  4. iobroker admin Zugriff nach Wiederherstellung nicht möglich
15 Beiträge 3 Kommentatoren 676 Aufrufe 2 Beobachtet
  • H humpl
    @thomas-braun hier die lange Fassung:
    Skript v.2024-04-21
    *** BASE SYSTEM ***
       Static hostname: iobroker
             Icon name: computer
      Operating System: Raspbian GNU/Linux 11 (bullseye)
                Kernel: Linux 5.15.76-v7l+
          Architecture: arm
    Model		: Raspberry Pi 4 Model B Rev 1.2
    Docker          : false
    Virtualization  : none
    Kernel          : armv7l
    Userland        : 32 bit
    Systemuptime and Load:
     13:35:32 up 10 min,  1 user,  load average: 1.37, 1.09, 0.74
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Tue 2024-05-21 13:35:32 CEST
               Universal time: Tue 2024-05-21 11:35:32 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    aschenm
    HOME=/home/aschenm
    GROUPS=aschenm adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    *** Display-Server-Setup ***
    Display-Server: false
    Desktop:
    Terminal: 	tty
    Boot Target: 	multi-user.target
    *** MEMORY ***
    Mem:            3.9G        1.6G        2.0G        1.0M        291M        2.6G
    Swap:            99M          0B         99M
    Total:          4.0G        1.6G        2.1G
    Active iob-Instances: 	37
             3888 M total memory
             1642 M used memory
              128 M active memory
             1689 M inactive memory
             1954 M free memory
               38 M buffer memory
              253 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    top - 13:35:32 up 10 min,  1 user,  load average: 1.37, 1.09, 0.74
    Tasks: 185 total,   2 running, 183 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  8.1 us,  5.4 sy,  0.0 ni, 86.5 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   3888.5 total,   1953.9 free,   1642.4 used,    292.1 buff/cache
    MiB Swap:    100.0 total,    100.0 free,      0.0 used.   2637.2 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    /dev/root      ext4       29G  3.9G   24G  14% /
    devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
    tmpfs          tmpfs     778M  1.1M  777M   1% /run
    /dev/mmcblk0p1 vfat      255M   52M  204M  21% /boot
    tmpfs          tmpfs     389M     0  389M   0% /run/user/1000
    [Tue May 21 13:24:39 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:FB:44:94 vc_mem.mem_base=0x3f000000 vc_mem.mem_size=0x3f600000  console=ttyS0,115200 console=tty1 root=PARTUUID=6a4743b9-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Tue May 21 13:24:40 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
    [Tue May 21 13:24:40 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Tue May 21 13:24:43 2024] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null). Quota mode: none.
    Show mounted filesystems:
    TARGET                       SOURCE         FSTYPE     OPTIONS
    /                            /dev/mmcblk0p2 ext4       rw,noatime
    |-/dev                       devtmpfs       devtmpfs   rw,relatime,size=1826028k,nr_inodes=84087,mode=755
    | |-/dev/shm                 tmpfs          tmpfs      rw,nosuid,nodev
    | |-/dev/pts                 devpts         devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
    | `-/dev/mqueue              mqueue         mqueue     rw,nosuid,nodev,noexec,relatime
    |-/proc                      proc           proc       rw,relatime
    | `-/proc/sys/fs/binfmt_misc systemd-1      autofs     rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
    |-/sys                       sysfs          sysfs      rw,nosuid,nodev,noexec,relatime
    | |-/sys/kernel/security     securityfs     securityfs rw,nosuid,nodev,noexec,relatime
    | |-/sys/fs/cgroup           cgroup2        cgroup2    rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
    | |-/sys/fs/pstore           pstore         pstore     rw,nosuid,nodev,noexec,relatime
    | |-/sys/fs/bpf              bpf            bpf        rw,nosuid,nodev,noexec,relatime,mode=700
    | |-/sys/kernel/debug        debugfs        debugfs    rw,nosuid,nodev,noexec,relatime
    | |-/sys/kernel/tracing      tracefs        tracefs    rw,nosuid,nodev,noexec,relatime
    | |-/sys/kernel/config       configfs       configfs   rw,nosuid,nodev,noexec,relatime
    | `-/sys/fs/fuse/connections fusectl        fusectl    rw,nosuid,nodev,noexec,relatime
    |-/run                       tmpfs          tmpfs      rw,nosuid,nodev,size=796360k,nr_inodes=819200,mode=755
    | |-/run/lock                tmpfs          tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k
    | |-/run/rpc_pipefs          sunrpc         rpc_pipefs rw,relatime
    | `-/run/user/1000           tmpfs          tmpfs      rw,nosuid,nodev,relatime,size=398176k,nr_inodes=99544,mode=700,uid=1000,gid=1000
    `-/boot                      /dev/mmcblk0p1 vfat       rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    475M	/var/
    211M	/var/log
    209M	/var/log/journal/c7926a6260574dac96912deb6bc692a0
    93M	/var/lib
    Archived and active journals take up 208.0M in the file system.
    /opt/iobroker/backups:
    53M	/opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    346M	/opt/iobroker/iobroker-data/
    292M	/opt/iobroker/iobroker-data/files
    78M	/opt/iobroker/iobroker-data/files/icons-open-icon-library-png
    48M	/opt/iobroker/iobroker-data/files/javascript.admin
    32M	/opt/iobroker/iobroker-data/files/javascript.admin/static
    19M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.904d455f.js.map
    16M	/opt/iobroker/iobroker-data/objects.jsonl
    12M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/790.1eb1f33b.chunk.js.map
    9.1M	/opt/iobroker/iobroker-data/files/echarts.admin/static/js/2.bbf74d5f.chunk.js.map
    8.9M	/opt/iobroker/iobroker-data/files/scenes.admin/static/js/2.7de3299d.chunk.js.map
    USB-Devices by-id:
    No Devices found 'by-id'
    *** NodeJS-Installation ***
    nodejs: 		N/A
    /usr/bin/node 		v16.18.1
    /usr/bin/npm 		8.19.2
    /usr/bin/npx 		8.19.2
    /usr/bin/corepack 	0.14.1
    *** nodejs is NOT correctly installed ***
    nodejs:
      Installed: 16.18.1-deb-1nodesource1
      Candidate: 16.20.2-deb-1nodesource1
      Version table:
         16.20.2-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
     *** 16.18.1-deb-1nodesource1 100
         12.22.12~dfsg-1~deb11u4 500
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller: 	4.0.24
    admin: 		6.3.2
    javascript: 	6.0.3
    nodejs modules from github: 	1
    +-- iobroker.doorbird@0.1.5 (git+ssh://git@github.com/BuZZy1337/ioBroker.doorbird.git#47440ddff9a9074ef1e0beb8ff7b7f2a6e368efb)
    Adapter State
      system.adapter.admin.0                  : admin                 : iobroker-pi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.admin.1                  : admin                 : iobroker-pi                              -  enabled, port: 8089, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : iobroker-pi                              -  enabled
    + system.adapter.backitup.0               : backitup              : iobroker-pi                              -  enabled
    + system.adapter.bring.0                  : bring                 : iobroker-pi                              -  enabled
    + system.adapter.bydhvs.0                 : bydhvs                : iobroker-pi                              -  enabled
    + system.adapter.cloud.0                  : cloud                 : iobroker-pi                              -  enabled
    + system.adapter.denon.0                  : denon                 : iobroker-pi                              -  enabled
    + system.adapter.discovery.0              : discovery             : iobroker-pi                              -  enabled
    + system.adapter.doorbird.0               : doorbird              : iobroker-pi                              -  enabled
    + system.adapter.echarts.0                : echarts               : iobroker-pi                              -  enabled
      system.adapter.flot.0                   : flot                  : iobroker-pi                              -  enabled
    + system.adapter.fullybrowser.0           : fullybrowser          : iobroker-pi                              -  enabled
    + system.adapter.history.0                : history               : iobroker-pi                              -  enabled
    + system.adapter.hmip.0                   : hmip                  : iobroker-pi                              -  enabled
      system.adapter.ical.0                   : ical                  : iobroker-pi                              -  enabled
      system.adapter.icons-material-png.0     : icons-material-png    : iobroker-pi                              -  enabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker-pi                              -  enabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker-pi                              -  enabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker-pi                              -  enabled
    + system.adapter.info.0                   : info                  : iobroker-pi                              -  enabled
    + system.adapter.iot.0                    : iot                   : iobroker-pi                              -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker-pi                              -  enabled
    + system.adapter.kecontact.0              : kecontact             : iobroker-pi                              -  enabled
    + system.adapter.knx.0                    : knx                   : iobroker-pi                              -  enabled, bind: 192.168.0.15
    + system.adapter.linux-control.0          : linux-control         : iobroker-pi                              -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : iobroker-pi                              -  enabled, port: 1883, bind: 192.168.0.15
    + system.adapter.niu.0                    : niu                   : iobroker-pi                              -  enabled
    + system.adapter.openknx.0                : openknx               : iobroker-pi                              -  enabled
    + system.adapter.ping.0                   : ping                  : iobroker-pi                              -  enabled
    + system.adapter.plenticore.0             : plenticore            : iobroker-pi                              -  enabled, port: 80
    + system.adapter.roomba.0                 : roomba                : iobroker-pi                              -  enabled
    + system.adapter.scenes.0                 : scenes                : iobroker-pi                              -  enabled
    + system.adapter.shelly.0                 : shelly                : iobroker-pi                              -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.solarlog.0               : solarlog              : iobroker-pi                              -  enabled, port: 80
    + system.adapter.sonoff.0                 : sonoff                : iobroker-pi                              -  enabled, port: 1884, bind: 192.168.0.15
    + system.adapter.squeezeboxrpc.0          : squeezeboxrpc         : iobroker-pi                              -  enabled, port: 9000
    + system.adapter.tr-064.0                 : tr-064                : iobroker-pi                              -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : iobroker-pi                              -  enabled
      system.adapter.vis-bars.0               : vis-bars              : iobroker-pi                              -  enabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker-pi                              -  enabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker-pi                              -  enabled
      system.adapter.vis-history.0            : vis-history           : iobroker-pi                              -  enabled
      system.adapter.vis-justgage.0           : vis-justgage          : iobroker-pi                              -  enabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker-pi                              -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker-pi                              -  enabled
      system.adapter.vis.0                    : vis                   : iobroker-pi                              -  enabled
    + system.adapter.volvo.0                  : volvo                 : iobroker-pi                              -  enabled
    + system.adapter.web.0                    : web                   : iobroker-pi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker-pi                              -  enabled
    + system.adapter.worx.0                   : worx                  : iobroker-pi                              -  enabled
    + system.adapter.yahka.0                  : yahka                 : iobroker-pi                              -  enabled
      system.adapter.zwave2.0                 : zwave2                : iobroker-slave                           -  enabled
    + instance is alive
    ioBroker-Repositories
    Stable (default): http://download.iobroker.net/sources-dist.json
    Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
    Installed ioBroker-Instances
    Adapter    "admin"        : 6.13.16  , installed 6.3.2  [Updatable]
    Adapter    "alexa2"       : 3.26.5   , installed 3.23.2 [Updatable]
    Adapter    "backitup"     : 2.11.0   , installed 2.5.12 [Updatable]
    Adapter    "bring"        : 1.8.4    , installed 1.8.1  [Updatable]
    Adapter    "bydhvs"       : 1.5.0    , installed 1.4.0  [Updatable]
    Adapter    "cloud"        : 5.0.1    , installed 4.3.0  [Updatable]
    Adapter    "denon"        : 1.15.5   , installed 1.13.4 [Updatable]
    Adapter    "discovery"    : 4.4.0    , installed 2.7.5  [Updatable]
    Adapter    "doorbird"     : 1.5.0    , installed 0.1.5  [Updatable]
    Adapter    "echarts"      : 1.7.2    , installed 1.0.12 [Updatable]
    Adapter    "flot"         : 1.12.0   , installed 1.10.7 [Updatable]
    Adapter    "fullybrowser" : 3.0.12   , installed 2.1.2  [Updatable]
    Adapter    "history"      : 3.0.1    , installed 2.2.4  [Updatable]
    Adapter    "hmip"         : 1.22.0   , installed 1.20.0 [Updatable]
    Adapter    "ical"         : 1.15.0   , installed 1.13.1 [Updatable]
    Adapter    "icons-mfd-svg": 1.2.0    , installed 1.1.0  [Updatable]
    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
    Adapter    "iot"          : 3.2.2    , installed 1.14.2 [Updatable]
    Adapter    "javascript"   : 7.8.0    , installed 6.0.3  [Updatable]
    Controller "js-controller": 5.0.19   , installed 4.0.24 [Updatable]
    Adapter    "kecontact"    : 2.1.1    , installed 1.5.2  [Updatable]
    Adapter    "knx"          : 2.0.26   , installed 2.0.13 [Updatable]
    Adapter    "linux-control": 1.1.5    , installed 1.1.3  [Updatable]
    Adapter    "mqtt"         : 5.2.0    , installed 4.0.7  [Updatable]
    Adapter    "niu"          : 0.0.3    , installed 0.0.3
    Adapter    "openknx"      : 0.9.0    , installed 0.2.5  [Updatable]
    Adapter    "ping"         : 1.6.2    , installed 1.5.0  [Updatable]
    Adapter    "plenticore"   : 2.2.0    , installed 2.2.0
    Adapter    "roomba"       : 1.3.0    , installed 1.1.4  [Updatable]
    Adapter    "shelly"       : 6.9.0    , installed 6.4.1  [Updatable]
    Adapter    "socketio"     : 6.7.0    , installed 4.2.0  [Updatable]
    Adapter    "solarlog"     : 2.2.8    , installed 2.2.2  [Updatable]
    Adapter    "sonoff"       : 3.0.3    , installed 2.5.1  [Updatable]
    Adapter    "squeezeboxrpc": 1.3.9    , installed 1.3.9
    Adapter    "tr-064"       : 4.3.0    , installed 4.2.15 [Updatable]
    Adapter    "trashschedule": 3.2.0    , installed 2.0.3  [Updatable]
    Adapter    "vis"          : 1.5.4    , installed 1.4.15 [Updatable]
    Adapter    "vis-canvas-gauges": 1.0.1, installed 0.1.5  [Updatable]
    Adapter    "vis-justgage" : 2.1.7    , installed 1.0.2  [Updatable]
    Adapter    "vis-material-advanced": 1.7.4, installed 1.7.2 [Updatable]
    Adapter    "volvo"        : 0.1.0    , installed 0.1.0
    Adapter    "web"          : 6.2.5    , installed 4.3.0  [Updatable]
    Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.2  [Updatable]
    Adapter    "worx"         : 2.3.4    , installed 2.1.3  [Updatable]
    Adapter    "ws"           : 2.6.1    , installed 1.3.0  [Updatable]
    Adapter    "yahka"        : 1.0.3    , installed 0.13.1 [Updatable]
    Objects and States
    Objects: 	7537
    States: 	6030
    Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:3 https://deb.nodesource.com/node_16.x bullseye InRelease
    Reading package lists...
    Pending Updates: 144
    iob diag has finished.
    Press any key for a summary
    @humpl
    Ich hätte die Gelegenheit ja genutzt hier auf ein aktuelles 64Bit-System zu gehen.
    Nodejs ist nicht richtig. Bring das auf die aktuelle Empfehlung nodejs@18:
    iob nodejs-update
    sudo reboot
    Dann die iobroker-Adapter inkl. js-controller auf Stand bringen.
    iob update
    iob upgrade all -y
    iob stop
    iob upgrade self
    iob start
    H 1 Antwort Letzte Antwort
      @humpl
      iob nodejs-update
      sudo reboot
      iob update
      iob upgrade all -y
      iob stop
      iob upgrade self
      iob start
      humpl
      @thomas-braun Dane dir, das mache ich als nächstes. Ich hatte auch schon den gedanken einen aktuellen Stand einzusetzen, hier Frage ich mich aber, ob mein altes Backup dann noch tut? Ich hatte nämlich das letzte iobroker Image schon verscuht, mein Backup eingespielt und ein ähnliches verhalten, keine Oberfläche erreichbar und ich kam per SSH Login auch nicht rein...
      Was wäre dein Tipp wie mit dem alten Backup umgehen?
      Vielen Dank schon mal!
      • H humpl
        @humpl sagte in iobroker admin Zugriff nach Wiederherstellung nicht möglich:
        Dann bring das Ding JETZT auf einen aktuellen Stand und zieh dann mit einem Backup davon um. (Kein IMAGE, sondern ein Backup via Backitup-Adapter).
          humpl
          schrieb am zuletzt editiert von humpl
          @thomas-braun So mit den Anweisungen habe ich ihn nun wieder zum laufen gebraucht. scheint aber immernoch nicht alles aktuell zu sein:
          sieht so aus wie wenn der JS-controller auch noch ein update bräuchte:
          hast du mir dafür ein Vorgehen? Oder einfach noch mal die Standard Anweisungen zum updaten durchgehen?
          Tausend Dank schon vorab, ich bin happy dass er überhaupt wieder lebt!!!
          • H humpl
            ja!
            Ja
            iob stop
            iob update
            iob upgrade self
            iob start
              ja!
              Ja
              iob stop
              iob update
              iob upgrade self
              iob start
              humpl
              jetzt siehts gut aus:
              Du meintest nun dennoch ein frisches System aufsetzen und das Backup vom BackitUp einspielen?
              • H humpl
                natürlich.
                Das Betriebssystem ist ja nicht angefasst worden.
                  natürlich.
                  humpl
                  @homoran Stimmt! Aber mit einem nun frischen Backup sollte sich das System dann auch gleich wiederherstellen lassen diesmal oder gibts noch bedenken?
                  • H humpl
                    ja
                    • H humpl
                      @humpl
                      Okay, Kiste sauber rebootet?
                      Dann sollte ein erneuter Lauf von
                      iob diag
                      auch nichts mehr zu bemäkeln haben.
