  4. Adapter: ebus
    6.7k
Adapter: ebus
ebus adapter
712 Beiträge 73 Kommentatoren 332.4k Aufrufe 60 Beobachtet
  • icebearI Offline
    icebearI Offline
    icebear
    #598
    ebus --> 3.3.1
    Admin --> 6.17.14
    js-controller --> 5.0.19
    • Lenny.CBL Lenny.CB
      Bin aktuell auf folgenden Versionen:
      eBus --> 3.2.3
      Admin --> 7.0.12
      js-controller --> 6.0.6
      folgende Fehlermeldung bekomme ich.
      ebus.0
      2024-07-11 12:08:50.743	error	exception in ebusd_ReceiveData [Error [ERR_REQUIRE_ESM]: require() of ES Module /opt/iobroker/node_modules/iobroker.ebus/node_modules/flat/index.js from /opt/iobroker/node_modules/iobroker.ebus/main.js not supported. Instead change the require of index.js in /opt/iobroker/node_modules/iobroker.ebus/main.js to a dynamic import() which is available in all CommonJS modules.]
      ebus.0
      2024-07-11 12:07:50.731	error	exception in ebusd_ReceiveData [Error [ERR_REQUIRE_ESM]: require() of ES Module /opt/iobroker/node_modules/iobroker.ebus/node_modules/flat/index.js from /opt/iobroker/node_modules/iobroker.ebus/main.js not supported. Instead change the require of index.js in /opt/iobroker/node_modules/iobroker.ebus/main.js to a dynamic import() which is available in all CommonJS modules.]
      ebus.0
      2024-07-11 12:06:50.790	error	exception in ebusd_ReceiveData [Error [ERR_REQUIRE_ESM]: require() of ES Module /opt/iobroker/node_modules/iobroker.ebus/node_modules/flat/index.js from /opt/iobroker/node_modules/iobroker.ebus/main.js not supported. Instead change the require of index.js in /opt/iobroker/node_modules/iobroker.ebus/main.js to a dynamic import() which is available in all CommonJS modules.]
      ebus.0
      2024-07-11 12:05:50.561	error	exception in ebusd_ReceiveData [Error [ERR_REQUIRE_ESM]: require() of ES Module /opt/iobroker/node_modules/iobroker.ebus/node_modules/flat/index.js from /opt/iobroker/node_modules/iobroker.ebus/main.js not supported. Instead change the require of index.js in /opt/iobroker/node_modules/iobroker.ebus/main.js to a dynamic import() which is available in all CommonJS modules.]
      ebus.0
      2024-07-11 12:04:50.461	error	exception in ebusd_ReceiveData [Error [ERR_REQUIRE_ESM]: require() of ES Module /opt/iobroker/node_modules/iobroker.ebus/node_modules/flat/index.js from /opt/iobroker/node_modules/iobroker.ebus/main.js not supported. Instead change the require of index.js in /opt/iobroker/node_modules/iobroker.ebus/main.js to a dynamic import() which is available in all CommonJS modules.]
      ebus.0
      2024-07-11 12:03:50.449	error	exception in ebusd_ReceiveData [Error [ERR_REQUIRE_ESM]: require() of ES Module /opt/iobroker/node_modules/iobroker.ebus/node_modules/flat/index.js from /opt/iobroker/node_modules/iobroker.ebus/main.js not supported. Instead change the require of index.js in /opt/iobroker/node_modules/iobroker.ebus/main.js to a dynamic import() which is available in all CommonJS modules.]
      ebus.0
      2024-07-11 12:02:50.608	error	exception in ebusd_ReceiveData [Error [ERR_REQUIRE_ESM]: require() of ES Module /opt/iobroker/node_modules/iobroker.ebus/node_modules/flat/index.js from /opt/iobroker/node_modules/iobroker.ebus/main.js not supported. Instead change the require of index.js in /opt/iobroker/node_modules/iobroker.ebus/main.js to a dynamic import() which is available in all CommonJS modules.]
      vielleicht hilft es was.
      Rene_HMR Offline
      Rene_HMR Offline
      Rene_HM
      #599
      @lenny-cb ja, das könnte ein Hinweis sein, ich versteh nur nicht, warum die exception nur bei dir angezeigt wird...
      Lenny.CBL 1 Antwort Letzte Antwort
      • Rene_HMR Rene_HM
        Lenny.CBL Offline
        Lenny.CBL Offline
        Lenny.CB
        #600
        @rene_hm sagte in Adapter: ebus:
        diese Meldung ist mit eBus-Adapter-Upgrade auf die aktuelle Version weg.
        • Rene_HMR Rene_HM
          @lenny-cb @AleXburnA @Kanumouse @icebaer
          Hallo zusammen, ich sehe das Problem hier bei mir auch. Seit 10.7.2024 im 11:56 Uhr werden keine Daten mehr übernommen. Ich schaue mir das an...
          Habt ihr evtl. ein anderes update (js-controller, admin, ...) gemacht?
          Dette
          #601
          @rene_hm
          Schließe mich an, hatte auch schon ein Issue auf GitHub eröffnet. Fehlerbild ist exakt das selbe, wie es hier beschrieben wird.
          Keinerlei Updates.
          Noch eine Info, ich hatte den kompletten Objektbaum gelöscht und den Adapter neu gestartet.
          Daraufhin hat er dann alle Ordner mit dem Datenpunkt-Namen neu angelegt, aber keine Datenpunkte selber geschrieben.
          Nach einem Neustart des ebusd Servers (ebusd deamon) wurden dann alle Datenpunkte EINMALIG gezogen/aktualisiert, danach selber Fehler wie vorher.
          192.168.xxx.xxx:8889/data zeigt die Werte aktuell an.
          • D Dette
            @rene_hm
            Keinerlei Updates.
            Dette
            #602
            Info aus dem GitHub Issue mit einem funktionierenden Workaround:
            *Die per http abfragbaren Daten des ebusd (http://<ip_fqdn>:8889/data) hatten/haben seither einen Fehler in der json-Formatierung. Bei mir wurde in der Sektion "global" beim Wert '"updatecheck": "OK",' ein Zeilenumbruch/newline (?) zwischen " und OK eingefügt. Die den Daten zu Grunde liegende Abfrage des ebusd ("ebusctl info") liefert(e) diese Zeichenfolge. Ergo kam kein valides json raus. jsonlint und jq können mit den "json"-Daten nichts anfangen. Entfernt man den Zeilenumbruch/newline (?), hat man wieder valides json.
            Ich habe in der Datei /etc/defaults/ebusd die Option "--updatecheck=off" bei den Startoptionen des Daemon ergänzt und den ebusd neu gestartet. Der Wert "updatecheck" wird nun mit "ebusctl info" nicht mehr abfragt/anzeigt und kommt auch nicht mehr in die json-Daten rein.
            Die Ursache ist damit nicht behoben. Es klappt aber wieder. Der/die Programmierer des genialen ebusd findet/finden hoffentlich irgendwann Lust/Zeit der Sache auf den Grund zu gehen.*
            HiltexH K Lenny.CBL 3 Antworten Letzte Antwort
            • Lenny.CBL Offline
              Lenny.CBL Offline
              Lenny.CB
              schrieb am zuletzt editiert von Lenny.CB
              #603
              @Rene_HM
              so schaut bei mir das Log aus wenn die Daten geschrieben werden. (nach Neustart eBusd)
              und so wenn nicht aktualisiert wird:
              hier fehlt alles zum Objekt-Update
              Außerdem fällt auf, dass im "got data string" die Formatierung komisch ist.
              habe grad erst den Beitrag von @Dette gelesen. Da stehts ja mit dem Formatproblem!
              • D Dette
                HiltexH Offline
                HiltexH Offline
                Hiltex
                #604
                Ich war auch betroffen - gestern 11:26 Uhr
                @dette
                Danke für den Hinweis. Ich hab das bei mir eingefügt und aktuell läuft der Adapter wieder korrekt, alle Werte sind da.
                Letztes Mal hatte bei mir ein Neustart des Systems gereicht, auf dem ebusd läuft. Das habe ich dieses Mal jedoch nicht ausprobiert, sondern direkt den Parameter hinzugefügt.
                Blog: indibit.de
                • D Dette
                  Kanumouse
                  #605
                  @dette
                  Danke für die schnelle Hilfe, funktioniert auch bei mir wieder.
                  • D Dette
                    Lenny.CBL Offline
                    Lenny.CBL Offline
                    Lenny.CB
                    #606
                    @dette sagte in Adapter: ebus:
                    Danke für den Tipp. läuft erst einmal wieder!
                      mameier1234
                      #607
                      Sehr sehr cool .. alles wieder schön !
                      Grüße,
                      Martin
                      • icebearI Offline
                        icebearI Offline
                        icebear
                        #608
                        @dette said in Adapter: ebus:
                        Ich habe in der Datei /etc/defaults/ebusd die Option "--updatecheck=off" bei den Startoptionen des Daemon ergänzt...
                        Perfekt, danke für den Tip, läuft bei mir auch erstmal wieder
                        • MassiveAttackM Offline
                          MassiveAttack
                          #609
                          Seit mitternacht sind wieder alle werte gekommen, aber seit dem adapter update kommen nur noch fehler
                          • MassiveAttackM MassiveAttack
                            Kanumouse
                            #610
                            wenn ich das auf Github richtig sehe, hat john30 den Fehler im ebusd gestern korrigiert.
                              thiozinc
                              #611
                              Sorry, ich bin neu hier, aber vielleicht hat hier jemand einen Tipp.
                              Meine cloud stürzt immer mit folgendem Fehler ab:
                              Cannot request web pages "http://127.0.0.1:8082/vis/widgets/ebus.html?visVersion=1.5.6&_=1724355654893": File widgets/ebus.html not found: {}
                              Für mich sieht das so aus, als ob das widget von ebus nicht richtig installiert ist?
                              Eine De- und Reinstallation des Adapter hat leider nichts gebracht.
                              • T thiozinc
                                #612
                                @thiozinc sagte in Adapter: ebus:
                                Was ist denn überhaupt da in welchen Versionen installiert?
                                Schau die die Ausgabe von
                                iob diag
                                an.
                                  iob diag
                                  an.
                                  thiozinc
                                  #613
                                  			v.2024-05-22
                                   Static hostname: raspberrypi
                                         Icon name: computer
                                            Kernel: Linux 6.6.31+rpt-rpi-v8
                                      Architecture: arm64
                                  Installation: 		native
                                  Kernel: 		aarch64
                                  Userland: 		64 bit
                                  Timezone: 		Europe/Berlin (CEST, +0200)
                                  User-ID: 		1000
                                  Display-Server: 	false
                                  Boot Target: 		multi-user.target
                                  Pending OS-Updates: 	0
                                  Pending iob updates: 	0
                                  Nodejs-Installation:
                                  /usr/bin/nodejs 	v18.20.4
                                  /usr/bin/node 		v18.20.4
                                  /usr/bin/npm 		10.7.0
                                  /usr/bin/npx 		10.7.0
                                  /usr/bin/corepack 	0.28.0
                                  Recommended versions are nodejs 20.17.0 and npm 10.8.2
                                  MEMORY:
                                  Mem:            4.0G        2.8G        318M        225K        875M        1.1G
                                  Swap:           209M        157M         52M
                                  Total:          4.2G        3.0G        370M
                                  Active iob-Instances: 	29
                                  Upgrade policy: none
                                  ioBroker Core: 		js-controller 		6.0.9
                                  			admin 			7.0.23
                                  ioBroker Status: 	iobroker is running on this host.
                                  Objects type: jsonl
                                  States  type: jsonl
                                  + system.adapter.webuntis.0               : webuntis              : raspberrypi                              -  enabled
                                  Objects: 		12368
                                  States: 		11091
                                  Size of iob-Database:
                                  25M	/opt/iobroker/iobroker-data/objects.jsonl
                                  5.7M	/opt/iobroker/iobroker-data/states.jsonl
                                  • Thomas BraunT Online
                                    #614
                                    @thiozinc
                                    Das sieht schon mal gut aus. Die Langfassung verrät?
                                      @thiozinc
                                      thiozinc
                                      #615
                                      Skript v.2024-05-22
                                      *** BASE SYSTEM ***
                                             Icon name: computer
                                          Architecture: arm64
                                      Model		: Raspberry Pi 4 Model B Rev 1.1
                                      Docker          : false
                                      Virtualization  : none
                                      Kernel          : aarch64
                                      Userland        : 64 bit
                                      Systemuptime and Load:
                                       23:01:46 up 14 days,  3:14,  2 users,  load average: 1.05, 1.34, 1.15
                                      CPU threads: 4
                                      *** RASPBERRY THROTTLING ***
                                      Current issues:
                                      Previously detected issues:
                                      *** Time and Time Zones ***
                                                     Local time: Thu 2024-08-22 23:01:46 CEST
                                                 Universal time: Thu 2024-08-22 21:01:46 UTC
                                                       RTC time: n/a
                                                    NTP service: active
                                                RTC in local TZ: no
                                      *** Users and Groups ***
                                      User that called 'iob diag':
                                      pi
                                      HOME=/home/pi
                                      GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                                      iobroker
                                      HOME=/home/iobroker
                                      GROUPS=iobroker tty dialout sudo audio video bluetooth gpio i2c
                                      *** Display-Server-Setup ***
                                      Desktop:
                                      Terminal: 	tty
                                      *** MEMORY ***
                                      Mem:            4.0G        2.8G        541M        135K        679M        1.2G
                                      Swap:           209M        195M         13M
                                      Total:          4.2G        3.0G        555M
                                               3792 M total memory
                                               2689 M used memory
                                               2254 M active memory
                                                833 M inactive memory
                                                516 M free memory
                                                 75 M buffer memory
                                                572 M swap cache
                                                199 M total swap
                                                186 M used swap
                                                 13 M free swap
                                      top - 23:01:46 up 14 days,  3:14,  2 users,  load average: 1.05, 1.34, 1.15
                                      Tasks: 216 total,   1 running, 215 sleeping,   0 stopped,   0 zombie
                                      %Cpu(s):  0.0 us, 40.0 sy,  0.0 ni, 60.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                      MiB Mem :   3792.1 total,    515.9 free,   2689.6 used,    647.8 buff/cache
                                      MiB Swap:    200.0 total,     13.1 free,    186.9 used.   1102.5 avail Mem
                                      *** FAILED SERVICES ***
                                      0 loaded units listed.
                                      *** FILESYSTEM ***
                                      udev           devtmpfs  1.6G     0  1.6G   0% /dev
                                      tmpfs          tmpfs     380M  1.3M  378M   1% /run
                                      /dev/mmcblk0p2 ext4       29G  9.5G   18G  35% /
                                      tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
                                      /dev/mmcblk0p1 vfat      510M   64M  447M  13% /boot/firmware
                                      /dev/sda1      ext4      116G  1.7G  109G   2% /media/usbdisk
                                      tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
                                      [Thu Aug  8 19:47:22 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:30:B4:93 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=68b36b16-02 rootfstype=ext4 fsck.repair=yes rootwait
                                      [Thu Aug  8 19:47:26 2024] EXT4-fs (mmcblk0p2): mounted filesystem 3b614a3f-4a65-4480-876a-8a998e01ac9b ro with ordered data mode. Quota mode: none.
                                      [Thu Aug  8 19:47:29 2024] EXT4-fs (mmcblk0p2): re-mounted 3b614a3f-4a65-4480-876a-8a998e01ac9b r/w. Quota mode: none.
                                      [Thu Aug  8 19:47:32 2024] EXT4-fs (sda1): warning: mounting fs with errors, running e2fsck is recommended
                                      [Thu Aug  8 19:47:32 2024] EXT4-fs (sda1): mounted filesystem 3d241c43-2bbf-49ce-a4f9-270fcb182309 r/w with ordered data mode. Quota mode: none.
                                      [Thu Aug  8 19:47:36 2024] EXT4-fs error (device sda1): ext4_validate_block_bitmap:421: comm ext4lazyinit: bg 122: bad block bitmap checksum
                                      [Thu Aug  8 19:47:36 2024] EXT4-fs error (device sda1): ext4_validate_block_bitmap:421: comm ext4lazyinit: bg 203: bad block bitmap checksum
                                      [Thu Aug  8 19:52:38 2024] EXT4-fs (sda1): error count since last fsck: 71
                                      [Thu Aug  8 19:52:38 2024] EXT4-fs (sda1): initial error at time 1668261680: ext4_validate_block_bitmap:390
                                      [Thu Aug  8 19:52:38 2024] EXT4-fs (sda1): last error at time 1723139237: ext4_validate_block_bitmap:421
                                      [Fri Aug  9 21:30:18 2024] EXT4-fs (sda1): error count since last fsck: 71
                                      [Fri Aug  9 21:30:18 2024] EXT4-fs (sda1): initial error at time 1668261680: ext4_validate_block_bitmap:390
                                      [Fri Aug  9 21:30:18 2024] EXT4-fs (sda1): last error at time 1723139237: ext4_validate_block_bitmap:421
                                      [Sat Aug 10 23:08:14 2024] EXT4-fs (sda1): error count since last fsck: 71
                                      [Sat Aug 10 23:08:14 2024] EXT4-fs (sda1): initial error at time 1668261680: ext4_validate_block_bitmap:390
                                      [Sat Aug 10 23:08:14 2024] EXT4-fs (sda1): last error at time 1723139237: ext4_validate_block_bitmap:421
                                      [Mon Aug 12 00:46:11 2024] EXT4-fs (sda1): error count since last fsck: 71
                                      [Mon Aug 12 00:46:11 2024] EXT4-fs (sda1): initial error at time 1668261680: ext4_validate_block_bitmap:390
                                      [Mon Aug 12 00:46:11 2024] EXT4-fs (sda1): last error at time 1723139237: ext4_validate_block_bitmap:421
                                      [Tue Aug 13 02:24:07 2024] EXT4-fs (sda1): error count since last fsck: 71
                                      [Tue Aug 13 02:24:07 2024] EXT4-fs (sda1): initial error at time 1668261680: ext4_validate_block_bitmap:390
                                      [Tue Aug 13 02:24:07 2024] EXT4-fs (sda1): last error at time 1723139237: ext4_validate_block_bitmap:421
                                      [Wed Aug 14 04:02:04 2024] EXT4-fs (sda1): error count since last fsck: 71
                                      [Wed Aug 14 04:02:04 2024] EXT4-fs (sda1): initial error at time 1668261680: ext4_validate_block_bitmap:390
                                      [Wed Aug 14 04:02:04 2024] EXT4-fs (sda1): last error at time 1723139237: ext4_validate_block_bitmap:421
                                      [Thu Aug 15 05:40:00 2024] EXT4-fs (sda1): error count since last fsck: 71
                                      [Thu Aug 15 05:40:00 2024] EXT4-fs (sda1): initial error at time 1668261680: ext4_validate_block_bitmap:390
                                      [Thu Aug 15 05:40:00 2024] EXT4-fs (sda1): last error at time 1723139237: ext4_validate_block_bitmap:421
                                      [Fri Aug 16 07:17:57 2024] EXT4-fs (sda1): error count since last fsck: 71
                                      [Fri Aug 16 07:17:57 2024] EXT4-fs (sda1): initial error at time 1668261680: ext4_validate_block_bitmap:390
                                      [Fri Aug 16 07:17:57 2024] EXT4-fs (sda1): last error at time 1723139237: ext4_validate_block_bitmap:421
                                      [Sat Aug 17 08:55:53 2024] EXT4-fs (sda1): error count since last fsck: 71
                                      [Sat Aug 17 08:55:53 2024] EXT4-fs (sda1): initial error at time 1668261680: ext4_validate_block_bitmap:390
                                      [Sat Aug 17 08:55:53 2024] EXT4-fs (sda1): last error at time 1723139237: ext4_validate_block_bitmap:421
                                      [Sun Aug 18 10:33:50 2024] EXT4-fs (sda1): error count since last fsck: 71
                                      [Sun Aug 18 10:33:50 2024] EXT4-fs (sda1): initial error at time 1668261680: ext4_validate_block_bitmap:390
                                      [Sun Aug 18 10:33:50 2024] EXT4-fs (sda1): last error at time 1723139237: ext4_validate_block_bitmap:421
                                      [Mon Aug 19 12:11:46 2024] EXT4-fs (sda1): error count since last fsck: 71
                                      [Mon Aug 19 12:11:46 2024] EXT4-fs (sda1): initial error at time 1668261680: ext4_validate_block_bitmap:390
                                      [Mon Aug 19 12:11:46 2024] EXT4-fs (sda1): last error at time 1723139237: ext4_validate_block_bitmap:421
                                      [Tue Aug 20 13:49:43 2024] EXT4-fs (sda1): error count since last fsck: 71
                                      [Tue Aug 20 13:49:43 2024] EXT4-fs (sda1): initial error at time 1668261680: ext4_validate_block_bitmap:390
                                      [Tue Aug 20 13:49:43 2024] EXT4-fs (sda1): last error at time 1723139237: ext4_validate_block_bitmap:421
                                      [Wed Aug 21 15:27:39 2024] EXT4-fs (sda1): error count since last fsck: 71
                                      [Wed Aug 21 15:27:39 2024] EXT4-fs (sda1): initial error at time 1668261680: ext4_validate_block_bitmap:390
                                      [Wed Aug 21 15:27:39 2024] EXT4-fs (sda1): last error at time 1723139237: ext4_validate_block_bitmap:421
                                      [Thu Aug 22 17:05:36 2024] EXT4-fs (sda1): error count since last fsck: 71
                                      [Thu Aug 22 17:05:36 2024] EXT4-fs (sda1): initial error at time 1668261680: ext4_validate_block_bitmap:390
                                      [Thu Aug 22 17:05:36 2024] EXT4-fs (sda1): last error at time 1723139237: ext4_validate_block_bitmap:421
                                      Show mounted filesystems:
                                      TARGET                                                  SOURCE         FSTYPE      OPTIONS
                                      /                                                       /dev/mmcblk0p2 ext4        rw,noatime
                                      |-/sys                                                  sysfs          sysfs       rw,nosuid,nodev,noexec,relatime
                                      | |-/sys/kernel/security                                securityfs     securityfs  rw,nosuid,nodev,noexec,relatime
                                      | |-/sys/fs/cgroup                                      cgroup2        cgroup2     rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
                                      | |-/sys/fs/pstore                                      pstore         pstore      rw,nosuid,nodev,noexec,relatime
                                      | |-/sys/fs/bpf                                         bpf            bpf         rw,nosuid,nodev,noexec,relatime,mode=700
                                      | |-/sys/kernel/debug                                   debugfs        debugfs     rw,nosuid,nodev,noexec,relatime
                                      | | `-/sys/kernel/debug/tracing                         tracefs        tracefs     rw,nosuid,nodev,noexec,relatime
                                      | |-/sys/kernel/tracing                                 tracefs        tracefs     rw,nosuid,nodev,noexec,relatime
                                      | |-/sys/fs/fuse/connections                            fusectl        fusectl     rw,nosuid,nodev,noexec,relatime
                                      | `-/sys/kernel/config                                  configfs       configfs    rw,nosuid,nodev,noexec,relatime
                                      |-/proc                                                 proc           proc        rw,relatime
                                      | `-/proc/sys/fs/binfmt_misc                            systemd-1      autofs      rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=143
                                      |   `-/proc/sys/fs/binfmt_misc                          binfmt_misc    binfmt_misc rw,nosuid,nodev,noexec,relatime
                                      |-/dev                                                  udev           devtmpfs    rw,nosuid,relatime,size=1671304k,nr_inodes=417826,mode=755
                                      | |-/dev/pts                                            devpts         devpts      rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
                                      | |-/dev/shm                                            tmpfs          tmpfs       rw,nosuid,nodev
                                      | `-/dev/mqueue                                         mqueue         mqueue      rw,nosuid,nodev,noexec,relatime
                                      |-/run                                                  tmpfs          tmpfs       rw,nosuid,nodev,noexec,relatime,size=388308k,mode=755
                                      | |-/run/lock                                           tmpfs          tmpfs       rw,nosuid,nodev,noexec,relatime,size=5120k
                                      | |-/run/credentials/systemd-sysctl.service             ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                                      | |-/run/credentials/systemd-sysusers.service           ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                                      | |-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                                      | |-/run/rpc_pipefs                                     sunrpc         rpc_pipefs  rw,relatime
                                      | |-/run/credentials/systemd-tmpfiles-setup.service     ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                                      | `-/run/user/1000                                      tmpfs          tmpfs       rw,nosuid,nodev,relatime,size=388304k,nr_inodes=97076,mode=700,uid=1000,gid=1000
                                      |-/boot/firmware                                        /dev/mmcblk0p1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                      `-/media/usbdisk                                        /dev/sda1      ext4        rw,nosuid,nodev,noexec,noatime
                                      /var:
                                      3.6G	/var/
                                      1.9G	/var/log/journal/1c963a2d6f5d49798d662b895e4632cd
                                      1.9G	/var/log
                                      1.3G	/var/lib
                                      Archived and active journals take up 1.8G in the file system.
                                      /opt/iobroker/backups:
                                      384M	/opt/iobroker/backups/
                                      /opt/iobroker/iobroker-data:
                                      894M	/opt/iobroker/iobroker-data/
                                      700M	/opt/iobroker/iobroker-data/files
                                      441M	/opt/iobroker/iobroker-data/files/javascript.admin
                                      409M	/opt/iobroker/iobroker-data/files/javascript.admin/static
                                      408M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js
                                      42M	/opt/iobroker/iobroker-data/files/telegram-menu.admin/build/index.js.map
                                      30M	/opt/iobroker/iobroker-data/objects.jsonl
                                      24M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                                      22M	/opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.18496c94.js.map
                                      19M	/opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.02fc3820.js.map
                                      USB-Devices by-id:
                                      /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A50285BI-if00-port0
                                      /dev/serial/by-id/usb-Silicon_Labs_CP2102N_USB_to_UART_Bridge_Controller_d2fcfed44da0ea1184b05dcbfe9faf31-if00-port0
                                      /dev/serial/by-id/usb-Espressif_USB_JTAG_serial_debug_unit_80:65:99:99:A8:30-if00
                                      *** NodeJS-Installation ***
                                      /usr/bin/npm 		10.7.0
                                      /usr/bin/npx 		10.7.0
                                      nodejs:
                                        Installed: 18.20.4-1nodesource1
                                        Candidate: 18.20.4-1nodesource1
                                        Version table:
                                       *** 18.20.4-1nodesource1 1001
                                              500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
                                           18.20.3-1nodesource1 1001
                                           18.20.2-1nodesource1 1001
                                           18.20.1-1nodesource1 1001
                                           18.20.0-1nodesource1 1001
                                           18.19.1-1nodesource1 1001
                                           18.19.0+dfsg-6~deb12u2 500
                                              500 http://deb.debian.org/debian bookworm/main arm64 Packages
                                           18.19.0+dfsg-6~deb12u1 500
                                              500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
                                           18.19.0-1nodesource1 1001
                                           18.18.2-1nodesource1 1001
                                           18.18.1-1nodesource1 1001
                                           18.18.0-1nodesource1 1001
                                           18.17.1-1nodesource1 1001
                                           18.17.0-1nodesource1 1001
                                           18.16.1-1nodesource1 1001
                                           18.16.0-1nodesource1 1001
                                           18.15.0-1nodesource1 1001
                                           18.14.2-1nodesource1 1001
                                           18.14.1-1nodesource1 1001
                                           18.14.0-1nodesource1 1001
                                           18.13.0-1nodesource1 1001
                                           18.12.0-1nodesource1 1001
                                           18.11.0-1nodesource1 1001
                                           18.10.0-1nodesource1 1001
                                           18.9.1-1nodesource1 1001
                                           18.9.0-1nodesource1 1001
                                           18.8.0-1nodesource1 1001
                                           18.7.0-1nodesource1 1001
                                           18.6.0-1nodesource1 1001
                                           18.5.0-1nodesource1 1001
                                           18.4.0-1nodesource1 1001
                                           18.3.0-1nodesource1 1001
                                           18.2.0-1nodesource1 1001
                                           18.1.0-1nodesource1 1001
                                           18.0.0-1nodesource1 1001
                                      No problems detected
                                      Errors in npm tree:
                                      *** ioBroker-Installation ***
                                      ioBroker Status
                                      Objects type: jsonl
                                      States  type: jsonl
                                      Core adapters versions
                                      js-controller: 	6.0.9
                                      admin: 		7.0.23
                                      javascript: 	8.7.6
                                      nodejs modules from github: 	3
                                      +-- iobroker.robonect@1.3.6 (git+ssh://git@github.com/Grizzelbee/ioBroker.robonect.git#b3e15ba3ceda35dbc6688cc5431da2493a4c2f62)
                                      +-- iobroker.vw-connect@0.5.1 (git+ssh://git@github.com/ta2k/ioBroker.vw-connect.git#29ef72ba0568014661f431d5fc0908619fff89c2)
                                      +-- iobroker.wireless-mbus@0.9.2 (git+ssh://git@github.com/lvogt/ioBroker.wireless-mbus.git#de09e441e4c88799ada3abd396f04fad74f80325)
                                      Adapter State
                                        system.adapter.ble.0                    : ble                   : raspberrypi                              - disabled
                                      + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
                                        system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
                                        system.adapter.discovery.0              : discovery             : raspberrypi                              - disabled
                                      + system.adapter.drag-indicator.0         : drag-indicator        : raspberrypi                              -  enabled
                                      + system.adapter.ebus.0                   : ebus                  : raspberrypi                              -  enabled
                                        system.adapter.feiertage.0              : feiertage             : raspberrypi                              -  enabled
                                      + system.adapter.followthesun.0           : followthesun          : raspberrypi                              -  enabled
                                      + system.adapter.history.0                : history               : raspberrypi                              -  enabled
                                      + system.adapter.kecontact.0              : kecontact             : raspberrypi                              -  enabled
                                      + system.adapter.modbus.0                 : modbus                : raspberrypi                              -  enabled
                                      + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
                                        system.adapter.openligadb.0             : openligadb            : raspberrypi                              - disabled
                                      + system.adapter.parser.1                 : parser                : raspberrypi                              -  enabled
                                      + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
                                        system.adapter.psa.0                    : psa                   : raspberrypi                              - disabled
                                      + system.adapter.pushover.1               : pushover              : raspberrypi                              -  enabled
                                      + system.adapter.pushover.2               : pushover              : raspberrypi                              -  enabled
                                      + system.adapter.robonect.0               : robonect              : raspberrypi                              -  enabled
                                        system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              - disabled
                                        system.adapter.schoolfree.0             : schoolfree            : raspberrypi                              -  enabled
                                      + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1886, bind: 0.0.0.0
                                      + system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                                      + system.adapter.smartmeter.0             : smartmeter            : raspberrypi                              -  enabled
                                      + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1884, bind: 0.0.0.0
                                      + system.adapter.sql.0                    : sql                   : raspberrypi                              -  enabled, port: 3306
                                        system.adapter.telegram-menu.0          : telegram-menu         : raspberrypi                              - disabled
                                      + system.adapter.text2command.0           : text2command          : raspberrypi                              -  enabled
                                        system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              - disabled
                                        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              - disabled
                                        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              - disabled
                                        system.adapter.vis-history.0            : vis-history           : raspberrypi                              - disabled
                                        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
                                        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              - disabled
                                        system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi                              - disabled
                                        system.adapter.vis-lcars.0              : vis-lcars             : raspberrypi                              - disabled
                                        system.adapter.vis-plumb.0              : vis-plumb             : raspberrypi                              - disabled
                                        system.adapter.vis-rgraph.0             : vis-rgraph            : raspberrypi                              - disabled
                                        system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
                                        system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              - disabled
                                      + system.adapter.vw-connect.0             : vw-connect            : raspberrypi                              -  enabled
                                        system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              - disabled
                                      + system.adapter.wireless-mbus.0          : wireless-mbus         : raspberrypi                              -  enabled
                                      + instance is alive
                                      ioBroker-Repositories
                                      │ (index) │   name   │                           url                           │ auto upgrade │
                                      │    0    │ 'stable' │    'http://download.iobroker.net/sources-dist.json'     │    false     │
                                      │    1    │  'beta'  │ 'http://download.iobroker.net/sources-dist-latest.json' │    false     │
                                      Active repo(s): stable
                                      Installed ioBroker-Instances
                                      Used repository: stable
                                      Adapter    "admin"        : 7.0.23   , installed 7.0.23
                                      Adapter    "backitup"     : 3.0.19   , installed 3.0.19
                                      Adapter    "ble"          : 0.14.0   , installed 0.14.0
                                      Adapter    "daswetter"    : 3.1.15   , installed 3.1.15
                                      Adapter    "discovery"    : 4.5.0    , installed 4.5.0
                                      Adapter    "drag-indicator": 2.1.4   , installed 2.1.4
                                      Adapter    "ebus"         : 3.3.4    , installed 3.3.4
                                      Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
                                      Adapter    "followthesun" : 0.5.0    , installed 0.5.0
                                      Adapter    "javascript"   : 8.7.6    , installed 8.7.6
                                      Controller "js-controller": 6.0.9    , installed 6.0.9
                                      Adapter    "kecontact"    : 2.2.0    , installed 2.2.0
                                      Adapter    "modbus"       : 6.2.3    , installed 6.2.3
                                      Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                                      Adapter    "openligadb"   : 1.4.9    , installed 1.4.9
                                      Adapter    "parser"       : 2.2.2    , installed 2.2.2
                                      Adapter    "pushover"     : 3.0.6    , installed 3.0.6
                                      Adapter    "robonect"     : 1.3.6    , installed 1.3.6
                                      Adapter    "schoolfree"   : 1.1.4    , installed 1.1.4
                                      Adapter    "shelly"       : 7.0.0    , installed 7.0.0
                                      Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
                                      Adapter    "sonoff"       : 3.1.0    , installed 3.1.0
                                      Adapter    "sql"          : 3.0.1    , installed 3.0.1
                                      Adapter    "telegram"     : 3.9.0    , installed 3.9.0
                                      Adapter    "telegram-menu": 1.7.4    , installed 1.7.4
                                      Adapter    "text2command" : 3.0.3    , installed 3.0.3
                                      Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
                                      Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
                                      Adapter    "web"          : 6.2.5    , installed 6.2.5
                                      Adapter    "webuntis"     : 0.3.4    , installed 0.3.4
                                      Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
                                      Adapter    "wireless-mbus": 0.9.1    , installed 0.9.2
                                      Objects and States
                                      Objects: 	12368
                                      States: 	11091
                                      Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
                                      Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
                                      Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
                                      Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
                                      Reading package lists...
                                      Pending Updates: 0
                                      *** Listening Ports ***
                                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          674        787/sshd: /usr/sbin
                                      tcp        0      0 127.0.0.1:3306          0.0.0.0:*               LISTEN      106        6015       847/mariadbd
                                      tcp        0      0 0.0.0.0:8888            0.0.0.0:*               LISTEN      0          50950559   1469294/ebusd
                                      tcp        0      0 0.0.0.0:8889            0.0.0.0:*               LISTEN      0          50950560   1469294/ebusd
                                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       66105371   2118966/iobroker.js
                                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       66105364   2118966/iobroker.js
                                      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       66109578   2119230/io.mqtt.0
                                      tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       66108352   2119342/io.sonoff.0
                                      tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       66106731   2119302/io.shelly.0
                                      tcp6       0      0 :::22                   :::*                    LISTEN      0          676        787/sshd: /usr/sbin
                                      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       66105455   2118992/io.admin.0
                                      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       66107057   2119380/io.web.0
                                      tcp6       0      0 :::8087                 :::*                    LISTEN      1001       66110036   2119540/io.simple-a
                                      udp        0      0 0.0.0.0:7090            0.0.0.0:*                           1001       66108612   2119189/io.kecontac
                                      udp        0      0 0.0.0.0:7092            0.0.0.0:*                           1001       66108613   2119189/io.kecontac
                                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        4020       625/avahi-daemon: r
                                      udp        0      0 0.0.0.0:56809           0.0.0.0:*                           1001       66108614   2119189/io.kecontac
                                      udp        0      0 0.0.0.0:59006           0.0.0.0:*                           104        4022       625/avahi-daemon: r
                                      udp6       0      0 :::5353                 :::*                                104        4021       625/avahi-daemon: r
                                      udp6       0      0 :::44356                :::*                                104        4023       625/avahi-daemon: r
                                      udp6       0      0 fe80::79ca:2591:a72:546 :::*                                0          6377       700/NetworkManager
                                      2024-08-22 22:59:56.774  - warn: ebus.0 (2254253) no update since 21/08/2024, 21:41:21 uih.messages.TempIncrease.lastup
                                      2024-08-22 22:59:56.792  - warn: ebus.0 (2254253) no update since 21/08/2024, 21:41:22 uih.messages.YieldLastYear.lastup
                                      2024-08-22 22:59:57.019  - warn: ebus.0 (2254253) no update since 21/08/2024, 21:41:22 uih.messages.YieldOld.lastup
                                      2024-08-22 22:59:57.041  - warn: ebus.0 (2254253) no update since 21/08/2024, 21:41:22 uih.messages.YieldSum.lastup
                                      2024-08-22 22:59:57.241  - info: ebus.0 (2254253) installed ebusd version is 23.3
                                      2024-08-22 22:59:57.321  - info: ebus.0 (2254253) all http done
                                      2024-08-22 23:00:00.610  - info: smartmeter.0 (2119319) Received 10 values, 3 updated
                                      2024-08-22 23:00:05.555  - info: webuntis.0 (2119585) Cannot read Inbox - possible block by scool
                                      2024-08-22 23:00:07.395  - info: javascript.0 (2119026) script.js.Garten.Robbie: Robbi Temp i.O.!
                                      2024-08-22 23:00:11.397  - info: smartmeter.0 (2119319) Received 10 values, 3 updated
                                      2024-08-22 23:00:22.384  - info: smartmeter.0 (2119319) Received 10 values, 3 updated
                                      2024-08-22 23:00:33.313  - info: smartmeter.0 (2119319) Received 10 values, 3 updated
                                      2024-08-22 23:00:40.529  - info: shelly.0 (2119302) [MQTT] Device with client id "shellydw2-D73F3F" connected!
                                      2024-08-22 23:00:44.334  - info: smartmeter.0 (2119319) Received 10 values, 3 updated
                                      2024-08-22 23:00:55.332  - info: smartmeter.0 (2119319) Received 10 values, 3 updated
                                      2024-08-22 23:01:06.287  - info: smartmeter.0 (2119319) Received 10 values, 3 updated
                                      2024-08-22 23:01:17.337  - info: smartmeter.0 (2119319) Received 10 values, 2 updated
                                      2024-08-22 23:01:28.334  - info: smartmeter.0 (2119319) Received 10 values, 3 updated
                                      2024-08-22 23:01:39.341  - info: smartmeter.0 (2119319) Received 10 values, 3 updated
                                      2024-08-22 23:01:50.331  - info: smartmeter.0 (2119319) Received 10 values, 3 updated
                                      2024-08-22 23:02:01.342  - info: smartmeter.0 (2119319) Received 10 values, 3 updated
                                      2024-08-22 23:02:04.457  - info: javascript.0 (2119026) script.js.Garten.Robbie: Robbi Temp i.O.!
                                      2024-08-22 23:02:12.379  - info: smartmeter.0 (2119319) Received 10 values, 3 updated
                                      2024-08-22 23:02:23.371  - info: smartmeter.0 (2119319) Received 10 values, 3 updated
                                      2024-08-22 23:02:34.426  - info: smartmeter.0 (2119319) Received 10 values, 3 updated
                                      • T thiozinc
                                        Skript v.2024-05-22
                                        *** BASE SYSTEM ***
                                               Icon name: computer
                                            Architecture: arm64
                                        Docker          : false
                                        Kernel          : aarch64
                                        Userland        : 64 bit
                                        CPU threads: 4
                                        Current issues:
                                                         RTC time: n/a
                                                      NTP service: active
                                                  RTC in local TZ: no
                                        pi
                                        HOME=/home/pi
                                        iobroker
                                        HOME=/home/iobroker
                                        Desktop:
                                        Terminal: 	tty
                                        *** MEMORY ***
                                        Swap:           209M        195M         13M
                                                 3792 M total memory
                                                 2689 M used memory
                                                  516 M free memory
                                                   75 M buffer memory
                                                  572 M swap cache
                                                  199 M total swap
                                                  186 M used swap
                                                   13 M free swap
                                        *** FILESYSTEM ***
                                        /var:
                                        3.6G	/var/
                                        1.9G	/var/log
                                        1.3G	/var/lib
                                        USB-Devices by-id:
                                        /usr/bin/npm 		10.7.0
                                        /usr/bin/npx 		10.7.0
                                        nodejs:
                                          Version table:
                                        Errors in npm tree:
                                        ioBroker Status
                                        Objects type: jsonl
                                        States  type: jsonl
                                        admin: 		7.0.23
                                        javascript: 	8.7.6
                                        Adapter State
                                        + instance is alive
                                        Objects and States
                                        Objects: 	12368
                                        States: 	11091
                                        Pending Updates: 0
                                        #616
                                        @thiozinc
                                        Dein Dateisystem auf /dev/sda1 (/media/usbdisk) hat Einschläge.
                                        Bring nodejs auf Version 20
                                        iob nodejs-update
                                        Ansonsten nix auffälliges.
                                          @thiozinc
                                          iob nodejs-update
                                          thiozinc
                                          schrieb am zuletzt editiert von thiozinc
                                          #617
                                          @thomas-braun said in Adapter: ebus:
                                          iob nodejs-update
                                          Danke für den Tipp, aber das Update hat leider auch keine Verbesserung gebracht.
