  4. Adapter: ioBroker.unifi
    6.3k
unifi
1.0k Beiträge 172 Kommentatoren 531.1k Aufrufe 93 Beobachtet
  • P Pino72
    Es hagelt leider immer noch Fehler....manchmal läuft es auch einen Tag ohne Fehler...man kann keine Logik aus den Fehler rauslesen, scheint recht willkürlich zu passieren.
    	2024-01-12 09:37:15.693	error	[updateUnifiData-login site undefined] error: timeout of 10000ms exceeded, stack: AxiosError: timeout of 10000ms exceeded at RedirectableRequest.handleRequestTimeout (C:\Program Files\ioBroker\node_modules\node-unifi\node_modules\axios\lib\adapters\http.js:643:16) at RedirectableRequest.emit (node:events:517:28) at RedirectableRequest.emit (node:domain:489:12) at Timeout.<anonymous> (C:\Program Files\ioBroker\node_modules\follow-redirects\index.js:209:12) at listOnTimeout (node:internal/timers:569:17) at processTimers (node:internal/timers:512:7)
    unifi.0
    	2024-01-12 09:10:00.810	error	[updateUnifiData-login site undefined] error: timeout of 10000ms exceeded, stack: AxiosError: timeout of 10000ms exceeded at RedirectableRequest.handleRequestTimeout (C:\Program Files\ioBroker\node_modules\node-unifi\node_modules\axios\lib\adapters\http.js:643:16) at RedirectableRequest.emit (node:events:517:28) at RedirectableRequest.emit (node:domain:489:12) at Timeout.<anonymous> (C:\Program Files\ioBroker\node_modules\follow-redirects\index.js:209:12) at listOnTimeout (node:internal/timers:569:17) at processTimers (node:internal/timers:512:7)
    unifi.0
    	2024-01-12 08:46:57.842	error	[updateUnifiData-login site undefined] error: timeout of 10000ms exceeded, stack: AxiosError: timeout of 10000ms exceeded at RedirectableRequest.handleRequestTimeout (C:\Program Files\ioBroker\node_modules\node-unifi\node_modules\axios\lib\adapters\http.js:643:16) at RedirectableRequest.emit (node:events:517:28) at RedirectableRequest.emit (node:domain:489:12) at Timeout.<anonymous> (C:\Program Files\ioBroker\node_modules\follow-redirects\index.js:209:12) at listOnTimeout (node:internal/timers:569:17) at processTimers (node:internal/timers:512:7)
    unifi.0
    	2024-01-12 08:37:53.398	error	[updateUnifiData-login site undefined] error: timeout of 10000ms exceeded, stack: AxiosError: timeout of 10000ms exceeded at RedirectableRequest.handleRequestTimeout (C:\Program Files\ioBroker\node_modules\node-unifi\node_modules\axios\lib\adapters\http.js:643:16) at RedirectableRequest.emit (node:events:517:28) at RedirectableRequest.emit (node:domain:489:12) at Timeout.<anonymous> (C:\Program Files\ioBroker\node_modules\follow-redirects\index.js:209:12) at listOnTimeout (node:internal/timers:569:17) at processTimers (node:internal/timers:512:7)
    unifi.0
    	2024-01-12 08:36:43.316	error	[updateUnifiData-login site undefined] error: timeout of 10000ms exceeded, stack: AxiosError: timeout of 10000ms exceeded at RedirectableRequest.handleRequestTimeout (C:\Program Files\ioBroker\node_modules\node-unifi\node_modules\axios\lib\adapters\http.js:643:16) at RedirectableRequest.emit (node:events:517:28) at RedirectableRequest.emit (node:domain:489:12) at Timeout.<anonymous> (C:\Program Files\ioBroker\node_modules\follow-redirects\index.js:209:12) at listOnTimeout (node:internal/timers:569:17) at processTimers (node:internal/timers:512:7)
    boergl
    #922
    @pino72 funktioniert der Adapter bei dir überhaupt noch? Ich habe auch diese Meldung:
    [updateUnifiData-login site undefined] error: timeout of 10000ms exceeded, stack: AxiosError: timeout of 10000ms exceeded at RedirectableRequest.handleRequestTimeout (D:\ioBroker\node_modules\axios\lib\adapters\http.js:643:16) at RedirectableRequest.emit (node:events:518:28) at RedirectableRequest.emit (node:domain:488:12) at Timeout.<anonymous> (D:\ioBroker\node_modules\follow-redirects\index.js:210:12) at listOnTimeout (node:internal/timers:573:17) at processTimers (node:internal/timers:514:7)
    Bekomme aber gar keine Verbindung zusammen. Habe da so eine böse Befürchtung, dass es am letzten release (Network 8.1.113) liegt.
    ? crunchipC 2 Antworten Letzte Antwort
    • B boergl
      #923
      @boergl
      nee, an der 8.1.113 liegt es nicht, bei mir laeuft der Adapter...
      ( iobroker im buanet-Docker V9.0.1 )
      • B boergl
        crunchipC Offline
        crunchipC Offline
        #924
        @boergl die Meldung gibt es schon länger, gibt auch ein Github issue dazu.
        Einzige was vorkommen kann, das gewisse Datenpunkte nicht aktualisiert werden, Abhilfe schafft dann nur die Instanz neu zu starten( z. B in gewissen Abständen per cron)
        • P Offline
          Pino72
          #925
          Ist der Adapter nicht bald eh tot weil Unifi die obligatorische 2FA einführt...hasb eben angemacht und jedes Mal wenn der Controller sich verbinden will im IOBroker muss man das in der App am Handy freigeben...?
          Den nervigen Fehler mit dem is_online scheint auch keiner beheben zu können oder wollen?
          • P Pino72
            Meister MopperM Offline
            Meister Mopper
            #926
            @pino72 sagte in Adapter: ioBroker.unifi:
            Du kannst deine Hardware sowohl über Ubiquiti (dann mit 2FA) oder auch lokal (ohne 2FA) einbinden.
            Proxmox und HA ...
            P 1 Antwort Letzte Antwort
              Pino72
              #927
              @meister-mopper
              Aber im IOBroker Unifi Adapter gibt es nur 1 login Methode.
              NegaleinN Meister MopperM 2 Antworten Letzte Antwort
              • P Pino72
                @meister-mopper
                NegaleinN Offline
                NegaleinN Offline
                Negalein
                #928
                aus der Readme
                Minimum required information
                To get this adapter up and running the following information is needed:
                IP address and port of your UniFi controller (Leave the port empty in case your controller is running on UniFiOS (e.g. UDM-Pro))
                Local username and password (2FA cannot be supported)
                ° Fixer ---> iob fix
                • P Pino72
                  @meister-mopper
                  Meister Mopper
                  schrieb am zuletzt editiert von Meister Mopper
                  #929
                  @meister-mopper
                  Ja, und da verwendest du deinen lokal eingerichteten User. Du hast ja dann zwei User.
                  Das kannst du dir im Ubiquiti Help Center erklären lassen.
                  Proxmox und HA ...
                  • NegaleinN Negalein
                    aus der Readme
                    mhuber
                    #930
                    @Meister-Mopper
                    Du braucht nicht mal zwingend 2 User, geht auch mit dem normalen Admin solange er auch Lokale "Credentials" hat, zumindest bei mir ist das so
                    • M mhuber
                      @Meister-Mopper
                      Pino72
                      schrieb am zuletzt editiert von Pino72
                      #931
                      @mhuber
                      Hat sich erledigt, hab nen neuen localen User angelegt und gut.
                      • P Pino72
                        @mhuber
                        Pino72
                        #932
                        Mit dem neuesten Unifi Adapter scheinen die Fehlermeldungen verschwunden zu sein und ich hoffe damit auch der is_online Wert immer aktuell :-)
                        -1
                          tazdevil20
                          schrieb am zuletzt editiert von tazdevil20
                          #933
                          ich habe mir einen U6+ AP und zwei Flex Mini zugelegt. Den Manager habe ich lokal als LXC (Debian) unter Proxmox laufen.
                          Ich habe nun jedoch mit dem Adapter folgende Probleme:
                          • Es werden nur Systeme die Online sind im iobroker erstellt
                          • Es werden nur WLAN-Systeme im iobroker erstellt
                          • Das silly-Log funktioniert leider nicht (laut Quelltest sollten dann die erhaltenen JSONs ausgegeben werden)
                          Vorerst war es das. Der wichtigste Punkt wäre mir, dass ich im Adapter auch die Systeme wir per Kabel im Netzwerk hängen sehen kann.
                          Habe versucht in der Thread-Historie zu suchen. Das hatte leider keinen Erfolg.
                          Jemand Ideen?
                          O T 2 Antworten Letzte Antwort
                          • T tazdevil20
                            Jemand Ideen?
                            O Offline
                            O Offline
                            oxident
                            #934
                            @tazdevil20 Ich muss mal blöd fragen: Im Manager werden die aber angezeigt, ja?
                            Mir war nicht klar, dass das ohne Gateway und/oder Switches von Ubiquiti überhaupt funktioniert.
                            • O oxident
                              tazdevil20
                              #935
                              @oxident
                              Ja, im Manager wird alles angezeigt. Die im LAN befindlichen Systeme werden aber nur mit MAC und der Anbindung (GbE, FE, ...) angezeigt. Die IP fehlt.
                              Die Flex Mini sind Switches ;-)
                              • P Pino72
                                Pino72
                                #936
                                @pino72 said in Adapter: ioBroker.unifi:
                                Leider wohl zu früh gefreut:
                                [updateUnifiData-login site undefined] error: timeout of 10000ms exceeded, stack: AxiosError: timeout of 10000ms exceeded at RedirectableRequest.handleRequestTimeout (C:\ioBroker\node_modules\node-unifi\node_modules\axios\lib\adapters\http.js:643:16) at RedirectableRequest.emit (node:events:517:28) at RedirectableRequest.emit (node:domain:489:12) at Timeout.<anonymous> (C:\ioBroker\node_modules\follow-redirects\index.js:210:12) at listOnTimeout (node:internal/timers:569:17) at processTimers (node:internal/timers:512:7)
                                ? M 2 Antworten Letzte Antwort
                                • P Pino72
                                  #937
                                  @pino72
                                  Bei mir trat der Fehler sowieso nur ab und zu mal auf, seit dem Update auf 4.0.3 der UDM Pro gar nicht mehr.
                                  Laeuft alles perfekt... sowohl die AP's als auch die Switche..
                                  ( 8 AP's, 21 Switche, UDM Pro, ca 90 Lan Devices und ca. 320 Wifi Devices..)
                                    @pino72
                                    Pino72
                                    #938
                                    @ilovegym Woher hast Du die 4.0.3 ich bin auf Release channel und auf der 3.2.12?
                                    Ok sehe gerade die gibts im Early Access...na dann hol ich die mir auch mal.
                                    • P Pino72
                                      mrMuppet
                                      #939
                                      @pino72 Hat sich bei is_online bei dir etwas verbessert? Hab kein UDM Pro (nur ein USG 😁 ) und hab jetzt mal die Version 0.7.0 vom Unifi-Adapter probiert, aber auch damit sind keine Geräte online.
                                      ioBroker auf NUC (Celeron mit Ubuntu-Server)
                                      Homematic, HMIP, Hue, Unifi, Plex, Nest, Roborock, Google Assistant
                                      • M mrMuppet
                                        Pino72
                                        #940
                                        @mrmuppet Mit dem Update auf 4.0.3 hab ich bisher auch keine Fehlermeldung mehr gehabt...is_online passt.
                                        • T tazdevil20
                                          Jemand Ideen?
                                          tazdevil20
                                          #941
                                          @tazdevil20 said in Adapter: ioBroker.unifi:
                                          Das Thema silly-Log ist erledigt. Ich war einfach zu doof in der Loganzeige umzustellen.
                                          Ist es so gewollt, dass nur die Systeme im iobroker hinterlegt werden die aktuell online sind? Wenn die Systeme mal online waren wird der Status (online/offline) richtig dargestellt. Die Systeme die im Unifi Manager als offline stehen werden bei dem hinzufügen ignoriert.
                                          Wie erwähnt werden bei mir nur die WLAN-Clients im iobroker erstellt. Die LAN-Clients nicht. Im JSON sind die LAN-Clients enthalten.
                                          Json eines WLAN-Clients:
                                              "site_id": "65fd52e3b3f9ac6516c4eb9c",
                                              "ap_mac": "<gelöscht>",
                                              "assoc_time": 1714917545,
                                              "latest_assoc_time": 1715145603,
                                              "oui": "Espressif Inc.",
                                              "user_id": "662d5039d9cd7826570761e3",
                                              "last_ip": "<gelöscht>",
                                              "note": "{\"image\": \"tasmota\"}",
                                              "first_seen": 1714245689,
                                              "last_seen": 1715145618,
                                              "is_guest": false,
                                              "disconnect_timestamp": 1714838219,
                                              "use_fixedip": false,
                                              "local_dns_record": "",
                                              "is_wired": false,
                                              "usergroup_id": "",
                                              "last_connection_network_name": "Default",
                                              "mac": "<gelöscht>",
                                              "virtual_network_override_enabled": false,
                                              "noted": true,
                                              "last_connection_network_id": "65fd5303b3f9ac6516c4ebb3",
                                              "hostname": "<gelöscht>",
                                              "fixed_ap_enabled": false,
                                              "local_dns_record_enabled": false,
                                              "virtual_network_override_id": "",
                                              "_id": "662d5039d9cd7826570761e3",
                                              "fixed_ip": "<gelöscht>",
                                              "wlanconf_id": "662a9a1bdaf35c0d57a9d9df",
                                              "_uptime_by_uap": 228018,
                                              "_last_seen_by_uap": 1715145618,
                                              "_is_guest_by_uap": false,
                                              "ip": "<gelöscht>",
                                              "channel": 6,
                                              "radio": "ng",
                                              "radio_name": "ra0",
                                              "essid": "<gelöscht>",
                                              "bssid": "<gelöscht>",
                                              "powersave_enabled": true,
                                              "is_11r": false,
                                              "user_group_id_computed": "65fd5303b3f9ac6516c4ebb4",
                                              "anomalies": 0,
                                              "anon_client_id": "3cc9599e2acd8ac3edf72591df4587",
                                              "ccq": 0,
                                              "dhcpend_time": 172,
                                              "idletime": 15,
                                              "noise": -96,
                                              "nss": 1,
                                              "rx_rate": 48000,
                                              "rssi": 40,
                                              "satisfaction_now": 100,
                                              "satisfaction_real": 97,
                                              "satisfaction_reason": 8,
                                              "signal": -56,
                                              "tx_mcs": 7,
                                              "tx_power": 0,
                                              "tx_rate": 72000,
                                              "tx_retry_burst_count": 0,
                                              "satisfaction": 97,
                                              "hostname_source": "uap",
                                              "radio_proto": "ng",
                                              "channel_width": 20,
                                              "satisfaction_avg": {
                                                "total": 2361375,
                                                "count": 24274
                                              "uptime": 228073,
                                              "tx_bytes": 2314553,
                                              "rx_bytes": 18155944,
                                              "tx_packets": 41110,
                                              "rx_packets": 1195597,
                                              "authorized": true,
                                              "qos_policy_applied": true,
                                              "bytes-r": 72.47187519423208,
                                              "tx_bytes-r": 11.560693641618498,
                                              "rx_bytes-r": 60.91118155261359,
                                              "tx_retries": 2028,
                                              "wifi_tx_attempts": 43138,
                                              "wifi_tx_dropped": 0,
                                              "wifi_tx_retries_percentage": 0,
                                              "_uptime_by_usw": 0,
                                              "_last_seen_by_usw": 1715145603,
                                              "_is_guest_by_usw": false,
                                              "network": "Default",
                                              "network_id": "65fd5303b3f9ac6516c4ebb3"
                                          Json eines LAN-Clients:
                                              "assoc_time": 1714927259,
                                              "latest_assoc_time": 1715145606,
                                              "oui": "Onkyo Technology K.K.",
                                              "user_id": "6634bb9a6de0d017cd319251",
                                              "note": "{\"image\": \"onkyo\"}",
                                              "first_seen": 1714731930,
                                              "last_seen": 1715145606,
                                              "is_guest": false,
                                              "is_wired": true,
                                              "usergroup_id": "",
                                              "noted": true,
                                              "name": "Onkyo",
                                              "_id": "6634bb9a6de0d017cd319251",
                                              "_last_seen_by_usw": 1715145606,
                                              "sw_mac": "<gelöscht>",
                                              "wired_rate_mbps": 100,
                                              "sw_depth": 1,
                                              "network_id": "65fd5303b3f9ac6516c4ebb3",
                                              "anomalies": -1,
                                                "total": 0,
                                                "count": 24650
                                              "uptime": 218347,
                                              "wired-tx_bytes": 123052254,
                                              "wired-rx_bytes": 38954069,
                                              "wired-tx_packets": 924014,
                                              "wired-rx_packets": 149819,
                                              "wired-tx_bytes-r": 494.98847617516213,
                                              "wired-rx_bytes-r": 28.353969019670902,
                                              "sw_port": 3
                                          Ich habe nicht herausfinden können warum die LAN-Clients aussortiert werden. Dazu habe ich in der main.js als auch in der objects_clients.json gesucht und Anpassungen gemacht. Jedoch offenbar nicht die richtigen.
