  4. Node-Red
  5. Node-Red Filter
    6.4k
Node-Red Filter
58 Beiträge 2 Kommentatoren 6.8k Aufrufe 2 Beobachtet
  • mickymM mickym
    @ranzen sagte in Node-Red Filter:
    16.5
    16.5
    16.400000000000006
    -100
    15.299999999999997
    -100
    15.099999999999994
    15.400000000000006
    16.099999999999994
    16.799999999999997
    17.400000000000006
    18.299999999999997
    18.5
    Ist das ein Array aus Zahlen?
    Falls dem so ist - entweder mit einer Switch Nodes die unerwünschten Werte ausfiltern.
    Hier alles zusammen zum Import:
    [{"id":"3d235207a6ec473c","type":"debug","z":"289f539dcc33814e","name":"Array","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":770,"y":5600,"wires":[]},{"id":"da4a22c6c93ff7f8","type":"inject","z":"289f539dcc33814e","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":200,"y":5600,"wires":[["8210f8d23f2e3b99"]]},{"id":"8210f8d23f2e3b99","type":"template","z":"289f539dcc33814e","name":"","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"16.5\n16.5\n16.400000000000006\n-100\n15.299999999999997\n-100\n15.099999999999994\n15.400000000000006\n16.099999999999994\n16.799999999999997\n17.400000000000006\n18.299999999999997\n18.5","output":"str","x":360,"y":5600,"wires":[["3f43c3b365968227"]]},{"id":"3f43c3b365968227","type":"change","z":"289f539dcc33814e","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"$split(payload,\"\\n\").$number()","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":550,"y":5600,"wires":[["3d235207a6ec473c","e259d08c2c4841b7","bfe84a1beb7dcb3f"]]},{"id":"ad881d5147a9b75b","type":"switch","z":"289f539dcc33814e","name":"","property":"payload","propertyType":"msg","rules":[{"t":"gt","v":"0","vt":"num"}],"checkall":"true","repair":true,"outputs":1,"x":890,"y":5680,"wires":[["5d2cc22962edafe1"]]},{"id":"07c3ea21296c6061","type":"debug","z":"289f539dcc33814e","name":"gefiltertes Array","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1200,"y":5680,"wires":[]},{"id":"e259d08c2c4841b7","type":"split","z":"289f539dcc33814e","name":"","splt":"\\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"","x":750,"y":5680,"wires":[["ad881d5147a9b75b"]]},{"id":"5d2cc22962edafe1","type":"join","z":"289f539dcc33814e","name":"","mode":"auto","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":true,"timeout":"","count":"","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":1030,"y":5680,"wires":[["07c3ea21296c6061"]]},{"id":"bfe84a1beb7dcb3f","type":"change","z":"289f539dcc33814e","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"$filter(payload, function($v){$v > 0})\t","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":770,"y":5760,"wires":[["79cbf6a910fbec2f"]]},{"id":"79cbf6a910fbec2f","type":"debug","z":"289f539dcc33814e","name":"gefiltertes Array mit JSONATA","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1030,"y":5760,"wires":[]}]
    1. Mit switch Node die unerwünschten Werte aus dem Array filtern:
    2. oder mit JSONATA
    ranzen
    @mickym
    Danke für Deine Hilfe.
    Ich habe mein Node-RED Programmierung angepasst.
    Nach meiner Funktion, in der ich den Payload extrahiere, habe ich folgendes Ergebnis:
    msg.payload : array[1]
    array[1]
    0: object
    battery: 3.378
    resistance: 7.386
    sensorType: 1
    temperature: 20.5
    trigger: 0
    Von meinem Problem ist nur der temperature-Wert betroffen.
    Jetzt leite ich den Datenfluss weiter in Deine Kaskade (change, split, switch, join) und dann in die InfluxDB.
    Dann kommt folgender Fehler:
    msg : string[92]
    "Invalid JSONata expression: Argument 1 of function "split" does not match function signature"
    In die DB wird nicht geschrieben.
    VG Heiner
    • R ranzen
      @mickym
      array[1]
      0: object
      battery: 3.378
      resistance: 7.386
      sensorType: 1
      temperature: 20.5
      trigger: 0
      msg : string[92]
      VG Heiner
      mickymM Offline
      mickymM Offline
      mickym
      Also Du musst nur eine von beiden Methoden verwenden. Dann nimm halt nur die ChangeNode und filtere halt nach der Temperatur direkt deinem Output Deiner function Node..
      Also nur die change Node mit folgendem JSONATA:
      $filter(payload, function($v){$v.temperature > 0})
      R 1 Antwort Letzte Antwort
      • mickymM mickym
        ranzen
        @mickym said in Node-Red Filter:
        Da kommt dann die folgende Fehlermeldung:
        "Invalid JSONata expression: The expressions either side of operator ">" must evaluate to numeric or string values"
        • R ranzen
          mickymM Offline
          mickymM Offline
          mickym
          @ranzen Ich würde vorschlagen, Du kopierst das was Du filtern willst direkt aus dem Debug Fenster in CodeTags hier rein.
          Ich hab das nun zwar mühsam versucht, aber wenn man keine Daten hat, um das nachzustellen, dann kann man auch nicht helfen.
          Also schau mal ob Deine Debug Ausgabe so aussieht.
          Und dann kopiert man aus dem Debug-Fenster den Wert der payload in die Zwischenablage
          und stellt den hier in CodeTags ein:
          [{"battery":3.378,"resistance":7.386,"sensorType":1,"temperature":20.5,"trigger":0}]
          Dann muss ich keine Gänsefüsschen, Klammern etc selbst drum rum machen.
          So und wenn ich nun mit meiner Change Node teste dann werden die Objekte, die eine ungültige Temperatur haben - ausgefiltert - sprich die payload ist undefined (rot markiert). Kannst ggf noch eine Switch Node dahinter machen, um diese Nachrichten komplett zu filtern.
          Hier kannst ja selbst testen oder in die Inject NOde ein Objekt rein machen, was passt.
          [{"id":"e45337f4a3f55c96","type":"inject","z":"289f539dcc33814e","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"[{\"battery\":3.378,\"resistance\":7.386,\"sensorType\":1,\"temperature\":-100,\"trigger\":0}]","payloadType":"json","x":390,"y":6180,"wires":[["6ef399891f05414c","c6fa94570d7b3b5a"]]},{"id":"6ef399891f05414c","type":"debug","z":"289f539dcc33814e","name":"Input","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":550,"y":6120,"wires":[]},{"id":"c6fa94570d7b3b5a","type":"change","z":"289f539dcc33814e","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"$filter(payload, function($v){$v.temperature > 0})","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":590,"y":6180,"wires":[["ca0c74d4d7932b9f"]]},{"id":"ca0c74d4d7932b9f","type":"debug","z":"289f539dcc33814e","name":"gefiltert","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":780,"y":6180,"wires":[]}]
          • mickymM mickym
            mickymM Offline
            mickymM Offline
            mickym
            @mickym Und wenn Du nur den negativen Temperaturwert oder -100 herausfiltern willst, dann aktualisierst Du halt das Objekt.
            • mickymM mickym
              ranzen
              @mickym
              23.5.2024, 16:30:35node: 2da49fa7d532a2d4
              array[1]
              0: object
              battery: 3.389
              resistance: 17.991
              sensorType: 1
              temperature: 20.900000000000006
              trigger: 0
              Ja, so der Payload aus, den ich aus der Funktion Richtung DB schicke.
              Mein Code in der Funktion sieht so aus:
              var msg1 = {};
              msg1.payload = [
                      battery: msg.payload.uplink_message.decoded_payload["battery"],
                      resistance: msg.payload.uplink_message.decoded_payload["resistance"],
                      sensorType: msg.payload.uplink_message.decoded_payload["sensorType"],
                      temperature: msg.payload.uplink_message.decoded_payload["temperature"],
                      trigger: msg.payload.uplink_message.decoded_payload["trigger"]
              return (msg1);
              R mickymM 2 Antworten Letzte Antwort
              • R ranzen
                @mickym
                array[1]
                0: object
                battery: 3.389
                resistance: 17.991
                sensorType: 1
                trigger: 0
                var msg1 = {};
                msg1.payload = [
                return (msg1);
                ranzen
                Und in der DB sieht das dann so aus:
                time                           battery resistance sensorType temperature          trigger
                2024-04-08T15:59:41.629377294Z 3.398   1000       1          24.400000000000006   0
                2024-04-08T16:14:41.795550813Z 3.401   1000       1          24.400000000000006   0
                2024-04-08T16:29:41.794306826Z 3.398   1000       1          24.400000000000006   0
                2024-04-08T16:44:41.73256775Z  3.403   1000       1          24.5                 0
                2024-04-08T16:59:41.786260269Z 3.398   1000       1          24.400000000000006   0
                2024-04-08T17:14:41.783145044Z 3.401   1000       1          24.299999999999997   0
                2024-04-08T17:44:41.779760184Z 3.401   1000       1          24.200000000000003   0
                2024-04-08T17:59:41.612032196Z 3.401   1000       1          24.099999999999994   0
                2024-04-08T18:14:41.774595375Z 3.401   1000       1          24                   0
                2024-04-08T18:29:41.705639142Z 3.401   1000       1          23.900000000000006   0
                2024-04-08T18:44:41.768656569Z 3.398   1000       1          23.900000000000006   0
                2024-04-08T18:59:41.767234983Z 3.398   1000       1          23.900000000000006   0
                2024-04-08T19:14:41.772372995Z 3.401   1000       1          23.799999999999997   0
                2024-04-08T19:29:41.768979924Z 3.401   1000       1          23.799999999999997   0
                2024-04-08T19:44:41.605064779Z 3.398   1000       1          23.799999999999997   0
                2024-04-08T19:59:41.696679475Z 3.398   1000       1          23.799999999999997   0
                2024-04-08T20:14:41.776049783Z 3.398   1000       1          23.700000000000003   0
                2024-04-08T20:29:41.760546515Z 3.401   1000       1          23.599999999999994   0
                2024-04-08T20:44:41.758661338Z 3.398   1000       1          23.599999999999994   0
                • R ranzen
                  ranzen
                  Aber die Fehlermeldung kommt immer noch.
                  Im Change-Node steht als Regel:
                  Setze msg.payload
                  to the value
                  • R ranzen
                    @mickym
                    array[1]
                    0: object
                    battery: 3.389
                    resistance: 17.991
                    sensorType: 1
                    trigger: 0
                    var msg1 = {};
                    msg1.payload = [
                    return (msg1);
                    mickymM Offline
                    mickymM Offline
                    mickym
        23.5.2024, 16:30:35node: 2da49fa7d532a2d4        msg.payload : array[1]        array[1]        0: object        battery: 3.389        resistance: 17.991        sensorType: 1        temperature: 20.900000000000006        trigger: 0
                    Du hast schon wieder den Wert nicht über das Debug Fenster und der Schaltfläche Wert kopieren rauskopiert, sondern mit der MAUS - das ist Unsinn. Ich habe Dir doch unten einen Screenshot eingestellt, wie man die Werte sauber aus dem Debugfenster kopiert. So ist das unbrauchbar.
                    Aber OK - ich habs nochmal transformiert.
                    Das dann nächste ist, Du willst mir nicht sagen, dass Du wegen so einem Input Objekt eine function mit JS Code erstellst??
                    R 2 Antworten Letzte Antwort
                    • mickymM mickym
                      ranzen
                      @mickym
                      code_text
                      So sah mein Code aus.
                      • R ranzen
                        @mickym
                        code_text
                        ranzen
                        @ranzen
                        Ok, jetzt habe ich es kapiert. Debugfenster und dann Schaltfläche Wert.
                        • mickymM mickym
                          ranzen
                          Doch ;-)
                          So habe ich es mir in den letzten Jahren abgeguckt. Ich mache sehr wenig mit der Jvascipt-Programmierung. Sicherlich geht das eleganter.
                          • R ranzen
                            Doch ;-)
                            ranzen
                            schrieb am zuletzt editiert von ranzen
                            Wie geht es eleganter ?
                            Ich hole die Daten per MQTT (in diesem Fall mit MQTT in) von der Quelle ab.
                            Dann kommt schon die Funktion, in die ich die geholten Daten rein kippe. Und dann in die DB, wo sich Grafana dann bedient.
                            Das hat bis jetzt immer super funktioniert.
                            Wenn es eleganter geht. Nur zu, ich lerne gern dazu.
                            • mickymM Offline
                              mickymM Offline
                              mickym
                              Wenn also der Sinn Deiner function Node ist nur das ganze nach oben zu ziehen , da braucht man gar nichts programmieren. Dann nimmt man eine Change Node und VERÄNDERT die payload entsprechend.
                              Diese EINE Regel in der Change Node - macht das Gleiche wie dein Javascript Code. Also vielleicht solltest Du Dich mal mit Objekten beschäftigen. ;)
                              • mickymM mickym
                                ranzen
                                @mickym
                                ok, da werde ich mich bestimmt mit beschäftigen.
                                Aber die Fehlermeldung ist immer noch ;-) Im Moment wird die DB nicht bedient.
                                • mickymM Offline
                                  mickymM Offline
                                  mickym
                                  Ich bin ja auch noch nicht fertig
                                  So ich hab Dir nun 2 Möglichkeiten zum Filtern gemacht - da ich auch noch keine Antwort hatte, ob Du das ganze Objekt wegfiltern willst, wenn die Temperatur -100 ist oder nur die Objekteigenschaft Temperatur:
                                  Im ersten Fall kommt also gar nichts hinten raus, wenn in der temperature Eigenschaft -100 steht
                                  • mickymM mickym
                                    ranzen
                                    @mickym
                                    Ich möchte alles, was kommt, in die DB schreiben. Ausser: -100.
                                    • mickymM mickym
                                      ranzen
                                      @mickym
                                      Dieser Wert -100 zieht mir die schöne Visualisierung vom Grafana runter.
                                      • R ranzen
                                        @mickym
                                        mickymM Offline
                                        mickymM Offline
                                        mickym
                                        @mickym
                                        OK dann hätte ich mir das wahrscheinlich sparen können, dann willst Du also nur die temperature Eigenschaft wegfiltern.
                                        dann sollte also im Prinzip das langen:
                                        [{"id":"487d44863b93b5de","type":"change","z":"289f539dcc33814e","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.temperature = -100 ? payload~>|$|{},\"temperature\"|","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":570,"y":6440,"wires":[["7b3c154c0eb45240"]]}]
                                        Und zum Schluss mach ich Dir noch eine Version, in der Du Dir die ganze function Node sparen kannst.
                                        • mickymM mickym
                                          @mickym
                                          ranzen
                                          @mickym
                                          Im Copycode steht folgendes:
