  4. Homekit Adapter lässt sich nicht installieren
    3.0k
    3.0k
20 Beiträge 4 Kommentatoren 1.9k Aufrufe 2 Beobachtet
    Maddog-1
    • Adaptername: Homekit-Controller
    • Link zu Adapterrepository: www.github.com...
    • Adapterversion: 0.5.10
    • js-controller Version: 5.0.19
    • Admin Version: 6.17.14
    • Hardwaresystem: Beelink
    • Arbeitsspeicher: 4GB
    • Festplattenart: SSD,
    • Betriebssystem: Debian Buster auf einem (Proxmox LXC)
    • Nodejs-Version: v20.15.1
    • NPM-Version: 10.7.0
    Probleme bei der Installation des Homekit adapters
    $ iobroker add homekit-controller --host pIOBroker
    NPM version: 10.7.0
    Installing iobroker.homekit-controller@0.5.10... (System call)
    npm error code 1npm error path /opt/iobroker/node_modules/@abandonware/noblenpm error command failednpm error command sh -c node-gyp-buildnpm error Traceback (most recent call last):npm error File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 42, in <module>npm error import gyp # noqa: E402npm error File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 9, in <module>npm error import gyp.inputnpm error File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 8, in <module>npm error import gyp.commonnpm error File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/common.py", line 435npm error if CC := os.environ.get("CC_target") or os.environ.get("CC"):npm error ^npm error SyntaxError: invalid syntaxnpm error gyp ERR! configure error npm error gyp ERR! stack Error: `gyp` failed with exit code: 1npm error gyp ERR! stack at ChildProcess.<anonymous> (/opt/iobroker/node_modules/node-gyp/lib/configure.js:317:18)npm error gyp ERR! stack at ChildProcess.emit (node:events:519:28)npm error gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:294:12)npm error gyp ERR! System Linux 6.8.8-3-pvenpm error gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"npm error gyp ERR! cwd /opt/iobroker/node_modules/@abandonware/noblenpm error gyp ERR! node -v v20.15.1npm error gyp ERR! node-gyp -v v10.2.0npm error gyp ERR! not oknpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-07-19T12_44_36_102Z-debug-0.log
    host.pIOBroker Cannot install iobroker.homekit-controller@0.5.10: 1
    ERROR: Process exited with code 25
    werde nicht so richtig schlau aus der meldung
    Ro75R HomoranH 2 Antworten Letzte Antwort
    • M Maddog-1
      NPM version: 10.7.0
      Ro75R Online
      Ro75R Online
      Ro75
      @maddog-1 sagte in Homekit Adapter lässt sich nicht installieren:
      Debian Buster
      zu alt.
      Ro75.
      • M Maddog-1
        NPM version: 10.7.0
        HomoranH Offline
        HomoranH Offline
        ich denke mal, dass das vollkommen veraltete Betriebssystem da auch mitspielt
          Maddog-1
          oh ok, gut dann hat sich das erledigt, dann muss ich mal schauen wie ich den Aqara M3 hub ans laufen bekomme
          • M Maddog-1
            Ein aktuelles Betriebssystem wäre schon mal eine gute Ausgangsbasis...
            Zu noble auch mal hier schauen:
            https://github.com/noble/noble#readme
            Das baut etwas 'zickig'.
              Maddog-1
              gut dazu müsste ich dann wahrscheinlich komplett neu aufsetzen
              das muss dann warten bis ich mal viel Zeit habe
              oder lässt sich das auch anders Updaten?
              noble schau ich mir mal an
              • M Maddog-1
                @maddog-1
                Container ist doch kein Ding...
                Wobei ich eh nicht überzeugt bin, dass du da wirklich ein Buster laufen hast, denn eigentlich läuft da ein nodejs@20 nicht mehr drauf.
                Was haste denn da wirklich am Start?
                iob diag
                sagt dir das.
                  Maddog-1
                  Skript v.2024-05-22
                  *** BASE SYSTEM ***
                     Static hostname: pIOBroker
                           Icon name: computer-container
                             Chassis: container
                      Virtualization: lxc
                    Operating System: Debian GNU/Linux 10 (buster)
                              Kernel: Linux 6.8.8-3-pve
                        Architecture: x86-64
                  model name      : Intel(R) Celeron(R) N5095 @ 2.00GHz
                  Docker          : false
                  Virtualization  : lxc
                  Kernel          : x86_64
                  Userland        : 64 bit
                  Systemuptime and Load:
                   13:20:54 up  1:16,  1 user,  load average: 0.42, 0.57, 0.39
                  CPU threads: 2
                  *** Time and Time Zones ***
                                 Local time: Fri 2024-07-19 13:20:54 UTC
                             Universal time: Fri 2024-07-19 13:20:54 UTC
                                   RTC time: n/a
                                  Time zone: Etc/UTC (UTC, +0000)
                                NTP service: inactive
                            RTC in local TZ: no
                  *** Users and Groups ***
                  User that called 'iob diag':
                  manuel
                  HOME=/home/manuel
                  GROUPS=manuel sudo
                  iobroker
                  HOME=/home/iobroker
                  GROUPS=iobroker tty dialout audio video plugdev
                  *** Display-Server-Setup ***
                  Display-Server: false
                  Desktop:
                  Terminal:
                  *** MEMORY ***
                  Mem:           4.1G        1.5G        1.7G        8.0M        902M        2.6G
                  Swap:          4.1G          0B        4.1G
                  Total:         8.2G        1.5G        5.8G
                  Active iob-Instances:   26
                           4096 M total memory
                           1524 M used memory
                           1419 M active memory
                            813 M inactive memory
                           1668 M free memory
                              0 M buffer memory
                            902 M swap cache
                           4096 M total swap
                              0 M used swap
                           4096 M free swap
                  top - 13:20:55 up  1:16,  1 user,  load average: 0.42, 0.57, 0.39
                  Tasks:  52 total,   1 running,  51 sleeping,   0 stopped,   0 zombie
                  %Cpu(s):  3.1 us,  3.1 sy,  0.0 ni, 93.8 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                  MiB Mem :   4096.0 total,   1668.5 free,   1525.0 used,    902.5 buff/cache
                  MiB Swap:   4096.0 total,   4096.0 free,      0.0 used.   2562.9 avail Mem
                  *** FAILED SERVICES ***
                    UNIT                          LOAD   ACTIVE SUB    DESCRIPTION
                  * run-rpc_pipefs.mount          loaded failed failed RPC Pipe File System
                  * sys-kernel-config.mount       loaded failed failed Kernel Configuration File System
                  * systemd-journald-audit.socket loaded failed failed Journal Audit Socket
                  3 loaded units listed. Pass --all to see loaded but inactive units, too.
                  To show all installed unit files use 'systemctl list-unit-files'.
                  *** FILESYSTEM ***
                  Filesystem                       Type      Size  Used Avail Use% Mounted on
                  /dev/mapper/pve-vm--101--disk--0 ext4       32G  5.1G   25G  18% /
                  none                             tmpfs     492K  4.0K  488K   1% /dev
                  udev                             devtmpfs  7.7G     0  7.7G   0% /dev/tty
                  tmpfs                            tmpfs     7.8G     0  7.8G   0% /dev/shm
                  tmpfs                            tmpfs     7.8G  8.1M  7.7G   1% /run
                  tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
                  dmesg: read kernel buffer failed: Operation not permitted
                  Show mounted filesystems:
                  TARGET                                SOURCE                           FSTYPE     OPTIONS
                  /                                     /dev/mapper/pve-vm--101--disk--0 ext4       rw,relatime,stripe=16
                  |-/run                                tmpfs                            tmpfs      rw,nosuid,nodev,mode=755,uid=100000,gid=100000,inode64
                  | `-/run/lock                         tmpfs                            tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k,uid=100000,gid=100000,inode64
                  |-/dev                                none                             tmpfs      rw,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
                  | |-/dev/shm                          tmpfs                            tmpfs      rw,nosuid,nodev,uid=100000,gid=100000,inode64
                  | |-/dev/mqueue                       mqueue                           mqueue     rw,relatime
                  | |-/dev/ttyUSB0                      udev[/ttyUSB0]                   devtmpfs   rw,nosuid,relatime,size=8043388k,nr_inodes=2010847,mode=755,inode64
                  | |-/dev/.lxc/proc                    proc                             proc       rw,relatime
                  | |-/dev/.lxc/sys                     sys                              sysfs      rw,relatime
                  | |-/dev/full                         udev[/full]                      devtmpfs   rw,nosuid,relatime,size=8043388k,nr_inodes=2010847,mode=755,inode64
                  | |-/dev/null                         udev[/null]                      devtmpfs   rw,nosuid,relatime,size=8043388k,nr_inodes=2010847,mode=755,inode64
                  | |-/dev/random                       udev[/random]                    devtmpfs   rw,nosuid,relatime,size=8043388k,nr_inodes=2010847,mode=755,inode64
                  | |-/dev/tty                          udev[/tty]                       devtmpfs   rw,nosuid,relatime,size=8043388k,nr_inodes=2010847,mode=755,inode64
                  | |-/dev/urandom                      udev[/urandom]                   devtmpfs   rw,nosuid,relatime,size=8043388k,nr_inodes=2010847,mode=755,inode64
                  | |-/dev/zero                         udev[/zero]                      devtmpfs   rw,nosuid,relatime,size=8043388k,nr_inodes=2010847,mode=755,inode64
                  | |-/dev/pts                          devpts                           devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
                  | |-/dev/ptmx                         devpts[/ptmx]                    devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
                  | |-/dev/console                      devpts[/0]                       devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
                  | |-/dev/tty1                         devpts[/1]                       devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
                  | `-/dev/tty2                         devpts[/2]                       devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
                  |-/proc                               proc                             proc       rw,nosuid,nodev,noexec,relatime
                  | |-/proc/sys                         proc[/sys]                       proc       ro,relatime
                  | | |-/proc/sys/net                   proc[/sys/net]                   proc       rw,nosuid,nodev,noexec,relatime
                  | | `-/proc/sys/kernel/random/boot_id none[/.lxc-boot-id]              tmpfs      ro,nosuid,nodev,noexec,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
                  | |-/proc/sysrq-trigger               proc[/sysrq-trigger]             proc       ro,relatime
                  | |-/proc/cpuinfo                     lxcfs[/proc/cpuinfo]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                  | |-/proc/diskstats                   lxcfs[/proc/diskstats]           fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                  | |-/proc/loadavg                     lxcfs[/proc/loadavg]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                  | |-/proc/meminfo                     lxcfs[/proc/meminfo]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                  | |-/proc/slabinfo                    lxcfs[/proc/slabinfo]            fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                  | |-/proc/stat                        lxcfs[/proc/stat]                fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                  | |-/proc/swaps                       lxcfs[/proc/swaps]               fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                  | `-/proc/uptime                      lxcfs[/proc/uptime]              fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                  `-/sys                                sysfs                            sysfs      ro,nosuid,nodev,noexec,relatime
                    |-/sys/fs/fuse/connections          fusectl                          fusectl    rw,nosuid,nodev,noexec,relatime
                    |-/sys/devices/virtual/net          sysfs[/devices/virtual/net]      sysfs      rw,nosuid,nodev,noexec,relatime
                    |-/sys/fs/cgroup                    none                             cgroup2    rw,nosuid,nodev,noexec,relatime
                    `-/sys/devices/system/cpu           lxcfs[/sys/devices/system/cpu]   fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                  /var:
                  419M    /var/
                  235M    /var/cache
                  231M    /var/cache/apt
                  181M    /var/lib
                  169M    /var/cache/apt/archives
                        Users in the 'systemd-journal' group can see all messages. Pass -q to
                        turn off this notice.
                  No journal files were opened due to insufficient permissions.
                  /opt/iobroker/backups:
                  34M     /opt/iobroker/backups/
                  /opt/iobroker/iobroker-data:
                  705M    /opt/iobroker/iobroker-data/
                  568M    /opt/iobroker/iobroker-data/files
                  149M    /opt/iobroker/iobroker-data/files/vis-2
                  138M    /opt/iobroker/iobroker-data/files/javascript.admin
                  118M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                  33M     /opt/iobroker/iobroker-data/files/meteoalarm.admin/geocodes.json
                  27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
                  24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                  24M     /opt/iobroker/iobroker-data/files/eventlist/static/js/main.bf7d9efc.js.map
                  24M     /opt/iobroker/iobroker-data/files/eventlist.admin/static/js/main.bf7d9efc.js.map
                  USB-Devices by-id:
                  /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_22559e53cd9ded11af12dca5a7669f5d-if00-port0
                  HINT:
                  Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
                  /dev/ttyUSB0
                  *** NodeJS-Installation ***
                  /usr/bin/nodejs         v20.15.1
                  /usr/bin/node           v20.15.1
                  /usr/bin/npm            10.7.0
                  /usr/bin/npx            10.7.0
                  /usr/bin/corepack       0.28.1
                  nodejs:
                    Installed: 20.15.1-1nodesource1
                    Candidate: 20.15.1-1nodesource1
                    Version table:
                   *** 20.15.1-1nodesource1 1001
                          500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                       20.15.0-1nodesource1 1001
                       20.14.0-1nodesource1 1001
                       20.13.1-1nodesource1 1001
                       20.13.0-1nodesource1 1001
                       20.12.2-1nodesource1 1001
                       20.12.1-1nodesource1 1001
                       20.12.0-1nodesource1 1001
                       20.11.1-1nodesource1 1001
                       20.11.0-1nodesource1 1001
                       20.10.0-1nodesource1 1001
                       20.9.0-1nodesource1 1001
                       20.8.1-1nodesource1 1001
                       20.8.0-1nodesource1 1001
                       20.7.0-1nodesource1 1001
                       20.6.1-1nodesource1 1001
                       20.6.0-1nodesource1 1001
                       20.5.1-1nodesource1 1001
                       20.5.0-1nodesource1 1001
                       20.4.0-1nodesource1 1001
                       20.3.1-1nodesource1 1001
                       20.3.0-1nodesource1 1001
                       20.2.0-1nodesource1 1001
                       20.1.0-1nodesource1 1001
                       20.0.0-1nodesource1 1001
                       10.24.0~dfsg-1~deb10u4 500
                          500 http://security.debian.org buster/updates/main amd64 Packages
                       10.24.0~dfsg-1~deb10u1 500
                          500 http://ftp.debian.org/debian buster/main amd64 Packages
                  No problems detected
                  Errors in npm tree:
                  *** ioBroker-Installation ***
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  Core adapters versions
                  js-controller:  5.0.19
                  admin:          6.17.14
                  javascript:     8.3.1
                  nodejs modules from github:     2
                  +-- iobroker.gotify@0.2.0 (git+ssh://git@github.com/ThomasPohl/ioBroker.gotify.git#c20ff9a8867b6b452a30b947c005fd7b6f42b41d)
                  | +-- syno@3.0.0 (git+ssh://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
                  Adapter State
                  + system.adapter.admin.0                  : admin                 : pIOBroker                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                  + system.adapter.alexa2.0                 : alexa2                : pIOBroker                                -  enabled
                  + system.adapter.backitup.0               : backitup              : pIOBroker                                -  enabled
                    system.adapter.daswetter.0              : daswetter             : pIOBroker                                -  enabled
                    system.adapter.discovery.0              : discovery             : pIOBroker                                - disabled
                    system.adapter.dwd.0                    : dwd                   : pIOBroker                                -  enabled
                  + system.adapter.eventlist.0              : eventlist             : pIOBroker                                -  enabled
                  + system.adapter.firetv.0                 : firetv                : pIOBroker                                -  enabled
                  + system.adapter.fritzbox.0               : fritzbox              : pIOBroker                                -  enabled
                  + system.adapter.gotify.0                 : gotify                : pIOBroker                                -  enabled
                  + system.adapter.hm-rega.0                : hm-rega               : pIOBroker                                -  enabled
                  + system.adapter.hm-rpc.0                 : hm-rpc                : pIOBroker                                -  enabled, port: 0
                  + system.adapter.hm-rpc.1                 : hm-rpc                : pIOBroker                                -  enabled, port: 0
                    system.adapter.ical.0                   : ical                  : pIOBroker                                -  enabled
                    system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: pIOBroker                                -  enabled
                    system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : pIOBroker                                -  enabled
                    system.adapter.icons-icons8.0           : icons-icons8          : pIOBroker                                - disabled
                    system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : pIOBroker                                - disabled
                  + system.adapter.javascript.0             : javascript            : pIOBroker                                -  enabled
                    system.adapter.meteoalarm.0             : meteoalarm            : pIOBroker                                -  enabled
                  + system.adapter.node-red.0               : node-red              : pIOBroker                                -  enabled, port: 1880, bind: 0.0.0.0
                  + system.adapter.pi-hole.0                : pi-hole               : pIOBroker                                -  enabled
                  + system.adapter.ping.0                   : ping                  : pIOBroker                                -  enabled
                  + system.adapter.proxmox.0                : proxmox               : pIOBroker                                -  enabled, port: 8006
                  + system.adapter.signal-cmb.0             : signal-cmb            : pIOBroker                                -  enabled
                  + system.adapter.synology.0               : synology              : pIOBroker                                -  enabled, port: 5000
                  + system.adapter.synology.1               : synology              : pIOBroker                                -  enabled, port: 5000
                  + system.adapter.tankerkoenig.0           : tankerkoenig          : pIOBroker                                -  enabled
                  + system.adapter.telegram.0               : telegram              : pIOBroker                                -  enabled, port: 8443, bind: 0.0.0.0
                    system.adapter.tr-064.0                 : tr-064                : pIOBroker                                - disabled
                  + system.adapter.trashschedule.0          : trashschedule         : pIOBroker                                -  enabled
                  + system.adapter.vis-2.0                  : vis-2                 : pIOBroker                                -  enabled
                    system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : pIOBroker                                - disabled
                    system.adapter.vis-icontwo.0            : vis-icontwo           : pIOBroker                                -  enabled
                  + system.adapter.vis-inventwo.0           : vis-inventwo          : pIOBroker                                -  enabled
                    system.adapter.vis-material-advanced.0  : vis-material-advanced : pIOBroker                                - disabled
                    system.adapter.vis-timeandweather.0     : vis-timeandweather    : pIOBroker                                - disabled
                    system.adapter.vis-weather.0            : vis-weather           : pIOBroker                                - disabled
                    system.adapter.vis.0                    : vis                   : pIOBroker                                -  enabled
                  + system.adapter.web.0                    : web                   : pIOBroker                                -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                  + system.adapter.zigbee.0                 : zigbee                : pIOBroker                                -  enabled, port: /dev/ttyUSB0
                  + instance is alive
                  ioBroker-Repositories
                  Active repo(s): stable
                  Installed ioBroker-Instances
                  Used repository: stable
                  Adapter    "admin"        : 6.17.14  , installed 6.17.14
                  Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
                  Adapter    "backitup"     : 2.11.0   , installed 2.11.0
                  Adapter    "coronavirus-statistics": 0.9.0, installed 0.9.0
                  Adapter    "daswetter"    : 3.1.15   , installed 3.1.15
                  Adapter    "deconz"       : 1.4.1    , installed 1.4.1
                  Adapter    "device-reminder": 3.1.2  , installed 3.1.2
                  Adapter    "discovery"    : 4.5.0    , installed 4.5.0
                  Adapter    "eventlist"    : 2.0.1    , installed 2.0.1
                  Adapter    "firetv"       : 2.1.0    , installed 2.1.0
                  Adapter    "fritzbox"     : 0.6.0    , installed 0.6.0
                  Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
                  Adapter    "hm-rpc"       : 1.17.0   , installed 1.17.0
                  Adapter    "ical"         : 1.15.0   , installed 1.15.0
                  Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
                  Adapter    "javascript"   : 8.3.1    , installed 8.3.1
                  Controller "js-controller": 5.0.19   , installed 5.0.19
                  Adapter    "meteoalarm"   : 3.0.2    , installed 3.0.2
                  Adapter    "node-red"     : 5.2.1    , installed 5.2.1
                  Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
                  Adapter    "proxmox"      : 2.3.0    , installed 2.3.0
                  Adapter    "signal-cmb"   : 0.3.0    , installed 0.3.0
                  Adapter    "socketio"     : 6.7.0    , installed 6.7.0
                  Adapter    "synology"     : 3.1.0    , installed 3.1.0
                  Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
                  Adapter    "telegram"     : 3.3.2    , installed 3.3.2
                  Adapter    "trashschedule": 3.3.0    , installed 3.3.0
                  Adapter    "tuya"         : 3.15.0   , installed 3.15.0
                  Adapter    "upnp"         : 1.0.21   , installed 1.0.21
                  Adapter    "vis-2"        : 2.9.32   , installed 2.9.32
                  Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
                  Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
                  Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
                  Adapter    "web"          : 6.2.5    , installed 6.2.5
                  Adapter    "ws"           : 2.6.1    , installed 2.6.1
                  Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
                  Adapter    "zigbee2mqtt"  : 2.13.6   , installed 2.13.6
                  Objects and States
                  Objects:        8340
                  States:         7148
                  Hit:1 http://security.debian.org buster/updates InRelease
                  Hit:2 http://ftp.debian.org/debian buster InRelease
                  Hit:3 http://ftp.debian.org/debian buster-updates InRelease
                  Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
                  Reading package lists...
                  Pending Updates: 0
                  *** Listening Ports ***
                  tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      105        351606     93/systemd-resolved
                  tcp        0      0 192.168.1.126:2010      0.0.0.0:*               LISTEN      1000       398547     5104/io.hm-rpc.1
                  tcp        0      0 192.168.1.126:2001      0.0.0.0:*               LISTEN      1000       398483     5089/io.hm-rpc.0
                  tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          351918     279/master
                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       396467     4898/iobroker.js-co
                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       394973     4898/iobroker.js-co
                  tcp        0      0 0.0.0.0:5355            0.0.0.0:*               LISTEN      105        351600     93/systemd-resolved
                  tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          345978     1/init
                  tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1000       396717     4973/node-red
                  tcp6       0      0 :::8081                 :::*                    LISTEN      1000       396593     4916/io.admin.0
                  tcp6       0      0 :::8082                 :::*                    LISTEN      1000       401823     5307/io.web.0
                  tcp6       0      0 ::1:25                  :::*                    LISTEN      0          351919     279/master
                  tcp6       0      0 :::5355                 :::*                    LISTEN      105        351603     93/systemd-resolved
                  tcp6       0      0 :::22                   :::*                    LISTEN      0          350584     1/init
                  tcp6       0      0 :::111                  :::*                    LISTEN      0          345980     1/init
                  tcp6       0      0 :::80                   :::*                    LISTEN      1000       396720     4973/node-red
                  udp        0      0 0.0.0.0:5355            0.0.0.0:*                           105        351599     93/systemd-resolved
                  udp        0      0 127.0.0.53:53           0.0.0.0:*                           105        351605     93/systemd-resolved
                  udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          345979     1/init
                  udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       396721     4973/node-red
                  udp6       0      0 :::5355                 :::*                                105        351602     93/systemd-resolved
                  udp6       0      0 :::111                  :::*                                0          345981     1/init
                  2024-07-19 13:13:05.365  - info: fritzbox.0 (5059) data from 192.168.1.1: 19.07.24 15:13:05;CALL;1;11;913872;6929;SIP1;
                  2024-07-19 13:13:09.324  - info: fritzbox.0 (5059) data from 192.168.1.1: 19.07.24 15:13:09;CONNECT;1;11;6929;
                  2024-07-19 13:15:00.021  - info: host.pIOBroker instance system.adapter.dwd.0 started with pid 8529
                  2024-07-19 13:15:01.020  - info: dwd.0 (8529) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.15.1, js-controller: 5.0.19
                  2024-07-19 13:15:02.450  - info: dwd.0 (8529) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2024-07-19 13:15:02.964  - info: host.pIOBroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2024-07-19 13:15:04.067  - info: host.pIOBroker instance system.adapter.daswetter.0 started with pid 8547
                  2024-07-19 13:15:04.888  - info: daswetter.0 (8547) starting. Version 3.1.15 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.15.1, js-controller: 5.0.19
                  2024-07-19 13:15:07.049  - info: daswetter.0 (8547) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
                  2024-07-19 13:15:07.556  - info: daswetter.0 (8547) cleaned everything up...
                  2024-07-19 13:15:07.565  - info: host.pIOBroker instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2024-07-19 13:16:42.242  - info: fritzbox.0 (5059) data from 192.168.1.1: 19.07.24 15:16:42;DISCONNECT;1;213;
                  2024-07-19 13:20:00.012  - info: host.pIOBroker instance system.adapter.dwd.0 started with pid 8675
                  2024-07-19 13:20:00.885  - info: dwd.0 (8675) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.15.1, js-controller: 5.0.19
                  2024-07-19 13:20:02.041  - info: dwd.0 (8675) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2024-07-19 13:20:02.556  - info: host.pIOBroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2024-07-19 13:20:04.027  - info: host.pIOBroker instance system.adapter.meteoalarm.0 started with pid 8693
                  2024-07-19 13:20:05.927  - info: meteoalarm.0 (8693) starting. Version 3.0.2 in /opt/iobroker/node_modules/iobroker.meteoalarm, node: v20.15.1, js-controller: 5.0.19
                  2024-07-19 13:20:07.845  - info: meteoalarm.0 (8693) 15.1: Updated Weather Alarms for Kreis Kronach -> 0 alarm(s) found
                  2024-07-19 13:20:07.845  - info: meteoalarm.0 (8693) Terminated (ADAPTER_REQUESTED_TERMINATION): All data processed. Adapter stopped until next scheduled process.
                  2024-07-19 13:20:08.376  - info: host.pIOBroker instance system.adapter.meteoalarm.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  • M Maddog-1
                    Skript v.2024-05-22
                    *** BASE SYSTEM ***
                               Chassis: container
                        Virtualization: lxc
                    Docker          : false
                    Kernel          : x86_64
                    Userland        : 64 bit
                    CPU threads: 2
                                     RTC time: n/a
                              RTC in local TZ: no
                    manuel
                    HOME=/home/manuel
                    GROUPS=manuel sudo
                    iobroker
                    HOME=/home/iobroker
                    Desktop:
                    Terminal:
                    *** MEMORY ***
                    Swap:          4.1G          0B        4.1G
                             4096 M total memory
                             1524 M used memory
                             1668 M free memory
                                0 M buffer memory
                              902 M swap cache
                             4096 M total swap
                                0 M used swap
                             4096 M free swap
                    *** FILESYSTEM ***
                    /var:
                    419M    /var/
                    235M    /var/cache
                    231M    /var/cache/apt
                    181M    /var/lib
                    USB-Devices by-id:
                    HINT:
                    /dev/ttyUSB0
                    /usr/bin/npm            10.7.0
                    /usr/bin/npx            10.7.0
                    nodejs:
                      Version table:
                    Errors in npm tree:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    admin:          6.17.14
                    javascript:     8.3.1
                    Adapter State
                    + instance is alive
                    Objects and States
                    Objects:        8340
                    States:         7148
                    Pending Updates: 0
                    HomoranH Offline
                    HomoranH Offline
                    also doch.
                    dann frag ich mich auch wo da nodejs v20 herkommt
                    Pending Updates: 0
                    aber nur, weil keine mehr angeboten werden
                      also doch.
                      Pending Updates: 0
                      Maddog-1
                      hatte vorhin das iob Nodejs-Update gemacht, ich war der aus dem anderen Beitrag mit dem Problem das ich als Root user das Update nicht machen konnte
                      • M Maddog-1
                        HomoranH Offline
                        HomoranH Offline
                        @maddog-1 aber wie auch @Thomas-Braun schrieb sollte es für Buster gar nicht mehr gebaut werden.
                        • M Maddog-1
                          Skript v.2024-05-22
                          *** BASE SYSTEM ***
                                     Chassis: container
                              Virtualization: lxc
                          Docker          : false
                          Kernel          : x86_64
                          Userland        : 64 bit
                          CPU threads: 2
                                           RTC time: n/a
                                    RTC in local TZ: no
                          manuel
                          HOME=/home/manuel
                          GROUPS=manuel sudo
                          iobroker
                          HOME=/home/iobroker
                          Desktop:
                          Terminal:
                          *** MEMORY ***
                          Swap:          4.1G          0B        4.1G
                                   4096 M total memory
                                   1524 M used memory
                                   1668 M free memory
                                      0 M buffer memory
                                    902 M swap cache
                                   4096 M total swap
                                      0 M used swap
                                   4096 M free swap
                          *** FILESYSTEM ***
                          /var:
                          419M    /var/
                          235M    /var/cache
                          231M    /var/cache/apt
                          181M    /var/lib
                          USB-Devices by-id:
                          HINT:
                          /dev/ttyUSB0
                          /usr/bin/npm            10.7.0
                          /usr/bin/npx            10.7.0
                          nodejs:
                            Version table:
                          Errors in npm tree:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          admin:          6.17.14
                          javascript:     8.3.1
                          Adapter State
                          + instance is alive
                          Objects and States
                          Objects:        8340
                          States:         7148
                          Pending Updates: 0
                          @maddog-1
                          Deine Systemzeit ist falsch.
                          Setz das auf die richtige Zeitzone.
                          Der user 'manuel' fehlt in der Gruppe 'iobroker' (und ggfls. noch weiteren).
                          Boot Target: graphical.target
                          Sollte auf multi-user.target gesetzt werden.
                          @Homoran
                          Gut möglich, dass nur ein Raspberry 'Buster' davon betroffen ist. Die waren damals auch noch weiter von der Debian-Basis weg als heute.
                          Aber nichts destotrotz ist Buster einfach 'end-of-life' und muss durch ein noch lebendes Release ersetzt werden.
                            Maddog-1
                            da bin ich überfragt, hatte nur den Befehl ausgeführt
                            iob nodejs-update
                            • M Maddog-1
                              iob nodejs-update
                              Das geht im Moment noch, in einer kommenden Version wird das auf keinem Buster-basierendem System mehr möglich sein.
                                @maddog-1
                                @Homoran
                                Maddog-1
                                gibt es da noch einen anderen befehl für die Zeitzone?
                                dpkg-reconfigure tzdata
                                der den ich gerade über google gefunden habe funktioniert nicht
                                das mit dem user in den gruppen und multi user Target muss ich auch erstmal googeln, da hab ich keinen plan hab vorhin nur nach deinem anderen Beitrag den User angelegt
                                • M Maddog-1
                                  Maddog-1
                                  ok das mit der Zeitzone hat sich erledigt, hatte das Sudo vergessen, bin ja jetzt kein root mehr
                                  • M Maddog-1
                                    @maddog-1
                                    Zeitzone
                                    sudo timedatectl set-timezone Europe/Berlin
                                    Über tzdata geht's aber auch.
                                    User Gruppen:
                                    sudo usermod -aG adm,dialout,sudo,audio,video,plugdev,users,iobroker DEIN_USERNAME
                                    exit
                                    Boot Target:
                                    sudo systemctl set-default multi-user.target
                                      @maddog-1
                                      Zeitzone
                                      User Gruppen:
                                      exit
                                      Boot Target:
                                      Maddog-1
                                      @thomas-braun said in Homekit Adapter lässt sich nicht installieren:
                                      super, Dankeschön, hat alles funktioniert
                                      zum thema Update,
                                      kann man das 1 zu 1 von hier übernehmen
                                      https://forum.iobroker.net/topic/47213/upgrade-von-debian-10-buster-auf-11-bullseye
                                      oder gibts ne andere vorgehensweise für nen Proxmox container
                                      oder eben ganz neu aufsetzten
                                      • M Maddog-1
                                        zum thema Update,
                                        @maddog-1
                                        Container sind Wegwerfartikel. Das ist wohl am einfachsten und schnellsten, da einen aktuellen Container drüberzustülpen als zwei Dist-Upgrades zu fahren, bis du dann auf Debian 12 Bookworm bist.
                                          @maddog-1
                                          Maddog-1
                                          ok dann werde ich mich mal wenn ich frei hab dran setzen
                                          Danke für die Hilfe
