  4. Heizöl24 - MEX
    5.1k
Heizöl24 - MEX
adapteroilfoxheizöltank
37 Beiträge 12 Kommentatoren 9.9k Aufrufe 12 Beobachtet
  • spicerS spicer
    @gjo editiere Zeile 95 nach:
    client = mqtt.Client("MEX")
    Ich vermute, dass Du mqtt Version < 2.0 hast.
    Werde das beim nächsten Update abfangen.
    gjo
    @spicer
    das war auch meine Vermutung.
    heidenei ... nach:
    root@DietPi:/home/script# pip install paho-mqtt --upgrade
    Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple/
    Requirement already satisfied: paho-mqtt in /usr/local/lib/python3.7/dist-packages (1.6.1)
    Collecting paho-mqtt
     Downloading https://www.piwheels.org/simple/paho-mqtt/paho_mqtt-2.0.0-py3-none-any.whl (66 kB)
        ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 66.9/66.9 kB 746.1 kB/s eta 0:00:00
    Installing collected packages: paho-mqtt
     Attempting uninstall: paho-mqtt
       Found existing installation: paho-mqtt 1.6.1
       Uninstalling paho-mqtt-1.6.1:
         Successfully uninstalled paho-mqtt-1.6.1
    Successfully installed paho-mqtt-2.0.0
    WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
    [notice] A new release of pip is available: 23.3.2 -> 24.0
    [notice] To update, run: python3 -m pip install --upgrade pip
    kommt jetzt:
    root@DietPi:/home/script# python3 /home/script/mex.py
    Traceback (most recent call last):
      File "/usr/local/lib/python3.7/dist-packages/paho/mqtt/client.py", line 49, in <module>
        from typing import Literal
    ImportError: cannot import name 'Literal' from 'typing' (/usr/lib/python3.7/typing.py)
    During handling of the above exception, another exception occurred:
      File "/home/script/mex.py", line 38, in <module>
        import paho.mqtt.client as mqtt
      File "/usr/local/lib/python3.7/dist-packages/paho/mqtt/client.py", line 51, in <module>
        from typing_extensions import Literal  # type: ignore
    ModuleNotFoundError: No module named 'typing_extensions'
    also via:
    root@DietPi:/home/script# pip install typing-extensions
    Collecting typing-extensions
      Downloading https://www.piwheels.org/simple/typing-extensions/typing_extensions-4.7.1-py3-none-any.whl (33 kB)
    Installing collected packages: typing-extensions
    Successfully installed typing-extensions-4.7.1
    nachinstalliert. dann mit folgendem Ergebnis:
    /home/script/mex.py:95: DeprecationWarning: Callback API version 1 is deprecated, update to latest version
      client = mqtt.Client(mqtt.CallbackAPIVersion.VERSION1, "MEX")
    spicerS 1 Antwort Letzte Antwort
    • G gjo
      @spicer
      heidenei ... nach:
      kommt jetzt:
      also via:
      spicerS Offline
      spicerS Offline
      spicer
      schrieb am zuletzt editiert von spicer
      @gjo
      Diese Warnung ist ok. Die hab ich auch. Sollte eigentlich funktionieren so.
      Funktioniert's denn?
      Frage: Bist Du als root unterwegs, nicht als pi?
      Edit:
      Warnung ist nun weg. Code nutzt nun aktuelle Parameter ;)
      Wenn es mehrere Möglichkeiten gibt, eine Aufgabe zu erledigen, und eine davon in einer Katastrophe endet oder sonstwie unerwünschte Konsequenzen nach sich zieht, dann wird es jemand genau so machen. Alles, was schiefgehen kann, wird auch schiefgehen.
      (Murphys Gesetz)
      G 1 Antwort Letzte Antwort
      • spicerS spicer
        @gjo
        Edit:
        gjo
        @spicer
        die Daten kommen an ... wie cool. Danke nochmal.
        ja, auf dem Testsystem hatte ich s mir einfacher gemacht.
        • spicerS Offline
          spicerS Offline
          spicer
          V1.2 auf github
          • DataReceived Punkt hinzugefügt
          • paho-mqtt Versionsabfrage
          (Murphys Gesetz)
          • G gjo
            @spicer
            @gjo sagte in Heizöl24 - MEX:
            Das ist aber auch nur vermeintlich einfacher.
            In der Realität ist es nämlich aufwändiger die Rechte richtig zu halten.
            Und deswegen gilt halt: NIE root.
            Die Meldung:
            steht nämlich da auch nicht zum Spaß.
              Die Meldung:
              spicerS Offline
              spicerS Offline
              spicer
              @thomas-braun sagte in Heizöl24 - MEX:
              Die Meldung:
              Jep. Dachte ich mir auch, dass das wegen dem root so ist ;)
              (Murphys Gesetz)
              • spicerS Offline
                spicerS Offline
                spicer
                V1.3 auch auf github.
                mex.py
                #!/usr/bin/python3
                ###################################             V1.3               ###################
                ################################### MEX-Daten in ioBroker einlesen ###################
                ###################################    Benötigt den MQTT Adapter   ###################
                ###################################    (C) 2024 Daniel Luginbühl   ###################
                ######################################### WICHTIGE INFOS #############################
                ################## Im ioBroker ist der MQTT Broker/Client Adapter zu installieren   ##
                ################## Einstellungen:                                                   ##
                ##################    IP: Server/Broker                                             ##
                ##################    Authentifizierungseinstellungen: Benutzer/Passwort definieren ##
                ##################                  Alles als User PI ausführen!                    ##
                ################## mex.py Script auf Rechte 754 setzen mit:                         ##
                ################## chmod 754 mex.py                                                 ##
                ################## Dieses Script per Cronjob alle 2 bis 4 Stunden ausführen:        ##
                ################## crontab -e                                                       ##
                ################## 0 */3 * * * /home/pi/mex.py          # Pfad ggf anpassen!        ##
                ################## Vorgängig zu installieren (auf Host, wo dieses Script läuft):    ##
                ##################    sudo apt install python3-requests                             ##
                ##################    pip3 install paho-mqtt                                        ##
                ##################    pip3 install typing-extensions                                ##
                ################################### Hier Einträge anpassen! ##########################
                username = "AAAAA@gmail.com"    # Deine Email Adresse bei HeizOel24
                passwort = "BBBBBBBBB"          # Dein Passwort bei HeizOel24
                broker_address = "192.168.1.50" # ioBroker IP, auf welchem der MQTT (Server) Adapter läuft
                mqtt_user = "uuuuuu"            # ioBroker MQTT User     (in Authentifizierungseinstellungen definiert)
                mqtt_pass = "pppppp"            # ioBroker MQTT Passwort (in Authentifizierungseinstellungen definiert)
                debug = False                   # True = Debug Infos auf die Konsole
                import requests
                import time
                import json
                def mqtt_send(client, topic, wert):
                    client.publish("MEX/" + topic, wert)
                def login():
                    if debug:
                        print('Login in...')
                    global session_id
                    url = "https://api.heizoel24.de/app/api/app/Login"
                    newHeaders = {'Content-type': 'application/json'}
                    reply = requests.post(url, json = { "Password" : passwort, "Username" : username}, headers=newHeaders)
                    return_flag = False
                    if reply.status_code == 200:
                        if debug:
                            print("Login OK")
                        reply_json = json.loads(reply.text)
                        if reply_json['ResultCode'] == 0:
                            session_id = reply_json['SessionId']
                            if debug:
                                print('Session ID: ' + session_id)
                            return_flag = True
                        else:
                            if debug:
                                print('ResultCode nicht 0. Keine Session ID erhalten!')
                    else:
                        if debug:
                            print('Login fehlgeschlagen! Heizoel24 Login Status Code: ' + str(reply.status_code))
                    return return_flag
                def mex():
                    login_status = login()
                    if login_status == False:
                        return "error"
                    if debug:
                        print('Refresh sensor data cache...')
                    url = 'https://api.heizoel24.de/app/api/app/GetDashboardData/'+ session_id + '/1/1/False'
                    reply = requests.get(url)
                        if debug:
                            print("Daten wurden empfangen")
                        sensor_data = reply
                    else:
                        if debug:
                            print('Heizoel24 GetDashboardData Status Code: ' + str(reply.status_code))
                        sensor_data = "error"   # Fehler. Keine Daten empfangen.
                    return sensor_data
                def main():
                    topic1 = ['SensorId', 'IsMain', 'CurrentVolumePercentage', 'CurrentVolume', 'NotifyAtLowLevel', 'NotifyAtAlmostEmptyLevel', 'NotificationsEnabled', 'Usage', 'RemainsUntil', 'MaxVolume', 'ZipCode', 'MexName', 'LastMeasurementTimeStamp', 'LastMeasurementWithDifferentValue', 'BatteryPercentage', 'Battery', 'LitresPerCentimeter', 'LastMeasurementWasSuccessfully', 'SensorTypeId', 'HasMeasurements', 'MeasuredDaysCount', 'LastMeasurementWasTooHigh', 'YearlyOilUsage', 'RemainingDays', 'LastOrderPrice', 'ResultCode', 'ResultMessage']
                    topic2 = ['LastOrderPrice', 'PriceComparedToYesterdayPercentage', 'PriceForecastPercentage', 'HasMultipleMexDevices', 'DashboardViewMode', 'ShowComparedToYesterday', 'ShowForecast', 'ResultCode', 'ResultMessage']
                    RemainsUntilCombined = ['MonthAndYear', 'RemainsValue', 'RemainsUnit']
                    try:
                        client = mqtt.Client("mex")
                        if debug:
                            print("paho-mqtt version < 2.0")
                    except:
                        client = mqtt.Client(mqtt.CallbackAPIVersion.VERSION2, "mex")
                        if debug:
                            print("paho-mqtt version >= 2.0")
                    if debug:
                        print("---------------------")
                        print("client:", client)
                    client.username_pw_set(mqtt_user, mqtt_pass)
                    client.connect(broker_address)
                    daten = mex()
                    if daten == "error":
                        if debug:
                            print("Fehler. Keine Daten empfangen.")
                        mqtt_send(client, "Items/DataReceived", False)
                        client.disconnect()
                        return
                    daten = daten.json()
                    if debug:
                        print()
                        print("JSON-Daten:")
                        print("===========")
                        print()
                        print(daten)
                        print()
                    if debug:
                        print()
                    for n in range(len(topic2)):
                        if debug:
                            print(topic2[n] + ":", daten[topic2[n]])
                        mqtt_send(client, "PricingForecast/" + topic2[n], daten[topic2[n]])
                    daten = daten["Items"]
                    daten = daten[0]
                    if debug:
                    for n in range(len(topic1)):
                        if debug:
                            print(topic1[n] + ":", daten[topic1[n]])
                        mqtt_send(client, "Items/" + topic1[n], daten[topic1[n]])
                    mqtt_send(client, "Items/DataReceived", True)
                    daten3 = daten['RemainsUntilCombined']
                    if debug:
                        print('RemainsUntilCombined:')
                    for n in range(len(RemainsUntilCombined)):
                        if debug:
                            print(RemainsUntilCombined[n] + ":", daten3[RemainsUntilCombined[n]])
                        mqtt_send(client, "RemainsUntilCombined/" + RemainsUntilCombined[n], daten3[RemainsUntilCombined[n]])
                    client.disconnect()
                if __name__ == '__main__':
                    main()
                (Murphys Gesetz)
                • spicerS Offline
                  spicerS Offline
                  spicer
                  Ich wäre übrigens sehr empfänglich für Hilfe beim Erstellen eines ioBroker Adapters.
                  Die Links
                  https://iobroker.readthedocs.io/de/latest/development/adapter.html
                  und
                  https://www.codeconvert.ai/python-to-javascript-converter
                  hab ich zwar, aber ohne Hilfe ist das doch etwas schwierig.
                  Ich weiss nichtmal, wie ich meinem Code beibringe, Input- und Output vom/zum ioBroker zu senden/empfangen.
                  Mit anderen Worten: Die Schnittstelle.
                  Bin für jeden Rat dankbar.
                  Totaler Anfänger im programmieren bin ich nicht.
                  Jedoch Java = 0 Ahnung. Python sieht's anders aus (hoffentlich oben im Py-Script ersichtlich).
                  Bin halt ein Basic & Assembler Kind aus den C64 bzw Atari Jahren ^^
                  (Murphys Gesetz)
                  • spicerS spicer
                    Die Links
                    und
                    mcm1957M Offline
                    mcm1957M Offline
                    mcm1957
                    @spicer
                    Hier (aus Zeitgründen) nur eine ganz kurze Info:
                    -) Am besten schaust du dir einen (eher einfachen) Adapter auf github mal an und versuchst zu verstehen was da steht.
                    -) Ein Grundverständnis für javascript (das ist NICHT Java) ist hilfreich. Aber wenn du eine andere Sprache kannst, sollte das nicht das Problem sein.
                    -) Für Testzwecke erstellst du am besten einen neuen Adapter mittels adapter creator.
                    -) Testen tust du am besten mittels dev-server.
                    Ich würde dir empfehlen dich in der telgramm Gruppe adapter-developer-starters anzumelden. Invite Links windest du auf www.iobroker.dev. Dort gibts sicher wen der dir mal ein wenig beim Start helfen kann und wird.
                    P.S: Uns ja, die dokumentation ist (m.E.) eine der größten Baustellen / Schwachstellen von ioB. Wenns es da leite gibt die sowas gener schreiben sind sie sicher gern gesehen. (Viele Code-Entwickler schreiben ungern Dokumentaionen ...)
                    Support Repositoryverwaltung.
                    LESEN - gute Forenbeitrage
                    • xadoxX Offline
                      xadoxX Offline
                      xadox
                      schrieb am zuletzt editiert von xadox
                      Das Script ließt den MEX direkt aus und der Adapter geht über den Heizöl24 Account?
                      Bitte ignorieren wer lesen kann ist im Vorteil 😳
                      • xadoxX xadox
                        spicerS Offline
                        spicerS Offline
                        spicer
                        @xadox
                        Für den ioBroker hab ich ja einen Adapter erstellt ( https://github.com/ltspicer/ioBroker.heizoel24-mex ) ;)
                        Und hier ist die aktuelle Version vom Script: https://github.com/ltspicer/heizoel24.mex
                        (Murphys Gesetz)
