  4. iobroker exit 25 bei Adapter-Update
    1.0k
    6.1k
113 Beiträge 8 Kommentatoren 19.1k Aufrufe 7 Beobachtet
    @joe550
    Zeig mal bitte die Summary von
    iob diag
    Joe550
    schrieb am zuletzt editiert von Joe550
    @thomas-braun said in iobroker exit 25 bei Adapter-Update:
    @joe550
    iob diag
    			v.2023-10-10
     Static hostname: XXXXXXXXXX
           Icon name: computer-desktop
             Chassis: desktop
    Operating System: Ubuntu 22.04.4 LTS
              Kernel: Linux 5.15.0-101-generic
        Architecture: x86-64
     Hardware Vendor: Intel Corporation
      Hardware Model: NUC6CAYH
    Installation: 		native
    Kernel: 		x86_64
    Userland: 		amd64
    Timezone: 		Europe/Berlin (CEST, +0200)
    User-ID: 		1000
    X-Server: 		false
    Boot Target: 		graphical.target
    Pending OS-Updates: 	0
    Pending iob updates: 	0
    Nodejs-Installation: 	/usr/bin/nodejs 	v18.20.0
    			/usr/bin/node 		v18.20.0
    			/usr/bin/npm 		10.5.0
    			/usr/bin/npx 		10.5.0
    			/usr/bin/corepack 	0.25.2
    Recommended versions are nodejs 18.20.0 and npm 10.5.0
    MEMORY:
    Mem:            7.8G        3.9G        433M         43M        3.5G        3.5G
    Swap:           2.0G        251M        1.8G
    Total:          9.8G        4.1G        2.2G
    Active iob-Instances: 	24
    Active repo(s): stable
    ioBroker Core: 		js-controller 		5.0.19
    			admin 			6.13.16
    ioBroker Status: 	iobroker is running on this host.
    Objects type: jsonl
    States  type: jsonl
    + system.adapter.admin.0                  : admin                 : smarthome                                -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
    + system.adapter.web.0                    : web                   : smarthome                                -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    Objects: 		12707
    States: 		11195
    Size of iob-Database:
    51M	/opt/iobroker/iobroker-data/objects.jsonl
    12M	/opt/iobroker/iobroker-data/objects.json.migrated
    12M	/opt/iobroker/iobroker-data/objects.json.bak.migrated
    0	/opt/iobroker/iobroker-data/objects.json.broken
    20M	/opt/iobroker/iobroker-data/states.jsonl
    2.2M	/opt/iobroker/iobroker-data/states.json.migrated
    2.2M	/opt/iobroker/iobroker-data/states.json.bak.migrated
    0	/opt/iobroker/iobroker-data/states.json.broken
      @siggi0904 sagte in iobroker exit 25 bei Adapter-Update:
      ohne Angabe einer Version?
      Ohne Angabe einer Version wird die empfohlene Version installiert. Heute also die 18.20.0.
      Siggi0904S Offline
      Siggi0904S Offline
      Siggi0904
      #66
      @thomas-braun bei mir kommt bei iob nodejs-update folgender Fehler:
      mario@iobroker:/opt/iobroker$ iob nodejs-update
      iobroker nodejs-update [<major-version>]
      Upgrade the Node.JS installation to the current LTS
      Options:
        --help  Show help  [boolean]
      Ansonsten lief die Installation der neuen mihome-vacuum wohl ohne Probleme.
      Beim Aufruf von npm ls xmlbuilder aber da habe ich im GitHub ein Feature Request für @haus-automatisierung aufgemacht.
      mario@iobroker:/opt/iobroker$ npm ls xmlbuilder
      npm ERR! code ELSPROBLEMS
      npm ERR! invalid: xmlbuilder@0.4.2 /opt/iobroker/node_modules/xmlbuilder
      iobroker.inst@2.0.3 /opt/iobroker
      ├─┬ iobroker.hm-rega@4.0.0
      │ └─┬ xml2js@0.6.2
      │   └── xmlbuilder@11.0.1
      ├─┬ iobroker.hm-rpc@1.16.0
      │ └─┬ homematic-xmlrpc@1.0.2
      │   └── xmlbuilder@0.4.2 invalid: "https://github.com/hobbyquaker/xmlbuilder-js/tarball/29fe5030dc6852007dc8d1bfd5109d75f8da58d5" from node_modules/homematic-xmlrpc
      ├─┬ iobroker.shelly@6.8.0
      │ └── xmlbuilder@15.1.1
      └─┬ iobroker.tr-064@4.2.18
        └─┬ xml2js@0.4.23
      • Siggi0904S Siggi0904
        Options:
        │ └─┬ xml2js@0.6.2
          └─┬ xml2js@0.4.23
        #67
        @siggi0904
        Dann solltest du da mal den
        iob stop
        iob fix
        iob start
        drüber jagen. Dann kennt deine Installation auch alle aktuellen Kommandos wie iobroker nodejs-update.
        Siggi0904S 1 Antwort Letzte Antwort
          @siggi0904
          iob stop
          iob fix
          iob start
          Siggi0904S Offline
          Siggi0904S Offline
          Siggi0904
          #68
          @thomas-braun oh man, nun kommt der js-controller nicht mehr hoch.
          2024-04-03 20:30:31.554 - error: host.iobroker Caught by controller[0]: /opt/iobroker/node_modules/iobroker.javascript/node_modules/sshpk/lib/formats/x509.js:56
          2024-04-03 20:30:31.554 - error: host.iobroker Caught by controller[0]: return (asn1.Ber.Context | asn1.Ber.Constructor | i);
          2024-04-03 20:30:31.554 - error: host.iobroker Caught by controller[0]: ^
          2024-04-03 20:30:31.554 - error: host.iobroker Caught by controller[0]: TypeError: Cannot read properties of undefined (reading 'Context')
          2024-04-03 20:30:31.554 - error: host.iobroker Caught by controller[0]: at Local (/opt/iobroker/node_modules/iobroker.javascript/node_modules/sshpk/lib/formats/x509.js:56:19)
          2024-04-03 20:30:31.554 - error: host.iobroker Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.javascript/node_modules/sshpk/lib/formats/x509.js:216:13)
          2024-04-03 20:30:31.554 - error: host.iobroker Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1364:14)
          2024-04-03 20:30:31.555 - error: host.iobroker Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
          2024-04-03 20:30:31.555 - error: host.iobroker Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1203:32)
          2024-04-03 20:30:31.555 - error: host.iobroker Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1019:12)
          2024-04-03 20:30:31.555 - error: host.iobroker Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1231:19)
          2024-04-03 20:30:31.555 - error: host.iobroker Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
          2024-04-03 20:30:31.561 - error: host.iobroker Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.javascript/node_modules/sshpk/lib/certificate.js:20:19)
          2024-04-03 20:30:31.561 - error: host.iobroker Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1364:14)
          2024-04-03 20:30:31.561 - error: host.iobroker Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
          2024-04-03 20:30:31.561 - error: host.iobroker Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1203:32)
          2024-04-03 20:30:31.561 - error: host.iobroker Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1019:12)
          2024-04-03 20:30:31.561 - error: host.iobroker Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1231:19)
          2024-04-03 20:30:31.561 - error: host.iobroker Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
          2024-04-03 20:30:31.561 - error: host.iobroker Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.javascript/node_modules/sshpk/lib/fingerprint.js:12:19)
          2024-04-03 20:30:31.562 - error: host.iobroker Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1364:14)
          2024-04-03 20:30:31.562 - error: host.iobroker Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
          2024-04-03 20:30:31.562 - error: host.iobroker Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1203:32)
          2024-04-03 20:30:31.562 - error: host.iobroker Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1019:12)
          2024-04-03 20:30:31.562 - error: host.iobroker Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1231:19)
          2024-04-03 20:30:31.562 - error: host.iobroker Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
          2024-04-03 20:30:31.562 - error: host.iobroker Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.javascript/node_modules/sshpk/lib/key.js:8:19)
          2024-04-03 20:30:31.562 - error: host.iobroker Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.javascript/node_modules/sshpk/lib/index.js:3:11)
          2024-04-03 20:30:31.563 - error: host.iobroker Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1231:19)
          2024-04-03 20:30:31.563 - error: host.iobroker Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
          2024-04-03 20:30:31.563 - error: host.iobroker Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.javascript/node_modules/http-signature/lib/utils.js:4:13)
          2024-04-03 20:30:31.563 - error: host.iobroker Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1364:14)
          2024-04-03 20:30:31.563 - error: host.iobroker Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
          2024-04-03 20:30:31.563 - error: host.iobroker Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1203:32)
          2024-04-03 20:30:31.563 - error: host.iobroker Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1019:12)
          2024-04-03 20:30:31.563 - error: host.iobroker Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.javascript/node_modules/http-signature/lib/parser.js:5:13)
          2024-04-03 20:30:31.564 - error: host.iobroker Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
          2024-04-03 20:30:31.564 - error: host.iobroker Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1203:32)
          2024-04-03 20:30:31.564 - error: host.iobroker Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1019:12)
          2024-04-03 20:30:31.564 - error: host.iobroker Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1231:19)
          2024-04-03 20:30:31.564 - error: host.iobroker Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
          2024-04-03 20:30:31.564 - error: host.iobroker Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.javascript/node_modules/http-signature/lib/index.js:3:14)
          2024-04-03 20:30:31.564 - error: host.iobroker Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1364:14)
          2024-04-03 20:30:31.564 - error: host.iobroker Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:11:21)
          2024-04-03 20:30:31.565 - error: host.iobroker Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1364:14)
          2024-04-03 20:30:31.565 - error: host.iobroker Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
          2024-04-03 20:30:31.565 - error: host.iobroker Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1203:32)
          2024-04-03 20:30:31.565 - error: host.iobroker Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1019:12)
          2024-04-03 20:30:31.565 - error: host.iobroker Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1231:19)
          2024-04-03 20:30:31.565 - error: host.iobroker Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
          2024-04-03 20:30:31.565 - error: host.iobroker Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/index.js:143:19)
          2024-04-03 20:30:31.571 - error: host.iobroker Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1203:32)
          2024-04-03 20:30:31.571 - error: host.iobroker Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1019:12)
          2024-04-03 20:30:31.572 - error: host.iobroker Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1231:19)
          2024-04-03 20:30:31.572 - error: host.iobroker Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
          2024-04-03 20:30:31.572 - error: host.iobroker Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.javascript/lib/request.js:5:18)
          2024-04-03 20:30:31.572 - error: host.iobroker Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1364:14)
          2024-04-03 20:30:31.572 - error: host.iobroker Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
          2024-04-03 20:30:31.572 - error: host.iobroker Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1203:32)
          2024-04-03 20:30:31.572 - error: host.iobroker Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1019:12)
          2024-04-03 20:30:31.572 - error: host.iobroker Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.javascript/main.js:44:23)
          2024-04-03 20:30:31.572 - error: host.iobroker Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
          2024-04-03 20:30:31.572 - error: host.iobroker Caught by controller[0]: at node:internal/main/run_main_module:28:49
          2024-04-03 20:30:31.572 - error: host.iobroker Caught by controller[1]: Node.js v18.20.1
          2024-04-03 20:30:31.572 - error: host.iobroker instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          Ich brauch deine Hilfe. :-(
          Thomas BraunT mcm1957M 2 Antworten Letzte Antwort
            #69
            @siggi0904
            Was haste gemacht?
            • Siggi0904S Offline
              Siggi0904S Offline
              Siggi0904
              #70
              @thomas-braun nur das System aktualisiert und dann wollte ich die fehlende js für den node-mihome einfügen und den js-controller danach neustarten
                #71
                Da war mit Sicherheit nodejs mit dabei. Den iobroker dafür herunter gefahren?
                  Siggi0904S Offline
                  Siggi0904S Offline
                  Siggi0904
                  #72
                  @thomas-braun ja. das node-js update lief davor.
                    mcm1957M Online
                    mcm1957M Online
                    mcm1957
                    #73
                    @siggi0904 said in iobroker exit 25 bei Adapter-Update:
                    Mal die Panictaste ausschakten.
                    Der js-controller hat keine Proble. Der meldet nur, das der JAVASCRIPT Adapter ein Problem hat,
                    Support Repositoryverwaltung.
                    LESEN - gute Forenbeitrage
                      #74
                      @siggi0904
                      Gut, nodejs-update stoppt den iobroker.
                      iob stop
                      iob fix
                      sudo reboot
                      führt zu?
                        Siggi0904S Offline
                        Siggi0904
                        #75
                        @thomas-braun Fehler bleibt gleich. Alle Adapter starten, nur der Javascript startet nicht.
                          mcm1957M Online
                          mcm1957M Online
                          mcm1957
                          #76
                          @siggi0904
                          Welche Version des javascript Adapters ist installiert?
                          • mcm1957M mcm1957
                            @siggi0904
                            Siggi0904S Offline
                            Siggi0904S Offline
                            Siggi0904
                            #77
                            @mcm57 v7.8.0
                              @mcm57 v7.8.0
                              #78
                              @siggi0904
                              iob update
                              iob upgrade javascript@7.8.0
                              mcm1957M Siggi0904S 2 Antworten Letzte Antwort
                                @siggi0904
                                iob update
                                mcm1957M Online
                                mcm1957M Online
                                mcm1957
                                #79
                                7.8.0 ist ok / stable.
                                7.9.x ff sollte übersprungen werden bzw. als mit breaking changes versehen betrachtet werden (Änderungen an Zugriffsrechten ins Filesystem, Entfernung von request, ...) . Nächste stable wird 8.x.x werden soweit ich weiss.
                                Klärt aber alles nicht dein Problem
                                  @siggi0904
                                  iob update
                                  Siggi0904S Offline
                                  Siggi0904S Offline
                                  Siggi0904
                                  #80
                                  @thomas-braun yeah, das hat geholfen. Javascript ist wieder da.
                                  Da hat sich wohl jemand verschluckt.
                                    #81
                                    @siggi0904
                                    Zeig mal das Gesamtkunstwerk...
                                    iob diag
                                    in der Langfassung.
                                      @siggi0904
                                      iob diag
                                      in der Langfassung.
                                      Siggi0904S Offline
                                      Siggi0904S Offline
                                      Siggi0904
                                      #82
                                      @thomas-braun sollst du bekommen:
                                      Skript v.2023-10-10
                                      *** BASE SYSTEM ***
                                       Static hostname: iobroker
                                             Icon name: computer-vm
                                               Chassis: vm 🖴
                                        Virtualization: kvm
                                                Kernel: Linux 6.1.0-18-amd64
                                       Hardware Vendor: QEMU
                                        Hardware Model: Standard PC _i440FX + PIIX, 1996_
                                      Firmware Version: rel-1.16.2-0-gea1b7a073390-prebuilt.qemu.org
                                      model name      : Common KVM processor
                                      Docker          : false
                                      Virtualization  : kvm
                                      Kernel          : x86_64
                                      Userland        : amd64
                                      Systemuptime and Load:
                                       21:21:58 up 34 min,  2 users,  load average: 0.18, 0.30, 0.43
                                      CPU threads: 2
                                      *** Time and Time Zones ***
                                                     Local time: Wed 2024-04-03 21:21:58 CEST
                                                 Universal time: Wed 2024-04-03 19:21:58 UTC
                                                       RTC time: Wed 2024-04-03 19:21:58
                                                    NTP service: active
                                                RTC in local TZ: no
                                      *** User and Groups ***
                                      mario
                                      /home/mario
                                      mario adm sudo iobroker
                                      *** X-Server-Setup ***
                                      X-Server:       false
                                      Desktop:
                                      Terminal:       tty
                                      *** MEMORY ***
                                      Mem:            4.1G        2.8G        607M        499K        960M        1.3G
                                      Swap:           4.3G         59M        4.2G
                                      Total:          8.4G        2.9G        4.8G
                                               3915 M total memory
                                               2664 M used memory
                                                480 M active memory
                                               2539 M inactive memory
                                                579 M free memory
                                                 91 M buffer memory
                                                824 M swap cache
                                               4092 M total swap
                                                 56 M used swap
                                               4036 M free swap
                                      *** FAILED SERVICES ***
                                      0 loaded units listed.
                                      *** FILESYSTEM ***
                                      udev           devtmpfs  1.9G     0  1.9G   0% /dev
                                      tmpfs          tmpfs     392M  552K  392M   1% /run
                                      /dev/sda1      ext4       45G  9.7G   34G  23% /
                                      tmpfs          tmpfs     2.0G     0  2.0G   0% /dev/shm
                                      tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
                                      tmpfs          tmpfs     392M     0  392M   0% /run/user/1001
                                      [Wed Apr  3 20:47:27 2024] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
                                      [Wed Apr  3 20:47:28 2024] EXT4-fs (sda1): re-mounted. Quota mode: none.
                                      TARGET SOURCE    FSTYPE OPTIONS
                                      /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
                                      /var:
                                      3.7G    /var/
                                      3.5G    /var/log
                                      3.4G    /var/log/journal/06882d2afcc64e848dd2d19ddcda7ca8
                                      192M    /var/lib
                                      Archived and active journals take up 3.3G in the file system.
                                      /opt/iobroker/backups:
                                      1.4M    /opt/iobroker/backups/
                                      /opt/iobroker/iobroker-data:
                                      435M    /opt/iobroker/iobroker-data/
                                      253M    /opt/iobroker/iobroker-data/files
                                      121M    /opt/iobroker/iobroker-data/backup-objects
                                      58M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js
                                      33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
                                      30M     /opt/iobroker/iobroker-data/objects.jsonl
                                      22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
                                      9.7M    /opt/iobroker/iobroker-data/states.jsonl
                                      9.6M    /opt/iobroker/iobroker-data/objects.json.migrated
                                      USB-Devices by-id:
                                      /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2139836-if00
                                      *** NodeJS-Installation ***
                                      /usr/bin/nodejs         v18.20.1
                                      /usr/bin/node           v18.20.1
                                      /usr/bin/npm            10.5.0
                                      /usr/bin/npx            10.5.0
                                      nodejs:
                                        Installed: 18.20.1-1nodesource1
                                        Candidate: 18.20.1-1nodesource1
                                        Version table:
                                       *** 18.20.1-1nodesource1 1001
                                              500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                                           18.20.0-1nodesource1 1001
                                           18.19.1-1nodesource1 1001
                                           18.19.0+dfsg-6~deb12u1 500
                                              500 https://deb.debian.org/debian-security bookworm-security/main amd64 Packages
                                           18.19.0-1nodesource1 1001
                                           18.18.2-1nodesource1 1001
                                           18.18.1-1nodesource1 1001
                                           18.18.0-1nodesource1 1001
                                           18.17.1-1nodesource1 1001
                                           18.17.0-1nodesource1 1001
                                           18.16.1-1nodesource1 1001
                                           18.16.0-1nodesource1 1001
                                           18.15.0-1nodesource1 1001
                                           18.14.2-1nodesource1 1001
                                           18.14.1-1nodesource1 1001
                                           18.14.0-1nodesource1 1001
                                           18.13.0+dfsg1-1 500
                                              500 http://deb.debian.org/debian bookworm/main amd64 Packages
                                           18.13.0-1nodesource1 1001
                                           18.12.0-1nodesource1 1001
                                           18.11.0-1nodesource1 1001
                                           18.10.0-1nodesource1 1001
                                           18.9.1-1nodesource1 1001
                                           18.9.0-1nodesource1 1001
                                           18.8.0-1nodesource1 1001
                                           18.7.0-1nodesource1 1001
                                           18.6.0-1nodesource1 1001
                                           18.5.0-1nodesource1 1001
                                           18.4.0-1nodesource1 1001
                                           18.3.0-1nodesource1 1001
                                           18.2.0-1nodesource1 1001
                                           18.1.0-1nodesource1 1001
                                           18.0.0-1nodesource1 1001
                                      No problems detected
                                      Errors in npm tree:
                                      npm ERR! extraneous: @types/caseless@0.12.5 /opt/iobroker/node_modules/@types/caseless
                                      npm ERR! extraneous: @types/request@2.48.12 /opt/iobroker/node_modules/@types/request
                                      npm ERR! extraneous: @types/tough-cookie@4.0.5 /opt/iobroker/node_modules/@types/tough-cookie
                                      npm ERR! extraneous: coffeescript@2.7.0 /opt/iobroker/node_modules/coffeescript
                                      npm ERR! extraneous: jsonata@2.0.4 /opt/iobroker/node_modules/jsonata
                                      npm ERR! extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
                                      npm ERR! extraneous: picocolors@1.0.0 /opt/iobroker/node_modules/picocolors
                                      npm ERR! extraneous: typescript@5.3.3 /opt/iobroker/node_modules/typescript
                                      npm ERR! extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
                                      npm ERR! extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
                                      npm ERR! extraneous: form-data@2.5.1 /opt/iobroker/node_modules/@types/request/node_modules/form-data
                                      npm ERR! extraneous: debug@4.3.4 /opt/iobroker/node_modules/virtual-tsc/node_modules/debug
                                      npm ERR! extraneous: ms@2.1.2 /opt/iobroker/node_modules/virtual-tsc/node_modules/ms
                                      npm ERR! A complete log of this run can be found in: /home/mario/.npm/_logs/2024-04-03T19_22_04_172Z-debug-0.log
                                      *** ioBroker-Installation ***
                                      ioBroker Status
                                      Objects type: jsonl
                                      States  type: jsonl
                                      Core adapters versions
                                      js-controller:  5.0.19
                                      admin:          6.13.16
                                      javascript:     7.8.0
                                      Adapters from github:   0
                                      Adapter State
                                      + system.adapter.alarm.0                  : alarm                 : iobroker                                 -  enabled
                                      + system.adapter.alexa-timer-vis.0        : alexa-timer-vis       : iobroker                                 -  enabled
                                      + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
                                      + system.adapter.awtrix-light.0           : awtrix-light          : iobroker                                 -  enabled
                                      + system.adapter.awtrix-light.1           : awtrix-light          : iobroker                                 -  enabled
                                      + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                                      + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
                                        system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
                                      + system.adapter.deconz.0                 : deconz                : iobroker                                 -  enabled
                                      + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                                        system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
                                      + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
                                        system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
                                        system.adapter.flot.0                   : flot                  : iobroker                                 -  enabled
                                      + system.adapter.heatingcontrol.0         : heatingcontrol        : iobroker                                 -  enabled
                                      + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
                                      + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                                      + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                                        system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                                        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
                                      + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
                                      + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                                      + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
                                        system.adapter.openweathermap.0         : openweathermap        : iobroker                                 -  enabled
                                      + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
                                      + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
                                      + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                                      + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                                      + system.adapter.sql.0                    : sql                   : iobroker                                 -  enabled, port: 3307
                                      + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
                                      + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
                                      + system.adapter.tr-064.1                 : tr-064                : iobroker                                 -  enabled
                                      + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
                                        system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                                      + instance is alive
                                      ioBroker-Repositories
                                      Installed ioBroker-Instances
                                      Used repository: stable
                                      Adapter    "admin"        : 6.13.16  , installed 6.13.16
                                      Adapter    "alarm"        : 3.6.0    , installed 3.6.0
                                      Adapter    "alexa-timer-vis": 0.3.0  , installed 0.3.0
                                      Adapter    "alexa2"       : 3.26.4   , installed 3.26.4
                                      Adapter    "awtrix-light" : 0.16.0   , installed 0.16.0
                                      Adapter    "backitup"     : 2.10.11  , installed 2.10.11
                                      Adapter    "daswetter"    : 3.1.13   , installed 3.1.13
                                      Adapter    "deconz"       : 1.4.0    , installed 1.4.0
                                      Adapter    "discovery"    : 4.4.0    , installed 4.4.0
                                      Adapter    "email"        : 1.2.2    , installed 1.2.2
                                      Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
                                      Adapter    "heatingcontrol": 2.12.5  , installed 2.12.5
                                      Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
                                      Adapter    "hm-rpc"       : 1.16.0   , installed 1.16.0
                                      Adapter    "ical"         : 1.14.3   , installed 1.14.3
                                      Adapter    "iot"          : 2.0.11   , installed 2.0.11
                                      Adapter    "javascript"   : 7.8.0    , installed 7.8.0
                                      Controller "js-controller": 5.0.19   , installed 5.0.19
                                      Adapter    "mihome-vacuum": 4.1.1    , installed 4.2.0
                                      Adapter    "openweathermap": 1.0.4   , installed 1.0.4
                                      Adapter    "shelly"       : 6.8.0    , installed 6.8.0
                                      Adapter    "socketio"     : 6.6.1    , installed 6.6.1
                                      Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
                                      Adapter    "trashschedule": 3.2.0    , installed 3.2.0
                                      Adapter    "vis"          : 1.5.4    , installed 1.5.4
                                      Adapter    "web"          : 6.2.3    , installed 6.2.3
                                      Adapter    "ws"           : 2.5.11   , installed 2.5.11
                                      Objects and States
                                      Objects:        11202
                                      States:         9365
                                      Hit:1 http://phoscon.de/apt/deconz bookworm InRelease
                                      Hit:2 https://deb.debian.org/debian-security bookworm-security InRelease
                                      Hit:3 http://deb.debian.org/debian bookworm InRelease
                                      Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
                                      Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
                                      Reading package lists...
                                      Pending Updates: 0
                                      *** Listening Ports ***
                                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       16341      443/iobroker.js-con
                                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       16349      443/iobroker.js-con
                                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15846      475/sshd: /usr/sbin
                                      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          13256      1/init
                                      tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       16050      437/deCONZ
                                      tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       16294      437/deCONZ
                                      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          16268      770/exim4
                                      tcp        0      0 192.168.178.64:2001     0.0.0.0:*               LISTEN      1000       16918      908/io.hm-rpc.1
                                      tcp        0      0 192.168.178.64:2010     0.0.0.0:*               LISTEN      1000       16864      893/io.hm-rpc.0
                                      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       18353      1026/io.sonoff.0
                                      tcp6       0      0 :::22                   :::*                    LISTEN      0          15863      475/sshd: /usr/sbin
                                      tcp6       0      0 :::111                  :::*                    LISTEN      0          13262      1/init
                                      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          16269      770/exim4
                                      tcp6       0      0 :::8082                 :::*                    LISTEN      1000       19722      1191/io.web.0
                                      tcp6       0      0 :::8081                 :::*                    LISTEN      1000       16491      797/io.admin.0
                                      udp        0      0 192.168.178.64:5353     0.0.0.0:*                           1000       18887      1057/io.tr-064.0
                                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           107        15766      430/avahi-daemon: r
                                      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       19228      1107/io.shelly.0
                                      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       19979      1243/io.deconz.0
                                      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       16330      437/deCONZ
                                      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15482      405/dhclient
                                      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          13259      1/init
                                      udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1000       19325      1139/io.mihome-vacu
                                      udp        0      0 0.0.0.0:59854           0.0.0.0:*                           107        15768      430/avahi-daemon: r
                                      udp        0      0 0.0.0.0:47686           0.0.0.0:*                           1000       41292      2805/io.javascript.
                                      udp6       0      0 :::5353                 :::*                                107        15767      430/avahi-daemon: r
                                      udp6       0      0 :::38572                :::*                                107        15769      430/avahi-daemon: r
                                      udp6       0      0 :::1900                 :::*                                1000       19981      1243/io.deconz.0
                                      udp6       0      0 :::1900                 :::*                                1000       19980      1243/io.deconz.0
                                      udp6       0      0 :::111                  :::*                                0          13265      1/init
                                      2024-04-03 21:10:00.036  - info: host.iobroker instance system.adapter.dwd.0 started with pid 2901
                                      2024-04-03 21:10:02.750  - info: dwd.0 (2901) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.20.1, js-controller: 5.0.19
                                      2024-04-03 21:10:05.230  - info: dwd.0 (2901) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                      2024-04-03 21:10:05.756  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                      2024-04-03 21:13:35.422  - info: admin.0 (797) ==> Connected system.user.admin from ::ffff:192.168.178.41
                                      2024-04-03 21:15:00.038  - info: javascript.0 (2805) script.js.Skripte.Wohnung.VerbrauchTasmota: Tasmota Verbrauch: Verbrauchswerte aktualisiert: 0 | Reboots korrigiert: 0 | Unveränderte Werte: 6
                                      2024-04-03 21:15:00.100  - info: host.iobroker instance system.adapter.dwd.0 started with pid 3532
                                      2024-04-03 21:15:00.109  - info: javascript.0 (2805) script.js.Skripte.Wohnung.VerbrauchShelly: Shelly Verbrauch: Verbrauchswerte aktualisiert: 1 | Reboots korrigiert: 0 | Unveränderte Werte: 0
                                      2024-04-03 21:15:00.150  - info: javascript.0 (2805) script.js.Skripte.Wohnzimmer.Luftqualität: Daten des Alexa-Luftqualitätsmonitors aktualisiert.
                                      2024-04-03 21:15:02.595  - info: dwd.0 (3532) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.20.1, js-controller: 5.0.19
                                      2024-04-03 21:15:04.109  - info: host.iobroker instance system.adapter.daswetter.0 started with pid 3548
                                      2024-04-03 21:15:05.029  - info: dwd.0 (3532) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                      2024-04-03 21:15:05.673  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                      2024-04-03 21:15:08.349  - info: daswetter.0 (3548) starting. Version 3.1.13 in /opt/iobroker/node_modules/iobroker.daswetter, node: v18.20.1, js-controller: 5.0.19
                                      2024-04-03 21:15:14.554  - info: daswetter.0 (3548) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
                                      2024-04-03 21:15:15.073  - info: daswetter.0 (3548) cleaned everything up...
                                      2024-04-03 21:15:15.086  - info: host.iobroker instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                      2024-04-03 21:16:13.897  - info: javascript.0 (2805) Stop script script.js.Skripte.Außen.CarportLichtMorgensEin
                                      2024-04-03 21:16:13.921  - info: javascript.0 (2805) Start javascript script.js.Skripte.Außen.CarportLichtMorgensEin
                                      2024-04-03 21:16:13.936  - info: javascript.0 (2805) script.js.Skripte.Außen.CarportLichtMorgensEin: registered 0 subscriptions, 2 schedules, 0 messages, 0 logs and 0 file subscriptions
                                      2024-04-03 21:16:33.064  - info: admin.0 (797) <== Disconnect system.user.admin from ::ffff:192.168.178.41 javascript
                                      2024-04-03 21:20:00.019  - info: host.iobroker instance system.adapter.dwd.0 started with pid 3775
                                      2024-04-03 21:20:02.273  - info: dwd.0 (3775) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.20.1, js-controller: 5.0.19
                                      2024-04-03 21:20:04.491  - info: dwd.0 (3775) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                      2024-04-03 21:20:05.019  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                      Der xmlbuilder Error sieht so aus:
                                      │ └─┬ xml2js@0.6.2
                                        └─┬ xml2js@0.4.23
                                      Das ist aber auch noch im aktuellen Code so alt.
                                      Da gibt es evtl. schon eine Klärung.
                                      Ansonsten nochmal großes Danke.
                                        Skript v.2023-10-10
                                        *** BASE SYSTEM ***
                                                 Chassis: vm 🖴
                                          Virtualization: kvm
                                        Docker          : false
                                        Kernel          : x86_64
                                        Userland        : amd64
                                        CPU threads: 2
                                                      NTP service: active
                                                  RTC in local TZ: no
                                        mario
                                        /home/mario
                                        X-Server:       false
                                        Desktop:
                                        Terminal:       tty
                                        *** MEMORY ***
                                        Swap:           4.3G         59M        4.2G
                                                 3915 M total memory
                                                 2664 M used memory
                                                  480 M active memory
                                                  579 M free memory
                                                   91 M buffer memory
                                                  824 M swap cache
                                                 4092 M total swap
                                                   56 M used swap
                                                 4036 M free swap
                                        *** FILESYSTEM ***
                                        /var:
                                        3.7G    /var/
                                        3.5G    /var/log
                                        192M    /var/lib
                                        USB-Devices by-id:
                                        /usr/bin/npm            10.5.0
                                        /usr/bin/npx            10.5.0
                                        nodejs:
                                          Version table:
                                             18.13.0+dfsg1-1 500
                                        Errors in npm tree:
                                        ioBroker Status
                                        Objects type: jsonl
                                        States  type: jsonl
                                        admin:          6.13.16
                                        javascript:     7.8.0
                                        Adapter State
                                        + instance is alive
                                        Objects and States
                                        Objects:        11202
                                        States:         9365
                                        Pending Updates: 0
                                        │ └─┬ xml2js@0.6.2
                                          └─┬ xml2js@0.4.23
                                        #83
                                        iob update
                                        iob upgrade hm-rpc@1.16.0
                                        Denn eigentlich will der "homematic-xmlrpc": "^1.0.2" haben und nicht den alten Kram.
                                        Edit: Falsch geschaut...
                                          iob update
                                          Siggi0904S Offline
                                          Siggi0904S Offline
                                          Siggi0904
                                          #84
                                          @thomas-braun ne, der will die alte Version. Steht in der https://github.com/ioBroker/ioBroker.hm-rpc/blob/master/package-lock.json ab Zeile 3761.
                                          Beim Fritzox-Adapter tr-061 ist das auch so alt.
