  4. Influxdb restore geht nicht.
44 Beiträge 4 Kommentatoren 3.9k Aufrufe 2 Beobachtet
  • B Bill S. Preston
    @marc-berg
    Und wie bekomme ich die Version 1.8.10 installiert?
    Werde aus der Anleitung überhaupt nicht schlau.
    Sorry bin nicht so fit mit Linux .
    @bill-s-preston
    Repo angelegt?
    sudo apt update
    apt policy influx*
    sagt?
      @bill-s-preston
      Repo angelegt?
      sudo apt update
      apt policy influx*
      sagt?
      Bill S. Preston
      schrieb am zuletzt editiert von Bill S. Preston
      herke@raspberrypi:~ $ sudo apt update
      apt policy influx*
      Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
      Get:4 https://repos.influxdata.com/debian bookworm InRelease [12.9 kB]
      Hit:5 https://apt.grafana.com stable InRelease
      Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
      Get:7 https://packages.grafana.com/oss/deb stable InRelease [7,660 B]
      Hit:8 http://archive.raspberrypi.com/debian bookworm InRelease
      Err:4 https://repos.influxdata.com/debian bookworm InRelease
        The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
      Err:7 https://packages.grafana.com/oss/deb stable InRelease
        The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
      Reading package lists... Done
      W: GPG error: https://repos.influxdata.com/debian bookworm InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
      E: The repository 'https://repos.influxdata.com/debian bookworm InRelease' is not signed.
      N: Updating from such a repository can't be done securely, and is therefore disabled by default.
      N: See apt-secure(8) manpage for repository creation and user configuration details.
      W: GPG error: https://packages.grafana.com/oss/deb stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
      E: The repository 'https://packages.grafana.com/oss/deb stable InRelease' is not signed.
      N: Unable to locate package influxdata-archive_compat.key
      N: Unable to locate package influxdata-archive_compat.key.1
      N: Unable to locate package influxdata-archive_compat.key.2
      N: Unable to locate package influxdata-archive_compat.key.3
      herke@raspberrypi:~ $ apt policy influx*
      • B Bill S. Preston
        apt policy influx*
        @bill-s-preston
        Keine Ahnung was du da angestellt hast, aber das ist Kraut und Rüben...
        Für influxdb:
        rm influx*
        sudo rm /etc/apt/sources.list.d/influ*
        wget -q https://repos.influxdata.com/influxdata-archive_compat.key
        echo '393e8779c89ac8d958f81f942f9ad7fb82a25e133faddaf92e15b16e6ac9ce4c influxdata-archive_compat.key' | sha256sum -c && cat influxdata-archive_compat.key | gpg --dearmor | sudo tee /usr/share/keyrings/influxdata-archive_compat.gpg > /dev/null
        echo 'deb [signed-by=/usr/share/keyrings/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
        rm influxdata-archive_compat.key
        und grafana ist auch nicht korrekt. Versuch es so:
        sudo apt-get install -y apt-transport-https
        sudo apt-get install -y software-properties-common wget
        sudo wget -q -O /usr/share/keyrings/grafana.key https://apt.grafana.com/gpg.key
        echo "deb [signed-by=/usr/share/keyrings/grafana.key] https://apt.grafana.com stable main" | sudo tee /etc/apt/sources.list.d/grafana.list
        Dann nochmal
        sudo apt update
          @bill-s-preston
          Für influxdb:
          rm influx*
          Dann nochmal
          sudo apt update
          Bill S. Preston
          Super danke dir! Werde ich heute Abend versuchen. Ich hoffe es wird keine Nachtschicht wieder!
          Muss ich die alte grafana und influx Installation deinstallieren?
          Wenn ja, wie am besten?
          • B Bill S. Preston
            @bill-s-preston sagte in Influxdb restore geht nicht.:
            Nein. Du musst aber die Paket-Quellen senkrecht haben.
            • B Bill S. Preston
              Du musst lediglich die 10 Zeilen per copy&paste in dein Terminal kopieren. Ist eine Sache von 2 Sekunden...
                Bill S. Preston
                sudo apt update
                apt policy influx*
                sagt jetzt:
                apt policy influx*
                Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
                Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
                Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
                Get:5 https://packages.grafana.com/oss/deb stable InRelease [7,660 B]
                Hit:6 https://repos.influxdata.com/debian stable InRelease
                Hit:7 https://apt.grafana.com stable InRelease
                Hit:8 https://deb.nodesource.com/node_18.x nodistro InRelease
                Err:5 https://packages.grafana.com/oss/deb stable InRelease
                influxdb2-cli:
                  Installed: (none)
                  Candidate: 2.7.5-1
                  Version table:
                     2.7.5-1 500
                        500 https://repos.influxdata.com/debian stable/main arm64 Packages
                     2.7.3-1 500
                     2.7.1-2 500
                     2.6.1 500
                     2.6.0 500
                     2.5.0 500
                     2.4.0 500
                     2.3.0 500
                influxdb-client:
                  Installed: (none)
                  Candidate: 1.6.7~rc0-1+b13
                  Version table:
                     1.6.7~rc0-1+b13 500
                        500 http://deb.debian.org/debian bookworm/main arm64 Packages
                influxdb-dev:
                  Installed: (none)
                  Candidate: (none)
                  Version table:
                influxdb2-client:
                  Installed: (none)
                  Candidate: 2.7.1-1
                  Version table:
                     2.7.1-1 500
                influxdb:
                  Installed: 1.6.7~rc0-1+b13
                  Candidate: 1.8.10-1
                  Version table:
                     1.8.10-1 500
                 *** 1.6.7~rc0-1+b13 500
                influxctl:
                  Installed: (none)
                  Candidate: 2.8.0
                  Version table:
                     2.8.0 500
                     2.7.1 500
                     2.7.0 500
                     2.6.0 500
                     2.5.0 500
                     2.4.4 500
                     2.4.3 500
                     2.4.2 500
                     2.4.1 500
                     2.4.0 500
                     2.3.1 500
                     2.3.0 500
                     2.2.0 500
                     2.1.0 500
                     2.0.4 500
                     2.0.3 500
                     2.0.2 500
                     2.0.1 500
                     2.0.0 500
                influxdb2:
                  Installed: (none)
                  Candidate: 2.7.6-1
                  Version table:
                     2.7.6-1 500
                     2.7.5-1 500
                     2.7.4-1 500
                     2.7.3-1 500
                     2.7.1-1 500
                     2.7.0-1 500
                     2.6.1-1 500
                     2.6.0-1 500
                     2.5.1-1 500
                     2.4.0-1 500
                     2.3.0-1 500
                     2.2.0 500
                und...
                rm influx*
                herke@raspberrypi:~ $ rm influx*
                rm: cannot remove 'influx*': No such file or directory
                und
                sudo apt update
                sagt
                Hit:4 https://apt.grafana.com stable InRelease
                Hit:5 https://repos.influxdata.com/debian stable InRelease
                Get:6 https://packages.grafana.com/oss/deb stable InRelease [7,660 B]
                Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
                Err:6 https://packages.grafana.com/oss/deb stable InRelease
                • B Bill S. Preston
                  sudo apt update
                  apt policy influx*
                  sagt jetzt:
                  apt policy influx*
                  influxdb2-cli:
                    Installed: (none)
                    Candidate: 2.7.5-1
                    Version table:
                       2.7.5-1 500
                       2.7.3-1 500
                       2.7.1-2 500
                       2.6.1 500
                       2.6.0 500
                       2.5.0 500
                       2.4.0 500
                       2.3.0 500
                  influxdb-client:
                    Installed: (none)
                    Version table:
                       1.6.7~rc0-1+b13 500
                  influxdb-dev:
                    Installed: (none)
                    Candidate: (none)
                    Version table:
                  influxdb2-client:
                    Installed: (none)
                    Candidate: 2.7.1-1
                    Version table:
                       2.7.1-1 500
                  influxdb:
                    Candidate: 1.8.10-1
                    Version table:
                       1.8.10-1 500
                  influxctl:
                    Installed: (none)
                    Candidate: 2.8.0
                    Version table:
                       2.8.0 500
                       2.7.1 500
                       2.7.0 500
                       2.6.0 500
                       2.5.0 500
                       2.4.4 500
                       2.4.3 500
                       2.4.2 500
                       2.4.1 500
                       2.4.0 500
                       2.3.1 500
                       2.3.0 500
                       2.2.0 500
                       2.1.0 500
                       2.0.4 500
                       2.0.3 500
                       2.0.2 500
                       2.0.1 500
                       2.0.0 500
                  influxdb2:
                    Installed: (none)
                    Candidate: 2.7.6-1
                    Version table:
                       2.7.6-1 500
                       2.7.5-1 500
                       2.7.4-1 500
                       2.7.3-1 500
                       2.7.1-1 500
                       2.7.0-1 500
                       2.6.1-1 500
                       2.6.0-1 500
                       2.5.1-1 500
                       2.4.0-1 500
                       2.3.0-1 500
                       2.2.0 500
                  und...
                  rm influx*
                  und
                  sudo apt update
                  sagt
                  @bill-s-preston
                  Bei grafana hast du einen alten Eintrag irgendwo.
                  Such die Datei:
                  grep -Rnw /etc/apt/ -e packages.grafana
                  Dann dort die Zeile, die den Text packages.grafana.com enthält löschen.
                  Die Zeile mit apt.grafana.com ist die richtige und muss bleiben.
                    @bill-s-preston
                    Such die Datei:
                    Bill S. Preston
                    @thomas-braun said in Influxdb restore geht nicht.:
                    @bill-s-preston
                    Such die Datei:
                    herke@raspberrypi:~ $ grep -Rnw /etc/apt/ -e packages.grafana
                    /etc/apt/sources.list.d/archive_uri-https_packages_grafana_com_oss_deb-bookworm.
                    list:1:deb https://packages.grafana.com/oss/deb stable main
                    list:2:# deb-src https://packages.grafana.com/oss/deb stable main
                    ist nicht so richtig ersichtlich was ich löschen muss.
                    außerdem wie lösche ich die Zeilen. Hier wird es doch nur gelistet.
                    • B Bill S. Preston
                      @bill-s-preston
                      Such die Datei:
                      Lösch die komische Datei komplett. Wo haste die überhaupt her?
                      sudo rm /etc/apt/sources.list.d/archive_uri-https_packages_grafana_com_oss_deb-bookworm.list
                      sudo apt update
                      sudo apt full-upgrade
                        sudo apt update
                        Bill S. Preston
                        unter
                        wird nun nichts mehr angezeigt.
                        und
                        herke@raspberrypi:~ $ influxd
                         8888888           .d888 888                   8888888b.  888888b.
                           888            d88P"  888                   888  "Y88b 888  "88b
                           888            888    888                   888    888 888  .88P
                           888   88888b.  888888 888 888  888 888  888 888    888 8888888K.
                           888   888 "88b 888    888 888  888  Y8bd8P' 888    888 888  "Y88b
                           888   888  888 888    888 888  888   X88K   888    888 888    888
                           888   888  888 888    888 Y88b 888 .d8""8b. 888  .d88P 888   d88P
                         8888888 888  888 888    888  "Y88888 888  888 8888888P"  8888888P"
                        2024-05-04T18:09:02.252026Z     info    InfluxDB starting       {"log_id": "0oyCZoAl000", "versi        on": "1.8.10", "branch": "1.8", "commit": "688e697c51fd"}
                        2024-05-04T18:09:02.252066Z     info    Go runtime      {"log_id": "0oyCZoAl000", "version": "go        1.13.8", "maxprocs": 4}
                        run: open server: listen: listen tcp 127.0.0.1:8088: bind: address already in use
                        sieht nun auch gut aus oder?
                        • B Bill S. Preston
                          unter
                          und
                          Das ist richtig, die Datei hast du ja auch gelöscht.
                          Hast du jetzt grafana wie auch influxdb auf der Kiste?
                          sudo apt update
                          sudo apt install grafana influxdb
                            sudo apt update
                            Bill S. Preston
                            sudo apt update sudo apt install grafana influxdb
                            ja. komme nun in die shell...
                            Connected to http://localhost:8086 version 1.6.7~rc0
                            InfluxDB shell version: 1.8.10
                            Kann ich jetzt einfach via Backitup ein Restore drauf packen?
                            • B Bill S. Preston
                              Ja, sollte.
                              • B Bill S. Preston
                                unter
                                und
                                  Bill S. Preston
                                  8088 wird durch influx genutzt oder sehe ich das falsch?
                                  herke@raspberrypi:~ $ sudo netstat -tulpn | grep LISTEN
                                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      678/sshd: /usr/sbin
                                  tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      665/influxd
                                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      666/iobroker.js-con
                                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      666/iobroker.js-con
                                  tcp6       0      0 :::22                   :::*                    LISTEN      678/sshd: /usr/sbin
                                  tcp6       0      0 :::3000                 :::*                    LISTEN      751/grafana
                                  tcp6       0      0 :::8082                 :::*                    LISTEN      918/io.web.0
                                  tcp6       0      0 :::8081                 :::*                    LISTEN      3440/io.admin.0
                                  tcp6       0      0 :::8086                 :::*                    LISTEN      665/influxd
                                  • B Bill S. Preston
                                    anscheinend aber nicht nur.
                                    oder interpretiere ich die Meldung falsch?
                                    • B Bill S. Preston
                                      @bill-s-preston
                                      Reboote die Kiste mal sauber.
                                        @bill-s-preston
                                        Bill S. Preston
                                        Kann es sein, dass 8088 durch Influx für den Restore benutzt wird?
                                        So liest es sich jedenfalls auf der Influx Homepage
                                        InfluxDB ports
                                        8088
                                        The default port used by the RPC service for RPC calls made by the CLI for backup and restore operations (influxdb backup and influxd restore). Configure this port in the configuration file.
                                        Resources Backup and Restore
                                        Ich habe das Influx Restore jetzt nochmal wiederholt. Grafana zeigt noch immer Quatsch an.
                                        Auf dem alten System wird Grafana Version 6.6.1 benutzt
                                        auf dem Neuen Grafana v10.4.2
                                        Wie bekomme ich auf das neue System ebenfalls 6.6.1 ?
                                        Kann ich mit diesem Befehl von der Grafana Homepage einfach auf 6.6.1 downgraden?
                                        sudo apt-get install -y adduser libfontconfig1 musl
                                        wget https://dl.grafana.com/enterprise/release/grafana-enterprise_6.6.1_amd64.deb
                                        sudo dpkg -i grafana-enterprise_6.6.1_amd64.deb
                                        • B Bill S. Preston
                                          InfluxDB ports
                                          8088
                                          Mit deinem Paketmanager? Wie immer unter Linux/Debian. Man installiert i.d.R. nicht irgendwas von irgendwoher, wenn man das auch aus seinen Repos ziehen kann. Was meinst denn du, warum du die beiden Quellen gerade ziehen solltest?
                                          sudo apt install grafana=6.6.1
                                          Auch wenn ich vermute, das es nicht an der Version hängt, sondern an dem noch nicht richtig eingespielten Backup der Datenquelle.
