  4. [gelöst] iobroker lässt sich nicht richtig installieren
27 Beiträge 4 Kommentatoren 3.5k Aufrufe 3 Beobachtet
  • DJMarc75D DJMarc75
    @mipl sagte in iobroker lässt sich nicht richtig installieren:
    Ähm und iob diag gibt nichts aus
    mööööp.... dann mach mal
    iob fix
    scheinst ja nicht gerade aktuell zu sein dünkt es mir ;)
    MiPl
    @djmarc75
    da kommt:
    pi@ubuntu:~$ iob fix
    library: loaded
    Library version=2024-05-24
        Welcome to the ioBroker installation fixer!
        Script version: 2024-01-04
        You might need to enter your password a couple of times.
        Installing prerequisites (1/5)
    Hit:1 http://ports.ubuntu.com/ubuntu-ports focal InRelease
    Get:2 http://ports.ubuntu.com/ubuntu-ports focal-updates InRelease [128 kB]
    Hit:3 http://ports.ubuntu.com/ubuntu-ports focal-backports InRelease
    Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
    Hit:5 http://ports.ubuntu.com/ubuntu-ports focal-security InRelease
    Fetched 128 kB in 3s (42.9 kB/s)
    Reading package lists... Done
        Checking ioBroker user and directory permissions (2/5)
        Check and cleanup npm temporary directories (3/5)
    Done.
        Database maintenance (4/5)
    Checking for uncompressed JSONL databases... This might take a while!
    npm error code EACCES
    npm error syscall mkdir
    npm error path /home/iobroker
    npm error errno EACCES
    npm error FetchError: Invalid response body while trying to fetch https://registry.npmjs.org/@iobroker%2fjsonltool: EACCES: permission denied, mkdir '/home/iobroker'
    npm error     at /usr/lib/node_modules/npm/node_modules/minipass-fetch/lib/body.js:170:15
    npm error     at async Response.json (/usr/lib/node_modules/npm/node_modules/minipass-fetch/lib/body.js:75:17)
    npm error     at async RegistryFetcher.packument (/usr/lib/node_modules/npm/node_modules/pacote/lib/registry.js:98:25)
    npm error     at async RegistryFetcher.manifest (/usr/lib/node_modules/npm/node_modules/pacote/lib/registry.js:129:23)
    npm error     at async getManifest (/usr/lib/node_modules/npm/node_modules/libnpmexec/lib/index.js:27:22)
    npm error     at async missingFromTree (/usr/lib/node_modules/npm/node_modules/libnpmexec/lib/index.js:61:22)
    npm error     at async /usr/lib/node_modules/npm/node_modules/libnpmexec/lib/index.js:163:32
    npm error     at async Promise.all (index 0)
    npm error     at async exec (/usr/lib/node_modules/npm/node_modules/libnpmexec/lib/index.js:161:3)
    npm error     at async module.exports (/usr/lib/node_modules/npm/lib/cli/entry.js:74:5) {
    npm error   code: 'EACCES',
    npm error   errno: 'EACCES',
    npm error   syscall: 'mkdir',
    npm error   path: '/home/iobroker',
    npm error   type: 'system'
    npm error }
    npm error
    npm error The operation was rejected by your operating system.
    npm error It is likely you do not have the permissions to access this file as the current user
    npm error
    npm error If you believe this might be a permissions issue, please double-check the
    npm error permissions of the file and its containing directories, or try running
    npm error the command again as root/Administrator.
    npm error Log files were not written due to an error writing to the directory: /home/iobroker/.npm/_logs
    npm error You can rerun the command with `--loglevel=verbose` to see the logs in your terminal
        Checking autostart (5/5)
    Enabling autostart...
    Autostart enabled!
        Your installation was fixed successfully
        Run iobroker start to start ioBroker again!
    HomoranH DJMarc75D 2 Antworten Letzte Antwort
    • M MiPl
      @djmarc75
      da kommt:
      library: loaded
      Done.
      npm error }
      npm error
      npm error
      Autostart enabled!
      ohh, oooooh!
      Habe iobroker auf ein laufendes System "hinzuinstalliert".
      wie genau hast du das gemacht?
      klappt iob diag jetzt trotzdem?
      • M MiPl
        @djmarc75
        da kommt:
        library: loaded
        Done.
        npm error }
        npm error
        npm error
        Autostart enabled!
        DJMarc75D Offline
        DJMarc75D Offline
        DJMarc75
        @mipl mach es so wie @Homoran geschrieben hat.
        Lehrling seit 1975 !!!
          ohh, oooooh!
          MiPl
          Installation via ssh mit dem Befehl:
          curl -sLf https://iobroker.net/install.sh | bash -
          iob diag geht weiterhin nicht.
          • M MiPl
            @mipl
            Dann ruf iob diag wie in meiner Signatur zu sehen auf.
            Also per
            curl -sLf -o diag.sh https://iobroker.net/diag.sh && bash diag.sh
            • M MiPl
              als root??
                @mipl
                Also per
                MiPl
                Keine Ausgabe mit curl -sLf -o diag.sh https://iobroker.net/diag.sh && bash diag.sh
                  als root??
                  MiPl
                  Nein, nicht als root
                  • M MiPl
                    @mipl
                    curl -L -o diag.sh https://iobroker.net/diag.sh && bash diag.sh
                      @mipl
                      MiPl
                      schrieb am zuletzt editiert von MiPl
                      liefert
                      pi@ubuntu:/$ curl -L -o diag.sh https://iobroker.net/diag.sh && bash diag.sh
                        % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                                       Dload  Upload   Total   Spent    Left  Speed
                      100   169  100   169    0     0    800      0 --:--:-- --:--:-- --:--:--   800
                      Warning: Failed to create the file diag.sh: Permission denied
                       69 23302   69 16126    0     0  37502      0 --:--:-- --:--:-- --:--:-- 37502
                      curl: (23) Failed writing body (0 != 16126)
                      • M MiPl
                        liefert
                        @mipl
                        Bitte immer die vollständigen Ein- wie Ausgaben inkl. LoginPrompt posten.
                        • M MiPl
                          nicht als root
                          wieso dann
                          System ist mit apt-get update und apt-upgrade aktualisiert.
                          ohne sudo?
                            nicht als root
                            wieso dann
                            ohne sudo?
                            MiPl
                            update und upgrade wurde mit sudo ausgeführt.
                            • M MiPl
                              @mipl Danke!
                              hmm, wo klemmt's denn dann mit den Rechten?
                              • M MiPl
                                @mipl
                                Stell dich in das home-Verzeichnis vom pi. Der darf (zum Glück) nicht in / schreiben.
                                  @mipl
                                  MiPl
                                  Du meintest so?
                                  pi@ubuntu:/$ cd /home/pi
                                  pi@ubuntu:~$ pwd
                                  /home/pi
                                  pi@ubuntu:~$ ls -l
                                  total 1872
                                  -rw-rw-r-- 1 pi pi    1800 Mar  1  2023 Cron-Send-new-IP.sh
                                  -rw-rw-r-- 1 pi pi      70 Mar  1  2023 IP-per-Email.txt
                                  -rw-rw-r-- 1 pi pi 1908226 Sep 20  2023 get-pip.py
                                  • M MiPl
                                    Du meintest so?
                                    pi@ubuntu:~$ pwd
                                    /home/pi
                                    pi@ubuntu:~$ ls -l
                                    total 1872
                                    @mipl
                                    Natürlich... Was treibst du eigentlich im root? Da haste nix zu wollen.
                                      @mipl
                                      MiPl
                                      ok, curl -sLf -o diag.sh https://iobroker.net/diag.sh && bash diag.sh liefert nun:
                                      Skript v.2024-05-22
                                      *** BASE SYSTEM ***
                                         Static hostname: ubuntu
                                               Icon name: computer
                                        Operating System: Ubuntu 20.04.6 LTS
                                                  Kernel: Linux 5.4.0-1111-raspi
                                            Architecture: arm64
                                      Model           : Raspberry Pi 3 Model B Rev 1.2
                                      Docker          : false
                                      Virtualization  : none
                                      Kernel          : aarch64
                                      Userland        : 64 bit
                                      Systemuptime and Load:
                                       20:45:23 up  1:34,  1 user,  load average: 0.25, 0.12, 0.12
                                      CPU threads: 4
                                      *** Time and Time Zones ***
                                                     Local time: Mon 2024-07-01 20:45:23 CEST
                                                 Universal time: Mon 2024-07-01 18:45:23 UTC
                                                       RTC time: n/a
                                                    NTP service: active
                                                RTC in local TZ: no
                                      *** Users and Groups ***
                                      User that called 'iob diag':
                                      pi
                                      HOME=/home/pi
                                      GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio spi i2c iobroker
                                      iobroker
                                      HOME=/home/iobroker
                                      GROUPS=iobroker tty dialout audio video plugdev gpio i2c
                                      *** Display-Server-Setup ***
                                      Display-Server: false
                                      Desktop:
                                      Terminal:       tty
                                      *** MEMORY ***
                                      Mem:           906M        223M        186M        2.0M        496M        588M
                                      Swap:            0B          0B          0B
                                      Total:         906M        223M        186M
                                      Active iob-Instances:   1
                                                906 M total memory
                                                223 M used memory
                                                472 M active memory
                                                111 M inactive memory
                                                186 M free memory
                                                 38 M buffer memory
                                                457 M swap cache
                                                  0 M total swap
                                                  0 M used swap
                                                  0 M free swap
                                      top - 20:45:24 up  1:34,  1 user,  load average: 0.25, 0.12, 0.12
                                      Tasks: 149 total,   1 running, 148 sleeping,   0 stopped,   0 zombie
                                      %Cpu(s):  1.2 us,  6.1 sy,  0.0 ni, 92.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                      MiB Mem :    906.1 total,    186.2 free,    223.5 used,    496.5 buff/cache
                                      MiB Swap:      0.0 total,      0.0 free,      0.0 used.    589.0 avail Mem
                                      *** FAILED SERVICES ***
                                        UNIT                                 LOAD   ACTIVE SUB    DESCRIPTION
                                      * systemd-networkd-wait-online.service loaded failed failed Wait for Network to be Configured
                                      1 loaded units listed.
                                      *** FILESYSTEM ***
                                      udev           devtmpfs  405M     0  405M   0% /dev
                                      tmpfs          tmpfs      91M  3.0M   88M   4% /run
                                      /dev/mmcblk0p2 ext4       15G  6.7G  7.1G  49% /
                                      tmpfs          tmpfs     454M   16K  454M   1% /dev/shm
                                      tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
                                      tmpfs          tmpfs     454M     0  454M   0% /sys/fs/cgroup
                                      /dev/loop0     squashfs   60M   60M     0 100% /snap/core20/2107
                                      /dev/loop2     squashfs   62M   62M     0 100% /snap/lxd/22761
                                      /dev/loop1     squashfs   60M   60M     0 100% /snap/core20/2321
                                      /dev/loop4     squashfs   36M   36M     0 100% /snap/snapd/20674
                                      /dev/loop5     squashfs   34M   34M     0 100% /snap/snapd/21761
                                      /dev/loop3     squashfs   92M   92M     0 100% /snap/lxd/24065
                                      /dev/mmcblk0p1 vfat      253M  121M  132M  48% /boot/firmware
                                      tmpfs          tmpfs      91M     0   91M   0% /run/user/1000
                                      [Mon Jul  1 19:10:44 2024] Kernel command line:  coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=720 bcm2708_fb.fbheight=480 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  elevator=deadline net.ifnames=0 console=ttyS0,115200 dwc_otg.lpm_enable=0 console=tty1 root=LABEL=writable rootfstype=ext4 rootwait fixrtc quiet splash quiet splash
                                      [Mon Jul  1 19:10:50 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
                                      [Mon Jul  1 19:10:53 2024] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
                                      Show mounted filesystems:
                                      TARGET                                SOURCE                 FSTYPE      OPTIONS
                                      /                                     /dev/mmcblk0p2         ext4        rw,relatime
                                      |-/sys                                sysfs                  sysfs       rw,nosuid,nodev,noexec,relatime
                                      | |-/sys/kernel/security              securityfs             securityfs  rw,nosuid,nodev,noexec,relatime
                                      | |-/sys/fs/cgroup                    tmpfs                  tmpfs       ro,nosuid,nodev,noexec,mode=755
                                      | | |-/sys/fs/cgroup/unified          cgroup2                cgroup2     rw,nosuid,nodev,noexec,relatime,nsdelegate
                                      | | |-/sys/fs/cgroup/systemd          cgroup                 cgroup      rw,nosuid,nodev,noexec,relatime,xattr,name=systemd
                                      | | |-/sys/fs/cgroup/blkio            cgroup                 cgroup      rw,nosuid,nodev,noexec,relatime,blkio
                                      | | |-/sys/fs/cgroup/rdma             cgroup                 cgroup      rw,nosuid,nodev,noexec,relatime,rdma
                                      | | |-/sys/fs/cgroup/perf_event       cgroup                 cgroup      rw,nosuid,nodev,noexec,relatime,perf_event
                                      | | |-/sys/fs/cgroup/hugetlb          cgroup                 cgroup      rw,nosuid,nodev,noexec,relatime,hugetlb
                                      | | |-/sys/fs/cgroup/freezer          cgroup                 cgroup      rw,nosuid,nodev,noexec,relatime,freezer
                                      | | |-/sys/fs/cgroup/cpu,cpuacct      cgroup                 cgroup      rw,nosuid,nodev,noexec,relatime,cpu,cpuacct
                                      | | |-/sys/fs/cgroup/net_cls,net_prio cgroup                 cgroup      rw,nosuid,nodev,noexec,relatime,net_cls,net_prio
                                      | | |-/sys/fs/cgroup/cpuset           cgroup                 cgroup      rw,nosuid,nodev,noexec,relatime,cpuset
                                      | | |-/sys/fs/cgroup/pids             cgroup                 cgroup      rw,nosuid,nodev,noexec,relatime,pids
                                      | | `-/sys/fs/cgroup/devices          cgroup                 cgroup      rw,nosuid,nodev,noexec,relatime,devices
                                      | |-/sys/fs/pstore                    pstore                 pstore      rw,nosuid,nodev,noexec,relatime
                                      | |-/sys/fs/bpf                       none                   bpf         rw,nosuid,nodev,noexec,relatime,mode=700
                                      | |-/sys/kernel/debug                 debugfs                debugfs     rw,nosuid,nodev,noexec,relatime
                                      | |-/sys/kernel/tracing               tracefs                tracefs     rw,nosuid,nodev,noexec,relatime
                                      | |-/sys/fs/fuse/connections          fusectl                fusectl     rw,nosuid,nodev,noexec,relatime
                                      | `-/sys/kernel/config                configfs               configfs    rw,nosuid,nodev,noexec,relatime
                                      |-/proc                               proc                   proc        rw,nosuid,nodev,noexec,relatime
                                      | `-/proc/sys/fs/binfmt_misc          systemd-1              autofs      rw,relatime,fd=28,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=1192
                                      |   `-/proc/sys/fs/binfmt_misc        binfmt_misc            binfmt_misc rw,nosuid,nodev,noexec,relatime
                                      |-/dev                                udev                   devtmpfs    rw,nosuid,noexec,relatime,size=414248k,nr_inodes=103562,mode=755
                                      | |-/dev/pts                          devpts                 devpts      rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
                                      | |-/dev/shm                          tmpfs                  tmpfs       rw,nosuid,nodev
                                      | |-/dev/hugepages                    hugetlbfs              hugetlbfs   rw,relatime,pagesize=2M
                                      | `-/dev/mqueue                       mqueue                 mqueue      rw,nosuid,nodev,noexec,relatime
                                      |-/run                                tmpfs                  tmpfs       rw,nosuid,nodev,noexec,relatime,size=92792k,mode=755
                                      | |-/run/lock                         tmpfs                  tmpfs       rw,nosuid,nodev,noexec,relatime,size=5120k
                                      | |-/run/rpc_pipefs                   sunrpc                 rpc_pipefs  rw,relatime
                                      | |-/run/user/1000                    tmpfs                  tmpfs       rw,nosuid,nodev,relatime,size=92788k,mode=700,uid=1000,gid=1003
                                      | `-/run/snapd/ns                     tmpfs[/snapd/ns]       tmpfs       rw,nosuid,nodev,noexec,relatime,size=92792k,mode=755
                                      |   `-/run/snapd/ns/lxd.mnt           nsfs[mnt:[4026533439]] nsfs        rw
                                      |-/snap/core20/2107                   /dev/loop0             squashfs    ro,nodev,relatime
                                      |-/snap/lxd/22761                     /dev/loop2             squashfs    ro,nodev,relatime
                                      |-/snap/core20/2321                   /dev/loop1             squashfs    ro,nodev,relatime
                                      |-/snap/snapd/20674                   /dev/loop4             squashfs    ro,nodev,relatime
                                      |-/snap/snapd/21761                   /dev/loop5             squashfs    ro,nodev,relatime
                                      |-/snap/lxd/24065                     /dev/loop3             squashfs    ro,nodev,relatime
                                      `-/boot/firmware                      /dev/mmcblk0p1         vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                      /var:
                                      3.1G    /var/
                                      1.8G    /var/log
                                      1.5G    /var/log/journal/4d4f67eb4fe2458ca82aed624af367f8
                                      1016M   /var/lib
                                      Archived and active journals take up 1.4G in the file system.
                                      /opt/iobroker/backups:
                                      du: cannot access '/opt/iobroker/backups/': No such file or directory
                                      /opt/iobroker/iobroker-data:
                                      228K    /opt/iobroker/iobroker-data/
                                      4.0K    /opt/iobroker/iobroker-data/states.jsonl.lock
                                      4.0K    /opt/iobroker/iobroker-data/objects.jsonl.lock
                                      4.0K    /opt/iobroker/iobroker-data/backup-objects
                                      188K    /opt/iobroker/iobroker-data/states.jsonl
                                      16K     /opt/iobroker/iobroker-data/objects.jsonl
                                      8.0K    /opt/iobroker/iobroker-data/iobroker.json
                                      USB-Devices by-id:
                                      No Devices found 'by-id'
                                      *** NodeJS-Installation ***
                                      /usr/bin/nodejs         v20.15.0
                                      /usr/bin/node           v20.15.0
                                      /usr/bin/npm            10.7.0
                                      /usr/bin/npx            10.7.0
                                      /usr/bin/corepack       0.28.1
                                      nodejs:
                                        Installed: 20.15.0-1nodesource1
                                        Candidate: 20.15.0-1nodesource1
                                        Version table:
                                       *** 20.15.0-1nodesource1 1001
                                              500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                                           20.14.0-1nodesource1 1001
                                           20.13.1-1nodesource1 1001
                                           20.13.0-1nodesource1 1001
                                           20.12.2-1nodesource1 1001
                                           20.12.1-1nodesource1 1001
                                           20.12.0-1nodesource1 1001
                                           20.11.1-1nodesource1 1001
                                           20.11.0-1nodesource1 1001
                                           20.10.0-1nodesource1 1001
                                           20.9.0-1nodesource1 1001
                                           20.8.1-1nodesource1 1001
                                           20.8.0-1nodesource1 1001
                                           20.7.0-1nodesource1 1001
                                           20.6.1-1nodesource1 1001
                                           20.6.0-1nodesource1 1001
                                           20.5.1-1nodesource1 1001
                                           20.5.0-1nodesource1 1001
                                           20.4.0-1nodesource1 1001
                                           20.3.1-1nodesource1 1001
                                           20.3.0-1nodesource1 1001
                                           20.2.0-1nodesource1 1001
                                           20.1.0-1nodesource1 1001
                                           20.0.0-1nodesource1 1001
                                           10.19.0~dfsg-3ubuntu1.6 500
                                              500 http://ports.ubuntu.com/ubuntu-ports focal-updates/universe arm64 Packages
                                              500 http://ports.ubuntu.com/ubuntu-ports focal-security/universe arm64 Packages
                                           10.19.0~dfsg-3ubuntu1 500
                                              500 http://ports.ubuntu.com/ubuntu-ports focal/universe arm64 Packages
                                      No problems detected
                                      Errors in npm tree:
                                      *** ioBroker-Installation ***
                                      ioBroker Status
                                       Cannot read system.config: null (OK when migrating or restoring)
                                      Objects type: jsonl
                                      States  type: jsonl
                                      Core adapters versions
                                      js-controller:  5.0.19
                                      admin:          6.17.14
                                      javascript:     "javascript" not found
                                      nodejs modules from github:     0
                                      Adapter State
                                      + instance is alive
                                      ioBroker-Repositories
                                      List is empty
                                      Installed ioBroker-Instances
                                      Error: Object "system.config" not found
                                      Objects and States
                                      Objects:        33
                                      States:         26
                                      Hit:2 http://ports.ubuntu.com/ubuntu-ports focal-updates InRelease
                                      Hit:4 http://ports.ubuntu.com/ubuntu-ports focal-security InRelease
                                      Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
                                      Pending Updates: 2
                                      *** Listening Ports ***
                                      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          15414      1/init
                                      tcp        0      0 127.0.0.1:8081          0.0.0.0:*               LISTEN      0          25397      864/motion
                                      tcp        0      0 127.0.0.1:8082          0.0.0.0:*               LISTEN      0          25398      864/motion
                                      tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      101        24040      621/systemd-resolve
                                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          29099      1054/sshd: /usr/sbi
                                      tcp        0      0 0.0.0.0:8765            0.0.0.0:*               LISTEN      0          26854      657/python2
                                      tcp        0      0 127.0.0.1:7999          0.0.0.0:*               LISTEN      0          25399      864/motion
                                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       50450      5240/iobroker.js-co
                                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       50445      5240/iobroker.js-co
                                      tcp6       0      0 :::111                  :::*                    LISTEN      0          15252      1/init
                                      tcp6       0      0 :::22                   :::*                    LISTEN      0          29101      1054/sshd: /usr/sbi
                                      udp        0      0 127.0.0.53:53           0.0.0.0:*                           101        24039      621/systemd-resolve
                                      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          15415      1/init
                                      udp6       0      0 :::111                  :::*                                0          15418      1/init
                                      2024-07-01 19:27:48.803  - info: host.ubuntu iobroker.js-controller version 5.0.19 js-controller starting
                                      2024-07-01 19:27:48.817  - info: host.ubuntu Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
                                      2024-07-01 19:27:48.820  - info: host.ubuntu hostname: ubuntu, node: v20.15.0
                                      2024-07-01 19:27:48.822  - info: host.ubuntu ip addresses: 10.56.78.100
                                      2024-07-01 19:27:49.080  - info: host.ubuntu Objects protocol version has changed, disconnecting!
                                      2024-07-01 19:27:49.154  - error: host.ubuntu Cannot read system.config: null (OK when migrating or restoring)
                                      2024-07-01 19:27:49.225  - error: host.ubuntu Cannot find view "system" for search "host"
                                      2024-07-01 19:27:49.371  - info: host.ubuntu connected to Objects and States
                                      2024-07-01 19:27:49.454  - info: host.ubuntu Node.js version has changed from unknown to 20.15.0
                                      2024-07-01 19:27:49.542  - info: host.ubuntu added notifications configuration of host
                                      2024-07-01 19:27:49.547  - info: host.ubuntu Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
                                      2024-07-01 19:27:49.614  - error: host.ubuntu Cannot find view "system" for search "instance"
                                      2024-07-01 19:27:49.617  - error: host.ubuntu Could not add notifications config of this host: Could not get notifications setup from instances: Cannot find view "system"
                                      2024-07-01 19:27:49.697  - info: host.ubuntu Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                                      2024-07-01 19:27:49.716  - error: host.ubuntu Cannot find view "system" for search "host"
                                      2024-07-01 19:27:49.737  - error: host.ubuntu Cannot find view "system" for search "state"
                                      2024-07-01 19:27:49.739  - error: host.ubuntu Cannot find view "system" for search "instance"
                                      2024-07-01 19:27:49.741  - error: host.ubuntu Could not collect system.host.ubuntu states to check for obsolete states: Cannot find view "system"
                                      2024-07-01 19:27:49.743  - error: host.ubuntu  _design/system missing - call node iobroker.js setup
                                      2024-07-01 19:27:49.744  - info: host.ubuntu  no instances found
                                      2024-07-01 19:27:49.745  - info: host.ubuntu no instances found
                                      2024-07-01 19:27:50.339  - info: host.ubuntu Created UUID: 67b55ea4-7e7d-e632-81e0-66bd95578b60
                                      iob diag has finished.
                                      • M MiPl
                                        Skript v.2024-05-22
                                        *** BASE SYSTEM ***
                                                 Icon name: computer
                                              Architecture: arm64
                                        Docker          : false
                                        Kernel          : aarch64
                                        Userland        : 64 bit
                                        CPU threads: 4
                                                         RTC time: n/a
                                                      NTP service: active
                                                  RTC in local TZ: no
                                        pi
                                        HOME=/home/pi
                                        iobroker
                                        HOME=/home/iobroker
                                        Desktop:
                                        Terminal:       tty
                                        *** MEMORY ***
                                        Swap:            0B          0B          0B
                                                  906 M total memory
                                                  223 M used memory
                                                  472 M active memory
                                                  186 M free memory
                                                   38 M buffer memory
                                                  457 M swap cache
                                                    0 M total swap
                                                    0 M used swap
                                                    0 M free swap
                                        *** FILESYSTEM ***
                                        /var:
                                        3.1G    /var/
                                        1.8G    /var/log
                                        1016M   /var/lib
                                        USB-Devices by-id:
                                        /usr/bin/npm            10.7.0
                                        /usr/bin/npx            10.7.0
                                        nodejs:
                                          Version table:
                                        Errors in npm tree:
                                        ioBroker Status
                                        Objects type: jsonl
                                        States  type: jsonl
                                        admin:          6.17.14
                                        Adapter State
                                        + instance is alive
                                        List is empty
                                        Objects and States
                                        Objects:        33
                                        States:         26
                                        Pending Updates: 2
                                        und dann
                                        und das bei nur 1GB RAM, und dann ausgerechnet
                                        motion
                                        das auch noch die Ports blockiert
                                          und dann
                                          motion
                                          MiPl
                                          läuft auf einem Raspi 4 problemlos - iobroker auf Port 8083.
                                          Und auf diesem Raspi 3 ist (derzeit zumindest) noch Ram verfügbar. Daran kann es noch nicht klemmen, oder?
                                          Kann man iobroker nicht aus der shell auf Port 8083 installieren?
                                          Liegt es denn nicht eventuell an
