  3. Einsteigerfragen
  4. Zigbee Adapter nach Stromausfall keine Verbindung (gelöst)
    5.4k
148 Beiträge 9 Kommentatoren 20.8k Aufrufe 8 Beobachtet
  • stefu87_CHS stefu87_CH
    @crunchip
    2024-06-22 16:16:28.763 - info: host.Iobroker instance system.adapter.zigbee.0 started with pid 23502
    2024-06-22 16:16:29.687 - debug: zigbee.0 (23502) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2024-06-22 16:16:29.725 - debug: zigbee.0 (23502) Objects client ready ... initialize now
    2024-06-22 16:16:29.726 - debug: zigbee.0 (23502) Objects create System PubSub Client
    2024-06-22 16:16:29.726 - debug: zigbee.0 (23502) Objects create User PubSub Client
    2024-06-22 16:16:29.778 - debug: zigbee.0 (23502) Objects client initialize lua scripts
    2024-06-22 16:16:29.780 - debug: zigbee.0 (23502) Objects connected to redis: 127.0.0.1:9001
    2024-06-22 16:16:29.781 - silly: zigbee.0 (23502) redis psubscribe cfg.o.system.user.*
    2024-06-22 16:16:29.808 - silly: zigbee.0 (23502) redis psubscribe cfg.o.enum.*
    2024-06-22 16:16:29.809 - silly: zigbee.0 (23502) objectDB connected
    2024-06-22 16:16:29.810 - debug: zigbee.0 (23502) Redis States: Use Redis connection: 127.0.0.1:9000
    2024-06-22 16:16:29.828 - debug: zigbee.0 (23502) States create System PubSub Client
    2024-06-22 16:16:29.828 - debug: zigbee.0 (23502) States create User PubSub Client
    2024-06-22 16:16:29.903 - debug: zigbee.0 (23502) States connected to redis: 127.0.0.1:9000
    2024-06-22 16:16:29.903 - silly: zigbee.0 (23502) statesDB connected
    2024-06-22 16:16:29.928 - debug: zigbee.0 (23502) Plugin sentry Initialize Plugin (enabled=true)
    2024-06-22 16:16:30.040 - info: zigbee.0 (23502) starting. Version 1.10.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.14.0, js-controller: 5.0.19
    2024-06-22 16:16:30.050 - debug: zigbee.0 (23502) Using zigbee-herdsman with settings: {"network":{"panID":1207,"extendedPanID":[221,141,221,125,229,221,221,211],"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"ls /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20230218155837-if00","adapter":"ezsp"},"adapter":{"forceStartWithInconsistentAdapterConfiguration":false},"legacy":false}
    2024-06-22 16:16:30.064 - info: zigbee.0 (23502) delete old Backup files. keep only last 10
    2024-06-22 16:16:30.065 - info: zigbee.0 (23502) Starting Zigbee npm ...
    2024-06-22 16:16:30.073 - silly: zigbee.0 (23502) States system redis pmessage system.adapter.zigbee.0.logLevel/system.adapter.zigbee.0.logLevel:{"val":"silly","ack":true,"ts":1719065790065,"q":0,"from":"system.adapter.zigbee.0","lc":1718297685652}
    2024-06-22 16:16:30.077 - debug: zigbee.0 (23502) Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2024_06_22-16_16_30.tar.gz success
    2024-06-22 16:16:30.147 - debug: zigbee.0 (23502) Starting zigbee-herdsman...
    2024-06-22 16:16:30.221 - info: zigbee.0 (23502) Installed Version: iobroker.zigbee@latest
    2024-06-22 16:16:30.264 - silly: zigbee.0 (23502) States user redis pmessage zigbee.0.*/zigbee.0.info.connection:{"val":false,"ack":true,"ts":1719065790263,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1718899786323}
    2024-06-22 16:17:00.258 - error: zigbee.0 (23502) Starting zigbee-herdsman problem : "Failure to connect"
    2024-06-22 16:17:00.259 - error: zigbee.0 (23502) Failed to start Zigbee
    2024-06-22 16:17:00.259 - error: zigbee.0 (23502) Error herdsman start
    2024-06-22 16:17:00.343 - silly: zigbee.0 (23502) States user redis pmessage zigbee.0.*/zigbee.0.info.pairingMessage:{"val":"Error: Starting zigbee-herdsman problem : \"Failure to connect\". undefined","ack":true,"ts":1719065820263,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1719059632123}
    2024-06-22 16:17:00.344 - silly: zigbee.0 (23502) States user redis pmessage zigbee.0.*/zigbee.0.info.connection:{"val":false,"ack":true,"ts":1719065820343,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1718899786323}
    2024-06-22 16:17:10.260 - info: zigbee.0 (23502) Try to reconnect. 1 attempts left
    2024-06-22 16:17:10.260 - info: zigbee.0 (23502) Starting Zigbee npm ...
    2024-06-22 16:17:10.261 - debug: zigbee.0 (23502) Starting zigbee-herdsman...
    2024-06-22 16:17:10.262 - info: zigbee.0 (23502) Installed Version: iobroker.zigbee@latest
    2024-06-22 16:17:40.266 - error: zigbee.0 (23502) Starting zigbee-herdsman problem : "Failure to connect"
    2024-06-22 16:17:40.267 - error: zigbee.0 (23502) Failed to start Zigbee
    2024-06-22 16:17:40.267 - error: zigbee.0 (23502) Error herdsman start
    2024-06-22 16:17:40.273 - silly: zigbee.0 (23502) States user redis pmessage zigbee.0.*/zigbee.0.info.pairingMessage:{"val":"Error: Starting zigbee-herdsman problem : \"Failure to connect\". undefined","ack":true,"ts":1719065860272,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1719059632123}
    2024-06-22 16:17:40.313 - silly: zigbee.0 (23502) States user redis pmessage zigbee.0.*/zigbee.0.info.connection:{"val":false,"ack":true,"ts":1719065860312,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1718899786323}
    AsgothianA Offline
    AsgothianA Offline
    Asgothian
    #74
    @stefu87_ch
    Steckt der Stick in einem usb3 Anschluss ?
    Nutzt du eine usb Verlängerung ?
    • AsgothianA Asgothian
      @stefu87_ch
      stefu87_CHS Offline
      stefu87_CHS Offline
      stefu87_CH
      schrieb am zuletzt editiert von stefu87_CH
      #75
      @asgothian sagte in Zigbee Adapter nach Stromausfall keine Verbindung:
      Nein ist ein USB 2.0 Anschluss
      Ist direkt eingesteckt
      Cores: 1 × 8 = 8 cores
      Threads: 16
      mit Proxmox
      LXC Container mit Iobroker
        AsgothianA Offline
        AsgothianA Offline
        Asgothian
        #76
        @stefu87_ch hast du im Direkten Umfeld etwas via USB3 angeschlossen ? USB3 hat die sehr unangenehme Eigenschaft im Zigbee-Band stören zu können
        A.
          A.
          stefu87_CHS Offline
          stefu87_CHS Offline
          stefu87_CH
          #77
          @asgothian nein da ist nichts.
          Bevor ich die umstellung per Direkt USB verbindung gemacht habe, also über die Anpassung der Daten, hat ja alles funktioniert.
          Das Problem liegt ja daran, das er den Stick nicht erkennt im Zigbee Adapter.
          Threads: 16
          mit Proxmox
            Meister MopperM Online
            Meister Mopper
            schrieb am zuletzt editiert von Meister Mopper
            #78
            @stefu87_ch sagte in Zigbee Adapter nach Stromausfall keine Verbindung:
            Trotzdem kann es ja jetzt die Hardware sein, probier es aus.
            Ich hatte schon oft Fehler, die vorher nicht auftraten, obwohl ich nichts geändert hatte. Vielleicht ist es der Nachbar, oder es lag am Fettgehalt der Sonne :man-shrugging: .
            Proxmox und HA ...
            Ich schreibe den Code nicht mehr selbst – ich schimpfe mit der KI, bis er funktioniert.
              stefu87_CHS Offline
              stefu87_CHS Offline
              stefu87_CH
              #79
              @meister-mopper Habe auch mit einem anderen Sonoff Stick versucht ohne Erfolg. Auch auf meiner Testumgebung, die im Keller ist, hat sich keiner der beiden Sticks verbunden.
              Und im Keller ist nichts anderes als der Intel Nuc
              Threads: 16
              mit Proxmox
                Meister Mopper
                #80
                Ich rede von der Hardware, die mit einer veränderten Umgebung konfrontiert ist.
                Proxmox und HA ...
                  stefu87_CHS Offline
                  stefu87_CHS Offline
                  stefu87_CH
                  #81
                  @meister-mopper Ich wüsste nicht was anderst sein sollte. Es ist nichts dazu gekommen. Es sind ja 2 verschiedene Geräte und auf beiden klappt es nicht.
                  Threads: 16
                  mit Proxmox
                  • stefu87_CHS Offline
                    stefu87_CHS Offline
                    stefu87_CH
                    #82
                    Habe jetzt mal in der Iobroker Shell das ausgeführt und frage mich, sind da alle Berechtigungen freigegeben?
                    admin@Iobroker:~$ ls -la /dev/serial/by-id/
                    total 0
                    drwxr-xr-x 2 root  root      60 Jun 22 16:56 .
                    drwxr-xr-x 3 root  root      60 Jun 22 16:56 ..
                    crw-rw---- 1 admin admin 166, 0 Jun 22 16:56 usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20230218155837-if00
                    Threads: 16
                    mit Proxmox
                      total 0
                      #83
                      Da darf nur der user admin und dessen Gruppe was melden. Der iobroker ist aber mit Sicherheit nicht in dieser Gruppe enthalten. Üblich ist sowas:
                      echad@chet:~ $ ls -la /dev/serial/by-id/usb-Silicon_Labs_slae.sh_cc2652rb_stick_-_slaesh_s_iot_stuff_00_12_4B_00_23_93_2C_A8-if00-port0
                      lrwxrwxrwx 1 root root 13 Jun 21 14:43 /dev/serial/by-id/usb-Silicon_Labs_slae.sh_cc2652rb_stick_-_slaesh_s_iot_stuff_00_12_4B_00_23_93_2C_A8-if00-port0 -> ../../ttyUSB0
                      echad@chet:~ $ ls -la /dev/ttyUSB0
                      crw-rw---- 1 root dialout 188, 0 Jun 22 14:45 /dev/ttyUSB0
                      echad@chet:~ $
                      Wie kommt da admin:admin her? Das ist absolut unüblich.
                      Davon ab liegen in /dev/serial/by-id/ nur Links zu den eigentlichen Geräten drin. Die finden sich dann in /dev/ wieder.
                        echad@chet:~ $
                        stefu87_CHS Offline
                        stefu87_CHS Offline
                        stefu87_CH
                        #84
                        @thomas-braun sagte in Zigbee Adapter nach Stromausfall keine Verbindung:
                        Wieso da 2 mal admin drin sind, weiss ich auch nicht, keine Ahnung wie die da rein kommen. Habe ja nichts verändert ausser die Sache mit dem Zigbee Stick.
                        Threads: 16
                        mit Proxmox
                          #85
                          @stefu87_ch
                          Das ist ein LXC? Dann ist das falsch durchgereicht worden.
                            @stefu87_ch
                            stefu87_CHS Offline
                            stefu87_CHS Offline
                            stefu87_CH
                            #86
                            @thomas-braun Ja ist ein LXC Container
                            Threads: 16
                            mit Proxmox
                            Thomas BraunT M 2 Antworten Letzte Antwort
                              #87
                              @stefu87_ch
                              Da bin ich dann wieder raus.
                                M Online
                                M Online
                                mrjeschke
                                #88
                                @stefu87_ch
                                Welche id hat der user iobroker?
                                In der iobroker-Konsole.
                                sudo -u iobroker id
                                • M mrjeschke
                                  @stefu87_ch
                                  sudo -u iobroker id
                                  stefu87_CHS Offline
                                  stefu87_CHS Offline
                                  stefu87_CH
                                  #89
                                  @mrjeschke sagte in Zigbee Adapter nach Stromausfall keine Verbindung:
                                  sudo -u iobroker id
                                  uid=1000(iobroker) gid=1000(iobroker) groups=1000(iobroker),5(tty),20(dialout),29(audio),44(video),46(plugdev)
                                  Threads: 16
                                  mit Proxmox
                                    sudo -u iobroker id
                                    M Online
                                    M Online
                                    mrjeschke
                                    #90
                                    @stefu87_ch
                                    Sorry, das hatte ich befürchtet.
                                    Normalerweise hat der user iobroker 1001/1001
                                    Ändere im device-passtrough die UID/GID auf 1000 dann sollten die Rechte hoffentlich passen.
                                    • M mrjeschke
                                      @stefu87_ch
                                      stefu87_CHS Offline
                                      stefu87_CHS Offline
                                      stefu87_CH
                                      #91
                                      @mrjeschke
                                      total 0
                                      drwxr-xr-x 2 root     root         60 Jun 23 10:08 .
                                      drwxr-xr-x 3 root     root         60 Jun 23 10:08 ..
                                      crw-rw---- 1 iobroker iobroker 166, 0 Jun 23 10:08 usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20230218155837-if00
                                      Threads: 16
                                      mit Proxmox
                                        stefu87_CHS Offline
                                        stefu87_CH
                                        #92
                                        @mrjeschke habe jetzt mal zum Testen den Mode auf 0666 geändert und erhalte nun diese Rechte:
                                        total 0
                                        drwxr-xr-x 2 root     root         60 Jun 23 10:31 .
                                        drwxr-xr-x 3 root     root         60 Jun 23 10:31 ..
                                        crw-rw-rw- 1 iobroker iobroker 166, 0 Jun 23 10:31 usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20230218155837-if00
                                        Threads: 16
                                        mit Proxmox
                                          total 0
                                          M Online
                                          M Online
                                          mrjeschke
                                          #93
                                          @stefu87_ch
                                          Das sieht doch gut aus.
                                          Aber was sagt der Adapter?
                                          Gleiche, andere Fehler?
