  4. Dieser Adapter benötigt den vis- oder vis-2-Adapter
    6.0k
18 Beiträge 4 Kommentatoren 2.1k Aufrufe 3 Beobachtet
    @ppb1308 sagte in Dieser Adapter benötigt den vis- oder vis-2-Adapter:
    Dieser Adapter benötigt den vis- oder vis-2-Adapter,
    hast du den?
    was sagt die Langfassung von iob diag ?
    PPB1308
    @homoran said in Dieser Adapter benötigt den vis- oder vis-2-Adapter:
    hast du den?
    ja, beide.
    lt. diag imho keine Probleme bezüglich vis zu erkennen:
    Skript v.2024-05-22
    *** BASE SYSTEM ***
       Static hostname: briioBrProx
             Icon name: computer-container
               Chassis: container
        Virtualization: lxc
      Operating System: Ubuntu 20.04.6 LTS
                Kernel: Linux 5.15.104-1-pve
          Architecture: x86-64
    model name      : Intel(R) Core(TM) i5-8259U CPU @ 2.30GHz
    Docker          : false
    Virtualization  : lxc
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     09:51:23 up 16:01,  1 user,  load average: 1.41, 1.07, 1.04
    CPU threads: 2
    *** Time and Time Zones ***
                   Local time: Fri 2024-05-31 09:51:23 CEST
               Universal time: Fri 2024-05-31 07:51:23 UTC
                     RTC time: n/a
                  NTP service: inactive
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    peter
    HOME=/home/peter
    GROUPS=peter sudo iobroker
    iobroker
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout audio video plugdev
    *** Display-Server-Setup ***
    Display-Server: false
    Desktop:
    Terminal:
    *** MEMORY ***
    Mem:           7.2G        5.7G        292M        0.0K        1.2G        1.5G
    Swap:          4.1G        0.0K        4.1G
    Total:          11G        5.7G        4.4G
    Active iob-Instances:   63
             7168 M total memory
             5661 M used memory
              819 M active memory
             5730 M inactive memory
              292 M free memory
                0 M buffer memory
             1214 M swap cache
             4096 M total swap
                0 M used swap
             4095 M free swap
    top - 09:51:23 up 16:01,  1 user,  load average: 1.41, 1.07, 1.04
    Tasks:  92 total,   1 running,  91 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  9.7 us,  0.0 sy,  0.0 ni, 90.3 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   7168.0 total,    292.2 free,   5661.1 used,   1214.7 buff/cache
    MiB Swap:   4096.0 total,   4096.0 free,      0.0 used.   1506.9 avail Mem
    *** FAILED SERVICES ***
      UNIT               LOAD   ACTIVE SUB    DESCRIPTION
    * nightscout.service loaded failed failed Nightscout CGM service
    1 loaded units listed.
    *** FILESYSTEM ***
    Filesystem                       Type      Size  Used Avail Use% Mounted on
    /dev/mapper/pve-vm--220--disk--0 ext4       40G   13G   25G  34% /
    none                             tmpfs     492K  4.0K  488K   1% /dev
    udev                             devtmpfs  7.8G     0  7.8G   0% /dev/tty
    tmpfs                            tmpfs     7.8G     0  7.8G   0% /dev/shm
    tmpfs                            tmpfs     1.6G  116K  1.6G   1% /run
    tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
    dmesg: read kernel buffer failed: Operation not permitted
    Show mounted filesystems:
    TARGET                                SOURCE                           FSTYPE      OPTIONS
    /                                     /dev/mapper/pve-vm--220--disk--0 ext4        rw,relatime,stripe=16
    |-/run                                tmpfs                            tmpfs       rw,nosuid,nodev,size=1623916k,mode=755,uid=100000,gid=100000,inode64
    | `-/run/lock                         tmpfs                            tmpfs       rw,nosuid,nodev,noexec,relatime,size=5120k,uid=100000,gid=100000,inode64
    |-/dev                                none                             tmpfs       rw,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
    | |-/dev/shm                          tmpfs                            tmpfs       rw,nosuid,nodev,uid=100000,gid=100000,inode64
    | |-/dev/mqueue                       mqueue                           mqueue      rw,relatime
    | |-/dev/.lxc/proc                    proc                             proc        rw,relatime
    | |-/dev/.lxc/sys                     sys                              sysfs       rw,relatime
    | |-/dev/full                         udev[/full]                      devtmpfs    rw,nosuid,relatime,size=8084736k,nr_inodes=2021184,mode=755,inode64
    | |-/dev/null                         udev[/null]                      devtmpfs    rw,nosuid,relatime,size=8084736k,nr_inodes=2021184,mode=755,inode64
    | |-/dev/random                       udev[/random]                    devtmpfs    rw,nosuid,relatime,size=8084736k,nr_inodes=2021184,mode=755,inode64
    | |-/dev/tty                          udev[/tty]                       devtmpfs    rw,nosuid,relatime,size=8084736k,nr_inodes=2021184,mode=755,inode64
    | |-/dev/urandom                      udev[/urandom]                   devtmpfs    rw,nosuid,relatime,size=8084736k,nr_inodes=2021184,mode=755,inode64
    | |-/dev/zero                         udev[/zero]                      devtmpfs    rw,nosuid,relatime,size=8084736k,nr_inodes=2021184,mode=755,inode64
    | |-/dev/pts                          devpts                           devpts      rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
    | |-/dev/ptmx                         devpts[/ptmx]                    devpts      rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
    | |-/dev/console                      devpts[/0]                       devpts      rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
    | |-/dev/tty1                         devpts[/1]                       devpts      rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
    | `-/dev/tty2                         devpts[/2]                       devpts      rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
    |-/proc                               proc                             proc        rw,nosuid,nodev,noexec,relatime
    | |-/proc/sys                         proc[/sys]                       proc        ro,relatime
    | | |-/proc/sys/net                   proc[/sys/net]                   proc        rw,nosuid,nodev,noexec,relatime
    | | |-/proc/sys/fs/binfmt_misc        binfmt_misc                      binfmt_misc rw,nosuid,nodev,noexec,relatime
    | | `-/proc/sys/kernel/random/boot_id none[/.lxc-boot-id]              tmpfs       ro,nosuid,nodev,noexec,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
    | |-/proc/sysrq-trigger               proc[/sysrq-trigger]             proc        ro,relatime
    | |-/proc/cpuinfo                     lxcfs[/proc/cpuinfo]             fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    | |-/proc/diskstats                   lxcfs[/proc/diskstats]           fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    | |-/proc/loadavg                     lxcfs[/proc/loadavg]             fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    | |-/proc/meminfo                     lxcfs[/proc/meminfo]             fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    | |-/proc/slabinfo                    lxcfs[/proc/slabinfo]            fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    | |-/proc/stat                        lxcfs[/proc/stat]                fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    | |-/proc/swaps                       lxcfs[/proc/swaps]               fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    | `-/proc/uptime                      lxcfs[/proc/uptime]              fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    `-/sys                                sysfs                            sysfs       ro,nosuid,nodev,noexec,relatime
      |-/sys/fs/fuse/connections          fusectl                          fusectl     rw,nosuid,nodev,noexec,relatime
      |-/sys/devices/virtual/net          sysfs[/devices/virtual/net]      sysfs       rw,nosuid,nodev,noexec,relatime
      |-/sys/kernel/debug                 debugfs                          debugfs     rw,nosuid,nodev,noexec,relatime
      |-/sys/kernel/security              securityfs                       securityfs  rw,nosuid,nodev,noexec,relatime
      |-/sys/fs/pstore                    pstore                           pstore      rw,nosuid,nodev,noexec,relatime
      |-/sys/firmware/efi/efivars         efivarfs                         efivarfs    rw,nosuid,nodev,noexec,relatime
      |-/sys/fs/cgroup                    none                             cgroup2     rw,nosuid,nodev,noexec,relatime
      `-/sys/devices/system/cpu           lxcfs[/sys/devices/system/cpu]   fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    /var:
    5.5G    /var/
    3.9G    /var/log/journal/f13addc1d6aa9ba4cb18ff805da8906a
    3.9G    /var/log
    849M    /var/lib
    Archived and active journals take up 1.3G in the file system.
    /opt/iobroker/backups:
    75M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.7G    /opt/iobroker/iobroker-data/
    1.1G    /opt/iobroker/iobroker-data/files
    243M    /opt/iobroker/iobroker-data/files/vis-2
    236M    /opt/iobroker/iobroker-data/backup-objects
    187M    /opt/iobroker/iobroker-data/files/javascript.admin
    65M     /opt/iobroker/iobroker-data/states.jsonl
    52M     /opt/iobroker/iobroker-data/objects.jsonl
    41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
    38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
    27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
    USB-Devices by-id:
    No Devices found 'by-id'
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.20.3
    /usr/bin/node           v18.20.3
    /usr/bin/npm            10.7.0
    /usr/bin/npx            10.7.0
    /usr/bin/corepack       0.28.0
    nodejs:
      Installed: 18.20.3-1nodesource1
      Candidate: 18.20.3-1nodesource1
      Version table:
     *** 18.20.3-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
         18.20.2-1nodesource1 1001
         18.20.1-1nodesource1 1001
         18.20.0-1nodesource1 1001
         18.19.1-1nodesource1 1001
         18.19.0-1nodesource1 1001
         18.18.2-1nodesource1 1001
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
         10.19.0~dfsg-3ubuntu1.6 500
            500 http://archive.ubuntu.com/ubuntu focal-updates/universe amd64 Packages
            500 http://archive.ubuntu.com/ubuntu focal-security/universe amd64 Packages
         10.19.0~dfsg-3ubuntu1 500
            500 http://archive.ubuntu.com/ubuntu focal/universe amd64 Packages
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.19
    admin:          6.17.14
    javascript:     8.4.2
    nodejs modules from github:     6
    +-- @jpgorganizer/utils@1.2.1 (git+ssh://git@github.com/jpgorganizer/ioBroker.utils.git#952f8556cf8d45f865a84c9a911a7b2b87633f3a)
    | `-- kodi-ws@2.4.4 (git+https://git@github.com/iobroker-community-adapters/kodi-ws.git#ad5a1fdc5cd0a282e6818ff152594b5d32535103)
    +-- iobroker.life360@0.2.21 (git+ssh://git@github.com/MiGoller/ioBroker.life360.git#888e08024c2d93d86aa6eb74f281c574dce86c42)
    +-- iobroker.nightscout@1.1.0 (git+ssh://git@github.com/ioBroker/ioBroker.nightscout.git#1f5b39fa318cb78d844eb3c248c4baf00e51098f)
    +-- iobroker.onvif-alt@0.2.0 (git+ssh://git@github.com/Jey-Cee/iobroker.onvif-alt.git#f524cdbc00567a3351217272ab5af29d9947c967)
    | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
    Adapter State
    + system.adapter.admin.0                  : admin                 : briioBrProx                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alarm.0                  : alarm                 : briioBrProx                              -  enabled
    + system.adapter.alexa2.0                 : alexa2                : briioBrProx                              -  enabled
      system.adapter.alias-manager.0          : alias-manager         : briioBrProx                              -  enabled
    + system.adapter.backitup.0               : backitup              : briioBrProx                              -  enabled
    + system.adapter.bring.0                  : bring                 : briioBrProx                              -  enabled
    + system.adapter.cameras.0                : cameras               : briioBrProx                              -  enabled, port: 8200, bind: 127.0.0.1
    + system.adapter.cloud.0                  : cloud                 : briioBrProx                              -  enabled
      system.adapter.coronavirus-statistics.0 : coronavirus-statistics: briioBrProx                              -  enabled
      system.adapter.daswetter.0              : daswetter             : briioBrProx                              -  enabled
    + system.adapter.deconz.0                 : deconz                : briioBrProx                              -  enabled, port: 80
    + system.adapter.discovery.0              : discovery             : briioBrProx                              -  enabled
      system.adapter.dwd.0                    : dwd                   : briioBrProx                              -  enabled
    + system.adapter.email.0                  : email                 : briioBrProx                              -  enabled
    + system.adapter.enigma2.0                : enigma2               : briioBrProx                              -  enabled
    + system.adapter.enigma2.1                : enigma2               : briioBrProx                              -  enabled
    + system.adapter.fb-checkpresence.0       : fb-checkpresence      : briioBrProx                              -  enabled
      system.adapter.feiertage.0              : feiertage             : briioBrProx                              -  enabled
    + system.adapter.firetv.0                 : firetv                : briioBrProx                              -  enabled
      system.adapter.flot.0                   : flot                  : briioBrProx                              -  enabled
      system.adapter.fontui.0                 : fontui                : briioBrProx                              -  enabled
      system.adapter.fritzbox.0               : fritzbox              : briioBrProx                              -  enabled
    + system.adapter.fullybrowser.0           : fullybrowser          : briioBrProx                              -  enabled
      system.adapter.harmony.0                : harmony               : briioBrProx                              -  enabled
    + system.adapter.history.0                : history               : briioBrProx                              -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : briioBrProx                              -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : briioBrProx                              -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : briioBrProx                              -  enabled, port: 0
    + system.adapter.hm-rpc.2                 : hm-rpc                : briioBrProx                              -  enabled, port: 0
    + system.adapter.hm-rpc.3                 : hm-rpc                : briioBrProx                              -  enabled, port: 0
    + system.adapter.homeconnect.0            : homeconnect           : briioBrProx                              -  enabled
    + system.adapter.hue-extended.0           : hue-extended          : briioBrProx                              -  enabled
    + system.adapter.hue.0                    : hue                   : briioBrProx                              -  enabled, port: 443
      system.adapter.ical.0                   : ical                  : briioBrProx                              -  enabled
      system.adapter.ical.1                   : ical                  : briioBrProx                              -  enabled
      system.adapter.ical.2                   : ical                  : briioBrProx                              -  enabled
      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: briioBrProx                              -  enabled
      system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : briioBrProx                              -  enabled
      system.adapter.icons-icons8.0           : icons-icons8          : briioBrProx                              -  enabled
      system.adapter.icons-material-png.0     : icons-material-png    : briioBrProx                              -  enabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : briioBrProx                              -  enabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : briioBrProx                              -  enabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: briioBrProx                              -  enabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : briioBrProx                              -  enabled
    + system.adapter.info.0                   : info                  : briioBrProx                              -  enabled
    + system.adapter.iot.0                    : iot                   : briioBrProx                              -  enabled
    + system.adapter.javascript.0             : javascript            : briioBrProx                              -  enabled
    + system.adapter.javascript.1             : javascript            : briioBrProx                              -  enabled
    + system.adapter.kodi.0                   : kodi                  : briioBrProx                              -  enabled, port: 9090
    + system.adapter.life360.0                : life360               : briioBrProx                              -  enabled
      system.adapter.link.0                   : link                  : briioBrProx                              - disabled
    + system.adapter.linkeddevices.0          : linkeddevices         : briioBrProx                              -  enabled
      system.adapter.luftdaten.0              : luftdaten             : briioBrProx                              -  enabled
      system.adapter.material.0               : material              : briioBrProx                              -  enabled
      system.adapter.mobile.0                 : mobile                : briioBrProx                              - disabled
    + system.adapter.moma.0                   : moma                  : briioBrProx                              -  enabled
    + system.adapter.mqtt-client.0            : mqtt-client           : briioBrProx                              -  enabled, port: 1883
    + system.adapter.netatmo.0                : netatmo               : briioBrProx                              -  enabled
    + system.adapter.nina.0                   : nina                  : briioBrProx                              -  enabled
    + system.adapter.onvif.0                  : onvif                 : briioBrProx                              -  enabled
    + system.adapter.pi-hole.0                : pi-hole               : briioBrProx                              -  enabled
    + system.adapter.ping.0                   : ping                  : briioBrProx                              -  enabled
    + system.adapter.plex.0                   : plex                  : briioBrProx                              -  enabled
    + system.adapter.plexconnect.0            : plexconnect           : briioBrProx                              -  enabled, port: 41814
    + system.adapter.pollenflug.0             : pollenflug            : briioBrProx                              -  enabled
    + system.adapter.proxmox.0                : proxmox               : briioBrProx                              -  enabled, port: 8006
      system.adapter.proxy.0                  : proxy                 : briioBrProx                              -  enabled
    + system.adapter.pushover.0               : pushover              : briioBrProx                              -  enabled
    + system.adapter.shelly.0                 : shelly                : briioBrProx                              -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.simple-api.0             : simple-api            : briioBrProx                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.smartgarden.0            : smartgarden           : briioBrProx                              -  enabled
    + system.adapter.socketio.0               : socketio              : briioBrProx                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
    + system.adapter.socketio.1               : socketio              : briioBrProx                              -  enabled, port: 8085, bind: 0.0.0.0, run as: admin
    + system.adapter.sonoff.0                 : sonoff                : briioBrProx                              -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.synology.0               : synology              : briioBrProx                              -  enabled, port: 32400
      system.adapter.tahoma.0                 : tahoma                : briioBrProx                              - disabled
    + system.adapter.tankerkoenig.0           : tankerkoenig          : briioBrProx                              -  enabled
    + system.adapter.text2command.0           : text2command          : briioBrProx                              -  enabled
    + system.adapter.tr-064.0                 : tr-064                : briioBrProx                              -  enabled
    + system.adapter.tr-064.1                 : tr-064                : briioBrProx                              -  enabled
    + system.adapter.tr-064.2                 : tr-064                : briioBrProx                              -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : briioBrProx                              -  enabled
      system.adapter.tvspielfilm.0            : tvspielfilm           : briioBrProx                              -  enabled
    + system.adapter.upnp.0                   : upnp                  : briioBrProx                              -  enabled
      system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : briioBrProx                              -  enabled
      system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : briioBrProx                              -  enabled
      system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: briioBrProx                              -  enabled
      system.adapter.vis-2-widgets-jaeger-design.0: vis-2-widgets-jaeger-design: briioBrProx                              -  enabled
      system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: briioBrProx                              -  enabled
      system.adapter.vis-2-widgets-radar-trap.0: vis-2-widgets-radar-trap: briioBrProx                              -  enabled
      system.adapter.vis-2-widgets-sweethome3d.0: vis-2-widgets-sweethome3d: briioBrProx                              -  enabled
    + system.adapter.vis-2.0                  : vis-2                 : briioBrProx                              -  enabled
      system.adapter.vis-bars.0               : vis-bars              : briioBrProx                              -  enabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : briioBrProx                              -  enabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : briioBrProx                              -  enabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : briioBrProx                              -  enabled
      system.adapter.vis-google-fonts.0       : vis-google-fonts      : briioBrProx                              -  enabled
      system.adapter.vis-history.0            : vis-history           : briioBrProx                              -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : briioBrProx                              -  enabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : briioBrProx                              -  enabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : briioBrProx                              -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : briioBrProx                              -  enabled
      system.adapter.vis-justgage.0           : vis-justgage          : briioBrProx                              -  enabled
      system.adapter.vis-keyboard.0           : vis-keyboard          : briioBrProx                              -  enabled
      system.adapter.vis-lcars.0              : vis-lcars             : briioBrProx                              -  enabled
      system.adapter.vis-map.0                : vis-map               : briioBrProx                              -  enabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : briioBrProx                              -  enabled
      system.adapter.vis-material-webfont.0   : vis-material-webfont  : briioBrProx                              -  enabled
      system.adapter.vis-material.0           : vis-material          : briioBrProx                              -  enabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : briioBrProx                              -  enabled
      system.adapter.vis-metro.0              : vis-metro             : briioBrProx                              -  enabled
      system.adapter.vis-players.0            : vis-players           : briioBrProx                              -  enabled
      system.adapter.vis-plumb.0              : vis-plumb             : briioBrProx                              -  enabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : briioBrProx                              -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : briioBrProx                              -  enabled
      system.adapter.vis-weather.0            : vis-weather           : briioBrProx                              -  enabled
      system.adapter.vis.0                    : vis                   : briioBrProx                              -  enabled
      system.adapter.vofo-speedtest.0         : vofo-speedtest        : briioBrProx                              -  enabled
      system.adapter.weatherunderground.0     : weatherunderground    : briioBrProx                              -  enabled
      system.adapter.web-speedy.0             : web-speedy            : briioBrProx                              - disabled
    + system.adapter.web.0                    : web                   : briioBrProx                              -  enabled, port: 8082, bind: 192.168.8.220, run as: admin
    + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : briioBrProx                              -  enabled
    + system.adapter.yamaha.0                 : yamaha                : briioBrProx                              -  enabled
      system.adapter.yr.0                     : yr                    : briioBrProx                              -  enabled
      system.adapter.zwave2.0                 : zwave2                : briioBrProx                              - disabled
    + instance is alive
    ioBroker-Repositories
    Stable (default): http://download.iobroker.net/sources-dist.json
    Beta (latest) : http://iobroker.live/repo/sources-dist-latest.json
    Latest        : http://download.iobroker.net/sources-dist-latest.json
    Active repo(s): Beta (latest)
    Installed ioBroker-Instances
    Used repository: Beta (latest)
    Adapter    "admin"        : 6.17.14  , installed 6.17.14
    Adapter    "alarm"        : 3.6.0    , installed 3.6.0
    Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
    Adapter    "alias-manager": 1.2.6    , installed 1.2.6
    Adapter    "backitup"     : 3.0.1    , installed 2.11.0 [Updatable]
    Adapter    "bring"        : 1.8.4    , installed 1.8.4
    Adapter    "cameras"      : 2.0.5    , installed 2.0.5
    Adapter    "coronavirus-statistics": 0.9.0, installed 0.9.0
    Adapter    "daswetter"    : 3.1.15   , installed 3.1.15
    Adapter    "deconz"       : 1.4.1    , installed 1.4.1
    Adapter    "discovery"    : 4.5.0    , installed 4.5.0
    Adapter    "email"        : 1.3.0    , installed 1.3.0
    Adapter    "enigma2"      : 2.1.0    , installed 2.1.0
    Adapter    "fb-checkpresence": 1.2.4 , installed 1.2.4
    Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
    Adapter    "firetv"       : 2.1.0    , installed 2.1.0
    Adapter    "fritzbox"     : 0.6.0    , installed 0.2.1  [Updatable]
    Adapter    "fullcalendar" : 2.3.17   , installed 2.3.17
    Adapter    "fullybrowser" : 3.0.12   , installed 2.1.2  [Updatable]
    Adapter    "harmony"      : 1.4.0    , installed 1.4.0
    Adapter    "heizoel"      : 1.0.3    , installed 1.0.3
    Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
    Adapter    "hm-rpc"       : 1.17.0   , installed 1.15.19 [Updatable]
    Adapter    "hmip"         : 1.23.3   , installed 1.23.2 [Updatable]
    Adapter    "homeconnect"  : 1.4.0    , installed 1.4.0
    Adapter    "hs100"        : 2.2.0    , installed 2.2.0
    Adapter    "hue"          : 3.11.0   , installed 3.11.0
    Adapter    "ical"         : 1.15.0   , installed 1.15.0
    Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
    Adapter    "iot"          : 3.3.0    , installed 3.3.0
    Adapter    "javascript"   : 8.4.2    , installed 8.4.2
    Controller "js-controller": 5.0.19   , installed 5.0.19
    Adapter    "kodi"         : 3.1.0    , installed 3.1.0
    Adapter    "link"         : 0.5.12   , installed 0.5.12
    Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
    Adapter    "luftdaten"    : 3.1.0    , installed 3.1.0
    Adapter    "material"     : 1.3.1    , installed 1.3.1
    Adapter    "mihome"       : 1.4.0    , installed 1.4.0
    Adapter    "mikrotik"     : 1.2.0    , installed 1.2.0
    Adapter    "moma"         : 1.2.9    , installed 1.2.9
    Adapter    "mqtt-client"  : 1.8.0    , installed 1.8.0
    Adapter    "musiccast"    : 1.1.3    , installed 1.1.3
    Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
    Adapter    "nina"         : 0.0.26   , installed 0.0.26
    Adapter    "onvif"        : 1.1.4    , installed 1.1.3  [Updatable]
    Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
    Adapter    "plex"         : 1.1.4    , installed 1.1.4
    Adapter    "plexconnect"  : 0.0.7    , installed 0.0.7
    Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
    Adapter    "proxmox"      : 2.3.0    , installed 2.3.0
    Adapter    "proxy"        : 1.3.2    , installed 1.3.2
    Adapter    "pushover"     : 3.0.6    , installed 3.0.6
    Adapter    "radar2"       : 2.2.0    , installed 2.2.0
    Adapter    "shelly"       : 7.0.0    , installed 7.0.0
    Adapter    "smartgarden"  : 2.0.1    , installed 2.0.1
    Adapter    "socketio"     : 6.7.0    , installed 6.7.0
    Adapter    "sonoff"       : 3.1.0    , installed 3.1.0
    Adapter    "stockmarket"  : 0.0.2    , installed 0.0.2
    Adapter    "synology"     : 3.1.0    , installed 3.1.0
    Adapter    "tahoma"       : 0.10.4   , installed 0.10.4
    Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
    Adapter    "text2command" : 3.0.3    , installed 3.0.3
    Adapter    "trashschedule": 3.3.0    , installed 3.3.0
    Adapter    "tvspielfilm"  : 2.1.0    , installed 2.1.0
    Adapter    "upnp"         : 1.0.21   , installed 1.0.21
    Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
    Adapter    "vis-2-widgets-energy": 0.3.11, installed 0.3.11
    Adapter    "vis-2-widgets-gauges": 1.0.3, installed 1.0.3
    Adapter    "vis-2-widgets-inventwo": 0.1.9, installed 0.1.9
    Adapter    "vis-2-widgets-jaeger-design": 1.1.27, installed 1.1.27
    Adapter    "vis-2-widgets-material": 1.3.32, installed 1.3.32
    Adapter    "vis-2-widgets-radar-trap": 2.0.0, installed 2.0.0
    Adapter    "vis-2-widgets-sweethome3d": 0.1.6, installed 0.1.6
    Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
    Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
    Adapter    "vis-justgage" : 2.1.7    , installed 1.0.2  [Updatable]
    Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
    Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
    Adapter    "vis-map"      : 1.1.0    , installed 1.1.0
    Adapter    "vis-material" : 0.1.3    , installed 0.1.3
    Adapter    "vis-material-webfont": 0.0.3, installed 0.0.3
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
    Adapter    "vofo-speedtest": 2.0.1   , installed 2.0.1
    Adapter    "weatherunderground": 3.7.0, installed 3.7.0
    Adapter    "web"          : 6.2.6    , installed 6.2.6
    Adapter    "web-speedy"   : 0.2.0    , installed 0.2.0
    Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
    Adapter    "ws"           : 2.6.1    , installed 2.6.1
    Adapter    "yamaha"       : 0.5.3    , installed 0.5.3
    Adapter    "yr"           : 5.3.0    , installed 5.3.0
    Adapter    "zwave2"       : 3.1.0    , installed 3.1.0
    Objects and States
    Objects:        45006
    States:         38937
    Hit:1 https://deb.nodesource.com/node_18.x nodistro InRelease
    Hit:2 http://archive.ubuntu.com/ubuntu focal InRelease
    Hit:3 http://archive.ubuntu.com/ubuntu focal-updates InRelease
    Hit:4 http://archive.ubuntu.com/ubuntu focal-security InRelease
    Reading package lists...
    Pending Updates: 3
    *** Listening Ports ***
    tcp        0      0 192.168.8.220:8082      0.0.0.0:*               LISTEN      1000       45259877   1817/io.web.0
    tcp        0      0 127.0.0.1:27017         0.0.0.0:*               LISTEN      110        45236082   117/mongod
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       45238359   116/iobroker.js-con
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       45239415   116/iobroker.js-con
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          45237968   320/master
    tcp        0      0 127.0.0.1:8200          0.0.0.0:*               LISTEN      1000       45260787   2478/io.cameras.0
    tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      106        45237354   96/systemd-resolved
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          45237696   130/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       45239874   572/io.sonoff.0
    tcp        0      0 192.168.8.220:8701      0.0.0.0:*               LISTEN      1000       45246473   677/io.hm-rpc.3
    tcp        0      0 192.168.8.220:2010      0.0.0.0:*               LISTEN      1000       45240262   662/io.hm-rpc.2
    tcp        0      0 192.168.8.220:2001      0.0.0.0:*               LISTEN      1000       45240092   617/io.hm-rpc.0
    tcp        0      0 192.168.8.220:9292      0.0.0.0:*               LISTEN      1000       45240197   647/io.hm-rpc.1
    tcp6       0      0 :::8087                 :::*                    LISTEN      1000       45266603   2725/io.simple-api.
    tcp6       0      0 :::8084                 :::*                    LISTEN      1000       45259711   1747/io.socketio.0
    tcp6       0      0 :::8085                 :::*                    LISTEN      1000       45268159   2811/io.socketio.1
    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       49414612   88185/io.admin.0
    tcp6       0      0 :::8000                 :::*                    LISTEN      1000       45270974   2691/io.upnp.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          45237698   130/sshd: /usr/sbin
    tcp6       0      0 :::41814                :::*                    LISTEN      1000       45268427   2893/io.plexconnect
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          45237969   320/master
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       45269031   2691/io.upnp.0
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       45238878   557/io.deconz.0
    udp        0      0 192.168.8.220:5353      0.0.0.0:*                           1000       45251629   1054/io.tr-064.1
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       45248264   971/io.shelly.0
    udp        0      0 127.0.0.53:53           0.0.0.0:*                           106        45237353   96/systemd-resolved
    udp6       0      0 :::1900                 :::*                                1000       45238882   557/io.deconz.0
    udp6       0      0 :::1900                 :::*                                1000       45238881   557/io.deconz.0
    udp6       0      0 :::1900                 :::*                                1000       45238880   557/io.deconz.0
    udp6       0      0 :::1900                 :::*                                1000       45238879   557/io.deconz.0
    udp6       0      0 fe80::e82c:8aff:feb:546 :::*                                105        45238339   84/systemd-networkd
    2024-05-31 09:51:21.139  - warn: mqtt-client.0 (724) client error: Error: connect ECONNREFUSED 192.168.8.221:1883
    2024-05-31 09:51:41.950  - warn: fullybrowser.0 (2610) updateDeviceERROR 192.168.8.181
    2024-05-31 09:51:51.140  - warn: mqtt-client.0 (724) client error: Error: connect ECONNREFUSED 192.168.8.221:1883
    2024-05-31 09:51:51.172  - info: hue-extended.0 (1281) State value to set for "hue-extended.0.resourcelinks.peter_sensor_dg.classid" has to be type "string" but received type "number"
    2024-05-31 09:52:08.749  - error: life360.0 (2684) Connection established but failed to authenticate. Check your credentials!
    2024-05-31 09:52:08.749  - info: life360.0 (2684) Waiting for online operations to finish ...
    2024-05-31 09:52:08.834  - error: life360.0 (2684) Connection established but failed to authenticate. Check your credentials!
    2024-05-31 09:52:08.834  - info: life360.0 (2684) Waiting for online operations to finish ...
    2024-05-31 09:52:08.932  - error: life360.0 (2684) Connection established but failed to authenticate. Check your credentials!
    2024-05-31 09:52:08.932  - info: life360.0 (2684) Waiting for online operations to finish ...
    2024-05-31 09:52:09.040  - error: life360.0 (2684) Connection established but failed to authenticate. Check your credentials!
    2024-05-31 09:52:09.040  - info: life360.0 (2684) Waiting for online operations to finish ...
    2024-05-31 09:52:09.155  - error: life360.0 (2684) Connection established but failed to authenticate. Check your credentials!
    2024-05-31 09:52:09.156  - info: life360.0 (2684) Waiting for online operations to finish ...
    2024-05-31 09:52:09.425  - error: life360.0 (2684) Connection established but failed to authenticate. Check your credentials!
    2024-05-31 09:52:09.426  - info: life360.0 (2684) Waiting for online operations to finish ...
    2024-05-31 09:52:09.426  - error: life360.0 (2684) Failed to connect or to login for 6 times. Aborting ...
    2024-05-31 09:52:09.426  - error: life360.0 (2684) Error: Error: Connection established but failed to authenticate. Check your credentials!
    2024-05-31 09:52:09.426  - warn: life360.0 (2684) No data received from Life360 cloud services!
    2024-05-31 09:52:12.963  - info: hue-extended.0 (1281) State value to set for "hue-extended.0.sensors.004-peter_sensor_dg_light.state.lightlevel" has to be type "string" but received type "number"
    2024-05-31 09:52:12.963  - info: hue-extended.0 (1281) State value to set for "hue-extended.0.resourcelinks.peter_sensor_dg.classid" has to be type "string" but received type "number"
    2024-05-31 09:52:12.964  - info: hue-extended.0 (1281) State value to set for "hue-extended.0.resourcelinks.peter_sensor_dg.classid" has to be type "string" but received type "number"
    2024-05-31 09:52:12.964  - info: hue-extended.0 (1281) State value to set for "hue-extended.0.groups.000-all_lights.lightlevel.state.lightlevel" has to be type "string" but received type "number"
    2024-05-31 09:52:21.142  - warn: mqtt-client.0 (724) client error: Error: connect ECONNREFUSED 192.168.8.221:1883
    • P PPB1308
      hast du den?
      ja, beide.
      Skript v.2024-05-22
      *** BASE SYSTEM ***
                 Chassis: container
          Virtualization: lxc
      Docker          : false
      Kernel          : x86_64
      Userland        : 64 bit
      CPU threads: 2
                       RTC time: n/a
                RTC in local TZ: no
      peter
      HOME=/home/peter
      iobroker
      HOME=/home/iobroker
      Desktop:
      Terminal:
      *** MEMORY ***
               7168 M total memory
               5661 M used memory
                819 M active memory
                292 M free memory
                  0 M buffer memory
               1214 M swap cache
               4096 M total swap
                  0 M used swap
               4095 M free swap
      *** FILESYSTEM ***
      /var:
      5.5G    /var/
      3.9G    /var/log
      849M    /var/lib
      USB-Devices by-id:
      /usr/bin/npm            10.7.0
      /usr/bin/npx            10.7.0
      nodejs:
        Version table:
      Errors in npm tree:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.17.14
      javascript:     8.4.2
      Adapter State
      + instance is alive
      Objects and States
      Objects:        45006
      States:         38937
      Pending Updates: 3
      wer ist .220?
      P 1 Antwort Letzte Antwort
        wer ist .220?
        PPB1308
        wer ist .220?
        .220 ist der ioBroker lxc.
        • P PPB1308
          wer ist .220?
          @ppb1308 wieso ist nur der freigegeben?
          hast du da den port 8082 gemappt?
          • P PPB1308
            wer ist .220?
            @ppb1308
            ls -lah /opt/iobroker/node_modules/iobroker.vis-map/
            sagt?
            • P Offline
              PPB1308
              @thomas-braun said in Dieser Adapter benötigt den vis- oder vis-2-Adapter:
              peter@briioBrProx:/opt/iobroker$ ls -lah /opt/iobroker/node_modules/iobroker.vis-map/
              total 116K
              drwxrwxr-x+    5 iobroker iobroker 4.0K May 31 09:31 .
              drwxrwxr-x+ 1215 iobroker iobroker  68K May 31 09:31 ..
              -rw-rw-r--+    1 iobroker iobroker 2.6K May 31 09:31 LICENSE
              -rw-rw-r--+    1 iobroker iobroker 2.2K May 31 09:31 README.md
              drwxrwxr-x+    3 iobroker iobroker 4.0K May 31 09:31 admin
              drwxrwxr-x+    2 iobroker iobroker 4.0K May 31 09:31 img
              -rw-rw-r--+    1 iobroker iobroker 9.1K May 31 09:31 io-package.json
              -rw-rw-r--+    1 iobroker iobroker    1 May 31 09:31 iob_npm.done
              -rw-rw-r--+    1 iobroker iobroker 1.2K May 31 09:31 package.json
              drwxrwxr-x+    3 iobroker iobroker 4.0K May 31 09:31 widgets
                PPB1308
                ja
                • P PPB1308
                  total 116K
                  @ppb1308 dann versuch es erst mal mit iob upload all
                    PPB1308
                    ok, das hat nun fast alles upgedatet, aber das eine Vis Widget bleibt ohne Update und zeigt immer noch die Meldung im Debug "INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-justgage/www" was not found! Nothing was uploaded or deleted.":
                    das Log zum Update Versuch:
                    $ iobroker upgrade vis-justgage@2.1.7 --debug
                    Update vis-justgage from @1.0.2 to @2.1.7
                    NPM version: 10.7.0
                    Installing iobroker.vis-justgage@2.1.7... (System call)
                    npm warn ERESOLVE overriding peer dependencynpm warn While resolving: @iobroker/adapter-core@3.1.4npm warn Found: @iobroker/types@6.0.0npm warn node_modules/iobroker.admin/node_modules/@iobroker/typesnpm warn @iobroker/types@"6.0.0" from iobroker.admin@6.17.14npm warn node_modules/iobroker.adminnpm warn iobroker.admin@"6.17.14" from the root projectnpm warnnpm warn Could not resolve dependency:npm warn peer @iobroker/types@"^5.0.11" from @iobroker/adapter-core@3.1.4npm warn node_modules/iobroker.admin/node_modules/@iobroker/adapter-corenpm warn @iobroker/adapter-core@"^3.1.4" from iobroker.admin@6.17.14npm warn node_modules/iobroker.adminnpm warnnpm warn Conflicting peer dependency: @iobroker/types@5.0.19npm warn node_modules/@iobroker/typesnpm warn peer @iobroker/types@"^5.0.11" from @iobroker/adapter-core@3.1.4npm warn node_modules/iobroker.admin/node_modules/@iobroker/adapter-corenpm warn @iobroker/adapter-core@"^3.1.4" from iobroker.admin@6.17.14npm warn node_modules/iobroker.admin
                    npm warn deprecated left-pad@1.3.0: use String.prototype.padStart()
                    npm warn deprecated w3c-hr-time@1.0.2: Use your platform's native performance.now() and performance.timeOrigin.
                    npm warn deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
                    npm warn deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
                    removed 2 packages, and changed 1 package in 11s
                    Adapter "system.adapter.vis.0" restarted.
                    Adapter "system.adapter.vis-2.0" restarted.
                    Update "system.adapter.vis-justgage.0"
                    upload [2] vis-justgage.admin /opt/iobroker/node_modules/iobroker.vis-justgage/admin/index.html index.html text/html
                    upload [1] vis-justgage.admin /opt/iobroker/node_modules/iobroker.vis-justgage/admin/index_m.html index_m.html text/html
                    upload [0] vis-justgage.admin /opt/iobroker/node_modules/iobroker.vis-justgage/admin/justgage.png justgage.png image/png
                    Process exited with code 0
                    Das Verzeichnis gibts auch nicht:
                    peter@briioBrProx:/opt/iobroker$ ls -lah /opt/iobroker/node_modules/iobroker.vis-justgage
                    total 124K
                    drwxrwxr-x+    5 iobroker iobroker 4.0K May 31 10:54 .
                    drwxrwxr-x+ 1215 iobroker iobroker  68K May 31 10:54 ..
                    -rw-rw-r--+    1 iobroker iobroker 1.2K May 31 10:54 LICENSE
                    -rw-rw-r--+    1 iobroker iobroker 5.9K May 31 10:54 README.md
                    drwxrwxr-x+    2 iobroker iobroker 4.0K May 31 10:54 admin
                    drwxrwxr-x+    2 iobroker iobroker 4.0K May 31 10:54 img
                    -rw-rw-r--+    1 iobroker iobroker  14K May 31 10:54 io-package.json
                    -rw-rw-r--+    1 iobroker iobroker    1 May 31 10:54 iob_npm.done
                    -rw-rw-r--+    1 iobroker iobroker 2.5K May 31 10:54 package.json
                    drwxrwxr-x+    3 iobroker iobroker 4.0K May 31 10:54 widgets
                    HomoranH P 2 Antworten Letzte Antwort
                    • P PPB1308
                      NPM version: 10.7.0
                      total 124K
                      wR das die defekte Version?
                      • P PPB1308
                        NPM version: 10.7.0
                        total 124K
                        PPB1308
                        Update scheint aber nun geklappt zu haben, das Widget wird nicht mehr als ncht aktuell gelistet.
                        Hm, sehr merkwürdig.
                          PPB1308
                          schrieb am zuletzt editiert von PPB1308
                          Hm, kann ich nicht sagen, den Core Adapter hab ich gar nicht im Visier gehabt, nur die Vis Widgets, die sich nicht updaten ließen.
                          Das scheint ja nach dem update all wohl behoben.
                          Muss ich mir um das vermeintlich fehlende Verzeichnis Sorgen machen?
                          Danke für die Hilfe!
                          • P PPB1308
                            den Core Adapter
                            das ist kein Adapter, aber die defekte Version war es anscheinend nicht
                            Vielleicht weiss @Thomas-Braun das noch besser
                              den Core Adapter
                              @homoran @PPB1308
                              Keine Ahnung.
                              Aber bring alle Adapter auf Stand oder geh auf das Stable-Repository.
                                @homoran @PPB1308
                                Keine Ahnung.
                                PPB1308
                                ja, hab ich ja jetzt gemacht.
                                Danke.
                                • mcm1957M Online
                                  mcm1957M Online
                                  mcm1957
                                  @ppb1308
                                  Sodala
                                  adapter-core 3.1.4 ist die aktuellste und empfohlene Version
                                  vis-justgage hat kein www Verzeichnis. Keine Ahnung woher die Fehlermeldung kommt. vis-justgage ist m.W. nach nicht mit vis-2 kompatibel
                                  vis-map gibt diese Meldung via admin news aus. Die Funktion ist durch diese Meldung in keiner Weise beeinflusst. Wenn das Widget funktioniert sollte also alles OK sein. Bitte eröffne ggF ein Issue im adapter repo.
                                  Support Repositoryverwaltung.
                                  LESEN - gute Forenbeitrage
