  4. [gelöst] Netatmo funktioniert nicht mehr
10 Beiträge 3 Kommentatoren 818 Aufrufe 3 Beobachtet
    ManfredHi
    schrieb am zuletzt editiert von ManfredHi
    Hallo. Seit heute nach funktioniert der Netatmo-Adapter bei mir nicht mehr. Es kommen folgende FEhler im Log:
    2024-07-17 07:45:48.683 - info: netatmo.0 (1818329) Got terminate signal TERMINATE_YOURSELF
    2024-07-17 07:45:48.684 - info: netatmo.0 (1818329) cleaned everything up...
    2024-07-17 07:45:48.685 - info: netatmo.0 (1818329) terminating
    2024-07-17 07:45:48.685 - info: netatmo.0 (1818329) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2024-07-17 07:45:49.187 - info: netatmo.0 (1818329) terminating
    2024-07-17 07:45:53.035 - info: netatmo.0 (1819120) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.netatmo, node: v20.15.0, js-controller: 5.0.19
    2024-07-17 07:45:53.057 - info: netatmo.0 (1819120) Authenticating with Netatmo using individual client-ID 64ebxxxxxxxxxxxxxx913d
    2024-07-17 07:45:53.057 - warn: netatmo.0 (1819120) API Error: Please Authenticate manually once using the Admin UI of this instance.
    2024-07-17 07:46:54.575 - warn: admin.0 (78490) netatmo has an invalid jsonConfig: [{"instancePath":"/items/_authenticate","schemaPath":"#/definitions/sendToProps/additionalProperties","keyword":"additionalProperties","params":{"additionalProperty":"window"},"message":"must NOT have additional properties"},{"instancePath":"","schemaPath":"#/if","keyword":"if","params":{"failingKeyword":"else"},"message":"must match \"else\" schema"}]
    2024-07-17 07:46:56.100 - error: netatmo.0 (1819120) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2024-07-17 07:46:56.101 - error: netatmo.0 (1819120) unhandled promise rejection: Cannot read properties of undefined (reading 'netatmoCoach')
    2024-07-17 07:46:56.233 - error: netatmo.0 (1819120) TypeError: Cannot read properties of undefined (reading 'netatmoCoach')
    at getScopeList (/opt/iobroker/node_modules/iobroker.netatmo/main.js:232:16)
    at AdapterClass. (/opt/iobroker/node_modules/iobroker.netatmo/main.js:84:34)
    at AdapterClass.emit (node:events:519:28)
    at AdapterClass.emit (node:domain:488:12)
    at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11114:34)
    at Immediate. (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:381:37)
    at processImmediate (node:internal/timers:478:21)
    2024-07-17 07:46:56.234 - error: netatmo.0 (1819120) Cannot read properties of undefined (reading 'netatmoCoach')
    2024-07-17 07:46:56.246 - info: netatmo.0 (1819120) cleaned everything up...
    2024-07-17 07:46:56.246 - info: netatmo.0 (1819120) terminating
    2024-07-17 07:46:56.247 - warn: netatmo.0 (1819120) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2024-07-17 07:46:56.748 - info: netatmo.0 (1819120) terminating
    2024-07-17 07:46:56.893 - error: host.iobroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2024-07-17 07:46:56.894 - error: host.iobroker Caught by controller[1]: TypeError: Cannot read properties of undefined (reading 'netatmoCoach')
    2024-07-17 07:46:56.894 - error: host.iobroker Caught by controller[1]: at getScopeList (/opt/iobroker/node_modules/iobroker.netatmo/main.js:232:16)
    2024-07-17 07:46:56.894 - error: host.iobroker Caught by controller[1]: at AdapterClass. (/opt/iobroker/node_modules/iobroker.netatmo/main.js:84:34)
    2024-07-17 07:46:56.894 - error: host.iobroker Caught by controller[1]: at AdapterClass.emit (node:events:519:28)
    2024-07-17 07:46:56.894 - error: host.iobroker Caught by controller[1]: at AdapterClass.emit (node:domain:488:12)
    2024-07-17 07:46:56.894 - error: host.iobroker Caught by controller[1]: at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11114:34)
    2024-07-17 07:46:56.894 - error: host.iobroker Caught by controller[1]: at Immediate. (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:381:37)
    2024-07-17 07:46:56.894 - error: host.iobroker Caught by controller[1]: at processImmediate (node:internal/timers:478:21)
    2024-07-17 07:46:56.895 - error: host.iobroker instance system.adapter.netatmo.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2024-07-17 07:46:56.895 - warn: host.iobroker Do not restart adapter system.adapter.netatmo.0 because restart loop detected
    Neue client-ID und client-Secret habe ich bereits erstellt und im Adapter eingetragen. Auch hab ich anschließend auf die Schaltfläche Authenticate Netamto geklickt. ohne Erfolg.
    Kann mir bitte jemand helfen? Bis heute nach hat es einwandfrei funktioniert.
    • M ManfredHi
      ManfredHi
      Aufgefallen ist mir, dass wenn man auf die Schaltfläche "Authenticate Netatmo" klickt kein Fenster aufgeht. Normalerweise sollte lt. Anleitung des Adapters ein neues Fenster mit dem Login zu Netatmo öffnen. Das tut es aber nicht. Habe es mit mehreren Browsers und auf verschiedenen Geräten probiert. Popupblocker usw. sind ausgeschalten.
        ManfredHi
        Komisch, verwendet niemand mehr diesen Adapter ?
        • WinniW Offline
          WinniW Offline
          Winni
          Also hier läuft der Adapter. Ist dein System aktuell? Gib doch mal ein:
          iob diag
          und stelle das Ergebnis hier ein.
            ManfredHi
            Skript v.2024-05-22
            *** BASE SYSTEM ***
               Static hostname: iobroker
                     Icon name: computer-vm
                       Chassis: vm
                Virtualization: kvm
              Operating System: Debian GNU/Linux 11 (bullseye)
                        Kernel: Linux 5.10.0-30-amd64
                  Architecture: x86-64
            model name      : Intel(R) Core(TM) i5-7260U CPU @ 2.20GHz
            Docker          : false
            Virtualization  : kvm
            Kernel          : x86_64
            Userland        : 64 bit
            Systemuptime and Load:
             21:40:13 up 10 days,  3:15,  1 user,  load average: 0.73, 0.48, 0.62
            CPU threads: 4
            *** Time and Time Zones ***
                           Local time: Wed 2024-07-17 21:40:13 CEST
                       Universal time: Wed 2024-07-17 19:40:13 UTC
                             RTC time: Wed 2024-07-17 19:40:14
                            Time zone: Europe/Vienna (CEST, +0200)
                          NTP service: n/a
                      RTC in local TZ: no
            *** Users and Groups ***
            User that called 'iob diag':
            iobuser
            HOME=/home/iobuser
            GROUPS=iobuser cdrom floppy sudo audio dip video plugdev netdev iobroker
            iobroker
            HOME=/home/iobroker
            GROUPS=iobroker tty dialout audio video plugdev redis
            *** Display-Server-Setup ***
            Display-Server: false
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Mem:             11G        6.1G        3.2G        0.0K        2.7G        5.5G
            Swap:           974M          0B        974M
            Total:           12G        6.1G        4.1G
            Active iob-Instances:   67
                    11964 M total memory
                     6106 M used memory
                      689 M active memory
                     7671 M inactive memory
                     3162 M free memory
                      187 M buffer memory
                     2509 M swap cache
                      974 M total swap
                        0 M used swap
                      974 M free swap
            top - 21:40:14 up 10 days,  3:15,  1 user,  load average: 0.73, 0.48, 0.62
            Tasks: 179 total,   2 running, 177 sleeping,   0 stopped,   0 zombie
            %Cpu(s):  3.2 us,  0.0 sy,  0.0 ni, 96.8 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
            MiB Mem :  11964.9 total,   3162.0 free,   6106.5 used,   2696.4 buff/cache
            MiB Swap:    975.0 total,    975.0 free,      0.0 used.   5548.4 avail Mem
            *** FAILED SERVICES ***
            0 loaded units listed.
            *** FILESYSTEM ***
            Filesystem              Type      Size  Used Avail Use% Mounted on
            udev                    devtmpfs  5.9G     0  5.9G   0% /dev
            tmpfs                   tmpfs     1.2G  728K  1.2G   1% /run
            /dev/sda1               ext4       19G   12G  6.4G  65% /
            tmpfs                   tmpfs     5.9G     0  5.9G   0% /dev/shm
            tmpfs                   tmpfs     5.0M     0  5.0M   0% /run/lock
            //192.168.0.40/ioBroker cifs      1.3T  1.1T  223G  83% /media/ioBroker
            tmpfs                   tmpfs     1.2G     0  1.2G   0% /run/user/1000
            [Sun Jul  7 18:24:22 2024] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
            [Sun Jul  7 18:24:22 2024] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
            Show mounted filesystems:
            TARGET                       SOURCE                  FSTYPE     OPTIONS
            /                            /dev/sda1               ext4       rw,relatime,errors=remount-ro
            |-/sys                       sysfs                   sysfs      rw,nosuid,nodev,noexec,relatime
            | |-/sys/kernel/security     securityfs              securityfs rw,nosuid,nodev,noexec,relatime
            | |-/sys/fs/cgroup           cgroup2                 cgroup2    rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
            | |-/sys/fs/pstore           pstore                  pstore     rw,nosuid,nodev,noexec,relatime
            | |-/sys/fs/bpf              none                    bpf        rw,nosuid,nodev,noexec,relatime,mode=700
            | |-/sys/kernel/debug        debugfs                 debugfs    rw,nosuid,nodev,noexec,relatime
            | |-/sys/kernel/tracing      tracefs                 tracefs    rw,nosuid,nodev,noexec,relatime
            | |-/sys/kernel/config       configfs                configfs   rw,nosuid,nodev,noexec,relatime
            | `-/sys/fs/fuse/connections fusectl                 fusectl    rw,nosuid,nodev,noexec,relatime
            |-/proc                      proc                    proc       rw,nosuid,nodev,noexec,relatime
            | `-/proc/sys/fs/binfmt_misc systemd-1               autofs     rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=11449
            |-/dev                       udev                    devtmpfs   rw,nosuid,relatime,size=6108208k,nr_inodes=1527052,mode=755
            | |-/dev/pts                 devpts                  devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
            | |-/dev/shm                 tmpfs                   tmpfs      rw,nosuid,nodev
            | |-/dev/hugepages           hugetlbfs               hugetlbfs  rw,relatime,pagesize=2M
            | `-/dev/mqueue              mqueue                  mqueue     rw,nosuid,nodev,noexec,relatime
            |-/run                       tmpfs                   tmpfs      rw,nosuid,nodev,noexec,relatime,size=1225212k,mode=755
            | |-/run/lock                tmpfs                   tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k
            | |-/run/rpc_pipefs          sunrpc                  rpc_pipefs rw,relatime
            | `-/run/user/1000           tmpfs                   tmpfs      rw,nosuid,nodev,relatime,size=1225208k,nr_inodes=306302,mode=700,uid=1000,gid=1000
            `-/media/ioBroker            //192.168.0.40/ioBroker cifs       rw,relatime,vers=3.0,cache=strict,username=Lokaler_User,uid=0,noforceuid,gid=0,noforcegid,addr=192.168.0.40,file_mode=0777,dir_mode=0777,soft,nounix,serverino,mapposix,rsize=4194304,wsize=4194304,bsize=1048576,echo_interval=60,actimeo=1
            /var:
            2.5G    /var/
            2.0G    /var/log
            1.9G    /var/log/journal/f3e74dfd154748e6b8f322b9b58612ad
            319M    /var/cache
            Archived and active journals take up 1.0G in the file system.
            /opt/iobroker/backups:
            82M     /opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            1.3G    /opt/iobroker/iobroker-data/
            1.1G    /opt/iobroker/iobroker-data/files
            299M    /opt/iobroker/iobroker-data/files/javascript.admin
            265M    /opt/iobroker/iobroker-data/files/javascript.admin/static
            264M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
            85M     /opt/iobroker/iobroker-data/objects.jsonl
            83M     /opt/iobroker/iobroker-data/objects.pretty.jsonl
            41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
            38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
            37M     /opt/iobroker/iobroker-data/files/telegram-menu.admin/build/index.js.map
            USB-Devices by-id:
            No Devices found 'by-id'
            *** NodeJS-Installation ***
            /usr/bin/nodejs         v20.15.0
            /usr/bin/node           v20.15.0
            /usr/bin/npm            10.7.0
            /usr/bin/npx            10.7.0
            /usr/bin/corepack       0.28.1
            nodejs:
              Installed: 20.15.0-1nodesource1
              Candidate: 20.15.0-1nodesource1
              Version table:
             *** 20.15.0-1nodesource1 1001
                    500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                 20.14.0-1nodesource1 1001
                 20.13.1-1nodesource1 1001
                 20.13.0-1nodesource1 1001
                 20.12.2-1nodesource1 1001
                 20.12.1-1nodesource1 1001
                 20.12.0-1nodesource1 1001
                 20.11.1-1nodesource1 1001
                 20.11.0-1nodesource1 1001
                 20.10.0-1nodesource1 1001
                 20.9.0-1nodesource1 1001
                 20.8.1-1nodesource1 1001
                 20.8.0-1nodesource1 1001
                 20.7.0-1nodesource1 1001
                 20.6.1-1nodesource1 1001
                 20.6.0-1nodesource1 1001
                 20.5.1-1nodesource1 1001
                 20.5.0-1nodesource1 1001
                 20.4.0-1nodesource1 1001
                 20.3.1-1nodesource1 1001
                 20.3.0-1nodesource1 1001
                 20.2.0-1nodesource1 1001
                 20.1.0-1nodesource1 1001
                 20.0.0-1nodesource1 1001
                 12.22.12~dfsg-1~deb11u4 500
                    500 http://ftp.tu-graz.ac.at/mirror/debian bullseye/main amd64 Packages
                    500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
            No problems detected
            Errors in npm tree:
            *** ioBroker-Installation ***
            ioBroker Status
            Objects type: jsonl
            States  type: redis
            Core adapters versions
            admin:          7.0.11
            javascript:     8.6.0
            nodejs modules from github:     8
            +-- iobroker.blockly-plus@0.0.1 (git+ssh://git@github.com/excal-foley/ioBroker.blockly-plus.git#8487239d69fc53c13853013110da15b42bc487e9)
            | `-- kodi-ws@2.4.4 (git+https://git@github.com/iobroker-community-adapters/kodi-ws.git#ad5a1fdc5cd0a282e6818ff152594b5d32535103)
            +-- iobroker.linux-control@1.1.6 (git+ssh://git@github.com/Scrounger/ioBroker.linux-control.git#59f578f3402850684ba8767a24a9ff288b05a3f0)
            +-- iobroker.nut@1.6.0 (git+ssh://git@github.com/Apollon77/ioBroker.nut.git#b684261dd657bc315c638037c397e42db2c361e1)
            | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550)
            +-- iobroker.solaredge-modbus@0.0.25 (git+ssh://git@github.com/joergspoerl/ioBroker.solaredge-modbus.git#a17300b3182465292a476c4e0fbaa96c9706e14d)
            +-- iobroker.sourceanalytix@0.4.14 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#9c4635239c7b9321601dcf0fcdd8677a55a8b13f)
            +-- iobroker.vesync@0.0.7 (git+ssh://git@github.com/TA2k/ioBroker.vesync.git#b0109fb28c94f7a3664eb0e599fd8359808a7b3e)
            Adapter State
            + system.adapter.admin.1                  : admin                 : iobroker                                 -  enabled, port: 8079, bind: 192.168.0.30, run as: admin
            + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
              system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
            + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
              system.adapter.birthdays.0              : birthdays             : iobroker                                 -  enabled
              system.adapter.blockly-plus.0           : blockly-plus          : iobroker                                 - disabled
            + system.adapter.bosch-ebike.0            : bosch-ebike           : iobroker                                 -  enabled
            + system.adapter.bydbatt.0                : bydbatt               : iobroker                                 -  enabled
            + system.adapter.bydhvs.0                 : bydhvs                : iobroker                                 -  enabled
            + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
              system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
            + system.adapter.denon.0                  : denon                 : iobroker                                 -  enabled
              system.adapter.device-reminder.0        : device-reminder       : iobroker                                 - disabled
              system.adapter.device-watcher.0         : device-watcher        : iobroker                                 - disabled
              system.adapter.devices.0                : devices               : iobroker                                 - disabled
            + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
            + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
            + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker                                 -  enabled
              system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 - disabled
            + system.adapter.fritzbox.0               : fritzbox              : iobroker                                 -  enabled
            + system.adapter.fritzdect.1              : fritzdect             : iobroker                                 -  enabled
              system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 - disabled
            + system.adapter.harmony.0                : harmony               : iobroker                                 -  enabled
            + system.adapter.heatingcontrol.0         : heatingcontrol        : iobroker                                 -  enabled
            + system.adapter.history.0                : history               : iobroker                                 -  enabled
            + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
            + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
            + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
            + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 0
            + system.adapter.homeconnect.0            : homeconnect           : iobroker                                 -  enabled
              system.adapter.hue-extended.0           : hue-extended          : iobroker                                 - disabled
              system.adapter.hue.0                    : hue                   : iobroker                                 - disabled, port: 443
            + system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
              system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
              system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
            + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
            + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
              system.adapter.jarvis.0                 : jarvis                : iobroker                                 - disabled
            + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
              system.adapter.javascript.1             : javascript            : iobroker                                 - disabled
            + system.adapter.kodi.0                   : kodi                  : iobroker                                 -  enabled, port: 9090
            + system.adapter.linux-control.0          : linux-control         : iobroker                                 -  enabled
            + system.adapter.logparser.0              : logparser             : iobroker                                 -  enabled
              system.adapter.material.0               : material              : iobroker                                 - disabled
            + system.adapter.meross.0                 : meross                : iobroker                                 -  enabled
            + system.adapter.meross.1                 : meross                : iobroker                                 -  enabled
            + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
            + system.adapter.modbus.1                 : modbus                : iobroker                                 -  enabled
              system.adapter.modbus.2                 : modbus                : iobroker                                 - disabled
            + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1886, bind: 192.168.0.30
            + system.adapter.mqtt.1                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
              system.adapter.netatmo-crawler.0        : netatmo-crawler       : iobroker                                 -  enabled
              system.adapter.netatmo.0                : netatmo               : iobroker                                 - disabled
            + system.adapter.nuki-extended.0          : nuki-extended         : iobroker                                 -  enabled
            + system.adapter.nut.0                    : nut                   : iobroker                                 -  enabled
            + system.adapter.operating-hours.0        : operating-hours       : iobroker                                 -  enabled
              system.adapter.parser.0                 : parser                : iobroker                                 - disabled
              system.adapter.pi-hole.0                : pi-hole               : iobroker                                 - disabled
            + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
            + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
              system.adapter.proxy.0                  : proxy                 : iobroker                                 -  enabled
            + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
            + system.adapter.pushover.1               : pushover              : iobroker                                 -  enabled
            + system.adapter.samsung.0                : samsung               : iobroker                                 -  enabled
            + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
            + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1884, bind: 192.168.0.30
            + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 192.168.0.30, run as: admin
              system.adapter.socketio.0               : socketio              : iobroker                                 - disabled, port: 8085, bind: 192.168.0.30, run as: admin
            + system.adapter.solaredge-modbus.0       : solaredge-modbus      : iobroker                                 -  enabled, port: 1502
              system.adapter.solaredge.0              : solaredge             : iobroker                                 - disabled
            + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1885, bind: 192.168.0.30
            + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
            + system.adapter.sourceanalytix.1         : sourceanalytix        : iobroker                                 -  enabled
            + system.adapter.sql.0                    : sql                   : iobroker                                 -  enabled, port: 3306
              system.adapter.systeminfo.0             : systeminfo            : iobroker                                 - disabled
              system.adapter.telegram-menu.0          : telegram-menu         : iobroker                                 - disabled
            + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
            + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
            + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
            + system.adapter.traccar.0                : traccar               : iobroker                                 -  enabled
            + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
            + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
              system.adapter.unifi.0                  : unifi                 : iobroker                                 - disabled
            + system.adapter.upnp.0                   : upnp                  : iobroker                                 -  enabled
            + system.adapter.valuetrackerovertime.0   : valuetrackerovertime  : iobroker                                 -  enabled
              system.adapter.vesync.0                 : vesync                : iobroker                                 - disabled
            + system.adapter.virtualpowermeter.0      : virtualpowermeter     : iobroker                                 -  enabled
              system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : iobroker                                 -  enabled
              system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : iobroker                                 -  enabled
              system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker                                 -  enabled
              system.adapter.vis-2.0                  : vis-2                 : iobroker                                 - disabled
              system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
              system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 - disabled
              system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
              system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker                                 -  enabled
              system.adapter.vis-metro.0              : vis-metro             : iobroker                                 -  enabled
              system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
              system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
              system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled
            + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 192.168.0.30, run as: admin
            + system.adapter.web.1                    : web                   : iobroker                                 -  enabled, port: 9082, bind: 0.0.0.0, run as: admin
            + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker                                 -  enabled
            + system.adapter.windows-control.0        : windows-control       : iobroker                                 -  enabled
            + system.adapter.ws.0                     : ws                    : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
            + system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : iobroker                                 -  enabled
            + instance is alive
            ioBroker-Repositories
            Stable (default): http://download.iobroker.net/sources-dist.json
            Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
            Installed ioBroker-Instances
            Adapter    "admin"        : 6.17.14  , installed 7.0.11
            Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
            Adapter    "alias-manager": 1.2.6    , installed 1.2.6
            Adapter    "backitup"     : 2.11.0   , installed 2.11.0
            Adapter    "birthdays"    : 3.0.1    , installed 3.0.0  [Updatable]
            Adapter    "bydbatt"      : 1.1.0    , installed 1.1.0
            Adapter    "bydhvs"       : 1.5.0    , installed 1.5.0
            Adapter    "daswetter"    : 3.1.15   , installed 3.1.15
            Adapter    "denon"        : 1.15.5   , installed 1.15.5
            Adapter    "device-reminder": 3.1.2  , installed 3.1.2
            Adapter    "device-watcher": 2.12.1  , installed 2.12.1
            Adapter    "devices"      : 1.1.5    , installed 1.1.5
            Adapter    "discovery"    : 4.5.0    , installed 4.5.0
            Adapter    "echarts"      : 1.7.2    , installed 1.7.2
            Adapter    "email"        : 1.3.1    , installed 1.3.1
            Adapter    "energiefluss-erweitert": 0.4.1, installed 0.4.1
            Adapter    "fb-checkpresence": 1.2.4 , installed 1.2.4
            Adapter    "fritzbox"     : 0.6.0    , installed 0.6.0
            Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
            Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
            Adapter    "harmony"      : 1.4.0    , installed 1.4.0
            Adapter    "heatingcontrol": 2.12.8  , installed 2.12.8
            Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
            Adapter    "hm-rpc"       : 1.17.0   , installed 1.17.0
            Adapter    "homeconnect"  : 1.4.0    , installed 1.4.0
            Adapter    "hue"          : 3.11.0   , installed 3.11.0
            Adapter    "ical"         : 1.15.0   , installed 1.15.0
            Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
            Adapter    "iot"          : 3.3.0    , installed 3.3.0
            Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
            Adapter    "javascript"   : 8.3.1    , installed 8.6.0
            Controller "js-controller": 5.0.19   , installed 5.0.19
            Adapter    "kodi"         : 3.1.0    , installed 3.1.0
            Adapter    "linux-control": 1.1.5    , installed 1.1.6
            Adapter    "logparser"    : 2.2.2    , installed 2.2.2
            Adapter    "material"     : 1.3.1    , installed 1.3.1
            Adapter    "meross"       : 1.17.0   , installed 1.17.0
            Adapter    "modbus"       : 6.2.3    , installed 6.2.3
            Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
            Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
            Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
            Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
            Adapter    "nut"          : 1.6.0    , installed 1.6.0
            Adapter    "operating-hours": 1.0.6  , installed 1.0.6
            Adapter    "parser"       : 2.1.0    , installed 2.1.0
            Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
            Adapter    "proxmox"      : 2.3.0    , installed 2.3.0
            Adapter    "proxy"        : 1.3.2    , installed 1.3.2
            Adapter    "pushover"     : 3.0.6    , installed 3.0.6
            Adapter    "samsung"      : 0.6.0    , installed 0.6.0
            Adapter    "scenes"       : 3.0.4    , installed 3.0.4
            Adapter    "shelly"       : 7.0.0    , installed 7.0.0
            Adapter    "socketio"     : 6.7.0    , installed 6.7.0
            Adapter    "solaredge"    : 1.4.1    , installed 1.4.1
            Adapter    "sonoff"       : 3.1.0    , installed 3.1.0
            Adapter    "systeminfo"   : 1.2.0    , installed 1.2.0
            Adapter    "telegram"     : 3.3.2    , installed 3.3.2
            Adapter    "telegram-menu": 1.7.4    , installed 1.7.0  [Updatable]
            Adapter    "text2command" : 3.0.3    , installed 3.0.3
            Adapter    "traccar"      : 1.1.4    , installed 1.1.4
            Adapter    "trashschedule": 3.3.0    , installed 3.3.0
            Adapter    "tuya"         : 3.15.0   , installed 3.15.0
            Adapter    "unifi"        : 0.7.0    , installed 0.7.0
            Adapter    "upnp"         : 1.0.21   , installed 1.0.21
            Adapter    "valuetrackerovertime": 1.0.1, installed 1.0.1
            Adapter    "virtualpowermeter": 1.4.6, installed 1.4.6
            Adapter    "vis-2"        : 2.9.32   , installed 2.9.32
            Adapter    "vis-2-widgets-energy": 0.3.11, installed 0.3.11
            Adapter    "vis-2-widgets-gauges": 1.0.3, installed 1.0.3
            Adapter    "vis-2-widgets-material": 1.3.32, installed 1.3.32
            Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
            Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
            Adapter    "weatherunderground": 3.7.0, installed 3.7.0
            Adapter    "web"          : 6.2.5    , installed 6.2.5
            Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
            Adapter    "windows-control": 0.1.5  , installed 0.1.5
            Adapter    "ws"           : 2.6.1    , installed 2.6.1
            Adapter    "zigbee2mqtt"  : 2.13.6   , installed 2.13.6
            Objects and States
            Objects:        81909
            States:         75304
            Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
            Hit:2 http://ftp.tu-graz.ac.at/mirror/debian bullseye InRelease
            Hit:3 http://ftp.tu-graz.ac.at/mirror/debian bullseye-updates InRelease
            Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
            Reading package lists...
            Pending Updates: 2
            *** Listening Ports ***
            tcp        0      0 192.168.0.30:1885       0.0.0.0:*               LISTEN      1001       34737081   3345584/io.sonoff.0
            tcp        0      0 192.168.0.30:1886       0.0.0.0:*               LISTEN      1001       19394      1982/io.mqtt.0
            tcp        0      0 192.168.0.30:4197       0.0.0.0:*               LISTEN      1001       39560472   679560/io.modbus.1
            tcp        0      0 127.0.0.1:3493          0.0.0.0:*               LISTEN      0          13213      570/upsd
            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       13821      533/iobroker.js-con
            tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      109        14972      487/redis-server 12
            tcp        0      0 192.168.0.30:9292       0.0.0.0:*               LISTEN      1001       18985      1587/io.hm-rpc.2
            tcp        0      0 192.168.0.30:8079       0.0.0.0:*               LISTEN      1001       251671     78491/io.admin.1
            tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          12349      1/init
            tcp        0      0 192.168.0.30:2001       0.0.0.0:*               LISTEN      1001       20790      1417/io.hm-rpc.1
            tcp        0      0 192.168.0.30:8082       0.0.0.0:*               LISTEN      1001       225868     70302/io.web.0
            tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      0          15387      521/dnsmasq
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13777      511/sshd: /usr/sbin
            tcp        0      0 192.168.0.30:8087       0.0.0.0:*               LISTEN      1001       28802      3894/io.simple-api.
            tcp        0      0 192.168.0.30:2010       0.0.0.0:*               LISTEN      1001       16004      1397/io.hm-rpc.0
            tcp        0      0 192.168.0.30:1884       0.0.0.0:*               LISTEN      1001       21743      2217/io.shelly.0
            tcp6       0      0 :::8000                 :::*                    LISTEN      1001       68983      7556/io.upnp.0
            tcp6       0      0 ::1:3493                :::*                    LISTEN      0          13212      570/upsd
            tcp6       0      0 :::61991                :::*                    LISTEN      1001       20618      1203/io.harmony.0
            tcp6       0      0 :::10123                :::*                    LISTEN      1001       37846      7801/io.energieflus
            tcp6       0      0 ::1:6379                :::*                    LISTEN      109        14973      487/redis-server 12
            tcp6       0      0 :::111                  :::*                    LISTEN      0          12353      1/init
            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       249766     78490/io.admin.0
            tcp6       0      0 :::8084                 :::*                    LISTEN      1001       38030      7610/io.ws.0
            tcp6       0      0 :::53                   :::*                    LISTEN      0          15389      521/dnsmasq
            tcp6       0      0 :::22                   :::*                    LISTEN      0          13788      511/sshd: /usr/sbin
            tcp6       0      0 :::9082                 :::*                    LISTEN      1001       226870     70308/io.web.1
            udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       20352      2608/io.tuya.0
            udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       20353      2608/io.tuya.0
            udp        0      0 0.0.0.0:53              0.0.0.0:*                           0          15386      521/dnsmasq
            udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          12350      1/init
            udp        0      0 192.168.0.30:123        0.0.0.0:*                           0          14932      507/ntpd
            udp        0      0 127.0.0.1:123           0.0.0.0:*                           0          14930      507/ntpd
            udp        0      0 0.0.0.0:123             0.0.0.0:*                           0          14926      507/ntpd
            udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       39139      7556/io.upnp.0
            udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       20619      1203/io.harmony.0
            udp        0      0 192.168.0.30:5353       0.0.0.0:*                           1001       22775      2412/io.tr-064.0
            udp6       0      0 :::53                   :::*                                0          15388      521/dnsmasq
            udp6       0      0 :::111                  :::*                                0          12356      1/init
            udp6       0      0 fe80::3417:62ff:fe4:123 :::*                                0          14938      507/ntpd
            udp6       0      0 fd34:8751:2f48:4dcc:123 :::*                                0          14936      507/ntpd
            udp6       0      0 ::1:123                 :::*                                0          14934      507/ntpd
            udp6       0      0 :::123                  :::*                                0          14923      507/ntpd
            2024-07-17 21:14:27.374  - info: javascript.0 (691) script.js.common.Beleuchtung.Lichter_zaehlen: Kellerstiege Licht ausgeschalten.
            2024-07-17 21:15:05.209  - info: netatmo-crawler.0 (2666540) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v20.15.0, js-controller: 5.0.19
            2024-07-17 21:15:05.235  - info: netatmo-crawler.0 (2666540) Getting data for stationid:70:ee:50:a5:86:0a
            2024-07-17 21:15:06.494  - info: netatmo-crawler.0 (2666540) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
            2024-07-17 21:15:09.095  - info: daswetter.0 (2666562) starting. Version 3.1.15 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.15.0, js-controller: 5.0.19
            2024-07-17 21:15:14.328  - info: daswetter.0 (2666562) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
            2024-07-17 21:15:14.839  - info: daswetter.0 (2666562) cleaned everything up...
            2024-07-17 21:20:01.233  - info: netatmo-crawler.0 (2671646) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v20.15.0, js-controller: 5.0.19
            2024-07-17 21:20:01.262  - info: netatmo-crawler.0 (2671646) Getting data for stationid:70:ee:50:a5:86:0a
            2024-07-17 21:20:02.212  - info: netatmo-crawler.0 (2671646) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
            2024-07-17 21:25:05.038  - info: netatmo-crawler.0 (2677093) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v20.15.0, js-controller: 5.0.19
            2024-07-17 21:25:05.063  - info: netatmo-crawler.0 (2677093) Getting data for stationid:70:ee:50:a5:86:0a
            2024-07-17 21:25:06.266  - info: netatmo-crawler.0 (2677093) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
            2024-07-17 21:30:01.402  - info: netatmo-crawler.0 (2682159) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v20.15.0, js-controller: 5.0.19
            2024-07-17 21:30:01.465  - info: netatmo-crawler.0 (2682159) Getting data for stationid:70:ee:50:a5:86:0a
            2024-07-17 21:30:03.810  - info: netatmo-crawler.0 (2682159) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
            2024-07-17 21:30:09.120  - info: daswetter.0 (2682356) starting. Version 3.1.15 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.15.0, js-controller: 5.0.19
            2024-07-17 21:30:14.348  - info: daswetter.0 (2682356) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
            2024-07-17 21:30:14.855  - info: daswetter.0 (2682356) cleaned everything up...
            2024-07-17 21:35:05.214  - info: netatmo-crawler.0 (2687611) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v20.15.0, js-controller: 5.0.19
            2024-07-17 21:35:05.235  - info: netatmo-crawler.0 (2687611) Getting data for stationid:70:ee:50:a5:86:0a
            2024-07-17 21:35:06.246  - info: netatmo-crawler.0 (2687611) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
            2024-07-17 21:40:01.809  - info: netatmo-crawler.0 (2692702) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v20.15.0, js-controller: 5.0.19
            2024-07-17 21:40:01.837  - info: netatmo-crawler.0 (2692702) Getting data for stationid:70:ee:50:a5:86:0a
            2024-07-17 21:40:02.789  - info: netatmo-crawler.0 (2692702) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
            iob diag has finished.
            Press any key for a summary
            • WinniW Offline
              WinniW Offline
              Winni
              @manfredhi Guten Morgen, was mir auffällt, Bullseye ist nicht mehr aktuell und für Node gibt es die Version 20.15.1. Ob das etwas deinem Adapter Problem zu tun hat glaube ich aber eher nicht. Vielleicht kann da noch jemand darüber schauen der mehr Ahnung hat als ich. Trotzdem würde ich node updaten und auch mal den fixer laufen lassen.
              • WinniW Winni
                ManfredHi
                @Winni
                Hab beim Admin-Adapter ein Downgrade von 7.0.11 auf 6.7.14 gemacht und jetzt funktioniert es wieder.
                DAs Problem dürfte beim Admin-Adapter auftreten, weil wenn man im Netatmo-Adapter auf "authenticate Netatmo" klickt geht das FEnster für die Anmeldung bei Netatmo nicht auf. Mit dem Admin 6.7.14 sehr wohl.
                • M ManfredHi
                  @Winni
                  @manfredhi
                  Das ist dann eine Regression.
                  Hast du ein Issue geloggt?
                  Wobei das vielleicht auch mit
                  admin
                  latest:	7.0.17
                  auch schon behoben ist...
                  Du betreibst ja Beta-Testing mit einer alten Version:
                  Das ist natürlich wenig sinnvoll.
                  M 2 Antworten Letzte Antwort
                    @manfredhi
                    admin
                    latest:	7.0.17
                    ManfredHi
                    @thomas-braun sagte in Netatmo funktioniert nicht mehr:
                    stimmt. hab die 7.0.11 vor ca. 2 Wochen installiert.
                    Werd jetzt mal bei der 6.17.14 bleiben bis die 7.x offiziell und nicht mehr im beta-stadium ist.
                      @manfredhi
                      admin
                      latest:	7.0.17
                      ManfredHi
                      Copy to Clipboard admin latest: 7.0.17
                      Hab doch die 7.0.17 installiert. Dort ist das Problem nicht mehr vorhanden,
                      82.8k
