  4. Homekit Adapter lässt sich nicht installieren
    1.0k
    6.1k
20 Beiträge 4 Kommentatoren 2.0k Aufrufe 2 Beobachtet
  • M Maddog-1
    • Adaptername: Homekit-Controller
    • Link zu Adapterrepository: www.github.com...
    • Adapterversion: 0.5.10
    • js-controller Version: 5.0.19
    • Admin Version: 6.17.14
    • Hardwaresystem: Beelink
    • Arbeitsspeicher: 4GB
    • Festplattenart: SSD,
    • Betriebssystem: Debian Buster auf einem (Proxmox LXC)
    • Nodejs-Version: v20.15.1
    • NPM-Version: 10.7.0
    Probleme bei der Installation des Homekit adapters
    $ iobroker add homekit-controller --host pIOBroker
    NPM version: 10.7.0
    Installing iobroker.homekit-controller@0.5.10... (System call)
    npm error code 1npm error path /opt/iobroker/node_modules/@abandonware/noblenpm error command failednpm error command sh -c node-gyp-buildnpm error Traceback (most recent call last):npm error File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 42, in <module>npm error import gyp # noqa: E402npm error File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 9, in <module>npm error import gyp.inputnpm error File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 8, in <module>npm error import gyp.commonnpm error File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/common.py", line 435npm error if CC := os.environ.get("CC_target") or os.environ.get("CC"):npm error ^npm error SyntaxError: invalid syntaxnpm error gyp ERR! configure error npm error gyp ERR! stack Error: `gyp` failed with exit code: 1npm error gyp ERR! stack at ChildProcess.<anonymous> (/opt/iobroker/node_modules/node-gyp/lib/configure.js:317:18)npm error gyp ERR! stack at ChildProcess.emit (node:events:519:28)npm error gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:294:12)npm error gyp ERR! System Linux 6.8.8-3-pvenpm error gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"npm error gyp ERR! cwd /opt/iobroker/node_modules/@abandonware/noblenpm error gyp ERR! node -v v20.15.1npm error gyp ERR! node-gyp -v v10.2.0npm error gyp ERR! not oknpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-07-19T12_44_36_102Z-debug-0.log
    host.pIOBroker Cannot install iobroker.homekit-controller@0.5.10: 1
    ERROR: Process exited with code 25
    werde nicht so richtig schlau aus der meldung
    Ro75R Offline
    Ro75R Offline
    Ro75
    @maddog-1 sagte in Homekit Adapter lässt sich nicht installieren:
    Debian Buster
    zu alt.
    Ro75.
    • M Maddog-1
      NPM version: 10.7.0
      ich denke mal, dass das vollkommen veraltete Betriebssystem da auch mitspielt
        Maddog-1
        oh ok, gut dann hat sich das erledigt, dann muss ich mal schauen wie ich den Aqara M3 hub ans laufen bekomme
        • M Maddog-1
          Ein aktuelles Betriebssystem wäre schon mal eine gute Ausgangsbasis...
          Zu noble auch mal hier schauen:
          https://github.com/noble/noble#readme
          Das baut etwas 'zickig'.
            Maddog-1
            gut dazu müsste ich dann wahrscheinlich komplett neu aufsetzen
            das muss dann warten bis ich mal viel Zeit habe
            oder lässt sich das auch anders Updaten?
            noble schau ich mir mal an
            • M Maddog-1
              @maddog-1
              Container ist doch kein Ding...
              Wobei ich eh nicht überzeugt bin, dass du da wirklich ein Buster laufen hast, denn eigentlich läuft da ein nodejs@20 nicht mehr drauf.
              Was haste denn da wirklich am Start?
              iob diag
              sagt dir das.
                Maddog-1
                Skript v.2024-05-22
                *** BASE SYSTEM ***
                   Static hostname: pIOBroker
                         Icon name: computer-container
                           Chassis: container
                    Virtualization: lxc
                  Operating System: Debian GNU/Linux 10 (buster)
                            Kernel: Linux 6.8.8-3-pve
                      Architecture: x86-64
                model name      : Intel(R) Celeron(R) N5095 @ 2.00GHz
                Docker          : false
                Virtualization  : lxc
                Kernel          : x86_64
                Userland        : 64 bit
                Systemuptime and Load:
                 13:20:54 up  1:16,  1 user,  load average: 0.42, 0.57, 0.39
                CPU threads: 2
                *** Time and Time Zones ***
                               Local time: Fri 2024-07-19 13:20:54 UTC
                           Universal time: Fri 2024-07-19 13:20:54 UTC
                                 RTC time: n/a
                                Time zone: Etc/UTC (UTC, +0000)
                              NTP service: inactive
                          RTC in local TZ: no
                *** Users and Groups ***
                User that called 'iob diag':
                manuel
                HOME=/home/manuel
                GROUPS=manuel sudo
                iobroker
                HOME=/home/iobroker
                GROUPS=iobroker tty dialout audio video plugdev
                *** Display-Server-Setup ***
                Display-Server: false
                Desktop:
                Terminal:
                *** MEMORY ***
                Mem:           4.1G        1.5G        1.7G        8.0M        902M        2.6G
                Swap:          4.1G          0B        4.1G
                Total:         8.2G        1.5G        5.8G
                Active iob-Instances:   26
                         4096 M total memory
                         1524 M used memory
                         1419 M active memory
                          813 M inactive memory
                         1668 M free memory
                            0 M buffer memory
                          902 M swap cache
                         4096 M total swap
                            0 M used swap
                         4096 M free swap
                top - 13:20:55 up  1:16,  1 user,  load average: 0.42, 0.57, 0.39
                Tasks:  52 total,   1 running,  51 sleeping,   0 stopped,   0 zombie
                %Cpu(s):  3.1 us,  3.1 sy,  0.0 ni, 93.8 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                MiB Mem :   4096.0 total,   1668.5 free,   1525.0 used,    902.5 buff/cache
                MiB Swap:   4096.0 total,   4096.0 free,      0.0 used.   2562.9 avail Mem
                *** FAILED SERVICES ***
                  UNIT                          LOAD   ACTIVE SUB    DESCRIPTION
                * run-rpc_pipefs.mount          loaded failed failed RPC Pipe File System
                * sys-kernel-config.mount       loaded failed failed Kernel Configuration File System
                * systemd-journald-audit.socket loaded failed failed Journal Audit Socket
                3 loaded units listed. Pass --all to see loaded but inactive units, too.
                To show all installed unit files use 'systemctl list-unit-files'.
                *** FILESYSTEM ***
                Filesystem                       Type      Size  Used Avail Use% Mounted on
                /dev/mapper/pve-vm--101--disk--0 ext4       32G  5.1G   25G  18% /
                none                             tmpfs     492K  4.0K  488K   1% /dev
                udev                             devtmpfs  7.7G     0  7.7G   0% /dev/tty
                tmpfs                            tmpfs     7.8G     0  7.8G   0% /dev/shm
                tmpfs                            tmpfs     7.8G  8.1M  7.7G   1% /run
                tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
                dmesg: read kernel buffer failed: Operation not permitted
                Show mounted filesystems:
                TARGET                                SOURCE                           FSTYPE     OPTIONS
                /                                     /dev/mapper/pve-vm--101--disk--0 ext4       rw,relatime,stripe=16
                |-/run                                tmpfs                            tmpfs      rw,nosuid,nodev,mode=755,uid=100000,gid=100000,inode64
                | `-/run/lock                         tmpfs                            tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k,uid=100000,gid=100000,inode64
                |-/dev                                none                             tmpfs      rw,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
                | |-/dev/shm                          tmpfs                            tmpfs      rw,nosuid,nodev,uid=100000,gid=100000,inode64
                | |-/dev/mqueue                       mqueue                           mqueue     rw,relatime
                | |-/dev/ttyUSB0                      udev[/ttyUSB0]                   devtmpfs   rw,nosuid,relatime,size=8043388k,nr_inodes=2010847,mode=755,inode64
                | |-/dev/.lxc/proc                    proc                             proc       rw,relatime
                | |-/dev/.lxc/sys                     sys                              sysfs      rw,relatime
                | |-/dev/full                         udev[/full]                      devtmpfs   rw,nosuid,relatime,size=8043388k,nr_inodes=2010847,mode=755,inode64
                | |-/dev/null                         udev[/null]                      devtmpfs   rw,nosuid,relatime,size=8043388k,nr_inodes=2010847,mode=755,inode64
                | |-/dev/random                       udev[/random]                    devtmpfs   rw,nosuid,relatime,size=8043388k,nr_inodes=2010847,mode=755,inode64
                | |-/dev/tty                          udev[/tty]                       devtmpfs   rw,nosuid,relatime,size=8043388k,nr_inodes=2010847,mode=755,inode64
                | |-/dev/urandom                      udev[/urandom]                   devtmpfs   rw,nosuid,relatime,size=8043388k,nr_inodes=2010847,mode=755,inode64
                | |-/dev/zero                         udev[/zero]                      devtmpfs   rw,nosuid,relatime,size=8043388k,nr_inodes=2010847,mode=755,inode64
                | |-/dev/pts                          devpts                           devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
                | |-/dev/ptmx                         devpts[/ptmx]                    devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
                | |-/dev/console                      devpts[/0]                       devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
                | |-/dev/tty1                         devpts[/1]                       devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
                | `-/dev/tty2                         devpts[/2]                       devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
                |-/proc                               proc                             proc       rw,nosuid,nodev,noexec,relatime
                | |-/proc/sys                         proc[/sys]                       proc       ro,relatime
                | | |-/proc/sys/net                   proc[/sys/net]                   proc       rw,nosuid,nodev,noexec,relatime
                | | `-/proc/sys/kernel/random/boot_id none[/.lxc-boot-id]              tmpfs      ro,nosuid,nodev,noexec,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
                | |-/proc/sysrq-trigger               proc[/sysrq-trigger]             proc       ro,relatime
                | |-/proc/cpuinfo                     lxcfs[/proc/cpuinfo]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                | |-/proc/diskstats                   lxcfs[/proc/diskstats]           fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                | |-/proc/loadavg                     lxcfs[/proc/loadavg]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                | |-/proc/meminfo                     lxcfs[/proc/meminfo]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                | |-/proc/slabinfo                    lxcfs[/proc/slabinfo]            fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                | |-/proc/stat                        lxcfs[/proc/stat]                fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                | |-/proc/swaps                       lxcfs[/proc/swaps]               fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                | `-/proc/uptime                      lxcfs[/proc/uptime]              fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                `-/sys                                sysfs                            sysfs      ro,nosuid,nodev,noexec,relatime
                  |-/sys/fs/fuse/connections          fusectl                          fusectl    rw,nosuid,nodev,noexec,relatime
                  |-/sys/devices/virtual/net          sysfs[/devices/virtual/net]      sysfs      rw,nosuid,nodev,noexec,relatime
                  |-/sys/fs/cgroup                    none                             cgroup2    rw,nosuid,nodev,noexec,relatime
                  `-/sys/devices/system/cpu           lxcfs[/sys/devices/system/cpu]   fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                /var:
                419M    /var/
                235M    /var/cache
                231M    /var/cache/apt
                181M    /var/lib
                169M    /var/cache/apt/archives
                      Users in the 'systemd-journal' group can see all messages. Pass -q to
                      turn off this notice.
                No journal files were opened due to insufficient permissions.
                /opt/iobroker/backups:
                34M     /opt/iobroker/backups/
                /opt/iobroker/iobroker-data:
                705M    /opt/iobroker/iobroker-data/
                568M    /opt/iobroker/iobroker-data/files
                149M    /opt/iobroker/iobroker-data/files/vis-2
                138M    /opt/iobroker/iobroker-data/files/javascript.admin
                118M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                33M     /opt/iobroker/iobroker-data/files/meteoalarm.admin/geocodes.json
                27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
                24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                24M     /opt/iobroker/iobroker-data/files/eventlist/static/js/main.bf7d9efc.js.map
                24M     /opt/iobroker/iobroker-data/files/eventlist.admin/static/js/main.bf7d9efc.js.map
                USB-Devices by-id:
                /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_22559e53cd9ded11af12dca5a7669f5d-if00-port0
                HINT:
                Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
                /dev/ttyUSB0
                *** NodeJS-Installation ***
                /usr/bin/nodejs         v20.15.1
                /usr/bin/node           v20.15.1
                /usr/bin/npm            10.7.0
                /usr/bin/npx            10.7.0
                /usr/bin/corepack       0.28.1
                nodejs:
                  Installed: 20.15.1-1nodesource1
                  Candidate: 20.15.1-1nodesource1
                  Version table:
                 *** 20.15.1-1nodesource1 1001
                        500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                     20.15.0-1nodesource1 1001
                     20.14.0-1nodesource1 1001
                     20.13.1-1nodesource1 1001
                     20.13.0-1nodesource1 1001
                     20.12.2-1nodesource1 1001
                     20.12.1-1nodesource1 1001
                     20.12.0-1nodesource1 1001
                     20.11.1-1nodesource1 1001
                     20.11.0-1nodesource1 1001
                     20.10.0-1nodesource1 1001
                     20.9.0-1nodesource1 1001
                     20.8.1-1nodesource1 1001
                     20.8.0-1nodesource1 1001
                     20.7.0-1nodesource1 1001
                     20.6.1-1nodesource1 1001
                     20.6.0-1nodesource1 1001
                     20.5.1-1nodesource1 1001
                     20.5.0-1nodesource1 1001
                     20.4.0-1nodesource1 1001
                     20.3.1-1nodesource1 1001
                     20.3.0-1nodesource1 1001
                     20.2.0-1nodesource1 1001
                     20.1.0-1nodesource1 1001
                     20.0.0-1nodesource1 1001
                     10.24.0~dfsg-1~deb10u4 500
                        500 http://security.debian.org buster/updates/main amd64 Packages
                     10.24.0~dfsg-1~deb10u1 500
                        500 http://ftp.debian.org/debian buster/main amd64 Packages
                No problems detected
                Errors in npm tree:
                *** ioBroker-Installation ***
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                Core adapters versions
                js-controller:  5.0.19
                admin:          6.17.14
                javascript:     8.3.1
                nodejs modules from github:     2
                +-- iobroker.gotify@0.2.0 (git+ssh://git@github.com/ThomasPohl/ioBroker.gotify.git#c20ff9a8867b6b452a30b947c005fd7b6f42b41d)
                | +-- syno@3.0.0 (git+ssh://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
                Adapter State
                + system.adapter.admin.0                  : admin                 : pIOBroker                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                + system.adapter.alexa2.0                 : alexa2                : pIOBroker                                -  enabled
                + system.adapter.backitup.0               : backitup              : pIOBroker                                -  enabled
                  system.adapter.daswetter.0              : daswetter             : pIOBroker                                -  enabled
                  system.adapter.discovery.0              : discovery             : pIOBroker                                - disabled
                  system.adapter.dwd.0                    : dwd                   : pIOBroker                                -  enabled
                + system.adapter.eventlist.0              : eventlist             : pIOBroker                                -  enabled
                + system.adapter.firetv.0                 : firetv                : pIOBroker                                -  enabled
                + system.adapter.fritzbox.0               : fritzbox              : pIOBroker                                -  enabled
                + system.adapter.gotify.0                 : gotify                : pIOBroker                                -  enabled
                + system.adapter.hm-rega.0                : hm-rega               : pIOBroker                                -  enabled
                + system.adapter.hm-rpc.0                 : hm-rpc                : pIOBroker                                -  enabled, port: 0
                + system.adapter.hm-rpc.1                 : hm-rpc                : pIOBroker                                -  enabled, port: 0
                  system.adapter.ical.0                   : ical                  : pIOBroker                                -  enabled
                  system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: pIOBroker                                -  enabled
                  system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : pIOBroker                                -  enabled
                  system.adapter.icons-icons8.0           : icons-icons8          : pIOBroker                                - disabled
                  system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : pIOBroker                                - disabled
                + system.adapter.javascript.0             : javascript            : pIOBroker                                -  enabled
                  system.adapter.meteoalarm.0             : meteoalarm            : pIOBroker                                -  enabled
                + system.adapter.node-red.0               : node-red              : pIOBroker                                -  enabled, port: 1880, bind: 0.0.0.0
                + system.adapter.pi-hole.0                : pi-hole               : pIOBroker                                -  enabled
                + system.adapter.ping.0                   : ping                  : pIOBroker                                -  enabled
                + system.adapter.proxmox.0                : proxmox               : pIOBroker                                -  enabled, port: 8006
                + system.adapter.signal-cmb.0             : signal-cmb            : pIOBroker                                -  enabled
                + system.adapter.synology.0               : synology              : pIOBroker                                -  enabled, port: 5000
                + system.adapter.synology.1               : synology              : pIOBroker                                -  enabled, port: 5000
                + system.adapter.tankerkoenig.0           : tankerkoenig          : pIOBroker                                -  enabled
                + system.adapter.telegram.0               : telegram              : pIOBroker                                -  enabled, port: 8443, bind: 0.0.0.0
                  system.adapter.tr-064.0                 : tr-064                : pIOBroker                                - disabled
                + system.adapter.trashschedule.0          : trashschedule         : pIOBroker                                -  enabled
                + system.adapter.vis-2.0                  : vis-2                 : pIOBroker                                -  enabled
                  system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : pIOBroker                                - disabled
                  system.adapter.vis-icontwo.0            : vis-icontwo           : pIOBroker                                -  enabled
                + system.adapter.vis-inventwo.0           : vis-inventwo          : pIOBroker                                -  enabled
                  system.adapter.vis-material-advanced.0  : vis-material-advanced : pIOBroker                                - disabled
                  system.adapter.vis-timeandweather.0     : vis-timeandweather    : pIOBroker                                - disabled
                  system.adapter.vis-weather.0            : vis-weather           : pIOBroker                                - disabled
                  system.adapter.vis.0                    : vis                   : pIOBroker                                -  enabled
                + system.adapter.web.0                    : web                   : pIOBroker                                -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                + system.adapter.zigbee.0                 : zigbee                : pIOBroker                                -  enabled, port: /dev/ttyUSB0
                + instance is alive
                ioBroker-Repositories
                Active repo(s): stable
                Installed ioBroker-Instances
                Used repository: stable
                Adapter    "admin"        : 6.17.14  , installed 6.17.14
                Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
                Adapter    "backitup"     : 2.11.0   , installed 2.11.0
                Adapter    "coronavirus-statistics": 0.9.0, installed 0.9.0
                Adapter    "daswetter"    : 3.1.15   , installed 3.1.15
                Adapter    "deconz"       : 1.4.1    , installed 1.4.1
                Adapter    "device-reminder": 3.1.2  , installed 3.1.2
                Adapter    "discovery"    : 4.5.0    , installed 4.5.0
                Adapter    "eventlist"    : 2.0.1    , installed 2.0.1
                Adapter    "firetv"       : 2.1.0    , installed 2.1.0
                Adapter    "fritzbox"     : 0.6.0    , installed 0.6.0
                Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
                Adapter    "hm-rpc"       : 1.17.0   , installed 1.17.0
                Adapter    "ical"         : 1.15.0   , installed 1.15.0
                Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
                Adapter    "javascript"   : 8.3.1    , installed 8.3.1
                Controller "js-controller": 5.0.19   , installed 5.0.19
                Adapter    "meteoalarm"   : 3.0.2    , installed 3.0.2
                Adapter    "node-red"     : 5.2.1    , installed 5.2.1
                Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
                Adapter    "proxmox"      : 2.3.0    , installed 2.3.0
                Adapter    "signal-cmb"   : 0.3.0    , installed 0.3.0
                Adapter    "socketio"     : 6.7.0    , installed 6.7.0
                Adapter    "synology"     : 3.1.0    , installed 3.1.0
                Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
                Adapter    "telegram"     : 3.3.2    , installed 3.3.2
                Adapter    "trashschedule": 3.3.0    , installed 3.3.0
                Adapter    "tuya"         : 3.15.0   , installed 3.15.0
                Adapter    "upnp"         : 1.0.21   , installed 1.0.21
                Adapter    "vis-2"        : 2.9.32   , installed 2.9.32
                Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
                Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
                Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
                Adapter    "web"          : 6.2.5    , installed 6.2.5
                Adapter    "ws"           : 2.6.1    , installed 2.6.1
                Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
                Adapter    "zigbee2mqtt"  : 2.13.6   , installed 2.13.6
                Objects and States
                Objects:        8340
                States:         7148
                Hit:1 http://security.debian.org buster/updates InRelease
                Hit:2 http://ftp.debian.org/debian buster InRelease
                Hit:3 http://ftp.debian.org/debian buster-updates InRelease
                Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
                Reading package lists...
                Pending Updates: 0
                *** Listening Ports ***
                tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      105        351606     93/systemd-resolved
                tcp        0      0 192.168.1.126:2010      0.0.0.0:*               LISTEN      1000       398547     5104/io.hm-rpc.1
                tcp        0      0 192.168.1.126:2001      0.0.0.0:*               LISTEN      1000       398483     5089/io.hm-rpc.0
                tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          351918     279/master
                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       396467     4898/iobroker.js-co
                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       394973     4898/iobroker.js-co
                tcp        0      0 0.0.0.0:5355            0.0.0.0:*               LISTEN      105        351600     93/systemd-resolved
                tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          345978     1/init
                tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1000       396717     4973/node-red
                tcp6       0      0 :::8081                 :::*                    LISTEN      1000       396593     4916/io.admin.0
                tcp6       0      0 :::8082                 :::*                    LISTEN      1000       401823     5307/io.web.0
                tcp6       0      0 ::1:25                  :::*                    LISTEN      0          351919     279/master
                tcp6       0      0 :::5355                 :::*                    LISTEN      105        351603     93/systemd-resolved
                tcp6       0      0 :::22                   :::*                    LISTEN      0          350584     1/init
                tcp6       0      0 :::111                  :::*                    LISTEN      0          345980     1/init
                tcp6       0      0 :::80                   :::*                    LISTEN      1000       396720     4973/node-red
                udp        0      0 0.0.0.0:5355            0.0.0.0:*                           105        351599     93/systemd-resolved
                udp        0      0 127.0.0.53:53           0.0.0.0:*                           105        351605     93/systemd-resolved
                udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          345979     1/init
                udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       396721     4973/node-red
                udp6       0      0 :::5355                 :::*                                105        351602     93/systemd-resolved
                udp6       0      0 :::111                  :::*                                0          345981     1/init
                2024-07-19 13:13:05.365  - info: fritzbox.0 (5059) data from 192.168.1.1: 19.07.24 15:13:05;CALL;1;11;913872;6929;SIP1;
                2024-07-19 13:13:09.324  - info: fritzbox.0 (5059) data from 192.168.1.1: 19.07.24 15:13:09;CONNECT;1;11;6929;
                2024-07-19 13:15:00.021  - info: host.pIOBroker instance system.adapter.dwd.0 started with pid 8529
                2024-07-19 13:15:01.020  - info: dwd.0 (8529) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.15.1, js-controller: 5.0.19
                2024-07-19 13:15:02.450  - info: dwd.0 (8529) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2024-07-19 13:15:02.964  - info: host.pIOBroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2024-07-19 13:15:04.067  - info: host.pIOBroker instance system.adapter.daswetter.0 started with pid 8547
                2024-07-19 13:15:04.888  - info: daswetter.0 (8547) starting. Version 3.1.15 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.15.1, js-controller: 5.0.19
                2024-07-19 13:15:07.049  - info: daswetter.0 (8547) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
                2024-07-19 13:15:07.556  - info: daswetter.0 (8547) cleaned everything up...
                2024-07-19 13:15:07.565  - info: host.pIOBroker instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2024-07-19 13:16:42.242  - info: fritzbox.0 (5059) data from 192.168.1.1: 19.07.24 15:16:42;DISCONNECT;1;213;
                2024-07-19 13:20:00.012  - info: host.pIOBroker instance system.adapter.dwd.0 started with pid 8675
                2024-07-19 13:20:00.885  - info: dwd.0 (8675) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.15.1, js-controller: 5.0.19
                2024-07-19 13:20:02.041  - info: dwd.0 (8675) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2024-07-19 13:20:02.556  - info: host.pIOBroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2024-07-19 13:20:04.027  - info: host.pIOBroker instance system.adapter.meteoalarm.0 started with pid 8693
                2024-07-19 13:20:05.927  - info: meteoalarm.0 (8693) starting. Version 3.0.2 in /opt/iobroker/node_modules/iobroker.meteoalarm, node: v20.15.1, js-controller: 5.0.19
                2024-07-19 13:20:07.845  - info: meteoalarm.0 (8693) 15.1: Updated Weather Alarms for Kreis Kronach -> 0 alarm(s) found
                2024-07-19 13:20:07.845  - info: meteoalarm.0 (8693) Terminated (ADAPTER_REQUESTED_TERMINATION): All data processed. Adapter stopped until next scheduled process.
                2024-07-19 13:20:08.376  - info: host.pIOBroker instance system.adapter.meteoalarm.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                • M Maddog-1
                  Skript v.2024-05-22
                  *** BASE SYSTEM ***
                             Chassis: container
                      Virtualization: lxc
                  Docker          : false
                  Kernel          : x86_64
                  Userland        : 64 bit
                  CPU threads: 2
                                   RTC time: n/a
                            RTC in local TZ: no
                  manuel
                  HOME=/home/manuel
                  GROUPS=manuel sudo
                  iobroker
                  HOME=/home/iobroker
                  Desktop:
                  Terminal:
                  *** MEMORY ***
                  Swap:          4.1G          0B        4.1G
                           4096 M total memory
                           1524 M used memory
                           1668 M free memory
                              0 M buffer memory
                            902 M swap cache
                           4096 M total swap
                              0 M used swap
                           4096 M free swap
                  *** FILESYSTEM ***
                  /var:
                  419M    /var/
                  235M    /var/cache
                  231M    /var/cache/apt
                  181M    /var/lib
                  USB-Devices by-id:
                  HINT:
                  /dev/ttyUSB0
                  /usr/bin/npm            10.7.0
                  /usr/bin/npx            10.7.0
                  nodejs:
                    Version table:
                  Errors in npm tree:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  admin:          6.17.14
                  javascript:     8.3.1
                  Adapter State
                  + instance is alive
                  Objects and States
                  Objects:        8340
                  States:         7148
                  Pending Updates: 0
                  also doch.
                  dann frag ich mich auch wo da nodejs v20 herkommt
                  Pending Updates: 0
                  aber nur, weil keine mehr angeboten werden
                    also doch.
                    Pending Updates: 0
                    Maddog-1
                    hatte vorhin das iob Nodejs-Update gemacht, ich war der aus dem anderen Beitrag mit dem Problem das ich als Root user das Update nicht machen konnte
                    • M Maddog-1
                      @maddog-1 aber wie auch @Thomas-Braun schrieb sollte es für Buster gar nicht mehr gebaut werden.
                      • M Maddog-1
                        Skript v.2024-05-22
                        *** BASE SYSTEM ***
                                   Chassis: container
                            Virtualization: lxc
                        Docker          : false
                        Kernel          : x86_64
                        Userland        : 64 bit
                        CPU threads: 2
                                         RTC time: n/a
                                  RTC in local TZ: no
                        manuel
                        HOME=/home/manuel
                        GROUPS=manuel sudo
                        iobroker
                        HOME=/home/iobroker
                        Desktop:
                        Terminal:
                        *** MEMORY ***
                        Swap:          4.1G          0B        4.1G
                                 4096 M total memory
                                 1524 M used memory
                                 1668 M free memory
                                    0 M buffer memory
                                  902 M swap cache
                                 4096 M total swap
                                    0 M used swap
                                 4096 M free swap
                        *** FILESYSTEM ***
                        /var:
                        419M    /var/
                        235M    /var/cache
                        231M    /var/cache/apt
                        181M    /var/lib
                        USB-Devices by-id:
                        HINT:
                        /dev/ttyUSB0
                        /usr/bin/npm            10.7.0
                        /usr/bin/npx            10.7.0
                        nodejs:
                          Version table:
                        Errors in npm tree:
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        admin:          6.17.14
                        javascript:     8.3.1
                        Adapter State
                        + instance is alive
                        Objects and States
                        Objects:        8340
                        States:         7148
                        Pending Updates: 0
                        @maddog-1
                        Deine Systemzeit ist falsch.
                        Setz das auf die richtige Zeitzone.
                        Der user 'manuel' fehlt in der Gruppe 'iobroker' (und ggfls. noch weiteren).
                        Boot Target: graphical.target
                        Sollte auf multi-user.target gesetzt werden.
                        @Homoran
                        Gut möglich, dass nur ein Raspberry 'Buster' davon betroffen ist. Die waren damals auch noch weiter von der Debian-Basis weg als heute.
                        Aber nichts destotrotz ist Buster einfach 'end-of-life' und muss durch ein noch lebendes Release ersetzt werden.
                          Maddog-1
                          da bin ich überfragt, hatte nur den Befehl ausgeführt
                          iob nodejs-update
                          • M Maddog-1
                            iob nodejs-update
                            Das geht im Moment noch, in einer kommenden Version wird das auf keinem Buster-basierendem System mehr möglich sein.
                              @maddog-1
                              @Homoran
                              Maddog-1
                              gibt es da noch einen anderen befehl für die Zeitzone?
                              dpkg-reconfigure tzdata
                              der den ich gerade über google gefunden habe funktioniert nicht
                              das mit dem user in den gruppen und multi user Target muss ich auch erstmal googeln, da hab ich keinen plan hab vorhin nur nach deinem anderen Beitrag den User angelegt
                              • M Maddog-1
                                Maddog-1
                                ok das mit der Zeitzone hat sich erledigt, hatte das Sudo vergessen, bin ja jetzt kein root mehr
                                • M Maddog-1
                                  @maddog-1
                                  Zeitzone
                                  sudo timedatectl set-timezone Europe/Berlin
                                  Über tzdata geht's aber auch.
                                  User Gruppen:
                                  sudo usermod -aG adm,dialout,sudo,audio,video,plugdev,users,iobroker DEIN_USERNAME
                                  exit
                                  Boot Target:
                                  sudo systemctl set-default multi-user.target
                                    @maddog-1
                                    Zeitzone
                                    User Gruppen:
                                    exit
                                    Boot Target:
                                    Maddog-1
                                    @thomas-braun said in Homekit Adapter lässt sich nicht installieren:
                                    super, Dankeschön, hat alles funktioniert
                                    zum thema Update,
                                    kann man das 1 zu 1 von hier übernehmen
                                    https://forum.iobroker.net/topic/47213/upgrade-von-debian-10-buster-auf-11-bullseye
                                    oder gibts ne andere vorgehensweise für nen Proxmox container
                                    oder eben ganz neu aufsetzten
                                    • M Maddog-1
                                      zum thema Update,
                                      @maddog-1
                                      Container sind Wegwerfartikel. Das ist wohl am einfachsten und schnellsten, da einen aktuellen Container drüberzustülpen als zwei Dist-Upgrades zu fahren, bis du dann auf Debian 12 Bookworm bist.
                                        @maddog-1
                                        Maddog-1
                                        ok dann werde ich mich mal wenn ich frei hab dran setzen
                                        Danke für die Hilfe
