  4. mihome-vacuum Adapter Karten werden nichtmehr geladen.
    6.0k
kartekartenmapmihome vacuum
36 Beiträge 5 Kommentatoren 4.4k Aufrufe 5 Beobachtet
  • R Rushmed
    @haselchen Oha, da steh was:
    mihome-vacuum.0
    2024-07-18 22:59:44.831	warn	CANVAS package not installed....please install Canvas package manually or disable Map in config see also https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum#error-at-installation
    Wie installier' ich die noch gleich? Auf der Adapterseite konnte ichs nichmehr finden.
    Edit: Hab was gefunden:
    https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum?tab=readme-ov-file#error-at-installation
    das probier' ich.
    Rushmed
    schrieb am zuletzt editiert von Rushmed
    @rushmed
    pi@Smartazamba:/opt/iobroker $ cd /opt/iobroker/node_modules/iobroker.mihome-vacuum
    pi@Smartazamba:/opt/iobroker/node_modules/iobroker.mihome-vacuum $ npm install canvas
    npm warn deprecated inflight@1.0.6: This module is not supported, and leaks memory. Do not use it. Check out lru-cache if you want a good and tested way to coalesce async requests by a key value, which is much more comprehensive and powerful.
    npm warn deprecated har-validator@5.1.5: this library is no longer supported
    npm warn deprecated glob@7.2.3: Glob versions prior to v9 are no longer supported
    npm warn deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
    npm warn deprecated glob@8.1.0: Glob versions prior to v9 are no longer supported
    npm warn deprecated are-we-there-yet@2.0.0: This package is no longer supported.
    npm warn deprecated @humanwhocodes/object-schema@2.0.3: Use @eslint/object-schema instead
    npm warn deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
    npm warn deprecated @humanwhocodes/config-array@0.11.14: Use @eslint/config-array instead
    npm warn deprecated rimraf@3.0.2: Rimraf versions prior to v4 are no longer supported
    npm warn deprecated npmlog@5.0.1: This package is no longer supported.
    npm warn deprecated gauge@3.0.2: This package is no longer supported.
    npm warn deprecated sinon@15.2.0: 16.1.1
    added 420 packages, and audited 421 packages in 4m
    54 packages are looking for funding
     run `npm fund` for details
    2 moderate severity vulnerabilities
    Some issues need review, and may require choosing
    a different dependency.
    Run `npm audit` for details.
    pi@Smartazamba:/opt/iobroker/node_modules/iobroker.mihome-vacuum $ cd /opt/iobroker/ && npm ls canvas
    iobroker.inst@3.0.0 /opt/iobroker
    ├── canvas@2.11.2 extraneous
    └─┬ iobroker.mihome-vacuum@4.2.0
      └── canvas@2.11.2
    Edit:
    Keine Ahnung wie das in den Post kommt:
    • R Offline
      Rushmed
      Danke, die Karten sind wieder da.
      Woher weiß ich wann canvas Zuwendung braucht bevor tagelang keine Karte aktualisiert wird.
      Bzw. Wann wird dieser Eingriff notwendig?
      haselchenH Thomas BraunT 2 Antworten Letzte Antwort
      • R Rushmed
        haselchenH Offline
        haselchenH Offline
        haselchen
        @rushmed
        Das Log bei Updates und Installationen verfolgen....
        R 1 Antwort Letzte Antwort
        • R Rushmed
          @rushmed sagte in mihome-vacuum Adapter Karten werden nichtmehr geladen.:
          Z. B. wenn sich die Major nodejs-Version ändert. Dann müssen gewisse Adapater/Module gegen die neue Version gebaut werden. Geht i.d.R. automatisch beim ersten Start einer Instanz.
          • haselchenH haselchen
            @rushmed
            Rushmed
            @haselchen Ich kann mit der Forenhilfe solche Sachen handhaben. Aber es ist echt immer schwierig den ioBroker als sorgenfreies Smarthome an andere zu vermitteln.
            • R Rushmed
              haselchenH Offline
              haselchenH Offline
              haselchen
              @rushmed
              Ich weiss, was Du meinst.
              Das System permanent zu pflegen ist schon ne Aufgabe.
              Neben Familie, Arbeit und anderen Hobbys...
              Damit es Spass macht, nicht unter Druck setzen, permanent nach Updates zu gucken.
              Jeder setzt das System anders ein.
              Ich möchte ein wenig Automation, aber es soll nicht mein Leben bestimmen.
              Ich denke, ich habe einen guten Mittelweg gefunden.
              • R Rushmed
                @rushmed
                  └── canvas@2.11.2
                Edit:
                @rushmed
                cd /opt/iobroker && npm prune
                Dann wirst du den extraneous noch los.
                  @rushmed
                  Rushmed
                  @thomas-braun sagte in mihome-vacuum Adapter Karten werden nichtmehr geladen.:
                  pi@Smartazamba:/opt/iobroker $ cd /opt/iobroker/ && npm ls canvas
                    └── canvas@2.11.2
                  Ich küsse deine Augen!
                  Edit: Auch wieder so eine Sache, ich kümmer mich um sowas aber die meisten wollen das es einfach funktioniert. Kann mann dan icht mit "wenn Major Update mache XXX" im Hintergrund gleich alles geradeziehen?
                  • R Rushmed
                      └── canvas@2.11.2
                    Das machen die Adapter wie gesagt i. d. R. automatisch. Funktioniert aber nicht immer.
                      Rushmed
                      @thomas-braun Bitte nicht falsch verstehen, das ist keineswegs persönliche Kritik.
                      • R Offline
                        Rushmed
                        Jetzt werden die Karten wieder nicht mehr angelegt.
                        Beim Adapterstart kommt wieder:
                        mihome-vacuum.0
                        2024-07-19 11:52:02.734	warn	CANVAS package not installed....please install Canvas package manually or disable Map in config see also https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum#error-at-installation
                        Wie kann das sein?
                        • R Rushmed
                          mihome-vacuum.0
                          Wie kann das sein?
                          @rushmed
                          Das Paket canvas muss wohl im Pfad von mihome-vaccuum installiert werden.
                            @rushmed
                            Rushmed
                            @thomas-braun Ich hatte gestern die Anleitung befolgt und danach ging es ja auch.
                            • R Rushmed
                              @rushmed
                              Dann mach es nochmal.
                              Es darf aber am Ende kein 'canvas' in der obersten Ebene des npm tree liegen.
                              R P 2 Antworten Letzte Antwort
                                @rushmed
                                Rushmed
                                Wie kann ich das prüfen?
                                • R Rushmed
                                  @rushmed
                                  Per
                                    @rushmed
                                    Per
                                    Rushmed
                                    pi@Smartazamba:~ $ cd /opt/iobroker/ && npm ls canvas
                                      └── canvas@2.11.2
                                    Hab jetzt noch nicht neu installiert aber die Ausgabe sieht doch gut aus, oder?
                                    • R Rushmed
                                        └── canvas@2.11.2
                                      @rushmed
                                      Ja, so soll das aussehen.
                                      Kann aber dennoch sein, das du das nochmal anlegen musst.
                                        @rushmed
                                        Rushmed
                                        Folgendes hab ich jetzt durchgeführt:
                                        • canvas nach Anleitung installiert, Adapter neu gestartet --> Kartenerstellung funktioniert.
                                        • cd /opt/iobroker && npm prune, Adapter neu gestartet --> Kartenerstellung funktioniert nicht.
                                        • cd /opt/iobroker && npm prune, Adapter neu gestartet --> Kartenerstellung funktioniert.
                                        • Adapter neu gestartet --> Kartenerstellung funktioniert nicht.
                                        Ich beobachte das jetzt mal weiter.
                                        • R Offline
                                          Rushmed
                                          Bei mir kommen weider seit vier Tagen keine Karten mehr über den Adapter. Weiß noch jemand Hilfe?
                                          Wie gesagt, Adapterstart bringt:
                                          mihome-vacuum.0
                                          2024-07-24 19:38:02.863	warn	CANVAS package not installed....please install Canvas package manually or disable Map in config see also https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum#error-at-installation
                                          Obwohl:
                                            └── canvas@2.11.2
                                          gut aussieht.
                                          Laut der Adapteranleitung soll Canvas hier liegen: /opt/iobroker/node_modules/iobroker.mihome-vacuum
                                          Die Installation funktioniert auch:
                                          pi@Smartazamba:/opt/iobroker/node_modules/iobroker.mihome-vacuum $ npm ls canvas                                        iobroker.mihome-vacuum@4.2.0 /opt/iobroker/node_modules/iobroker.mihome-vacuum
                                          └── canvas@2.11.2
                                          Edit:
                                          Jetz kommt die Warnmeldung beim Adapterstart wieder und:
                                          pi@Smartazamba:~ $ cd /opt/iobroker/node_modules/iobroker.mihome-vacuum && npm ls canvas
                                          └── (empty)
                                          Canvas ist in /opt/iobroker/node_modules/iobroker.mihome-vacuum scheinbar wieder verschwunden.
                                          Wie kann das sein? @mcm1957 und @dirkhe habt ihr noch ne Idee?
