  4. Test Adapter TrashSchedule
    6.1k
adaptercalendaricalkalendermülltrash
1.4k Beiträge 186 Kommentatoren 681.2k Aufrufe 171 Beobachtet
    @australien Ok, ich bräuchte aber schon ein Log auf Debug-Loglevel um dazu irgendetwas sagen zu können.
    australien
    #1394
    @haus-automatisierung
    das sieht so aus
    Zeit
    Nachricht
    trashschedule.0
    	2024-03-12 12:39:01.826	debug	re-creating refresh timeout in 1263174ms (in 00:21:03)
    trashschedule.0
    	2024-03-12 12:39:01.826	debug	(0) [ical] update started by foreign state value - lc: 2023-12-30T23:00:19.626Z - ts: 2024-03-12T11:30:05.702Z
    trashschedule.0
    	2024-03-12 12:39:01.704	debug	[ical] found ical event(s): {"name":"Leichtverpackungen","enabled":true,"id":"","on":"","off":"","ack":false,"display":true}
    trashschedule.0
    	2024-03-12 12:39:01.703	debug	[ical] found ical event(s): {"name":"Papierbehälter","enabled":true,"id":"","on":"","off":"","ack":false,"display":true}
    trashschedule.0
    	2024-03-12 12:39:01.703	debug	[ical] found ical event(s): {"name":"Restabfallbehälter","enabled":true,"id":"","on":"","off":"","ack":false,"display":true}
    trashschedule.0
    	2024-03-12 12:39:01.703	info	[ical] configurured ical preview is 60 days (until 11.05.2024) - increase this value to find more events in the future
    trashschedule.0
    	2024-03-12 12:39:01.702	debug	[ical] current ical version: 1.13.3
    trashschedule.0
    	2024-03-12 12:39:01.694	debug	found configured trash type: "Leichtverpackungen" with ID "type.leichtverpackungen"
    trashschedule.0
    	2024-03-12 12:39:01.689	debug	found configured trash type: "Papierbehälter" with ID "type.papierbehälter"
    trashschedule.0
    	2024-03-12 12:39:01.681	debug	found configured trash type: "Restabfallbehälter" with ID "type.restabfallbehälter"
    trashschedule.0
    	2024-03-12 12:39:01.681	debug	found existing trash type with ID "type.leichtverpackungen"
    trashschedule.0
    	2024-03-12 12:39:01.680	debug	found existing trash type with ID "type.papierbehälter"
    trashschedule.0
    	2024-03-12 12:39:01.680	debug	found existing trash type with ID "type.restabfallbehälter"
    trashschedule.0
    	2024-03-12 12:39:01.568	info	starting. Version 3.2.0 in /opt/iobroker/node_modules/iobroker.trashschedule, node: v18.19.1, js-controller: 5.0.19
    trashschedule.0
    	2024-03-12 12:39:01.388	debug	Plugin sentry Initialize Plugin (enabled=true)
    trashschedule.0
    	2024-03-12 12:38:57.093	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    trashschedule.0
    trashschedule.0
    trashschedule.0
    trashschedule.0
    trashschedule.0
    	2024-03-12 12:38:57.093	debug	Plugin sentry destroyed
    trashschedule.0
    	2024-03-12 12:38:57.093	info	terminating
    trashschedule.0
    	2024-03-12 12:38:57.093	debug	clearing refresh timeout
    trashschedule.0
    	2024-03-12 12:38:57.092	info	cleaned everything up...
    trashschedule.0
    	2024-03-12 12:38:57.092	info	Got terminate signal TERMINATE_YOURSELF
    • A australien
      das sieht so aus
      Zeit
      Nachricht
      trashschedule.0
      trashschedule.0
      trashschedule.0
      trashschedule.0
      trashschedule.0
      trashschedule.0
      trashschedule.0
      trashschedule.0
      trashschedule.0
      trashschedule.0
      trashschedule.0
      trashschedule.0
      trashschedule.0
      trashschedule.0
      trashschedule.0
      trashschedule.0
      trashschedule.0
      trashschedule.0
      trashschedule.0
      trashschedule.0
      trashschedule.0
      trashschedule.0
      trashschedule.0
      trashschedule.0
      trashschedule.0
      haus-automatisierungH Offline
      #1395
      @australien Zeig mal den Inhalt von ical.0.data.table
      📚 Meine Dokumentation
        australien
        schrieb am zuletzt editiert von australien
        #1396
        mehr ist da nicht drinnen, habe ich übrigends in allen meiner 3 ical instanzen.
        • A australien
          #1397
          @australien Dann ist das der Grund. Sorry für die fehlende Meldung in 3.2.0, dass keine Termine existieren. Reiche ich nach.
          iCal-Konfiguration checken.
            Aktuelle Test Version 2.0.0
            Veröffentlichungsdatum 04.05.2022
            Github Link https://github.com/klein0r/ioBroker.trashschedule
            Im Forum existieren mehrere Themen, wie man aus einem iCal-Kalender die Müllabfahrtzeiten extrahieren kann. Dafür werden immer wieder Blockly und JavaScript-Funktionen geteilt. Ich dachte mir, dass es doch viel schöner wäre, wenn das ein Adapter erledigen könnte.
            Die Idee kommt aus dem FHEM-Umfeld, wo das ABFALL-Modul genau das gleiche macht. Auch dort wurden zuvor viele Funktionen bereitgestellt und jeder hat das Thema anders gelöst.
            Dieser Adapter nimmt eine iCal-Instanz als Quelle und durchsucht die nächsten Events nach den vorher definierten "Abfall-Typen". Wird ein Typ gefunden, werden die Tage bis zur Abholung berechnet und in einem State bereitgestellt. So entsteht eine Struktur, welche als Basis für VIS o.ä. genutzt werden kann.
            Weiterhin gibt es eine Zusammenfassung der nächsten Abholung, wenn mehrere "Abfall-Typen" auf einmal abgeholt werden. Diese kann man zum Beispiel für Pushover- oder Telegram-Nachrichten nutzen.
            Konfiguration
            Gelöscht. Bitte die aktuelle Doku nutzen: https://github.com/klein0r/ioBroker.trashschedule/blob/master/docs/de/README.md
            Wichtige Änderung ab Version 1.1.0
            Leider musste ich die Namen der Datenpunkte aufräumen, da immer wieder Quatsch dort reingeschrieben wurde. Solltest Du also Scripts oder eine Visualisierung auf den Datenpunkten der einzelnen Abfalltypen haben, müssen diese kontrolliert und ggf. angepasst werden.
            Reihenfolge um ab Version 1.0.1 wieder Daten zu bekommen (in VIS)
            1. Trashschedule Instanz stoppen
            2. Alle Datenpunkte des Adapters löschen (also von trashschedule.0). Einfach in der Objektansicht auf die Mülltonne klicken und weg damit.
            3. In der Expertenansicht der Adapterliste erst bei Trashschedule auf Upload klicken, dann bei VIS
            4. iCal einmal Instanzliste neustarten, dann Trashschedule wieder starten
              Danach sollte alles wieder richtig sein.
            MartinPM Online
            MartinPM Online
            MartinP
            #1398
            @haus-automatisierung said in Test Adapter TrashSchedule:
            Konfiguration
            Gelöscht. Bitte die aktuelle Doku nutzen: https://github.com/klein0r/ioBroker.trashschedule/blob/master/docs/de/basics.md
            (Zitat aus dem Thread-Eröffnungs-Beitrag.) Da liegt nichts mehr...
            • MartinPM MartinP
              Konfiguration
              #1399
              @martinp sagte in Test Adapter TrashSchedule:
              Von 2019 :) Danke, ist korrigiert. Zur Doku kommt man aber eh immer am besten über den Admin. Foren-Posts kann ich leider nicht immer alle pflegen und aktuell halten.
              Michael SchmittM 1 Antwort Letzte Antwort
                australien
                #1400
                Danke für deine Hilfe, die ics Datei war korrupt.
                Jetzt passt wieder alles.
                  Michael SchmittM Online
                  Michael Schmitt
                  #1401
                  und was macht man nun wenn man diese Einträge auf einmal hat ?
                  trashschedule.0
                  2024-03-19 17:54:36.744	info	Setting "actionNeeded" flag for type.restmülltonne.actionNeeded to true (???)
                  trashschedule.0
                  2024-03-19 17:54:36.721	info	Setting "actionNeeded" flag for type.gelberSack.actionNeeded to true (???)
                  • Michael SchmittM Michael Schmitt
                    trashschedule.0
                    trashschedule.0
                    #1402
                    @michael-schmitt Nix erstmal. Ignorieren
                    • Merlin123M Offline
                      Merlin123M Offline
                      Merlin123
                      #1403
                      Vis-2: Widget verschwindet manchmal
                      Hab das ein ganz komisches Phänomen:
                      Das Widget geht eigentlich in der Vis2 ganz gut. Aber manchmal ist es auf dem Tablet einfach verschwunden. Ist auf meiner Startseite, da fällt das auf.
                      Manchmal erscheint es wieder, wenn die die Seite neu lade, manchmal muss ich es einen Pixel verschieben.
                      Da ich im Moment viel an der Vis baue, weiß ich nicht, ob es daher irgendwie kommt oder ne andere Ursache hat.
                      Es wird nicht durch was anderes überlagert und es ist immer sichtbar.
                      Hat das noch jemand oder ne Idee, wie ich das verhindern kann?
                      Beta-Tester
                      S XsevX 2 Antworten Letzte Antwort
                      • Merlin123M Merlin123
                        schneidy76
                        #1404
                        @merlin123 schau mal hier: https://github.com/klein0r/ioBroker.trashschedule/issues/193
                        Raspberry Matic (RP3), LIVE PV Monitoring mit Smartmeter, Poolsteuerung mit NodeRed, KNX Ausbau (ersetzt stückweise HM & klassische Installation), ioBroker Multihost (RP4 &RP2), Visu mit VIS
                        Merlin123M 1 Antwort Letzte Antwort
                          XsevX Offline
                          XsevX Offline
                          Xsev
                          schrieb am zuletzt editiert von Xsev
                          #1405
                          @merlin123 Bei mir ist das Widget in Vis2 nur dann sichtbar sobald ich einmal die Seite wechsle. Ich habs auch auf der Startseite, beim ersten laden ist es nicht sichtbar sobald ich einmal eine andere Seite lade (innerhalb dem Vis Projekt) und wieder auf die Startseite zurück gehe, ist es da. Dann bleibt es bei mir auch sichtbar und verschwindet nicht mehr bis ich Vis neu lade.
                          • XsevX Xsev
                            Merlin123M Offline
                            Merlin123M Offline
                            Merlin123
                            #1406
                            @xsev Kann auch sein, dass es nach nem Umschalten weg ist... Muss ich mal drauf achten.
                            Beta-Tester
                            • S schneidy76
                              Merlin123M Offline
                              Merlin123M Offline
                              Merlin123
                              #1407
                              @schneidy76 Ah ok. Danke... ich wusste, dass ein neues Widget gemacht werden sollte, aber nicht, dass es so seltsame Anzeigeprobleme gibt.
                              Beta-Tester
                              • Siggi0904S Offline
                                Siggi0904S Offline
                                Siggi0904
                                #1408
                                @haus-automatisierung ich hätte gern zwei Erweiterungswünsche.
                                Für die Jahresabrechnung benötige die wirklich abgeholten Mülltonnen je Müllart.
                                Denn gerade der Restabfall wird ja je Tonne berechnet.
                                Könntest du einen Zähler einbauen, z.b. der completed entsprechend zählt?
                                Eine Option als Gegenteil zum completed wäre toll.
                                Wir stellen z.B. nicht bei jedem Termin die Tonne raus, der Termin schlägt aber natürlich trotzdem auf.
                                Wenn es eine Option gäbe der z.B. "nicht benötigt" heißen würde, je Müllsorte.
                                So kann man entsprechend vorher quasi die Müllabholung abwählen, da nicht benötigt.
                                Ich hoffe, meine Wünsche waren verständlich.
                                Dank dir.
                                • Siggi0904S Siggi0904
                                  Dank dir.
                                  #1409
                                  @siggi0904 Puh, ich finde das jetzt schon alles zu kompliziert mit den ganzen Abläufen. Irgendwann sieht ja niemand mehr durch.
                                  Schreibst Du die Doku dafür? Dann könntet wir drüber reden
                                  Siggi0904S 1 Antwort Letzte Antwort
                                    Siggi0904S Offline
                                    Siggi0904S Offline
                                    Siggi0904
                                    #1410
                                    @haus-automatisierung kann ich die Doku hier schreiben oder muss das im GIT erfolgen?
                                    Aber ich würde gern mehr am Doku Teil unterstützen, nur ist das mit dem Forken etc. immer sehr nervig,für jemanden der eigentlich keine Repo auf Github führt.
                                    Wie machst du oder die anderen das denn, wenn die Tonne nicht raus gestellt werden muss?
                                    haus-automatisierungH DJMarc75D 2 Antworten Letzte Antwort
                                      #1411
                                      @siggi0904 sagte in Test Adapter TrashSchedule:
                                      Den Fall habe ich nicht. Kommt immer raus wenn der Termin drin steht
                                        DJMarc75D Offline
                                        DJMarc75D Offline
                                        DJMarc75
                                        #1412
                                        Mal so am Rande: Wir haben eine Jahresmarke auf der Tonne kleben und da ist es Wurscht ob ich die raus stelle oder nicht. Wir zahlen einmalig für die Marke.
                                        Lehrling seit 1975 !!!
                                          Siggi0904S Offline
                                          Siggi0904S Offline
                                          Siggi0904
                                          #1413
                                          @haus-automatisierung wie ich das aktuell im Adapter mit aktueller Stable-Version sehe,
                                          sind ja alle Text zu übersetzen.
                                          Da könnte ich mal eine einleitende Hilfe benötigen zur Übersetzung.
                                          Z.B. auch, wenn an dem Datenwert z.B. "14 days" steht, wie man daraus "14 Tage" macht.
                                          Bei mir werden alle Beschreibungen auf englisch angezeigt.
                                          Was ist eigentlich der Unterschied zwischen trashschedule.0.nextAfter.types und trashschedule.0.nextAfter.typesText? das sind doch beides Texte und sehen spontan identisch aus.
                                          haus-automatisierungH 2 Antworten Letzte Antwort
