  4. Beta Test js-controller Kiera (v6.0)
    6.7k
betajs-controllerkieratest
331 Beiträge 39 Kommentatoren 117.3k Aufrufe 42 Beobachtet
    anwa
    schrieb am zuletzt editiert von anwa
    Kalender (calendar) 1.2.0
    host.ioBroker
    2024-06-11 21:04:44.153	info	Restart adapter system.adapter.calendar.0 because enabled
    host.ioBroker
    2024-06-11 21:04:44.153	error	instance system.adapter.calendar.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.ioBroker
    2024-06-11 21:04:44.153	error	Caught by controller[0]: Node.js v20.14.0
    host.ioBroker
    2024-06-11 21:04:44.153	error	Caught by controller[0]: at node:internal/main/run_main_module:28:49
    host.ioBroker
    2024-06-11 21:04:44.153	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:174:12)
    host.ioBroker
    2024-06-11 21:04:44.153	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1024:12)
    host.ioBroker
    2024-06-11 21:04:44.153	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1208:32)
    host.ioBroker
    2024-06-11 21:04:44.153	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
    host.ioBroker
    2024-06-11 21:04:44.153	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1358:14)
    host.ioBroker
    2024-06-11 21:04:44.153	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.calendar/main.js:17:30)
    host.ioBroker
    2024-06-11 21:04:44.153	error	Caught by controller[0]: TypeError: Class extends value #<Object> is not a constructor or null
    host.ioBroker
    2024-06-11 21:04:44.153	error	Caught by controller[0]: ^
    host.ioBroker
    2024-06-11 21:04:44.152	error	Caught by controller[0]: class Calendar extends utils.Adapter {
    host.ioBroker
    2024-06-11 21:04:44.152	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.calendar/main.js:17
    Vermutlich der gleiche Fehler...
    • A anwa
      Sorry, immer die neueste... 0.4.14
      mcm1957M Online
      mcm1957M Online
      mcm1957
      @anwa said in Beta Test js-controller Kiera (v6.0):
      @foxriver76
      Bitte sourceanalytix auf die inkompaibel Liste.
      Im Latest ist 0.4.14 mit "@iobroker/adapter-core": "^2.6.0" - das funkt nicht.
      @Dutchman muss da ne neue Release mit aktuellem Adaptercore erstellen (außer du hast da Zugriff - hab aber keine Ahnung welchen Status die zwischenzeitlichen WIP Änderungen haben.
      Hinweis:: sourceanalytix ist nicht im stable
      Support Repositoryverwaltung.
      LESEN - gute Forenbeitrage
        anwa
        E-Charts (echarts) 1.7.2
        host.ioBroker
        2024-06-11 21:06:38.263	info	Restart adapter system.adapter.echarts.0 because enabled
        host.ioBroker
        2024-06-11 21:06:38.263	error	instance system.adapter.echarts.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        host.ioBroker
        2024-06-11 21:06:38.263	error	Caught by controller[0]: Node.js v20.14.0
        host.ioBroker
        2024-06-11 21:06:38.263	error	Caught by controller[0]: at node:internal/main/run_main_module:28:49
        host.ioBroker
        2024-06-11 21:06:38.263	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:174:12)
        host.ioBroker
        2024-06-11 21:06:38.262	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1024:12)
        host.ioBroker
        2024-06-11 21:06:38.262	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1208:32)
        host.ioBroker
        2024-06-11 21:06:38.262	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
        host.ioBroker
        2024-06-11 21:06:38.262	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1358:14)
        host.ioBroker
        2024-06-11 21:06:38.262	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.echarts/main.js:325:5)
        host.ioBroker
        2024-06-11 21:06:38.262	error	Caught by controller[0]: at startAdapter (/opt/iobroker/node_modules/iobroker.echarts/main.js:70:15)
        host.ioBroker
        2024-06-11 21:06:38.262	error	Caught by controller[0]: TypeError: utils.Adapter is not a constructor
        host.ioBroker
        2024-06-11 21:06:38.262	error	Caught by controller[0]: ^
        host.ioBroker
        2024-06-11 21:06:38.262	error	Caught by controller[0]: adapter = new utils.Adapter(options);
        host.ioBroker
        2024-06-11 21:06:38.262	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.echarts/main.js:70
        host.ioBroker
        2024-06-11 21:06:37.428	info	instance system.adapter.echarts.0 started with pid 212103
        host.ioBroker
        2024-06-11 21:06:36.303	info	"system.adapter.echarts.0" enabled
        • JB_SullivanJ Offline
          JB_Sullivan
          Ist nur eine Info Meldung, aber seit dem Update auf den 6er Controller, wirft einer von 5! Shelly 3EM diese Meldung ins Log.
          Alles Shellys sind gleich konfiguriert und auf Berlin konfiguriert, aber nur einer wirft diese Meldung.
          Weder in den ioB Basiseinstellungen noch in den Shelly Adapter Einstellungen gibt es einen Punkt wo man UTC einstellen oder ändern könnte.
          Hängt das ggf. mit dem 6er Controller zusammen?
          shelly.0
          11596	2024-06-11 20:59:21.019	info	[Sys.timezone] 10.122.60.105 (shellyem3 / shellyem3-8CAAB561EFDE / SHEM-3#8CAAB561EFDE#1): Configured timezone "UTC-120" and system timezone "Europe/Berlin" do not match. Please check configuration
          • A anwa
            host.ioBroker
            host.ioBroker
            host.ioBroker
            host.ioBroker
            host.ioBroker
            host.ioBroker
            host.ioBroker
            host.ioBroker
            host.ioBroker
            host.ioBroker
            host.ioBroker
            host.ioBroker
            host.ioBroker
            host.ioBroker
            mcm1957M Online
            mcm1957M Online
            mcm1957
            Bitte für calendar ein Issue im Adapter repo erstellen.
            Adapter core @iobroker/adapter-core": "^2.3.1" ist inkompatibel.
            Allerdings ist der Adapter schon Jahre nicht mehr gewartet. Ich kann derzeit nicht sagen ob dieser gefixed oder deprectaed wird.
            • JB_SullivanJ JB_Sullivan
              shelly.0
              foxriver76F Offline
              foxriver76F Offline
              foxriver76
              @jb_sullivan eher unwahrscheinlich also würde mich wundern..
              Videotutorials & mehr
              • mcm1957M mcm1957
                @foxriver76 said in Beta Test js-controller Kiera (v6.0):
                @mcm1957 Geht rflink in 2.1.7?
                Sieht leider nicht so aus:
                Siehe https://forum.iobroker.net/topic/75222/rflink-keine-serielle-schnittstelle/14
                host.GLT
                2024-06-11 20:10:24.709	info	Rebuild for adapter system.adapter.rflink.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                host.GLT
                2024-06-11 20:10:24.709	error	instance system.adapter.rflink.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                host.GLT
                2024-06-11 20:10:24.709	error	Caught by controller[1]: Node.js v20.14.0
                host.GLT
                host.GLT
                2024-06-11 20:10:24.709	error	Caught by controller[1]: at node:internal/main/run_main_module:28:49
                host.GLT
                2024-06-11 20:10:24.709	error	Caught by controller[1]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:174:12)
                host.GLT
                2024-06-11 20:10:24.709	error	Caught by controller[1]: at Module._load (node:internal/modules/cjs/loader:1024:12)
                host.GLT
                2024-06-11 20:10:24.709	error	Caught by controller[1]: at Module.load (node:internal/modules/cjs/loader:1208:32)
                host.GLT
                2024-06-11 20:10:24.709	error	Caught by controller[1]: at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                host.GLT
                2024-06-11 20:10:24.709	error	Caught by controller[1]: at Module._compile (node:internal/modules/cjs/loader:1358:14)
                host.GLT
                2024-06-11 20:10:24.709	error	Caught by controller[1]: at Object.<anonymous> (C:\ioBroker\GLT\node_modules\iobroker.rflink\main.js:17:17)
                host.GLT
                2024-06-11 20:10:24.709	error	Caught by controller[1]: TypeError: Cannot read properties of undefined (reading 'supportsFeature')
                host.GLT
                host.GLT
                2024-06-11 20:10:24.709	error	Caught by controller[1]: ^
                host.GLT
                2024-06-11 20:10:24.709	error	Caught by controller[1]: if (adapter.supportsFeature && !adapter.supportsFeature('CONTROLLER_NPM_AUTO_REBUILD')) {
                host.GLT
                2024-06-11 20:10:24.709	error	Caught by controller[1]: C:\ioBroker\GLT\node_modules\iobroker.rflink\main.js:17
                host.GLT
                2024-06-11 20:10:24.709	error	Caught by controller[0]: → C:\ioBroker\GLT\node_modules\@serialport\bindings\lib\binding\node-v115-win32-x64\bindings.node
                host.GLT
                2024-06-11 20:10:24.709	error	Caught by controller[0]: → C:\ioBroker\GLT\node_modules\@serialport\bindings\addon-build\default\install-root\bindings.node
                host.GLT
                2024-06-11 20:10:24.709	error	Caught by controller[0]: → C:\ioBroker\GLT\node_modules\@serialport\bindings\addon-build\debug\install-root\bindings.node
                host.GLT
                2024-06-11 20:10:24.708	error	Caught by controller[0]: → C:\ioBroker\GLT\node_modules\@serialport\bindings\addon-build\release\install-root\bindings.node
                host.GLT
                2024-06-11 20:10:24.708	error	Caught by controller[0]: → C:\ioBroker\GLT\node_modules\@serialport\bindings\compiled\20.14.0\win32\x64\bindings.node
                host.GLT
                2024-06-11 20:10:24.708	error	Caught by controller[0]: → C:\ioBroker\GLT\node_modules\@serialport\bindings\build\default\bindings.node
                host.GLT
                2024-06-11 20:10:24.708	error	Caught by controller[0]: → C:\ioBroker\GLT\node_modules\@serialport\bindings\Release\bindings.node
                host.GLT
                2024-06-11 20:10:24.708	error	Caught by controller[0]: → C:\ioBroker\GLT\node_modules\@serialport\bindings\out\Release\bindings.node
                host.GLT
                2024-06-11 20:10:24.708	error	Caught by controller[0]: → C:\ioBroker\GLT\node_modules\@serialport\bindings\Debug\bindings.node
                host.GLT
                2024-06-11 20:10:24.708	error	Caught by controller[0]: → C:\ioBroker\GLT\node_modules\@serialport\bindings\out\Debug\bindings.node
                host.GLT
                2024-06-11 20:10:24.708	error	Caught by controller[0]: → C:\ioBroker\GLT\node_modules\@serialport\bindings\build\Release\bindings.node
                host.GLT
                2024-06-11 20:10:24.708	error	Caught by controller[0]: → C:\ioBroker\GLT\node_modules\@serialport\bindings\build\Debug\bindings.node
                host.GLT
                2024-06-11 20:10:24.708	error	Caught by controller[0]: → C:\ioBroker\GLT\node_modules\@serialport\bindings\build\bindings.node
                host.GLT
                2024-06-11 20:10:24.707	error	Caught by controller[0]: Cannot load serialport module : Error: Could not locate the bindings file. Tried:
                foxriver76F Offline
                foxriver76F Offline
                foxriver76
                schrieb am zuletzt editiert von foxriver76
                @mcm1957 puh und ne alte Version geht mit alt Controller? Schaut eher nach serialport speziell aus.. Villt Zusammenhang mit Node 20? Ja das Ding braucht mal Tests …
                • A anwa
                  host.ioBroker
                  host.ioBroker
                  host.ioBroker
                  host.ioBroker
                  host.ioBroker
                  host.ioBroker
                  host.ioBroker
                  host.ioBroker
                  host.ioBroker
                  host.ioBroker
                  host.ioBroker
                  host.ioBroker
                  host.ioBroker
                  host.ioBroker
                  host.ioBroker
                  host.ioBroker
                  host.ioBroker
                  mcm1957M Online
                  mcm1957M Online
                  mcm1957
                  @anwa
                  Bitte erstell in den Repositories für
                  • sourceanalytix
                  • calendar
                  • echarts
                  jeweils ein Issue
                  @foxriver76
                  Bitte setz diese VIER Adapter auf die Liste der inkompatiblen Adapter
                  • ad sourceanalytix
                    Auf Github ist adaptercore schon auf einer (alten) 3.x.x. Alldings wurden auch div. Dinge erweitert / geändert. Da sollte @Dutchman eine saubere Release mit aktuellem adapter-core erstellen
                  • ad calendar
                    Der Adapter ist verwaist. Dev ist seit langem inaktiv. Hier muss abgeklärt werden ob fullcalendar ein Ersatz wäre und / oder ob wir den Adapter in community verschieben wollen (und ihn dorr anpassen. Bitte ggF Bescheid geben, wenn ich ein Timeout Issue erstellen soll.
                  • ad echarts
                    Der hat in der letzen Release noch nicht mal adapter-core benutzt. Auf Github wurde allerdings alles mögliche incl. adapter-core gemerged. Tests sind allerdings rot. Da muss wer sanieren. (iobroker orga, Zugriff sollte also da sein)
                  • ad contact
                    Der contact Adapter ist ebenfalls von WLANkabel und verwaist. Benutzt @iobroker/adapter-core": "^2.2.1" - wird also ziemlich sicher auch nicht gehen.
                  • foxriver76F foxriver76
                    mcm1957M Online
                    mcm1957M Online
                    mcm1957
                    OK, Issue beim Adapter ist offen. Von mir aus kann der zunächst als offen liegen bleiben. Kann ihn mir ca. Mitte Juli ansehen. Oder wer andere hat vorher Zeit. Setz ihn halt mal auf inkompatibel
                    • mcm1957M mcm1957
                      foxriver76F Offline
                      foxriver76F Offline
                      foxriver76
                      @mcm1957 ich habe eine 2.1.8 gemacht in der das Serialport geupdated wurde. Hoffe tut nun.
                      mcm1957M JB_SullivanJ 2 Antworten Letzte Antwort
                        mcm1957M Online
                        mcm1957M Online
                        mcm1957
                        @foxriver76
                        Ich geh dann eher mal in standby modus. Muss morgen früh raus...
                          JB_Sullivan
                          @foxriver76
                          Nicht ganz ......
                          rflink.0
                          15048	2024-06-11 22:00:56.233	error	Cannot open serial port "COM3": TypeError: SerialPort is not a constructor
                            @foxriver76
                            Nicht ganz ......
                            rflink.0
                            foxriver76F Offline
                            foxriver76F Offline
                            foxriver76
                            @jb_sullivan dann 2.1.9 ansonsten muss es sich jemand anschauen der das testen kann,
                            • da_WoodyD Offline
                              da_WoodyD Offline
                              gerade update auf 6.0.2 gemacht, smartcontrol 2.0.1 will nicht mehr starten.
                              https://github.com/iobroker-community-adapters/ioBroker.smartcontrol/issues/177
                              • ESP8266E Offline
                                ESP8266E Offline
                                ESP8266
                                schrieb am zuletzt editiert von ESP8266
                                @mcm1957 sagte in Beta Test js-controller Kiera (v6.0):
                                @anwa
                                • sourceanalytix
                                • calendar
                                • echarts
                                jeweils ein Issue
                                @foxriver76
                                • ad echarts
                                Ich nutze echarts selbst, läuft im Hintergrund. Nur die Einstellungen sind weg.
                                Ist mir erst jetzt aufgefallen.
                                  @bommel_030 Das mit javascript ist mit der nächsten Version vom Adapter (8.5.2 gerade auf dem Weg) gefixt, dann bleibt nur ein Sepcial Case wenn URLs genutzt werden https://github.com/ioBroker/ioBroker.js-controller/issues/2796 den ich heute oder morgen probiere im Controller zu fixen
                                  bommel_030
                                  @foxriver76 sagte in Beta Test js-controller Kiera (v6.0):
                                  Also "moment" läuft wieder. Mit moment-duration-format hab ich noch so meine Probleme (https://www.npmjs.com/package/moment-duration-format)
                                  Seit Update js-controller 6.x bekomme ich bei einem Skript noch folgende Fehlermeldung:
                                  script.js.Online.VIS.IO_Adapterstatus: [adapterStatus] error: moment.duration(...).format is not a function, stack: TypeError: moment.duration(...).format is not a function at Object.adapterStatus (script.js.Online.VIS.IO_Adapterstatus:2584:115) at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1802:34) at Job.invoke (/opt/iobroker/node_modules/node-schedule/lib/Job.js:171:15) at /opt/iobroker/node_modules/node-schedule/lib/Invocation.js:268:28 at Timeout._onTimeout (/opt/iobroker/node_modules/node-schedule/lib/Invocation.js:228:7) at listOnTimeout (node:internal/timers:573:17) at processTimers (node:internal/timers:514:7)
                                  Wenn ich das Paket, analaog zu "moment" aus dem Javascript-Adapter entferne erhalte ich im LOG auch die Info, dass es entfernt wurde. Trage ich es danach wieder ein kommt im LOG keine Meldung dass es installiert wurde oder ob es ein Fehler gab. Laut npm list ist es auch nicht installiert. Wenn ich, wie in deinem verlinkten Issue via
                                  git+https://github.com/jsmreese/moment-duration-format
                                  eintrage bekomme ich die Fehlermeldung er findet das Modul nicht. Seitdem ich den Eintrag entfernt habe bekomme ich bei jeden Start die Meldung
                                  Removed custom npm package: "gith"
                                  laut npm list ist es aber weiterhin installiert...
                                  bommel@iobroker:/opt/iobroker$ npm list
                                  iobroker.inst@3.0.0 /opt/iobroker
                                  ├── @iobroker-javascript.0/axios@npm:axios@1.7.2
                                  ├── @iobroker-javascript.0/chroma-js@npm:chroma-js@2.4.2
                                  ├── @iobroker-javascript.0/dateformat@npm:dateformat@5.0.3
                                  ├── @iobroker-javascript.0/dewpoint@npm:dewpoint@1.0.0
                                  ├── @iobroker-javascript.0/jquery@npm:jquery@3.7.1
                                  ├── @iobroker-javascript.0/moment-duration-format@npm:moment-duration-format@2.3.2 (git+ssh://git@github.com/jsmreese/moment-duration-format.git#796c9c8e11dfc043842c12785dadfb210f33f380)
                                  ├── @iobroker-javascript.0/moment-timezone@npm:moment-timezone@0.5.45
                                  ├── @iobroker-javascript.0/moment@npm:moment@2.30.1
                                  ├── @iobroker-javascript.0/net-snmp@npm:net-snmp@3.11.2
                                  ├── @iobroker-javascript.0/net@npm:net@1.0.2
                                  ├── @iobroker-javascript.0/request@npm:request@2.88.2
                                  Dadurch stellen sich mir die Fragen, wie bekomme ich das "Removed custom npm package: "gith" " wieder weg, und wie bekomme ich moment-duration-format korrekt installiert.
                                  • B bommel_030
                                    foxriver76F Offline
                                    foxriver76F Offline
                                    foxriver76
                                    @bommel_030 Das Paket möchtest du mit Absicht von GitHub installieren? Ist controller schon 6.0.2?
                                      bommel_030
                                      @foxriver76
                                      Ja, wollte ich absichtlich von GitHub installieren, da das Paket über den "normalen" NPM Eintrag im JavaScript Adapter (v8.5.2) nicht installiert wurde.
                                      Keine Ahnung ob das an den beiden "-" liegen kann. Das Paket moment ließ sich nach dem update des JavaScript-Adapters ja wieder installieren.
                                      controller ist bei 6.0.2
                                        JB_Sullivan
                                        schrieb am zuletzt editiert von JB_Sullivan
                                        @foxriver76
                                        Es kommen noch diese beiden Meldungen. Für den Fall das es wichtig ist - ioB läuft auf einem Windows System bei mir und da hier von "path" gesprochen wird - hier die Pfad Angabe wo der serialport unter Win abgelegt ist - für den Fall das dass von Bedeutung sein könnte.
                                        rflink.0
                                        7132	2024-06-12 16:01:47.061	error	Cannot open serial port "COM3": TypeError: "path" is not defined: undefined
                                        rflink.0
                                        7132	2024-06-12 16:01:46.171	info	starting. Version 2.1.9 (non-npm: ioBroker/ioBroker.rflink) in C:/ioBroker/GLT/node_modules/iobroker.rflink, node: v20.14.0, js-controller: 6.0.2
                                          @foxriver76
                                          rflink.0
                                          rflink.0
                                          foxriver76F Offline
                                          foxriver76F Offline
                                          foxriver76
                                          @jb_sullivan 2.1.10 villt lol
                                          JB_SullivanJ Rene55R 2 Antworten Letzte Antwort
