  2. English
  3. ioBroker general
  4. Automatic Instance Generation
    apollon77A
Geplant Angeheftet Gesperrt Verschoben ioBroker general
5 Beiträge 3 Kommentatoren 3.2k Aufrufe 3 Beobachtet
  • Jack 3J
    Jack 3J
    Jack 3
    I would like to be able to automatically generate an instance (or at most with 1 or 2 clicks) when I connect a new TCP device with a predetermined and known IP adress. Does anybody have any tips for this? I tried using the JavaScript adapter but I couldn't find any node modules which had this functionality. Thanks in advance.
    • Jack 3J Jack 3
      mcm1957M
      mcm1957M
      mcm1957
      @jack-3
      Which adapter do you refer to ? Normally only very few instances are created per adapter.
      Support Repositoryverwaltung.
      LESEN - gute Forenbeitrage
      • Jack 3J
        Jack 3J
        Jack 3
        @mcm1957 I mean the modbus adapter, the main point that I want to be able to do this for is so that I can update all of the instances at once if I need to make changes instead of having to manually go through each of the instances.
        OliverIOO mcm1957M 2 Antworten Letzte Antwort
        • Jack 3J Jack 3
          OliverIOO
          OliverIOO
          OliverIO
          @jack-3
          If you want to change the instance configuration of an adapter you can change the object data of the datapoint
          system.adapter.<adaptername>.<instancenumber>
          You can find the configuration in this object in the native attribute
          To see this datapoint you have to enable the expert mode.
          I do not recommend to create or delete an instance programaticaly
          Meine Adapter und Widgets
          Links im Profil
          • Jack 3J Jack 3
            mcm1957M
            mcm1957M
            mcm1957
            @jack-3 said in Automatic Instance Generation:
            Why do you have multiple instances of modbus? Client or Server? I do not see the use case.
            And what MODBUS config needs to be changed at multiple instances?
            Anyway.
            As toll you can change the config of an existing instance by readibg and writing the native Part of the instance object
            83.9k
