  4. NodeRed fkt. nicht nach Node.js Update auf 18.20.2
    1.0k
    6.1k
49 Beiträge 11 Kommentatoren 6.0k Aufrufe 10 Beobachtet
  • Marc BergM Marc Berg
    @thomas-braun sagte in NodeRed fkt. nicht nach Node.js Update auf 18.20.2:
    iob update node-red@5.2.0
    Computer sagt: Nö!
    iobroker@iobroker:~$ iob upgrade node-red@5.2.0
    Would you like to reinstall version 5.2.0 of node-red now? [(y)es, (n)o]: y
    Update node-red from @5.2.0 to @5.2.0
    host.iobroker Adapter "system.adapter.node-red.0" is stopped.
    NPM version: 10.5.2
    Installing iobroker.node-red@5.2.0... (System call)
    up to date in 3s
    109 packages are looking for funding
      run `npm fund` for details
    upload [13] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/de/translations.json i18n/de/translations.json application/json
    upload [12] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/en/translations.json i18n/en/translations.json application/json
    upload [11] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/es/translations.json i18n/es/translations.json application/json
    upload [10] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
    upload [9] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/it/translations.json i18n/it/translations.json application/json
    upload [8] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
    upload [7] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    upload [6] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
    upload [5] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
    upload [4] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
    upload [3] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
    upload [2] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/jsonConfig.json jsonConfig.json application/json
    upload [1] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/node-red.png node-red.png image/png
    upload [0] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/words.js words.js application/javascript
    host.iobroker Adapter "system.adapter.node-red.0" is started
    iobroker@iobroker:~$ npm ls node-red
    iobroker.inst@3.0.0 /opt/iobroker
    └─┬ iobroker.node-red@5.2.0
      └── node-red@3.1.5
    @marc-berg sagte in NodeRed fkt. nicht nach Node.js Update auf 18.20.2:
    Du stehst aber auch nicht im Installationsverzeichnis vom ioBroker sondern in dessen home.
    cd /opt/iobroker
    npm ls node-red
    Es sei denn, du hast das bei der Installation auf ~ umgebogen.
      cd /opt/iobroker
      npm ls node-red
      Marc BergM Offline
      Marc BergM Offline
      Marc Berg
      Zumindest im Container ist das home Verzeichnis des Users "iobroker" = /opt/iobroker. Nichts umgebogen.
        Ist mir neu. Wird im iob diag nämlich auch nicht berücksichtigt und das funktioniert da mit cwd /opt/iobroker
          Marc BergM Offline
          Marc BergM Offline
          Marc Berg
          Ist mir neu.
          Steht aber so im Dockerfile
              # Setting up iobroker-user
              && chsh -s /bin/bash iobroker \
              && usermod --home /opt/iobroker iobroker \
              && usermod -u 1000 iobroker \
              && groupmod -g 1000 iobroker \
              && chown root:iobroker /usr/sbin/gosu \
            Ist mir neu.
            @marc-berg
            Ach, docker? Die Dinger interessieren mich nicht.
            Bei LXCs hast du aber definitv /opt/iobroker als Installationsverzeichnis als Default.
              @marc-berg
              Marc BergM Offline
              Marc BergM Offline
              Marc Berg
              Welche Relevanz hat das jetzt gerade für das aktuelle Problem? Unter einer VM habe ich das gleiche Verhalten, dass ich Node-Red nicht auf die 3.19 gehoben bekomme. Es sei denn, ich deinstalliere komplett.
                nur dass Thomas sichergestellt haben möchte, dass der Versuch korrekt gelaufen ist, und das frustrane Ergebnis nicht aufgrund falscher Durchführung existiert
                  Nur insofern, dass ich in Unkenntnis der Docker-Situation davon ausgehen muss, dass ~ nach /home/USER führt und nicht nach /opt/iobroker.
                    mcm1957M Offline
                    mcm1957M Offline
                    mcm1957
                    Ich habe das Thema REINSTALLATION vor Kurzem getestet. Und nein, node / iobroker reinstalliert definitiv zumindest den Adapter nicht nochmals , wenn schon was in der selben Version installiert ist.
                    Siehe: https://github.com/ioBroker/ioBroker.js-controller/issues/2667
                    Ob dependencies aktualisiert werden hab ich da nicht getestet.
                    Support Repositoryverwaltung.
                    LESEN - gute Forenbeitrage
                    • mcm1957M mcm1957
                      @mcm57 sagte in NodeRed fkt. nicht nach Node.js Update auf 18.20.2:
                      Werden sie. Zumindest auf meinem System...
                      echad@chet:/opt/iobroker $ npm ls node-red
                      `-- iobroker.node-red@5.2.0
                        `-- node-red@3.1.2
                      echad@chet:/opt/iobroker $ iob upgrade node-red@5.2.0
                      host.chet Adapter "system.adapter.node-red.0" is stopped.
                      NPM version: 10.5.0
                      removed 722 packages, and changed 13 packages in 13s
                      143 packages are looking for funding
                      host.chet Adapter "system.adapter.node-red.0" is started
                        `-- node-red@3.1.9
                          `-- node-red@3.1.2
                        NPM version: 10.5.0
                          `-- node-red@3.1.9
                        mcm1957M Offline
                        mcm1957M Offline
                        mcm1957
                        OK danke,
                        Dann optimiert node nur die Installation identer Versionen weg.
                        Hintergrund (bei mir):
                        Nach ein wenig direkter Pfusch in den Scripts wg. Debugging wollte ich alle Datein wieder auf den offiziellen Stand bringen - daher reinstallationd erselben Versione - neda, das geht so nicht :-(
                        • mcm1957M mcm1957
                          OK danke,
                          haus-automatisierungH Offline
                          @mcm57 Ne, dann wird ja auch nix gemacht, weil npm denkt es ist immer alles so wie installiert. Es wird ja nicht jede Datei geprüft (ob die zur noch Version passt).
                          📚 Meine Dokumentation
                            mcm1957M Offline
                            mcm1957M Offline
                            mcm1957
                            @haus-automatisierung said in NodeRed fkt. nicht nach Node.js Update auf 18.20.2:
                            Ja - das weiß ich jetzt auch. Nur versteh zumindest ich unter REINSTALLATION was anderes. Reinstallation bedeutet für mich, dass der Stand wie nach einer Installation hergestellt wird - zumindest was Code & Libraries betrifft - nicht den Datenbestand. Daher auch das Issue. Minimal ist der Text irreführend. Aber es spricht m.E. auch nichts dagegen npm deinstall und install zu machen und damit wirklich alles zu erneuern. Derzeit geht das nur über downgrade / upgrade oder manuell mit npm. Beides eindeutig zweite Wahl Lösungen.
                            • apollon77A Offline
                              Was npm (nicht iobroker!!) bei einem reinstall tut weiss man nie so genau. Das Paket was man reinstalliert - wenn gleiche version - das fasst er denke nicht an. Was npm mit Sub Deps machen ... keine Ahnung und gefühlt Sonnenfleckenabhängig. Also am besten reinstall ...
                              • apollon77A apollon77
                                mcm1957M Offline
                                mcm1957M Offline
                                mcm1957
                                @apollon77
                                iobroker reinstall macht derzeit noch ein npm i reinstall ...
                                Aber ich habe schon ein commit gesehen dass da in Zukunft ein echtes uninstall / reinstall erfolgen sollte.
                                • mcm1957M mcm1957
                                  @apollon77
                                  mcm1957M Offline
                                  mcm1957M Offline
                                  mcm1957
                                  Und noch was - keine Ahnung ob das auch ioBroker / node-red betrifft:
                                  https://github.com/node-red/node-red/pull/4652
                                  Ein Windows security Fix hat node-red auf windows getroffen. Wurde bereits gefixed.
                                  U 1 Antwort Letzte Antwort
                                  • mcm1957M mcm1957
                                    U Offline
                                    U Offline
                                    undeat
                                    @mcm57 Ich habe das gleiche Problem. Der Telegram Adapter und der vom Saugroboter haben mich auf node 18.20 gezwungen aber jetzt geht node red nicht mehr. Der Fix für Node Red sollte ja da sein, aber wie bekomme ich den in das Node Red vom Iobroker? Ein Update für den Adapter gibt es noch nicht, auch nicht als Beta.
                                    • U undeat
                                      mcm1957M Offline
                                      mcm1957M Offline
                                      mcm1957
                                      @undeat
                                      Das MS induzierte Problem hat eigentlich nichts mit nodeJs x zu tun.
                                      Bitte gib mal an
                                      -) welche Versionen von Adapter, js-conttrolelr und node nun bei dir aktiv sind
                                      -) welche Fehlermeldung du nun hast (Kopie vom Log)
                                      • mcm1957M mcm1957
                                        @undeat
                                        Bitte gib mal an
                                        U Offline
                                        U Offline
                                        undeat
                                        @mcm57
                                        Win11
                                        Node.js 18.20.2
                                        node-red Adapter 5.2.0
                                        NPM 10.5.0
                                        Node-RED: 20 Apr 18:32:29 - [error] Error: spawn EINVAL at ChildProcess.spawn (node:internal/child_process:414:11) at spawn (node:child_process:761:9) at Object.execFile (node:child_process:351:17) at G:\SmartHome\node_modules@node-red\registry\lib\installer.js:581:27 at new Promise (<anonymous>) at Object.checkPrereq (G:\SmartHome\node_modules@node-red\registry\lib\installer.js:580:16) at Object.load (G:\SmartHome\node_modules@node-red\registry\lib\index.js:59:22) at G:\SmartHome\node_modules@node-red\runtime\lib\index.js:162:29
                                        Ich habe es selbst hin bekommen.
                                        Ich habe die node-red 3.1.9.zip herunter geladen und die beiden Ordner, die da drin sind ("node-red" und "@node-red") in den Ordner "G:\SmartHome\node_modules" kopiert. Nun läuft es wieder
                                          naja wenns eine node-red Version gibt die das fixt dann GitHub issue anlegen das wir eine node-red Adapterversion veröffentlichen die dazu passt ...
