  4. SNMP Adapter Update startet nicht
15 Beiträge 3 Kommentatoren 538 Aufrufe 2 Beobachtet
    @martinp
    Mach es über die Konsole. Die ist ggf. gesprächiger.
    iob update
    iob upgrade
    Edit: Kann auch kein Fehler im Paket sein, hier läuft das nämlich durch:
    echad@chet:~ $ iob add snmp
    NPM version: 10.5.0
    Installing iobroker.snmp@3.2.0... (System call)
    added 3 packages in 12s
    171 packages are looking for funding
      run `npm fund` for details
    host.chet install adapter snmp
    upload [14] snmp.admin /opt/iobroker/node_modules/iobroker.snmp/admin/i18n/de/translations.json i18n/de/translations.json application/json
    upload [13] snmp.admin /opt/iobroker/node_modules/iobroker.snmp/admin/i18n/en/translations.json i18n/en/translations.json application/json
    upload [12] snmp.admin /opt/iobroker/node_modules/iobroker.snmp/admin/i18n/es/translations.json i18n/es/translations.json application/json
    upload [11] snmp.admin /opt/iobroker/node_modules/iobroker.snmp/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
    upload [10] snmp.admin /opt/iobroker/node_modules/iobroker.snmp/admin/i18n/it/translations.json i18n/it/translations.json application/json
    upload [9] snmp.admin /opt/iobroker/node_modules/iobroker.snmp/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
    upload [8] snmp.admin /opt/iobroker/node_modules/iobroker.snmp/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    upload [7] snmp.admin /opt/iobroker/node_modules/iobroker.snmp/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
    upload [6] snmp.admin /opt/iobroker/node_modules/iobroker.snmp/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
    upload [5] snmp.admin /opt/iobroker/node_modules/iobroker.snmp/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
    upload [4] snmp.admin /opt/iobroker/node_modules/iobroker.snmp/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
    upload [3] snmp.admin /opt/iobroker/node_modules/iobroker.snmp/admin/index_m.html index_m.html text/html
    upload [2] snmp.admin /opt/iobroker/node_modules/iobroker.snmp/admin/jsonConfig.json jsonConfig.json application/json
    upload [1] snmp.admin /opt/iobroker/node_modules/iobroker.snmp/admin/snmp.png snmp.png image/png
    upload [0] snmp.admin /opt/iobroker/node_modules/iobroker.snmp/admin/words.js words.js application/javascript
    host.chet object system.adapter.snmp created/updated
    host.chet create instance snmp
    host.chet object system.adapter.snmp.0.alive created
    host.chet object system.adapter.snmp.0.connected created
    host.chet object system.adapter.snmp.0.compactMode created
    host.chet object system.adapter.snmp.0.cpu created
    host.chet object system.adapter.snmp.0.cputime created
    host.chet object system.adapter.snmp.0.memHeapUsed created
    host.chet object system.adapter.snmp.0.memHeapTotal created
    host.chet object system.adapter.snmp.0.memRss created
    host.chet object system.adapter.snmp.0.uptime created
    host.chet object system.adapter.snmp.0.inputCount created
    host.chet object system.adapter.snmp.0.outputCount created
    host.chet object system.adapter.snmp.0.eventLoopLag created
    host.chet object system.adapter.snmp.0.sigKill created
    host.chet object system.adapter.snmp.0.logLevel created
    host.chet object snmp.0.info created
    host.chet object snmp.0.info.connection created
    host.chet Set default value of snmp.0.info.connection: false
    host.chet object system.adapter.snmp.0 created
    echad@chet:~ $
    MartinPM Online
    MartinPM Online
    MartinP
    @thomas-braun Aus der Konsole hat es geklappt
    Die Web-GUI war da auch inkonsistent
    Eine blaue "2" über "Instances", aber nur der SNMP Adapter wurde angezeigt .. in der Konsole war es vollständig ...
    martin@iobroker-test-sicher:/opt/iobroker/backups$ iob update
    Used repository: stable
    Adapter    "admin"        : 6.13.16  , installed 6.13.16
    Adapter    "alias-manager": 1.2.6    , installed 1.2.6
    Adapter    "backitup"     : 2.11.0   , installed 2.10.11 [Updatable]
    Adapter    "benchmark"    : 1.1.4    , installed 1.1.4
    Adapter    "deconz"       : 1.4.0    , installed 1.4.0
    Adapter    "discovery"    : 4.4.0    , installed 4.4.0
    Adapter    "email"        : 1.2.2    , installed 1.2.2
    Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
    Adapter    "ical"         : 1.14.3   , installed 1.14.3
    Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
    Adapter    "javascript"   : 7.8.0    , installed 7.8.0
    Controller "js-controller": 5.0.19   , installed 5.0.19
    Adapter    "meross"       : 1.17.0   , installed 1.17.0
    Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
    Adapter    "mqtt-client"  : 1.7.0    , installed 1.7.0
    Adapter    "operating-hours": 1.0.6  , installed 1.0.6
    Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
    Adapter    "snmp"         : 3.2.0    , installed 3.1.0  [Updatable]
    Adapter    "socketio"     : 6.6.1    , installed 6.6.1
    Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
    Adapter    "tradfri"      : 3.1.3    , installed 3.1.3
    Adapter    "vis"          : 1.5.4    , installed 1.5.4
    Adapter    "web"          : 6.2.5    , installed 6.2.5
    Adapter    "ws"           : 2.5.11   , installed 2.5.11
    Adapter    "zigbee2mqtt"  : 2.13.6   , installed 2.13.6
    martin@iobroker-test-sicher:/opt/iobroker/backups$ iob upgrade
    This upgrade of "snmp" will introduce the following changes:
    -> 3.2.0:
    Adapter requires node.js 18 and js-controller >= 5 now
    Dependencies have been updated
    Would you like to upgrade snmp from @3.1.0 to @3.2.0 now? [(y)es, (n)o]: y
    Update snmp from @3.1.0 to @3.2.0
    host.iobroker-test-sicher Adapter "system.adapter.snmp.0" is stopped.
    NPM version: 10.5.0
    changed 3 packages in 21s
    132 packages are looking for funding
    Update "system.adapter.snmp.0"
    host.iobroker-test-sicher Adapter "system.adapter.snmp.0" is started
    This upgrade of "backitup" will introduce the following changes:
    -> 2.11.0:
    Fix Sqlite3 Path
    Would you like to upgrade backitup from @2.10.11 to @2.11.0 now? [(y)es, (n)o]: y
    Update backitup from @2.10.11 to @2.11.0
    host.iobroker-test-sicher Adapter "system.adapter.backitup.0" is stopped.
    NPM version: 10.5.0
    Installing iobroker.backitup@2.11.0... (System call)
    removed 2 packages, and changed 6 packages in 19s
    Update "system.adapter.backitup.0"
    upload [21] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
    upload [20] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
    upload [19] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
    upload [18] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/de/translations.json i18n/de/translations.json application/json
    upload [17] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/en/translations.json i18n/en/translations.json application/json
    upload [16] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/es/translations.json i18n/es/translations.json application/json
    upload [15] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
    upload [14] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/it/translations.json i18n/it/translations.json application/json
    upload [13] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
    upload [12] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    upload [11] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
    upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
    upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
    upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
    upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
    upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
    upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
    upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
    upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
    upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
    upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
    upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
    host.iobroker-test-sicher Adapter "system.adapter.backitup.0" is started
    • MartinPM MartinP
      -> 3.2.0:
      NPM version: 10.5.0
      -> 2.11.0:
      Fix Sqlite3 Path
      NPM version: 10.5.0
      @martinp
      Und was sag ich immer: GUIs lügen.
        @martinp
        MartinPM Online
        MartinPM Online
        MartinP
        @thomas-braun aktuell aber sowas von ...
        host.iobroker-test-sicher	2024-04-15 18:45:37.552	error	cannot get getHostInfo: Cannot read properties of undefined (reading 'speed')
        Und das hier dazu noch ...
        Ist das ggfs. ein Kollateralschaden der neuen SNMP Adapter Version?
        Mal schauen, ob sich das irgendwann beruhigt...
        ein "iob restart" habe ich schon gemacht - immer noch "offline", und dieses "cannot read properties of undefined ... " im Logging taucht immer mal wieder auf ...
        "iob stop - iob fix - iob start"
        Offline bleibt ...
        Mal schauen, wie sich das ansonsten auswirkt ...
        • MartinPM MartinP
          Offline bleibt ...
          @martinp
          Kannst dir ja mal die Großwetterlage per
          iob diag
          anschauen.
            @martinp
            iob diag
            anschauen.
            MartinPM Online
            MartinPM Online
            MartinP
            @thomas-braun vorher iob stop wenn ich mich nicht irre?
            • MartinPM MartinP
              @martinp
              Nein, bei laufendem System.
                @martinp
                MartinPM Online
                MartinPM Online
                MartinP
                Die "Transport Endpoint is not connected" Meldungen sind etwas merkwürdig ...
                Skript v.2023-10-10
                *** BASE SYSTEM ***
                 Static hostname: iobroker-test-sicher
                       Icon name: computer-container
                         Chassis: container ☐
                  Virtualization: lxc
                          Kernel: Linux 6.5.13-5-pve
                    Architecture: x86-64
                grep: /proc/cpuinfo: Transport endpoint is not connected
                Docker          : false
                Virtualization  : lxc
                Kernel          : x86_64
                Userland        : amd64
                Systemuptime and Load:
                uptime: Cannot get system uptime: Transport endpoint is not connected
                CPU threads:
                *** Time and Time Zones ***
                               Local time: Mon 2024-04-15 19:14:08 CEST
                           Universal time: Mon 2024-04-15 17:14:08 UTC
                                 RTC time: n/a
                              NTP service: inactive
                          RTC in local TZ: no
                *** User and Groups ***
                martin
                /home/martin
                martin sudo iobroker
                *** X-Server-Setup ***
                X-Server:       false
                Desktop:
                Terminal:
                *** MEMORY ***
                free: Unable to create meminfo structure
                vmstat: Unable to create system stat structure
                *** FAILED SERVICES ***
                  UNIT                                 LOAD   ACTIVE SUB    DESCRIPTION
                * mnt-backup.mount                     loaded failed failed /mnt/backup
                * mnt-data.mount                       loaded failed failed /mnt/data
                * mnt-unterhaltung.mount               loaded failed failed /mnt/unterhaltung
                * run-rpc_pipefs.mount                 loaded failed failed RPC Pipe File System
                * sys-kernel-config.mount              loaded failed failed Kernel Configuration File System
                * systemd-networkd-wait-online.service loaded failed failed Wait for Network to be Configured
                6 loaded units listed.
                *** FILESYSTEM ***
                df: /proc/cpuinfo: Transport endpoint is not connected
                df: /proc/diskstats: Transport endpoint is not connected
                df: /proc/loadavg: Transport endpoint is not connected
                df: /proc/meminfo: Transport endpoint is not connected
                df: /proc/slabinfo: Transport endpoint is not connected
                df: /proc/stat: Transport endpoint is not connected
                df: /proc/swaps: Transport endpoint is not connected
                df: /proc/uptime: Transport endpoint is not connected
                df: /sys/devices/system/cpu: Transport endpoint is not connected
                Filesystem                       Type      Size  Used Avail Use% Mounted on
                /dev/mapper/pve-vm--101--disk--0 ext4       63G   13G   47G  22% /
                none                             tmpfs     492K  4.0K  488K   1% /dev
                udev                             devtmpfs  3.8G     0  3.8G   0% /dev/tty
                tmpfs                            tmpfs     3.8G     0  3.8G   0% /dev/shm
                tmpfs                            tmpfs     1.6G  124K  1.6G   1% /run
                tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
                dmesg: read kernel buffer failed: Operation not permitted
                TARGET SOURCE                           FSTYPE OPTIONS
                /      /dev/mapper/pve-vm--101--disk--0 ext4   rw,relatime,stripe=16
                /var:
                2.2G    /var/
                1.2G    /var/lib
                1.1G    /var/lib/influxdb/engine
                978M    /var/lib/influxdb/engine/data/f11825691705bf53/autogen
                Archived and active journals take up 106.9M in the file system.
                /opt/iobroker/backups:
                4.6G    /opt/iobroker/backups/
                /opt/iobroker/iobroker-data:
                952M    /opt/iobroker/iobroker-data/
                905M    /opt/iobroker/iobroker-data/files
                771M    /opt/iobroker/iobroker-data/files/vis-2-beta
                738M    /opt/iobroker/iobroker-data/files/vis-2-beta/static
                736M    /opt/iobroker/iobroker-data/files/vis-2-beta/static/js
                24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                9.7M    /opt/iobroker/iobroker-data/files/vis-2-beta/material-icons/knx-uf.json
                8.5M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js
                8.3M    /opt/iobroker/iobroker-data/files/vis-2-beta/static/js/main.a81e98bd.js
                8.3M    /opt/iobroker/iobroker-data/files/vis-2-beta/static/js/main.a256af99.js
                USB-Devices by-id:
                find: '/dev/serial/by-id/': No such file or directory
                *** NodeJS-Installation ***
                /usr/bin/nodejs         v18.20.2
                /usr/bin/node           v18.20.2
                /usr/bin/npm            10.5.0
                /usr/bin/npx            10.5.0
                /usr/bin/corepack       0.25.2
                nodejs:
                  Installed: 18.20.2-1nodesource1
                  Candidate: 18.20.2-1nodesource1
                  Version table:
                 *** 18.20.2-1nodesource1 1001
                        500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                     18.20.1-1nodesource1 1001
                     18.20.0-1nodesource1 1001
                     18.19.1-1nodesource1 1001
                     18.19.0+dfsg-6~deb12u1 500
                        500 http://security.debian.org bookworm-security/main amd64 Packages
                     18.19.0-1nodesource1 1001
                     18.18.2-1nodesource1 1001
                     18.18.1-1nodesource1 1001
                     18.18.0-1nodesource1 1001
                     18.17.1-1nodesource1 1001
                     18.17.0-1nodesource1 1001
                     18.16.1-1nodesource1 1001
                     18.16.0-1nodesource1 1001
                     18.15.0-1nodesource1 1001
                     18.14.2-1nodesource1 1001
                     18.14.1-1nodesource1 1001
                     18.14.0-1nodesource1 1001
                     18.13.0+dfsg1-1 500
                        500 http://ftp.debian.org/debian bookworm/main amd64 Packages
                     18.13.0-1nodesource1 1001
                     18.12.0-1nodesource1 1001
                     18.11.0-1nodesource1 1001
                     18.10.0-1nodesource1 1001
                     18.9.1-1nodesource1 1001
                     18.9.0-1nodesource1 1001
                     18.8.0-1nodesource1 1001
                     18.7.0-1nodesource1 1001
                     18.6.0-1nodesource1 1001
                     18.5.0-1nodesource1 1001
                     18.4.0-1nodesource1 1001
                     18.3.0-1nodesource1 1001
                     18.2.0-1nodesource1 1001
                     18.1.0-1nodesource1 1001
                     18.0.0-1nodesource1 1001
                No problems detected
                Errors in npm tree:
                *** ioBroker-Installation ***
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                Core adapters versions
                js-controller:  5.0.19
                admin:          6.13.16
                javascript:     7.8.0
                Adapters from github:   0
                Adapter State
                + system.adapter.admin.0                  : admin                 : iobroker-test-sicher                     -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                  system.adapter.alias-manager.0          : alias-manager         : iobroker-test-sicher                     -  enabled
                + system.adapter.backitup.0               : backitup              : iobroker-test-sicher                     -  enabled
                + system.adapter.discovery.0              : discovery             : iobroker-test-sicher                     -  enabled
                + system.adapter.email.0                  : email                 : iobroker-test-sicher                     -  enabled
                + system.adapter.fritzdect.0              : fritzdect             : iobroker-test-sicher                     -  enabled
                  system.adapter.ical.0                   : ical                  : iobroker-test-sicher                     -  enabled
                  system.adapter.ical.1                   : ical                  : iobroker-test-sicher                     -  enabled
                + system.adapter.influxdb.0               : influxdb              : iobroker-test-sicher                     -  enabled, port: 8086
                + system.adapter.javascript.0             : javascript            : iobroker-test-sicher                     -  enabled
                + system.adapter.meross.0                 : meross                : iobroker-test-sicher                     -  enabled
                + system.adapter.mqtt-client.0            : mqtt-client           : iobroker-test-sicher                     -  enabled, port: 1888
                + system.adapter.mqtt.0                   : mqtt                  : iobroker-test-sicher                     -  enabled, port: 1888, bind: 0.0.0.0
                + system.adapter.operating-hours.0        : operating-hours       : iobroker-test-sicher                     -  enabled
                + system.adapter.ping.0                   : ping                  : iobroker-test-sicher                     -  enabled
                + system.adapter.simple-api.0             : simple-api            : iobroker-test-sicher                     -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                + system.adapter.snmp.0                   : snmp                  : iobroker-test-sicher                     -  enabled
                + system.adapter.sonoff.0                 : sonoff                : iobroker-test-sicher                     -  enabled, port: 1892, bind: 0.0.0.0
                + system.adapter.tradfri.0                : tradfri               : iobroker-test-sicher                     -  enabled
                  system.adapter.vis.0                    : vis                   : iobroker-test-sicher                     -  enabled
                + system.adapter.web.0                    : web                   : iobroker-test-sicher                     -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                + instance is alive
                ioBroker-Repositories
                Active repo(s): stable
                Installed ioBroker-Instances
                Adapter    "backitup"     : 2.11.0   , installed 2.11.0
                Adapter    "snmp"         : 3.2.0    , installed 3.2.0
                Objects and States
                Objects:        1561
                States:         1208
                Hit:1 http://security.debian.org bookworm-security InRelease
                Hit:2 http://ftp.debian.org/debian bookworm InRelease
                Hit:3 http://ftp.debian.org/debian bookworm-updates InRelease
                Hit:4 https://apt.grafana.com stable InRelease
                Hit:5 https://repos.influxdata.com/debian stable InRelease
                Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
                Reading package lists...
                Pending Updates: 0
                *** Listening Ports ***
                tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          35821      1/init
                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       32173897   50483/iobroker.js-c
                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       32173937   50483/iobroker.js-c
                tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          44561      349/master
                tcp        0      0 0.0.0.0:1892            0.0.0.0:*               LISTEN      1001       32177860   50670/io.sonoff.0
                tcp        0      0 0.0.0.0:1888            0.0.0.0:*               LISTEN      1001       32177590   50645/io.mqtt.0
                tcp6       0      0 :::111                  :::*                    LISTEN      0          35823      1/init
                tcp6       0      0 :::22                   :::*                    LISTEN      0          38539      1/init
                tcp6       0      0 ::1:25                  :::*                    LISTEN      0          44562      349/master
                tcp6       0      0 :::3000                 :::*                    LISTEN      109        10568373   16590/grafana
                tcp6       0      0 :::8087                 :::*                    LISTEN      1001       32182013   50978/io.simple-api
                tcp6       0      0 :::8086                 :::*                    LISTEN      998        32082191   48633/influxd
                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       32175354   50501/io.admin.0
                tcp6       0      0 :::8082                 :::*                    LISTEN      1001       32181799   50948/io.web.0
                udp        0      0 0.0.0.0:52497           0.0.0.0:*                           1001       32180338   50812/io.snmp.0
                udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          35822      1/init
                udp        0      0 0.0.0.0:37461           0.0.0.0:*                           1001       32182377   50967/io.tradfri.0
                udp6       0      0 :::111                  :::*                                0          35824      1/init
                2024-04-15 19:14:38.133  - info: tradfri.0 (50967) got all scenes in group 131075: []
                2024-04-15 19:14:38.226  - info: tradfri.0 (50967) updating possible scenes for group 131073: ["196611"]
                2024-04-15 19:14:38.379  - info: tradfri.0 (50967) updating possible scenes for group 131073: ["196611","196612"]
                2024-04-15 19:14:38.478  - info: tradfri.0 (50967) updating possible scenes for group 131073: ["196611","196612","196614"]
                2024-04-15 19:14:38.607  - info: tradfri.0 (50967) received all groups and scenes
                2024-04-15 19:14:38.642  - info: tradfri.0 (50967) updating possible scenes for group 131074: ["196615","196616"]
                2024-04-15 19:14:38.773  - info: host.iobroker-test-sicher instance system.adapter.operating-hours.0 started with pid 51001
                2024-04-15 19:14:41.714  - info: simple-api.0 (50978) starting. Version 2.7.2 in /opt/iobroker/node_modules/iobroker.simple-api, node: v18.20.2, js-controller: 5.0.19
                2024-04-15 19:14:41.777  - warn: simple-api.0 (50978) Information for Developer: Using the direct "Let's encrypt" module import is deprecated and will be removed in the next js-controller version, use @iobroker/webserver instead
                2024-04-15 19:14:41.804  - info: simple-api.0 (50978) simpleAPI server listening on port 8087
                2024-04-15 19:14:41.814  - info: simple-api.0 (50978) Allow states only when user is owner: false
                2024-04-15 19:14:41.857  - info: simple-api.0 (50978) http server listening on port 8087
                2024-04-15 19:14:43.965  - info: operating-hours.0 (51001) starting. Version 1.0.6 in /opt/iobroker/node_modules/iobroker.operating-hours, node: v18.20.2, js-controller: 5.0.19
                2024-04-15 19:14:48.740  - warn: mqtt.0 (50645) Client [esp8266-cf6d7a] Message 1 deleted after 11 retries
                2024-04-15 19:14:54.742  - warn: mqtt.0 (50645) Client [esp8266-cf6d7a] Message 1 deleted after 11 retries
                2024-04-15 19:14:58.743  - warn: mqtt.0 (50645) Client [esp8266-cf6d7a] Message 1 deleted after 11 retries
                2024-04-15 19:15:02.722  - info: mqtt.0 (50645) Client [esp8266-cf6d7a] connection closed: closed
                2024-04-15 19:15:04.722  - info: mqtt.0 (50645) Client [esp8266-cf6d7a] connected with secret 1713201304721_956
                2024-04-15 19:15:04.724  - info: mqtt.0 (50645) Client [esp8266-cf6d7a] Received pubrec on esp8266-cf6d7a for unknown messageId 1
                2024-04-15 19:15:32.770  - warn: mqtt.0 (50645) Client [esp8266-cf6d7a] Message 1 deleted after 11 retries
                2024-04-15 19:15:40.772  - warn: mqtt.0 (50645) Client [esp8266-cf6d7a] Message 1 deleted after 11 retries
                2024-04-15 19:15:44.773  - warn: mqtt.0 (50645) Client [esp8266-cf6d7a] Message 1 deleted after 11 retries
                2024-04-15 19:15:45.815  - info: mqtt.0 (50645) Client [esp8266-cf6d7a] connection closed: closed
                2024-04-15 19:15:47.822  - info: mqtt.0 (50645) Client [esp8266-cf6d7a] connected with secret 1713201347821_3327
                2024-04-15 19:15:47.824  - info: mqtt.0 (50645) Client [esp8266-cf6d7a] Received pubrec on esp8266-cf6d7a for unknown messageId 1
                Thomas BraunT MartinPM 2 Antworten Letzte Antwort
                • MartinPM MartinP
                  Skript v.2023-10-10
                  *** BASE SYSTEM ***
                    Virtualization: lxc
                  Docker          : false
                  Kernel          : x86_64
                  Userland        : amd64
                  CPU threads:
                                   RTC time: n/a
                            RTC in local TZ: no
                  martin
                  /home/martin
                  X-Server:       false
                  Desktop:
                  Terminal:
                  *** MEMORY ***
                  *** FILESYSTEM ***
                  /var:
                  2.2G    /var/
                  1.2G    /var/lib
                  USB-Devices by-id:
                  /usr/bin/npm            10.5.0
                  /usr/bin/npx            10.5.0
                  nodejs:
                    Version table:
                       18.13.0+dfsg1-1 500
                  Errors in npm tree:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  admin:          6.13.16
                  javascript:     7.8.0
                  Adapter State
                  + instance is alive
                  Objects and States
                  Objects:        1561
                  States:         1208
                  Pending Updates: 0
                  @martinp
                  Das führe ich auf den Betrieb im LXC zurück.
                  • MartinPM MartinP
                    Skript v.2023-10-10
                    *** BASE SYSTEM ***
                      Virtualization: lxc
                    Docker          : false
                    Kernel          : x86_64
                    Userland        : amd64
                    CPU threads:
                                     RTC time: n/a
                              RTC in local TZ: no
                    martin
                    /home/martin
                    X-Server:       false
                    Desktop:
                    Terminal:
                    *** MEMORY ***
                    *** FILESYSTEM ***
                    /var:
                    2.2G    /var/
                    1.2G    /var/lib
                    USB-Devices by-id:
                    /usr/bin/npm            10.5.0
                    /usr/bin/npx            10.5.0
                    nodejs:
                      Version table:
                         18.13.0+dfsg1-1 500
                    Errors in npm tree:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    admin:          6.13.16
                    javascript:     7.8.0
                    Adapter State
                    + instance is alive
                    Objects and States
                    Objects:        1561
                    States:         1208
                    Pending Updates: 0
                    MartinPM Online
                    MartinPM Online
                    MartinP
                    schon ein
                    "ls /proc/cpuinfo" meldet dieses "Transport endpoint is not connected"
                    Starte den Container mal neu ...
                    EDIT Nach dem Neustart funzt es wieder
                    Auch die Übersichtsseite sieht gut aus ...
                    • MartinPM MartinP
                      schon ein
                      @martinp sagte in SNMP Adapter Update startet nicht:
                      Und den Host...
                      Laufen da mehrere Container? Schaut für mich aus wie 'Kampf um die gleichen Ressourcen'.
                        Und den Host...
                        MartinPM Online
                        MartinPM Online
                        MartinP
                        @thomas-braun Sieht erstmal unauffällig aus, PVE Speicherauslastung bei ca 4/8 GByte, CPU auch nicht am Anschlag...
                        Mal eine Nacht nicht an den Knöpfen drehen, und schauen, ob es morgen immer noch funktioniert ...
                        • MartinPM MartinP
                          MartinPM Online
                          MartinPM Online
                          MartinP
                          Bis jetzt funktioniert der LXC Container von iobroker tadellos.
                          Ein zweiter Container, in dem ich weitere Spielereien betreibe, scheint auch das "Transport endpoint is not connected" Problem zu haben.
                          Kriegt jetzt auch einen Neustart ... done, Probleme behoben.
                          Scheint dies zu sein:
                          https://discuss.linuxcontainers.org/t/top-failed-proc-stat-open-transport-endpoint-is-not-connected/13630
