  2. English
  3. Scripting / Logic
  4. JavaScript
  5. problem during boot with schedule command in the script
5 Beiträge 4 Kommentatoren 1.6k Aufrufe 3 Beobachtet
  • H
    H
    hschief
    Dear Forum,
    i face some problems during system boot. There are some scripts with time schedules. For testing I create the following:
    function Test1() {
        log('In Function','error');
        setState('0_userdata.0.Allgemein.TestBoot', 'test', false);
    log('Script Test1 aufgerufen','error');
    schedule("*/10 * * * * *", Test1 )
    During normal operation it logs every 10s: "In Function" - as expected.
    During boot-up the following happend - it wrote logs to the log file more than 1000 times in a minute.:
    2024-04-16 14:25:31.573 - error: javascript.0 (726) script.js.Technik.Heizung.BootTestScript: In Function
    2024-04-16 14:25:31.580 - error: javascript.0 (726) script.js.Technik.Heizung.BootTestScript: In Function
    2024-04-16 14:25:31.591 - error: javascript.0 (726) script.js.Technik.Heizung.BootTestScript: In Function
    2024-04-16 14:25:31.598 - error: javascript.0 (726) script.js.Technik.Heizung.BootTestScript: In Function
    2024-04-16 14:25:31.610 - error: javascript.0 (726) script.js.Technik.Heizung.BootTestScript: In Function
    2024-04-16 14:25:31.622 - error: javascript.0 (726) script.js.Technik.Heizung.BootTestScript: In Function
    2024-04-16 14:25:31.634 - error: javascript.0 (726) script.js.Technik.Heizung.BootTestScript: In Function
    2024-04-16 14:25:31.642 - error: javascript.0 (726) script.js.Technik.Heizung.BootTestScript: In Function
    This happens in my installation for any scripts which such a schedule.
    In case i go to the shell and i use the commands: iobroker stop and afterwards iobroker start .. the system runs as expected without scheduling this 1000 times.
    In case I do a fresh boot, without starting the iobroker and then starting the iobroker from the console, I have the same problem. After I do iobroker stop/start all is fine again.
    I run:
    js: 5.0.19
    node: v18.17.1
    javascript: v7.8.0
    Any ideas? Anybody able to reproduce this before I create a bug report?
    • H hschief
      Dear Forum,
      function Test1() {
      I run:
      js: 5.0.19
      node: v18.17.1
      javascript: v7.8.0
      DJMarc75D
      DJMarc75D
      DJMarc75
      @hschief i don´t think that a double post in an other language is helpful to solve you´re Problem ;)
      Lehrling seit 1975 !!!
      H 1 Antwort Letzte Antwort
      • arteckA
        arteckA
        arteck
        why .....
        https://forum.iobroker.net/topic/74128/maximum-of-1000-setstate-during-boot?_=1713335509270
        • DJMarc75D DJMarc75
          H
          H
          hschief
          @djmarc75 easy to explain.... more english speaker the German speaker ... to reach a bigger audience. Thx. for the hint ... doesn't help anything for the question
          • H hschief
            @hschief sagte in problem during boot with schedule command in the script:
            das sind die Installationen und im forum istcdie Luft noch viel dünner
            83.8k
