            : pIOBroker                                -  enabled
      system.adapter.meteoalarm.0             : meteoalarm            : pIOBroker                                -  enabled
    + system.adapter.node-red.0               : node-red              : pIOBroker                                -  enabled, port: 1880, bind: 0.0.0.0
    + system.adapter.pi-hole.0                : pi-hole               : pIOBroker                                -  enabled
    + system.adapter.ping.0                   : ping                  : pIOBroker                                -  enabled
    + system.adapter.proxmox.0                : proxmox               : pIOBroker                                -  enabled, port: 8006
    + system.adapter.signal-cmb.0             : signal-cmb            : pIOBroker                                -  enabled
    + system.adapter.synology.0               : synology              : pIOBroker                                -  enabled, port: 5000
    + system.adapter.synology.1               : synology              : pIOBroker                                -  enabled, port: 5000
    + system.adapter.tankerkoenig.0           : tankerkoenig          : pIOBroker                                -  enabled
    + system.adapter.telegram.0               : telegram              : pIOBroker                                -  enabled, port: 8443, bind: 0.0.0.0
      system.adapter.tr-064.0                 : tr-064                : pIOBroker                                - disabled
    + system.adapter.trashschedule.0          : trashschedule         : pIOBroker                                -  enabled
    + system.adapter.vis-2.0                  : vis-2                 : pIOBroker                                -  enabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : pIOBroker                                - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : pIOBroker                                -  enabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : pIOBroker                                -  enabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : pIOBroker                                - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : pIOBroker                                - disabled
      system.adapter.vis-weather.0            : vis-weather           : pIOBroker                                - disabled
      system.adapter.vis.0                    : vis                   : pIOBroker                                -  enabled
    + system.adapter.web.0                    : web                   : pIOBroker                                -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.zigbee.0                 : zigbee                : pIOBroker                                -  enabled, port: /dev/ttyUSB0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.17.14  , installed 6.17.14
    Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
    Adapter    "backitup"     : 2.11.0   , installed 2.11.0
    Adapter    "coronavirus-statistics": 0.9.0, installed 0.9.0
    Adapter    "daswetter"    : 3.1.15   , installed 3.1.15
    Adapter    "deconz"       : 1.4.1    , installed 1.4.1
    Adapter    "device-reminder": 3.1.2  , installed 3.1.2
    Adapter    "discovery"    : 4.5.0    , installed 4.5.0
    Adapter    "eventlist"    : 2.0.1    , installed 2.0.1
    Adapter    "firetv"       : 2.1.0    , installed 2.1.0
    Adapter    "fritzbox"     : 0.6.0    , installed 0.6.0
    Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
    Adapter    "hm-rpc"       : 1.17.0   , installed 1.17.0
    Adapter    "ical"         : 1.15.0   , installed 1.15.0
    Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
    Adapter    "javascript"   : 8.3.1    , installed 8.3.1
    Controller "js-controller": 5.0.19   , installed 5.0.19
    Adapter    "meteoalarm"   : 3.0.2    , installed 3.0.2
    Adapter    "node-red"     : 5.2.1    , installed 5.2.1
    Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
    Adapter    "proxmox"      : 2.3.0    , installed 2.3.0
    Adapter    "signal-cmb"   : 0.3.0    , installed 0.3.0
    Adapter    "socketio"     : 6.7.0    , installed 6.7.0
    Adapter    "synology"     : 3.1.0    , installed 3.1.0
    Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
    Adapter    "telegram"     : 3.3.2    , installed 3.3.2
    Adapter    "trashschedule": 3.3.0    , installed 3.3.0
    Adapter    "tuya"         : 3.15.0   , installed 3.15.0
    Adapter    "upnp"         : 1.0.21   , installed 1.0.21
    Adapter    "vis-2"        : 2.9.32   , installed 2.9.32
    Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
    Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
    Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
    Adapter    "web"          : 6.2.5    , installed 6.2.5
    Adapter    "ws"           : 2.6.1    , installed 2.6.1
    Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
    Adapter    "zigbee2mqtt"  : 2.13.6   , installed 2.13.6
    Objects and States
    Objects:        8340
    States:         7148
    Hit:1 http://security.debian.org buster/updates InRelease
    Hit:2 http://ftp.debian.org/debian buster InRelease
    Hit:3 http://ftp.debian.org/debian buster-updates InRelease
    Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      105        351606     93/systemd-resolved
    tcp        0      0 192.168.1.126:2010      0.0.0.0:*               LISTEN      1000       398547     5104/io.hm-rpc.1
    tcp        0      0 192.168.1.126:2001      0.0.0.0:*               LISTEN      1000       398483     5089/io.hm-rpc.0
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          351918     279/master
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       396467     4898/iobroker.js-co
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       394973     4898/iobroker.js-co
    tcp        0      0 0.0.0.0:5355            0.0.0.0:*               LISTEN      105        351600     93/systemd-resolved
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          345978     1/init
    tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1000       396717     4973/node-red
    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       396593     4916/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1000       401823     5307/io.web.0
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          351919     279/master
    tcp6       0      0 :::5355                 :::*                    LISTEN      105        351603     93/systemd-resolved
    tcp6       0      0 :::22                   :::*                    LISTEN      0          350584     1/init
    tcp6       0      0 :::111                  :::*                    LISTEN      0          345980     1/init
    tcp6       0      0 :::80                   :::*                    LISTEN      1000       396720     4973/node-red
    udp        0      0 0.0.0.0:5355            0.0.0.0:*                           105        351599     93/systemd-resolved
    udp        0      0 127.0.0.53:53           0.0.0.0:*                           105        351605     93/systemd-resolved
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          345979     1/init
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       396721     4973/node-red
    udp6       0      0 :::5355                 :::*                                105        351602     93/systemd-resolved
    udp6       0      0 :::111                  :::*                                0          345981     1/init
    2024-07-19 13:13:05.365  - info: fritzbox.0 (5059) data from 192.168.1.1: 19.07.24 15:13:05;CALL;1;11;913872;6929;SIP1;
    2024-07-19 13:13:09.324  - info: fritzbox.0 (5059) data from 192.168.1.1: 19.07.24 15:13:09;CONNECT;1;11;6929;
    2024-07-19 13:15:00.021  - info: host.pIOBroker instance system.adapter.dwd.0 started with pid 8529
    2024-07-19 13:15:01.020  - info: dwd.0 (8529) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.15.1, js-controller: 5.0.19
    2024-07-19 13:15:02.450  - info: dwd.0 (8529) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2024-07-19 13:15:02.964  - info: host.pIOBroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2024-07-19 13:15:04.067  - info: host.pIOBroker instance system.adapter.daswetter.0 started with pid 8547
    2024-07-19 13:15:04.888  - info: daswetter.0 (8547) starting. Version 3.1.15 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.15.1, js-controller: 5.0.19
    2024-07-19 13:15:07.049  - info: daswetter.0 (8547) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
    2024-07-19 13:15:07.556  - info: daswetter.0 (8547) cleaned everything up...
    2024-07-19 13:15:07.565  - info: host.pIOBroker instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2024-07-19 13:16:42.242  - info: fritzbox.0 (5059) data from 192.168.1.1: 19.07.24 15:16:42;DISCONNECT;1;213;
    2024-07-19 13:20:00.012  - info: host.pIOBroker instance system.adapter.dwd.0 started with pid 8675
    2024-07-19 13:20:00.885  - info: dwd.0 (8675) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.15.1, js-controller: 5.0.19
    2024-07-19 13:20:02.041  - info: dwd.0 (8675) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2024-07-19 13:20:02.556  - info: host.pIOBroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2024-07-19 13:20:04.027  - info: host.pIOBroker instance system.adapter.meteoalarm.0 started with pid 8693
    2024-07-19 13:20:05.927  - info: meteoalarm.0 (8693) starting. Version 3.0.2 in /opt/iobroker/node_modules/iobroker.meteoalarm, node: v20.15.1, js-controller: 5.0.19
    2024-07-19 13:20:07.845  - info: meteoalarm.0 (8693) 15.1: Updated Weather Alarms for Kreis Kronach -> 0 alarm(s) found
    2024-07-19 13:20:07.845  - info: meteoalarm.0 (8693) Terminated (ADAPTER_REQUESTED_TERMINATION): All data processed. Adapter stopped until next scheduled process.
    2024-07-19 13:20:08.376  - info: host.pIOBroker instance system.adapter.meteoalarm.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    @maddog-1 sagte in Homekit Adapter lässt sich nicht installieren:
    also doch.
    dann frag ich mich auch wo da nodejs v20 herkommt
    Pending Updates: 0
    aber nur, weil keine mehr angeboten werden
      also doch.
      Pending Updates: 0
      Maddog-1
      hatte vorhin das iob Nodejs-Update gemacht, ich war der aus dem anderen Beitrag mit dem Problem das ich als Root user das Update nicht machen konnte
      • M Maddog-1
        @maddog-1 aber wie auch @Thomas-Braun schrieb sollte es für Buster gar nicht mehr gebaut werden.
        • M Maddog-1
          Skript v.2024-05-22
          *** BASE SYSTEM ***
                     Chassis: container
              Virtualization: lxc
          Docker          : false
          Kernel          : x86_64
          Userland        : 64 bit
          CPU threads: 2
                           RTC time: n/a
                    RTC in local TZ: no
          manuel
          HOME=/home/manuel
          GROUPS=manuel sudo
          iobroker
          HOME=/home/iobroker
          Desktop:
          Terminal:
          *** MEMORY ***
          Swap:          4.1G          0B        4.1G
                   4096 M total memory
                   1524 M used memory
                   1668 M free memory
                      0 M buffer memory
                    902 M swap cache
                   4096 M total swap
                      0 M used swap
                   4096 M free swap
          *** FILESYSTEM ***
          /var:
          419M    /var/
          235M    /var/cache
          231M    /var/cache/apt
          181M    /var/lib
          USB-Devices by-id:
          HINT:
          /dev/ttyUSB0
          /usr/bin/npm            10.7.0
          /usr/bin/npx            10.7.0
          nodejs:
            Version table:
          Errors in npm tree:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin:          6.17.14
          javascript:     8.3.1
          Adapter State
          + instance is alive
          Objects and States
          Objects:        8340
          States:         7148
          Pending Updates: 0
          @maddog-1
          Deine Systemzeit ist falsch.
          Setz das auf die richtige Zeitzone.
          Der user 'manuel' fehlt in der Gruppe 'iobroker' (und ggfls. noch weiteren).
          Boot Target: graphical.target
          Sollte auf multi-user.target gesetzt werden.
          @Homoran
          Gut möglich, dass nur ein Raspberry 'Buster' davon betroffen ist. Die waren damals auch noch weiter von der Debian-Basis weg als heute.
          Aber nichts destotrotz ist Buster einfach 'end-of-life' und muss durch ein noch lebendes Release ersetzt werden.
            Maddog-1
            da bin ich überfragt, hatte nur den Befehl ausgeführt
            iob nodejs-update
            • M Maddog-1
              iob nodejs-update
              Das geht im Moment noch, in einer kommenden Version wird das auf keinem Buster-basierendem System mehr möglich sein.
                @maddog-1
                @Homoran
                Maddog-1
                gibt es da noch einen anderen befehl für die Zeitzone?
                dpkg-reconfigure tzdata
                der den ich gerade über google gefunden habe funktioniert nicht
                das mit dem user in den gruppen und multi user Target muss ich auch erstmal googeln, da hab ich keinen plan hab vorhin nur nach deinem anderen Beitrag den User angelegt
                • M Maddog-1
                  Maddog-1
                  ok das mit der Zeitzone hat sich erledigt, hatte das Sudo vergessen, bin ja jetzt kein root mehr
                  • M Maddog-1
                    @maddog-1
                    Zeitzone
                    sudo timedatectl set-timezone Europe/Berlin
                    Über tzdata geht's aber auch.
                    User Gruppen:
                    sudo usermod -aG adm,dialout,sudo,audio,video,plugdev,users,iobroker DEIN_USERNAME
                    exit
                    Boot Target:
                    sudo systemctl set-default multi-user.target
                      @maddog-1
                      Zeitzone
                      User Gruppen:
                      exit
                      Boot Target:
                      Maddog-1
                      @thomas-braun said in Homekit Adapter lässt sich nicht installieren:
                      super, Dankeschön, hat alles funktioniert
                      zum thema Update,
                      kann man das 1 zu 1 von hier übernehmen
                      https://forum.iobroker.net/topic/47213/upgrade-von-debian-10-buster-auf-11-bullseye
                      oder gibts ne andere vorgehensweise für nen Proxmox container
                      oder eben ganz neu aufsetzten
                      • M Maddog-1
                        zum thema Update,
                        @maddog-1
                        Container sind Wegwerfartikel. Das ist wohl am einfachsten und schnellsten, da einen aktuellen Container drüberzustülpen als zwei Dist-Upgrades zu fahren, bis du dann auf Debian 12 Bookworm bist.
                          @maddog-1
                          Maddog-1
                          ok dann werde ich mich mal wenn ich frei hab dran setzen
                          Danke für die Hilfe
