  4. Sonos Adapter probleme
    6.6k
20 Beiträge 10 Kommentatoren 2.6k Aufrufe 9 Beobachtet
    Dominik_neu
    ich habe seit ein paar Tagen Probleme mit meinem Sonos Adapter und weis nicht wie ich das Problem lösen soll. viellecht hat hier jemand eine Idee was hinter dem Fehler steckt. Bildschirmfoto 2024-05-30 um 12.36.29.png
    Thomas BraunT S 3 Antworten Letzte Antwort
    • D Dominik_neu
      @dominik_neu
      Bitte das Log in Textform hier rein.
      Schau dir
      iob logs
      an.
        @dominik_neu
        Schau dir
        iob logs
        an.
        Dominik_neu
        schrieb am zuletzt editiert von Dominik_neu
        2024-05-30 14:19:47.130 - info: host.raspberrypi instance system.adapter.sonos.0 started with pid 6092
        2024-05-30 14:19:49.125 - info: sonos.0 (6092) starting. Version 3.0.0 in /opt/iobroker/node_modules/iobroker.sonos, node: v18.14.2, js-controller: 5.0.19
        2024-05-30 14:19:49.931 - error: sonos.0 (6092) Cannot write file coverImage/192_168_20_12.png: sonos is not an object of type "meta"
        2024-05-30 14:19:49.946 - error: sonos.0 (6092) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        2024-05-30 14:19:49.946 - error: sonos.0 (6092) unhandled promise rejection: sonos is not an object of type "meta"
        2024-05-30 14:19:49.948 - error: sonos.0 (6092) Error: sonos is not an object of type "meta"
        at ObjectsInRedisClient.validateMetaObject (/opt/iobroker/node_modules/@iobroker/db-objects-redis/build/lib/objects/objectsInRedisClient.js:587:39)
        at runNextTicks (node:internal/process/task_queues:60:5)
        at process.processImmediate (node:internal/timers:447:9)
        at async ObjectsInRedisClient.writeFile (/opt/iobroker/node_modules/@iobroker/db-objects-redis/build/lib/objects/objectsInRedisClient.js:821:13)
        2024-05-30 14:19:49.949 - error: sonos.0 (6092) sonos is not an object of type "meta"
        2024-05-30 14:19:49.952 - error: sonos.0 (6092) Cannot write file coverImage/192_168_20_10.png: sonos is not an object of type "meta"
        2024-05-30 14:19:49.956 - info: sonos.0 (6092) terminating
        2024-05-30 14:19:49.966 - info: sonos.0 (6092) terminating
        2024-05-30 14:19:49.968 - warn: sonos.0 (6092) Terminated (UNCAUGHT_EXCEPTION): Without reason
        2024-05-30 14:19:49.989 - error: sonos.0 (6092) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        2024-05-30 14:19:49.991 - error: sonos.0 (6092) unhandled promise rejection: sonos is not an object of type "meta"
        2024-05-30 14:19:49.992 - error: sonos.0 (6092) Error: sonos is not an object of type "meta"
        2024-05-30 14:19:49.992 - error: sonos.0 (6092) sonos is not an object of type "meta"
        2024-05-30 14:19:50.470 - info: sonos.0 (6092) terminating
        2024-05-30 14:19:50.533 - error: host.raspberrypi instance system.adapter.sonos.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
        2024-05-30 14:19:50.533 - info: host.raspberrypi Restart adapter system.adapter.sonos.0 because enabled
        2024-05-30 14:20:20.597 - info: host.raspberrypi instance system.adapter.sonos.0 started with pid 6108
        2024-05-30 14:20:22.958 - info: sonos.0 (6108) starting. Version 3.0.0 in /opt/iobroker/node_modules/iobroker.sonos, node: v18.14.2, js-controller: 5.0.19
        2024-05-30 14:20:24.038 - error: sonos.0 (6108) Cannot write file coverImage/192_168_20_11.png: sonos is not an object of type "meta"
        2024-05-30 14:20:24.056 - error: sonos.0 (6108) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        2024-05-30 14:20:24.057 - error: sonos.0 (6108) unhandled promise rejection: sonos is not an object of type "meta"
        2024-05-30 14:20:24.059 - error: sonos.0 (6108) Error: sonos is not an object of type "meta"
        2024-05-30 14:20:24.060 - error: sonos.0 (6108) sonos is not an object of type "meta"
        2024-05-30 14:20:24.062 - error: sonos.0 (6108) Cannot write file coverImage/192_168_20_10.png: sonos is not an object of type "meta"
        2024-05-30 14:20:24.064 - error: sonos.0 (6108) Cannot write file coverImage/192_168_20_12.png: sonos is not an object of type "meta"
        2024-05-30 14:20:24.068 - info: sonos.0 (6108) terminating
        2024-05-30 14:20:24.077 - info: sonos.0 (6108) terminating
        2024-05-30 14:20:24.078 - warn: sonos.0 (6108) Terminated (UNCAUGHT_EXCEPTION): Without reason
        2024-05-30 14:20:24.094 - error: sonos.0 (6108) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        2024-05-30 14:20:24.096 - error: sonos.0 (6108) unhandled promise rejection: sonos is not an object of type "meta"
        2024-05-30 14:20:24.096 - error: sonos.0 (6108) Error: sonos is not an object of type "meta"
        2024-05-30 14:20:24.097 - error: sonos.0 (6108) sonos is not an object of type "meta"
        2024-05-30 14:20:24.103 - error: sonos.0 (6108) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        2024-05-30 14:20:24.103 - error: sonos.0 (6108) unhandled promise rejection: sonos is not an object of type "meta"
        2024-05-30 14:20:24.106 - error: sonos.0 (6108) Error: sonos is not an object of type "meta"
        2024-05-30 14:20:24.106 - error: sonos.0 (6108) sonos is not an object of type "meta"
        2024-05-30 14:20:24.580 - info: sonos.0 (6108) terminating
        2024-05-30 14:20:24.650 - error: host.raspberrypi instance system.adapter.sonos.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
        2024-05-30 14:20:24.651 - info: host.raspberrypi Restart adapter system.adapter.sonos.0 because enabled
        2024-05-30 14:20:54.766 - info: host.raspberrypi instance system.adapter.sonos.0 started with pid 6123
        2024-05-30 14:20:57.156 - info: sonos.0 (6123) starting. Version 3.0.0 in /opt/iobroker/node_modules/iobroker.sonos, node: v18.14.2, js-controller: 5.0.19
        2024-05-30 14:20:58.345 - error: sonos.0 (6123) Cannot write file coverImage/192_168_20_11.png: sonos is not an object of type "meta"
        2024-05-30 14:20:58.355 - error: sonos.0 (6123) Cannot write file coverImage/192_168_20_12.png: sonos is not an object of type "meta"
        2024-05-30 14:20:58.373 - error: sonos.0 (6123) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        2024-05-30 14:20:58.375 - error: sonos.0 (6123) unhandled promise rejection: sonos is not an object of type "meta"
        2024-05-30 14:20:58.377 - error: sonos.0 (6123) Error: sonos is not an object of type "meta"
        2024-05-30 14:20:58.378 - error: sonos.0 (6123) sonos is not an object of type "meta"
        2024-05-30 14:20:58.384 - error: sonos.0 (6123) Cannot write file coverImage/192_168_20_10.png: sonos is not an object of type "meta"
        2024-05-30 14:20:58.388 - error: sonos.0 (6123) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        2024-05-30 14:20:58.390 - error: sonos.0 (6123) unhandled promise rejection: sonos is not an object of type "meta"
        2024-05-30 14:20:58.394 - error: sonos.0 (6123) Error: sonos is not an object of type "meta"
        at ObjectsInRedisClient.validateMetaObject (/opt/iobroker/node_modules/@iobroker/db-objects-redis/build/lib/objects/objectsInRedisClient.js:591:35)
        at ObjectsInRedisClient.writeFile (/opt/iobroker/node_modules/@iobroker/db-objects-redis/build/lib/objects/objectsInRedisClient.js:821:24)
        at AdapterClass.writeFile (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:4816:73)
        at /opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/tools.js:2022:16
        at new Promise ()
        at AdapterClass.writeFileAsync (/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/tools.js:2021:16)
        at takeSonosState (/opt/iobroker/node_modules/iobroker.sonos/main.js:1456:31)
        at processSonosEvents (/opt/iobroker/node_modules/iobroker.sonos/main.js:1693:17)
        at SonosSystem. (/opt/iobroker/node_modules/iobroker.sonos/main.js:2105:13)
        at SonosSystem.emit (node:events:513:28)
        2024-05-30 14:20:58.395 - error: sonos.0 (6123) sonos is not an object of type "meta"
        2024-05-30 14:20:58.399 - info: sonos.0 (6123) terminating
        2024-05-30 14:20:58.412 - info: sonos.0 (6123) terminating
        2024-05-30 14:20:58.413 - warn: sonos.0 (6123) Terminated (UNCAUGHT_EXCEPTION): Without reason
        2024-05-30 14:20:58.437 - error: sonos.0 (6123) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        2024-05-30 14:20:58.437 - error: sonos.0 (6123) unhandled promise rejection: sonos is not an object of type "meta"
        2024-05-30 14:20:58.438 - error: sonos.0 (6123) Error: sonos is not an object of type "meta"
        2024-05-30 14:20:58.439 - error: sonos.0 (6123) sonos is not an object of type "meta"
        2024-05-30 14:20:58.916 - info: sonos.0 (6123) terminating
        2024-05-30 14:20:58.993 - error: host.raspberrypi instance system.adapter.sonos.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
        2024-05-30 14:20:58.994 - info: host.raspberrypi Restart adapter system.adapter.sonos.0 because enabled
        2024-05-30 14:20:58.994 - warn: host.raspberrypi Do not restart adapter system.adapter.sonos.0 because restart loop detected
        2024-05-30 14:25:18.683 - warn: admin.0 (5545) sonos has an invalid jsonConfig: [{"instancePath":"/items/devicesTab/items/_sendto","schemaPath":"#/definitions/sendToProps/additionalProperties","keyword":"additionalProperties","params":{"additionalProperty":"timeout"},"message":"must NOT have additional properties"},{"instancePath":"/items/devicesTab","schemaPath":"#/properties/items/patternProperties/%5E.%2B/allOf/8/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"},{"instancePath":"","schemaPath":"#/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"}]
        2024-05-30 14:25:25.881 - info: admin.0 (5545) ==> Connected system.user.admin from ::ffff:192.168.50.50
        2024-05-30 14:26:19.956 - info: admin.0 (5545) <== Disconnect system.user.admin from ::ffff:192.168.50.50 javascript
        • D Dominik_neu
          SmartHomie
          @dominik_neu Hänge mich hier mal ran. Habe den Sonos Adapter neu installiert da ich immer viele Warnungen/Abstürze von dem Adapter erhalten habe. Jetzt geht aber leider gar nichts mehr und die Instanz geht auf rot.
          Habe auch die Meldung "Restart loop detected". Ein iob stop und iob fix haben nichts gebracht.
          2024-06-02 11:45:05.138  - warn: admin.0 (1193178) sonos has an invalid jsonConfig: [{"instancePath":"/items/devicesTab/items/_sendto","schemaPath":"#/definitions/sendToProps/additionalProperties","keyword":"additionalProperties","params":{"additionalProperty":"timeout"},"message":"must NOT have additional properties"},{"instancePath":"/items/devicesTab","schemaPath":"#/properties/items/patternProperties/%5E.%2B/allOf/8/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"},{"instancePath":"","schemaPath":"#/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"}]
          2024-06-02 11:48:06.599  - info: host.ioBroker2 instance system.adapter.sonos.0 started with pid 1196483
          2024-06-02 11:48:09.964  - info: sonos.0 (1196483) starting. Version 3.0.0 in /opt/iobroker/node_modules/iobroker.sonos, node: v18.20.2, js-controller: 5.0.19
          2024-06-02 11:48:11.252  - error: sonos.0 (1196483) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          2024-06-02 11:48:11.255  - error: sonos.0 (1196483) unhandled promise rejection: Cannot read properties of undefined (reading 'id')
          2024-06-02 11:48:11.259  - error: sonos.0 (1196483) TypeError: Cannot read properties of undefined (reading 'id')
              at syncConfig (/opt/iobroker/node_modules/iobroker.sonos/main.js:2029:71)
          2024-06-02 11:48:11.261  - error: sonos.0 (1196483) Cannot read properties of undefined (reading 'id')
          2024-06-02 11:48:11.276  - info: sonos.0 (1196483) terminating
          2024-06-02 11:48:11.279  - info: sonos.0 (1196483) terminating
          2024-06-02 11:48:11.281  - warn: sonos.0 (1196483) Terminated (UNCAUGHT_EXCEPTION): Without reason
          2024-06-02 11:48:11.787  - info: sonos.0 (1196483) terminating
          2024-06-02 11:48:12.037  - error: host.ioBroker2 instance system.adapter.sonos.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
          2024-06-02 11:48:12.038  - info: host.ioBroker2 Restart adapter system.adapter.sonos.0 because enabled
          2024-06-02 11:48:34.343  - info: connector-local-control.0 (1194295) receive server message from 192.168.178.56: 32100: {"msgType":"Heartbeat","mac":"f008d179f228","deviceType":"02000001","token":"37412C478E0FBEAB","data":{"currentState":1,"numberOfDevices":1,"RSSI":-43}}
          2024-06-02 11:48:34.345  - info: connector-local-control.0 (1194295) Heartbeat
          2024-06-02 11:48:42.260  - info: host.ioBroker2 instance system.adapter.sonos.0 started with pid 1196660
          2024-06-02 11:48:45.467  - info: sonos.0 (1196660) starting. Version 3.0.0 in /opt/iobroker/node_modules/iobroker.sonos, node: v18.20.2, js-controller: 5.0.19
          2024-06-02 11:48:46.671  - error: sonos.0 (1196660) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          2024-06-02 11:48:46.672  - error: sonos.0 (1196660) unhandled promise rejection: Cannot read properties of undefined (reading 'id')
          2024-06-02 11:48:46.675  - error: sonos.0 (1196660) TypeError: Cannot read properties of undefined (reading 'id')
          2024-06-02 11:48:46.677  - error: sonos.0 (1196660) Cannot read properties of undefined (reading 'id')
          2024-06-02 11:48:46.692  - info: sonos.0 (1196660) terminating
          2024-06-02 11:48:46.693  - info: sonos.0 (1196660) terminating
          2024-06-02 11:48:46.695  - warn: sonos.0 (1196660) Terminated (UNCAUGHT_EXCEPTION): Without reason
          2024-06-02 11:48:47.199  - info: sonos.0 (1196660) terminating
          2024-06-02 11:48:47.402  - error: host.ioBroker2 instance system.adapter.sonos.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
          2024-06-02 11:48:47.402  - info: host.ioBroker2 Restart adapter system.adapter.sonos.0 because enabled
          2024-06-02 11:49:17.682  - info: host.ioBroker2 instance system.adapter.sonos.0 started with pid 1196804
          2024-06-02 11:49:20.994  - info: sonos.0 (1196804) starting. Version 3.0.0 in /opt/iobroker/node_modules/iobroker.sonos, node: v18.20.2, js-controller: 5.0.19
          2024-06-02 11:49:22.232  - error: sonos.0 (1196804) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          2024-06-02 11:49:22.234  - error: sonos.0 (1196804) unhandled promise rejection: Cannot read properties of undefined (reading 'id')
          2024-06-02 11:49:22.238  - error: sonos.0 (1196804) TypeError: Cannot read properties of undefined (reading 'id')
          2024-06-02 11:49:22.240  - error: sonos.0 (1196804) Cannot read properties of undefined (reading 'id')
          2024-06-02 11:49:22.254  - info: sonos.0 (1196804) terminating
          2024-06-02 11:49:22.256  - info: sonos.0 (1196804) terminating
          2024-06-02 11:49:22.259  - warn: sonos.0 (1196804) Terminated (UNCAUGHT_EXCEPTION): Without reason
          2024-06-02 11:49:22.764  - info: sonos.0 (1196804) terminating
          2024-06-02 11:49:23.034  - error: host.ioBroker2 instance system.adapter.sonos.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
          2024-06-02 11:49:23.035  - info: host.ioBroker2 Restart adapter system.adapter.sonos.0 because enabled
          2024-06-02 11:49:23.035  - warn: host.ioBroker2 Do not restart adapter system.adapter.sonos.0 because restart loop detected```
          • S SmartHomie
            Hier startet der Adapter zwar, meckert aber einiges an:
            2024-06-02 12:05:36.075  - warn: admin.0 (817993) sonos has an invalid jsonConfig: [{"instancePath":"/items/devicesTab/items/_sendto","schemaPath":"#/definitions/sendToProps/additionalProperties","keyword":"additionalProperties","params":{"additionalProperty":"timeout"},"message":"must NOT have additional properties"},{"instancePath":"/items/devicesTab","schemaPath":"#/properties/items/patternProperties/%5E.%2B/allOf/8/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"},{"instancePath":"","schemaPath":"#/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"}]
            2024-06-02 12:05:36.587  - info: sonos.0 (829438) starting. Version 3.0.0 in /opt/iobroker/node_modules/iobroker.sonos, node: v20.14.0, js-controller: 6.0.1-alpha.0-20240529-9dbeeb628
            2024-06-02 12:05:36.691  - info: sonos.0 (829438) Method "createDevice" is deprecated and will be removed in js-controller 7, use "extendObject/setObjectNotExists" instead
            2024-06-02 12:05:36.793  - info: sonos.0 (829438) Method "createChannel" is deprecated and will be removed in js-controller 7, use "extendObject/setObjectNotExists" instead
            2024-06-02 12:05:36.803  - info: sonos.0 (829438) Method "createState" is deprecated and will be removed in js-controller 7, use "extendObject/setObjectNotExists" instead
            2024-06-02 12:05:36.827  - info: sonos.0 (829438) Method "createState" is deprecated and will be removed in js-controller 7, use "extendObject/setObjectNotExists" instead
            2024-06-02 12:05:36.847  - info: sonos.0 (829438) Method "createState" is deprecated and will be removed in js-controller 7, use "extendObject/setObjectNotExists" instead
            2024-06-02 12:05:36.865  - info: sonos.0 (829438) Method "createState" is deprecated and will be removed in js-controller 7, use "extendObject/setObjectNotExists" instead
            2024-06-02 12:05:36.884  - info: sonos.0 (829438) Method "createState" is deprecated and will be removed in js-controller 7, use "extendObject/setObjectNotExists" instead
            2024-06-02 12:05:36.906  - info: sonos.0 (829438) Method "createState" is deprecated and will be removed in js-controller 7, use "extendObject/setObjectNotExists" instead
            Das ganze mit nodejs@20.
            • D Dominik_neu
              SmartHomie
              @dominik_neu und, Problem gelöst? Keine Ahnung ob der Entwickler des Sonos Adapters das hier im Forum mitliest.
              • S SmartHomie
                mameier1234
                Ich hatte die selben Meldungen ..
                Lösung: Instanz UND Adapter löschen und neu einrichten. Nur die Instanz löschen und wieder anlegen hat es nicht gebracht.
                Grüße,
                Martin
                haus-automatisierungH S M 3 Antworten Letzte Antwort
                • M mameier1234
                  haus-automatisierungH Offline
                  @mameier1234 Dann gibt es wohl eine neue Version einer Abhängigkeit, welche das Problem behebt.
                  Wäre sinnvoll wenn der Entwickler eine neue Version freigibt damit das Update automatisch passiert
                  📚 Meine Dokumentation
                    mcm1957M Online
                    mcm1957M Online
                    mcm1957
                    @thomas-braun said in Sonos Adapter probleme:
                    Du hast wahrscheinlich js-controller 6 installiert. Mit js-controller 6 werden diese Methoden deprecated funktionieren aber weiter. Ergo bitte nur ein Issue im Aapzter Repo eröffnen wenn es noch nicht existiert.
                    Support Repositoryverwaltung.
                    LESEN - gute Forenbeitrage
                    • mcm1957M mcm1957
                      @mcm1957
                      Schon läääääängst passiert:
                      https://github.com/ioBroker/ioBroker.sonos/issues/238
                      • M mameier1234
                        SmartHomie
                        @mameier1234 DANKKEEE. Das hat bei mir jetzt auch funktioniert. 👍
                          steffensammet
                          schrieb am zuletzt editiert von steffensammet
                          Hat jemand eine Idee für Docker ? Da hat Instanz & Adapter löschen bisher leider nichts gebracht :-(
                          docker official image - v9.1.2
                          admin: v6.17.14
                          Node.js: v18.20.3
                          NPM: 10.8.1
                          Habe ich vielleicht ein Problem mit den Ports ??
                          sonos.0
                          2024-06-30 12:10:16.455	debug	Process channel: sonos.0.root.192_168_178_88
                          sonos.0
                          2024-06-30 12:10:16.408	debug	Process channel: sonos.0.root.192_168_178_87
                          sonos.0
                          2024-06-30 12:10:16.358	debug	Process channel: sonos.0.root.192_168_178_86
                          sonos.0
                          2024-06-30 12:10:16.307	debug	Process channel: sonos.0.root.192_168_178_89
                          sonos.0
                          2024-06-30 12:10:16.307	debug	Channels of root: [{"type":"channel","common":{"role":"media.music","name":"Sonos Play:1 Terrasse"},"native":{"ip":"192.168.178.89"},"from":"system.adapter.sonos.0","user":"system.user.admin","ts":1719742183531,"_id":"sonos.0.root.192_168_178_89","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}},{"type":"channel","common":{"role":"media.music","name":"Sonos AMP Badezimmer"},"native":{"ip":"192.168.178.86"},"from":"system.adapter.sonos.0","user":"system.user.admin","ts":1719742183595,"_id":"sonos.0.root.192_168_178_86","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}},{"type":"channel","common":{"role":"media.music","name":"Sonos AMP Hobbyraum"},"native":{"ip":"192.168.178.87"},"from":"system.adapter.sonos.0","user":"system.user.admin","ts":1719742183855,"_id":"sonos.0.root.192_168_178_87","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}},{"type":"channel","common":{"role":"media.music","name":"Sonos AMP Hobbyraum"},"native":{"ip":"192.168.178.88"},"from":"system.adapter.sonos.0","user":"system.user.admin","ts":1719742184125,"_id":"sonos.0.root.192_168_178_88","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}]
                          sonos.0
                          2024-06-30 12:10:16.257	debug	Initialize known devices: [{"type":"device","common":{"name":"root"},"native":{},"from":"system.adapter.sonos.0","user":"system.user.admin","ts":1719739575452,"_id":"sonos.0.root","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}]
                          sonos.0
                          2024-06-30 12:10:16.164	debug	Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
                          sonos.0
                          2024-06-30 12:10:16.140	info	starting. Version 3.0.0 in /opt/iobroker/node_modules/iobroker.sonos, node: v18.20.3, js-controller: 5.0.19
                          sonos.0
                          2024-06-30 12:10:16.021	debug	States connected to redis: 127.0.0.1:9000
                          sonos.0
                          2024-06-30 12:10:15.918	debug	States create User PubSub Client
                          sonos.0
                          2024-06-30 12:10:15.917	debug	States create System PubSub Client
                          sonos.0
                          2024-06-30 12:10:15.884	debug	Redis States: Use Redis connection: 127.0.0.1:9000
                          sonos.0
                          2024-06-30 12:10:15.826	debug	Objects connected to redis: 127.0.0.1:9001
                          sonos.0
                          2024-06-30 12:10:15.822	debug	Objects client initialize lua scripts
                          sonos.0
                          2024-06-30 12:10:15.722	debug	Objects create User PubSub Client
                          sonos.0
                          2024-06-30 12:10:15.722	debug	Objects create System PubSub Client
                          sonos.0
                          2024-06-30 12:10:15.720	debug	Objects client ready ... initialize now
                          sonos.0
                          2024-06-30 12:10:15.671	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
                          • S steffensammet
                            admin: v6.17.14
                            Node.js: v18.20.3
                            NPM: 10.8.1
                            sonos.0
                            sonos.0
                            sonos.0
                            sonos.0
                            sonos.0
                            sonos.0
                            sonos.0
                            sonos.0
                            sonos.0
                            sonos.0
                            sonos.0
                            sonos.0
                            sonos.0
                            sonos.0
                            sonos.0
                            sonos.0
                            sonos.0
                            sonos.0
                            steffensammet
                            tatsächlich .... ein Problem mit den Ports ..... :-)
                            R 1 Antwort Letzte Antwort
                            • S steffensammet
                              road_runner31
                              @steffensammet Welche Ports werden denn benötigt? Muss ich die explizit freigeben?
                              Danke für eine kurze Info.. :)
                              • R road_runner31
                                steffensammet
                                @road_runner31
                                laut meinem Log war es 9000 und 9001;
                                in der Realität habe ich den Container aber von Host zu einer Bridge umgezogen und hatte somit alle Ports verfügbar.
                                Ich hoffe dies hilft dir weiter.
                                Es halt komisch ist, bei Home Assistant funktioniert es "out-of-the-box" ... :-(
                                FriedhofsblondF 1 Antwort Letzte Antwort
                                • S steffensammet
                                  @road_runner31
                                  FriedhofsblondF Offline
                                  Friedhofsblond
                                  Moin,
                                  irgendwie habe ich Ladehemmung 😊
                                  Ich wollte den IObroker als Sonos-API-Server nutzen.
                                  (wollte per HUE-Taster und Webhook einen Sonos-One steuern)
                                  Ich dachte das geht mit dem Sonos-Adapter?
                                  Habe die Adapter Web und Sonos installiert und upgedatet.
                                  Dann zwei Speaker eingetragen - wird auch alles ausgelesen - keine errors im Log.
                                  Nun wollte ich per http einen Befehl senden z.B. volume 20 - also 20% Lautstärke.
                                  "http://192.168.115.29:5005/Wohnzimmer/volume/20"
                                  Schmeiß ich das einfach so in irgendeinen Browser - irgendwie steh ich auf dem Schlauch.
                                  Danke für einen Denkanstoß
                                  • FriedhofsblondF Friedhofsblond
                                    Moin,
                                    Friedhofsblond
                                    Moin,
                                    Habe den Api-Server testweise erstmal auf einem Raspi-Z installiert.
                                    Soweit läuft das, alle Speaker werden erkannt (auch mit neuer Firmware).
                                    Wie installiere ich den Api-Server nun richtig auf dem iob ?
                                    Ich werde den wohl hauptsächlich extern nutzen und im homey webooks versenden. Aber eine Integration/kontrolle im iob wäre schön.
                                    Grüsse
                                    • M mameier1234
                                      mpa9
                                      @mameier1234 hab das selbe Problem und steh gerade auf dem Schlauch. Instanz neu installieren ist mir klar. Aber was meinst du mit Adapter neu installieren?
                                      • M mpa9
                                        mameier1234
                                        schrieb am zuletzt editiert von mameier1234
                                        @mpa9 Nunja..
                                        Wie gesagt, unter Instanz.. die Instanz löschen, dann unter Adapter den Adapter deinstallieren / löschen... Dann wieder neu installieren..
                                        Hier auf den Mülleimer klicken...
                                        Grüße,
                                        Martin
                                        • M mameier1234
                                          @mpa9 Nunja..
                                          mpa9
                                          @mameier1234 Nunja.. Problem besteht weiterhin, Lösungsansatz scheint nicht mehr zu funktionieren.
