  4. FoxEss H3 Wechselrichter per Modbus in ioBroker
    6.7k
74 Beiträge 20 Kommentatoren 20.7k Aufrufe 17 Beobachtet
    SuFra
    Hallo zusammen
    Ich habe seit kurzem einen FoxEss H1 Hybrid Wechselrichter.
    Nun wollte ich auch die Daten per ModBus abfragen.
    Als Gateway habe ich von Waveshare den "RS232/485/422 ZU POE ETH (B)". Link
    Einstellungen des Gateways:
    Einstellungen im Adapter:
    Fehlerlog:
    2023-11-25 14:45:45.127	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-11-25 14:45:45.127	debug	Plugin sentry destroyed
    2023-11-25 14:45:45.127	info	terminating
    2023-11-25 14:45:45.126	debug	Closing client on purpose.
    2023-11-25 14:45:45.126	info	Got terminate signal TERMINATE_YOURSELF
    2023-11-25 14:45:42.272	info	Disconnected from slave 10.10.20.115
    2023-11-25 14:45:42.272	debug	Closing client on purpose.
    2023-11-25 14:45:41.276	debug	Cleaning up request fifo.
    2023-11-25 14:45:41.275	debug	Clearing timeout of the current request.
    2023-11-25 14:45:41.275	debug	Socket closed with error
    2023-11-25 14:45:41.273	warn	Poll error count: 1 code: {"err":"timeout","timeout":5000}
    2023-11-25 14:45:41.272	error	Client in error state.
    2023-11-25 14:45:41.272	error	Request timed out.
    2023-11-25 14:45:41.271	warn	Error: undefined
    2023-11-25 14:45:36.269	debug	[DevID_124/holdingRegs] Poll address 31000 - 1 registers
    2023-11-25 14:45:36.269	debug	Initialization of scale factors done!
    2023-11-25 14:45:36.269	debug	[DevID_124] Poll start ---------------------
    2023-11-25 14:45:36.268	info	Connected to slave 10.10.20.115
    2023-11-25 14:45:36.179	debug	Add holdingRegisters.31000_PV1-Voltage: {"_id":"holdingRegisters.31000_PV1-Voltage","type":"state","common":{"name":"","role":"","type":"number","read":true,"write":true,"def":0,"unit":"V"},"native":{"regType":"holdingRegs","address":31000,"deviceId":124,"type":"int16be","len":1,"offset":0,"factor":1,"poll":true}}
    2023-11-25 14:45:36.179	debug	Initialize Objects for holdingRegs: [{"_address":"31000","name":"PV1-Voltage","description":"","unit":"V","type":"int16be","len":1,"factor":1,"offset":0,"formula":"","role":"","room":"","poll":true,"wp":"","cw":false,"isScale":"","address":31000,"deviceId":124,"id":"holdingRegisters.31000_PV1-Voltage"}]
    2023-11-25 14:45:36.179	debug	Initialize Objects for inputRegs: []
    2023-11-25 14:45:36.179	debug	Initialize Objects for coils: []
    2023-11-25 14:45:36.179	debug	Initialize Objects for disInputs: []
    2023-11-25 14:45:36.138	info	starting. Version 5.0.11 in /opt/iobroker/node_modules/iobroker.modbus, node: v18.18.2, js-controller: 5.0.16
    2023-11-25 14:45:36.061	debug	Plugin sentry Initialize Plugin (enabled=true)
    Auf einem Linuxrechner mit mbpoll :
    frank@Ubuntu-1:~$ mbpoll 10.10.20.115 -a 124 -r 30000 -l 1000 -v
    debug enabled
    Set device=10.10.20.115
    mbpoll 1.0-0 - FieldTalk(tm) Modbus(R) Master Simulator
    Copyright © 2015-2019 Pascal JEAN, https://github.com/epsilonrt/mbpoll
    This program comes with ABSOLUTELY NO WARRANTY.
    This is free software, and you are welcome to redistribute it
    under certain conditions; type 'mbpoll -w' for details.
    Connecting to [10.10.20.115]:502
    Set response timeout to 1 sec, 0 us
    Protocol configuration: Modbus TCP
    Slave configuration...: address = [124]
                            start reference = 30000, count = 1
    Communication.........: 10.10.20.115, port 502, t/o 1.00 s, poll rate 1000 ms
    Data type.............: 16-bit register, output (holding) register table
    -- Polling slave 124... Ctrl-C to stop)
    [00][01][00][00][00][06][7C][03][75][2F][00][01]
    Waiting for a confirmation...
    ERROR Connection timed out: select
    Read output (holding) register failed: Connection timed out
    [00][02][00][00][00][06][7C][03][75][2F][00][01]
    [00][03][00][00][00][06][7C][03][75][2F][00][01]
    [00][04][00][00][00][06][7C][03][75][2F][00][01]
    ^C--- 10.10.20.115 poll statistics ---
    4 frames transmitted, 0 received, 3 errors, 100.0% frame loss
    everything was closed.
    Have a nice day !
    Habe mir schon alle Threads zu dem Thema hier im Forum angeschaut, bekomme aber keine Daten...
    Wahrscheinlich übersehe ich da einfach was ;)
    Hoffe ihr könnt mir helfen.
    Grüße Frank
    HA-Cluster 1x NUC11TNHI50L00, 2x NUC11TNHI30L00, 1x BSi3, 1x BSi5
    LXC's: PiHole, Grafana, MariaDB, TasmoAdmin, NTP Server, PeaNUT, ESPHome, paperless-ai, ollama
    VM's: PBS, ioBroker, frigate, paperless, trueNAS (Plex)
    • M MrX552
      Für alle die, die Ihre FoxEss H3 Wechselrichter in ioBroker einbinden möchten, auch einigen erfolglosen Versuchen läuft es nun. Angeschlossen ist ein FoxEss H3-12.0E mit 1x ECM2900 und 2x ECS2900.
      Die FoxEss Cloud und / oder FoxEss App ist ja doch recht langsam mit 5min Updatezeiten!!!
      Benötigt wird:
      1x Elfin EW11 RS485 ->Wifi Adapter (wie es mit anderen funktioniert, weiß ich nicht, habe nur diesen)
      1x Kabel (für kurze Wege reicht ein Stück Lautsprecherkabel)
      1. Der Anschluß erfolgt an die Pins 1 und 2 des RS485 Steckers, Pin 3 und 4 sollten belegt sein und die Verbindung zur DTSU666 sein.
      1. Per WLAN auf den Elfin zugreifen (AP) und unter der Adresse: 10.10.100.254 unter WLAN das eigene WLAN einrichten, anschließend den Elfin neu starten.
      2. Über das eigene Netzwerk auf die IP des Elfin zugreifen und die Einstellungen wie in den folgenden Bildern anpassen:
      Einstellungen jeweils speichern und den Elfin neu starten.
      1. im ioBroker den Modbus Adapter installieren und die Einstellungen wie folgt wählen:
      Die Geräte ID muss die gleiche sein, wie im Wechselrichter eingestellt, zu finden unter:
      Menü -> Konfiguration -> Kommunikation -> RS485 -> DeviceID
      Die IP-Adresse ist die des Elfin EW11
      Die entsprechenden Modbus Adressen gibts hier als xls Datei:
      https://github.com/TonyM1958/HA-FoxESS-Modbus/wiki/H1-H3-Modbus-Map.xls
      Was man mit den Daten macht, sei jedem selbst überlassen!!
      in diesem Sinne
      SuFra
      Hallo, die Exel Datei H1-H3-Modbus-Map.xls ist leider nicht mehr online zu finden.
      Kann die jemand mir schicken?
      f.strauss@gmx.de
        Tiedi
        vielen Dank schonmal für die Dokumentation.
        Kann man die Modbus Register nicht hier direkt reinstellen?
        Funktioniert das auch mit der T-Serie von Fox ESS?
        Ich überlege mir den FOX ESS T15-G3 15kW zu holen.
        • T Tiedi
          MrX552
          @tiedi
          Moin,
          so weit ich das verstanden habe, geht das nicht, man kann die irgendwie bei FoxEss anfordern und darf sie dann wohl nicht öffentlich machen. Ich meine das zumindest irgendwo gelesen zu haben.
          Da es die Datei nicht mehr gibt und ich sie auch gerade nicht mehr finde, geht aber folgendes:
          Link aufrufen und dort die entsprechenden Werte aus dem Code rausnehmen!
          https://github.com/nathanmarlor/foxess_modbus/blob/main/custom_components/foxess_modbus/entities/entity_descriptions.py
          Wenn man ein bisschen scrollt, findet man folgendes:
          _PV_ENTITIES: list[EntityFactory] = [
              _pv_voltage(
                  key="pv1_voltage",
                  addresses=[
                      ModbusAddressesSpec(models=[*H1_SET, KH], input=[11000], holding=[31000]),
                      ModbusAddressesSpec(models=H3_SET, holding=[31000]),
                  name="PV1 Voltage",
          Ich denke, das was man benötigt bekommt man daher!!
          Jörn
            MrX552
            Kleiner Nachtrag für die Modbus Register:
            Man kann kann auch einfach eine kurze EMail an service.de@fox-ess.com schreiben und direkt nach den Modbus-Registern für seinen Wechselrichter fragen. Man bekommt eine Verschwiegenheitserklärung, die man unterschreiben muß (weswegen ich das hier nicht reinstelle) und dann bekommt man innerhalb eines Tages ein pdf zugeschickt, in dem alles steht, was man braucht, oder brauchen könnte.
            Ralla66R 1 Antwort Letzte Antwort
            • M MrX552
              Ralla66R Offline
              Ralla66R Offline
              Ralla66
              @mrx552
              ist es dieses Projekt ?
              • Ralla66R Ralla66
                @mrx552
                MrX552
                @ralla66
                Ja, das ist es, aber es sind nicht alle register aufgeführt!
                I 1 Antwort Letzte Antwort
                • M MrX552
                  @ralla66
                  I Offline
                  I Offline
                  ichderarnd
                  Ich habe hier einen Fox ESS H3 29.9 und mir ist nicht klar, ob ich diesen direkt über RS485 an den Raspberry anbinden kann. Es gibt zwei RS485: Einer ist mit „meter“ beschriftet, das ist die Verbindung zum Zähler im Schrank. Der andere ist mit „ems“ beschriftet und wäre theoretisch frei.
                  Kann ich diesen nutzen, um die Modbus-Kommunikation aufzusetzen? Oder muss ich diesen umständlichen Weg über Wifi gehen, den ich noch nicht so ganz verstanden habe…
                  • I ichderarnd
                    I Offline
                    I Offline
                    ichderarnd
                    Es ist wirklich so einfach: Ich habe mir diesen RS485 auf USB Adaper besorgt:
                    https://www.reichelt.de/raspberry-pi-usb-rs485-schnittstelle-ch340c-rpi-usb-rs485-p242783.html?&nbc=1
                    Dann von einem LAN-Kabel die Stecker abgeschnitten, zwei verdrillte Adern an A und B des „EMS“ Anschlusses des Fox und an A und B des USB-Adapters. Den USB Stecker in den Pi stecken, Modbusadapter installieren, den USB-Port auswählen, Device ID 247 setzen und die Holdingregister anlegen.
                    Lief sofort 👍
                    Jetzt muss ich nur noch sehen, wo ich die Daten für String 3 und folgende herbekomme. Werde die Doku beim Hersteller anfragen.
                    M E 2 Antworten Letzte Antwort
                    • I ichderarnd
                      Lief sofort 👍
                      MrX552
                      @ichderarnd
                      Moin,
                      wie ich das bis jetzt verstanden habe, gibt es String 3 nicht! 1 und 2 werden zusammen verarbeitet und 3 als einzelner String.
                      Ich habe bei mir auf der 1 die Panele auf der Ostseite, auf 2 die Westseite und auf 3 die Südseite (da Ost und West die gleiche Anzahl Panele hat). Mein Eindruck ist aber bisher, das ich jetzt mehr Leistung aus den Panelen ziehe…. Warum auch immer…
                      • M MrX552
                        @ichderarnd
                        Moin,
                        I Offline
                        I Offline
                        ichderarnd
                        @mrx552 sagte in FoxEss H3 Wechselrichter per Modbus in ioBroker:
                        @ichderarnd
                        Moin,
                        Eigentlich sind es 5 Strings, immer zwei an einem MPPT. Mir fehlt noch die Modbus Doku zu dem Teil, um das richtig zuzuordnen.
                        Leider läuft die Modbus-Verbindung aktuell instabil, ab und an Timeouts oder fehlerhafte CRC. Ich finde im Installationshanbuch nix zu Thema Busterminierung. Seltsam…
                        E 1 Antwort Letzte Antwort
                        • I ichderarnd
                          @ichderarnd
                          Moin,
                          exitus
                          welchen modbus könnt ihr mir empfehlen
                          soll wlan und poe haben am besten soll es vom poe switch mit strom versorgt werden.
                          Ist es egal welche man Kauft??
                          oder sollte man den hier in der 1.Post nehmen
                          • D Dirk 6
                            @ottishome Hallo OttisHome
                            Ich habe unser (mein) Problem gefunden.
                            Ich war in der Annahme, dass im Elfin schon serielle Daten angezeigt werden müssen auch wenn keine Register (Holding-Register) angelegt sind!
                            Allein als ich die ersten Register per Hand angelegt habe, wurden auch im Elfin Serielle Datenpakete angezeigt!
                            Ich könnte mir in den Allerwertesten beißen. Wochenlang rumgedoktert! 😬
                            Jetzt aber 😀
                            saylem
                            @dirk-6 Moin.
                            Habe jetzt auch eine Fox was h3 und elfin.
                            Der elfin ist im Heim Netz
                            Und im iobroker ist der Adapter Modbus grün.
                            Nun habe ich auch im Register selber paar Punkte angelegt aber wenn ich dann in die Objekte gehe steht da immer 0 und die wird dann gelb.
                            Der Adapter bleibt selber grün.
                            Woran könnte es liegen?
                            • M MrX552
                              Benötigt wird:
                              in diesem Sinne
                              exitus
                              schrieb am zuletzt editiert von exitus
                              @mrx552 hallo
                              ich habe den h13 10
                              elfin firmware 1.44.1
                              ich bekomme keine verbindung adapter bleibt gelb was mache ich falsch???
                              Habe am wechselrichter pin1 auf elfin A pin 2 auf Elfin B
                              Meine einstellungen
                              das steht in log
                              On error: {"errno":-111,"code":"ECONNREFUSED","syscall":"connect","address":"192.168.0.87","port":502}
                              • E exitus
                                @mrx552 hallo
                                ich habe den h13 10
                                Meine einstellungen
                                das steht in log
                                Dieter_P
                                @exitus said in FoxEss H3 Wechselrichter per Modbus in ioBroker:
                                das steht in log
                                hiernach schlägt die Modbus TCP Verbindung vom Adapter zu Deinem Gateway fehl. Im Screenshot zeigst Du die Einstellungen des Gateways auf der seriellen / Modbus RTU Seite. Insofern solltest Du die TCP Settings prüfen und korrigieren, was nicht heißt, dass die RTU Seite so stimmt (hab ich mir nicht angesehen).
                                • D Dieter_P
                                  das steht in log
                                  exitus
                                  @dieter_p es lag an den TCP port
                                  welche register ist für Netz einspeisung Netztbezug und Heim verbrauch ich finde nichts
                                  • E exitus
                                    Dieter_P
                                    die def zu grid ct /feed_in /grid_consumption sieht recht brauchbar aus: https://forum.iobroker.net/post/1130418
                                    • E Offline
                                      exitus
                                      Weiß jemand wie die modbusregister für String 3 ist für H3 12 e??
                                      • I ichderarnd
                                        Lief sofort 👍
                                        exitus
                                        @ichderarnd hast du es hinbekommen String 3 auszulesen ich finde kein Register für String 3 hast du Info
                                        • E exitus
                                          MrX552
                                          @exitus
                                          Moin,
                                          String 3 "gibt es nicht". Intern werden String 1 und 2 zusammen als pv1 und String 3 als pv2 ausgegeben.
                                          Jörn
