  4. invalid Key bei Zugriff auf iobroker
33 Beiträge 7 Kommentatoren 4.0k Aufrufe 4 Beobachtet
  • L Loco
    Hallo Leute!
    Nach mühsamer Neuinstallation von VIs und iobroker läuft meine VIS endlich wieder, jedoch komme ich nicht mehr auf iobroker. Wenn ich die Adresse 192.168.220.191:8081 oder http://192.168.220.191:8081/#tab-intro eingebe, kommt sofort die Meldung invalid key im Browser. Hätte ihr eine Idee was ich machen könnte?
    iob diag liefert folgendes:
    The state system.host.raspberrypi.versions.nodeNewestNext was not found!
    The state system.host.raspberrypi.versions.npmNewestNext was not found!
    The state system.host.raspberrypi.versions.nodeCurrent was not found!
    Skript v.2024-05-22
    *** BASE SYSTEM ***
     Static hostname: raspberrypi
           Icon name: computer
              Kernel: Linux 6.6.20+rpt-rpi-v8
        Architecture: arm64
    Model           : Raspberry Pi 4 Model B Rev 1.2
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     12:06:59 up 16:22,  2 users,  load average: 0.53, 0.27, 0.21
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    ~ Under-voltage has occurred
    ~ Arm frequency capping has occurred
    *** Time and Time Zones ***
                   Local time: Fri 2024-06-14 12:06:59 CEST
               Universal time: Fri 2024-06-14 10:06:59 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    HOME=/home/ioBroker
    GROUPS=ioBroker adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    *** Display-Server-Setup ***
    Display-Server: false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            4.0G        986M        1.4G        1.2M        1.7G        3.0G
    Swap:           104M          0B        104M
    Total:          4.1G        986M        1.5G
    Active iob-Instances:   25
             3792 M total memory
              941 M used memory
              939 M active memory
             1253 M inactive memory
             1334 M free memory
              154 M buffer memory
             1438 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    top - 12:07:00 up 16:22,  2 users,  load average: 0.53, 0.27, 0.21
    Tasks: 175 total,   1 running, 174 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 20.0 us, 20.0 sy,  0.0 ni, 40.0 id, 20.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   3792.1 total,   1333.8 free,    941.9 used,   1593.1 buff/cache
    MiB Swap:    100.0 total,    100.0 free,      0.0 used.   2850.1 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    udev           devtmpfs  1.6G     0  1.6G   0% /dev
    tmpfs          tmpfs     380M  1.2M  379M   1% /run
    /dev/mmcblk0p2 ext4       29G  6.0G   22G  22% /
    tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
    /dev/mmcblk0p1 vfat      510M   63M  448M  13% /boot/firmware
    tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
    [Thu Jun 13 19:44:35 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:84:3E:C9 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=d17a74ee-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=DE
    [Thu Jun 13 19:44:38 2024] EXT4-fs (mmcblk0p2): mounted filesystem 93c89e92-8f2e-4522-ad32-68faed883d2f ro with ordered data mode. Quota mode: none.
    [Thu Jun 13 19:44:41 2024] EXT4-fs (mmcblk0p2): re-mounted 93c89e92-8f2e-4522-ad32-68faed883d2f r/w. Quota mode: none.
    Show mounted filesystems:
    TARGET                                                  SOURCE         FSTYPE      OPTIONS
    /                                                       /dev/mmcblk0p2 ext4        rw,noatime
    |-/sys                                                  sysfs          sysfs       rw,nosuid,nodev,noexec,relatime
    | |-/sys/kernel/security                                securityfs     securityfs  rw,nosuid,nodev,noexec,relatime
    | |-/sys/fs/cgroup                                      cgroup2        cgroup2     rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
    | |-/sys/fs/pstore                                      pstore         pstore      rw,nosuid,nodev,noexec,relatime
    | |-/sys/fs/bpf                                         bpf            bpf         rw,nosuid,nodev,noexec,relatime,mode=700
    | |-/sys/kernel/debug                                   debugfs        debugfs     rw,nosuid,nodev,noexec,relatime
    | |-/sys/kernel/tracing                                 tracefs        tracefs     rw,nosuid,nodev,noexec,relatime
    | |-/sys/kernel/config                                  configfs       configfs    rw,nosuid,nodev,noexec,relatime
    | `-/sys/fs/fuse/connections                            fusectl        fusectl     rw,nosuid,nodev,noexec,relatime
    |-/proc                                                 proc           proc        rw,relatime
    | `-/proc/sys/fs/binfmt_misc                            systemd-1      autofs      rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=1140
    |   `-/proc/sys/fs/binfmt_misc                          binfmt_misc    binfmt_misc rw,nosuid,nodev,noexec,relatime
    |-/dev                                                  udev           devtmpfs    rw,nosuid,relatime,size=1671540k,nr_inodes=417885,mode=755
    | |-/dev/pts                                            devpts         devpts      rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
    | |-/dev/shm                                            tmpfs          tmpfs       rw,nosuid,nodev
    | `-/dev/mqueue                                         mqueue         mqueue      rw,nosuid,nodev,noexec,relatime
    |-/run                                                  tmpfs          tmpfs       rw,nosuid,nodev,noexec,relatime,size=388308k,mode=755
    | |-/run/lock                                           tmpfs          tmpfs       rw,nosuid,nodev,noexec,relatime,size=5120k
    | |-/run/credentials/systemd-sysctl.service             ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
    | |-/run/credentials/systemd-sysusers.service           ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
    | |-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
    | |-/run/rpc_pipefs                                     sunrpc         rpc_pipefs  rw,relatime
    | |-/run/credentials/systemd-tmpfiles-setup.service     ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
    | `-/run/user/1000                                      tmpfs          tmpfs       rw,nosuid,nodev,relatime,size=388304k,nr_inodes=97076,mode=700,uid=1000,gid=1000
    `-/boot/firmware                                        /dev/mmcblk0p1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    636M    /var/
    325M    /var/cache
    319M    /var/cache/apt
    206M    /var/cache/apt/archives
    166M    /var/lib
    Archived and active journals take up 44.0M in the file system.
    /opt/iobroker/backups:
    89M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    762M    /opt/iobroker/iobroker-data/
    695M    /opt/iobroker/iobroker-data/files
    156M    /opt/iobroker/iobroker-data/files/vis-2
    90M     /opt/iobroker/iobroker-data/files/echarts.admin
    81M     /opt/iobroker/iobroker-data/files/vis-2/static
    24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.5f66c5d9.js.map
    24M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.9f2a6569.js.map
    24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.5f66c5d9.js.map
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
    20M     /opt/iobroker/iobroker-data/files/cameras.admin/static/js/main.9f324f1d.js.map
    USB-Devices by-id:
    No Devices found 'by-id'
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.14.0
    /usr/bin/node           v20.14.0
    /usr/bin/npm            10.7.0
    /usr/bin/npx            10.7.0
    /usr/bin/corepack       0.28.1
    nodejs:
      Installed: 20.14.0-1nodesource1
      Candidate: 20.14.0-1nodesource1
      Version table:
     *** 20.14.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         18.19.0+dfsg-6~deb12u1 500
            500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
         18.13.0+dfsg1-1 500
            500 http://deb.debian.org/debian bookworm/main arm64 Packages
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.19
    admin:          6.3.5
    javascript:     7.1.4
    nodejs modules from github:     0
    Adapter State
    + system.adapter.accuweather.0            : accuweather           : raspberrypi                              -  enabled, compact enabled (group 1)
      system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, compact disabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled, compact disabled
    + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled, compact enabled (group 1)
    + system.adapter.broadlink2.0             : broadlink2            : raspberrypi                              -  enabled
    + system.adapter.cameras.0                : cameras               : raspberrypi                              -  enabled, compact disabled, port: 8081, bind: 192.168.220.191
    + system.adapter.chromecast.0             : chromecast            : raspberrypi                              -  enabled, compact enabled (group 1)
      system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled, compact enabled (group 1)
    + system.adapter.deyeidc.0                : deyeidc               : raspberrypi                              -  enabled, compact disabled, port: 8899
      system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled, compact enabled (group 1)
    + system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled, compact disabled
      system.adapter.flot.0                   : flot                  : raspberrypi                              -  enabled
    + system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled, compact enabled (group 1)
    + system.adapter.history.0                : history               : raspberrypi                              -  enabled, compact enabled (group 1)
      system.adapter.hue-extended.0           : hue-extended          : raspberrypi                              -  enabled, compact enabled (group 1)
      system.adapter.hue-extended.1           : hue-extended          : raspberrypi                              -  enabled, compact enabled (group 1)
      system.adapter.hue-extended.2           : hue-extended          : raspberrypi                              -  enabled, compact enabled (group 1)
    + system.adapter.hue.0                    : hue                   : raspberrypi                              -  enabled, compact enabled (group 1), port: 443
    + system.adapter.hue.1                    : hue                   : raspberrypi                              -  enabled, compact enabled (group 1), port: 443
    + system.adapter.hue.2                    : hue                   : raspberrypi                              -  enabled, compact enabled (group 1), port: 443
      system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled, compact enabled (group 1)
      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: raspberrypi                              -  enabled
      system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi                              -  enabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              -  enabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              -  enabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: raspberrypi                              -  enabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : raspberrypi                              -  enabled
    + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled, compact disabled
    + system.adapter.net-tools.0              : net-tools             : raspberrypi                              -  enabled, compact enabled (group 1)
      system.adapter.onvif.0                  : onvif                 : raspberrypi                              -  enabled, compact enabled (group 1)
    + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled, compact disabled
    + system.adapter.pollenflug.0             : pollenflug            : raspberrypi                              -  enabled, compact enabled (group 1)
    + system.adapter.signal-cmb.0             : signal-cmb            : raspberrypi                              -  enabled, compact enabled (group 1)
    + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, compact disabled, port: 1883, bind: 0.0.0.0
    + system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi                              -  enabled, compact disabled
    + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled, compact disabled
      system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled, compact enabled (group 1)
    + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled, compact enabled (group 1)
    + system.adapter.vesync.0                 : vesync                : raspberrypi                              -  enabled, compact disabled
      system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              -  enabled
      system.adapter.vis-history.0            : vis-history           : raspberrypi                              -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              -  enabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              -  enabled, compact enabled (group 1)
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              -  enabled
      system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi                              -  enabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              -  enabled
      system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              -  enabled
      system.adapter.vis-players.0            : vis-players           : raspberrypi                              -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
      system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              -  enabled
      system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled, compact disabled
    + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, compact enabled (group 1), port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.wifilight.0              : wifilight             : raspberrypi                              -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): beta
    Installed ioBroker-Instances
    Used repository: beta
    Adapter    "accuweather"  : 1.4.0    , installed 1.2.4  [Updatable]
    Adapter    "admin"        : 6.17.14  , installed 6.3.5  [Updatable]
    Adapter    "alexa2"       : 3.26.5   , installed 3.25.2 [Updatable]
    Adapter    "backitup"     : 3.0.3    , installed 2.8.1  [Updatable]
    Adapter    "broadlink2"   : 2.3.0    , installed 2.1.5  [Updatable]
    Adapter    "cameras"      : 2.0.8    , installed 1.2.2  [Updatable]
    Adapter    "chromecast"   : 3.4.0    , installed 2.3.1  [Updatable]
    Adapter    "daswetter"    : 3.1.15   , installed 3.1.8  [Updatable]
    Adapter    "deyeidc"      : 0.0.14   , installed 0.0.14
    Adapter    "discovery"    : 4.5.0    , installed 3.0.3  [Updatable]
    Adapter    "echarts"      : 1.8.1    , installed 1.5.4  [Updatable]
    Adapter    "fritzdect"    : 2.5.9    , installed 2.3.1  [Updatable]
    Adapter    "history"      : 3.0.1    , installed 2.2.4  [Updatable]
    Adapter    "hue"          : 3.11.0   , installed 3.7.1  [Updatable]
    Adapter    "ical"         : 1.15.0   , installed 1.13.2 [Updatable]
    Adapter    "icons-mfd-png": 1.2.1    , installed 1.1.0  [Updatable]
    Adapter    "icons-mfd-svg": 1.2.0    , installed 1.1.0  [Updatable]
    Adapter    "javascript"   : 8.5.2    , installed 7.1.4  [Updatable]
    Controller "js-controller": 6.0.4    , installed 5.0.19 [Updatable]
    Adapter    "net-tools"    : 1.0.11   , installed 0.2.0  [Updatable]
    Adapter    "onvif"        : 1.1.4    , installed 0.4.4  [Updatable]
    Adapter    "ping"         : 1.6.2    , installed 1.5.3  [Updatable]
    Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
    Adapter    "signal-cmb"   : 0.3.0    , installed 0.3.0
    Adapter    "socketio"     : 6.7.0    , installed 6.6.0  [Updatable]
    Adapter    "sonoff"       : 3.1.0    , installed 2.5.7  [Updatable]
    Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
    Adapter    "tankerkoenig" : 3.4.0    , installed 2.1.1  [Updatable]
    Adapter    "tr-064"       : 4.3.0    , installed 4.2.16 [Updatable]
    Adapter    "trashschedule": 3.3.0    , installed 2.0.3  [Updatable]
    Adapter    "vesync"       : 0.0.7    , installed 0.0.5  [Updatable]
    Adapter    "vis"          : 1.5.6    , installed 1.4.15 [Updatable]
    Adapter    "vis-hqwidgets": 1.5.1    , installed 1.3.1  [Updatable]
    Adapter    "vis-icontwo"  : 1.5.0    , installed 0.90.0 [Updatable]
    Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.0.12 [Updatable]
    Adapter    "vis-justgage" : 2.1.7    , installed 1.0.2  [Updatable]
    Adapter    "vis-material-advanced": 1.7.4, installed 1.7.2 [Updatable]
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "vis-weather"  : 2.5.9    , installed 2.5.6  [Updatable]
    Adapter    "web"          : 6.2.6    , installed 6.1.10 [Updatable]
    Adapter    "wifilight"    : 1.2.2    , installed 1.1.4  [Updatable]
    Adapter    "ws"           : 2.6.1    , installed 2.5.8  [Updatable]
    Objects and States
    Objects:        10754
    States:         8987
    Hit:1 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:2 http://deb.debian.org/debian bookworm InRelease
    Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists...
    Pending Updates: 23
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       140543     15690/io.sonoff.0
    tcp        0      0 192.168.220.191:8081    0.0.0.0:*               LISTEN      1001       140610     15746/io.cameras.0
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       137914     15531/iobroker.js-c
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       137909     15531/iobroker.js-c
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6204       698/sshd: /usr/sbin
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       139723     15586/iobroker.js-c
    tcp6       0      0 :::22                   :::*                    LISTEN      0          6215       698/sshd: /usr/sbin
    udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       139660     15731/io.broadlink2
    udp        0      0 0.0.0.0:54058           0.0.0.0:*                           1001       138138     15731/io.broadlink2
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       138110     15586/iobroker.js-c
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        3065       526/avahi-daemon: r
    udp        0      0 0.0.0.0:45007           0.0.0.0:*                           104        3067       526/avahi-daemon: r
    udp6       0      0 :::42182                :::*                                104        3068       526/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                104        3066       526/avahi-daemon: r
    udp6       0      0 fe80::b8c3:506d:cd3:546 :::*                                0          1780       634/NetworkManager
    2024-06-14 12:07:27.172  - error: hue.1 (COMPACT) Could not poll all: Cannot read properties of undefined (reading 'configuration')
    2024-06-14 12:07:27.798  - error: hue.2 (COMPACT) connect ECONNREFUSED 192.168.220.144:443
    2024-06-14 12:07:27.799  - warn: hue.2 (COMPACT) Could not get configuration from HUE bridge (192.168.220.144:443)
    2024-06-14 12:07:28.318  - error: hue.1 (COMPACT) connect ECONNREFUSED 192.168.220.133:443
    2024-06-14 12:07:28.318  - warn: hue.1 (COMPACT) Could not get configuration from HUE bridge (192.168.220.133:443)
    2024-06-14 12:07:28.863  - error: hue.2 (COMPACT) Could not poll all: Cannot read properties of undefined (reading 'configuration')
    2024-06-14 12:07:32.816  - error: hue.2 (COMPACT) connect ECONNREFUSED 192.168.220.144:443
    2024-06-14 12:07:32.816  - warn: hue.2 (COMPACT) Could not get configuration from HUE bridge (192.168.220.144:443)
    2024-06-14 12:07:32.966  - error: hue.0 (COMPACT) connect EHOSTUNREACH 192.168.220.115:443
    2024-06-14 12:07:32.966  - warn: hue.0 (COMPACT) Could not get configuration from HUE bridge (192.168.220.115:443)
    2024-06-14 12:07:33.328  - error: hue.1 (COMPACT) connect ECONNREFUSED 192.168.220.133:443
    2024-06-14 12:07:33.328  - warn: hue.1 (COMPACT) Could not get configuration from HUE bridge (192.168.220.133:443)
    2024-06-14 12:07:37.177  - error: hue.0 (COMPACT) Could not poll all: Cannot read properties of undefined (reading 'configuration')
    2024-06-14 12:07:37.178  - error: hue.1 (COMPACT) Could not poll all: Cannot read properties of undefined (reading 'configuration')
    2024-06-14 12:07:37.835  - error: hue.2 (COMPACT) connect ECONNREFUSED 192.168.220.144:443
    2024-06-14 12:07:37.835  - warn: hue.2 (COMPACT) Could not get configuration from HUE bridge (192.168.220.144:443)
    2024-06-14 12:07:38.351  - error: hue.1 (COMPACT) connect ECONNREFUSED 192.168.220.133:443
    2024-06-14 12:07:38.351  - warn: hue.1 (COMPACT) Could not get configuration from HUE bridge (192.168.220.133:443)
    2024-06-14 12:07:38.867  - error: hue.2 (COMPACT) Could not poll all: Cannot read properties of undefined (reading 'configuration')
    2024-06-14 12:07:41.026  - error: hue.0 (COMPACT) connect EHOSTUNREACH 192.168.220.115:443
    2024-06-14 12:07:41.026  - warn: hue.0 (COMPACT) Could not get configuration from HUE bridge (192.168.220.115:443)
    2024-06-14 12:07:42.958  - error: hue.2 (COMPACT) connect ECONNREFUSED 192.168.220.144:443
    2024-06-14 12:07:42.959  - warn: hue.2 (COMPACT) Could not get configuration from HUE bridge (192.168.220.144:443)
    2024-06-14 12:07:43.362  - error: hue.1 (COMPACT) connect ECONNREFUSED 192.168.220.133:443
    2024-06-14 12:07:43.362  - warn: hue.1 (COMPACT) Could not get configuration from HUE bridge (192.168.220.133:443)
    iob diag has finished.
    @loco sagte: Idee was ich machen könnte?
    iob start admin.0
    L 1 Antwort Letzte Antwort
      iob start admin.0
      Loco
      @paul53 leider kein Erfolg....
      • L Loco
        @loco sagte: leider kein Erfolg....
        Läuft die Admin-Instanz jetzt oder kamen Fehlermeldungen beim Start?
        iob list instances
        L HomoranH 2 Antworten Letzte Antwort
          iob list instances
          Loco
          ioBroker@raspberrypi:~ $ iob list instances
          + instance is alive
          • L Loco
            Hallo Leute!
            Skript v.2024-05-22
            *** BASE SYSTEM ***
                   Icon name: computer
                Architecture: arm64
            Docker          : false
            Kernel          : aarch64
            Userland        : 64 bit
            CPU threads: 4
            Current issues:
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            HOME=/home/ioBroker
            iobroker
            HOME=/home/iobroker
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Swap:           104M          0B        104M
                     3792 M total memory
                      941 M used memory
                      939 M active memory
                     1334 M free memory
                      154 M buffer memory
                     1438 M swap cache
                       99 M total swap
                        0 M used swap
                       99 M free swap
            *** FILESYSTEM ***
            /var:
            636M    /var/
            325M    /var/cache
            319M    /var/cache/apt
            166M    /var/lib
            USB-Devices by-id:
            /usr/bin/npm            10.7.0
            /usr/bin/npx            10.7.0
            nodejs:
              Version table:
                 18.13.0+dfsg1-1 500
            Errors in npm tree:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            admin:          6.3.5
            javascript:     7.1.4
            Adapter State
            + instance is alive
            Objects and States
            Objects:        10754
            States:         8987
            Pending Updates: 23
            @loco sagte in invalid Key bei Zugriff auf iobroker:
            Pending Updates: 23
            Updaten...
            iob stop
            sudo apt update
            sudo apt full-upgrade
            sudo reboot
            Den ioBroker auch updaten, besser aber auf das Stable-Repo zurückgehen.
              iob list instances
              @paul53 sagte in invalid Key bei Zugriff auf iobroker:
              nöö
              • system.adapter.accuweather.0 : accuweather : raspberrypi - enabled, compact enabled (group 1)
                nöö
                Loco
                ich hab mal iob upgrade ausgeführt. Alle Adapter aktualisiert. Jetz geht es wieder.
                Hab keine Ahnung warum! Wie auch immer, Chat kann geschloßen werden....
                Danke für eure Hilfe!
                Ro75R Thomas BraunT 2 Antworten Letzte Antwort
                • L Loco
                  Ro75R Online
                  Ro75R Online
                  Ro75
                  @loco und an das Netzteil denken.
                  Ro75.
                  • L Loco
                    Weil die Kisten halt am besten laufen, wenn die vollständig auf einem aktuellen Stand sind, deswegen.
                    • Ro75R Ro75
                      Ro75.
                      Loco
                      @ro75
                      Hab ich schon! Hab jetzt ein 3A Netzteil dran. Keine weiteren Meldungen bzgl. Undervoltage bisher gesehen...
                        Loco
                        Macht Sinn !!!! Sind aber immer diese Meldungen mit denen ein "etwas" Unwissender dann nicht so klarkommt und sich dann da durchbeißen muß (oder will). Finde es aber super das es dieses Forum gibt wo man (Mann) dann da auch mal nachfragen kann...
                        Schönes Wochenende euch allen und genießt die Fußball-EM
                        • L Loco
                          Loco
                          Gibt doch ein Problem, nach Update aller Adapter öffnet das Widget eCharts keine Diagramm mehr:
                          Die Diagramm sind da bei Zugriff auf eCharts über iobroker werden die Diagramm dargestellt. In der VIS jedoch nicht. Hätte jemand eine Idee warum?
                          Ach ja, die neuste Version von eCharts funzzt überhaupt nicht. Die Instanz wird unter iobroker nichtmal geöffnet. Bin auf Version 1.5.3 zurück, diese Instanz läßt sich öffnen und es werden Diagramme angezeigt (aber im Widget nicht).
                          BananaJoeB amg_666A 2 Antworten Letzte Antwort
                          • L Loco
                            BananaJoeB Offline
                            BananaJoeB Offline
                            BananaJoe
                            @loco wie sind die Einstellungen im Web-Adapter? Screenshot. Könnte an der Web-Socket-Einstellung liegen
                            • L Loco
                              amg_666A Offline
                              amg_666A Offline
                              amg_666
                              @loco Dann wirf mal einen Blick ins Github. Die Version 1.8.1 von eCharts hat da ein Problem, das ist bereits gemeldet.
                              Ich bin da gestern auch drauf reingefallen :-)
                              https://github.com/ioBroker/ioBroker.echarts/issues/630
                              • amg_666A amg_666
                                BananaJoeB Offline
                                BananaJoeB Offline
                                BananaJoe
                                @amg_666 Ich hatte verstanden er ist auf die 1.5.3 zurück und es geht immer noch nicht
                                @Loco schon mal das System neu gestartet?
                                • BananaJoeB BananaJoe
                                  Loco
                                  @bananajoe: ich mußte wegen einem anderen Fehler ein Backup zurückspielen. Interesanterweise läuft eCharts jetzt in Version 1.8.1. Die Diagramme werden sauber angezeigt - keine Fehler mehr.
                                  Kann euch nicht sagen warum es jetzt geht,...
                                  • L Loco
                                    amg_666A Offline
                                    amg_666A Offline
                                    amg_666
                                    Bei der 1.8.1 werden bei mir die Diagramme in meiner VIS korrekt angezeigt, aber wenn ich auf dem iobroker admin links im Menu auf ECharts klicke, dann habe ich einen leeren Bildschirm
                                    HomoranH BananaJoeB 2 Antworten Letzte Antwort
                                    • amg_666A amg_666
                                      @amg_666 wenn ich das noch richtig in Erinnerung habe führt der Link in der admin-Sidebar über den Adminport :8081.
                                      in der vis über web :8082
                                      • amg_666A amg_666
                                        BananaJoeB Offline
                                        BananaJoeB Offline
                                        BananaJoe
                                        @amg_666 sagte in invalid Key bei Zugriff auf iobroker:
                                        Bei funktioniert 1.8.1 - außer auf einem Fire-Tablet. Schon älter, ungepatcht, mit Fully Kiosk. Da kommt dann einfach nichts.
                                        Eigentlich wollte ich das Tablet gar nicht anfassen, habe ich in 3 Jahren vielleicht 3 mal neu gestartet, das läuft einfach ...
                                          amg_666A Offline
                                          amg_666A Offline
                                          amg_666
                                          @bananajoe ich hab das nur gepostet um von @Loco zu erfahren, ob bei ihm wirklich alles funkioniert.
                                          Der Fehler, den ich beschrieben habe, ist bekannt und als issue in github gemeldet, ich bin da nicht alleine :-) Man sieht es auch im Admin, bei der 1.8.1 fehlt im iobroker admin das "Logo" neben EChart.
