  5. Kann mit diesen Logs noch nix anfangen...
    6.6k
16 Beiträge 3 Kommentatoren 1.2k Aufrufe 3 Beobachtet
    docsnyder7
    javascript.0
    	2024-05-07 21:51:23.350	warn	at processImmediate (node:internal/timers:476:21)
    javascript.0
    	2024-05-07 21:51:23.350	warn	at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:381:37)
    javascript.0
    	2024-05-07 21:51:23.349	warn	at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11154:36)
    javascript.0
    	2024-05-07 21:51:23.349	warn	at Array.forEach (<anonymous>)
    javascript.0
    	2024-05-07 21:51:23.349	warn	at /opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11172:47
    javascript.0
    	2024-05-07 21:51:23.349	warn	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:641:29)
    javascript.0
    	2024-05-07 21:51:23.348	warn	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1269:38)
    javascript.0
    	2024-05-07 21:51:23.348	warn	at Object.<anonymous> (script.js.common.Hausstatus.Status_setzen_überwachen:40:14)
    javascript.0
    	2024-05-07 21:51:23.346	warn	getState "[object Object]" not found (3)
    javascript.0
    	2024-05-07 21:51:23.346	warn	at processImmediate (node:internal/timers:476:21)
    javascript.0
    	2024-05-07 21:51:23.345	warn	at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:381:37)
    javascript.0
    	2024-05-07 21:51:23.345	warn	at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11154:36)
    javascript.0
    	2024-05-07 21:51:23.345	warn	at Array.forEach (<anonymous>)
    javascript.0
    	2024-05-07 21:51:23.345	warn	at /opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11172:47
    javascript.0
    	2024-05-07 21:51:23.344	warn	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:641:29)
    javascript.0
    	2024-05-07 21:51:23.344	warn	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1269:38)
    javascript.0
    	2024-05-07 21:51:23.344	warn	at Object.<anonymous> (script.js.common.Hausstatus.Status_setzen_überwachen:33:7)
    iob fix hab ich schon durchlaufen lassen...
    die Meldung kommt von nachstehenden Blockly, mit welchem der Hausstatus gesetzt wird...
    die Meldungen im LOG sind mir erst jetzt aufgefallen... kann jemand dazu etwas sagen, worauf ich achten muss, um zu sehen, aus welcher Ecke des Blocklys hier Ärger kommt?
    • D docsnyder7
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      BananaJoeB Offline
      BananaJoeB Offline
      BananaJoe
      @docsnyder7 sagte in Kann mit diesen Logs noch nix anfangen...:
      Vermutlich geht das mit deiner Liste nicht?
      Und falls doch: Irgend ein objekt kann nicht abgefragt werden. Wenn du oben rechts auf die Ansicht mit dem Quellcode umschaltest wäre dann Zeile 40 die mit dem Problem
      • BananaJoeB BananaJoe
        docsnyder7
        @bananajoe
        ich hab grad herausgefunden, dass ich beim Öffnen der Fenster dies im LOg erhalte
        22:24:21.764	warn	javascript.0 (390534) at Object.<anonymous> (script.js.common.Hausstatus.Status_setzen_überwachen:33:7)
        22:24:21.770	warn	javascript.0 (390534) at Object.<anonymous> (script.js.common.Hausstatus.Status_setzen_überwachen:40:14)
        BananaJoeB CodierknechtC 2 Antworten Letzte Antwort
        • D docsnyder7
          @bananajoe
          BananaJoeB Offline
          BananaJoeB Offline
          BananaJoe
          @docsnyder7 und, was steht in den beiden Zeilen?
          • D docsnyder7
            @bananajoe
            CodierknechtC Offline
            Codierknecht
            @docsnyder7
            Dazu müsste man - wie @BananaJoe bereits erwähnt hat - den Quellcode sehen.
            Zeile 33 und 40 sind hier von Interesse.
            Aber mir fallen noch weitere Sachen auf:
            • Ein Zeitplan mit dem Wizard funktioniert nach meiner Erfahrung nicht immer so wie man es sich wünscht. Besser wäre CRON.
            • Scriptnamen sollten keine Umlaute enthalten.
            • Warum baust Du so umständlich eine Liste zusammen? Das geht über "Aufzählungen" wesentlich eleganter.
            HmIP|ZigBee|Tasmota|Unifi
            Zabbix Certified Specialist
            • CodierknechtC Codierknecht
              @docsnyder7
              docsnyder7
              @codierknecht
              Zeile 33
              if (getState(getObject('0_userdata.0.Hausstatus.Abwesend')).val == 1) {
              und
              zeile 40
              } else if (getState(getObject('0_userdata.0.Hausstatus.Schlafen')).val == 1) {
              Aufzählung statt Liste.. naja ich bin immernoch am lernen und tüfteln, bis dato funktionierte das Blockly... wenn Du nen Wink hast mit Aufzählung, dann gerne her damit
              • D docsnyder7
                @codierknecht
                Zeile 33
                und
                zeile 40
                Codierknecht
                @docsnyder7
                Sowas geht nicht
                Das sollte so aussehen
                Da wird eine Objekt-ID erwartet - kein komplettes Objekt!
                • BananaJoeB Offline
                  BananaJoeB Offline
                  BananaJoe
                  kannst auch einfach das Objekt als Pfad nehmen: 2846cf55-3866-4a1b-a87d-58987ee90af7-image.png
                  Dazu ein Textfeld hineinziehen - so mache ich das gerne, finde ich etwas lesbarer
                  • D docsnyder7
                    @codierknecht
                    Zeile 33
                    und
                    zeile 40
                    Codierknecht
                    D 2 Antworten Letzte Antwort
                      @docsnyder7
                      Sowas geht nicht
                      docsnyder7
                      @codierknecht
                      ich fass es nicht... das war der Fehler!?! Blöder Anfänger-Nicht-Hingeschaut-Fehler :man-facepalming:
                      @BananaJoe verstehe, würde hier auch die realtiv neuen grünen bausteine aus dem SYSTEM reiter funktionieren?
                      Mal wieder herzlichen Dank Euch beiden
                      @BananaJoe +
                      @Codierknecht
                        docsnyder7
                        @codierknecht Danke, dass guck ich mir an 😎
                        • D docsnyder7
                          @codierknecht
                          @BananaJoe +
                          @Codierknecht
                          BananaJoeB Offline
                          BananaJoeB Offline
                          BananaJoe
                          Ja. Aber dann hast du immer noch nicht den Pfad sondern nur den Namen, da würde ich jetzt keinen Vorteil sehen.
                            docsnyder7
                            @bananajoe
                            Ok…jetzt hab ich es verstanden 👍
                              docsnyder7
                              @codierknecht
                              kurze Frage dazu... anlegen von functions im Reiter Aufzählungen und dann ziehe ich nur die zb door DP oder open DP der Fenstersensoren in die passende function?
                              und dann den ID Selector functions=window zb? für die Liste der Sensoren?
                              • D docsnyder7
                                @codierknecht
                                Codierknecht
                                @docsnyder7
                                Genau so ;-)
                                  @docsnyder7
                                  Genau so ;-)
                                  docsnyder7
                                  @codierknecht
                                  Sänkju 😁
