  4. Cannot download and install adapter "telegram@3.2.1"
24 Beiträge 5 Kommentatoren 1.3k Aufrufe 3 Beobachtet
  • jmeister79J Offline
    jmeister79J Offline
    jmeister79
    meine Waschmaschine ist fertig und ich wudnere mich, warum ich keine Nachricht kriege,
    der Telegram Adapter ist gestoppt und wenn ich ihn restarte gibts das hier:
    host.iobrokerpi
    2024-06-11 14:47:07.332	error	Cannot download and install adapter "telegram@3.2.1". To retry it disable/enable the adapter or restart host. Also check the error messages in the log!
    host.iobrokerpi
    2024-06-11 14:47:07.214	info	iobroker npm-install: exit 1
    host.iobrokerpi
    2024-06-11 14:47:07.203	error	iobroker npm-install: node:internal/modules/cjs/loader:1143 throw err; ^Error: Cannot find module 'axios'Require stack:- /opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/tools.js- /opt/iobroker/node_modules/@iobroker/js-controller-common/build/index.js- /opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup.js- /opt/iobroker/node_modules/@iobroker/js-controller-cli/build/index.js- /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15) at Module._load (node:internal/modules/cjs/loader:981:27) at Module.require (node:internal/modules/cjs/loader:1231:19) at require (node:internal/modules/helpers:177:18) at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/tools.js:36:33) at Module._compile (node:internal/modules/cjs/loader:1364:14) at Module._extensions..js (node:internal/modules/cjs/loader:1422:10) at Module.load (node:internal/modules/cjs/loader:1203:32) at Module._load (node:internal/modules/cjs/loader:1019:12) at Module.require (node:internal/modules/cjs/loader:1231:19) { code: 'MODULE_NOT_FOUND', requireStack: [ '/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/tools.js', '/opt/iobroker/node_modules/@iobroker/js-controller-common/build/index.js', '/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup.js', '/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/index.js', '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js' ]}Node.js v18.20.2
    Ging jetzt ca 4 Jahre problemlos und nun das...
    • jmeister79J jmeister79
      host.iobrokerpi
      host.iobrokerpi
      host.iobrokerpi
      @jmeister79
      System aktuell halten.
      UPDATEN:
      telegram
      github:	3.4.1
      latest:	3.4.1 for 1 days
      stable:	3.3.2 for 16 days
      Deine 3.2.1 gibt es wohl nicht mehr im Repo.
        jmeister79J Offline
        jmeister79
        @thomas-braun Danke für die antwort, was neueres zeigt er nicht an. ist alles so aktuell wie er sagt. Das problem hab ich seit wochen
          @jmeister79 sagte in Cannot download and install adapter "telegram@3.2.1":
          was sagt iob update ?
          jmeister79J 1 Antwort Letzte Antwort
            @jmeister79
            Dann schau dir die Ausgabe von
            iob diag
            an.
              jmeister79J Offline
              jmeister79J Offline
              jmeister79
              schrieb am zuletzt editiert von jmeister79
              @homoran spannend, habe die eltzten monate immer über das Webinterface geupdated und nicht mehr über die konsole.
              in der konsole gibts neue versionen für admin, backitup discovery und -js-controller.
              im Webinterface ganz andere
              liegts daran?
              Wichtig: ich darf nicht alles updaten, da das letzte update für VIS auf keinem meiner panels funktioniert und VIS 2 für mich keine alternative ist.
                liegts daran?
                liegts daran?
                @homoran sagte in Cannot download and install adapter "telegram@3.2.1":
                  liegts daran?
                  Die Konsole lügt (im Gegensatz zu GUIs) eigentlich nie.
                    jmeister79J Offline
                    jmeister79J Offline
                    jmeister79
                    @thomas-braun Screenshot_2024-06-11-15-05-25-65_e36872cd03453bb5e33ec96ae2d9a765.jpg
                    wie eben gesagt.
                    ich will eigentlich nicht mehr updaten, da das system für mich läuft unt hatte nur gezielt einige adapter upgedated, scheinbar war das ne doofe idee.
                    jmeister79J Thomas BraunT Ro75R 3 Antworten Letzte Antwort
                      wie eben gesagt.
                      jmeister79J Offline
                      jmeister79J Offline
                      jmeister79
                      dagegen das GUI
                        wie eben gesagt.
                        Ja, so handelt man sich nämlich Inkonsistenzen ein.
                        Nochmal:
                        Vollständige Ausgabe von
                        iob diag
                        wird benötigt.
                          wie eben gesagt.
                          Ro75R Offline
                          Ro75R Offline
                          Ro75
                          schrieb am zuletzt editiert von Ro75
                          @jmeister79 der js-controller ist mit Version 4 für die meisten Adapter zu alt.
                          Ro75
                          EDIT: ggfs auch NodeJS.
                            Nochmal:
                            iob diag
                            wird benötigt.
                            jmeister79J Offline
                            jmeister79J Offline
                            jmeister79
                                                    v.2024-05-22
                               Static hostname: iobrokerpi
                                     Icon name: computer
                              Operating System: Raspbian GNU/Linux 11 (bullseye)
                                        Kernel: Linux 6.1.21-v8+
                                  Architecture: arm64
                            Kernel:                 aarch64
                            Userland:               32 bit
                            User-ID:                1000
                            Display-Server:         false
                            Boot Target:            multi-user.target
                            Pending OS-Updates:     7
                              throw err;
                            Require stack:
                              requireStack: [
                            Node.js v18.20.2
                            Pending iob updates:    0
                            Nodejs-Installation:
                            /usr/bin/nodejs         v18.20.2
                            /usr/bin/node           v18.20.2
                            /usr/bin/npm            10.5.0
                            /usr/bin/npx            10.5.0
                            /usr/bin/corepack       0.25.2
                            Recommended versions are nodejs  and npm
                            MEMORY:
                            Mem:            3.8G        2.7G        182M        0.0K        898M        948M
                            Swap:            99M         99M        0.0K
                            Total:          3.9G        2.8G        182M
                            Active iob-Instances:   0
                              throw err;
                            Require stack:
                              requireStack: [
                            Node.js v18.20.2
                              throw err;
                            Require stack:
                              requireStack: [
                            Node.js v18.20.2
                            ioBroker Core:          js-controller
                              throw err;
                            Require stack:
                              requireStack: [
                            Node.js v18.20.2
                                                    admin
                              throw err;
                            Require stack:
                              requireStack: [
                            Node.js v18.20.2
                            ioBroker Status:
                            Objects:                0
                            States:                 0
                            Size of iob-Database:
                            18M     /opt/iobroker/iobroker-data/objects.jsonl
                            4.0M    /opt/iobroker/iobroker-data/states.jsonl
                            Some problems detected, please run iob fix and try to have them fixed
                              jmeister79J Offline
                              jmeister79
                              iob update:
                              pi@iobrokerpi:~ $ iob update
                                throw err;
                              Require stack:
                                requireStack: [
                              Node.js v18.20.2
                              pi@iobrokerpi:~ $
                                jmeister79J Offline
                                jmeister79
                                spannend, das putty hier die ganzen Fehler schmeisst und die ssh Console auf dem handy nicht
                                war ja auch der andere iobroker.... IDIOT
                                  jmeister79J Offline
                                  jmeister79
                                  Tja und jetzt läuft garnix mehr, update und upgrade geht nicht und nach nem restart ist auch der iobroker wech
                                    Tja, dann kannst du ja jetzt die vernachlässigten Updates nachholen. Insbesondere des js-controllers.
                                    iob stop
                                    cd /opt/iobroker
                                    npm install iobroker.js-controller@5.0.19
                                    iob start
                                    iob update
                                      iob stop
                                      cd /opt/iobroker
                                      iob start
                                      iob update
                                      jmeister79J Offline
                                      jmeister79J Offline
                                      jmeister79
                                      @thomas-braun said in Cannot download and install adapter "telegram@3.2.1":
                                      ok, wenn das so geht, kannst du mir kurz erklären wie das passiert das der iobroker sich selber so abschießt, wenn der js-controller alt sit? würde es gerne verstehen.
                                        passiert das. Weil dann Abhängigkeiten nicht bedient werden können.
                                        Deswegen funktioniert es ja auch nicht, das System einmal zu installieren und dann 'das running süstem never zu tatschen'.
                                        Die einzelnen Komponenten (Betriebssystem; Laufzeitumgebung, js-controller, iob-Adapter) müssen halt mit einander richtig zusammenspielen. Das kannst du aber nur mit jeweils aktuellen, stabilen Versionen gewährleisten.
                                          jmeister79J Offline
                                          jmeister79J Offline
                                          jmeister79
                                          @thomas-braun ok danke.
                                          leider bringt
                                          nix.
                                          selber Fehler bei iob update
                                          82.8k
