  4. (FAQ) Zigbee LAN-USB-WLAN Gateway CC2652P
90 Beiträge 13 Kommentatoren 22.5k Aufrufe 23 Beobachtet
    Dave83
    #68
    Darf ich das hier als Protokoll notieren. Leider war es bei mir heute wieder nicht erreichbar.
      Dave83
      #69
      Gerade funktionierte es wieder nicht.
      Hier mal aus dem protokoll.
      admin.0
      2024-05-10 13:34:44.970	info	<== Disconnect system.user.admin from ::ffff:172.17.0.1
      admin.0
      zigbee.0
      2024-05-10 13:34:43.617	info	List of port: [{"path":"/dev/ttyS1"},{"path":"/dev/ttyS0"},{"path":"/dev/ttyS2"},{"path":"/dev/ttyS3"}]
      admin.0
      2024-05-10 13:34:43.210	info	==> Connected system.user.admin from ::ffff:172.17.0.1
      zigbee.0
      2024-05-10 13:34:36.815	info	deregister device Ping for deactivated device "0x00158d00045cfa19"
      zigbee.0
      2024-05-10 13:34:36.815	info	debug devices set to []
      zigbee.0
      2024-05-10 13:34:36.803	info	deregister device Ping for deactivated device "0x50325ffffe29c8ca"
      zigbee.0
      2024-05-10 13:34:36.802	info	deregister device Ping for deactivated device "0x00158d00075f861e"
      zigbee.0
      2024-05-10 13:34:36.800	info	deregister device Ping for deactivated device "0x00158d0004452056"
      zigbee.0
      2024-05-10 13:34:36.800	info	deregister device Ping for deactivated device "0x0c4314fffea066d2"
      zigbee.0
      2024-05-10 13:34:36.800	info	deregister device Ping for deactivated device "0x0c4314fffea066e0"
      zigbee.0
      2024-05-10 13:34:36.800	info	deregister device Ping for deactivated device "0x00158d0006ba677b"
      zigbee.0
      2024-05-10 13:34:36.798	info	deregister device Ping for deactivated device "0x00158d00075f7ac6"
      zigbee.0
      2024-05-10 13:34:36.670	info	Zigbee started
      zigbee.0
      2024-05-10 13:34:36.670	info	0x8c6fb9fffe1d28dd (addr 45621): E2201 - IKEA RODRET wireless dimmer/power switch (EndDevice)
      zigbee.0
      2024-05-10 13:34:36.669	info	0x8c6fb9fffe1d2743 (addr 1765): E2201 - IKEA RODRET wireless dimmer/power switch (EndDevice)
      zigbee.0
      2024-05-10 13:34:36.669	info	0x8c6fb9fffe1d2912 (addr 32801): E2201 - IKEA RODRET wireless dimmer/power switch (EndDevice)
      zigbee.0
      2024-05-10 13:34:36.668	info	0x881a14fffef07a8c (addr 48839): E2134 - IKEA VALLHORN wireless motion sensor (EndDevice)
      zigbee.0
      2024-05-10 13:34:36.668	info	0x000d6f0014629597 (addr 63727): AC0251100NJ/AC0251600NJ/AC0251700NJ - OSRAM Smart+ switch mini (EndDevice)
      zigbee.0
      2024-05-10 13:34:36.667	info	0x60b647fffea44aa0 (addr 23451): E2001/E2002 - IKEA STYRBAR remote control (EndDevice)
      zigbee.0
      2024-05-10 13:34:36.667	info	0x9c6937000070fad1 (addr 20041): RS 227 T - Innr GU10 spot 420 lm, dimmable, white spectrum (Router)
      zigbee.0
      2024-05-10 13:34:36.666	info	0x8c6fb9fffe642632 (addr 1836): E2201 - IKEA RODRET wireless dimmer/power switch (EndDevice)
      zigbee.0
      2024-05-10 13:34:36.666	info	0xc498860000075005 (addr 16107): RS 227 T - Innr GU10 spot 420 lm, dimmable, white spectrum (Router)
      zigbee.0
      2024-05-10 13:34:36.665	info	0xc498860000006cb1 (addr 65500): RS 227 T - Innr GU10 spot 420 lm, dimmable, white spectrum (Router)
      zigbee.0
      2024-05-10 13:34:36.665	info	0x00158d00045cfa19 (addr 30315): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
      zigbee.0
      2024-05-10 13:34:36.664	info	0x00158d0004889d9c (addr 15156): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
      zigbee.0
      2024-05-10 13:34:36.664	info	0x847127fffe8cd4eb (addr 6215): SP 220 - Innr Smart plug (Router)
      zigbee.0
      2024-05-10 13:34:36.664	info	0x00158d000449a2f1 (addr 5018): RTCGQ11LM - Aqara Motion sensor (EndDevice)
      zigbee.0
      2024-05-10 13:34:36.663	info	0x50325ffffe29c8ca (addr 31158): E2007 - IKEA STARKVIND air purifier (Router)
      zigbee.0
      2024-05-10 13:34:36.663	info	0x00158d0005072e13 (addr 11768): RB 285 C - Innr E27 bulb RGBW (Router)
      zigbee.0
      2024-05-10 13:34:36.662	info	0x00158d00045c5030 (addr 41411): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
      zigbee.0
      2024-05-10 13:34:36.662	info	0x00158d00047b3204 (addr 49889): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
      zigbee.0
      2024-05-10 13:34:36.661	info	0x00158d000423b454 (addr 20655): RTCGQ11LM - Aqara Motion sensor (EndDevice)
      zigbee.0
      2024-05-10 13:34:36.661	info	0x00158d0006c41a66 (addr 38274): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
      zigbee.0
      2024-05-10 13:34:36.660	warn	DeviceConfigure: 0x8c6fb9fffe1d2743 RODRET Dimmer Failed to configure. When device works is all fine when not wake up the device and check again
      zigbee.0
      2024-05-10 13:34:36.580	info	-> Configuring 0x8c6fb9fffe1d2743 RODRET Dimmer
      zigbee.0
      2024-05-10 13:34:36.580	info	0x00158d00059ff725 (addr 21169): RB 285 C - Innr E27 bulb RGBW (Router)
      zigbee.0
      2024-05-10 13:34:36.579	info	0x00158d00059ff751 (addr 45839): RB 285 C - Innr E27 bulb RGBW (Router)
      zigbee.0
      2024-05-10 13:34:36.578	info	0x00158d0005a16be7 (addr 22617): RB 285 C - Innr E27 bulb RGBW (Router)
      zigbee.0
      2024-05-10 13:34:36.577	info	0x00124b0024c0f51a (addr 30003): ZBMINI - SONOFF Zigbee two way smart switch (Router)
      zigbee.0
      2024-05-10 13:34:36.577	info	0x540f57fffe1d0774 (addr 57469): ICPSHC24-30EU-IL-1/ICPSHC24-10EU-IL-2 - IKEA TRADFRI LED driver, 30 w (Router)
      zigbee.0
      2024-05-10 13:34:36.576	info	0x847127fffe19f0a2 (addr 57366): SP 220 - Innr Smart plug (Router)
      zigbee.0
      2024-05-10 13:34:36.576	info	0x00158d0002f5910a (addr 60854): RB 285 C - Innr E27 bulb RGBW (Router)
      zigbee.0
      2024-05-10 13:34:36.575	info	0x00158d0005a06374 (addr 36632): RB 285 C - Innr E27 bulb RGBW (Router)
      zigbee.0
      2024-05-10 13:34:36.574	info	0x00158d0005a060b6 (addr 61927): RB 285 C - Innr E27 bulb RGBW (Router)
      zigbee.0
      2024-05-10 13:34:36.573	info	0xcc86ecfffe543275 (addr 50277): E2007 - IKEA STARKVIND air purifier (Router)
      zigbee.0
      2024-05-10 13:34:36.573	info	0x00158d00075f861e (addr 6553): RTCGQ11LM - Aqara Motion sensor (EndDevice)
      zigbee.0
      2024-05-10 13:34:36.572	info	0x00158d00075f72dc (addr 27327): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
      zigbee.0
      2024-05-10 13:34:36.571	info	0x00158d0004f86d01 (addr 37140): RB 285 C - Innr E27 bulb RGBW (Router)
      zigbee.0
      2024-05-10 13:34:36.570	info	0x00158d0005a06306 (addr 44834): RB 285 C - Innr E27 bulb RGBW (Router)
      zigbee.0
      2024-05-10 13:34:36.569	info	0x00158d0004f969cb (addr 51841): RB 285 C - Innr E27 bulb RGBW (Router)
      zigbee.0
      2024-05-10 13:34:36.568	info	0x00158d0005a16c13 (addr 26127): RB 285 C - Innr E27 bulb RGBW (Router)
      zigbee.0
      2024-05-10 13:34:36.567	info	0x00158d00059ff643 (addr 44575): RB 285 C - Innr E27 bulb RGBW (Router)
      zigbee.0
      2024-05-10 13:34:36.566	info	0x00158d0002ff2453 (addr 24358): RB 285 C - Innr E27 bulb RGBW (Router)
      zigbee.0
      2024-05-10 13:34:36.565	info	0x00158d00075f688a (addr 23071): RTCGQ11LM - Aqara Motion sensor (EndDevice)
      zigbee.0
      2024-05-10 13:34:36.564	info	0x804b50fffec129ac (addr 62722): E1757 - IKEA FYRTUR roller blind, block-out (EndDevice)
      zigbee.0
      2024-05-10 13:34:36.564	info	0x9c6937000070f61a (addr 1176): RS 227 T - Innr GU10 spot 420 lm, dimmable, white spectrum (Router)
      zigbee.0
      2024-05-10 13:34:36.563	info	0x048727fffe5c78bb (addr 49232): E2013 - IKEA PARASOLL door/window sensor (EndDevice)
      zigbee.0
      2024-05-10 13:34:36.562	info	0x84fd27fffed11f0e (addr 6420): E1757 - IKEA FYRTUR roller blind, block-out (EndDevice)
      zigbee.0
      2024-05-10 13:34:36.561	info	0x00158d0004452056 (addr 62106): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
      zigbee.0
      2024-05-10 13:34:36.561	info	0x0c4314fffea066d2 (addr 42548): E1812 - IKEA TRADFRI shortcut button (EndDevice)
      zigbee.0
      2024-05-10 13:34:36.560	info	0x0c4314fffea066e0 (addr 57678): E1812 - IKEA TRADFRI shortcut button (EndDevice)
      zigbee.0
      2024-05-10 13:34:36.559	info	0x00158d0006ba677b (addr 21063): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
      zigbee.0
      2024-05-10 13:34:36.558	info	0x00158d00075f862b (addr 8787): RTCGQ11LM - Aqara Motion sensor (EndDevice)
      zigbee.0
      2024-05-10 13:34:36.557	info	0x00158d00075f59eb (addr 48604): RTCGQ11LM - Aqara Motion sensor (EndDevice)
      zigbee.0
      2024-05-10 13:34:36.556	info	0x00158d00020e79f5 (addr 21687): FL 140 C - Innr Color Flex LED strip 4m 1200lm (Router)
      zigbee.0
      2024-05-10 13:34:36.555	info	0x00158d000507dbd0 (addr 21791): RB 285 C - Innr E27 bulb RGBW (Router)
      zigbee.0
      2024-05-10 13:34:36.555	info	0x00158d0006f25bad (addr 30322): RTCGQ11LM - Aqara Motion sensor (EndDevice)
      zigbee.0
      2024-05-10 13:34:36.554	info	0x00158d0006f86b58 (addr 24624): RTCGQ11LM - Aqara Motion sensor (EndDevice)
      zigbee.0
      2024-05-10 13:34:36.553	info	0x00158d0006c3cbb2 (addr 39324): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
      zigbee.0
      2024-05-10 13:34:36.553	info	0x00158d0005080c62 (addr 21103): RB 285 C - Innr E27 bulb RGBW (Router)
      zigbee.0
      2024-05-10 13:34:36.552	info	0x00158d0006f6b4a7 (addr 31433): RTCGQ11LM - Aqara Motion sensor (EndDevice)
      zigbee.0
      2024-05-10 13:34:36.551	info	0x00158d00075f7ac6 (addr 58538): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
      zigbee.0
      2024-05-10 13:34:36.550	info	0x00124b0024c18e48 (addr 18983): ZBMINI - SONOFF Zigbee two way smart switch (Router)
      zigbee.0
      2024-05-10 13:34:36.547	info	0x00158d0005074e4e (addr 27528): RB 285 C - Innr E27 bulb RGBW (Router)
      zigbee.0
      2024-05-10 13:34:36.444	info	Currently 59 devices are joined:
      zigbee.0
      2024-05-10 13:34:36.302	info	--> transmitPower : normal
      zigbee.0
      2024-05-10 13:34:36.290	info	Unable to disable LED, unsupported function.
      zigbee.0
      2024-05-10 13:34:36.268	info	Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20230507}}
      zigbee.0
      2024-05-10 13:34:30.537	info	Installed Version: iobroker.zigbee@1.10.3
      zigbee.0
      2024-05-10 13:34:30.333	info	Starting Zigbee npm ...
      zigbee.0
      2024-05-10 13:34:30.331	info	delete old Backup files. keep only last 10
      zigbee.0
      2024-05-10 13:34:30.273	info	starting. Version 1.10.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.19.0, js-controller: 5.0.19
      web.0
      2024-05-10 13:34:30.229	info	==> Connected system.user.admin from ::ffff:172.17.0.1
      host.18220c58f746
      2024-05-10 13:34:27.933	info	instance system.adapter.zigbee.0 started with pid 15309
      host.18220c58f746
      2024-05-10 13:34:27.819	info	"system.adapter.zigbee.0" enabled
      nuki-extended.0
      2024-05-10 13:34:06.237	info	Polling Nuki Web API with a frequency of 600s.
      nuki-extended.0
      2024-05-10 13:34:06.131	info	starting. Version 2.7.0 in /opt/iobroker/node_modules/iobroker.nuki-extended, node: v18.19.0, js-controller: 5.0.19
      web.0
      2024-05-10 13:34:05.892	info	http server listening on port 8082
      web.0
      2024-05-10 13:34:05.878	info	socket.io server listening on port 8082
      web.0
      2024-05-10 13:34:05.417	info	starting. Version 6.2.5 in /opt/iobroker/node_modules/iobroker.web, node: v18.19.0, js-controller: 5.0.19
      host.18220c58f746
      2024-05-10 13:34:04.074	info	instance system.adapter.nuki-extended.0 started with pid 15260
      host.18220c58f746
      2024-05-10 13:34:03.900	info	instance system.adapter.web.0 started with pid 15253
      host.18220c58f746
      2024-05-10 13:34:02.117	info	iobroker exit 0
      host.18220c58f746
      2024-05-10 13:34:01.796	info	instance system.adapter.web.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      host.18220c58f746
      2024-05-10 13:34:01.748	info	stopInstance system.adapter.web.0 killing pid 464
      host.18220c58f746
      2024-05-10 13:34:01.560	info	instance system.adapter.nuki-extended.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      nuki-extended.0
      2024-05-10 13:34:01.508	info	terminating
      web.0
      2024-05-10 13:34:01.245	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      web.0
      2024-05-10 13:34:01.244	info	terminating
      host.18220c58f746
      2024-05-10 13:34:01.090	info	iobroker upload [0] nuki-extended.admin /opt/iobroker/node_modules/iobroker.nuki-extended/admin/words.js words.js application/javascript
      host.18220c58f746
      2024-05-10 13:34:01.085	info	iobroker upload [1] nuki-extended.admin /opt/iobroker/node_modules/iobroker.nuki-extended/admin/nuki-extended.png nuki-extended.png image/png
      host.18220c58f746
      2024-05-10 13:34:01.080	info	iobroker upload [2] nuki-extended.admin /opt/iobroker/node_modules/iobroker.nuki-extended/admin/index_m.html index_m.html text/html
      host.18220c58f746
      2024-05-10 13:34:01.074	info	iobroker upload [3] nuki-extended.admin /opt/iobroker/node_modules/iobroker.nuki-extended/admin/admin.js admin.js application/javascript
      host.18220c58f746
      2024-05-10 13:34:01.058	info	iobroker upload [4] nuki-extended.admin /opt/iobroker/node_modules/iobroker.nuki-extended/admin/admin.css admin.css text/css
      host.18220c58f746
      2024-05-10 13:34:01.035	info	stopInstance system.adapter.nuki-extended.0 send kill signal
      nuki-extended.0
      2024-05-10 13:34:01.005	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      nuki-extended.0
      2024-05-10 13:34:01.004	info	terminating
      nuki-extended.0
      2024-05-10 13:34:01.004	info	Adapter stopped und unloaded.
      nuki-extended.0
      2024-05-10 13:34:00.997	info	Got terminate signal TERMINATE_YOURSELF
      host.18220c58f746
      2024-05-10 13:34:00.994	info	stopInstance system.adapter.nuki-extended.0 (force=false, process=true)
      host.18220c58f746
      2024-05-10 13:34:00.984	info	iobroker Update "system.adapter.nuki-extended.0"
      host.18220c58f746
      2024-05-10 13:34:00.849	info	iobroker upload [0] nuki-extended /opt/iobroker/node_modules/iobroker.nuki-extended/www/vertical-timeline.js vertical-timeline.js application/javascript
      host.18220c58f746
      2024-05-10 13:34:00.834	info	iobroker upload [1] nuki-extended /opt/iobroker/node_modules/iobroker.nuki-extended/www/vertical-timeline.css vertical-timeline.css text/css
      host.18220c58f746
      2024-05-10 13:34:00.828	info	iobroker upload [2] nuki-extended /opt/iobroker/node_modules/iobroker.nuki-extended/www/nuki.css nuki.css text/css
      host.18220c58f746
      2024-05-10 13:34:00.822	info	iobroker upload [3] nuki-extended /opt/iobroker/node_modules/iobroker.nuki-extended/www/modernizr-custom.js modernizr-custom.js application/javascript
      host.18220c58f746
      2024-05-10 13:34:00.816	info	iobroker upload [4] nuki-extended /opt/iobroker/node_modules/iobroker.nuki-extended/www/index.html index.html text/html
      host.18220c58f746
      2024-05-10 13:34:00.810	info	iobroker upload [5] nuki-extended /opt/iobroker/node_modules/iobroker.nuki-extended/www/conn.js conn.js application/javascript
      host.18220c58f746
      2024-05-10 13:34:00.804	info	iobroker upload [6] nuki-extended /opt/iobroker/node_modules/iobroker.nuki-extended/www/LOCK.js LOCK.js application/javascript
      host.18220c58f746
      2024-05-10 13:34:00.799	info	iobroker upload [7] nuki-extended /opt/iobroker/node_modules/iobroker.nuki-extended/www/LANGUAGE.js LANGUAGE.js application/javascript
      host.18220c58f746
      2024-05-10 13:34:00.786	info	stopInstance system.adapter.web.0 send kill signal
      host.18220c58f746
      2024-05-10 13:34:00.785	info	iobroker upload [8] nuki-extended /opt/iobroker/node_modules/iobroker.nuki-extended/www/ICONS.js ICONS.js application/javascript
      web.0
      2024-05-10 13:34:00.750	info	Got terminate signal TERMINATE_YOURSELF
      host.18220c58f746
      2024-05-10 13:34:00.748	info	iobroker Adapter "system.adapter.web.0" restarted.
      host.18220c58f746
      2024-05-10 13:34:00.747	info	stopInstance system.adapter.web.0 send kill signal
      host.18220c58f746
      2024-05-10 13:34:00.745	info	stopInstance system.adapter.web.0 (force=false, process=true)
      host.18220c58f746
      2024-05-10 13:34:00.744	info	"system.adapter.web.0" enabled
      web.0
      2024-05-10 13:34:00.743	warn	setTimeout called, but adapter is shutting down
      web.0
      2024-05-10 13:34:00.742	info	Got terminate signal TERMINATE_YOURSELF
      host.18220c58f746
      2024-05-10 13:34:00.739	info	stopInstance system.adapter.web.0 (force=false, process=true)
      host.18220c58f746
      2024-05-10 13:34:00.739	info	"system.adapter.web.0" disabled
      host.18220c58f746
      2024-05-10 13:34:00.660	info	iobroker 108 packages are looking for funding run `npm fund` for details
      host.18220c58f746
      2024-05-10 13:34:00.659	info	iobroker added 1 package, removed 2 packages, and changed 4 packages in 8s
      host.18220c58f746
      2024-05-10 13:33:52.135	info	iobroker Installing iobroker.nuki-extended@2.7.0... (System call)
      host.18220c58f746
      2024-05-10 13:33:52.135	info	iobroker NPM version: 10.2.3
      host.18220c58f746
      2024-05-10 13:33:51.147	info	iobroker Update nuki-extended from @2.6.5 to @2.7.0
      host.18220c58f746
      2024-05-10 13:33:48.967	info	iobroker upgrade nuki-extended@2.7.0
      web.0
      2024-05-10 13:33:44.097	info	<== Disconnect system.user.admin from ::ffff:172.17.0.1 iqontrol.0
      host.18220c58f746
      2024-05-10 13:31:52.686	info	instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      zigbee.0
      2024-05-10 13:31:52.371	info	terminating
      zigbee.0
      2024-05-10 13:31:52.167	info	debug devices set to []
      zigbee.0
      2024-05-10 13:31:52.137	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      zigbee.0
      2024-05-10 13:31:52.136	info	terminating
      zigbee.0
      2024-05-10 13:31:52.136	warn	Failed to stop zigbee during startup
      zigbee.0
      2024-05-10 13:31:51.888	info	Zigbee: disabling joining new devices.
      zigbee.0
      2024-05-10 13:31:51.870	info	cleaned everything up...
      host.18220c58f746
      2024-05-10 13:31:51.908	info	stopInstance system.adapter.zigbee.0 send kill signal
      zigbee.0
      2024-05-10 13:31:51.869	info	Got terminate signal TERMINATE_YOURSELF
      host.18220c58f746
      2024-05-10 13:31:51.865	info	stopInstance system.adapter.zigbee.0 (force=false, process=true)
      host.18220c58f746
      2024-05-10 13:31:51.864	info	"system.adapter.zigbee.0" disabled
      zigbee.0
      2024-05-10 13:31:51.093	error	Error herdsman start
      zigbee.0
      2024-05-10 13:31:51.093	error	Failed to start Zigbee
      zigbee.0
      2024-05-10 13:31:51.092	error	Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
      admin.0
      2024-05-10 13:31:50.126	info	<== Disconnect system.user.admin from ::ffff:172.17.0.1
      zigbee.0
      2024-05-10 13:31:47.297	info	List of port: [{"path":"/dev/ttyS1"},{"path":"/dev/ttyS0"},{"path":"/dev/ttyS2"},{"path":"/dev/ttyS3"}]
      zigbee.0
      2024-05-10 13:31:47.077	error	getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
      admin.0
      2024-05-10 13:31:46.895	info	==> Connected system.user.admin from ::ffff:172.17.0.1
      zigbee.0
      2024-05-10 13:31:31.814	info	Installed Version: iobroker.zigbee@1.10.3
      zigbee.0
      2024-05-10 13:31:31.348	info	Starting Zigbee npm ...
      zigbee.0
      2024-05-10 13:31:31.347	info	delete old Backup files. keep only last 10
      zigbee.0
      2024-05-10 13:31:31.048	info	starting. Version 1.10.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.19.0, js-controller: 5.0.19
      host.18220c58f746
      2024-05-10 13:31:24.314	info	instance system.adapter.zigbee.0 started with pid 15081
      host.18220c58f746
      2024-05-10 13:31:22.508	info	instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      host.18220c58f746
      2024-05-10 13:31:22.305	info	stopInstance system.adapter.zigbee.0 killing pid 394
      zigbee.0
      2024-05-10 13:31:21.743	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      zigbee.0
      2024-05-10 13:31:21.742	info	terminating
      zigbee.0
      2024-05-10 13:31:21.243	info	Zigbee: disabling joining new devices.
      zigbee.0
      2024-05-10 13:31:21.241	info	cleaned everything up...
      host.18220c58f746
      2024-05-10 13:31:21.279	info	stopInstance system.adapter.zigbee.0 send kill signal
      zigbee.0
      2024-05-10 13:31:21.240	info	Got terminate signal TERMINATE_YOURSELF
      host.18220c58f746
      2024-05-10 13:31:21.236	info	stopInstance system.adapter.zigbee.0 (force=false, process=true)
      admin.0
      2024-05-10 13:31:15.449	info	<== Disconnect system.user.admin from ::ffff:172.17.0.1
      zigbee.0
      2024-05-10 13:31:01.110	info	List of port: [{"path":"/dev/ttyS1"},{"path":"/dev/ttyS0"},{"path":"/dev/ttyS2"},{"path":"/dev/ttyS3"}]
      admin.0
      2024-05-10 13:31:00.725	info	==> Connected system.user.admin from ::ffff:172.17.0.1
      admin.0
      2024-05-10 13:30:55.594	info	<== Disconnect system.user.admin from ::ffff:172.17.0.1
      zigbee.0
      2024-05-10 13:30:53.829	error	Send command to 0x00158d000507dbd0 failed with no error code (SRSP - AF - dataRequest after 6000ms)
      zigbee.0
      2024-05-10 13:30:50.393	info	List of port: [{"path":"/dev/ttyS1"},{"path":"/dev/ttyS0"},{"path":"/dev/ttyS2"},{"path":"/dev/ttyS3"}]
      admin.0
      2024-05-10 13:30:49.969	info	==> Connected system.user.admin from ::ffff:172.17.0.1
      zigbee.0
      2024-05-10 13:30:47.828	error	Send command to 0x00158d000507dbd0 failed with no error code (SRSP - AF - dataRequest after 6000ms)
      admin.0
      2024-05-10 13:30:44.015	info	==> Connected system.user.admin from ::ffff:172.17.0.1
      zigbee.0
      2024-05-10 13:30:41.834	error	Send command to 2 failed with no error code (SRSP - AF - dataRequestExt after 6000ms)
      zigbee.0
      2024-05-10 13:30:13.163	warn	unread brightness change for group members ["0x00158d0002ff2453","0x00158d00059ff643","0x00158d0005a16c13"]
      zigbee.0
      2024-05-10 13:30:07.162	warn	DeviceAvailability:Failed to ping 0x9c6937000070fad1 RS 227 T
      zigbee.0
      2024-05-10 13:29:37.157	warn	unread colortemp change for group members ["0x00158d0005a16c13"]
      zigbee.0
      2024-05-10 13:29:19.155	warn	unread brightness change for group members ["0x00158d0005a16c13"]
      web.0
      2024-05-10 13:29:05.472	info	<== Disconnect system.user.admin from ::ffff:172.17.0.1 iqontrol.0
      web.0
      2024-05-10 13:28:05.550	info	<== Disconnect system.user.admin from ::ffff:172.17.0.1 iqontrol.0
      web.0
      2024-05-10 13:26:44.037	info	==> Connected system.user.admin from ::ffff:172.17.0.1
      web.0
      2024-05-10 13:26:28.438	info	==> Connected system.user.admin from ::ffff:172.17.0.1
      web.0
      2024-05-10 13:25:24.853	info	==> Connected system.user.admin from ::ffff:172.17.0.1
      web.0
      2024-05-10 13:20:00.093	info	<== Disconnect system.user.admin from ::ffff:172.17.0.1 iqontrol.0
      web.0
      2024-05-10 13:15:29.107	info	==> Connected system.user.admin from ::ffff:172.17.0.1
      admin.0
      2024-05-10 12:53:55.366	info	Repository received successfully.
      host.18220c58f746
      2024-05-10 12:53:53.391	info	Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
      admin.0
      2024-05-10 12:53:53.182	info	Request actual repository...
      admin.0
      2024-05-10 12:53:44.738	info	Adapter rating updated
      web.0
      2024-05-10 12:49:42.706	info	<== Disconnect system.user.admin from ::ffff:172.17.0.1 iqontrol.0
      web.0
      2024-05-10 12:47:10.258	info	==> Connected system.user.admin from ::ffff:172.17.0.1
      web.0
      2024-05-10 12:33:03.707	info	<== Disconnect system.user.admin from ::ffff:172.17.0.1 iqontrol.0
      web.0
      2024-05-10 12:30:33.071	info	==> Connected system.user.admin from ::ffff:172.17.0.1
      web.0
      2024-05-10 12:16:47.149	info	<== Disconnect system.user.admin from ::ffff:172.17.0.1 iqontrol.0
      web.0
      2024-05-10 12:14:16.804	info	==> Connected system.user.admin from ::ffff:172.17.0.1
      web.0
      2024-05-10 12:13:03.581	info	<== Disconnect system.user.admin from ::ffff:172.17.0.1 iqontrol.0
      web.0
      2024-05-10 12:11:53.853	info	<== Disconnect system.user.admin from ::ffff:172.17.0.1 iqontrol.0
      web.0
      2024-05-10 12:09:47.500	info	==> Connected system.user.admin from ::ffff:172.17.0.1
      web.0
      2024-05-10 12:09:46.205	info	<== Disconnect system.user.admin from ::ffff:172.17.0.1
      web.0
      2024-05-10 12:09:45.730	info	==> Connected system.user.admin from ::ffff:172.17.0.1
      web.0
      2024-05-10 12:09:18.695	info	==> Connected system.user.admin from ::ffff:172.17.0.1
      web.0
      2024-05-10 12:03:31.891	info	<== Disconnect system.user.admin from ::ffff:172.17.0.1 iqontrol.0
      web.0
      2024-05-10 12:01:01.858	info	==> Connected system.user.admin from ::ffff:172.17.0.1
      web.0
      2024-05-10 12:00:31.143	info	<== Disconnect system.user.admin from ::ffff:172.17.0.1 iqontrol.0
      web.0
      2024-05-10 11:57:59.781	info	==> Connected system.user.admin from ::ffff:172.17.0.1
      web.0
      2024-05-10 11:55:24.782	info	<== Disconnect system.user.admin from ::ffff:172.17.0.1 iqontrol.0
      web.0
      2024-05-10 11:52:54.211	info	==> Connected system.user.admin from ::ffff:172.17.0.1
      web.0
      2024-05-10 11:52:16.631	info	<== Disconnect system.user.admin from ::ffff:172.17.0.1 iqontrol.0
      web.0
      2024-05-10 11:49:46.444	info	==> Connected system.user.admin from ::ffff:172.17.0.1
      web.0
      2024-05-10 11:49:44.953	info	<== Disconnect system.user.admin from ::ffff:172.17.0.1 iqontrol.0
      web.0
      2024-05-10 11:36:49.629	info	==> Connected system.user.admin from ::ffff:172.17.0.1
      web.0
      2024-05-10 11:33:14.013	info	<== Disconnect system.user.admin from ::ffff:172.17.0.1 iqontrol.0
      web.0
      2024-05-10 11:30:43.826	info	==> Connected system.user.admin from ::ffff:172.17.0.1
      web.0
      2024-05-10 11:11:47.006	info	<== Disconnect system.user.admin from ::ffff:172.17.0.1 iqontrol.0
      web.0
      2024-05-10 11:11:40.661	info	==> Connected system.user.admin from ::ffff:172.17.0.1
      web.0
      2024-05-10 10:39:51.110	info	<== Disconnect system.user.admin from ::ffff:172.17.0.1 iqontrol.0
      web.0
      2024-05-10 10:37:20.868	info	==> Connected system.user.admin from ::ffff:172.17.0.1
      web.0
      2024-05-10 10:08:51.132	info	<== Disconnect system.user.admin from ::ffff:172.17.0.1 iqontrol.0
      web.0
      2024-05-10 10:06:21.020	info	==> Connected system.user.admin from ::ffff:172.17.0.1
      web.0
      2024-05-10 09:48:36.790	info	<== Disconnect system.user.admin from ::ffff:172.17.0.1 iqontrol.0
      web.0
      2024-05-10 09:46:06.642	info	==> Connected system.user.admin from ::ffff:172.17.0.1
      web.0
      2024-05-10 09:03:52.481	info	<== Disconnect system.user.admin from ::ffff:172.17.0.1 iqontrol.0
      web.0
      2024-05-10 09:01:19.574	info	==> Connected system.user.admin from ::ffff:172.17.0.1
      web.0
      2024-05-10 08:25:55.478	info	<== Disconnect system.user.admin from ::ffff:172.17.0.1 iqontrol.0
      web.0
      2024-05-10 08:23:24.906	info	==> Connected system.user.admin from ::ffff:172.17.0.1
      web.0
      2024-05-10 08:15:33.995	info	<== Disconnect system.user.admin from ::ffff:172.17.0.1 iqontrol.0
      web.0
      2024-05-10 08:13:03.655	info	==> Connected system.user.admin from ::ffff:172.17.0.1
      web.0
      2024-05-10 07:38:28.049	info	<== Disconnect system.user.admin from ::ffff:172.17.0.1 iqontrol.0
      web.0
      2024-05-10 07:35:55.656	info	==> Connected system.user.admin from ::ffff:172.17.0.1
      Kann es sein, dass man den Strom einmal komplett abziehenn muss von der Antenne? Weil nur in der Weboberfläche neustarten, reicht nicht aus.
      Ich werde mal eine andere Version asuprobieren. Weil das hier super nervt. :-(
        Dave83
        #70
        Ich würde gerne eine niedrigere FirmeWare Version testen.
        Nun stehe ich hier:
        1. ich weiß nicht ob ich Ebyte Modul oder RF-Star Modul verwenden soll.
        2. Welche Version genau soll ich versuchen?
        3. Ich kann den Schritt 4 "NVRAM sichern (NVRAM Read) !!!" nicht ausführen. Da kommt ein Fehler.
        Ich hab die Zigbee Antenne direkt an meinem Mac über USB C angeschlossen.
        • D Dave83
          Nun stehe ich hier:
          dimaiv
          #71
          @dave83 sagte in (FAQ) Zigbee LAN-USB-WLAN Gateway CC2652P:
          Nun stehe ich hier:
          Ganz oben gehört die IP von deinem Stick eingetragen und nicht irgend ein USB com-port. Der Stick bleibt am Netzteil angeschlossen!
          Wenn du auf deiner Netzwerk-Buchse Buchstabe B stehen hast, dann ist es E-Byte.
          ioBroker- NUC8i3 / Proxmox / VM
          Node.js v22.21.0
          NPM v10.9.4
          JS controller 7.1.0
          Admin 7.7.20
          ZigBee Adapter 3.3.1alpha.0
          Zigbee LAN Gateway CC2652P
          Zigbee Firmware 20250321
          Pedder007P 1 Antwort Letzte Antwort
            Dave83
            #72
            Danke, hat alles funktioniert. Die verlinkten FirmeWare sind bereits die älteren Versionen. Die die empfohlen sind.
            • D dimaiv
              Nun stehe ich hier:
              Pedder007P Offline
              Pedder007P Offline
              Pedder007
              #73
              @dimaiv
              Hallo auch nochmal von mir. Ich bin jetzt endlich dazu gekommen auch wieder auf die ältere Firmware 20221226 down zu graden.
              Schauen wir mal, ob die Aussetzer dann aufhören :-)
              Hab' dazu meinen Workaround, immer zum Ende des Monats Adapter stoppen und GW per WLAN Steckdose einmal neu booten, erstmal abgeschaltet und warte nun ab.
              Pedder
              All @Proxmox/Trixie auf HP Elitedesk 800 G4; Zigbee: ZigStar (LAN), ~110Devices
              Unifi, Motioneye/3Reolinks, PiHole, Bosch CS7800i via BBQKees/EMS-ESP, Fronius/BYD 11kWp via Modbus
              Under construction: Smart-WoMo auf Raspi4
                Dave83
                schrieb am zuletzt editiert von Dave83
                #74
                Bei mir ist es mit der alten FirmeWare wieder gerade abgestürzt. Kann es sein, dass eventuell ioBroker etwas geändert hat, womit der Anbieten nicht zurecht kommt?
                2024-05-28 07:42:35.236 - info: zigbee.0 (20660) Device '0x00158d0005a16c13' announced itself
                2024-05-28 07:42:35.258 - info: zigbee.0 (20660) Device '0x804b50fffec129ac' announced itself
                2024-05-28 07:47:17.153 - info: zigbee.0 (20660) Device '0x8c6fb9fffe1d2912' announced itself
                2024-05-28 12:13:33.398 - error: zigbee.0 (20660) Adapter disconnected, stopping
                2024-05-28 12:13:43.451 - info: zigbee.0 (20660) Try to reconnect.
                2024-05-28 12:13:43.452 - info: zigbee.0 (20660) Starting Zigbee npm ...
                2024-05-28 12:13:43.461 - info: zigbee.0 (20660) Installed Version: iobroker.zigbee@1.10.3
                2024-05-28 12:14:20.219 - error: zigbee.0 (20660) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
                2024-05-28 12:14:20.219 - error: zigbee.0 (20660) Failed to start Zigbee
                2024-05-28 12:14:20.219 - error: zigbee.0 (20660) Error herdsman start
                2024-05-28 12:14:30.221 - info: zigbee.0 (20660) Try to reconnect.
                2024-05-28 12:14:30.221 - info: zigbee.0 (20660) Starting Zigbee npm ...
                2024-05-28 12:14:30.227 - info: zigbee.0 (20660) Installed Version: iobroker.zigbee@1.10.3
                2024-05-28 12:16:37.473 - error: zigbee.0 (20660) Starting zigbee-herdsman problem : "Error while opening socket"
                2024-05-28 12:16:37.473 - error: zigbee.0 (20660) Failed to start Zigbee
                2024-05-28 12:16:37.473 - error: zigbee.0 (20660) Error herdsman start
                2024-05-28 12:16:47.474 - info: zigbee.0 (20660) Try to reconnect.
                2024-05-28 12:16:47.475 - info: zigbee.0 (20660) Starting Zigbee npm ...
                2024-05-28 12:16:47.480 - info: zigbee.0 (20660) Installed Version: iobroker.zigbee@1.10.3
                2024-05-28 12:17:09.307 - info: zigbee.0 (20660) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20221226}}
                2024-05-28 12:17:09.307 - info: zigbee.0 (20660) Unable to disable LED, unsupported function.
                2024-05-28 12:17:09.309 - info: zigbee.0 (20660) --> transmitPower : normal
                2024-05-28 12:17:09.320 - info: zigbee.0 (20660) Currently 59 devices are joined:
                2024-05-28 12:17:09.325 - info: zigbee.0 (20660) 0x00158d0005074e4e (addr 27528): RB 285 C - Innr E27 bulb RGBW (Router)
                2024-05-28 12:17:09.326 - info: zigbee.0 (20660) 0x00124b0024c18e48 (addr 18983): ZBMINI - SONOFF Zigbee two way smart switch (Router)
                2024-05-28 12:17:09.326 - info: zigbee.0 (20660) 0x00158d00075f7ac6 (addr 58538): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                2024-05-28 12:17:09.326 - info: zigbee.0 (20660) 0x00158d0006f6b4a7 (addr 31433): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                2024-05-28 12:17:09.327 - info: zigbee.0 (20660) 0x00158d0005080c62 (addr 21103): RB 285 C - Innr E27 bulb RGBW (Router)
                2024-05-28 12:17:09.328 - info: zigbee.0 (20660) 0x00158d0006c3cbb2 (addr 39324): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                2024-05-28 12:17:09.328 - info: zigbee.0 (20660) 0x00158d0006f86b58 (addr 24624): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                2024-05-28 12:17:09.329 - info: zigbee.0 (20660) 0x00158d0006f25bad (addr 30322): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                2024-05-28 12:17:09.330 - info: zigbee.0 (20660) 0x00158d000507dbd0 (addr 21791): RB 285 C - Innr E27 bulb RGBW (Router)
                2024-05-28 12:17:09.331 - info: zigbee.0 (20660) 0x00158d00020e79f5 (addr 21687): FL 140 C - Innr Color Flex LED strip 4m 1200lm (Router)
                2024-05-28 12:17:09.331 - info: zigbee.0 (20660) 0x00158d00075f59eb (addr 48604): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                2024-05-28 12:17:09.331 - info: zigbee.0 (20660) 0x00158d00075f862b (addr 8787): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                2024-05-28 12:17:09.332 - info: zigbee.0 (20660) 0x00158d0006ba677b (addr 21063): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                2024-05-28 12:17:09.332 - info: zigbee.0 (20660) 0x0c4314fffea066e0 (addr 57678): E1812 - IKEA TRADFRI shortcut button (EndDevice)
                2024-05-28 12:17:09.333 - info: zigbee.0 (20660) 0x0c4314fffea066d2 (addr 42548): E1812 - IKEA TRADFRI shortcut button (EndDevice)
                2024-05-28 12:17:09.333 - info: zigbee.0 (20660) 0x00158d0004452056 (addr 62106): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                2024-05-28 12:17:09.334 - info: zigbee.0 (20660) 0x84fd27fffed11f0e (addr 6420): E1757 - IKEA FYRTUR roller blind, block-out (EndDevice)
                2024-05-28 12:17:09.334 - info: zigbee.0 (20660) 0x048727fffe5c78bb (addr 49232): E2013 - IKEA PARASOLL door/window sensor (EndDevice)
                2024-05-28 12:17:09.335 - info: zigbee.0 (20660) 0x9c6937000070f61a (addr 1176): RS 227 T - Innr GU10 spot 420 lm, dimmable, white spectrum (Router)
                2024-05-28 12:17:09.335 - info: zigbee.0 (20660) 0x804b50fffec129ac (addr 62722): E1757 - IKEA FYRTUR roller blind, block-out (EndDevice)
                2024-05-28 12:17:09.336 - info: zigbee.0 (20660) 0x00158d00075f688a (addr 23071): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                2024-05-28 12:17:09.336 - info: zigbee.0 (20660) 0x00158d0002ff2453 (addr 24358): RB 285 C - Innr E27 bulb RGBW (Router)
                2024-05-28 12:17:09.337 - info: zigbee.0 (20660) 0x00158d00059ff643 (addr 44575): RB 285 C - Innr E27 bulb RGBW (Router)
                2024-05-28 12:17:09.337 - info: zigbee.0 (20660) 0x00158d0005a16c13 (addr 26127): RB 285 C - Innr E27 bulb RGBW (Router)
                2024-05-28 12:17:09.339 - info: zigbee.0 (20660) 0x00158d0004f969cb (addr 51841): RB 285 C - Innr E27 bulb RGBW (Router)
                2024-05-28 12:17:09.339 - info: zigbee.0 (20660) 0x00158d0005a06306 (addr 44834): RB 285 C - Innr E27 bulb RGBW (Router)
                2024-05-28 12:17:09.340 - info: zigbee.0 (20660) 0x00158d0004f86d01 (addr 37140): RB 285 C - Innr E27 bulb RGBW (Router)
                2024-05-28 12:17:09.340 - info: zigbee.0 (20660) 0x00158d00075f72dc (addr 27327): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                2024-05-28 12:17:09.341 - info: zigbee.0 (20660) 0x00158d00075f861e (addr 6553): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                2024-05-28 12:17:09.341 - info: zigbee.0 (20660) 0xcc86ecfffe543275 (addr 45105): E2007 - IKEA STARKVIND air purifier (Router)
                2024-05-28 12:17:09.342 - info: zigbee.0 (20660) 0x00158d0005a060b6 (addr 61927): RB 285 C - Innr E27 bulb RGBW (Router)
                2024-05-28 12:17:09.342 - info: zigbee.0 (20660) 0x00158d0005a06374 (addr 19078): RB 285 C - Innr E27 bulb RGBW (Router)
                2024-05-28 12:17:09.343 - info: zigbee.0 (20660) 0x00158d0002f5910a (addr 60854): RB 285 C - Innr E27 bulb RGBW (Router)
                2024-05-28 12:17:09.343 - info: zigbee.0 (20660) 0x847127fffe19f0a2 (addr 57366): SP 220 - Innr Smart plug (Router)
                2024-05-28 12:17:09.344 - info: zigbee.0 (20660) 0x540f57fffe1d0774 (addr 57469): ICPSHC24-30EU-IL-1/ICPSHC24-10EU-IL-2 - IKEA TRADFRI LED driver, 30 w (Router)
                2024-05-28 12:17:09.344 - info: zigbee.0 (20660) 0x00124b0024c0f51a (addr 30003): ZBMINI - SONOFF Zigbee two way smart switch (Router)
                2024-05-28 12:17:09.345 - info: zigbee.0 (20660) 0x00158d0005a16be7 (addr 22617): RB 285 C - Innr E27 bulb RGBW (Router)
                2024-05-28 12:17:09.345 - info: zigbee.0 (20660) 0x00158d00059ff751 (addr 45839): RB 285 C - Innr E27 bulb RGBW (Router)
                2024-05-28 12:17:09.347 - info: zigbee.0 (20660) 0x00158d00059ff725 (addr 21169): RB 285 C - Innr E27 bulb RGBW (Router)
                2024-05-28 12:17:09.347 - info: zigbee.0 (20660) 0x00158d0006c41a66 (addr 38274): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                2024-05-28 12:17:09.348 - info: zigbee.0 (20660) 0x00158d000423b454 (addr 20655): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                2024-05-28 12:17:09.348 - info: zigbee.0 (20660) 0x00158d00047b3204 (addr 49889): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
                2024-05-28 12:17:09.349 - info: zigbee.0 (20660) 0x00158d00045c5030 (addr 41411): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
                2024-05-28 12:17:09.349 - info: zigbee.0 (20660) 0x00158d0005072e13 (addr 11768): RB 285 C - Innr E27 bulb RGBW (Router)
                2024-05-28 12:17:09.350 - info: zigbee.0 (20660) 0x50325ffffe29c8ca (addr 31158): E2007 - IKEA STARKVIND air purifier (Router)
                2024-05-28 12:17:09.350 - info: zigbee.0 (20660) 0x00158d000449a2f1 (addr 5018): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                2024-05-28 12:17:09.350 - info: zigbee.0 (20660) 0x847127fffe8cd4eb (addr 6215): SP 220 - Innr Smart plug (Router)
                2024-05-28 12:17:09.351 - info: zigbee.0 (20660) 0x00158d0004889d9c (addr 15156): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
                2024-05-28 12:17:09.351 - info: zigbee.0 (20660) 0x00158d00045cfa19 (addr 30315): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
                2024-05-28 12:17:09.351 - info: zigbee.0 (20660) 0xc498860000006cb1 (addr 65500): RS 227 T - Innr GU10 spot 420 lm, dimmable, white spectrum (Router)
                2024-05-28 12:17:09.352 - info: zigbee.0 (20660) 0xc498860000075005 (addr 16107): RS 227 T - Innr GU10 spot 420 lm, dimmable, white spectrum (Router)
                2024-05-28 12:17:09.353 - info: zigbee.0 (20660) 0x8c6fb9fffe642632 (addr 1836): E2201 - IKEA RODRET wireless dimmer/power switch (EndDevice)
                2024-05-28 12:17:09.353 - info: zigbee.0 (20660) 0x9c6937000070fad1 (addr 20041): RS 227 T - Innr GU10 spot 420 lm, dimmable, white spectrum (Router)
                2024-05-28 12:17:09.354 - info: zigbee.0 (20660) 0x60b647fffea44aa0 (addr 58546): E2001/E2002 - IKEA STYRBAR remote control (EndDevice)
                2024-05-28 12:17:09.354 - info: zigbee.0 (20660) 0x000d6f0014629597 (addr 63727): AC0251100NJ/AC0251600NJ/AC0251700NJ - OSRAM Smart+ switch mini (EndDevice)
                2024-05-28 12:17:09.355 - info: zigbee.0 (20660) 0x881a14fffef07a8c (addr 48839): E2134 - IKEA VALLHORN wireless motion sensor (EndDevice)
                2024-05-28 12:17:09.356 - info: zigbee.0 (20660) 0x8c6fb9fffe1d2912 (addr 30875): E2201 - IKEA RODRET wireless dimmer/power switch (EndDevice)
                2024-05-28 12:17:09.356 - info: zigbee.0 (20660) 0x8c6fb9fffe1d2743 (addr 17185): E2201 - IKEA RODRET wireless dimmer/power switch (EndDevice)
                2024-05-28 12:17:09.357 - info: zigbee.0 (20660) 0x8c6fb9fffe1d28dd (addr 7605): E2201 - IKEA RODRET wireless dimmer/power switch (EndDevice)
                2024-05-28 12:17:09.357 - info: zigbee.0 (20660) Zigbee started
                2024-05-28 12:17:09.495 - info: zigbee.0 (20660) deregister device Ping for deactivated device "0x00158d00075f7ac6"
                2024-05-28 12:17:09.496 - info: zigbee.0 (20660) deregister device Ping for deactivated device "0x00158d0006ba677b"
                2024-05-28 12:17:09.496 - info: zigbee.0 (20660) deregister device Ping for deactivated device "0x0c4314fffea066e0"
                2024-05-28 12:17:09.496 - info: zigbee.0 (20660) deregister device Ping for deactivated device "0x0c4314fffea066d2"
                2024-05-28 12:17:09.496 - info: zigbee.0 (20660) deregister device Ping for deactivated device "0x00158d0004452056"
                2024-05-28 12:17:09.497 - info: zigbee.0 (20660) deregister device Ping for deactivated device "0x00158d00075f861e"
                2024-05-28 12:17:09.498 - info: zigbee.0 (20660) deregister device Ping for deactivated device "0x50325ffffe29c8ca"
                2024-05-28 12:17:09.498 - info: zigbee.0 (20660) deregister device Ping for deactivated device "0x00158d00045cfa19"
                2024-05-28 12:17:39.859 - info: zigbee.0 (20660) Device '0x8c6fb9fffe1d2912' announced itself
                2024-05-28 12:17:39.860 - info: zigbee.0 (20660) Device '0x8c6fb9fffe1d2912' announced itself
                2024-05-28 12:17:57.711 - warn: zigbee.0 (20660) DeviceAvailability:Stopping to ping 0x847127fffe19f0a2 SP 220 after 9 ping attempts
                2024-05-28 12:19:20.065 - error: zigbee.0 (20660) Adapter disconnected, stopping
                2024-05-28 12:19:20.067 - error: zigbee.0 (20660) Adapter disconnected, stopping
                2024-05-28 12:19:20.069 - error: zigbee.0 (20660) Adapter disconnected, stopping
                2024-05-28 12:19:20.072 - error: zigbee.0 (20660) Adapter disconnected, stopping
                2024-05-28 12:19:30.082 - info: zigbee.0 (20660) Try to reconnect.
                2024-05-28 12:19:30.083 - info: zigbee.0 (20660) Starting Zigbee npm ...
                2024-05-28 12:19:30.083 - info: zigbee.0 (20660) Try to reconnect.
                2024-05-28 12:19:30.084 - info: zigbee.0 (20660) Try to reconnect.
                2024-05-28 12:19:30.084 - info: zigbee.0 (20660) Starting Zigbee npm ...
                2024-05-28 12:19:30.085 - info: zigbee.0 (20660) Starting Zigbee npm ...
                2024-05-28 12:19:30.097 - info: zigbee.0 (20660) Installed Version: iobroker.zigbee@1.10.3
                2024-05-28 12:19:30.098 - info: zigbee.0 (20660) Installed Version: iobroker.zigbee@1.10.3
                2024-05-28 12:19:30.103 - info: zigbee.0 (20660) Installed Version: iobroker.zigbee@1.10.3
                2024-05-28 12:19:48.257 - info: zigbee.0 (20660) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20221226}}
                2024-05-28 12:19:48.258 - info: zigbee.0 (20660) Unable to disable LED, unsupported function.
                2024-05-28 12:19:48.259 - info: zigbee.0 (20660) --> transmitPower : normal
                2024-05-28 12:19:48.275 - info: zigbee.0 (20660) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20221226}}
                2024-05-28 12:19:48.275 - info: zigbee.0 (20660) Unable to disable LED, unsupported function.
                2024-05-28 12:19:48.276 - info: zigbee.0 (20660) --> transmitPower : normal
                2024-05-28 12:19:48.289 - info: zigbee.0 (20660) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20221226}}
                2024-05-28 12:19:48.290 - info: zigbee.0 (20660) Unable to disable LED, unsupported function.
                2024-05-28 12:19:48.291 - info: zigbee.0 (20660) --> transmitPower : normal
                2024-05-28 12:19:48.318 - info: zigbee.0 (20660) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20221226}}
                2024-05-28 12:19:48.319 - info: zigbee.0 (20660) Unable to disable LED, unsupported function.
                2024-05-28 12:19:48.320 - info: zigbee.0 (20660) --> transmitPower : normal
                2024-05-28 12:19:48.331 - info: zigbee.0 (20660) Currently 59 devices are joined:
                2024-05-28 12:19:48.337 - info: zigbee.0 (20660) 0x00158d0005074e4e (addr 27528): RB 285 C - Innr E27 bulb RGBW (Router)
                2024-05-28 12:19:48.337 - info: zigbee.0 (20660) 0x00124b0024c18e48 (addr 18983): ZBMINI - SONOFF Zigbee two way smart switch (Router)
                2024-05-28 12:19:48.338 - info: zigbee.0 (20660) 0x00158d00075f7ac6 (addr 58538): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                2024-05-28 12:19:48.340 - info: zigbee.0 (20660) 0x00158d0006f6b4a7 (addr 31433): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                2024-05-28 12:19:48.341 - info: zigbee.0 (20660) 0x00158d0005080c62 (addr 21103): RB 285 C - Innr E27 bulb RGBW (Router)
                2024-05-28 12:19:48.341 - info: zigbee.0 (20660) 0x00158d0006c3cbb2 (addr 39324): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                2024-05-28 12:19:48.342 - info: zigbee.0 (20660) 0x00158d0006f86b58 (addr 24624): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                2024-05-28 12:19:48.342 - info: zigbee.0 (20660) 0x00158d0006f25bad (addr 30322): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                2024-05-28 12:19:48.343 - info: zigbee.0 (20660) 0x00158d000507dbd0 (addr 21791): RB 285 C - Innr E27 bulb RGBW (Router)
                2024-05-28 12:19:48.343 - info: zigbee.0 (20660) 0x00158d00020e79f5 (addr 21687): FL 140 C - Innr Color Flex LED strip 4m 1200lm (Router)
                2024-05-28 12:19:48.344 - info: zigbee.0 (20660) 0x00158d00075f59eb (addr 48604): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                2024-05-28 12:19:48.344 - info: zigbee.0 (20660) 0x00158d00075f862b (addr 8787): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                2024-05-28 12:19:48.344 - info: zigbee.0 (20660) 0x00158d0006ba677b (addr 21063): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                2024-05-28 12:19:48.345 - info: zigbee.0 (20660) 0x0c4314fffea066e0 (addr 57678): E1812 - IKEA TRADFRI shortcut button (EndDevice)
                2024-05-28 12:19:48.346 - info: zigbee.0 (20660) 0x0c4314fffea066d2 (addr 42548): E1812 - IKEA TRADFRI shortcut button (EndDevice)
                2024-05-28 12:19:48.346 - info: zigbee.0 (20660) 0x00158d0004452056 (addr 62106): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                2024-05-28 12:19:48.347 - info: zigbee.0 (20660) 0x84fd27fffed11f0e (addr 6420): E1757 - IKEA FYRTUR roller blind, block-out (EndDevice)
                2024-05-28 12:19:48.347 - info: zigbee.0 (20660) 0x048727fffe5c78bb (addr 49232): E2013 - IKEA PARASOLL door/window sensor (EndDevice)
                2024-05-28 12:19:48.348 - info: zigbee.0 (20660) 0x9c6937000070f61a (addr 1176): RS 227 T - Innr GU10 spot 420 lm, dimmable, white spectrum (Router)
                2024-05-28 12:19:48.348 - info: zigbee.0 (20660) 0x804b50fffec129ac (addr 62722): E1757 - IKEA FYRTUR roller blind, block-out (EndDevice)
                2024-05-28 12:19:48.349 - info: zigbee.0 (20660) 0x00158d00075f688a (addr 23071): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                2024-05-28 12:19:48.349 - info: zigbee.0 (20660) 0x00158d0002ff2453 (addr 24358): RB 285 C - Innr E27 bulb RGBW (Router)
                2024-05-28 12:19:48.350 - info: zigbee.0 (20660) 0x00158d00059ff643 (addr 44575): RB 285 C - Innr E27 bulb RGBW (Router)
                2024-05-28 12:19:48.350 - info: zigbee.0 (20660) 0x00158d0005a16c13 (addr 26127): RB 285 C - Innr E27 bulb RGBW (Router)
                2024-05-28 12:19:48.351 - info: zigbee.0 (20660) 0x00158d0004f969cb (addr 51841): RB 285 C - Innr E27 bulb RGBW (Router)
                2024-05-28 12:19:48.352 - info: zigbee.0 (20660) 0x00158d0005a06306 (addr 44834): RB 285 C - Innr E27 bulb RGBW (Router)
                2024-05-28 12:19:48.353 - info: zigbee.0 (20660) 0x00158d0004f86d01 (addr 37140): RB 285 C - Innr E27 bulb RGBW (Router)
                2024-05-28 12:19:48.353 - info: zigbee.0 (20660) 0x00158d00075f72dc (addr 27327): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                2024-05-28 12:19:48.354 - info: zigbee.0 (20660) 0x00158d00075f861e (addr 6553): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                2024-05-28 12:19:48.354 - info: zigbee.0 (20660) 0xcc86ecfffe543275 (addr 45105): E2007 - IKEA STARKVIND air purifier (Router)
                2024-05-28 12:19:48.355 - info: zigbee.0 (20660) 0x00158d0005a060b6 (addr 61927): RB 285 C - Innr E27 bulb RGBW (Router)
                2024-05-28 12:19:48.355 - info: zigbee.0 (20660) 0x00158d0005a06374 (addr 19078): RB 285 C - Innr E27 bulb RGBW (Router)
                2024-05-28 12:19:48.358 - info: zigbee.0 (20660) 0x00158d0002f5910a (addr 60854): RB 285 C - Innr E27 bulb RGBW (Router)
                2024-05-28 12:19:48.358 - info: zigbee.0 (20660) 0x847127fffe19f0a2 (addr 57366): SP 220 - Innr Smart plug (Router)
                2024-05-28 12:19:48.359 - info: zigbee.0 (20660) 0x540f57fffe1d0774 (addr 57469): ICPSHC24-30EU-IL-1/ICPSHC24-10EU-IL-2 - IKEA TRADFRI LED driver, 30 w (Router)
                2024-05-28 12:19:48.359 - info: zigbee.0 (20660) 0x00124b0024c0f51a (addr 30003): ZBMINI - SONOFF Zigbee two way smart switch (Router)
                2024-05-28 12:19:48.360 - info: zigbee.0 (20660) 0x00158d0005a16be7 (addr 22617): RB 285 C - Innr E27 bulb RGBW (Router)
                2024-05-28 12:19:48.360 - info: zigbee.0 (20660) 0x00158d00059ff751 (addr 45839): RB 285 C - Innr E27 bulb RGBW (Router)
                2024-05-28 12:19:48.361 - info: zigbee.0 (20660) 0x00158d00059ff725 (addr 21169): RB 285 C - Innr E27 bulb RGBW (Router)
                2024-05-28 12:19:48.361 - info: zigbee.0 (20660) 0x00158d0006c41a66 (addr 38274): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                2024-05-28 12:19:48.361 - info: zigbee.0 (20660) 0x00158d000423b454 (addr 20655): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                2024-05-28 12:19:48.362 - info: zigbee.0 (20660) 0x00158d00047b3204 (addr 49889): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
                2024-05-28 12:19:48.362 - info: zigbee.0 (20660) 0x00158d00045c5030 (addr 41411): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
                2024-05-28 12:19:48.363 - info: zigbee.0 (20660) 0x00158d0005072e13 (addr 11768): RB 285 C - Innr E27 bulb RGBW (Router)
                2024-05-28 12:19:48.363 - info: zigbee.0 (20660) 0x50325ffffe29c8ca (addr 31158): E2007 - IKEA STARKVIND air purifier (Router)
                2024-05-28 12:19:48.364 - info: zigbee.0 (20660) 0x00158d000449a2f1 (addr 5018): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                2024-05-28 12:19:48.364 - info: zigbee.0 (20660) 0x847127fffe8cd4eb (addr 6215): SP 220 - Innr Smart plug (Router)
                2024-05-28 12:19:48.365 - info: zigbee.0 (20660) 0x00158d0004889d9c (addr 15156): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
                2024-05-28 12:19:48.365 - info: zigbee.0 (20660) 0x00158d00045cfa19 (addr 30315): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
                2024-05-28 12:19:48.366 - info: zigbee.0 (20660) 0xc498860000006cb1 (addr 65500): RS 227 T - Innr GU10 spot 420 lm, dimmable, white spectrum (Router)
                2024-05-28 12:19:48.366 - info: zigbee.0 (20660) 0xc498860000075005 (addr 16107): RS 227 T - Innr GU10 spot 420 lm, dimmable, white spectrum (Router)
                2024-05-28 12:19:48.367 - info: zigbee.0 (20660) 0x8c6fb9fffe642632 (addr 1836): E2201 - IKEA RODRET wireless dimmer/power switch (EndDevice)
                2024-05-28 12:19:48.367 - info: zigbee.0 (20660) 0x9c6937000070fad1 (addr 20041): RS 227 T - Innr GU10 spot 420 lm, dimmable, white spectrum (Router)
                2024-05-28 12:19:48.368 - info: zigbee.0 (20660) 0x60b647fffea44aa0 (addr 58546): E2001/E2002 - IKEA STYRBAR remote control (EndDevice)
                2024-05-28 12:19:48.368 - info: zigbee.0 (20660) 0x000d6f0014629597 (addr 63727): AC0251100NJ/AC0251600NJ/AC0251700NJ - OSRAM Smart+ switch mini (EndDevice)
                2024-05-28 12:19:48.369 - info: zigbee.0 (20660) 0x881a14fffef07a8c (addr 48839): E2134 - IKEA VALLHORN wireless motion sensor (EndDevice)
                2024-05-28 12:19:48.369 - info: zigbee.0 (20660) 0x8c6fb9fffe1d2912 (addr 10704): E2201 - IKEA RODRET wireless dimmer/power switch (EndDevice)
                2024-05-28 12:19:48.369 - info: zigbee.0 (20660) 0x8c6fb9fffe1d2743 (addr 17185): E2201 - IKEA RODRET wireless dimmer/power switch (EndDevice)
                2024-05-28 12:19:48.370 - info: zigbee.0 (20660) 0x8c6fb9fffe1d28dd (addr 7605): E2201 - IKEA RODRET wireless dimmer/power switch (EndDevice)
                2024-05-28 12:19:48.370 - info: zigbee.0 (20660) Zigbee started
                2024-05-28 12:19:48.514 - info: zigbee.0 (20660) Currently 59 devices are joined:
                2024-05-28 12:19:48.515 - info: zigbee.0 (20660) 0x00158d0005074e4e (addr 27528): RB 285 C - Innr E27 bulb RGBW (Router)
                2024-05-28 12:19:48.515 - info: zigbee.0 (20660) 0x00124b0024c18e48 (addr 18983): ZBMINI - SONOFF Zigbee two way smart switch (Router)
                2024-05-28 12:19:48.516 - info: zigbee.0 (20660) 0x00158d00075f7ac6 (addr 58538): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                2024-05-28 12:19:48.516 - info: zigbee.0 (20660) 0x00158d0006f6b4a7 (addr 31433): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                2024-05-28 12:19:48.517 - info: zigbee.0 (20660) 0x00158d0005080c62 (addr 21103): RB 285 C - Innr E27 bulb RGBW (Router)
                2024-05-28 12:19:48.517 - info: zigbee.0 (20660) 0x00158d0006c3cbb2 (addr 39324): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                2024-05-28 12:19:48.518 - info: zigbee.0 (20660) 0x00158d0006f86b58 (addr 24624): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                2024-05-28 12:19:48.518 - info: zigbee.0 (20660) 0x00158d0006f25bad (addr 30322): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                2024-05-28 12:19:48.518 - info: zigbee.0 (20660) 0x00158d000507dbd0 (addr 21791): RB 285 C - Innr E27 bulb RGBW (Router)
                2024-05-28 12:19:48.519 - info: zigbee.0 (20660) 0x00158d00020e79f5 (addr 21687): FL 140 C - Innr Color Flex LED strip 4m 1200lm (Router)
                2024-05-28 12:19:48.519 - info: zigbee.0 (20660) 0x00158d00075f59eb (addr 48604): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                2024-05-28 12:19:48.520 - info: zigbee.0 (20660) 0x00158d00075f862b (addr 8787): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                2024-05-28 12:19:48.520 - info: zigbee.0 (20660) 0x00158d0006ba677b (addr 21063): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                2024-05-28 12:19:48.521 - info: zigbee.0 (20660) 0x0c4314fffea066e0 (addr 57678): E1812 - IKEA TRADFRI shortcut button (EndDevice)
                2024-05-28 12:19:48.521 - info: zigbee.0 (20660) 0x0c4314fffea066d2 (addr 42548): E1812 - IKEA TRADFRI shortcut button (EndDevice)
                2024-05-28 12:19:48.522 - info: zigbee.0 (20660) 0x00158d0004452056 (addr 62106): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                2024-05-28 12:19:48.522 - info: zigbee.0 (20660) 0x84fd27fffed11f0e (addr 6420): E1757 - IKEA FYRTUR roller blind, block-out (EndDevice)
                2024-05-28 12:19:48.522 - info: zigbee.0 (20660) 0x048727fffe5c78bb (addr 49232): E2013 - IKEA PARASOLL door/window sensor (EndDevice)
                2024-05-28 12:19:48.523 - info: zigbee.0 (20660) 0x9c6937000070f61a (addr 1176): RS 227 T - Innr GU10 spot 420 lm, dimmable, white spectrum (Router)
                2024-05-28 12:19:48.523 - info: zigbee.0 (20660) 0x804b50fffec129ac (addr 62722): E1757 - IKEA FYRTUR roller blind, block-out (EndDevice)
                2024-05-28 12:19:48.524 - info: zigbee.0 (20660) 0x00158d00075f688a (addr 23071): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                2024-05-28 12:19:48.524 - info: zigbee.0 (20660) 0x00158d0002ff2453 (addr 24358): RB 285 C - Innr E27 bulb RGBW (Router)
                2024-05-28 12:19:48.525 - info: zigbee.0 (20660) 0x00158d00059ff643 (addr 44575): RB 285 C - Innr E27 bulb RGBW (Router)
                2024-05-28 12:19:48.525 - info: zigbee.0 (20660) 0x00158d0005a16c13 (addr 26127): RB 285 C - Innr E27 bulb RGBW (Router)
                2024-05-28 12:19:48.529 - info: zigbee.0 (20660) 0x00158d0004f969cb (addr 51841): RB 285 C - Innr E27 bulb RGBW (Router)
                2024-05-28 12:19:48.529 - info: zigbee.0 (20660) 0x00158d0005a06306 (addr 44834): RB 285 C - Innr E27 bulb RGBW (Router)
                2024-05-28 12:19:48.530 - info: zigbee.0 (20660) 0x00158d0004f86d01 (addr 37140): RB 285 C - Innr E27 bulb RGBW (Router)
                2024-05-28 12:19:48.530 - info: zigbee.0 (20660) 0x00158d00075f72dc (addr 27327): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                2024-05-28 12:19:48.531 - info: zigbee.0 (20660) 0x00158d00075f861e (addr 6553): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                2024-05-28 12:19:48.531 - info: zigbee.0 (20660) 0xcc86ecfffe543275 (addr 45105): E2007 - IKEA STARKVIND air purifier (Router)
                2024-05-28 12:19:48.532 - info: zigbee.0 (20660) 0x00158d0005a060b6 (addr 61927): RB 285 C - Innr E27 bulb RGBW (Router)
                2024-05-28 12:19:48.532 - info: zigbee.0 (20660) 0x00158d0005a06374 (addr 19078): RB 285 C - Innr E27 bulb RGBW (Router)
                2024-05-28 12:19:48.533 - info: zigbee.0 (20660) 0x00158d0002f5910a (addr 60854): RB 285 C - Innr E27 bulb RGBW (Router)
                2024-05-28 12:19:48.533 - info: zigbee.0 (20660) 0x847127fffe19f0a2 (addr 57366): SP 220 - Innr Smart plug (Router)
                2024-05-28 12:19:48.534 - info: zigbee.0 (20660) 0x540f57fffe1d0774 (addr 57469): ICPSHC24-30EU-IL-1/ICPSHC24-10EU-IL-2 - IKEA TRADFRI LED driver, 30 w (Router)
                2024-05-28 12:19:48.534 - info: zigbee.0 (20660) 0x00124b0024c0f51a (addr 30003): ZBMINI - SONOFF Zigbee two way smart switch (Router)
                2024-05-28 12:19:48.535 - info: zigbee.0 (20660) 0x00158d0005a16be7 (addr 22617): RB 285 C - Innr E27 bulb RGBW (Router)
                2024-05-28 12:19:48.535 - info: zigbee.0 (20660) 0x00158d00059ff751 (addr 45839): RB 285 C - Innr E27 bulb RGBW (Router)
                2024-05-28 12:19:48.536 - info: zigbee.0 (20660) 0x00158d00059ff725 (addr 21169): RB 285 C - Innr E27 bulb RGBW (Router)
                2024-05-28 12:19:48.536 - info: zigbee.0 (20660) 0x00158d0006c41a66 (addr 38274): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                2024-05-28 12:19:48.536 - info: zigbee.0 (20660) 0x00158d000423b454 (addr 20655): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                2024-05-28 12:19:48.537 - info: zigbee.0 (20660) 0x00158d00047b3204 (addr 49889): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
                2024-05-28 12:19:48.537 - info: zigbee.0 (20660) 0x00158d00045c5030 (addr 41411): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
                2024-05-28 12:19:48.537 - info: zigbee.0 (20660) 0x00158d0005072e13 (addr 11768): RB 285 C - Innr E27 bulb RGBW (Router)
                2024-05-28 12:19:48.538 - info: zigbee.0 (20660) 0x50325ffffe29c8ca (addr 31158): E2007 - IKEA STARKVIND air purifier (Router)
                2024-05-28 12:19:48.538 - info: zigbee.0 (20660) 0x00158d000449a2f1 (addr 5018): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                2024-05-28 12:19:48.539 - info: zigbee.0 (20660) 0x847127fffe8cd4eb (addr 6215): SP 220 - Innr Smart plug (Router)
                2024-05-28 12:19:48.539 - info: zigbee.0 (20660) 0x00158d0004889d9c (addr 15156): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
                2024-05-28 12:19:48.539 - info: zigbee.0 (20660) 0x00158d00045cfa19 (addr 30315): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
                2024-05-28 12:19:48.540 - info: zigbee.0 (20660) 0xc498860000006cb1 (addr 65500): RS 227 T - Innr GU10 spot 420 lm, dimmable, white spectrum (Router)
                2024-05-28 12:19:48.540 - info: zigbee.0 (20660) 0xc498860000075005 (addr 16107): RS 227 T - Innr GU10 spot 420 lm, dimmable, white spectrum (Router)
                2024-05-28 12:19:48.541 - info: zigbee.0 (20660) 0x8c6fb9fffe642632 (addr 1836): E2201 - IKEA RODRET wireless dimmer/power switch (EndDevice)
                2024-05-28 12:19:48.541 - info: zigbee.0 (20660) 0x9c6937000070fad1 (addr 20041): RS 227 T - Innr GU10 spot 420 lm, dimmable, white spectrum (Router)
                2024-05-28 12:19:48.562 - info: zigbee.0 (20660) 0x60b647fffea44aa0 (addr 58546): E2001/E2002 - IKEA STYRBAR remote control (EndDevice)
                2024-05-28 12:19:48.562 - info: zigbee.0 (20660) 0x000d6f0014629597 (addr 63727): AC0251100NJ/AC0251600NJ/AC0251700NJ - OSRAM Smart+ switch mini (EndDevice)
                2024-05-28 12:19:48.563 - info: zigbee.0 (20660) 0x881a14fffef07a8c (addr 48839): E2134 - IKEA VALLHORN wireless motion sensor (EndDevice)
                2024-05-28 12:19:48.564 - info: zigbee.0 (20660) 0x8c6fb9fffe1d2912 (addr 10704): E2201 - IKEA RODRET wireless dimmer/power switch (EndDevice)
                2024-05-28 12:19:48.564 - info: zigbee.0 (20660) 0x8c6fb9fffe1d2743 (addr 17185): E2201 - IKEA RODRET wireless dimmer/power switch (EndDevice)
                2024-05-28 12:19:48.565 - info: zigbee.0 (20660) 0x8c6fb9fffe1d28dd (addr 7605): E2201 - IKEA RODRET wireless dimmer/power switch (EndDevice)
                2024-05-28 12:19:48.565 - info: zigbee.0 (20660) Zigbee started
                2024-05-28 12:19:48.707 - info: zigbee.0 (20660) deregister device Ping for deactivated device "0x00158d00075f7ac6"
                2024-05-28 12:19:48.708 - info: zigbee.0 (20660) deregister device Ping for deactivated device "0x00158d0006ba677b"
                2024-05-28 12:19:48.708 - info: zigbee.0 (20660) deregister device Ping for deactivated device "0x0c4314fffea066e0"
                2024-05-28 12:19:48.708 - info: zigbee.0 (20660) deregister device Ping for deactivated device "0x0c4314fffea066d2"
                2024-05-28 12:19:48.708 - info: zigbee.0 (20660) deregister device Ping for deactivated device "0x00158d0004452056"
                2024-05-28 12:19:48.708 - info: zigbee.0 (20660) deregister device Ping for deactivated device "0x00158d00075f861e"
                2024-05-28 12:19:48.709 - info: zigbee.0 (20660) deregister device Ping for deactivated device "0x50325ffffe29c8ca"
                2024-05-28 12:19:48.710 - info: zigbee.0 (20660) deregister device Ping for deactivated device "0x00158d00045cfa19"
                2024-05-28 12:19:48.712 - info: zigbee.0 (20660) Currently 59 devices are joined:
                2024-05-28 12:19:48.713 - info: zigbee.0 (20660) 0x00158d0005074e4e (addr 27528): RB 285 C - Innr E27 bulb RGBW (Router)
                2024-05-28 12:19:48.714 - info: zigbee.0 (20660) 0x00124b0024c18e48 (addr 18983): ZBMINI - SONOFF Zigbee two way smart switch (Router)
                2024-05-28 12:19:48.714 - info: zigbee.0 (20660) 0x00158d00075f7ac6 (addr 58538): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                2024-05-28 12:19:48.715 - info: zigbee.0 (20660) 0x00158d0006f6b4a7 (addr 31433): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                2024-05-28 12:19:48.718 - info: zigbee.0 (20660) 0x00158d0005080c62 (addr 21103): RB 285 C - Innr E27 bulb RGBW (Router)
                2024-05-28 12:19:48.719 - info: zigbee.0 (20660) 0x00158d0006c3cbb2 (addr 39324): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                2024-05-28 12:19:48.719 - info: zigbee.0 (20660) 0x00158d0006f86b58 (addr 24624): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                2024-05-28 12:19:48.719 - info: zigbee.0 (20660) 0x00158d0006f25bad (addr 30322): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                2024-05-28 12:19:48.720 - info: zigbee.0 (20660) 0x00158d000507dbd0 (addr 21791): RB 285 C - Innr E27 bulb RGBW (Router)
                2024-05-28 12:19:48.721 - info: zigbee.0 (20660) 0x00158d00020e79f5 (addr 21687): FL 140 C - Innr Color Flex LED strip 4m 1200lm (Router)
                2024-05-28 12:19:48.722 - info: zigbee.0 (20660) 0x00158d00075f59eb (addr 48604): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                2024-05-28 12:19:48.722 - info: zigbee.0 (20660) 0x00158d00075f862b (addr 8787): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                2024-05-28 12:19:48.723 - info: zigbee.0 (20660) 0x00158d0006ba677b (addr 21063): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                2024-05-28 12:19:48.724 - info: zigbee.0 (20660) 0x0c4314fffea066e0 (addr 57678): E1812 - IKEA TRADFRI shortcut button (EndDevice)
                2024-05-28 12:19:48.724 - info: zigbee.0 (20660) 0x0c4314fffea066d2 (addr 42548): E1812 - IKEA TRADFRI shortcut button (EndDevice)
                2024-05-28 12:19:48.724 - info: zigbee.0 (20660) 0x00158d0004452056 (addr 62106): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                2024-05-28 12:19:48.725 - info: zigbee.0 (20660) 0x84fd27fffed11f0e (addr 6420): E1757 - IKEA FYRTUR roller blind, block-out (EndDevice)
                2024-05-28 12:19:48.725 - info: zigbee.0 (20660) 0x048727fffe5c78bb (addr 49232): E2013 - IKEA PARASOLL door/window sensor (EndDevice)
                2024-05-28 12:19:48.726 - info: zigbee.0 (20660) 0x9c6937000070f61a (addr 1176): RS 227 T - Innr GU10 spot 420 lm, dimmable, white spectrum (Router)
                2024-05-28 12:19:48.727 - info: zigbee.0 (20660) 0x804b50fffec129ac (addr 62722): E1757 - IKEA FYRTUR roller blind, block-out (EndDevice)
                2024-05-28 12:19:48.728 - info: zigbee.0 (20660) 0x00158d00075f688a (addr 23071): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                2024-05-28 12:19:48.728 - info: zigbee.0 (20660) 0x00158d0002ff2453 (addr 24358): RB 285 C - Innr E27 bulb RGBW (Router)
                2024-05-28 12:19:48.729 - info: zigbee.0 (20660) 0x00158d00059ff643 (addr 44575): RB 285 C - Innr E27 bulb RGBW (Router)
                2024-05-28 12:19:48.730 - info: zigbee.0 (20660) 0x00158d0005a16c13 (addr 26127): RB 285 C - Innr E27 bulb RGBW (Router)
                2024-05-28 12:19:48.730 - info: zigbee.0 (20660) 0x00158d0004f969cb (addr 51841): RB 285 C - Innr E27 bulb RGBW (Router)
                2024-05-28 12:19:48.731 - info: zigbee.0 (20660) 0x00158d0005a06306 (addr 44834): RB 285 C - Innr E27 bulb RGBW (Router)
                2024-05-28 12:19:48.732 - info: zigbee.0 (20660) 0x00158d0004f86d01 (addr 37140): RB 285 C - Innr E27 bulb RGBW (Router)
                2024-05-28 12:19:48.732 - info: zigbee.0 (20660) 0x00158d00075f72dc (addr 27327): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                2024-05-28 12:19:48.732 - info: zigbee.0 (20660) 0x00158d00075f861e (addr 6553): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                2024-05-28 12:19:48.733 - info: zigbee.0 (20660) 0xcc86ecfffe543275 (addr 45105): E2007 - IKEA STARKVIND air purifier (Router)
                2024-05-28 12:19:48.733 - info: zigbee.0 (20660) 0x00158d0005a060b6 (addr 61927): RB 285 C - Innr E27 bulb RGBW (Router)
                2024-05-28 12:19:48.736 - info: zigbee.0 (20660) 0x00158d0005a06374 (addr 19078): RB 285 C - Innr E27 bulb RGBW (Router)
                2024-05-28 12:19:48.737 - info: zigbee.0 (20660) 0x00158d0002f5910a (addr 60854): RB 285 C - Innr E27 bulb RGBW (Router)
                2024-05-28 12:19:48.737 - info: zigbee.0 (20660) 0x847127fffe19f0a2 (addr 57366): SP 220 - Innr Smart plug (Router)
                2024-05-28 12:19:48.737 - info: zigbee.0 (20660) 0x540f57fffe1d0774 (addr 57469): ICPSHC24-30EU-IL-1/ICPSHC24-10EU-IL-2 - IKEA TRADFRI LED driver, 30 w (Router)
                2024-05-28 12:19:48.738 - info: zigbee.0 (20660) 0x00124b0024c0f51a (addr 30003): ZBMINI - SONOFF Zigbee two way smart switch (Router)
                2024-05-28 12:19:48.738 - info: zigbee.0 (20660) 0x00158d0005a16be7 (addr 22617): RB 285 C - Innr E27 bulb RGBW (Router)
                2024-05-28 12:19:48.739 - info: zigbee.0 (20660) 0x00158d00059ff751 (addr 45839): RB 285 C - Innr E27 bulb RGBW (Router)
                2024-05-28 12:19:48.739 - info: zigbee.0 (20660) 0x00158d00059ff725 (addr 21169): RB 285 C - Innr E27 bulb RGBW (Router)
                2024-05-28 12:19:48.740 - info: zigbee.0 (20660) 0x00158d0006c41a66 (addr 38274): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                2024-05-28 12:19:48.740 - info: zigbee.0 (20660) 0x00158d000423b454 (addr 20655): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                2024-05-28 12:19:48.740 - info: zigbee.0 (20660) 0x00158d00047b3204 (addr 49889): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
                2024-05-28 12:19:48.741 - info: zigbee.0 (20660) 0x00158d00045c5030 (addr 41411): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
                2024-05-28 12:19:48.741 - info: zigbee.0 (20660) 0x00158d0005072e13 (addr 11768): RB 285 C - Innr E27 bulb RGBW (Router)
                2024-05-28 12:19:48.742 - info: zigbee.0 (20660) 0x50325ffffe29c8ca (addr 31158): E2007 - IKEA STARKVIND air purifier (Router)
                2024-05-28 12:19:48.742 - info: zigbee.0 (20660) 0x00158d000449a2f1 (addr 5018): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                2024-05-28 12:19:48.742 - info: zigbee.0 (20660) 0x847127fffe8cd4eb (addr 6215): SP 220 - Innr Smart plug (Router)
                2024-05-28 12:19:48.743 - info: zigbee.0 (20660) 0x00158d0004889d9c (addr 15156): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
                2024-05-28 12:19:48.743 - info: zigbee.0 (20660) 0x00158d00045cfa19 (addr 30315): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
                2024-05-28 12:19:48.743 - info: zigbee.0 (20660) 0xc498860000006cb1 (addr 65500): RS 227 T - Innr GU10 spot 420 lm, dimmable, white spectrum (Router)
                2024-05-28 12:19:48.744 - info: zigbee.0 (20660) 0xc498860000075005 (addr 16107): RS 227 T - Innr GU10 spot 420 lm, dimmable, white spectrum (Router)
                2024-05-28 12:19:48.744 - info: zigbee.0 (20660) 0x8c6fb9fffe642632 (addr 1836): E2201 - IKEA RODRET wireless dimmer/power switch (EndDevice)
                2024-05-28 12:19:48.745 - info: zigbee.0 (20660) 0x9c6937000070fad1 (addr 20041): RS 227 T - Innr GU10 spot 420 lm, dimmable, white spectrum (Router)
                2024-05-28 12:19:48.745 - info: zigbee.0 (20660) 0x60b647fffea44aa0 (addr 58546): E2001/E2002 - IKEA STYRBAR remote control (EndDevice)
                2024-05-28 12:19:48.745 - info: zigbee.0 (20660) 0x000d6f0014629597 (addr 63727): AC0251100NJ/AC0251600NJ/AC0251700NJ - OSRAM Smart+ switch mini (EndDevice)
                2024-05-28 12:19:48.746 - info: zigbee.0 (20660) 0x881a14fffef07a8c (addr 48839): E2134 - IKEA VALLHORN wireless motion sensor (EndDevice)
                2024-05-28 12:19:48.746 - info: zigbee.0 (20660) 0x8c6fb9fffe1d2912 (addr 10704): E2201 - IKEA RODRET wireless dimmer/power switch (EndDevice)
                2024-05-28 12:19:48.747 - info: zigbee.0 (20660) 0x8c6fb9fffe1d2743 (addr 17185): E2201 - IKEA RODRET wireless dimmer/power switch (EndDevice)
                2024-05-28 12:19:48.747 - info: zigbee.0 (20660) 0x8c6fb9fffe1d28dd (addr 7605): E2201 - IKEA RODRET wireless dimmer/power switch (EndDevice)
                2024-05-28 12:19:48.747 - info: zigbee.0 (20660) Zigbee started
                2024-05-28 12:19:48.929 - info: zigbee.0 (20660) deregister device Ping for deactivated device "0x00158d00075f7ac6"
                2024-05-28 12:19:48.930 - info: zigbee.0 (20660) deregister device Ping for deactivated device "0x00158d0006ba677b"
                2024-05-28 12:19:48.930 - info: zigbee.0 (20660) deregister device Ping for deactivated device "0x0c4314fffea066e0"
                2024-05-28 12:19:48.930 - info: zigbee.0 (20660) deregister device Ping for deactivated device "0x0c4314fffea066d2"
                2024-05-28 12:19:48.931 - info: zigbee.0 (20660) deregister device Ping for deactivated device "0x00158d0004452056"
                2024-05-28 12:19:48.932 - info: zigbee.0 (20660) deregister device Ping for deactivated device "0x00158d00075f861e"
                2024-05-28 12:19:48.933 - info: zigbee.0 (20660) deregister device Ping for deactivated device "0x50325ffffe29c8ca"
                2024-05-28 12:19:48.933 - info: zigbee.0 (20660) deregister device Ping for deactivated device "0x00158d00045cfa19"
                2024-05-28 12:19:48.943 - info: zigbee.0 (20660) Currently 59 devices are joined:
                2024-05-28 12:19:48.944 - info: zigbee.0 (20660) 0x00158d0005074e4e (addr 27528): RB 285 C - Innr E27 bulb RGBW (Router)
                2024-05-28 12:19:48.945 - info: zigbee.0 (20660) 0x00124b0024c18e48 (addr 18983): ZBMINI - SONOFF Zigbee two way smart switch (Router)
                2024-05-28 12:19:48.946 - info: zigbee.0 (20660) 0x00158d00075f7ac6 (addr 58538): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                2024-05-28 12:19:48.947 - info: zigbee.0 (20660) 0x00158d0006f6b4a7 (addr 31433): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                2024-05-28 12:19:48.948 - info: zigbee.0 (20660) 0x00158d0005080c62 (addr 21103): RB 285 C - Innr E27 bulb RGBW (Router)
                2024-05-28 12:19:48.949 - info: zigbee.0 (20660) 0x00158d0006c3cbb2 (addr 39324): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                2024-05-28 12:19:48.950 - info: zigbee.0 (20660) 0x00158d0006f86b58 (addr 24624): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                2024-05-28 12:19:48.951 - info: zigbee.0 (20660) 0x00158d0006f25bad (addr 30322): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                2024-05-28 12:19:48.953 - info: zigbee.0 (20660) 0x00158d000507dbd0 (addr 21791): RB 285 C - Innr E27 bulb RGBW (Router)
                2024-05-28 12:19:48.954 - info: zigbee.0 (20660) 0x00158d00020e79f5 (addr 21687): FL 140 C - Innr Color Flex LED strip 4m 1200lm (Router)
                2024-05-28 12:19:48.956 - info: zigbee.0 (20660) 0x00158d00075f59eb (addr 48604): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                2024-05-28 12:19:48.957 - info: zigbee.0 (20660) 0x00158d00075f862b (addr 8787): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                2024-05-28 12:19:48.958 - info: zigbee.0 (20660) 0x00158d0006ba677b (addr 21063): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                2024-05-28 12:19:48.959 - info: zigbee.0 (20660) 0x0c4314fffea066e0 (addr 57678): E1812 - IKEA TRADFRI shortcut button (EndDevice)
                2024-05-28 12:19:48.960 - info: zigbee.0 (20660) 0x0c4314fffea066d2 (addr 42548): E1812 - IKEA TRADFRI shortcut button (EndDevice)
                2024-05-28 12:19:48.961 - info: zigbee.0 (20660) 0x00158d0004452056 (addr 62106): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                2024-05-28 12:19:48.962 - info: zigbee.0 (20660) 0x84fd27fffed11f0e (addr 6420): E1757 - IKEA FYRTUR roller blind, block-out (EndDevice)
                2024-05-28 12:19:48.963 - info: zigbee.0 (20660) 0x048727fffe5c78bb (addr 49232): E2013 - IKEA PARASOLL door/window sensor (EndDevice)
                2024-05-28 12:19:48.964 - info: zigbee.0 (20660) 0x9c6937000070f61a (addr 1176): RS 227 T - Innr GU10 spot 420 lm, dimmable, white spectrum (Router)
                2024-05-28 12:19:48.965 - info: zigbee.0 (20660) 0x804b50fffec129ac (addr 62722): E1757 - IKEA FYRTUR roller blind, block-out (EndDevice)
                2024-05-28 12:19:48.972 - info: zigbee.0 (20660) 0x00158d00075f688a (addr 23071): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                2024-05-28 12:19:48.973 - info: zigbee.0 (20660) 0x00158d0002ff2453 (addr 24358): RB 285 C - Innr E27 bulb RGBW (Router)
                2024-05-28 12:19:48.975 - info: zigbee.0 (20660) 0x00158d00059ff643 (addr 44575): RB 285 C - Innr E27 bulb RGBW (Router)
                2024-05-28 12:19:48.976 - info: zigbee.0 (20660) 0x00158d0005a16c13 (addr 26127): RB 285 C - Innr E27 bulb RGBW (Router)
                2024-05-28 12:19:48.978 - info: zigbee.0 (20660) 0x00158d0004f969cb (addr 51841): RB 285 C - Innr E27 bulb RGBW (Router)
                2024-05-28 12:19:48.979 - info: zigbee.0 (20660) 0x00158d0005a06306 (addr 44834): RB 285 C - Innr E27 bulb RGBW (Router)
                2024-05-28 12:19:48.980 - info: zigbee.0 (20660) 0x00158d0004f86d01 (addr 37140): RB 285 C - Innr E27 bulb RGBW (Router)
                2024-05-28 12:19:48.981 - info: zigbee.0 (20660) 0x00158d00075f72dc (addr 27327): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                2024-05-28 12:19:48.982 - info: zigbee.0 (20660) 0x00158d00075f861e (addr 6553): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                2024-05-28 12:19:48.983 - info: zigbee.0 (20660) 0xcc86ecfffe543275 (addr 45105): E2007 - IKEA STARKVIND air purifier (Router)
                2024-05-28 12:19:48.984 - info: zigbee.0 (20660) 0x00158d0005a060b6 (addr 61927): RB 285 C - Innr E27 bulb RGBW (Router)
                2024-05-28 12:19:48.986 - info: zigbee.0 (20660) 0x00158d0005a06374 (addr 19078): RB 285 C - Innr E27 bulb RGBW (Router)
                2024-05-28 12:19:48.987 - info: zigbee.0 (20660) 0x00158d0002f5910a (addr 60854): RB 285 C - Innr E27 bulb RGBW (Router)
                2024-05-28 12:19:48.987 - info: zigbee.0 (20660) 0x847127fffe19f0a2 (addr 57366): SP 220 - Innr Smart plug (Router)
                2024-05-28 12:19:48.988 - info: zigbee.0 (20660) 0x540f57fffe1d0774 (addr 57469): ICPSHC24-30EU-IL-1/ICPSHC24-10EU-IL-2 - IKEA TRADFRI LED driver, 30 w (Router)
                2024-05-28 12:19:48.989 - info: zigbee.0 (20660) 0x00124b0024c0f51a (addr 30003): ZBMINI - SONOFF Zigbee two way smart switch (Router)
                2024-05-28 12:19:48.990 - info: zigbee.0 (20660) 0x00158d0005a16be7 (addr 22617): RB 285 C - Innr E27 bulb RGBW (Router)
                2024-05-28 12:19:48.991 - info: zigbee.0 (20660) 0x00158d00059ff751 (addr 45839): RB 285 C - Innr E27 bulb RGBW (Router)
                2024-05-28 12:19:48.993 - info: zigbee.0 (20660) 0x00158d00059ff725 (addr 21169): RB 285 C - Innr E27 bulb RGBW (Router)
                2024-05-28 12:19:48.994 - info: zigbee.0 (20660) 0x00158d0006c41a66 (addr 38274): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                2024-05-28 12:19:48.994 - info: zigbee.0 (20660) 0x00158d000423b454 (addr 20655): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                2024-05-28 12:19:48.995 - info: zigbee.0 (20660) 0x00158d00047b3204 (addr 49889): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
                2024-05-28 12:19:48.996 - info: zigbee.0 (20660) 0x00158d00045c5030 (addr 41411): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
                2024-05-28 12:19:48.997 - info: zigbee.0 (20660) 0x00158d0005072e13 (addr 11768): RB 285 C - Innr E27 bulb RGBW (Router)
                2024-05-28 12:19:48.998 - info: zigbee.0 (20660) 0x50325ffffe29c8ca (addr 31158): E2007 - IKEA STARKVIND air purifier (Router)
                2024-05-28 12:19:48.999 - info: zigbee.0 (20660) 0x00158d000449a2f1 (addr 5018): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                2024-05-28 12:19:49.000 - info: zigbee.0 (20660) 0x847127fffe8cd4eb (addr 6215): SP 220 - Innr Smart plug (Router)
                2024-05-28 12:19:49.000 - info: zigbee.0 (20660) 0x00158d0004889d9c (addr 15156): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
                2024-05-28 12:19:49.001 - info: zigbee.0 (20660) 0x00158d00045cfa19 (addr 30315): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
                2024-05-28 12:19:49.002 - info: zigbee.0 (20660) 0xc498860000006cb1 (addr 65500): RS 227 T - Innr GU10 spot 420 lm, dimmable, white spectrum (Router)
                2024-05-28 12:19:49.003 - info: zigbee.0 (20660) 0xc498860000075005 (addr 16107): RS 227 T - Innr GU10 spot 420 lm, dimmable, white spectrum (Router)
                2024-05-28 12:19:49.004 - info: zigbee.0 (20660) 0x8c6fb9fffe642632 (addr 1836): E2201 - IKEA RODRET wireless dimmer/power switch (EndDevice)
                2024-05-28 12:19:49.006 - info: zigbee.0 (20660) 0x9c6937000070fad1 (addr 20041): RS 227 T - Innr GU10 spot 420 lm, dimmable, white spectrum (Router)
                2024-05-28 12:19:49.007 - info: zigbee.0 (20660) 0x60b647fffea44aa0 (addr 58546): E2001/E2002 - IKEA STYRBAR remote control (EndDevice)
                2024-05-28 12:19:49.008 - info: zigbee.0 (20660) 0x000d6f0014629597 (addr 63727): AC0251100NJ/AC0251600NJ/AC0251700NJ - OSRAM Smart+ switch mini (EndDevice)
                2024-05-28 12:19:49.009 - info: zigbee.0 (20660) 0x881a14fffef07a8c (addr 48839): E2134 - IKEA VALLHORN wireless motion sensor (EndDevice)
                2024-05-28 12:19:49.010 - info: zigbee.0 (20660) 0x8c6fb9fffe1d2912 (addr 10704): E2201 - IKEA RODRET wireless dimmer/power switch (EndDevice)
                2024-05-28 12:19:49.011 - info: zigbee.0 (20660) 0x8c6fb9fffe1d2743 (addr 17185): E2201 - IKEA RODRET wireless dimmer/power switch (EndDevice)
                2024-05-28 12:19:49.012 - info: zigbee.0 (20660) 0x8c6fb9fffe1d28dd (addr 7605): E2201 - IKEA RODRET wireless dimmer/power switch (EndDevice)
                2024-05-28 12:19:49.012 - info: zigbee.0 (20660) Zigbee started
                2024-05-28 12:19:49.240 - info: zigbee.0 (20660) deregister device Ping for deactivated device "0x00158d00075f7ac6"
                2024-05-28 12:19:49.241 - info: zigbee.0 (20660) deregister device Ping for deactivated device "0x00158d0006ba677b"
                2024-05-28 12:19:49.241 - info: zigbee.0 (20660) deregister device Ping for deactivated device "0x0c4314fffea066e0"
                2024-05-28 12:19:49.241 - info: zigbee.0 (20660) deregister device Ping for deactivated device "0x0c4314fffea066d2"
                2024-05-28 12:19:49.241 - info: zigbee.0 (20660) deregister device Ping for deactivated device "0x00158d0004452056"
                2024-05-28 12:19:49.242 - info: zigbee.0 (20660) deregister device Ping for deactivated device "0x00158d00075f861e"
                2024-05-28 12:19:49.243 - info: zigbee.0 (20660) deregister device Ping for deactivated device "0x50325ffffe29c8ca"
                2024-05-28 12:19:49.243 - info: zigbee.0 (20660) deregister device Ping for deactivated device "0x00158d00045cfa19"
                2024-05-28 12:19:49.278 - info: zigbee.0 (20660) deregister device Ping for deactivated device "0x00158d00075f7ac6"
                2024-05-28 12:19:49.279 - info: zigbee.0 (20660) deregister device Ping for deactivated device "0x00158d0006ba677b"
                2024-05-28 12:19:49.279 - info: zigbee.0 (20660) deregister device Ping for deactivated device "0x0c4314fffea066e0"
                2024-05-28 12:19:49.279 - info: zigbee.0 (20660) deregister device Ping for deactivated device "0x0c4314fffea066d2"
                2024-05-28 12:19:49.279 - info: zigbee.0 (20660) deregister device Ping for deactivated device "0x00158d0004452056"
                2024-05-28 12:19:49.280 - info: zigbee.0 (20660) deregister device Ping for deactivated device "0x00158d00075f861e"
                2024-05-28 12:19:49.281 - info: zigbee.0 (20660) deregister device Ping for deactivated device "0x50325ffffe29c8ca"
                2024-05-28 12:19:49.281 - info: zigbee.0 (20660) deregister device Ping for deactivated device "0x00158d00045cfa19"
                2024-05-28 12:20:03.150 - error: zigbee.0 (20660) Send command to 902 failed with no error code (AREQ - AF - dataConfirm after 3000ms)
                2024-05-28 12:20:09.423 - error: zigbee.0 (20660) Send command to 902 failed with no error code (SRSP - AF - dataRequestExt after 6000ms)
                2024-05-28 12:21:31.175 - warn: zigbee.0 (20660) DeviceAvailability:Failed to ping 0xcc86ecfffe543275 STARKVIND Air purifier
                2024-05-28 12:26:53.218 - warn: zigbee.0 (20660) DeviceAvailability:Stopping to ping 0xcc86ecfffe543275 STARKVIND Air purifier after 35 ping attempts
                2024-05-28 12:28:35.275 - warn: zigbee.0 (20660) DeviceAvailability:Stopping to ping 0x00158d000507dbd0 RB 285 C after 129 ping attempts
                2024-05-28 12:28:41.276 - warn: zigbee.0 (20660) DeviceAvailability:Stopping to ping 0x00158d00020e79f5 FL 140 C after 97 ping attempts
                2024-05-28 12:28:53.278 - warn: zigbee.0 (20660) DeviceAvailability:Stopping to ping 0x9c6937000070f61a RS 227 T after 33 ping attempts
                2024-05-28 12:28:59.279 - warn: zigbee.0 (20660) DeviceAvailability:Stopping to ping 0x00158d0002ff2453 RB 285 C after 97 ping attempts
                2024-05-28 12:29:05.280 - warn: zigbee.0 (20660) DeviceAvailability:Stopping to ping 0x00158d00059ff643 RB 285 C after 65 ping attempts
                2024-05-28 12:29:29.283 - warn: zigbee.0 (20660) DeviceAvailability:Stopping to ping 0x00158d0005a16c13 RB 285 C after 129 ping attempts
                2024-05-28 12:29:35.285 - warn: zigbee.0 (20660) DeviceAvailability:Stopping to ping 0x00158d0004f969cb RB 285 C after 193 ping attempts
                2024-05-28 12:29:41.287 - warn: zigbee.0 (20660) DeviceAvailability:Stopping to ping 0x00158d0005a06306 RB 285 C after 161 ping attempts
                2024-05-28 12:29:47.289 - warn: zigbee.0 (20660) DeviceAvailability:Stopping to ping 0x00158d0004f86d01 RB 285 C after 161 ping attempts
                2024-05-28 12:29:53.289 - warn: zigbee.0 (20660) DeviceAvailability:Stopping to ping 0x00158d0005a06374 RB 285 C after 97 ping attempts
                2024-05-28 12:30:05.293 - warn: zigbee.0 (20660) DeviceAvailability:Stopping to ping 0x00158d0005a060b6 RB 285 C after 97 ping attempts
                2024-05-28 12:30:17.295 - warn: zigbee.0 (20660) DeviceAvailability:Stopping to ping 0x00158d0002f5910a RB 285 C after 97 ping attempts
                2024-05-28 12:30:29.297 - warn: zigbee.0 (20660) DeviceAvailability:Stopping to ping 0x540f57fffe1d0774 TRADFRI Driver 30W after 33 ping attempts
                2024-05-28 12:30:35.298 - warn: zigbee.0 (20660) DeviceAvailability:Stopping to ping 0x00124b0024c0f51a 01MINIZB after 33 ping attempts
                2024-05-28 12:30:41.300 - warn: zigbee.0 (20660) DeviceAvailability:Stopping to ping 0x847127fffe8cd4eb SP 220 after 33 ping attempts
                2024-05-28 12:30:53.302 - warn: zigbee.0 (20660) DeviceAvailability:Stopping to ping 0x00158d00059ff751 RB 285 C after 129 ping attempts
                2024-05-28 12:30:59.302 - warn: zigbee.0 (20660) DeviceAvailability:Stopping to ping 0x00158d0005072e13 RB 285 C after 129 ping attempts
                2024-05-28 12:31:29.307 - warn: zigbee.0 (20660) DeviceAvailability:Stopping to ping 0xc498860000006cb1 RS 227 T after 33 ping attempts
                2024-05-28 12:31:41.309 - warn: zigbee.0 (20660) DeviceAvailability:Failed to ping 0xc498860000075005 RS 227 T
                2024-05-28 12:31:47.310 - warn: zigbee.0 (20660) DeviceAvailability:Failed to ping 0x9c6937000070fad1 RS 227 T
                2024-05-28 12:31:53.311 - warn: zigbee.0 (20660) DeviceAvailability:Stopping to ping 0x00158d0005074e4e RB 285 C after 97 ping attempts
                2024-05-28 12:31:59.312 - warn: zigbee.0 (20660) DeviceAvailability:Failed to ping 0x00124b0024c18e48 01MINIZB
                2024-05-28 12:32:05.314 - warn: zigbee.0 (20660) DeviceAvailability:Failed to ping 0x00158d0005080c62 RB 285 C
                2024-05-28 12:32:11.315 - warn: zigbee.0 (20660) DeviceAvailability:Stopping to ping 0x00158d000507dbd0 RB 285 C after 130 ping attempts
                2024-05-28 12:32:17.316 - warn: zigbee.0 (20660) DeviceAvailability:Stopping to ping 0x00158d00020e79f5 FL 140 C after 98 ping attempts
                2024-05-28 12:32:29.318 - warn: zigbee.0 (20660) DeviceAvailability:Stopping to ping 0x9c6937000070f61a RS 227 T after 34 ping attempts
                2024-05-28 12:32:35.319 - warn: zigbee.0 (20660) DeviceAvailability:Stopping to ping 0x00158d0002ff2453 RB 285 C after 98 ping attempts
                2024-05-28 12:32:41.320 - warn: zigbee.0 (20660) DeviceAvailability:Stopping to ping 0x00158d00059ff643 RB 285 C after 66 ping attempts
                2024-05-28 12:32:47.321 - warn: zigbee.0 (20660) DeviceAvailability:Stopping to ping 0x00158d0005a16c13 RB 285 C after 130 ping attempts
                2024-05-28 12:32:53.322 - warn: zigbee.0 (20660) DeviceAvailability:Stopping to ping 0x00158d0004f969cb RB 285 C after 194 ping attempts
                2024-05-28 12:32:59.323 - warn: zigbee.0 (20660) DeviceAvailability:Stopping to ping 0x00158d0005a06306 RB 285 C after 162 ping attempts
                2024-05-28 12:33:05.325 - warn: zigbee.0 (20660) DeviceAvailability:Stopping to ping 0x00158d0004f86d01 RB 285 C after 162 ping attempts
                2024-05-28 12:33:17.326 - warn: zigbee.0 (20660) DeviceAvailability:Stopping to ping 0x847127fffe19f0a2 SP 220 after 10 ping attempts
                2024-05-28 12:33:23.327 - warn: zigbee.0 (20660) DeviceAvailability:Stopping to ping 0x00158d0005a060b6 RB 285 C after 98 ping attempts
                2024-05-28 12:33:29.328 - warn: zigbee.0 (20660) DeviceAvailability:Stopping to ping 0x00158d0005a06374 RB 285 C after 98 ping attempts
                2024-05-28 12:33:35.329 - warn: zigbee.0 (20660) DeviceAvailability:Stopping to ping 0x00158d0002f5910a RB 285 C after 98 ping attempts
                2024-05-28 12:33:41.330 - warn: zigbee.0 (20660) DeviceAvailability:Stopping to ping 0x540f57fffe1d0774 TRADFRI Driver 30W after 34 ping attempts
                2024-05-28 12:33:47.331 - warn: zigbee.0 (20660) DeviceAvailability:Stopping to ping 0x00124b0024c0f51a 01MINIZB after 34 ping attempts
                2024-05-28 12:33:53.332 - warn: zigbee.0 (20660) DeviceAvailability:Stopping to ping 0x00158d00059ff751 RB 285 C after 130 ping attempts
                2024-05-28 12:33:59.333 - warn: zigbee.0 (20660) DeviceAvailability:Stopping to ping 0x00158d0005a16be7 RB 285 C after 129 ping attempts
                2024-05-28 12:34:05.334 - warn: zigbee.0 (20660) DeviceAvailability:Stopping to ping 0x00158d0005072e13 RB 285 C after 130 ping attempts
                2024-05-28 12:34:11.335 - warn: zigbee.0 (20660) DeviceAvailability:Stopping to ping 0x847127fffe8cd4eb SP 220 after 34 ping attempts
                2024-05-28 12:34:17.336 - warn: zigbee.0 (20660) DeviceAvailability:Stopping to ping 0xc498860000006cb1 RS 227 T after 34 ping attempts
                2024-05-28 12:34:41.339 - warn: zigbee.0 (20660) DeviceAvailability:Stopping to ping 0x00158d0005074e4e RB 285 C after 98 ping attempts
                2024-05-28 12:34:53.341 - warn: zigbee.0 (20660) DeviceAvailability:Stopping to ping 0x00158d000507dbd0 RB 285 C after 131 ping attempts
                2024-05-28 12:35:17.344 - warn: zigbee.0 (20660) DeviceAvailability:Stopping to ping 0x00158d00020e79f5 FL 140 C after 99 ping attempts
                2024-05-28 12:35:23.345 - warn: zigbee.0 (20660) DeviceAvailability:Stopping to ping 0x9c6937000070f61a RS 227 T after 35 ping attempts
                2024-05-28 12:35:47.349 - warn: zigbee.0 (20660) DeviceAvailability:Stopping to ping 0x00158d0002ff2453 RB 285 C after 99 ping attempts
                2024-05-28 12:35:53.350 - warn: zigbee.0 (20660) DeviceAvailability:Stopping to ping 0x00158d00059ff643 RB 285 C after 67 ping attempts
                2024-05-28 12:35:59.351 - warn: zigbee.0 (20660) DeviceAvailability:Stopping to ping 0x00158d0005a16c13 RB 285 C after 131 ping attempts
                2024-05-28 12:36:05.352 - warn: zigbee.0 (20660) DeviceAvailability:Stopping to ping 0x00158d0004f969cb RB 285 C after 195 ping attempts
                2024-05-28 12:36:11.353 - warn: zigbee.0 (20660) DeviceAvailability:Stopping to ping 0x00158d0005a06306 RB 285 C after 163 ping attempts
                2024-05-28 12:36:17.354 - warn: zigbee.0 (20660) DeviceAvailability:Stopping to ping 0x00158d0004f86d01 RB 285 C after 163 ping attempts
                2024-05-28 12:36:29.357 - warn: zigbee.0 (20660) DeviceAvailability:Stopping to ping 0x847127fffe19f0a2 SP 220 after 11 ping attempts
                2024-05-28 12:36:35.358 - warn: zigbee.0 (20660) DeviceAvailability:Stopping to ping 0x00158d0005a060b6 RB 285 C after 99 ping attempts
                2024-05-28 12:36:41.358 - warn: zigbee.0 (20660) DeviceAvailability:Stopping to ping 0x00158d0005a06374 RB 285 C after 99 ping attempts
                2024-05-28 12:36:47.360 - warn: zigbee.0 (20660) DeviceAvailability:Stopping to ping 0x00158d0002f5910a RB 285 C after 99 ping attempts
                2024-05-28 12:36:53.360 - warn: zigbee.0 (20660) DeviceAvailability:Stopping to ping 0x540f57fffe1d0774 TRADFRI Driver 30W after 35 ping attempts
                2024-05-28 12:36:59.362 - warn: zigbee.0 (20660) DeviceAvailability:Stopping to ping 0x00124b0024c0f51a 01MINIZB after 35 ping attempts
                2024-05-28 12:37:05.363 - warn: zigbee.0 (20660) DeviceAvailability:Stopping to ping 0x00158d00059ff751 RB 285 C after 131 ping attempts
                2024-05-28 12:37:11.371 - warn: zigbee.0 (20660) DeviceAvailability:Stopping to ping 0x00158d0005a16be7 RB 285 C after 130 ping attempts
                2024-05-28 12:37:17.371 - warn: zigbee.0 (20660) DeviceAvailability:Stopping to ping 0x00158d0005072e13 RB 285 C after 131 ping attempts
                2024-05-28 12:37:23.372 - warn: zigbee.0 (20660) DeviceAvailability:Stopping to ping 0x847127fffe8cd4eb SP 220 after 35 ping attempts
                2024-05-28 12:37:29.373 - warn: zigbee.0 (20660) DeviceAvailability:Stopping to ping 0xc498860000006cb1 RS 227 T after 35 ping attempts
                2024-05-28 12:37:47.377 - warn: zigbee.0 (20660) DeviceAvailability:Stopping to ping 0x00158d00059ff725 RB 285 C after 241 ping attempts
                2024-05-28 12:37:53.378 - warn: zigbee.0 (20660) DeviceAvailability:Stopping to ping 0x847127fffe19f0a2 SP 220 after 12 ping attempts
                2024-05-28 12:37:59.393 - warn: zigbee.0 (20660) unread brightness change for group members ["0x00158d0005a16be7","0x00158d00059ff751"]
                2024-05-28 12:38:17.380 - warn: zigbee.0 (20660) DeviceAvailability:Stopping to ping 0x847127fffe19f0a2 SP 220 after 13 ping attempts
                2024-05-28 12:38:23.382 - warn: zigbee.0 (20660) unread brightness change for group members ["0x00158d00059ff725","0x00158d0005a16be7","0x00158d00059ff751"]
                2024-05-28 12:38:35.384 - warn: zigbee.0 (20660) DeviceAvailability:Stopping to ping 0x00158d00059ff725 RB 285 C after 242 ping attempts
                2024-05-28 12:38:41.384 - warn: zigbee.0 (20660) unread brightness change for group members ["0x00158d00059ff725","0x00158d0005a16be7","0x00158d00059ff751"]
                2024-05-28 12:38:53.385 - warn: zigbee.0 (20660) DeviceAvailability:Stopping to ping 0x00158d00059ff725 RB 285 C after 243 ping attempts
                2024-05-28 12:38:59.386 - warn: zigbee.0 (20660) unread brightness change for group members ["0x00158d00059ff725","0x00158d0005a16be7","0x00158d00059ff751"]
                2024-05-28 12:39:05.387 - warn: zigbee.0 (20660) DeviceAvailability:Stopping to ping 0x00158d0005a16be7 RB 285 C after 131 ping attempts
                2024-05-28 12:39:11.386 - warn: zigbee.0 (20660) DeviceAvailability:Stopping to ping 0x00158d00059ff725 RB 285 C after 244 ping attempts
                2024-05-28 12:39:17.387 - warn: zigbee.0 (20660) unread brightness change for group members ["0x00158d00059ff725","0x00158d0005a16be7","0x00158d00059ff751"]
                2024-05-28 12:39:29.389 - warn: zigbee.0 (20660) unread brightness change for group members ["0x00158d00059ff725","0x00158d0005a16be7","0x00158d00059ff751"]
                2024-05-28 12:41:29.086 - error: zigbee.0 (20660) Adapter disconnected, stopping
                2024-05-28 12:41:29.097 - error: zigbee.0 (20660) Adapter disconnected, stopping
                2024-05-28 12:41:29.108 - error: zigbee.0 (20660) Adapter disconnected, stopping
                2024-05-28 12:41:29.110 - error: zigbee.0 (20660) Adapter disconnected, stopping
                2024-05-28 12:41:29.124 - error: zigbee.0 (20660) Adapter disconnected, stopping
                2024-05-28 12:41:29.138 - error: zigbee.0 (20660) Adapter disconnected, stopping
                2024-05-28 12:41:29.140 - error: zigbee.0 (20660) Adapter disconnected, stopping
                2024-05-28 12:41:29.146 - error: zigbee.0 (20660) Adapter disconnected, stopping
                2024-05-28 12:41:29.151 - error: zigbee.0 (20660) Adapter disconnected, stopping
                2024-05-28 12:41:29.153 - error: zigbee.0 (20660) Adapter disconnected, stopping
                2024-05-28 12:41:29.158 - error: zigbee.0 (20660) Adapter disconnected, stopping
                2024-05-28 12:41:29.160 - error: zigbee.0 (20660) Adapter disconnected, stopping
                2024-05-28 12:41:29.162 - error: zigbee.0 (20660) Adapter disconnected, stopping
                2024-05-28 12:41:29.166 - error: zigbee.0 (20660) Adapter disconnected, stopping
                2024-05-28 12:41:29.167 - error: zigbee.0 (20660) Adapter disconnected, stopping
                2024-05-28 12:41:29.175 - error: zigbee.0 (20660) Adapter disconnected, stopping
                2024-05-28 12:41:29.177 - error: zigbee.0 (20660) Adapter disconnected, stopping
                2024-05-28 12:41:29.179 - error: zigbee.0 (20660) Adapter disconnected, stopping
                2024-05-28 12:41:29.184 - error: zigbee.0 (20660) Adapter disconnected, stopping
                2024-05-28 12:41:29.186 - error: zigbee.0 (20660) Adapter disconnected, stopping
                2024-05-28 12:41:29.188 - error: zigbee.0 (20660) Adapter disconnected, stopping
                2024-05-28 12:41:29.189 - error: zigbee.0 (20660) Adapter disconnected, stopping
                2024-05-28 12:41:29.191 - error: zigbee.0 (20660) Adapter disconnected, stopping
                2024-05-28 12:41:29.203 - error: zigbee.0 (20660) Adapter disconnected, stopping
                2024-05-28 12:41:29.204 - error: zigbee.0 (20660) Adapter disconnected, stopping
                2024-05-28 12:41:29.206 - error: zigbee.0 (20660) Adapter disconnected, stopping
                2024-05-28 12:41:29.209 - error: zigbee.0 (20660) Adapter disconnected, stopping
                2024-05-28 12:41:29.211 - error: zigbee.0 (20660) Adapter disconnected, stopping
                2024-05-28 12:41:29.215 - error: zigbee.0 (20660) Adapter disconnected, stopping
                2024-05-28 12:41:29.217 - error: zigbee.0 (20660) Adapter disconnected, stopping
                2024-05-28 12:41:29.220 - error: zigbee.0 (20660) Adapter disconnected, stopping
                2024-05-28 12:41:29.221 - error: zigbee.0 (20660) Adapter disconnected, stopping
                2024-05-28 12:41:39.264 - info: zigbee.0 (20660) Try to reconnect.
                2024-05-28 12:41:39.306 - info: zigbee.0 (20660) Starting Zigbee npm ...
                2024-05-28 12:41:39.307 - info: zigbee.0 (20660) Try to reconnect.
                2024-05-28 12:41:39.307 - info: zigbee.0 (20660) Starting Zigbee npm ...
                2024-05-28 12:41:39.308 - info: zigbee.0 (20660) Try to reconnect.
                2024-05-28 12:41:39.308 - info: zigbee.0 (20660) Starting Zigbee npm ...
                2024-05-28 12:41:39.309 - info: zigbee.0 (20660) Try to reconnect.
                2024-05-28 12:41:39.309 - info: zigbee.0 (20660) Starting Zigbee npm ...
                2024-05-28 12:41:39.310 - info: zigbee.0 (20660) Starting Zigbee npm ...
                2024-05-28 12:41:39.310 - info: zigbee.0 (20660) Try to reconnect.
                2024-05-28 12:41:39.311 - info: zigbee.0 (20660) Starting Zigbee npm ...
                2024-05-28 12:41:39.311 - info: zigbee.0 (20660) Try to reconnect.
                2024-05-28 12:41:39.312 - info: zigbee.0 (20660) Try to reconnect.
                2024-05-28 12:41:39.312 - info: zigbee.0 (20660) Starting Zigbee npm ...
                2024-05-28 12:41:39.313 - info: zigbee.0 (20660) Starting Zigbee npm ...
                2024-05-28 12:41:39.313 - info: zigbee.0 (20660) Try to reconnect.
                2024-05-28 12:41:39.314 - info: zigbee.0 (20660) Starting Zigbee npm ...
                2024-05-28 12:41:39.315 - info: zigbee.0 (20660) Try to reconnect.
                2024-05-28 12:41:39.315 - info: zigbee.0 (20660) Starting Zigbee npm ...
                2024-05-28 12:41:39.316 - info: zigbee.0 (20660) Starting Zigbee npm ...
                2024-05-28 12:41:39.316 - info: zigbee.0 (20660) Try to reconnect.
                2024-05-28 12:41:39.317 - info: zigbee.0 (20660) Starting Zigbee npm ...
                2024-05-28 12:41:39.317 - info: zigbee.0 (20660) Try to reconnect.
                2024-05-28 12:41:39.318 - info: zigbee.0 (20660) Try to reconnect.
                2024-05-28 12:41:39.318 - info: zigbee.0 (20660) Starting Zigbee npm ...
                2024-05-28 12:41:39.320 - info: zigbee.0 (20660) Starting Zigbee npm ...
                2024-05-28 12:41:39.321 - info: zigbee.0 (20660) Try to reconnect.
                2024-05-28 12:41:39.321 - info: zigbee.0 (20660) Starting Zigbee npm ...
                2024-05-28 12:41:39.322 - info: zigbee.0 (20660) Starting Zigbee npm ...
                2024-05-28 12:41:39.322 - info: zigbee.0 (20660) Try to reconnect.
                2024-05-28 12:41:39.323 - info: zigbee.0 (20660) Try to reconnect.
                2024-05-28 12:41:39.323 - info: zigbee.0 (20660) Starting Zigbee npm ...
                2024-05-28 12:41:39.324 - info: zigbee.0 (20660) Starting Zigbee npm ...
                2024-05-28 12:41:39.324 - info: zigbee.0 (20660) Try to reconnect.
                2024-05-28 12:41:39.325 - info: zigbee.0 (20660) Starting Zigbee npm ...
                2024-05-28 12:41:39.325 - info: zigbee.0 (20660) Try to reconnect.
                2024-05-28 12:41:39.628 - info: zigbee.0 (20660) Installed Version: iobroker.zigbee@1.10.3
                2024-05-28 12:41:39.629 - info: zigbee.0 (20660) Installed Version: iobroker.zigbee@1.10.3
                2024-05-28 12:41:39.630 - info: zigbee.0 (20660) Installed Version: iobroker.zigbee@1.10.3
                2024-05-28 12:41:39.801 - info: zigbee.0 (20660) Installed Version: iobroker.zigbee@1.10.3
                2024-05-28 12:41:39.802 - info: zigbee.0 (20660) Installed Version: iobroker.zigbee@1.10.3
                2024-05-28 12:41:39.803 - info: zigbee.0 (20660) Installed Version: iobroker.zigbee@1.10.3
                2024-05-28 12:41:39.804 - info: zigbee.0 (20660) Installed Version: iobroker.zigbee@1.10.3
                2024-05-28 12:41:39.805 - info: zigbee.0 (20660) Installed Version: iobroker.zigbee@1.10.3
                2024-05-28 12:43:46.822 - error: zigbee.0 (20660) Starting zigbee-herdsman problem : "Error while opening socket"
                2024-05-28 12:43:46.822 - error: zigbee.0 (20660) Failed to start Zigbee
                2024-05-28 12:43:46.822 - error: zigbee.0 (20660) Error herdsman start
                2024-05-28 12:43:46.856 - error: zigbee.0 (20660) Starting zigbee-herdsman problem : "Error while opening socket"
                2024-05-28 12:43:46.857 - error: zigbee.0 (20660) Failed to start Zigbee
                2024-05-28 12:43:46.857 - error: zigbee.0 (20660) Error herdsman start
                2024-05-28 12:43:46.873 - error: zigbee.0 (20660) Starting zigbee-herdsman problem : "Error while opening socket"
                2024-05-28 12:43:46.873 - error: zigbee.0 (20660) Failed to start Zigbee
                2024-05-28 12:43:46.873 - error: zigbee.0 (20660) Error herdsman start
                2024-05-28 12:43:46.910 - error: zigbee.0 (20660) Starting zigbee-herdsman problem : "Error while opening socket"
                2024-05-28 12:43:46.913 - error: zigbee.0 (20660) Failed to start Zigbee
                2024-05-28 12:43:46.913 - error: zigbee.0 (20660) Error herdsman start
                2024-05-28 12:43:46.936 - error: zigbee.0 (20660) Starting zigbee-herdsman problem : "Error while opening socket"
                2024-05-28 12:43:46.936 - error: zigbee.0 (20660) Failed to start Zigbee
                2024-05-28 12:43:46.936 - error: zigbee.0 (20660) Error herdsman start
                2024-05-28 12:43:46.965 - error: zigbee.0 (20660) Starting zigbee-herdsman problem : "Error while opening socket"
                2024-05-28 12:43:46.965 - error: zigbee.0 (20660) Failed to start Zigbee
                2024-05-28 12:43:46.965 - error: zigbee.0 (20660) Error herdsman start
                2024-05-28 12:43:46.981 - error: zigbee.0 (20660) Starting zigbee-herdsman problem : "Error while opening socket"
                2024-05-28 12:43:46.982 - error: zigbee.0 (20660) Failed to start Zigbee
                2024-05-28 12:43:46.982 - error: zigbee.0 (20660) Error herdsman start
                2024-05-28 12:43:46.997 - error: zigbee.0 (20660) Starting zigbee-herdsman problem : "Error while opening socket"
                2024-05-28 12:43:46.997 - error: zigbee.0 (20660) Failed to start Zigbee
                2024-05-28 12:43:46.997 - error: zigbee.0 (20660) Error herdsman start
                2024-05-28 12:43:47.011 - error: zigbee.0 (20660) Starting zigbee-herdsman problem : "Error while opening socket"
                2024-05-28 12:43:47.011 - error: zigbee.0 (20660) Failed to start Zigbee
                2024-05-28 12:43:47.011 - error: zigbee.0 (20660) Error herdsman start
                2024-05-28 12:43:47.031 - error: zigbee.0 (20660) Starting zigbee-herdsman problem : "Error while opening socket"
                2024-05-28 12:43:47.031 - error: zigbee.0 (20660) Failed to start Zigbee
                2024-05-28 12:43:47.031 - error: zigbee.0 (20660) Error herdsman start
                2024-05-28 12:43:47.044 - error: zigbee.0 (20660) Starting zigbee-herdsman problem : "Error while opening socket"
                2024-05-28 12:43:47.045 - error: zigbee.0 (20660) Failed to start Zigbee
                2024-05-28 12:43:47.045 - error: zigbee.0 (20660) Error herdsman start
                2024-05-28 12:43:47.085 - error: zigbee.0 (20660) Starting zigbee-herdsman problem : "Error while opening socket"
                2024-05-28 12:43:47.085 - error: zigbee.0 (20660) Failed to start Zigbee
                2024-05-28 12:43:47.085 - error: zigbee.0 (20660) Error herdsman start
                2024-05-28 12:43:47.148 - error: zigbee.0 (20660) Starting zigbee-herdsman problem : "Error while opening socket"
                2024-05-28 12:43:47.149 - error: zigbee.0 (20660) Failed to start Zigbee
                2024-05-28 12:43:47.149 - error: zigbee.0 (20660) Error herdsman start
                2024-05-28 12:43:47.240 - error: zigbee.0 (20660) Starting zigbee-herdsman problem : "Error while opening socket"
                2024-05-28 12:43:47.240 - error: zigbee.0 (20660) Failed to start Zigbee
                2024-05-28 12:43:47.241 - error: zigbee.0 (20660) Error herdsman start
                2024-05-28 12:43:47.264 - error: zigbee.0 (20660) Starting zigbee-herdsman problem : "Error while opening socket"
                2024-05-28 12:43:47.265 - error: zigbee.0 (20660) Failed to start Zigbee
                2024-05-28 12:43:47.265 - error: zigbee.0 (20660) Error herdsman start
                2024-05-28 12:43:47.276 - error: zigbee.0 (20660) Starting zigbee-herdsman problem : "Error while opening socket"
                2024-05-28 12:43:47.276 - error: zigbee.0 (20660) Failed to start Zigbee
                2024-05-28 12:43:47.276 - error: zigbee.0 (20660) Error herdsman start
                2024-05-28 12:43:47.283 - error: zigbee.0 (20660) Starting zigbee-herdsman problem : "Error while opening socket"
                2024-05-28 12:43:47.283 - error: zigbee.0 (20660) Failed to start Zigbee
                2024-05-28 12:43:47.283 - error: zigbee.0 (20660) Error herdsman start
                2024-05-28 12:43:47.296 - error: zigbee.0 (20660) Starting zigbee-herdsman problem : "Error while opening socket"
                2024-05-28 12:43:47.296 - error: zigbee.0 (20660) Failed to start Zigbee
                2024-05-28 12:43:47.297 - error: zigbee.0 (20660) Error herdsman start
                2024-05-28 12:43:47.305 - error: zigbee.0 (20660) Starting zigbee-herdsman problem : "Error while opening socket"
                2024-05-28 12:43:47.306 - error: zigbee.0 (20660) Failed to start Zigbee
                2024-05-28 12:43:47.306 - error: zigbee.0 (20660) Error herdsman start
                2024-05-28 12:43:47.311 - error: zigbee.0 (20660) Starting zigbee-herdsman problem : "Error while opening socket"
                2024-05-28 12:43:47.311 - error: zigbee.0 (20660) Failed to start Zigbee
                2024-05-28 12:43:47.311 - error: zigbee.0 (20660) Error herdsman start
                2024-05-28 12:43:47.315 - error: zigbee.0 (20660) Starting zigbee-herdsman problem : "Error while opening socket"
                2024-05-28 12:43:47.316 - error: zigbee.0 (20660) Failed to start Zigbee
                2024-05-28 12:43:47.316 - error: zigbee.0 (20660) Error herdsman start
                2024-05-28 12:43:47.320 - error: zigbee.0 (20660) Starting zigbee-herdsman problem : "Error while opening socket"
                2024-05-28 12:43:47.321 - error: zigbee.0 (20660) Failed to start Zigbee
                2024-05-28 12:43:47.321 - error: zigbee.0 (20660) Error herdsman start
                2024-05-28 12:43:47.330 - error: zigbee.0 (20660) Starting zigbee-herdsman problem : "Error while opening socket"
                2024-05-28 12:43:47.330 - error: zigbee.0 (20660) Failed to start Zigbee
                2024-05-28 12:43:47.330 - error: zigbee.0 (20660) Error herdsman start
                2024-05-28 12:43:47.335 - error: zigbee.0 (20660) Starting zigbee-herdsman problem : "Error while opening socket"
                2024-05-28 12:43:47.335 - error: zigbee.0 (20660) Failed to start Zigbee
                2024-05-28 12:43:47.335 - error: zigbee.0 (20660) Error herdsman start
                2024-05-28 12:43:47.340 - error: zigbee.0 (20660) Starting zigbee-herdsman problem : "Error while opening socket"
                2024-05-28 12:43:47.340 - error: zigbee.0 (20660) Failed to start Zigbee
                2024-05-28 12:43:47.340 - error: zigbee.0 (20660) Error herdsman start
                2024-05-28 12:43:47.346 - error: zigbee.0 (20660) Starting zigbee-herdsman problem : "Error while opening socket"
                2024-05-28 12:43:47.346 - error: zigbee.0 (20660) Failed to start Zigbee
                2024-05-28 12:43:47.346 - error: zigbee.0 (20660) Error herdsman start
                2024-05-28 12:43:47.351 - error: zigbee.0 (20660) Starting zigbee-herdsman problem : "Error while opening socket"
                2024-05-28 12:43:47.351 - error: zigbee.0 (20660) Failed to start Zigbee
                2024-05-28 12:43:47.351 - error: zigbee.0 (20660) Error herdsman start
                2024-05-28 12:43:47.356 - error: zigbee.0 (20660) Starting zigbee-herdsman problem : "Error while opening socket"
                2024-05-28 12:43:47.357 - error: zigbee.0 (20660) Failed to start Zigbee
                2024-05-28 12:43:47.357 - error: zigbee.0 (20660) Error herdsman start
                2024-05-28 12:43:47.369 - error: zigbee.0 (20660) Starting zigbee-herdsman problem : "Error while opening socket"
                2024-05-28 12:43:47.370 - error: zigbee.0 (20660) Failed to start Zigbee
                2024-05-28 12:43:47.370 - error: zigbee.0 (20660) Error herdsman start
                2024-05-28 12:43:47.374 - error: zigbee.0 (20660) Starting zigbee-herdsman problem : "Error while opening socket"
                2024-05-28 12:43:47.374 - error: zigbee.0 (20660) Failed to start Zigbee
                2024-05-28 12:43:47.374 - error: zigbee.0 (20660) Error herdsman start
                2024-05-28 12:43:47.379 - error: zigbee.0 (20660) Starting zigbee-herdsman problem : "Error while opening socket"
                2024-05-28 12:43:47.379 - error: zigbee.0 (20660) Failed to start Zigbee
                2024-05-28 12:43:47.379 - error: zigbee.0 (20660) Error herdsman start
                2024-05-28 12:43:47.383 - error: zigbee.0 (20660) Starting zigbee-herdsman problem : "Error while opening socket"
                2024-05-28 12:43:47.383 - error: zigbee.0 (20660) Failed to start Zigbee
                2024-05-28 12:43:47.383 - error: zigbee.0 (20660) Error herdsman start
                2024-05-28 12:43:56.824 - info: zigbee.0 (20660) Try to reconnect.
                2024-05-28 12:43:56.825 - info: zigbee.0 (20660) Starting Zigbee npm ...
                2024-05-28 12:43:56.831 - info: zigbee.0 (20660) Installed Version: iobroker.zigbee@1.10.3
                2024-05-28 12:43:56.858 - info: zigbee.0 (20660) Try to reconnect.
                2024-05-28 12:43:56.858 - info: zigbee.0 (20660) Starting Zigbee npm ...
                2024-05-28 12:43:56.868 - info: zigbee.0 (20660) Installed Version: iobroker.zigbee@1.10.3
                2024-05-28 12:43:56.874 - info: zigbee.0 (20660) Try to reconnect.
                2024-05-28 12:43:56.875 - info: zigbee.0 (20660) Starting Zigbee npm ...
                2024-05-28 12:43:56.880 - info: zigbee.0 (20660) Installed Version: iobroker.zigbee@1.10.3
                2024-05-28 12:43:56.915 - info: zigbee.0 (20660) Try to reconnect.
                2024-05-28 12:43:56.916 - info: zigbee.0 (20660) Starting Zigbee npm ...
                2024-05-28 12:43:56.920 - info: zigbee.0 (20660) Installed Version: iobroker.zigbee@1.10.3
                2024-05-28 12:43:56.937 - info: zigbee.0 (20660) Try to reconnect.
                2024-05-28 12:43:56.938 - info: zigbee.0 (20660) Starting Zigbee npm ...
                2024-05-28 12:43:56.942 - info: zigbee.0 (20660) Installed Version: iobroker.zigbee@1.10.3
                2024-05-28 12:43:56.966 - info: zigbee.0 (20660) Try to reconnect.
                2024-05-28 12:43:56.966 - info: zigbee.0 (20660) Starting Zigbee npm ...
                2024-05-28 12:43:56.970 - info: zigbee.0 (20660) Installed Version: iobroker.zigbee@1.10.3
                2024-05-28 12:43:56.983 - info: zigbee.0 (20660) Try to reconnect.
                2024-05-28 12:43:56.983 - info: zigbee.0 (20660) Starting Zigbee npm ...
                2024-05-28 12:43:56.991 - info: zigbee.0 (20660) Installed Version: iobroker.zigbee@1.10.3
                2024-05-28 12:43:56.998 - info: zigbee.0 (20660) Try to reconnect.
                2024-05-28 12:43:56.999 - info: zigbee.0 (20660) Starting Zigbee npm ...
                2024-05-28 12:43:57.003 - info: zigbee.0 (20660) Installed Version: iobroker.zigbee@1.10.3
                2024-05-28 12:43:57.012 - info: zigbee.0 (20660) Try to reconnect.
                2024-05-28 12:43:57.012 - info: zigbee.0 (20660) Starting Zigbee npm ...
                2024-05-28 12:43:57.018 - info: zigbee.0 (20660) Installed Version: iobroker.zigbee@1.10.3
                2024-05-28 12:43:57.032 - info: zigbee.0 (20660) Try to reconnect.
                2024-05-28 12:43:57.032 - info: zigbee.0 (20660) Starting Zigbee npm ...
                2024-05-28 12:43:57.037 - info: zigbee.0 (20660) Installed Version: iobroker.zigbee@1.10.3
                2024-05-28 12:43:57.046 - info: zigbee.0 (20660) Try to reconnect.
                2024-05-28 12:43:57.047 - info: zigbee.0 (20660) Starting Zigbee npm ...
                2024-05-28 12:43:57.051 - info: zigbee.0 (20660) Installed Version: iobroker.zigbee@1.10.3
                2024-05-28 12:43:57.086 - info: zigbee.0 (20660) Try to reconnect.
                2024-05-28 12:43:57.086 - info: zigbee.0 (20660) Starting Zigbee npm ...
                2024-05-28 12:43:57.091 - info: zigbee.0 (20660) Installed Version: iobroker.zigbee@1.10.3
                2024-05-28 12:43:57.150 - info: zigbee.0 (20660) Try to reconnect.
                2024-05-28 12:43:57.150 - info: zigbee.0 (20660) Starting Zigbee npm ...
                2024-05-28 12:43:57.155 - info: zigbee.0 (20660) Installed Version: iobroker.zigbee@1.10.3
                2024-05-28 12:43:57.242 - info: zigbee.0 (20660) Try to reconnect.
                2024-05-28 12:43:57.242 - info: zigbee.0 (20660) Starting Zigbee npm ...
                2024-05-28 12:43:57.247 - info: zigbee.0 (20660) Installed Version: iobroker.zigbee@1.10.3
                2024-05-28 12:43:57.265 - info: zigbee.0 (20660) Try to reconnect.
                2024-05-28 12:43:57.265 - info: zigbee.0 (20660) Starting Zigbee npm ...
                2024-05-28 12:43:57.271 - info: zigbee.0 (20660) Installed Version: iobroker.zigbee@1.10.3
                2024-05-28 12:43:57.277 - info: zigbee.0 (20660) Try to reconnect.
                2024-05-28 12:43:57.278 - info: zigbee.0 (20660) Starting Zigbee npm ...
                2024-05-28 12:43:57.282 - info: zigbee.0 (20660) Installed Version: iobroker.zigbee@1.10.3
                2024-05-28 12:43:57.284 - info: zigbee.0 (20660) Try to reconnect.
                2024-05-28 12:43:57.284 - info: zigbee.0 (20660) Starting Zigbee npm ...
                2024-05-28 12:43:57.288 - info: zigbee.0 (20660) Installed Version: iobroker.zigbee@1.10.3
                2024-05-28 12:43:57.298 - info: zigbee.0 (20660) Try to reconnect.
                2024-05-28 12:43:57.299 - info: zigbee.0 (20660) Starting Zigbee npm ...
                2024-05-28 12:43:57.303 - info: zigbee.0 (20660) Installed Version: iobroker.zigbee@1.10.3
                2024-05-28 12:43:57.307 - info: zigbee.0 (20660) Try to reconnect.
                2024-05-28 12:43:57.307 - info: zigbee.0 (20660) Starting Zigbee npm ...
                2024-05-28 12:43:57.312 - info: zigbee.0 (20660) Try to reconnect.
                2024-05-28 12:43:57.312 - info: zigbee.0 (20660) Starting Zigbee npm ...
                2024-05-28 12:43:57.313 - info: zigbee.0 (20660) Installed Version: iobroker.zigbee@1.10.3
                2024-05-28 12:43:57.317 - info: zigbee.0 (20660) Try to reconnect.
                2024-05-28 12:43:57.317 - info: zigbee.0 (20660) Starting Zigbee npm ...
                2024-05-28 12:43:57.318 - info: zigbee.0 (20660) Installed Version: iobroker.zigbee@1.10.3
                2024-05-28 12:43:57.323 - info: zigbee.0 (20660) Try to reconnect.
                2024-05-28 12:43:57.323 - info: zigbee.0 (20660) Starting Zigbee npm ...
                2024-05-28 12:43:57.323 - info: zigbee.0 (20660) Installed Version: iobroker.zigbee@1.10.3
                2024-05-28 12:43:57.328 - info: zigbee.0 (20660) Installed Version: iobroker.zigbee@1.10.3
                2024-05-28 12:43:57.331 - info: zigbee.0 (20660) Try to reconnect.
                2024-05-28 12:43:57.332 - info: zigbee.0 (20660) Starting Zigbee npm ...
                2024-05-28 12:43:57.335 - info: zigbee.0 (20660) Try to reconnect.
                2024-05-28 12:43:57.336 - info: zigbee.0 (20660) Starting Zigbee npm ...
                2024-05-28 12:43:57.336 - info: zigbee.0 (20660) Installed Version: iobroker.zigbee@1.10.3
                2024-05-28 12:43:57.340 - info: zigbee.0 (20660) Installed Version: iobroker.zigbee@1.10.3
                2024-05-28 12:43:57.340 - info: zigbee.0 (20660) Try to reconnect.
                2024-05-28 12:43:57.341 - info: zigbee.0 (20660) Starting Zigbee npm ...
                2024-05-28 12:43:57.345 - info: zigbee.0 (20660) Installed Version: iobroker.zigbee@1.10.3
                2024-05-28 12:43:57.347 - info: zigbee.0 (20660) Try to reconnect.
                2024-05-28 12:43:57.348 - info: zigbee.0 (20660) Starting Zigbee npm ...
                2024-05-28 12:43:57.352 - info: zigbee.0 (20660) Try to reconnect.
                2024-05-28 12:43:57.352 - info: zigbee.0 (20660) Starting Zigbee npm ...
                2024-05-28 12:43:57.353 - info: zigbee.0 (20660) Installed Version: iobroker.zigbee@1.10.3
                2024-05-28 12:43:57.357 - info: zigbee.0 (20660) Installed Version: iobroker.zigbee@1.10.3
                2024-05-28 12:43:57.366 - info: zigbee.0 (20660) Try to reconnect.
                2024-05-28 12:43:57.366 - info: zigbee.0 (20660) Starting Zigbee npm ...
                2024-05-28 12:43:57.371 - info: zigbee.0 (20660) Try to reconnect.
                2024-05-28 12:43:57.371 - info: zigbee.0 (20660) Starting Zigbee npm ...
                2024-05-28 12:43:57.371 - info: zigbee.0 (20660) Installed Version: iobroker.zigbee@1.10.3
                2024-05-28 12:43:57.376 - info: zigbee.0 (20660) Try to reconnect.
                2024-05-28 12:43:57.376 - info: zigbee.0 (20660) Starting Zigbee npm ...
                2024-05-28 12:43:57.376 - info: zigbee.0 (20660) Installed Version: iobroker.zigbee@1.10.3
                2024-05-28 12:43:57.380 - info: zigbee.0 (20660) Try to reconnect.
                2024-05-28 12:43:57.381 - info: zigbee.0 (20660) Starting Zigbee npm ...
                2024-05-28 12:43:57.381 - info: zigbee.0 (20660) Installed Version: iobroker.zigbee@1.10.3
                2024-05-28 12:43:57.385 - info: zigbee.0 (20660) Try to reconnect.
                2024-05-28 12:43:57.385 - info: zigbee.0 (20660) Starting Zigbee npm ...
                2024-05-28 12:43:57.385 - info: zigbee.0 (20660) Installed Version: iobroker.zigbee@1.10.3
                2024-05-28 12:43:57.390 - info: zigbee.0 (20660) Installed Version: iobroker.zigbee@1.10.3
                2024-05-28 12:46:04.145 - error: zigbee.0 (20660) Starting zigbee-herdsman problem : "Error while opening socket"
                2024-05-28 12:46:04.147 - error: zigbee.0 (20660) Failed to start Zigbee
                2024-05-28 12:46:04.147 - error: zigbee.0 (20660) Error herdsman start
                2024-05-28 12:46:04.201 - error: zigbee.0 (20660) Starting zigbee-herdsman problem : "Error while opening socket"
                2024-05-28 12:46:04.201 - error: zigbee.0 (20660) Failed to start Zigbee
                2024-05-28 12:46:04.202 - error: zigbee.0 (20660) Error herdsman start
                2024-05-28 12:46:04.216 - error: zigbee.0 (20660) Starting zigbee-herdsman problem : "Error while opening socket"
                2024-05-28 12:46:04.217 - error: zigbee.0 (20660) Failed to start Zigbee
                2024-05-28 12:46:04.217 - error: zigbee.0 (20660) Error herdsman start
                2024-05-28 12:46:04.256 - error: zigbee.0 (20660) Starting zigbee-herdsman problem : "Error while opening socket"
                2024-05-28 12:46:04.256 - error: zigbee.0 (20660) Failed to start Zigbee
                2024-05-28 12:46:04.257 - error: zigbee.0 (20660) Error herdsman start
                2024-05-28 12:46:04.274 - error: zigbee.0 (20660) Starting zigbee-herdsman problem : "Error while opening socket"
                  Dave83
                  #75
                  kann es sein, dass die Antenne sich einfach so mehrmals neu startet?
                  Weil im Router erscheint er, und wird dann wieder alls offline angezeigt. Er ist mit Kabel anegschlossen. Da, wieder nicht da. Da, wieder nicht. ....
                  Und auf die IP komm ich nicht drauf.
                  Das nervt sowas von. -.-
                  Das Ding steht da einfach und macht so viel ärger. Dabei hab ich etwas zuverlässiges gesucht und es ist noch unzuverlässiger als die Deconz Antenne. -.-
                  • D Dave83
                    Dave83
                    #76
                    Toll, jetzt geht sie gar nicht. Das ganze Haus ist offline. -.-
                      Dave83
                      #77
                      Meine Recherche hat ergeben, dass der Stick bei HomeAssistant sehr stabil funktioniert. Kann es sein, dass es an ioBroker liegt?
                      Ist das hier das gleiche? Verwenden die dort auch die gleiche Firmware?
                      • D Dave83
                        dimaiv
                        #78
                        @dave83
                        Der Stick funktioniert bei über 20.000 Installationen stabil, sowie ioBroker wie HA.
                        Was für Netzteil hast du dran?
                        ioBroker- NUC8i3 / Proxmox / VM
                        Node.js v22.21.0
                        NPM v10.9.4
                        JS controller 7.1.0
                        Admin 7.7.20
                        ZigBee Adapter 3.3.1alpha.0
                        Zigbee LAN Gateway CC2652P
                        Zigbee Firmware 20250321
                          BigChris
                          schrieb am zuletzt editiert von BigChris
                          #79
                          @dimaiv
                          Ich hatte wiederholt das Problem, dass das GW zwar im Netz war (Webinterface erreichbar) aber von iobroker nicht angesprochen werden konnte.
                          Ich habe dann ein Update versucht, was wohl schief gegangen ist. Das GW startet nicht, oder verbindet sich zumindest nicht mehr mit dem WLAN. Da der Stick nicht gefunden wurde, hatte ich auch die Instanz nicht gestoppt und wahrscheinlich hätte ich auch nicht auf Update ESP klicken sollen.
                          Was kann ich tun?
                            BigChris
                            #80
                            @dimaiv
                            Per LAN komme ich ran.
                            So sieht es gerade aus:
                            Irgendwie deutlich anders als ich es kenne.
                            Was nun?
                              Dave83
                              #81
                              Funktioniert diese Version besser?
                              https://github.com/fairecasoimeme/LiXee-ZiBridge
                              Wie wird das weiter gepflegt?
                              • BananaJoeB Offline
                                BananaJoeB Offline
                                BananaJoe
                                #82
                                Das ZigStar Projekt ist ja eingestellt worden, siehe: https://github.com/xyzroe/ZigStarGW-FW/releases
                                Man soll nahtlos auf https://xzg.xyzroe.cc/ migrieren können, was @BigChris wohl schon gemacht hat bzw. der hat den gleich mit der neuen Software bekommen.
                                Hat das schon einer von euch gemacht? Die aktuelle *.bin von denen einfach über das Webinterface flashen?
                                B D 2 Antworten Letzte Antwort
                                • BananaJoeB BananaJoe
                                  BigChris
                                  #83
                                  Ja, ich habe ein Update gemacht und es läuft danach auch einfach wieder.
                                  Wäre aber schon schön gewesen, wenn man das vorher erfahren hätte :)
                                    dimaiv
                                    #84
                                    @bananajoe
                                    Ich empfehle Umstieg auf XZG Firmware über den WEB Flasher machen.
                                    Hier : https://xzg.xyzroe.cc/install/
                                    Im Moment unbedingt die Version 20240914 nehmen !
                                    Node.js v22.21.0
                                    NPM v10.9.4
                                    JS controller 7.1.0
                                    Admin 7.7.20
                                    P 1 Antwort Letzte Antwort
                                    • D dimaiv
                                      @bananajoe
                                      peterfido
                                      #85
                                      @dimaiv lohnt sich ein Update von der 0.6.10?
                                      Peterfido
                                      • P peterfido
                                        dimaiv
                                        #86
                                        @peterfido
                                        Zigbeetechnisch wird nix geändert !
                                        Es sind ein paar optische Änderungen im Webinterface.
                                        20240914 (ESP Firmware) läuft sehr stabil.
                                        0.6.10 lief bei mir auch ohne Fehler.
                                        Node.js v22.21.0
                                        NPM v10.9.4
                                        JS controller 7.1.0
                                        Admin 7.7.20
                                        P Pedder007P 2 Antworten Letzte Antwort
                                        • D dimaiv
                                          @peterfido
                                          peterfido
                                          #87
                                          @dimaiv Danke, dann sehe ich da keinen Grund zum updaten. Das Teil läuft ja stabil durch und auf dem Webinterface bin ich so gut wie gar nicht.
                                          Peterfido
