  4. Cannot download and install adapter "telegram@3.2.1"
24 Beiträge 5 Kommentatoren 1.7k Aufrufe 3 Beobachtet
  • jmeister79J Offline
    jmeister79J Offline
    jmeister79
    iob update:
    pi@iobrokerpi:~ $ iob update
    node:internal/modules/cjs/loader:1143
      throw err;
    Error: Cannot find module 'axios'
    Require stack:
    - /opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/tools.js
    - /opt/iobroker/node_modules/@iobroker/js-controller-common/build/index.js
    - /opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup.js
    - /opt/iobroker/node_modules/@iobroker/js-controller-cli/build/index.js
    - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
        at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
        at Module._load (node:internal/modules/cjs/loader:981:27)
        at Module.require (node:internal/modules/cjs/loader:1231:19)
        at require (node:internal/modules/helpers:177:18)
        at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/tools.js:36:33)
        at Module._compile (node:internal/modules/cjs/loader:1364:14)
        at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
        at Module.load (node:internal/modules/cjs/loader:1203:32)
        at Module._load (node:internal/modules/cjs/loader:1019:12)
        at Module.require (node:internal/modules/cjs/loader:1231:19) {
      code: 'MODULE_NOT_FOUND',
      requireStack: [
        '/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/tools.js',
        '/opt/iobroker/node_modules/@iobroker/js-controller-common/build/index.js',
        '/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup.js',
        '/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/index.js',
        '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
    Node.js v18.20.2
    pi@iobrokerpi:~ $
      jmeister79J Offline
      jmeister79
      schrieb am zuletzt editiert von jmeister79
      spannend, das putty hier die ganzen Fehler schmeisst und die ssh Console auf dem handy nicht
      war ja auch der andere iobroker.... IDIOT
        jmeister79J Offline
        jmeister79
        Tja und jetzt läuft garnix mehr, update und upgrade geht nicht und nach nem restart ist auch der iobroker wech
        • jmeister79J jmeister79
          @jmeister79 sagte in Cannot download and install adapter "telegram@3.2.1":
          Tja, dann kannst du ja jetzt die vernachlässigten Updates nachholen. Insbesondere des js-controllers.
          iob stop
          cd /opt/iobroker
          npm install iobroker.js-controller@5.0.19
          iob start
          iob update
          jmeister79J 1 Antwort Letzte Antwort
            iob stop
            cd /opt/iobroker
            iob start
            iob update
            jmeister79J Offline
            jmeister79J Offline
            jmeister79
            @thomas-braun said in Cannot download and install adapter "telegram@3.2.1":
            ok, wenn das so geht, kannst du mir kurz erklären wie das passiert das der iobroker sich selber so abschießt, wenn der js-controller alt sit? würde es gerne verstehen.
              passiert das. Weil dann Abhängigkeiten nicht bedient werden können.
              Deswegen funktioniert es ja auch nicht, das System einmal zu installieren und dann 'das running süstem never zu tatschen'.
              Die einzelnen Komponenten (Betriebssystem; Laufzeitumgebung, js-controller, iob-Adapter) müssen halt mit einander richtig zusammenspielen. Das kannst du aber nur mit jeweils aktuellen, stabilen Versionen gewährleisten.
                jmeister79J Offline
                jmeister79J Offline
                jmeister79
                @thomas-braun ok danke.
                leider bringt
                nix.
                selber Fehler bei iob update
                  leider bringt
                  nix.
                  leider bringt
                  nix.
                  Zeigen. Komplette Ein- wie Ausgaben.
                    leider bringt
                    nix.
                    jmeister79J Offline
                    jmeister79J Offline
                    jmeister79
                    @thomas-braun my bad, der iobroker lief noch, war unaufmerksam.
                    so ich update dann mal alles.
                    Aber nochmal doof gefragt:
                    Wenn ich n runden Stand hätte und NIX update, dann sollte es doch gehen (sofern es keine probleme mit den third parties gibt: Shelly, telegram, Xiaomi, Fronius, etc...) Es sit ja dann ein Inselsystem
                    Thomas BraunT W 2 Antworten Letzte Antwort
                      @jmeister79
                      Es wird immer Notwendigkeiten für Anpassungen geben.
                      Dein 'Inselbetrieb' ist nicht realistisch.
                        W Online
                        W Online
                        Wildbill
                        @jmeister79 Inselbetrieb heißt aber dann auch, dass das Gerät für sich läuft. Keine Verbindung nach außen, nirgends hin, wo auch nur irgendwo eine Verbindung woandershin bestehen könnte. Also: Kein LAN-Kabel eingesteckt, kein WLAN eingerichtet. Dann, ja dann läuft der Inselbetrieb auf Dauer und vermutlich stabil!
                        Gruss, Jürgen
