  3. Einsteigerfragen
  4. Installation
  5. [gelöst] Installation auf Raspi hängt bei Schritt 3/4
18 Beiträge 2 Kommentatoren 1.3k Aufrufe 2 Beobachtet
  • hruH hru
    wenn ich die Installation mit <Ctrl>+<C> abbreche kommen die folgenden Meldungen:
    npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
    npm ERR! command failed
    npm ERR! signal SIGINT
    npm ERR! command sh -c node iobroker.js setup first
    npm ERR! Cannot read system.config: null (OK when migrating or restoring)
    npm ERR! A complete log of this run can be found in: /home/hru/.npm/_logs/2024-04-18T19_55_35_258Z-debug-0.log
    Thomas BraunT Offline
    @hru
    Schau mal ob
    iob diag
    schon drauf ist. Oder danach:
    https://forum.iobroker.net/topic/59549/iob-diag-skript
    hruH 1 Antwort Letzte Antwort
      @hru
      Schau mal ob
      iob diag
      hruH Offline
      hruH Offline
      hru
      Hier das Ergebnis
                              v.2023-10-10
       Static hostname: pinas
             Icon name: computer
                Kernel: Linux 6.6.20+rpt-rpi-v8
          Architecture: arm64
      Kernel:                 aarch64
      Userland:               arm64
      User-ID:                1000
      X-Server:               false
      Boot Target:            multi-user.target
      Pending OS-Updates:     1
      node:internal/modules/cjs/loader:1143
        throw err;
      Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
          at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
          at Module._load (node:internal/modules/cjs/loader:981:27)
          at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
          at node:internal/main/run_main_module:28:49 {
        code: 'MODULE_NOT_FOUND',
        requireStack: []
      Node.js v18.20.2
      Pending iob updates:    0
      Nodejs-Installation:    /usr/bin/nodejs         v18.20.2
                              /usr/bin/node           v18.20.2
                              /usr/bin/npm            10.5.0
                              /usr/bin/npx            10.5.0
                              /usr/bin/corepack       0.25.2
      Recommended versions are nodejs  and npm
      MEMORY:
      Mem:            8.2G        524M        6.6G         10M        1.2G        7.7G
      Swap:           104M          0B        104M
      Total:          8.3G        524M        6.7G
        throw err;
        requireStack: []
      Node.js v18.20.2
      Active iob-Instances:   0
        throw err;
        requireStack: []
      Node.js v18.20.2
        throw err;
        requireStack: []
      Node.js v18.20.2
      ioBroker Core:          js-controller
        throw err;
        requireStack: []
      Node.js v18.20.2
                              admin
        throw err;
        requireStack: []
      Node.js v18.20.2
      ioBroker Status:
        throw err;
        requireStack: []
      Node.js v18.20.2
      Objects:                0
      States:                 0
      Size of iob-Database:
      4.0K    /opt/iobroker/iobroker-data/objects.jsonl
      0       /opt/iobroker/iobroker-data/states.jsonl
      PV-Anlage:
      13,5 kWp, WR: Sungrow SH10RT, Speicher: Sungrow SBR128, Heizstab: MyPV AC ELWA2
      Sonstige Geräte:
      ShellyPlusSmoke Rauchwarnmelder, Shelly Gas Warnmelder, Shelly Flood,
      IR-Leseköpfe für Stromzähler
      • hruH hru
        Hier das Ergebnis
                                v.2023-10-10
               Icon name: computer
            Architecture: arm64
        Kernel:                 aarch64
        Userland:               arm64
        User-ID:                1000
        X-Server:               false
          throw err;
          requireStack: []
        Node.js v18.20.2
                                /usr/bin/npm            10.5.0
                                /usr/bin/npx            10.5.0
        MEMORY:
        Swap:           104M          0B        104M
          throw err;
          requireStack: []
        Node.js v18.20.2
          throw err;
          requireStack: []
        Node.js v18.20.2
          throw err;
          requireStack: []
        Node.js v18.20.2
          throw err;
          requireStack: []
        Node.js v18.20.2
                                admin
          throw err;
          requireStack: []
        Node.js v18.20.2
        ioBroker Status:
          throw err;
          requireStack: []
        Node.js v18.20.2
        Objects:                0
        States:                 0
        @hru
        Sieht merkwürdig aus. Die Langfassung?
          @hru
          hruH Offline
          hruH Offline
          hru
          @thomas-braun Was ist die Langfassung?
          Ich habe iob diag ausgeführt und das Ergebnis zwischen den drei Aposthophs hier reinkopiert
          Ist das nicht das gewünschte?
          PV-Anlage:
          Sonstige Geräte:
          • hruH hru
            @hru sagte in Installation auf Raspi bleibt bei Schritt 3/4 hängen:
            Das ist die Zusammenfassung. Davor läuft die Langfassung durch.
              hruH Offline
              hruH Offline
              hru
              @thomas-braun Hier der Inhalt der oben genannten LOG Datei
              0 verbose cli /usr/bin/node /usr/lib/node_modules/npm/bin/npm-cli.js
              1 info using npm@10.5.0
              2 info using node@v18.20.2
              3 timing npm:load:whichnode Completed in 3ms
              4 timing config:load:defaults Completed in 6ms
              5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 2ms
              6 timing config:load:builtin Completed in 4ms
              7 timing config:load:cli Completed in 8ms
              8 timing config:load:env Completed in 3ms
              9 timing config:load:file:/opt/iobroker/node_modules/ursa-optional/.npmrc Completed in 0ms
              10 timing config:load:project Completed in 15ms
              11 timing config:load:file:/home/hru/.npmrc Completed in 2ms
              12 timing config:load:user Completed in 2ms
              13 timing config:load:file:/usr/etc/npmrc Completed in 0ms
              14 timing config:load:global Completed in 1ms
              15 timing config:load:setEnvs Completed in 2ms
              16 timing config:load Completed in 45ms
              17 timing npm:load:configload Completed in 45ms
              18 timing config:load:flatten Completed in 8ms
              19 timing npm:load:mkdirpcache Completed in 0ms
              20 timing npm:load:mkdirplogs Completed in 0ms
              21 verbose title npm run rebuild
              22 verbose argv "run" "rebuild"
              23 timing npm:load:setTitle Completed in 3ms
              24 timing npm:load:display Completed in 2ms
              25 verbose logfile logs-max:10 dir:/home/hru/.npm/_logs/2024-04-18T19_57_02_365Z-
              26 verbose logfile /home/hru/.npm/_logs/2024-04-18T19_57_02_365Z-debug-0.log
              27 timing npm:load:logFile Completed in 25ms
              28 timing npm:load:timers Completed in 0ms
              29 timing npm:load:configScope Completed in 0ms
              30 timing npm:load Completed in 128ms
              31 silly logfile start cleaning logs, removing 2 files
              32 silly logfile done cleaning log files
              33 timing command:run Completed in 4914ms
              34 verbose exit 1
              35 timing npm Completed in 5174ms
              36 verbose code 1
              PV-Anlage:
              Sonstige Geräte:
              • hruH hru
                34 verbose exit 1
                36 verbose code 1
                hruH Offline
                hruH Offline
                hru
                schrieb am zuletzt editiert von hru
                ok hier die komplette Ausgabe von iob diag
                Erzeugt per ./iob_diag | tee iob_diag.log. Enthält aber komische Steuerzeichen;-(
                iob_diag.log
                PV-Anlage:
                Sonstige Geräte:
                • hruH hru
                  iob_diag.log
                  @hru
                  Da beißt sich irgendwas auf dem port 9000:
                  tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      0          8222       828/python3
                    @hru
                    hruH Offline
                    hruH Offline
                    hru
                    @thomas-braun Ich glaube da läuft der modbusproxy.
                    Stört das den iobroker?
                    Dann halte ich den mal an, war nur zum ausprobieren.
                    PV-Anlage:
                    Sonstige Geräte:
                    • hruH hru
                      Ja, auf 9000 läuft die Datenbank vom iobroker. Also einer der beiden muss umziehen.
                        hruH Offline
                        hruH Offline
                        hru
                        @thomas-braun ok ich habe den modbus-proxy ausgeschaltet und iobroker noch einmal installiert.
                        Diesmal scheint es geklappt zu haben.
                        Anbei die Log-Ausgabe von iob diag.
                        Kannst ja noch einmal drüberschauen.
                        Danke und Gruß
                        Hartmut
                        iob_diag_neu.log
                        PV-Anlage:
                        Sonstige Geräte:
                        • hruH hru
                          Danke und Gruß
                          Hartmut
                          iob_diag_neu.log
                          @hru
                          Deine Quellen für openmediavault scheinen 'komisch' zu sein. Und mit dem Netzwerk/Internetzugang scheint es auch etwas zu klemmen.
                          hruH 2 Antworten Letzte Antwort
                            @hru
                            hruH Offline
                            hruH Offline
                            hru
                            @thomas-braun hm?
                            Ich kann jetzt auf jeden Fall die Bedienoberfläche des iobrokers öffnen.
                            Aktuell ist er im Step "Geräte und Dienste finden" bei "alle möglichen Geräte entdecken",
                            hat aber noch nichts gefunden;-(
                            PV-Anlage:
                            Sonstige Geräte:
                              @hru
                              hruH Offline
                              hruH Offline
                              hru
                              @thomas-braun Vielen Dank für Deine Unterstützung.
                              Für heute soll es bei mir mal reichen.
                              Ich werde mich auf jeden Fall in die Thematik iobroker noch einarbeiten müssen.
                              Mein Ziel ist es die Daten der folgenden Geräte "einzusammeln" und auszuwerten:
                              • Wechselrichter (und Speicher) Sungrow SH10RT
                              • Heizstab MyPV AC ELWA 2
                              • zwei Stromzähler
                              Bis demnächst;-)
                              PV-Anlage:
                              Sonstige Geräte:
