  4. ERLEDIGT: ioT Adapter Problem und keine Skill Verbindung
    2.4k
    4.4k
8 Beiträge 4 Kommentatoren 980 Aufrufe 4 Beobachtet
  • lemonbiterL Offline
    lemonbiterL Offline
    lemonbiter
    schrieb am zuletzt editiert von lemonbiter
    Ich nutze die aktuelle Version des iot Adapters 3.2.2 und habe eine aktive ioBroker Pro Lizenz
    seit drei Tagen erhalte ich alle 6 Stunden, so ungefähr auf die Minute genau, folgende Fehlermeldung im Log angezeigt:
    56
    Log-Größe: 42.7 KB
    Zeit
    warn
    Nachricht
    host.ioBroker
    2024-05-29 23:37:56.402	error	Caught by controller[0]: at TLSSocket.emit (node:events:529:35)
    host.ioBroker
    2024-05-29 23:37:56.402	error	Caught by controller[0]: at TLSSocket.<anonymous> (/opt/iobroker/node_modules/aws-iot-device-sdk/node_modules/mqtt/lib/client.js:360:10)
    host.ioBroker
    2024-05-29 23:37:56.402	error	Caught by controller[0]: at MqttClient.emit (node:domain:489:12)
    host.ioBroker
    2024-05-29 23:37:56.402	error	Caught by controller[0]: at MqttClient.emit (node:events:529:35)
    host.ioBroker
    2024-05-29 23:37:56.402	error	Caught by controller[0]: at MqttClient.<anonymous> (/opt/iobroker/node_modules/aws-iot-device-sdk/device/index.js:797:12)
    host.ioBroker
    2024-05-29 23:37:56.402	error	Caught by controller[0]: at DeviceClient.emit (node:domain:489:12)
    host.ioBroker
    2024-05-29 23:37:56.402	error	Caught by controller[0]: at DeviceClient.emit (node:events:517:28)
    host.ioBroker
    2024-05-29 23:37:56.402	error	Caught by controller[0]: at DeviceClient.onDisconnect (/opt/iobroker/node_modules/iobroker.iot/main.js:564:22)
    host.ioBroker
    2024-05-29 23:37:56.402	error	Caught by controller[0]: at RemoteAccess.onCloudDisconnect (/opt/iobroker/node_modules/iobroker.iot/lib/remote.js:720:29)
    host.ioBroker
    2024-05-29 23:37:56.402	error	Caught by controller[0]: at Function.keys (<anonymous>)
    host.ioBroker
    2024-05-29 23:37:56.402	error	Caught by controller[0]: TypeError: Cannot convert undefined or null to object
    iot.0
    2024-05-29 23:37:56.139	error	Cannot convert undefined or null to object
    iot.0
    2024-05-29 23:37:56.139	error	TypeError: Cannot convert undefined or null to object at Function.keys (<anonymous>) at RemoteAccess.onCloudDisconnect (/opt/iobroker/node_modules/iobroker.iot/lib/remote.js:720:29) at DeviceClient.onDisconnect (/opt/iobroker/node_modules/iobroker.iot/main.js:564:22) at DeviceClient.emit (node:events:517:28) at DeviceClient.emit (node:domain:489:12) at MqttClient.<anonymous> (/opt/iobroker/node_modules/aws-iot-device-sdk/device/index.js:797:12) at MqttClient.emit (node:events:529:35) at MqttClient.emit (node:domain:489:12) at TLSSocket.<anonymous> (/opt/iobroker/node_modules/aws-iot-device-sdk/node_modules/mqtt/lib/client.js:360:10) at TLSSocket.emit (node:events:529:35)
    iot.0
    2024-05-29 23:37:56.139	error	uncaught exception: Cannot convert undefined or null to object
    Ich habe zum Test den ioT Adapter einfach mal neugestartet und damit lässt sich bei jedem Neustart exakt der Fehler reproduzieren. Auch nach dem Neustart des kompletten ioB dasselbe...
    Daraufhin habe ich versucht die Zertifikate zu erneuern im ioT dapter.
    Nun meldet meine Alexa App auf dem Handy, dass ich mich im iobroker.iot Adapter neu anmelden muss...
    Aber das geht nicht, der Skill behauptet "User does not excist". Habe auch versucht, mich über die Amazon Website anzumelden... gleiche Fehlermeldung
    Adapter sind grün und laufen:
    Hat jemand eine gute Erklärung für mich, wie ich das wieder zum Laufen bekomme?
    Wenn ich in ioB den iot Adapter lösche würde und neu installiere, dann sind alle von mir hier manuell angelegten Verbindungen vermutlich auch gelöscht oder?? Das will ich lieber nicht machen, da ich einige Verknüpfungen habe...
    Lieben Dank Euch
    LEM
    • haselchenH Offline
      haselchenH Offline
      haselchen
      @lemonbiter
      Dazu gibt es anscheinend schon einen "kleinen" Thread
      https://forum.iobroker.net/topic/74277/alexa-skill-iot-anmeldung?_=1717015211720
      @apollon77
      • haselchenH haselchen
        @lemonbiter
        @apollon77
        Samson71S Offline
        Samson71S Offline
        Samson71
        @haselchen sagte in ioT Adapter Problem und keine Skill Verbindung:
        @apollon77
        Der ist im Urlaub. Kann also etwas dauern, daher Zähne zusammenbeißen und abwarten.
        Markus
        Bitte beachten:
        lemonbiterL 1 Antwort Letzte Antwort
        • Samson71S Samson71
          @apollon77
          lemonbiterL Offline
          lemonbiterL Offline
          lemonbiter
          @samson71 Danke Markus... :-)
          • lemonbiterL lemonbiter
            56
            Log-Größe: 42.7 KB
            Zeit
            warn
            Nachricht
            host.ioBroker
            host.ioBroker
            host.ioBroker
            host.ioBroker
            host.ioBroker
            host.ioBroker
            host.ioBroker
            host.ioBroker
            host.ioBroker
            host.ioBroker
            host.ioBroker
            iot.0
            iot.0
            iot.0
            Lieben Dank Euch
            LEM
            @lemonbiter Der Fehler ist in der aktuellen beta schon gefixt
            • apollon77A apollon77
              lemonbiterL Offline
              lemonbiterL Offline
              lemonbiter
              @apollon77
              Lieber @apollon77 , danke Dir herzlich, dass Du Dir sogar im Urlaub die Zeit nimmst
              ich habe die aktuelle Version 3.3.0 installiert, danach den Adapter neu gestartet. Aber Alexa sagt immer noch "User does not exist". Ich komme leider nicht weiter...
              Danach habe ich die beiden Anmeldeinformationen neu angefordert (nacheinander) und immer den Adapter jeweils neugestartet...
              Auch kann ich bei Alexa bei "Passwort vergessen" kein neues Passwort anfordern...
              Ich bin mir sicher, ich mache etwas verkehrt... aber wie mache ich es richtig??
              Danke Dir
              LEM
                @apollon77
                Danke Dir
                LEM
                @lemonbiter Und du gibst die korrekten credentials ein, die von https://iobroker.pro ??! Bitte verifizieren das du dich mit denen dort einloggen kannst UND der iot Adapter läuft und auch dort diese credentials angegeben sind
                  lemonbiterL Offline
                  lemonbiterL Offline
                  lemonbiter
                  @apollon77
                  Lieber @apollon77 ,
                  HAT SICH ERLEDIGT.
                  .. Habe es gerade noch einmal versucht die Verknüpfung auf dem iPhone wieder herzustellen. Alexa app sagt: "Kann nicht aktiviert werden, Deine App muss aktualisiert werden". ... Habe ich dann gemacht und ZACK... geht. Warum es über die Amazon Website auch nicht ging und warum mir vorher nicht angezeigt wurde, das die App auf dem iPhone aktuailsiert werden muss.. KEINE AHNUNG...
                  DANKE DIR für den super Adapter. Bin so froh, dass er wieder funktioniert!
                  ja, ... meine emailadresse, mit der ich mich bei iobroker.pro anmelde nutze ich, um den skill von iobroker.iot entweder in der alexa app auf meinem iphone oder bei amazon (webaktivierung des Skills) zu nutzen. Beim Versuch den Skill zu aktivieren nutze ich definitiv dieselben credentials, die ich auch für den weblogin bei iobroker.pro verwende.
                  Als Antwort bekomme ich dann
                  und der Adapter läuft:
                  Danke für Deine Unterstützung
                  LEM
