  4. Iobroker Absturz bei Zigbeeadapter mit Conbee2 einschalten
55 Beiträge 7 Kommentatoren 8.3k Aufrufe 5 Beobachtet
  • N NFTVirus
    @thomas-braun hier nochmal der letzte Absturz direkt beim hochfahren
    Mar 29 12:47:10 raspberrypi systemd-timesyncd[383]: Contacted time server [2606>
    Mar 29 12:47:10 raspberrypi systemd-timesyncd[383]: Initial clock synchronizati>
    Mar 29 12:47:12 raspberrypi systemd[1]: systemd-hostnamed.service: Deactivated >
    Mar 29 12:48:47 raspberrypi sudo[799]:       pi : TTY=pts/0 ; PWD=/home/pi ; US>
    Mar 29 12:48:47 raspberrypi sudo[799]: pam_unix(sudo:session): session opened f>
    Mar 29 12:48:57 raspberrypi sudo[799]: pam_unix(sudo:session): session closed f>
    Mar 29 12:49:00 raspberrypi sudo[1204]:       pi : TTY=pts/0 ; PWD=/home/pi ; U>
    Mar 29 12:49:00 raspberrypi sudo[1204]: pam_unix(sudo:session): session opened >
    Mar 29 12:49:00 raspberrypi sudo[1204]: pam_unix(sudo:session): session closed >
    Mar 29 12:49:00 raspberrypi sudo[1208]:       pi : TTY=pts/0 ; PWD=/home/pi ; U>
    Mar 29 12:49:00 raspberrypi sudo[1208]: pam_unix(sudo:session): session opened >
    Mar 29 12:49:00 raspberrypi sudo[1208]: pam_unix(sudo:session): session closed >
    Mar 29 12:49:00 raspberrypi sudo[1413]:       pi : TTY=pts/0 ; PWD=/home/pi ; U>
    Mar 29 12:49:00 raspberrypi sudo[1413]: pam_unix(sudo:session): session opened >
    Mar 29 12:49:00 raspberrypi sudo[1413]: pam_unix(sudo:session): session closed >
    Mar 29 12:49:00 raspberrypi sudo[1416]:       pi : TTY=pts/0 ; PWD=/home/pi ; U>
    Mar 29 12:49:00 raspberrypi sudo[1416]: pam_unix(sudo:session): session opened >
    Mar 29 12:49:00 raspberrypi sudo[1416]: pam_unix(sudo:session): session closed >
    Mar 29 12:49:00 raspberrypi sudo[1419]:       pi : TTY=pts/0 ; PWD=/home/pi ; U>
    Mar 29 12:49:00 raspberrypi sudo[1419]: pam_unix(sudo:session): session opened >
    Mar 29 12:49:00 raspberrypi sudo[1419]: pam_unix(sudo:session): session closed >
    Mar 29 12:49:00 raspberrypi sudo[1422]:       pi : TTY=pts/0 ; PWD=/home/pi ; U>
    Mar 29 12:49:00 raspberrypi sudo[1422]: pam_unix(sudo:session): session opened >
    lines 1-23...skipping...
    Mar 29 12:47:10 raspberrypi systemd-timesyncd[383]: Contacted time server [2606:4700:f1::123]:123 (2.debian.pool.ntp.org).
    Mar 29 12:47:10 raspberrypi systemd-timesyncd[383]: Initial clock synchronization to Fri 2024-03-29 12:47:10.351815 CET.
    Mar 29 12:47:12 raspberrypi systemd[1]: systemd-hostnamed.service: Deactivated successfully.
    Mar 29 12:48:47 raspberrypi sudo[799]:       pi : TTY=pts/0 ; PWD=/home/pi ; USER=root ; COMMAND=/usr/bin/apt-get update
    Mar 29 12:48:47 raspberrypi sudo[799]: pam_unix(sudo:session): session opened for user root(uid=0) by pi(uid=1000)
    Mar 29 12:48:57 raspberrypi sudo[799]: pam_unix(sudo:session): session closed for user root
    Mar 29 12:49:00 raspberrypi sudo[1204]:       pi : TTY=pts/0 ; PWD=/home/pi ; USER=root ; COMMAND=/usr/sbin/setcap cap_net_admin,cap_net_bind_service,cap_net_raw+eip /usr/bin/node
    Mar 29 12:49:00 raspberrypi sudo[1204]: pam_unix(sudo:session): session opened for user root(uid=0) by pi(uid=1000)
    Mar 29 12:49:00 raspberrypi sudo[1204]: pam_unix(sudo:session): session closed for user root
    Mar 29 12:49:00 raspberrypi sudo[1208]:       pi : TTY=pts/0 ; PWD=/home/pi ; USER=root ; COMMAND=/usr/sbin/usermod -a -G iobroker pi
    Mar 29 12:49:00 raspberrypi sudo[1208]: pam_unix(sudo:session): session opened for user root(uid=0) by pi(uid=1000)
    Mar 29 12:49:00 raspberrypi sudo[1208]: pam_unix(sudo:session): session closed for user root
    Mar 29 12:49:00 raspberrypi sudo[1413]:       pi : TTY=pts/0 ; PWD=/home/pi ; USER=root ; COMMAND=/usr/bin/rm -f /etc/sudoers.d/iobroker
    Mar 29 12:49:00 raspberrypi sudo[1413]: pam_unix(sudo:session): session opened for user root(uid=0) by pi(uid=1000)
    Mar 29 12:49:00 raspberrypi sudo[1413]: pam_unix(sudo:session): session closed for user root
    Mar 29 12:49:00 raspberrypi sudo[1416]:       pi : TTY=pts/0 ; PWD=/home/pi ; USER=root ; COMMAND=/usr/sbin/visudo -c -q -f /home/pi/temp_sudo_file
    Mar 29 12:49:00 raspberrypi sudo[1416]: pam_unix(sudo:session): session opened for user root(uid=0) by pi(uid=1000)
    Mar 29 12:49:00 raspberrypi sudo[1416]: pam_unix(sudo:session): session closed for user root
    Mar 29 12:49:00 raspberrypi sudo[1419]:       pi : TTY=pts/0 ; PWD=/home/pi ; USER=root ; COMMAND=/usr/bin/chown root:root /home/pi/temp_sudo_file
    Mar 29 12:49:00 raspberrypi sudo[1419]: pam_unix(sudo:session): session opened for user root(uid=0) by pi(uid=1000)
    Mar 29 12:49:00 raspberrypi sudo[1419]: pam_unix(sudo:session): session closed for user root
    Mar 29 12:49:00 raspberrypi sudo[1422]:       pi : TTY=pts/0 ; PWD=/home/pi ; USER=root ; COMMAND=/usr/bin/chmod 440 /home/pi/temp_sudo_file
    Mar 29 12:49:00 raspberrypi sudo[1422]: pam_unix(sudo:session): session opened for user root(uid=0) by pi(uid=1000)
    Mar 29 12:49:00 raspberrypi sudo[1422]: pam_unix(sudo:session): session closed for user root
    Mar 29 12:49:00 raspberrypi sudo[1425]:       pi : TTY=pts/0 ; PWD=/home/pi ; USER=root ; COMMAND=/usr/bin/mv /home/pi/temp_sudo_file /etc/sudoers.d/iobroker
    Mar 29 12:49:00 raspberrypi sudo[1425]: pam_unix(sudo:session): session opened for user root(uid=0) by pi(uid=1000)
    Mar 29 12:49:00 raspberrypi sudo[1425]: pam_unix(sudo:session): session closed for user root
    Mar 29 12:49:00 raspberrypi sudo[1429]:       pi : TTY=pts/0 ; PWD=/home/pi ; USER=root ; COMMAND=/usr/sbin/usermod -a -G audio iobroker
    Mar 29 12:49:00 raspberrypi sudo[1429]: pam_unix(sudo:session): session opened for user root(uid=0) by pi(uid=1000)
    Mar 29 12:49:00 raspberrypi sudo[1429]: pam_unix(sudo:session): session closed for user root
    Mar 29 12:49:00 raspberrypi sudo[1436]:       pi : TTY=pts/0 ; PWD=/home/pi ; USER=root ; COMMAND=/usr/sbin/usermod -a -G bluetooth iobroker
    Mar 29 12:49:00 raspberrypi sudo[1436]: pam_unix(sudo:session): session opened for user root(uid=0) by pi(uid=1000)
    Mar 29 12:49:00 raspberrypi sudo[1436]: pam_unix(sudo:session): session closed for user root
    Mar 29 12:49:00 raspberrypi sudo[1443]:       pi : TTY=pts/0 ; PWD=/home/pi ; USER=root ; COMMAND=/usr/sbin/usermod -a -G dialout iobroker
    Mar 29 12:49:00 raspberrypi sudo[1443]: pam_unix(sudo:session): session opened for user root(uid=0) by pi(uid=1000)
    Mar 29 12:49:01 raspberrypi sudo[1443]: pam_unix(sudo:session): session closed for user root
    Mar 29 12:49:01 raspberrypi sudo[1450]:       pi : TTY=pts/0 ; PWD=/home/pi ; USER=root ; COMMAND=/usr/sbin/usermod -a -G gpio iobroker
    Mar 29 12:49:01 raspberrypi sudo[1450]: pam_unix(sudo:session): session opened for user root(uid=0) by pi(uid=1000)
    Mar 29 12:49:01 raspberrypi sudo[1450]: pam_unix(sudo:session): session closed for user root
    Mar 29 12:49:01 raspberrypi sudo[1457]:       pi : TTY=pts/0 ; PWD=/home/pi ; USER=root ; COMMAND=/usr/sbin/usermod -a -G i2c iobroker
    Mar 29 12:49:01 raspberrypi sudo[1457]: pam_unix(sudo:session): session opened for user root(uid=0) by pi(uid=1000)
    Mar 29 12:49:01 raspberrypi sudo[1457]: pam_unix(sudo:session): session closed for user root
    Mar 29 12:49:01 raspberrypi sudo[1465]:       pi : TTY=pts/0 ; PWD=/home/pi ; USER=root ; COMMAND=/usr/sbin/usermod -a -G tty iobroker
    Mar 29 12:49:01 raspberrypi sudo[1465]: pam_unix(sudo:session): session opened for user root(uid=0) by pi(uid=1000)
    Mar 29 12:49:01 raspberrypi sudo[1465]: pam_unix(sudo:session): session closed for user root
    Mar 29 12:49:01 raspberrypi sudo[1472]:       pi : TTY=pts/0 ; PWD=/home/pi ; USER=root ; COMMAND=/usr/sbin/usermod -a -G video iobroker
    Mar 29 12:49:01 raspberrypi sudo[1472]: pam_unix(sudo:session): session opened for user root(uid=0) by pi(uid=1000)
    Mar 29 12:49:01 raspberrypi sudo[1472]: pam_unix(sudo:session): session closed for user root
    Mar 29 12:49:01 raspberrypi sudo[1478]:       pi : TTY=pts/0 ; PWD=/opt/iobroker ; USER=root ; COMMAND=/usr/bin/touch .npmrc
    Mar 29 12:49:01 raspberrypi sudo[1478]: pam_unix(sudo:session): session opened for user root(uid=0) by pi(uid=1000)
    Mar 29 12:49:01 raspberrypi sudo[1478]: pam_unix(sudo:session): session closed for user root
    Mar 29 12:49:01 raspberrypi sudo[1481]:       pi : TTY=pts/0 ; PWD=/opt/iobroker ; USER=root ; COMMAND=/usr/bin/grep -q -E ^audit=false .npmrc
    Mar 29 12:49:01 raspberrypi sudo[1481]: pam_unix(sudo:session): session opened for user root(uid=0) by pi(uid=1000)
    Mar 29 12:49:01 raspberrypi sudo[1481]: pam_unix(sudo:session): session closed for user root
    Mar 29 12:49:01 raspberrypi sudo[1484]:       pi : TTY=pts/0 ; PWD=/opt/iobroker ; USER=root ; COMMAND=/usr/bin/chown -R pi:pi .npmrc
    Mar 29 12:49:01 raspberrypi sudo[1484]: pam_unix(sudo:session): session opened for user root(uid=0) by pi(uid=1000)
    Mar 29 12:49:01 raspberrypi sudo[1484]: pam_unix(sudo:session): session closed for user root
    Mar 29 12:49:01 raspberrypi sudo[1487]:       pi : TTY=pts/0 ; PWD=/opt/iobroker ; USER=root ; COMMAND=/usr/bin/touch .npmrc
    Mar 29 12:49:01 raspberrypi sudo[1487]: pam_unix(sudo:session): session opened for user root(uid=0) by pi(uid=1000)
    Mar 29 12:49:01 raspberrypi sudo[1487]: pam_unix(sudo:session): session closed for user root
    Mar 29 12:49:01 raspberrypi sudo[1490]:       pi : TTY=pts/0 ; PWD=/opt/iobroker ; USER=root ; COMMAND=/usr/bin/grep -q -E ^update-notifier=false .npmrc
    Mar 29 12:49:01 raspberrypi sudo[1490]: pam_unix(sudo:session): session opened for user root(uid=0) by pi(uid=1000)
    Mar 29 12:49:01 raspberrypi sudo[1490]: pam_unix(sudo:session): session closed for user root
    Mar 29 12:49:01 raspberrypi sudo[1493]:       pi : TTY=pts/0 ; PWD=/opt/iobroker ; USER=root ; COMMAND=/usr/bin/chown -R pi:pi .npmrc
    Mar 29 12:49:01 raspberrypi sudo[1493]: pam_unix(sudo:session): session opened for user root(uid=0) by pi(uid=1000)
    Mar 29 12:49:01 raspberrypi sudo[1493]: pam_unix(sudo:session): session closed for user root
    Mar 29 12:49:01 raspberrypi sudo[1502]:       pi : TTY=pts/0 ; PWD=/opt/iobroker ; USER=root ; COMMAND=/usr/bin/tee /home/pi/.iobroker/iobroker_completions
    Mar 29 12:49:01 raspberrypi sudo[1502]: pam_unix(sudo:session): session opened for user root(uid=0) by pi(uid=1000)
    Mar 29 12:49:01 raspberrypi sudo[1502]: pam_unix(sudo:session): session closed for user root
    Mar 29 12:49:01 raspberrypi sudo[1506]:       pi : TTY=pts/0 ; PWD=/opt/iobroker ; USER=root ; COMMAND=/usr/bin/grep -q -E '^source ~/\\.iobroker/iobroker_completions' /home/pi/.bashrc
    Mar 29 12:49:01 raspberrypi sudo[1506]: pam_unix(sudo:session): session opened for user root(uid=0) by pi(uid=1000)
    Mar 29 12:49:01 raspberrypi sudo[1506]: pam_unix(sudo:session): session closed for user root
    Mar 29 12:49:01 raspberrypi sudo[1509]:       pi : TTY=pts/0 ; PWD=/opt/iobroker ; USER=root ; COMMAND=/usr/bin/touch .npmrc
    Mar 29 12:49:01 raspberrypi sudo[1509]: pam_unix(sudo:session): session opened for user root(uid=0) by pi(uid=1000)
    Mar 29 12:49:01 raspberrypi sudo[1509]: pam_unix(sudo:session): session closed for user root
    Mar 29 12:49:01 raspberrypi sudo[1512]:       pi : TTY=pts/0 ; PWD=/opt/iobroker ; USER=root ; COMMAND=/usr/bin/grep -q -E ^engine-strict=true .npmrc
    Mar 29 12:49:01 raspberrypi sudo[1512]: pam_unix(sudo:session): session opened for user root(uid=0) by pi(uid=1000)
    Mar 29 12:49:01 raspberrypi sudo[1512]: pam_unix(sudo:session): session closed for user root
    Mar 29 12:49:01 raspberrypi sudo[1515]:       pi : TTY=pts/0 ; PWD=/opt/iobroker ; USER=root ; COMMAND=/usr/bin/chown -R pi:pi .npmrc
    Mar 29 12:49:01 raspberrypi sudo[1515]: pam_unix(sudo:session): session opened for user root(uid=0) by pi(uid=1000)
    Mar 29 12:49:01 raspberrypi sudo[1515]: pam_unix(sudo:session): session closed for user root
    Mar 29 12:49:01 raspberrypi sudo[1524]:       pi : TTY=pts/0 ; PWD=/opt/iobroker ; USER=root ; COMMAND=/usr/bin/tee /home/pi/.iobroker/npm_command_fix
    Mar 29 12:49:01 raspberrypi sudo[1524]: pam_unix(sudo:session): session opened for user root(uid=0) by pi(uid=1000)
    Mar 29 12:49:01 raspberrypi sudo[1524]: pam_unix(sudo:session): session closed for user root
    Mar 29 12:49:01 raspberrypi sudo[1528]:       pi : TTY=pts/0 ; PWD=/opt/iobroker ; USER=root ; COMMAND=/usr/bin/grep -q -E '^source ~/\\.iobroker/npm_command_fix' /home/pi/.bashrc
    Mar 29 12:49:01 raspberrypi sudo[1528]: pam_unix(sudo:session): session opened for user root(uid=0) by pi(uid=1000)
    Mar 29 12:49:01 raspberrypi sudo[1528]: pam_unix(sudo:session): session closed for user root
    Mar 29 12:49:01 raspberrypi sudo[1535]:       pi : TTY=pts/0 ; PWD=/opt/iobroker ; USER=root ; COMMAND=/usr/bin/mkdir -p /root/.iobroker
    Mar 29 12:49:01 raspberrypi sudo[1535]: pam_unix(sudo:session): session opened for user root(uid=0) by pi(uid=1000)
    Mar 29 12:49:01 raspberrypi sudo[1535]: pam_unix(sudo:session): session closed for user root
    Mar 29 12:49:01 raspberrypi sudo[1539]:       pi : TTY=pts/0 ; PWD=/opt/iobroker ; USER=root ; COMMAND=/usr/bin/tee /root/.iobroker/npm_command_fix
    Mar 29 12:49:01 raspberrypi sudo[1539]: pam_unix(sudo:session): session opened for user root(uid=0) by pi(uid=1000)
    Mar 29 12:49:01 raspberrypi sudo[1539]: pam_unix(sudo:session): session closed for user root
    Mar 29 12:49:01 raspberrypi sudo[1542]:       pi : TTY=pts/0 ; PWD=/opt/iobroker ; USER=root ; COMMAND=/usr/bin/touch /root/.bashrc
    Mar 29 12:49:01 raspberrypi sudo[1542]: pam_unix(sudo:session): session opened for user root(uid=0) by pi(uid=1000)
    Mar 29 12:49:01 raspberrypi sudo[1542]: pam_unix(sudo:session): session closed for user root
    Mar 29 12:49:01 raspberrypi sudo[1545]:       pi : TTY=pts/0 ; PWD=/opt/iobroker ; USER=root ; COMMAND=/usr/bin/grep -q -E '^source /root/\\.iobroker/npm_command_fix' /root/.bashrc
    Mar 29 12:49:01 raspberrypi sudo[1545]: pam_unix(sudo:session): session opened for user root(uid=0) by pi(uid=1000)
    Mar 29 12:49:01 raspberrypi sudo[1545]: pam_unix(sudo:session): session closed for user root
    Mar 29 12:49:01 raspberrypi sudo[1548]:       pi : TTY=pts/0 ; PWD=/opt/iobroker ; USER=root ; COMMAND=/usr/bin/chown -R iobroker:iobroker /opt/iobroker
    Mar 29 12:49:01 raspberrypi sudo[1548]: pam_unix(sudo:session): session opened for user root(uid=0) by pi(uid=1000)
    Mar 29 12:49:07 raspberrypi sudo[1548]: pam_unix(sudo:session): session closed for user root
    Mar 29 12:49:07 raspberrypi sudo[1551]:       pi : TTY=pts/0 ; PWD=/opt/iobroker ; USER=root ; COMMAND=/usr/bin/chown -R iobroker:iobroker /opt/iobroker
    Mar 29 12:49:07 raspberrypi sudo[1551]: pam_unix(sudo:session): session opened for user root(uid=0) by pi(uid=1000)
    Mar 29 12:49:07 raspberrypi sudo[1551]: pam_unix(sudo:session): session closed for user root
    Mar 29 12:49:07 raspberrypi sudo[1554]:       pi : TTY=pts/0 ; PWD=/opt/iobroker ; USER=root ; COMMAND=/usr/bin/chown -R iobroker:iobroker /home/iobroker/.npm
    Mar 29 12:49:07 raspberrypi sudo[1554]: pam_unix(sudo:session): session opened for user root(uid=0) by pi(uid=1000)
    Mar 29 12:49:08 raspberrypi sudo[1554]: pam_unix(sudo:session): session closed for user root
    Mar 29 12:49:08 raspberrypi sudo[1557]:       pi : TTY=pts/0 ; PWD=/opt/iobroker ; USER=root ; COMMAND=/usr/sbin/usermod -a -G iobroker pi
    Mar 29 12:49:08 raspberrypi sudo[1557]: pam_unix(sudo:session): session opened for user root(uid=0) by pi(uid=1000)
    Mar 29 12:49:09 raspberrypi sudo[1557]: pam_unix(sudo:session): session closed for user root
    Mar 29 12:49:09 raspberrypi sudo[1563]:       pi : TTY=pts/0 ; PWD=/opt/iobroker ; USER=root ; COMMAND=/usr/bin/setfacl -Rdm g:iobroker:rwx /opt/iobroker
    Mar 29 12:49:09 raspberrypi sudo[1563]: pam_unix(sudo:session): session opened for user root(uid=0) by pi(uid=1000)
    Mar 29 12:49:10 raspberrypi sudo[1563]: pam_unix(sudo:session): session closed for user root
    Mar 29 12:49:10 raspberrypi sudo[1566]:       pi : TTY=pts/0 ; PWD=/opt/iobroker ; USER=root ; COMMAND=/usr/bin/setfacl -Rm g:iobroker:rwx /opt/iobroker
    Mar 29 12:49:10 raspberrypi sudo[1566]: pam_unix(sudo:session): session opened for user root(uid=0) by pi(uid=1000)
    Mar 29 12:49:11 raspberrypi sudo[1566]: pam_unix(sudo:session): session closed for user root
    Mar 29 12:49:11 raspberrypi sudo[1569]:       pi : TTY=pts/0 ; PWD=/opt/iobroker ; USER=root ; COMMAND=/usr/bin/find /opt/iobroker/node_modules -type d -iname .*-???????? ! -iname .local-chromium -exec rm -rf {>
    Mar 29 12:49:11 raspberrypi sudo[1569]: pam_unix(sudo:session): session opened for user root(uid=0) by pi(uid=1000)
    Mar 29 12:49:11 raspberrypi sudo[1569]: pam_unix(sudo:session): session closed for user root
    Mar 29 12:49:11 raspberrypi sudo[1577]:       pi : TTY=pts/0 ; PWD=/opt/iobroker ; USER=iobroker ; COMMAND=/usr/bin/npm -v
    Mar 29 12:49:11 raspberrypi sudo[1577]: pam_unix(sudo:session): session opened for user iobroker(uid=1001) by pi(uid=1000)
    Mar 29 12:49:14 raspberrypi sudo[1577]: pam_unix(sudo:session): session closed for user iobroker
    Mar 29 12:49:14 raspberrypi sudo[1590]:       pi : TTY=pts/0 ; PWD=/opt/iobroker ; USER=iobroker ; COMMAND=/usr/bin/npm x --yes @iobroker/jsonltool@latest /opt/iobroker/iobroker-data
    Mar 29 12:49:14 raspberrypi sudo[1590]: pam_unix(sudo:session): session opened for user iobroker(uid=1001) by pi(uid=1000)
    Mar 29 12:49:30 raspberrypi sudo[1590]: pam_unix(sudo:session): session closed for user iobroker
    Mar 29 12:49:30 raspberrypi sudo[1615]:       pi : TTY=pts/0 ; PWD=/opt/iobroker ; USER=root ; COMMAND=/usr/bin/rm /lib/systemd/system/iobroker.service
    Mar 29 12:49:30 raspberrypi sudo[1615]: pam_unix(sudo:session): session opened for user root(uid=0) by pi(uid=1000)
    Mar 29 12:49:30 raspberrypi sudo[1615]: pam_unix(sudo:session): session closed for user root
    Mar 29 12:49:30 raspberrypi sudo[1625]:       pi : TTY=pts/0 ; PWD=/opt/iobroker ; USER=root ; COMMAND=/usr/bin/systemctl daemon-reload
    Mar 29 12:49:30 raspberrypi sudo[1625]: pam_unix(sudo:session): session opened for user root(uid=0) by pi(uid=1000)
    Mar 29 12:49:30 raspberrypi systemd[1]: Reloading.
    Mar 29 12:49:33 raspberrypi sudo[1625]: pam_unix(sudo:session): session closed for user root
    Mar 29 12:49:33 raspberrypi sudo[1648]:       pi : TTY=pts/0 ; PWD=/opt/iobroker ; USER=root ; COMMAND=/usr/bin/rm -f /opt/iobroker/iobroker
    Mar 29 12:49:33 raspberrypi sudo[1648]: pam_unix(sudo:session): session opened for user root(uid=0) by pi(uid=1000)
    Mar 29 12:49:33 raspberrypi sudo[1648]: pam_unix(sudo:session): session closed for user root
    Mar 29 12:49:33 raspberrypi sudo[1651]:       pi : TTY=pts/0 ; PWD=/opt/iobroker ; USER=root ; COMMAND=/usr/bin/rm -f /usr/bin/iobroker
    Mar 29 12:49:33 raspberrypi sudo[1651]: pam_unix(sudo:session): session opened for user root(uid=0) by pi(uid=1000)
    Mar 29 12:49:33 raspberrypi sudo[1651]: pam_unix(sudo:session): session closed for user root
    Mar 29 12:49:33 raspberrypi sudo[1654]:       pi : TTY=pts/0 ; PWD=/opt/iobroker ; USER=root ; COMMAND=/usr/bin/rm -f /opt/iobroker/iob
    Mar 29 12:49:33 raspberrypi sudo[1654]: pam_unix(sudo:session): session opened for user root(uid=0) by pi(uid=1000)
    Mar 29 12:49:33 raspberrypi sudo[1654]: pam_unix(sudo:session): session closed for user root
    Mar 29 12:49:33 raspberrypi sudo[1657]:       pi : TTY=pts/0 ; PWD=/opt/iobroker ; USER=root ; COMMAND=/usr/bin/rm -f /usr/bin/iob
    Mar 29 12:49:33 raspberrypi sudo[1657]: pam_unix(sudo:session): session opened for user root(uid=0) by pi(uid=1000)
    Mar 29 12:49:33 raspberrypi sudo[1657]: pam_unix(sudo:session): session closed for user root
    Mar 29 12:49:33 raspberrypi sudo[1660]:       pi : TTY=pts/0 ; PWD=/opt/iobroker ; USER=root ; COMMAND=/usr/bin/ln -sfn /opt/iobroker/iobroker /usr/bin/iobroker
    Mar 29 12:49:33 raspberrypi sudo[1660]: pam_unix(sudo:session): session opened for user root(uid=0) by pi(uid=1000)
    Mar 29 12:49:33 raspberrypi sudo[1660]: pam_unix(sudo:session): session closed for user root
    Mar 29 12:49:33 raspberrypi sudo[1663]:       pi : TTY=pts/0 ; PWD=/opt/iobroker ; USER=root ; COMMAND=/usr/bin/ln -sfn /opt/iobroker/iobroker /usr/bin/iob
    Mar 29 12:49:33 raspberrypi sudo[1663]: pam_unix(sudo:session): session opened for user root(uid=0) by pi(uid=1000)
    Mar 29 12:49:33 raspberrypi sudo[1663]: pam_unix(sudo:session): session closed for user root
    Mar 29 12:49:33 raspberrypi sudo[1666]:       pi : TTY=pts/0 ; PWD=/opt/iobroker ; USER=root ; COMMAND=/usr/bin/ln -sfn /opt/iobroker/iobroker /opt/iobroker/iob
    Mar 29 12:49:33 raspberrypi sudo[1666]: pam_unix(sudo:session): session opened for user root(uid=0) by pi(uid=1000)
    Mar 29 12:49:33 raspberrypi sudo[1666]: pam_unix(sudo:session): session closed for user root
    Mar 29 12:49:33 raspberrypi sudo[1670]:       pi : TTY=pts/0 ; PWD=/opt/iobroker ; USER=root ; COMMAND=/usr/bin/tee /opt/iobroker/iobroker
    Mar 29 12:49:33 raspberrypi sudo[1670]: pam_unix(sudo:session): session opened for user root(uid=0) by pi(uid=1000)
    Mar 29 12:49:33 raspberrypi sudo[1670]: pam_unix(sudo:session): session closed for user root
    Mar 29 12:49:33 raspberrypi sudo[1673]:       pi : TTY=pts/0 ; PWD=/opt/iobroker ; USER=root ; COMMAND=/usr/bin/chmod 755 /opt/iobroker/iobroker
    Mar 29 12:49:33 raspberrypi sudo[1673]: pam_unix(sudo:session): session opened for user root(uid=0) by pi(uid=1000)
    Mar 29 12:49:33 raspberrypi sudo[1673]: pam_unix(sudo:session): session closed for user root
    Mar 29 12:49:33 raspberrypi sudo[1676]:       pi : TTY=pts/0 ; PWD=/opt/iobroker ; USER=root ; COMMAND=/usr/bin/chown iobroker:iobroker /opt/iobroker/iobroker
    Mar 29 12:49:33 raspberrypi sudo[1676]: pam_unix(sudo:session): session opened for user root(uid=0) by pi(uid=1000)
    Mar 29 12:49:33 raspberrypi sudo[1676]: pam_unix(sudo:session): session closed for user root
    Mar 29 12:49:33 raspberrypi sudo[1679]:       pi : TTY=pts/0 ; PWD=/opt/iobroker ; USER=root ; COMMAND=/usr/bin/chown -h iobroker:iobroker /opt/iobroker/iob
    Mar 29 12:49:33 raspberrypi sudo[1679]: pam_unix(sudo:session): session opened for user root(uid=0) by pi(uid=1000)
    Mar 29 12:49:33 raspberrypi sudo[1679]: pam_unix(sudo:session): session closed for user root
    Mar 29 12:49:33 raspberrypi sudo[1685]:       pi : TTY=pts/0 ; PWD=/opt/iobroker ; USER=root ; COMMAND=/usr/bin/tee /lib/systemd/system/iobroker.service
    Mar 29 12:49:33 raspberrypi sudo[1685]: pam_unix(sudo:session): session opened for user root(uid=0) by pi(uid=1000)
    Mar 29 12:49:33 raspberrypi sudo[1685]: pam_unix(sudo:session): session closed for user root
    Mar 29 12:49:33 raspberrypi sudo[1688]:       pi : TTY=pts/0 ; PWD=/opt/iobroker ; USER=root ; COMMAND=/usr/bin/chown root:root /lib/systemd/system/iobroker.service
    Mar 29 12:49:33 raspberrypi sudo[1688]: pam_unix(sudo:session): session opened for user root(uid=0) by pi(uid=1000)
    Mar 29 12:49:33 raspberrypi sudo[1688]: pam_unix(sudo:session): session closed for user root
    Mar 29 12:49:33 raspberrypi sudo[1691]:       pi : TTY=pts/0 ; PWD=/opt/iobroker ; USER=root ; COMMAND=/usr/bin/chmod 644 /lib/systemd/system/iobroker.service
    Mar 29 12:49:33 raspberrypi sudo[1691]: pam_unix(sudo:session): session opened for user root(uid=0) by pi(uid=1000)
    Mar 29 12:49:33 raspberrypi sudo[1691]: pam_unix(sudo:session): session closed for user root
    Mar 29 12:49:33 raspberrypi sudo[1694]:       pi : TTY=pts/0 ; PWD=/opt/iobroker ; USER=root ; COMMAND=/usr/bin/systemctl daemon-reload
    Mar 29 12:49:33 raspberrypi sudo[1694]: pam_unix(sudo:session): session opened for user root(uid=0) by pi(uid=1000)
    Mar 29 12:49:33 raspberrypi systemd[1]: Reloading.
    Mar 29 12:49:36 raspberrypi sudo[1694]: pam_unix(sudo:session): session closed for user root
    Mar 29 12:49:36 raspberrypi sudo[1713]:       pi : TTY=pts/0 ; PWD=/opt/iobroker ; USER=root ; COMMAND=/usr/bin/systemctl enable iobroker
    Mar 29 12:49:36 raspberrypi sudo[1713]: pam_unix(sudo:session): session opened for user root(uid=0) by pi(uid=1000)
    Mar 29 12:49:36 raspberrypi systemd[1]: Reloading.
    Mar 29 12:49:39 raspberrypi sudo[1713]: pam_unix(sudo:session): session closed for user root
    Mar 29 12:49:46 raspberrypi sudo[1734]:       pi : TTY=pts/0 ; PWD=/home/pi ; USER=root ; COMMAND=/usr/bin/systemctl start iobroker
    Mar 29 12:49:46 raspberrypi sudo[1734]: pam_unix(sudo:session): session opened for user root(uid=0) by pi(uid=1000)
    Mar 29 12:49:47 raspberrypi systemd[1]: Started iobroker.service - ioBroker Server.
    Mar 29 12:49:47 raspberrypi sudo[1734]: pam_unix(sudo:session): session closed for user root
    -- Boot 1f96de9d768c48ebb3bed6be5eab0ffc --
    Mar 29 12:50:00 raspberrypi bash[555]: host.raspberrypi check instance "system.adapter.admin.0" for host "raspberrypi"
    Mar 29 12:50:01 raspberrypi bash[555]: host.raspberrypi check instance "system.adapter.node-red.0" for host "raspberrypi"
    Mar 29 12:50:01 raspberrypi bash[555]: host.raspberrypi check instance "system.adapter.backitup.0" for host "raspberrypi"
    Mar 29 12:50:01 raspberrypi bash[555]: host.raspberrypi check instance "system.adapter.zigbee.0" for host "raspberrypi"
    Mar 29 12:50:01 raspberrypi bash[555]: host.raspberrypi check instance "system.adapter.mqtt.0" for host "raspberrypi"
    Mar 29 12:50:01 raspberrypi bash[555]: host.raspberrypi check instance "system.adapter.discovery.0" for host "raspberrypi"
    Mar 29 12:50:01 raspberrypi bash[555]: host.raspberrypi check instance "system.adapter.wled.0" for host "raspberrypi"
    -- Boot 393a456bd6b547d18acd9ff4ef6ce68e --
    Mar 29 12:50:01 raspberrypi kernel: usb 1-1.3: USB disconnect, device number 6
    Mar 29 12:50:02 raspberrypi kernel: usb 1-1.3: new full-speed USB device number 7 using dwc_otg
    Mar 29 12:50:02 raspberrypi kernel: usb 1-1.3: New USB device found, idVendor=1cf1, idProduct=0030, bcdDevice= 1.00
    Mar 29 12:50:02 raspberrypi kernel: usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
    Mar 29 12:50:02 raspberrypi kernel: usb 1-1.3: Product: ConBee II
    Mar 29 12:50:02 raspberrypi kernel: usb 1-1.3: Manufacturer: dresden elektronik ingenieurtechnik GmbH
    Mar 29 12:50:02 raspberrypi kernel: usb 1-1.3: SerialNumber: DE2466692
    Mar 29 12:50:02 raspberrypi kernel: cdc_acm 1-1.3:1.0: ttyACM0: USB ACM device
    Mar 29 12:50:02 raspberrypi mtp-probe[1814]: checking bus 1, device 7: "/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3"
    Mar 29 12:50:02 raspberrypi mtp-probe[1814]: bus: 1, device: 7 was not an MTP device
    Mar 29 12:50:02 raspberrypi mtp-probe[1815]: checking bus 1, device 7: "/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3"
    Mar 29 12:50:02 raspberrypi mtp-probe[1815]: bus: 1, device: 7 was not an MTP device
    Mar 29 12:50:04 raspberrypi ModemManager[521]: <info>  [base-manager] couldn't check support for device '/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3': not supported by any plugin
    Mar 29 12:50:06 raspberrypi kernel: usb 1-1.3: USB disconnect, device number 7
    Mar 29 12:50:06 raspberrypi kernel: usb 1-1.3: new full-speed USB device number 8 using dwc_otg
    Mar 29 12:50:06 raspberrypi kernel: usb 1-1.3: New USB device found, idVendor=1cf1, idProduct=0030, bcdDevice= 1.00
    Mar 29 12:50:06 raspberrypi kernel: usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
    Mar 29 12:50:06 raspberrypi kernel: usb 1-1.3: Product: ConBee II
    Mar 29 12:50:06 raspberrypi kernel: usb 1-1.3: Manufacturer: dresden elektronik ingenieurtechnik GmbH
    Mar 29 12:50:06 raspberrypi kernel: usb 1-1.3: SerialNumber: DE2466692
    Mar 29 12:50:06 raspberrypi kernel: cdc_acm 1-1.3:1.0: ttyACM0: USB ACM device
    Mar 29 12:50:06 raspberrypi mtp-probe[1829]: checking bus 1, device 8: "/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3"
    Mar 29 12:50:06 raspberrypi mtp-probe[1829]: bus: 1, device: 8 was not an MTP device
    Mar 29 12:50:06 raspberrypi mtp-probe[1830]: checking bus 1, device 8: "/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3"
    Mar 29 12:50:06 raspberrypi mtp-probe[1830]: bus: 1, device: 8 was not an MTP device
    Mar 29 12:50:08 raspberrypi ModemManager[521]: <info>  [base-manager] couldn't check support for device '/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3': not supported by any plugin
    Mar 29 12:50:05 raspberrypi systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
    Mar 29 12:50:18 raspberrypi systemd[1]: systemd-fsckd.service: Deactivated successfully.
    Mar 29 12:56:48 raspberrypi systemd-timesyncd[375]: Contacted time server [2001:638:504:2000::34]:123 (2.debian.pool.ntp.org).
    Mar 29 12:56:48 raspberrypi systemd-timesyncd[375]: Initial clock synchronization to Fri 2024-03-29 12:56:48.089209 CET.
    Mar 29 12:56:51 raspberrypi systemd[1]: systemd-hostnamed.service: Deactivated successfully.
    Mar 29 12:56:57 raspberrypi sshd[809]: Accepted password for pi from 192.168.178.91 port 53913 ssh2
    Mar 29 12:56:57 raspberrypi sshd[809]: pam_unix(sshd:session): session opened for user pi(uid=1000) by (uid=0)
    Mar 29 12:56:57 raspberrypi systemd[1]: Created slice user-1000.slice - User Slice of UID 1000.
    Mar 29 12:56:57 raspberrypi systemd[1]: Starting user-runtime-dir@1000.service - User Runtime Directory /run/user/1000...
    Mar 29 12:56:57 raspberrypi systemd-logind[449]: New session 1 of user pi.
    Mar 29 12:56:57 raspberrypi systemd[1]: Finished user-runtime-dir@1000.service - User Runtime Directory /run/user/1000.
    Mar 29 12:56:57 raspberrypi systemd[1]: Starting user@1000.service - User Manager for UID 1000...
    Mar 29 12:56:57 raspberrypi (systemd)[824]: pam_unix(systemd-user:session): session opened for user pi(uid=1000) by (uid=0)
    Mar 29 12:56:57 raspberrypi kernel: systemd[824]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
    Mar 29 12:56:58 raspberrypi systemd[824]: Queued start job for default target default.target.
    Mar 29 12:56:58 raspberrypi systemd-journald[224]: File /var/log/journal/cbb239608c0c466bb3f5fd6a9f701912/user-1000.journal corrupted or uncleanly shut down, renaming and replacing.
    Mar 29 12:56:58 raspberrypi systemd[824]: Created slice app.slice - User Application Slice.
    Mar 29 12:56:58 raspberrypi systemd[824]: Reached target paths.target - Paths.
    Mar 29 12:56:58 raspberrypi systemd[824]: Reached target timers.target - Timers.
    Mar 29 12:56:58 raspberrypi systemd[824]: Starting dbus.socket - D-Bus User Message Bus Socket...
    Mar 29 12:56:58 raspberrypi systemd[824]: Listening on dirmngr.socket - GnuPG network certificate management daemon.
    Mar 29 12:56:58 raspberrypi systemd[824]: Listening on gpg-agent-browser.socket - GnuPG cryptographic agent and passphrase cache (access for web browsers).
    Mar 29 12:56:58 raspberrypi systemd[824]: Listening on gpg-agent-extra.socket - GnuPG cryptographic agent and passphrase cache (restricted).
    Mar 29 12:56:58 raspberrypi systemd[824]: Listening on gpg-agent-ssh.socket - GnuPG cryptographic agent (ssh-agent emulation).
    Mar 29 12:56:58 raspberrypi systemd[824]: Listening on gpg-agent.socket - GnuPG cryptographic agent and passphrase cache.
    Mar 29 12:56:58 raspberrypi systemd[824]: Listening on dbus.socket - D-Bus User Message Bus Socket.
    Mar 29 12:56:58 raspberrypi systemd[824]: Reached target sockets.target - Sockets.
    Mar 29 12:56:58 raspberrypi systemd[824]: Reached target basic.target - Basic System.
    Mar 29 12:56:58 raspberrypi systemd[824]: Reached target default.target - Main User Target.
    Mar 29 12:56:58 raspberrypi systemd[824]: Startup finished in 879ms.
    Mar 29 12:56:58 raspberrypi systemd[1]: Started user@1000.service - User Manager for UID 1000.
    Mar 29 12:56:58 raspberrypi systemd[1]: Started session-1.scope - Session 1 of User pi.
    Mar 29 12:56:58 raspberrypi sshd[809]: pam_env(sshd:session): deprecated reading of user environment enabled
    Mar 29 12:56:59 raspberrypi bash[555]: Was not able to detect the Linky linky_mode. Default to historique
    Mar 29 12:56:59 raspberrypi bash[555]: Was not able to detect the Linky energy_phase. Default to single_phase
    Mar 29 12:56:59 raspberrypi bash[555]: Not able to detect the current tarif. Not filtering any expose...
    ubeckerU Offline
    ubeckerU Offline
    ubecker
    @nftvirus schon mal ans Netzteil gedacht? Wenn der Stick angeschlossen ist braucht der Pi mehr Strom.
    Gruß Udo
    N 1 Antwort Letzte Antwort
    • ubeckerU ubecker
      N Offline
      N Offline
      NFTVirus
      @ubecker das Netzteil habe ich letzte Woche schon ausgetauscht und habe jetzt ein 5,1V 3A Netzteil dran das sollte also nicht das Problem sein.
      • da_WoodyD Offline
        da_WoodyD Offline
        @nftvirus 3A sind selbst für einen 3er raspi knapp.
        USB Dingens saugen halt auch.
        • ubeckerU Offline
          ubeckerU Offline
          ubecker
          @nftvirus mein kleiner pi4 braucht im normalen betrieb ca 4 W. Beim Start kurzzeitig 15W. Da hängt kein Stick dran. Ich hab da ein Netzteil mit 40W dran. Ein 15W Netzteil und dann eine SSD dran startet nicht mehr.
          Gruß Udo
          • ubeckerU ubecker
            N Offline
            N Offline
            NFTVirus
            @ubecker @da_Woody Danke euch dachte das das sogar für den RPI 4 reicht. Was für Netzteile nehmt ihr denn da?
            da_WoodyD ubeckerU 2 Antworten Letzte Antwort
            • N NFTVirus
              da_WoodyD Offline
              da_WoodyD Offline
              @nftvirus tja, ich verwende keine raspis fürs smarthome, somit kann ich nix genaues flüstern was die sticks saugen.
              hab da zwar einen 4er mit SSD, aber der hängt an einer USB ladestation.
              kurz bei den amazonen gesucht:
              https://www.amazon.de/GeeekPi-Raspberry-Netzteil-5A-Adapter/dp/B0CQ1Q18HX
              erster treffer.
              • N NFTVirus
                ubeckerU Offline
                ubeckerU Offline
                ubecker
                @nftvirus said in Iobroker stürzt ab bei Zugriff auf Admin:
                meiner hängt an diesem: https://www.amazon.de/gp/product/B0BR98XW8T/ref=ppx_yo_dt_b_asin_title_o01_s01?ie=UTF8&psc=1
                Gruß Udo
                • ubeckerU ubecker
                  @ubecker
                  Ladegeräte sind keine Netzteile...
                  Hier laufen jeweils die originalen Netzteile für den jeweiligen Raspberry.
                  ubeckerU 1 Antwort Letzte Antwort
                    @ubecker
                    ubeckerU Offline
                    ubeckerU Offline
                    ubecker
                    @thomas-braun said in Iobroker stürzt ab bei Zugriff auf Admin:
                    nee, was sind das denn? Ein USB C Netzteil (Ladegerät) das PD fähig ist hat eine Spannungsversorgung von 5V wenn keine Kommunikation vorhanden ist. Die Spannung geht nur höher (bis 20V) wenn beide Teilnehmer den richtigen Wert aushandeln. Wenn keine Kommunikation stattfindet wird die Spannung auf 5V geregelt. Der maximale Strom ist vom Netzteil abhängig darf aber 5A nicht überschreiten. (Mehr kann der Stecker nicht)
                    Gruß Udo
                    wendy2702W Thomas BraunT 3 Antworten Letzte Antwort
                    • ubeckerU ubecker
                      wendy2702W Online
                      wendy2702W Online
                      @ubecker naja, der Akku Shop hat es schön erklärt
                      „ Ladegerät vs. Netzteil – das ist der Unterschied
                      Inwieweit unterscheidet sich ein Ladegerät von einem Netzteil? Dreh- und Angelpunkt zur Unterscheidung dieser beiden Begriffe ist deren Funktion. Das Ladegerät und Netzteil transformieren Spannung und Strom in die Menge, die das Gerät benötigt. Im Unterschied zum Netzteil dient ein Ladegerät dazu, einen Akku aufzuladen. Hierbei kommt technische Raffinesse ins Spiel. Je nach Akku-Typ, beispielsweise Li-Ion, NiMH oder NiCd-Akku, führt das Ladegerät ein zuverlässiges Ladeprogramm aus. Dieses Programm sorgt dafür, dass der Akku nicht überladen wird, und erkennt selbstständig, wenn der Akku vollständig aufgeladen ist. Die Tatsache, dass das Ladeprogramm eines Ladegerätes auf den jeweiligen Akku individuell angepasst ist, macht es notwendig, den Akku stets mit dem passenden Ladegerät zu laden. Anderenfalls kann der Akku Schaden nehmen.“
                      • ubeckerU ubecker
                        @ubecker
                        Ladegeräte sind Ladegeräte; Netzteile sind Netzteile...
                        Zusammenfassend lässt sich sagen, dass die Begriffe Netzteil und Ladegerät zwar von vielen Menschen synonym verwendet werden, es sich dabei jedoch um zwei unterschiedliche Gerätetypen mit unterschiedlichen Funktionen handelt. Ein Netzteil dient zur Umwandlung von Hochspannungs-Wechselstrom in Niederspannungs-Gleichstrom und ist für den Betrieb mit bestimmten elektronischen Geräten konzipiert. Ein Ladegerät hingegen wird verwendet, um die Energie in einer wiederaufladbaren Batterie wieder aufzuladen, und verfügt über eine bestimmte Ausgangsspannung und Stromstärke, die auf die zu ladende Batterie zugeschnitten sind.
                        https://de.ehpowersupply.com/info/what-is-the-difference-between-a-power-adapter-82742239.html
                          @ubecker
                          N Offline
                          N Offline
                          NFTVirus
                          @thomas-braun, @da_Woody, @Meister-Mopper : Ich habe jetzt nochmal mit Labornetzteil die Leistungsaufnahme bzw den gezogenen Strom gecheckt und komme eigentlich nie über 1,2A. Habe nun immer das Problem das sobald ich im Zigbeeadapter den Conbee einstelle und die Einstellungen speichere alles abstürzt. Iobroker Log sagt:
                          2024-04-01 18:18:11.563 - info: admin.0 (796) ==> Connected system.user.admin from ::ffff:192.168.178.91
                          2024-04-01 18:18:25.813 - info: admin.0 (796) <== Disconnect system.user.admin from ::ffff:192.168.178.91 admin
                          2024-04-01 18:18:41.500 - info: admin.0 (796) ==> Connected system.user.admin from ::ffff:192.168.178.91
                          2024-04-01 18:18:41.773 - error: zigbee.0 (728) getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
                          2024-04-01 18:18:42.120 - info: zigbee.0 (728) List of port: []
                          2024-04-01 18:19:58.505 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 (force=false, process=true)
                          2024-04-01 18:19:58.525 - info: zigbee.0 (728) Got terminate signal TERMINATE_YOURSELF
                          2024-04-01 18:19:58.565 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 send kill signal
                          2024-04-01 18:19:58.627 - info: admin.0 (796) <== Disconnect system.user.admin from ::ffff:192.168.178.91
                          2024-04-01 18:19:58.529 - info: zigbee.0 (728) cleaned everything up...
                          2024-04-01 18:19:58.564 - info: zigbee.0 (728) Zigbee: disabling joining new devices.
                          2024-04-01 18:19:58.728 - info: zigbee.0 (728) terminating
                          2024-04-01 18:19:58.731 - info: zigbee.0 (728) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                          2024-04-01 18:19:58.754 - info: zigbee.0 (728) debug devices set to []
                          2024-04-01 18:19:59.032 - info: zigbee.0 (728) terminating
                          2024-04-01 18:19:59.348 - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                          2024-04-01 18:20:00.636 - info: admin.0 (796) ==> Connected system.user.admin from ::ffff:192.168.178.91
                          2024-04-01 18:20:01.633 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 988
                          2024-04-01 18:20:17.136 - info: zigbee.0 (988) starting. Version 1.10.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.20.0, js-controller: 5.0.19
                          2024-04-01 18:20:17.240 - error: zigbee.0 (988) Serial port not selected! Go to settings page.
                          2024-04-01 18:20:18.707 - info: zigbee.0 (988) delete old Backup files. keep only last 10
                          2024-04-01 18:20:18.714 - info: zigbee.0 (988) Starting Zigbee npm ...
                          2024-04-01 18:20:19.963 - info: zigbee.0 (988) Installed Version: iobroker.zigbee@1.10.1
                          2024-04-01 18:20:22.480 - error: zigbee.0 (988) Starting zigbee-herdsman problem : "No path provided and failed to auto detect path"
                          2024-04-01 18:20:22.483 - error: zigbee.0 (988) Failed to start Zigbee
                          2024-04-01 18:20:22.485 - error: zigbee.0 (988) Error herdsman start
                          2024-04-01 18:19:53.889 - info: host.raspberrypi iobroker.js-controller version 5.0.19 js-controller starting
                          2024-04-01 18:19:53.900 - info: host.raspberrypi Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
                          2024-04-01 18:19:53.902 - info: host.raspberrypi hostname: raspberrypi, node: v18.20.0
                          2024-04-01 18:19:53.904 - info: host.raspberrypi ip addresses: 192.168.178.66 2001:9e8:af97:7500:8b90:d236:941a:3955 fe80::6d01:3670:f9db:134d
                          2024-04-01 18:19:56.733 - info: host.raspberrypi connected to Objects and States
                          2024-04-01 18:19:56.852 - info: host.raspberrypi added notifications configuration of host
                          2024-04-01 18:19:58.285 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.nodeCurrent"
                          2024-04-01 18:19:58.291 - info: host.raspberrypi 7 instances found
                          2024-04-01 18:19:58.351 - info: host.raspberrypi starting 7 instances
                          2024-04-01 18:19:58.523 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.nodeNewest"
                          2024-04-01 18:19:58.565 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.nodeNewestNext"
                          2024-04-01 18:19:58.652 - info: host.raspberrypi instance system.adapter.admin.0 started with pid 695
                          2024-04-01 18:19:58.682 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.npmCurrent"
                          2024-04-01 18:19:58.753 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.npmNewest"
                          2024-04-01 18:19:58.823 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.npmNewestNext"
                          2024-04-01 18:19:58.892 - info: host.raspberrypi Some obsolete host states deleted.
                          2024-04-01 18:20:02.490 - info: host.raspberrypi instance system.adapter.node-red.0 started with pid 702
                          2024-04-01 18:20:06.081 - error: admin.0 (695) admin.0 already running
                          2024-04-01 18:20:06.098 - warn: admin.0 (695) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                          2024-04-01 18:20:06.456 - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 713
                          2024-04-01 18:20:07.153 - error: host.raspberrypi instance system.adapter.admin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                          2024-04-01 18:20:07.157 - info: host.raspberrypi Restart adapter system.adapter.admin.0 because enabled
                          2024-04-01 18:20:08.528 - error: node-red.0 (702) node-red.0 already running
                          2024-04-01 18:20:08.545 - warn: node-red.0 (702) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                          2024-04-01 18:20:09.222 - error: host.raspberrypi instance system.adapter.node-red.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                          2024-04-01 18:20:09.225 - info: host.raspberrypi Restart adapter system.adapter.node-red.0 because enabled
                          2024-04-01 18:20:10.464 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 724
                          2024-04-01 18:20:12.161 - error: backitup.0 (713) backitup.0 already running
                          2024-04-01 18:20:12.174 - warn: backitup.0 (713) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                          2024-04-01 18:20:12.858 - error: host.raspberrypi instance system.adapter.backitup.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                          2024-04-01 18:20:12.863 - info: host.raspberrypi Restart adapter system.adapter.backitup.0 because enabled
                          • N NFTVirus
                            @nftvirus
                            Wie schaut denn dein Setup aus?
                              @nftvirus
                              N Offline
                              N Offline
                              NFTVirus
                              schrieb am zuletzt editiert von NFTVirus
                              er ist jetzt gerade wieder ohne eingesteckten Stick normal hochgefahren. Dann habe ich den Zigbee-Adapter gestoppt und den den Stick eingesteckt. Hat auch alles weiter funktioniert und beim starten des Adapters ist er wieder abgestürzt
                              • N NFTVirus
                                @nftvirus
                                In deiner Ausgabe von iob diag wird da nix gefunden:
                                USB-Devices by-id:
                                find: '/dev/serial/by-id/': No such file or directory
                                  @nftvirus
                                  USB-Devices by-id:
                                  N Offline
                                  N Offline
                                  NFTVirus
                                  @thomas-braun das war mein Fehler bei dem iob Diag lauf war der Stick nicht dran weil ich dachte dass der Stick das Problem ist und ich ihn deshalb gar nicht mehr booten konnte. Habe gerade nochmal einen Diag run gemacht nach einem Absturz aber jetzt mit abgeschaltetem Zigbeeadapter:
                                  Skript v.2023-10-10
                                  *** BASE SYSTEM ***
                                   Static hostname: raspberrypi
                                         Icon name: computer
                                            Kernel: Linux 6.6.20+rpt-rpi-v8
                                      Architecture: arm64
                                  Model           : Raspberry Pi 3 Model B Plus Rev 1.3
                                  Docker          : false
                                  Virtualization  : none
                                  Kernel          : aarch64
                                  Userland        : arm64
                                  Systemuptime and Load:
                                   20:36:34 up 9 min,  2 users,  load average: 0.13, 0.29, 0.22
                                  CPU threads: 4
                                  *** RASPBERRY THROTTLING ***
                                  Current issues:
                                  Previously detected issues:
                                  *** Time and Time Zones ***
                                                 Local time: Mon 2024-04-01 20:36:34 CEST
                                             Universal time: Mon 2024-04-01 18:36:34 UTC
                                                   RTC time: n/a
                                                NTP service: active
                                            RTC in local TZ: no
                                  *** User and Groups ***
                                  pi
                                  /home/pi
                                  pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                                  *** X-Server-Setup ***
                                  X-Server:       false
                                  Desktop:
                                  Terminal:       tty
                                  Boot Target:    multi-user.target
                                  *** MEMORY ***
                                  Mem:            951M        588M        163M        1.1M        256M        362M
                                  Swap:           104M          0B        104M
                                  Total:          1.1G        588M        268M
                                            907 M total memory
                                            561 M used memory
                                            596 M active memory
                                             81 M inactive memory
                                            155 M free memory
                                             24 M buffer memory
                                            219 M swap cache
                                             99 M total swap
                                              0 M used swap
                                             99 M free swap
                                  Raspberry only:
                                  oom events: 0
                                  *** FAILED SERVICES ***
                                  0 loaded units listed.
                                  *** FILESYSTEM ***
                                  udev           devtmpfs  318M     0  318M   0% /dev
                                  tmpfs          tmpfs      91M  1.1M   90M   2% /run
                                  /dev/mmcblk0p2 ext4       29G  3.4G   24G  13% /
                                  tmpfs          tmpfs     454M     0  454M   0% /dev/shm
                                  tmpfs          tmpfs     5.0M   12K  5.0M   1% /run/lock
                                  /dev/mmcblk0p1 vfat      510M   63M  448M  13% /boot/firmware
                                  tmpfs          tmpfs      91M     0   91M   0% /run/user/1000
                                  [Mon Apr  1 20:27:31 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=42fe4a7c-02 rootfstype=ext4 fsck.repair=yes rootwait
                                  [Mon Apr  1 20:27:35 2024] EXT4-fs (mmcblk0p2): mounted filesystem 93c89e92-8f2e-4522-ad32-68faed883d2f ro with ordered data mode. Quota mode: none.
                                  [Mon Apr  1 20:27:38 2024] EXT4-fs (mmcblk0p2): re-mounted 93c89e92-8f2e-4522-ad32-68faed883d2f r/w. Quota mode: none.
                                  TARGET           SOURCE         FSTYPE OPTIONS
                                  /                /dev/mmcblk0p2 ext4   rw,noatime
                                  `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                  /var:
                                  793M    /var/
                                  329M    /var/log/journal/cbb239608c0c466bb3f5fd6a9f701912
                                  329M    /var/log
                                  203M    /var/cache
                                  Journal file /var/log/journal/cbb239608c0c466bb3f5fd6a9f701912/user-1001@000614cb3d61abda-917fe1756f9553c1.journal~ corrupted, ignoring file.
                                  Archived and active journals take up 320.0M in the file system.
                                  /opt/iobroker/backups:
                                  4.5M    /opt/iobroker/backups/
                                  /opt/iobroker/iobroker-data:
                                  80M     /opt/iobroker/iobroker-data/
                                  35M     /opt/iobroker/iobroker-data/backup-objects
                                  23M     /opt/iobroker/iobroker-data/files
                                  13M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
                                  9.2M    /opt/iobroker/iobroker-data/objects.jsonl
                                  6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
                                  2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
                                  1.6M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
                                  1.5M    /opt/iobroker/iobroker-data/backup-objects/2024-03-30_14-56_objects.jsonl.gz
                                  USB-Devices by-id:
                                  /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2466692-if00
                                  *** NodeJS-Installation ***
                                  /usr/bin/nodejs         v18.20.0
                                  /usr/bin/node           v18.20.0
                                  /usr/bin/npm            10.5.0
                                  /usr/bin/npx            10.5.0
                                  /usr/bin/corepack       0.25.2
                                  nodejs:
                                    Installed: 18.20.0-1nodesource1
                                    Candidate: 18.20.0-1nodesource1
                                    Version table:
                                   *** 18.20.0-1nodesource1 1001
                                          500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
                                       18.19.1-1nodesource1 1001
                                       18.19.0+dfsg-6~deb12u1 500
                                          500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
                                       18.19.0-1nodesource1 1001
                                       18.18.2-1nodesource1 1001
                                       18.18.1-1nodesource1 1001
                                       18.18.0-1nodesource1 1001
                                       18.17.1-1nodesource1 1001
                                       18.17.0-1nodesource1 1001
                                       18.16.1-1nodesource1 1001
                                       18.16.0-1nodesource1 1001
                                       18.15.0-1nodesource1 1001
                                       18.14.2-1nodesource1 1001
                                       18.14.1-1nodesource1 1001
                                       18.14.0-1nodesource1 1001
                                       18.13.0+dfsg1-1 500
                                          500 http://deb.debian.org/debian bookworm/main arm64 Packages
                                       18.13.0-1nodesource1 1001
                                       18.12.0-1nodesource1 1001
                                       18.11.0-1nodesource1 1001
                                       18.10.0-1nodesource1 1001
                                       18.9.1-1nodesource1 1001
                                       18.9.0-1nodesource1 1001
                                       18.8.0-1nodesource1 1001
                                       18.7.0-1nodesource1 1001
                                       18.6.0-1nodesource1 1001
                                       18.5.0-1nodesource1 1001
                                       18.4.0-1nodesource1 1001
                                       18.3.0-1nodesource1 1001
                                       18.2.0-1nodesource1 1001
                                       18.1.0-1nodesource1 1001
                                       18.0.0-1nodesource1 1001
                                  No problems detected
                                  Errors in npm tree:
                                  *** ioBroker-Installation ***
                                  ioBroker Status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  Core adapters versions
                                  admin:          6.13.16
                                  javascript:     "javascript" not found
                                  Adapters from github:   0
                                  Adapter State
                                  + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
                                  + system.adapter.node-red.0               : node-red              : raspberrypi                              -  enabled, port: 1880, bind: 0.0.0.0
                                  + system.adapter.wled.0                   : wled                  : raspberrypi                              -  enabled
                                    system.adapter.zigbee.0                 : zigbee                : raspberrypi                              - disabled, port: /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2466692-if00
                                  + instance is alive
                                  ioBroker-Repositories
                                  Active repo(s): stable
                                  Installed ioBroker-Instances
                                  Used repository: stable
                                  Adapter    "admin"        : 6.13.16  , installed 6.13.16
                                  Adapter    "backitup"     : 2.10.11  , installed 2.10.11
                                  Adapter    "discovery"    : 4.4.0    , installed 4.4.0
                                  Controller "js-controller": 5.0.19   , installed 5.0.19
                                  Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                                  Adapter    "node-red"     : 5.2.0    , installed 5.1.0  [Updatable]
                                  Adapter    "wled"         : 0.7.2    , installed 0.7.2
                                  Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
                                  Objects and States
                                  Objects:        519
                                  States:         354
                                  Hit:1 http://archive.raspberrypi.com/debian bookworm InRelease
                                  Hit:2 http://deb.debian.org/debian bookworm InRelease
                                  Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
                                  Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
                                  Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
                                  Reading package lists...
                                  Pending Updates: 16
                                  *** Listening Ports ***
                                  tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       5842       851/node-red
                                  tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       7229       845/io.mqtt.0
                                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       4008       560/iobroker.js-con
                                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       5673       560/iobroker.js-con
                                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          2723       598/sshd: /usr/sbin
                                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       4096       800/io.admin.0
                                  tcp6       0      0 :::80                   :::*                    LISTEN      1001       8198       851/node-red
                                  tcp6       0      0 :::22                   :::*                    LISTEN      0          2725       598/sshd: /usr/sbin
                                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       5830       894/io.wled.0
                                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        3819       420/avahi-daemon: r
                                  udp        0      0 0.0.0.0:57157           0.0.0.0:*                           104        3821       420/avahi-daemon: r
                                  udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       8199       851/node-red
                                  udp6       0      0 :::5353                 :::*                                104        3820       420/avahi-daemon: r
                                  udp6       0      0 fe80::6d01:3670:f9d:546 :::*                                0          5579       486/NetworkManager
                                  udp6       0      0 :::48743                :::*                                104        3822       420/avahi-daemon: r
                                  2024-04-01 20:28:55.525  - info: wled.0 (894) LED-Esstisch connected
                                  2024-04-01 20:28:58.593  - info: node-red.0 (807) Node-RED: 1 Apr 20:28:58 - [info] Settings file  : /opt/iobroker/iobroker-data/node-red/settings.js
                                  2024-04-01 20:28:58.598  - info: node-red.0 (807) Node-RED: 1 Apr 20:28:58 - [info] Context store  : 'default' [module=memory]
                                  2024-04-01 20:28:58.604  - info: node-red.0 (807) Node-RED: 1 Apr 20:28:58 - [info] User directory : /opt/iobroker/iobroker-data/node-red/
                                  2024-04-01 20:28:58.607  - warn: node-red.0 (807) Node-RED: 1 Apr 20:28:58 - [warn] Projects disabled : editorTheme.projects.enabled=false
                                  2024-04-01 20:28:58.610  - info: node-red.0 (807) Node-RED: 1 Apr 20:28:58 - [info] Flows file     : /opt/iobroker/iobroker-data/node-red/flows.json
                                  2024-04-01 20:28:58.663  - warn: node-red.0 (807) Node-RED: 1 Apr 20:28:58 - [warn] Encrypted credentials not found
                                  2024-04-01 20:28:58.732  - info: node-red.0 (807) Node-RED: 1 Apr 20:28:58 - [info] Server now running at http://127.0.0.1:1880/
                                  2024-04-01 20:28:58.770  - info: node-red.0 (807) Node-RED: 1 Apr 20:28:58 - [info] Starting flows
                                  2024-04-01 20:28:59.539  - info: node-red.0 (807) Node-RED: 1 Apr 20:28:59 - [info] Started flows
                                  2024-04-01 20:29:05.398  - info: wled.0 (894) WLED initialisation finalized, ready to do my job have fun !
                                  2024-04-01 20:29:16.835  - info: mqtt.0 (845) Client [shellyswitch25-C45BBE765D8B] connected with secret 1711996156821_9429
                                  2024-04-01 20:29:17.165  - info: mqtt.0 (845) Client [shellyswitch25-C45BBE765D8B] subscribes on "mqtt.0.shellies.command"
                                  2024-04-01 20:29:17.169  - info: mqtt.0 (845) Client [shellyswitch25-C45BBE765D8B] subscribes on "mqtt.0.shellies.Rolladen-Ost.command"
                                  2024-04-01 20:29:17.172  - info: mqtt.0 (845) Client [shellyswitch25-C45BBE765D8B] subscribes on "mqtt.0.shellies.Rolladen-Ost.roller.0.command.pos"
                                  2024-04-01 20:29:17.174  - info: mqtt.0 (845) Client [shellyswitch25-C45BBE765D8B] subscribes on "mqtt.0.shellies.Rolladen-Ost.roller.0.command"
                                  2024-04-01 20:29:17.176  - info: mqtt.0 (845) Client [shellyswitch25-C45BBE765D8B] subscribes on "mqtt.0.shellies.Rolladen-Ost.relay.1.command"
                                  2024-04-01 20:29:17.178  - info: mqtt.0 (845) Client [shellyswitch25-C45BBE765D8B] subscribes on "mqtt.0.shellies.Rolladen-Ost.relay.0.command"
                                  2024-04-01 20:29:44.558  - info: mqtt.0 (845) Client [shellyswitch25-C45BBE7642B7] connected with secret 1711996184553_1378
                                  2024-04-01 20:29:44.617  - info: mqtt.0 (845) Client [shellyswitch25-C45BBE7642B7] subscribes on "mqtt.0.shellies.command"
                                  2024-04-01 20:29:44.665  - info: mqtt.0 (845) Client [shellyswitch25-C45BBE7642B7] subscribes on "mqtt.0.shellies.Rollladen-Süd-Gross.command"
                                  2024-04-01 20:29:44.668  - info: mqtt.0 (845) Client [shellyswitch25-C45BBE7642B7] subscribes on "mqtt.0.shellies.Rollladen-Süd-Gross.roller.0.command.pos"
                                  2024-04-01 20:29:44.670  - info: mqtt.0 (845) Client [shellyswitch25-C45BBE7642B7] subscribes on "mqtt.0.shellies.Rollladen-Süd-Gross.roller.0.command"
                                  2024-04-01 20:29:44.673  - info: mqtt.0 (845) Client [shellyswitch25-C45BBE7642B7] subscribes on "mqtt.0.shellies.Rollladen-Süd-Gross.relay.1.command"
                                  2024-04-01 20:29:44.682  - info: mqtt.0 (845) Client [shellyswitch25-C45BBE7642B7] subscribes on "mqtt.0.shellies.Rollladen-Süd-Gross.relay.0.command"
                                  • N NFTVirus
                                    Skript v.2023-10-10
                                    *** BASE SYSTEM ***
                                           Icon name: computer
                                        Architecture: arm64
                                    Docker          : false
                                    Kernel          : aarch64
                                    Userland        : arm64
                                    CPU threads: 4
                                    Current issues:
                                                     RTC time: n/a
                                                  NTP service: active
                                              RTC in local TZ: no
                                    pi
                                    /home/pi
                                    X-Server:       false
                                    Desktop:
                                    Terminal:       tty
                                    *** MEMORY ***
                                    Swap:           104M          0B        104M
                                              907 M total memory
                                              561 M used memory
                                              596 M active memory
                                              155 M free memory
                                               24 M buffer memory
                                              219 M swap cache
                                               99 M total swap
                                                0 M used swap
                                               99 M free swap
                                    Raspberry only:
                                    oom events: 0
                                    *** FILESYSTEM ***
                                    /var:
                                    793M    /var/
                                    329M    /var/log
                                    203M    /var/cache
                                    USB-Devices by-id:
                                    /usr/bin/npm            10.5.0
                                    /usr/bin/npx            10.5.0
                                    nodejs:
                                      Version table:
                                         18.13.0+dfsg1-1 500
                                    Errors in npm tree:
                                    ioBroker Status
                                    Objects type: jsonl
                                    States  type: jsonl
                                    admin:          6.13.16
                                    Adapter State
                                    + instance is alive
                                    Objects and States
                                    Objects:        519
                                    States:         354
                                    Pending Updates: 16
                                    @nftvirus sagte in Iobroker Absturz bei Zigbeeadapter mit Conbee2 einschalten:
                                    Pending Updates: 16
                                    Updaten...
                                    N 2 Antworten Letzte Antwort
                                      Pending Updates: 16
                                      Updaten...
                                      N Offline
                                      N Offline
                                      NFTVirus
                                      @thomas-braun Updates sind jetzt durchgeführt. Leider keine Verbesserung.
                                      Ich hatte den RPI und Iobroker seit gestern bis heute um 13:25 mit eingesteckten Conbee Stick aber deactiviertem Zigbeeadapter laufen. Um 13:25 habe ich dann den Adapter aktiviert und es ist wieder alles abgestürzt. System log von dem event:
                                      Apr 02 13:17:01 raspberrypi kernel: pcpu-alloc: s85672 r8192 d29016 u122880 alloc=30*4096
                                      Apr 02 13:17:01 raspberrypi kernel: pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
                                      Apr 02 13:17:01 raspberrypi kernel: Detected VIPT I-cache on CPU0
                                      Apr 02 13:17:01 raspberrypi kernel: CPU features: kernel page table isolation forced ON by KASLR
                                      Apr 02 13:17:01 raspberrypi kernel: CPU features: detected: Kernel page table isolation (KPTI)
                                      Apr 02 13:17:01 raspberrypi kernel: CPU features: detected: ARM erratum 843419
                                      Apr 02 13:17:01 raspberrypi kernel: CPU features: detected: ARM erratum 845719
                                      Apr 02 13:17:01 raspberrypi kernel: alternatives: applying boot alternatives
                                      Apr 02 13:17:01 raspberrypi kernel: Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  vc_>
                                      Apr 02 13:17:01 raspberrypi kernel: Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
                                      Apr 02 13:17:01 raspberrypi kernel: Inode-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
                                      Apr 02 13:17:01 raspberrypi kernel: Built 1 zonelists, mobility grouping on.  Total pages: 238896
                                      Apr 02 13:17:01 raspberrypi kernel: mem auto-init: stack:all(zero), heap alloc:off, heap free:off
                                      Apr 02 13:17:01 raspberrypi kernel: Memory: 651264K/970752K available (13376K kernel code, 2210K rwdata, 4260K rodata, 4864K init, 1083K bss, 57344K reserved, 262144K cma-reserved)
                                      Apr 02 13:17:01 raspberrypi kernel: SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
                                      Apr 02 13:17:01 raspberrypi kernel: ftrace: allocating 43116 entries in 169 pages
                                      Apr 02 13:17:01 raspberrypi kernel: ftrace: allocated 169 pages with 4 groups
                                      Apr 02 13:17:01 raspberrypi kernel: trace event string verifier disabled
                                      Apr 02 13:17:01 raspberrypi kernel: rcu: Preemptible hierarchical RCU implementation.
                                      Apr 02 13:17:01 raspberrypi kernel: rcu:         RCU event tracing is enabled.
                                      Apr 02 13:17:01 raspberrypi kernel: rcu:         RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
                                      Apr 02 13:17:01 raspberrypi kernel:         Trampoline variant of Tasks RCU enabled.
                                      Apr 02 13:17:01 raspberrypi kernel:         Rude variant of Tasks RCU enabled.
                                      Apr 02 13:17:01 raspberrypi kernel:         Tracing variant of Tasks RCU enabled.
                                      Apr 02 13:17:01 raspberrypi kernel: rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
                                      Apr 02 13:17:01 raspberrypi kernel: rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
                                      Apr 02 13:17:01 raspberrypi kernel: NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
                                      Apr 02 13:17:01 raspberrypi kernel: Root IRQ handler: bcm2836_arm_irqchip_handle_irq
                                      Apr 02 13:17:01 raspberrypi kernel: rcu: srcu_init: Setting srcu_struct sizes based on contention.
                                      Apr 02 13:17:01 raspberrypi kernel: arch_timer: cp15 timer(s) running at 19.20MHz (phys).
                                      Apr 02 13:17:01 raspberrypi kernel: clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
                                      Apr 02 13:17:01 raspberrypi kernel: sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
                                      Apr 02 13:17:01 raspberrypi kernel: Console: colour dummy device 80x25
                                      Apr 02 13:17:01 raspberrypi kernel: printk: console [tty1] enabled
                                      Apr 02 13:17:01 raspberrypi kernel: Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=76800)
                                      Apr 02 13:17:01 raspberrypi kernel: pid_max: default: 32768 minimum: 301
                                      Apr 02 13:17:01 raspberrypi kernel: LSM: initializing lsm=capability,integrity
                                      Apr 02 13:17:01 raspberrypi kernel: Mount-cache hash table entries: 2048 (order: 2, 16384 bytes, linear)
                                      Apr 02 13:17:01 raspberrypi kernel: Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes, linear)
                                      Apr 02 13:17:01 raspberrypi kernel: cgroup: Disabling memory control group subsystem
                                      Apr 02 13:17:01 raspberrypi kernel: RCU Tasks: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1.
                                      Apr 02 13:17:01 raspberrypi kernel: RCU Tasks Rude: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1.
                                      Apr 02 13:17:01 raspberrypi kernel: RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1.
                                      Apr 02 13:17:01 raspberrypi kernel: rcu: Hierarchical SRCU implementation.
                                      Apr 02 13:17:01 raspberrypi kernel: rcu:         Max phase no-delay instances is 1000.
                                      Apr 02 13:17:01 raspberrypi kernel: EFI services will not be available.
                                      Apr 02 13:17:01 raspberrypi kernel: smp: Bringing up secondary CPUs ...
                                      Apr 02 13:17:01 raspberrypi kernel: Detected VIPT I-cache on CPU1
                                      Apr 02 13:17:01 raspberrypi kernel: CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
                                      Apr 02 13:17:01 raspberrypi kernel: Detected VIPT I-cache on CPU2
                                      Apr 02 13:17:01 raspberrypi kernel: CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
                                      Apr 02 13:17:01 raspberrypi kernel: Detected VIPT I-cache on CPU3
                                      Apr 02 13:17:01 raspberrypi kernel: CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
                                      Apr 02 13:17:01 raspberrypi kernel: smp: Brought up 1 node, 4 CPUs
                                      Apr 02 13:17:01 raspberrypi kernel: SMP: Total of 4 processors activated.
                                      Apr 02 13:17:01 raspberrypi kernel: CPU features: detected: 32-bit EL0 Support
                                      Apr 02 13:17:01 raspberrypi kernel: CPU features: detected: 32-bit EL1 Support
                                      Apr 02 13:17:01 raspberrypi kernel: CPU features: detected: CRC32 instructions
                                      Apr 02 13:17:01 raspberrypi kernel: CPU: All CPU(s) started at EL2
                                      Apr 02 13:17:01 raspberrypi kernel: alternatives: applying system-wide alternatives
                                      Apr 02 13:17:01 raspberrypi kernel: devtmpfs: initialized
                                      Apr 02 13:17:01 raspberrypi kernel: Enabled cp15_barrier support
                                      Apr 02 13:17:01 raspberrypi kernel: Enabled setend support
                                      Apr 02 13:17:01 raspberrypi kernel: clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
                                      Apr 02 13:17:01 raspberrypi kernel: futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
                                      Apr 02 13:17:01 raspberrypi kernel: pinctrl core: initialized pinctrl subsystem
                                      Apr 02 13:17:01 raspberrypi kernel: DMI not present or invalid.
                                      Apr 02 13:17:01 raspberrypi kernel: NET: Registered PF_NETLINK/PF_ROUTE protocol family
                                      Apr 02 13:17:01 raspberrypi kernel: DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
                                      Apr 02 13:17:01 raspberrypi kernel: DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
                                      Apr 02 13:17:01 raspberrypi kernel: DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
                                      Apr 02 13:17:01 raspberrypi kernel: audit: initializing netlink subsys (disabled)
                                      Apr 02 13:17:01 raspberrypi kernel: audit: type=2000 audit(0.048:1): state=initialized audit_enabled=0 res=1
                                      Apr 02 13:17:01 raspberrypi kernel: thermal_sys: Registered thermal governor 'step_wise'
                                      Apr 02 13:17:01 raspberrypi kernel: cpuidle: using governor menu
                                      Apr 02 13:17:01 raspberrypi kernel: hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
                                      Apr 02 13:17:01 raspberrypi kernel: ASID allocator initialised with 32768 entries
                                      Apr 02 13:17:01 raspberrypi kernel: Serial: AMBA PL011 UART driver
                                      Apr 02 13:17:01 raspberrypi kernel: bcm2835-mbox 3f00b880.mailbox: mailbox enabled
                                      Apr 02 13:17:01 raspberrypi kernel: raspberrypi-firmware soc:firmware: Attached to firmware from 2024-02-29T12:26:47, variant start
                                      Apr 02 13:17:01 raspberrypi kernel: raspberrypi-firmware soc:firmware: Firmware hash is f4e2138c2adc8f3a92a3a65939e458f11d7298ba
                                      Apr 02 13:17:01 raspberrypi kernel: Modules: 2G module region forced by RANDOMIZE_MODULE_REGION_FULL
                                      Apr 02 13:17:01 raspberrypi kernel: Modules: 0 pages in range for non-PLT usage
                                      Apr 02 13:17:01 raspberrypi kernel: Modules: 517792 pages in range for PLT usage
                                      Apr 02 13:17:01 raspberrypi kernel: bcm2835-dma 3f007000.dma-controller: DMA legacy API manager, dmachans=0x1
                                      Apr 02 13:17:01 raspberrypi kernel: iommu: Default domain type: Translated
                                      Apr 02 13:17:01 raspberrypi kernel: iommu: DMA domain TLB invalidation policy: strict mode
                                      Apr 02 13:17:01 raspberrypi kernel: SCSI subsystem initialized
                                      Apr 02 13:17:01 raspberrypi kernel: usbcore: registered new interface driver usbfs
                                      Apr 02 13:17:01 raspberrypi kernel: usbcore: registered new interface driver hub
                                      Apr 02 13:17:01 raspberrypi kernel: usbcore: registered new device driver usb
                                      Apr 02 13:17:01 raspberrypi kernel: pps_core: LinuxPPS API ver. 1 registered
                                      Apr 02 13:17:01 raspberrypi kernel: pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
                                      Apr 02 13:17:01 raspberrypi kernel: PTP clock support registered
                                      Apr 02 13:17:01 raspberrypi kernel: vgaarb: loaded
                                      Apr 02 13:17:01 raspberrypi kernel: clocksource: Switched to clocksource arch_sys_counter
                                      Apr 02 13:17:01 raspberrypi kernel: VFS: Disk quotas dquot_6.6.0
                                      Apr 02 13:17:01 raspberrypi kernel: VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
                                      Apr 02 13:17:01 raspberrypi kernel: FS-Cache: Loaded
                                      Apr 02 13:17:01 raspberrypi kernel: CacheFiles: Loaded
                                      Apr 02 13:17:01 raspberrypi kernel: NET: Registered PF_INET protocol family
                                      Apr 02 13:17:01 raspberrypi kernel: IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
                                      Apr 02 13:17:01 raspberrypi kernel: tcp_listen_portaddr_hash hash table entries: 512 (order: 1, 8192 bytes, linear)
                                      Apr 02 13:17:01 raspberrypi kernel: Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
                                      Apr 02 13:17:01 raspberrypi kernel: TCP established hash table entries: 8192 (order: 4, 65536 bytes, linear)
                                      Apr 02 13:17:01 raspberrypi kernel: TCP bind hash table entries: 8192 (order: 6, 262144 bytes, linear)
                                      Apr 02 13:17:01 raspberrypi kernel: TCP: Hash tables configured (established 8192 bind 8192)
                                      Apr 02 13:17:01 raspberrypi kernel: MPTCP token hash table entries: 1024 (order: 2, 24576 bytes, linear)
                                      Apr 02 13:17:01 raspberrypi kernel: UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
                                      Apr 02 13:17:01 raspberrypi kernel: UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
                                      Apr 02 13:17:01 raspberrypi kernel: NET: Registered PF_UNIX/PF_LOCAL protocol family
                                      Apr 02 13:17:01 raspberrypi kernel: RPC: Registered named UNIX socket transport module.
                                      Apr 02 13:17:01 raspberrypi kernel: RPC: Registered udp transport module.
                                      Apr 02 13:17:01 raspberrypi kernel: RPC: Registered tcp transport module.
                                      Apr 02 13:17:01 raspberrypi kernel: RPC: Registered tcp-with-tls transport module.
                                      Apr 02 13:17:01 raspberrypi kernel: RPC: Registered tcp NFSv4.1 backchannel transport module.
                                      Apr 02 13:17:01 raspberrypi kernel: PCI: CLS 0 bytes, default 64
                                      Apr 02 13:17:01 raspberrypi kernel: Trying to unpack rootfs image as initramfs...
                                      Apr 02 13:17:01 raspberrypi kernel: kvm [1]: IPA Size Limit: 40 bits
                                      Apr 02 13:17:01 raspberrypi kernel: kvm [1]: Hyp mode initialized successfully
                                      Apr 02 13:17:01 raspberrypi kernel: Initialise system trusted keyrings
                                      Apr 02 13:17:01 raspberrypi kernel: workingset: timestamp_bits=46 max_order=18 bucket_order=0
                                      Apr 02 13:17:01 raspberrypi kernel: zbud: loaded
                                      Apr 02 13:17:01 raspberrypi kernel: NFS: Registering the id_resolver key type
                                      Apr 02 13:17:01 raspberrypi kernel: Key type id_resolver registered
                                      Apr 02 13:17:01 raspberrypi kernel: Key type id_legacy registered
                                      Apr 02 13:17:01 raspberrypi kernel: nfs4filelayout_init: NFSv4 File Layout Driver Registering...
                                      Apr 02 13:17:01 raspberrypi kernel: nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
                                      Apr 02 13:17:01 raspberrypi kernel: Key type asymmetric registered
                                      Apr 02 13:17:01 raspberrypi kernel: Asymmetric key parser 'x509' registered
                                      Apr 02 13:17:01 raspberrypi kernel: Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
                                      Apr 02 13:17:01 raspberrypi kernel: io scheduler mq-deadline registered
                                      Apr 02 13:17:01 raspberrypi kernel: io scheduler kyber registered
                                      Apr 02 13:17:01 raspberrypi kernel: io scheduler bfq registered
                                      Apr 02 13:17:01 raspberrypi kernel: simple-framebuffer 3eaa9000.framebuffer: framebuffer at 0x3eaa9000, 0x151800 bytes
                                      Apr 02 13:17:01 raspberrypi kernel: simple-framebuffer 3eaa9000.framebuffer: format=a8r8g8b8, mode=720x480x32, linelength=2880
                                      Apr 02 13:17:01 raspberrypi kernel: Console: switching to colour frame buffer device 90x30
                                      Apr 02 13:17:01 raspberrypi kernel: simple-framebuffer 3eaa9000.framebuffer: fb0: simplefb registered!
                                      Apr 02 13:17:01 raspberrypi kernel: bcm2835-rng 3f104000.rng: hwrng registered
                                      Apr 02 13:17:01 raspberrypi kernel: vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
                                      Apr 02 13:17:01 raspberrypi kernel: brd: module loaded
                                      Apr 02 13:17:01 raspberrypi kernel: loop: module loaded
                                      Apr 02 13:17:01 raspberrypi kernel: Loading iSCSI transport class v2.0-870.
                                      Apr 02 13:17:01 raspberrypi kernel: usbcore: registered new device driver r8152-cfgselector
                                      Apr 02 13:17:01 raspberrypi kernel: usbcore: registered new interface driver r8152
                                      Apr 02 13:17:01 raspberrypi kernel: usbcore: registered new interface driver lan78xx
                                      Apr 02 13:17:01 raspberrypi kernel: usbcore: registered new interface driver smsc95xx
                                      Apr 02 13:17:01 raspberrypi kernel: dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
                                      Apr 02 13:17:01 raspberrypi kernel: Core Release: 2.80a
                                      Apr 02 13:17:01 raspberrypi kernel: Setting default values for core params
                                      Apr 02 13:17:01 raspberrypi kernel: Finished setting default values for core params
                                      Apr 02 13:17:01 raspberrypi kernel: Freeing initrd memory: 10832K
                                      Apr 02 13:17:01 raspberrypi kernel: Using Buffer DMA mode
                                      Apr 02 13:17:01 raspberrypi kernel: Periodic Transfer Interrupt Enhancement - disabled
                                      Apr 02 13:17:01 raspberrypi kernel: Multiprocessor Interrupt Enhancement - disabled
                                      Apr 02 13:17:01 raspberrypi kernel: OTG VER PARAM: 0, OTG VER FLAG: 0
                                      Apr 02 13:17:01 raspberrypi kernel: Dedicated Tx FIFOs mode
                                      Apr 02 13:17:01 raspberrypi kernel: WARN::dwc_otg_hcd_init:1072: FIQ DMA bounce buffers: virt = ffffffc080b92000 dma = 0x00000000de800000 len=9024
                                      Apr 02 13:17:01 raspberrypi kernel: FIQ FSM acceleration enabled for :
        Non-periodic Split Transactions
        Periodic Split Transactions
        High-Speed Isochronous Endpoints
        Interrupt/Control Split Transaction hack enabled
                                      Apr 02 13:17:01 raspberrypi kernel: dwc_otg: Microframe scheduler enabled
                                      Apr 02 13:17:01 raspberrypi kernel: WARN::hcd_init_fiq:496: MPHI regs_base at ffffffc080065000
                                      Apr 02 13:17:01 raspberrypi kernel: dwc_otg 3f980000.usb: DWC OTG Controller
                                      Apr 02 13:17:01 raspberrypi kernel: dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
                                      Apr 02 13:17:01 raspberrypi kernel: dwc_otg 3f980000.usb: irq 74, io mem 0x00000000
                                      Apr 02 13:17:01 raspberrypi kernel: Init: Port Power? op_state=1
                                      Apr 02 13:17:01 raspberrypi kernel: Init: Power Port (0)
                                      Apr 02 13:17:01 raspberrypi kernel: usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.06
                                      Apr 02 13:17:01 raspberrypi kernel: usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
                                      Apr 02 13:17:01 raspberrypi kernel: usb usb1: Product: DWC OTG Controller
                                      Apr 02 13:17:01 raspberrypi kernel: usb usb1: Manufacturer: Linux 6.6.20+rpt-rpi-v8 dwc_otg_hcd
                                      Apr 02 13:17:01 raspberrypi kernel: usb usb1: SerialNumber: 3f980000.usb
                                      Apr 02 13:17:01 raspberrypi kernel: hub 1-0:1.0: USB hub found
                                      Apr 02 13:17:01 raspberrypi kernel: hub 1-0:1.0: 1 port detected
                                      Apr 02 13:17:01 raspberrypi kernel: dwc_otg: FIQ enabled
                                      Apr 02 13:17:01 raspberrypi kernel: dwc_otg: NAK holdoff enabled
                                      Apr 02 13:17:01 raspberrypi kernel: dwc_otg: FIQ split-transaction FSM enabled
                                      Apr 02 13:17:01 raspberrypi kernel: Module dwc_common_port init
                                      Apr 02 13:17:01 raspberrypi kernel: usbcore: registered new interface driver uas
                                      Apr 02 13:17:01 raspberrypi kernel: usbcore: registered new interface driver usb-storage
                                      Apr 02 13:17:01 raspberrypi kernel: mousedev: PS/2 mouse device common for all mice
                                      Apr 02 13:17:01 raspberrypi kernel: sdhci: Secure Digital Host Controller Interface driver
                                      Apr 02 13:17:01 raspberrypi kernel: sdhci: Copyright(c) Pierre Ossman
                                      Apr 02 13:17:01 raspberrypi kernel: sdhci-pltfm: SDHCI platform and OF driver helper
                                      Apr 02 13:17:01 raspberrypi kernel: ledtrig-cpu: registered to indicate activity on CPUs
                                      Apr 02 13:17:01 raspberrypi kernel: hid: raw HID events driver (C) Jiri Kosina
                                      Apr 02 13:17:01 raspberrypi kernel: usbcore: registered new interface driver usbhid
                                      Apr 02 13:17:01 raspberrypi kernel: usbhid: USB HID core driver
                                      Apr 02 13:17:01 raspberrypi kernel: hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
                                      Apr 02 13:17:01 raspberrypi kernel: NET: Registered PF_PACKET protocol family
                                      Apr 02 13:17:01 raspberrypi kernel: Key type dns_resolver registered
                                      Apr 02 13:17:01 raspberrypi kernel: registered taskstats version 1
                                      Apr 02 13:17:01 raspberrypi kernel: Loading compiled-in X.509 certificates
                                      Apr 02 13:17:01 raspberrypi kernel: Key type .fscrypt registered
                                      Apr 02 13:17:01 raspberrypi kernel: Key type fscrypt-provisioning registered
                                      Apr 02 13:17:01 raspberrypi kernel: uart-pl011 3f201000.serial: cts_event_workaround enabled
                                      Apr 02 13:17:01 raspberrypi kernel: 3f201000.serial: ttyAMA1 at MMIO 0x3f201000 (irq = 99, base_baud = 0) is a PL011 rev2
                                      Apr 02 13:17:01 raspberrypi kernel: Indeed it is in host mode hprt0 = 00021501
                                      Apr 02 13:17:01 raspberrypi kernel: serial serial0: tty port ttyAMA1 registered
                                      Apr 02 13:17:01 raspberrypi kernel: bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
                                      Apr 02 13:17:01 raspberrypi kernel: bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
                                      Apr 02 13:17:01 raspberrypi kernel: mmc-bcm2835 3f300000.mmcnr: mmc_debug:0 mmc_debug2:0
                                      Apr 02 13:17:01 raspberrypi kernel: mmc-bcm2835 3f300000.mmcnr: DMA channel allocated
                                      Apr 02 13:17:01 raspberrypi kernel: sdhost: log_buf @ 00000000b4431116 (c53ed000)
                                      Apr 02 13:17:01 raspberrypi kernel: mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
                                      Apr 02 13:17:01 raspberrypi kernel: of_cfs_init
                                      Apr 02 13:17:01 raspberrypi kernel: of_cfs_init: OK
                                      Apr 02 13:17:01 raspberrypi kernel: clk: Disabling unused clocks
                                      Apr 02 13:17:01 raspberrypi kernel: Freeing unused kernel memory: 4864K
                                      Apr 02 13:17:01 raspberrypi kernel: Run /init as init process
                                      Apr 02 13:17:01 raspberrypi kernel:   with arguments:
                                      Apr 02 13:17:01 raspberrypi kernel:     /init
                                      Apr 02 13:17:01 raspberrypi kernel:   with environment:
                                      Apr 02 13:17:01 raspberrypi kernel:     HOME=/
                                      Apr 02 13:17:01 raspberrypi kernel:     TERM=linux
                                      Apr 02 13:17:01 raspberrypi kernel: mmc0: host does not support reading read-only switch, assuming write-enable
                                      Apr 02 13:17:01 raspberrypi kernel: mmc0: Host Software Queue enabled
                                      Apr 02 13:17:01 raspberrypi kernel: mmc0: new high speed SDHC card at address 59b4
                                      Apr 02 13:17:01 raspberrypi kernel: mmcblk0: mmc0:59b4 LX32G 29.5 GiB
                                      Apr 02 13:17:01 raspberrypi kernel:  mmcblk0: p1 p2
                                      Apr 02 13:17:01 raspberrypi kernel: mmc1: new high speed SDIO card at address 0001
                                      Apr 02 13:17:01 raspberrypi kernel: usb 1-1: new high-speed USB device number 2 using dwc_otg
                                      Apr 02 13:17:01 raspberrypi kernel: Indeed it is in host mode hprt0 = 00001101
                                      Apr 02 13:17:01 raspberrypi kernel: usb 1-1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
                                      Apr 02 13:17:01 raspberrypi kernel: usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
                                      Apr 02 13:17:01 raspberrypi kernel: hub 1-1:1.0: USB hub found
                                      Apr 02 13:17:01 raspberrypi kernel: hub 1-1:1.0: 4 ports detected
                                      Apr 02 13:17:01 raspberrypi kernel: usb 1-1.1: new high-speed USB device number 3 using dwc_otg
                                      Apr 02 13:17:01 raspberrypi kernel: usb 1-1.1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
                                      Apr 02 13:17:01 raspberrypi kernel: usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
                                      Apr 02 13:17:01 raspberrypi kernel: hub 1-1.1:1.0: USB hub found
                                      Apr 02 13:17:01 raspberrypi kernel: hub 1-1.1:1.0: 3 ports detected
                                      Apr 02 13:17:01 raspberrypi kernel: dwc_otg_handle_wakeup_detected_intr lxstate = 2
                                      Apr 02 13:17:01 raspberrypi kernel: usb 1-1.1.1: new high-speed USB device number 4 using dwc_otg
                                      Apr 02 13:17:01 raspberrypi kernel: usb 1-1.1.1: New USB device found, idVendor=0424, idProduct=7800, bcdDevice= 3.00
                                      Apr 02 13:17:01 raspberrypi kernel: usb 1-1.1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
                                      Apr 02 13:17:01 raspberrypi kernel: lan78xx 1-1.1.1:1.0 (unnamed net_device) (uninitialized): No External EEPROM. Setting MAC Speed
                                      Apr 02 13:17:01 raspberrypi kernel: lan78xx 1-1.1.1:1.0 (unnamed net_device) (uninitialized): int urb period 64
                                      Apr 02 13:17:01 raspberrypi kernel: EXT4-fs (mmcblk0p2): mounted filesystem 93c89e92-8f2e-4522-ad32-68faed883d2f ro with ordered data mode. Quota mode: none.
                                      Apr 02 13:17:01 raspberrypi systemd[1]: System time before build time, advancing clock.
                                      Apr 02 13:17:01 raspberrypi kernel: NET: Registered PF_INET6 protocol family
                                      Apr 02 13:17:01 raspberrypi kernel: Segment Routing with IPv6
                                      Apr 02 13:17:01 raspberrypi kernel: In-situ OAM (IOAM) with IPv6
                                      Apr 02 13:17:01 raspberrypi systemd[1]: systemd 252.22-1~deb12u1 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -ID>
                                      Apr 02 13:17:01 raspberrypi systemd[1]: Detected architecture arm64.
                                      Apr 02 13:17:01 raspberrypi systemd[1]: Hostname set to <raspberrypi>.
                                      Apr 02 13:17:01 raspberrypi systemd[1]: Queued start job for default target multi-user.target.
                                      Apr 02 13:17:01 raspberrypi systemd[1]: Created slice system-getty.slice - Slice /system/getty.
                                      Apr 02 13:17:01 raspberrypi systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe.
                                      Apr 02 13:17:01 raspberrypi systemd[1]: Created slice system-systemd\x2dfsck.slice - Slice /system/systemd-fsck.
                                      Apr 02 13:17:01 raspberrypi systemd[1]: Created slice user.slice - User and Session Slice.
                                      Apr 02 13:17:01 raspberrypi systemd[1]: Started systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch.
                                      Apr 02 13:17:01 raspberrypi systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch.
                                      Apr 02 13:17:01 raspberrypi systemd[1]: Set up automount proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point.
                                      Apr 02 13:17:01 raspberrypi systemd[1]: Expecting device dev-disk-by\x2dpartuuid-42fe4a7c\x2d01.device - /dev/disk/by-partuuid/42fe4a7c-01...
                                      Apr 02 13:17:01 raspberrypi systemd[1]: Reached target cryptsetup.target - Local Encrypted Volumes.
                                      Apr 02 13:17:01 raspberrypi systemd[1]: Reached target integritysetup.target - Local Integrity Protected Volumes.
                                      Apr 02 13:17:01 raspberrypi systemd[1]: Reached target paths.target - Path Units.
                                      Apr 02 13:17:01 raspberrypi systemd[1]: Reached target slices.target - Slice Units.
                                      Apr 02 13:17:01 raspberrypi systemd[1]: Reached target swap.target - Swaps.
                                      Apr 02 13:17:01 raspberrypi systemd[1]: Reached target veritysetup.target - Local Verity Protected Volumes.
                                      Apr 02 13:17:01 raspberrypi systemd[1]: Listening on systemd-fsckd.socket - fsck to fsckd communication Socket.
                                      Apr 02 13:17:01 raspberrypi systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe.
                                      Apr 02 13:17:01 raspberrypi systemd[1]: Listening on systemd-journald-audit.socket - Journal Audit Socket.
                                      Apr 02 13:17:01 raspberrypi systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
                                      Apr 02 13:17:01 raspberrypi systemd[1]: Listening on systemd-journald.socket - Journal Socket.
                                      Apr 02 13:17:01 raspberrypi systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket.
                                      Apr 02 13:17:01 raspberrypi systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
                                      Apr 02 13:17:01 raspberrypi systemd[1]: dev-hugepages.mount - Huge Pages File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/mm/hugepages).
                                      Apr 02 13:17:01 raspberrypi systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System...
                                      Apr 02 13:17:01 raspberrypi systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System...
                                      Apr 02 13:17:01 raspberrypi systemd[1]: Mounting sys-kernel-tracing.mount - Kernel Trace File System...
                                      Apr 02 13:17:01 raspberrypi systemd[1]: auth-rpcgss-module.service - Kernel Module supporting RPCSEC_GSS was skipped because of an unmet condition check (ConditionPathExists=/etc/krb5.keytab).
                                      Apr 02 13:17:01 raspberrypi systemd[1]: Starting fake-hwclock.service - Restore / save the current clock...
                                      Apr 02 13:17:01 raspberrypi systemd[1]: Starting keyboard-setup.service - Set the console keyboard layout...
                                      Apr 02 13:17:01 raspberrypi systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes...
                                      Apr 02 13:17:01 raspberrypi systemd[1]: Starting modprobe@configfs.service - Load Kernel Module configfs...
                                      Apr 02 13:17:01 raspberrypi systemd[1]: Starting modprobe@dm_mod.service - Load Kernel Module dm_mod...
                                      Apr 02 13:17:01 raspberrypi systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm...
                                      Apr 02 13:17:01 raspberrypi systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
                                      Apr 02 13:17:01 raspberrypi systemd[1]: Starting modprobe@fuse.service - Load Kernel Module fuse...
                                      Apr 02 13:17:01 raspberrypi systemd[1]: Starting modprobe@loop.service - Load Kernel Module loop...
                                      Apr 02 13:17:01 raspberrypi systemd[1]: systemd-fsck-root.service - File System Check on Root Device was skipped because of an unmet condition check (ConditionPathExists=!/run/initramfs/fsck-root).
                                      Apr 02 13:17:01 raspberrypi systemd[1]: Starting systemd-journald.service - Journal Service...
                                      Apr 02 13:17:01 raspberrypi systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules...
                                      Apr 02 13:17:01 raspberrypi kernel: device-mapper: ioctl: 4.48.0-ioctl (2023-03-01) initialised: dm-devel@redhat.com
                                      Apr 02 13:17:01 raspberrypi systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems...
                                      Apr 02 13:17:01 raspberrypi systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices...
                                      Apr 02 13:17:01 raspberrypi kernel: fuse: init (API version 7.39)
                                      Apr 02 13:17:01 raspberrypi systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System.
                                      Apr 02 13:17:01 raspberrypi systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System.
                                      Apr 02 13:17:01 raspberrypi systemd[1]: Mounted sys-kernel-tracing.mount - Kernel Trace File System.
                                      Apr 02 13:17:01 raspberrypi systemd[1]: Finished fake-hwclock.service - Restore / save the current clock.
                                      Apr 02 13:17:01 raspberrypi systemd[1]: Finished kmod-static-nodes.service - Create List of Static Device Nodes.
                                      Apr 02 13:17:01 raspberrypi systemd[1]: modprobe@configfs.service: Deactivated successfully.
                                      Apr 02 13:17:01 raspberrypi systemd[1]: Finished modprobe@configfs.service - Load Kernel Module configfs.
                                      Apr 02 13:17:01 raspberrypi kernel: EXT4-fs (mmcblk0p2): re-mounted 93c89e92-8f2e-4522-ad32-68faed883d2f r/w. Quota mode: none.
                                      Apr 02 13:17:01 raspberrypi systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
                                      Apr 02 13:17:01 raspberrypi systemd[1]: Finished modprobe@dm_mod.service - Load Kernel Module dm_mod.
                                      Apr 02 13:17:01 raspberrypi systemd[1]: modprobe@drm.service: Deactivated successfully.
                                      Apr 02 13:17:01 raspberrypi systemd[1]: Finished modprobe@drm.service - Load Kernel Module drm.
                                      Apr 02 13:17:01 raspberrypi systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
                                      Apr 02 13:17:01 raspberrypi systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
                                      Apr 02 13:17:01 raspberrypi systemd[1]: modprobe@fuse.service: Deactivated successfully.
                                      Apr 02 13:17:01 raspberrypi systemd[1]: Finished modprobe@fuse.service - Load Kernel Module fuse.
                                      Apr 02 13:17:01 raspberrypi systemd[1]: modprobe@loop.service: Deactivated successfully.
                                      Apr 02 13:17:01 raspberrypi systemd[1]: Finished modprobe@loop.service - Load Kernel Module loop.
                                      Apr 02 13:17:01 raspberrypi systemd[1]: Finished systemd-modules-load.service - Load Kernel Modules.
                                      Apr 02 13:17:01 raspberrypi systemd[1]: Finished systemd-remount-fs.service - Remount Root and Kernel File Systems.
                                      Apr 02 13:17:01 raspberrypi systemd[1]: Mounting sys-fs-fuse-connections.mount - FUSE Control File System...
                                      Apr 02 13:17:01 raspberrypi systemd[1]: Mounting sys-kernel-config.mount - Kernel Configuration File System...
                                      Apr 02 13:17:01 raspberrypi systemd[1]: systemd-firstboot.service - First Boot Wizard was skipped because of an unmet condition check (ConditionFirstBoot=yes).
                                      Apr 02 13:17:01 raspberrypi systemd-journald[228]: Journal started
                                      Apr 02 13:17:01 raspberrypi systemd-journald[228]: Runtime Journal (/run/log/journal/cbb239608c0c466bb3f5fd6a9f701912) is 1.1M, max 9.0M, 7.9M free.
                                      Apr 02 13:17:01 raspberrypi systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore).
                                      Apr 02 13:17:01 raspberrypi fake-hwclock[219]: Tue  2 Apr 11:17:01 UTC 2024
                                      Apr 02 13:17:01 raspberrypi systemd[1]: Starting systemd-random-seed.service - Load/Save Random Seed...
                                      Apr 02 13:17:01 raspberrypi systemd[1]: systemd-repart.service - Repartition Root Disk was skipped because no trigger condition checks were met.
                                      Apr 02 13:17:01 raspberrypi systemd[1]: Starting systemd-sysctl.service - Apply Kernel Variables...
                                      Apr 02 13:17:01 raspberrypi systemd[1]: Starting systemd-sysusers.service - Create System Users...
                                      Apr 02 13:17:01 raspberrypi systemd[1]: Started systemd-journald.service - Journal Service.
                                      Apr 02 13:17:01 raspberrypi systemd[1]: Mounted sys-fs-fuse-connections.mount - FUSE Control File System.
                                      Apr 02 13:17:01 raspberrypi systemd[1]: Mounted sys-kernel-config.mount - Kernel Configuration File System.
                                      Apr 02 13:17:01 raspberrypi systemd[1]: Starting systemd-journal-flush.service - Flush Journal to Persistent Storage...
                                      Apr 02 13:17:01 raspberrypi systemd[1]: Finished systemd-random-seed.service - Load/Save Random Seed.
                                      Apr 02 13:17:01 raspberrypi systemd[1]: first-boot-complete.target - First Boot Complete was skipped because of an unmet condition check (ConditionFirstBoot=yes).
                                      Apr 02 13:17:01 raspberrypi systemd[1]: Finished systemd-sysctl.service - Apply Kernel Variables.
                                      Apr 02 13:17:01 raspberrypi systemd-journald[228]: Time spent on flushing to /var/log/journal/cbb239608c0c466bb3f5fd6a9f701912 is 33.395ms for 348 entries.
                                      Apr 02 13:17:01 raspberrypi systemd-journald[228]: System Journal (/var/log/journal/cbb239608c0c466bb3f5fd6a9f701912) is 336.0M, max 2.8G, 2.5G free.
                                      Apr 02 13:17:02 raspberrypi systemd-journald[228]: Received client request to flush runtime journal.
                                      Apr 02 13:17:02 raspberrypi systemd-journald[228]: File /var/log/journal/cbb239608c0c466bb3f5fd6a9f701912/system.journal corrupted or uncleanly shut down, renaming and replacing.
                                      Apr 02 13:17:01 raspberrypi systemd[1]: Finished systemd-sysusers.service - Create System Users.
                                      Apr 02 13:17:01 raspberrypi systemd[1]: Starting systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev...
                                      Apr 02 13:17:01 raspberrypi systemd[1]: Finished keyboard-setup.service - Set the console keyboard layout.
                                      Apr 02 13:17:01 raspberrypi systemd[1]: Finished systemd-udev-trigger.service - Coldplug All udev Devices.
                                      Apr 02 13:17:01 raspberrypi systemd[1]: Starting ifupdown-pre.service - Helper to synchronize boot up for ifupdown...
                                      Apr 02 13:17:01 raspberrypi systemd[1]: Finished ifupdown-pre.service - Helper to synchronize boot up for ifupdown.
                                      Apr 02 13:17:01 raspberrypi systemd[1]: Finished systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev.
                                      Apr 02 13:17:01 raspberrypi systemd[1]: Reached target local-fs-pre.target - Preparation for Local File Systems.
                                      Apr 02 13:17:01 raspberrypi systemd[1]: Starting systemd-udevd.service - Rule-based Manager for Device Events and Files...
                                      Apr 02 13:17:02 raspberrypi systemd-udevd[255]: Using default interface naming scheme 'v252'.
                                      Apr 02 13:17:02 raspberrypi systemd[1]: Finished systemd-journal-flush.service - Flush Journal to Persistent Storage.
                                      Apr 02 13:17:02 raspberrypi systemd[1]: Started systemd-udevd.service - Rule-based Manager for Device Events and Files.
                                      Apr 02 13:17:02 raspberrypi systemd[1]: Found device dev-disk-by\x2dpartuuid-42fe4a7c\x2d01.device - /dev/disk/by-partuuid/42fe4a7c-01.
                                      Apr 02 13:17:02 raspberrypi mtp-probe[271]: checking bus 1, device 4: "/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1/1-1.1.1"
                                      Apr 02 13:17:02 raspberrypi systemd[1]: Starting systemd-fsck@dev-disk-by\x2dpartuuid-42fe4a7c\x2d01.service - File System Check on /dev/disk/by-partuuid/42fe4a7c-01...
                                      Apr 02 13:17:02 raspberrypi mtp-probe[271]: bus: 1, device: 4 was not an MTP device
                                      Apr 02 13:17:02 raspberrypi systemd[1]: Started systemd-fsckd.service - File System Check Daemon to report status.
                                      Apr 02 13:17:03 raspberrypi kernel: vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
                                      Apr 02 13:17:03 raspberrypi kernel: rpi-gpiomem 3f200000.gpiomem: window base 0x3f200000 size 0x00001000
                                      Apr 02 13:17:03 raspberrypi kernel: rpi-gpiomem 3f200000.gpiomem: initialised 1 regions as /dev/gpiomem
                                      Apr 02 13:17:03 raspberrypi kernel: bcm2835_vc_sm_cma_probe: Videocore shared memory driver
                                      Apr 02 13:17:03 raspberrypi kernel: [vc_sm_connected_init]: start
                                      Apr 02 13:17:03 raspberrypi kernel: [vc_sm_connected_init]: installed successfully
                                      Apr 02 13:17:03 raspberrypi kernel: mc: Linux media interface: v0.10
                                      Apr 02 13:17:03 raspberrypi systemd-fsck[276]: fsck.fat 4.2 (2021-01-31)
                                      Apr 02 13:17:03 raspberrypi systemd-fsck[276]: There are differences between boot sector and its backup.
                                      Apr 02 13:17:03 raspberrypi systemd-fsck[276]: This is mostly harmless. Differences: (offset:original/backup)
                                      Apr 02 13:17:03 raspberrypi systemd-fsck[276]:   65:01/00
                                      Apr 02 13:17:03 raspberrypi systemd-fsck[276]:   Not automatically fixing this.
                                      Apr 02 13:17:03 raspberrypi systemd-fsck[276]: Dirty bit is set. Fs was not properly unmounted and some data may be corrupt.
                                      Apr 02 13:17:03 raspberrypi systemd-fsck[276]:  Automatically removing dirty bit.
                                      Apr 02 13:17:03 raspberrypi systemd-fsck[276]: *** Filesystem was changed ***
                                      Apr 02 13:17:03 raspberrypi systemd-fsck[276]: Writing changes.
                                      Apr 02 13:17:03 raspberrypi systemd-fsck[276]: /dev/mmcblk0p1: 365 files, 31795/261115 clusters
                                      Apr 02 13:17:03 raspberrypi systemd[1]: Finished systemd-fsck@dev-disk-by\x2dpartuuid-42fe4a7c\x2d01.service - File System Check on /dev/disk/by-partuuid/42fe4a7c-01.
                                      Apr 02 13:17:03 raspberrypi systemd[1]: Mounting boot-firmware.mount - /boot/firmware...
                                      Apr 02 13:17:03 raspberrypi systemd[1]: Mounted boot-firmware.mount - /boot/firmware.
                                      Apr 02 13:17:03 raspberrypi systemd[1]: Reached target local-fs.target - Local File Systems.
                                      Apr 02 13:17:03 raspberrypi systemd[1]: apparmor.service - Load AppArmor profiles was skipped because of an unmet condition check (ConditionSecurity=apparmor).
                                      Apr 02 13:17:03 raspberrypi kernel: snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
                                      Apr 02 13:17:03 raspberrypi systemd[1]: Starting console-setup.service - Set console font and keymap...
                                      Apr 02 13:17:03 raspberrypi systemd[1]: Starting networking.service - Raise network interfaces...
                                      Apr 02 13:17:03 raspberrypi systemd[1]: Starting systemd-binfmt.service - Set Up Additional Binary Formats...
                                      Apr 02 13:17:03 raspberrypi systemd[1]: systemd-machine-id-commit.service - Commit a transient machine-id on disk was skipped because of an unmet condition check (ConditionPathIsMountPoint=/etc/machine-id).
                                      Apr 02 13:17:03 raspberrypi kernel: bcm2835_audio bcm2835_audio: card created with 8 channels
                                      Apr 02 13:17:03 raspberrypi systemd[1]: Starting systemd-tmpfiles-setup.service - Create Volatile Files and Directories...
                                      Apr 02 13:17:03 raspberrypi systemd[1]: Finished console-setup.service - Set console font and keymap.
                                      Apr 02 13:17:03 raspberrypi kernel: videodev: Linux video capture interface: v2.00
                                      Apr 02 13:17:03 raspberrypi kernel: Bluetooth: Core ver 2.22
                                      Apr 02 13:17:03 raspberrypi kernel: NET: Registered PF_BLUETOOTH protocol family
                                      Apr 02 13:17:03 raspberrypi kernel: Bluetooth: HCI device and connection manager initialized
                                      Apr 02 13:17:03 raspberrypi kernel: Bluetooth: HCI socket layer initialized
                                      Apr 02 13:17:03 raspberrypi kernel: Bluetooth: L2CAP socket layer initialized
                                      Apr 02 13:17:03 raspberrypi kernel: Bluetooth: SCO socket layer initialized
                                      Apr 02 13:17:03 raspberrypi systemd[1]: proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 314 (systemd-binfmt)
                                      Apr 02 13:17:03 raspberrypi systemd[1]: Mounting proc-sys-fs-binfmt_misc.mount - Arbitrary Executable File Formats File System...
                                      Apr 02 13:17:03 raspberrypi kernel: Bluetooth: HCI UART driver ver 2.3
                                      Apr 02 13:17:03 raspberrypi kernel: Bluetooth: HCI UART protocol H4 registered
                                      Apr 02 13:17:03 raspberrypi kernel: Bluetooth: HCI UART protocol Three-wire (H5) registered
                                      Apr 02 13:17:03 raspberrypi kernel: Bluetooth: HCI UART protocol Broadcom registered
                                      Apr 02 13:17:03 raspberrypi kernel: hci_uart_bcm serial0-0: supply vbat not found, using dummy regulator
                                      Apr 02 13:17:03 raspberrypi kernel: hci_uart_bcm serial0-0: supply vddio not found, using dummy regulator
                                      Apr 02 13:17:03 raspberrypi kernel: bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
                                      Apr 02 13:17:03 raspberrypi kernel: cfg80211: Loading compiled-in X.509 certificates for regulatory database
                                      Apr 02 13:17:03 raspberrypi systemd[1]: Finished systemd-tmpfiles-setup.service - Create Volatile Files and Directories.
                                      Apr 02 13:17:03 raspberrypi kernel: Loaded X.509 cert 'benh@debian.org: 577e021cb980e0e820821ba7b54b4961b8b4fadf'
                                      Apr 02 13:17:03 raspberrypi kernel: Loaded X.509 cert 'romain.perier@gmail.com: 3abbc6ec146e09d1b6016ab9d6cf71dd233f0328'
                                      Apr 02 13:17:03 raspberrypi kernel: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
                                      Apr 02 13:17:03 raspberrypi kernel: Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
                                      Apr 02 13:17:03 raspberrypi kernel: uart-pl011 3f201000.serial: no DMA platform data
                                      Apr 02 13:17:03 raspberrypi systemd[1]: Mounting run-rpc_pipefs.mount - RPC Pipe File System...
                                      Apr 02 13:17:03 raspberrypi systemd[1]: Starting systemd-timesyncd.service - Network Time Synchronization...
                                      Apr 02 13:17:03 raspberrypi systemd[1]: Starting systemd-update-utmp.service - Record System Boot/Shutdown in UTMP...
                                      Apr 02 13:17:03 raspberrypi systemd[1]: Mounted run-rpc_pipefs.mount - RPC Pipe File System.
                                      Apr 02 13:17:03 raspberrypi systemd[1]: Reached target rpc_pipefs.target.
                                      Apr 02 13:17:03 raspberrypi systemd[1]: rpc-gssd.service - RPC security service for NFS client and server was skipped because of an unmet condition check (ConditionPathExists=/etc/krb5.keytab).
                                      Apr 02 13:17:03 raspberrypi systemd[1]: Reached target nfs-client.target - NFS client services.
                                      Apr 02 13:17:03 raspberrypi systemd[1]: Reached target remote-fs-pre.target - Preparation for Remote File Systems.
                                      Apr 02 13:17:03 raspberrypi systemd[1]: Reached target remote-fs.target - Remote File Systems.
                                      Apr 02 13:17:03 raspberrypi kernel: bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
                                      Apr 02 13:17:03 raspberrypi kernel: bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
                                      Apr 02 13:17:03 raspberrypi systemd[1]: Mounted proc-sys-fs-binfmt_misc.mount - Arbitrary Executable File Formats File System.
                                      Apr 02 13:17:03 raspberrypi kernel: bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
                                      Apr 02 13:17:04 raspberrypi kernel: bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
                                      Apr 02 13:17:04 raspberrypi kernel: bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
                                      Apr 02 13:17:04 raspberrypi systemd[1]: Finished systemd-binfmt.service - Set Up Additional Binary Formats.
                                      Apr 02 13:17:04 raspberrypi kernel: Bluetooth: hci0: BCM: chip id 107
                                      Apr 02 13:17:04 raspberrypi kernel: Bluetooth: hci0: BCM: features 0x2f
                                      Apr 02 13:17:04 raspberrypi kernel: bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
                                      Apr 02 13:17:04 raspberrypi kernel: Bluetooth: hci0: BCM4345C0
                                      Apr 02 13:17:04 raspberrypi kernel: Bluetooth: hci0: BCM4345C0 (003.001.025) build 0000
                                      Apr 02 13:17:04 raspberrypi kernel: bcm2835-codec bcm2835-codec: Device registered as /dev/video10
                                      Apr 02 13:17:04 raspberrypi kernel: bcm2835-codec bcm2835-codec: Loaded V4L2 decode
                                      Apr 02 13:17:04 raspberrypi systemd[1]: Finished systemd-update-utmp.service - Record System Boot/Shutdown in UTMP.
                                      Apr 02 13:17:04 raspberrypi kernel: bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
                                      Apr 02 13:17:04 raspberrypi kernel: bcm2835-isp bcm2835-isp: Register output node 0 with media controller
                                      Apr 02 13:17:04 raspberrypi kernel: bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
                                      Apr 02 13:17:04 raspberrypi kernel: bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
                                      Apr 02 13:17:04 raspberrypi kernel: bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
                                      Apr 02 13:17:04 raspberrypi kernel: bcm2835-codec bcm2835-codec: Device registered as /dev/video11
                                      Apr 02 13:17:04 raspberrypi kernel: bcm2835-codec bcm2835-codec: Loaded V4L2 encode
                                      Apr 02 13:17:04 raspberrypi kernel: bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video20
                                      Apr 02 13:17:04 raspberrypi kernel: bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video21
                                      Apr 02 13:17:04 raspberrypi kernel: bcm2835-codec bcm2835-codec: Device registered as /dev/video12
                                      Apr 02 13:17:04 raspberrypi kernel: bcm2835-codec bcm2835-codec: Loaded V4L2 isp
                                      Apr 02 13:17:04 raspberrypi kernel: Bluetooth: hci0: BCM4345C0 'brcm/BCM4345C0.raspberrypi,3-model-b-plus.hcd' Patch
                                      Apr 02 13:17:04 raspberrypi kernel: bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video22
                                      Apr 02 13:17:04 raspberrypi kernel: bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video23
                                      Apr 02 13:17:04 raspberrypi kernel: bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
                                      Apr 02 13:17:04 raspberrypi kernel: bcm2835-codec bcm2835-codec: Device registered as /dev/video18
                                      Apr 02 13:17:04 raspberrypi kernel: bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
                                      Apr 02 13:17:04 raspberrypi kernel: bcm2835-codec bcm2835-codec: Device registered as /dev/video31
                                      Apr 02 13:17:04 raspberrypi kernel: bcm2835-codec bcm2835-codec: Loaded V4L2 encode_image
                                      Apr 02 13:17:04 raspberrypi kernel: brcmfmac: F1 signature read @0x18000000=0x15264345
                                      Apr 02 13:17:04 raspberrypi kernel: brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
                                      Apr 02 13:17:04 raspberrypi kernel: usbcore: registered new interface driver brcmfmac
                                      Apr 02 13:17:04 raspberrypi kernel: brcmfmac_wcc: brcmf_wcc_attach: executing
                                      Apr 02 13:17:04 raspberrypi systemd[1]: Finished networking.service - Raise network interfaces.
                                      Apr 02 13:17:04 raspberrypi kernel: brcmfmac: brcmf_c_process_txcap_blob: no txcap_blob available (err=-2)
                                      Apr 02 13:17:04 raspberrypi kernel: brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Apr 15 2021 03:03:20 version 7.45.234 (4ca95bb CY) FWID 01-996384e2
                                      Apr 02 13:17:04 raspberrypi systemd-timesyncd[350]: System clock time unset or jumped backwards, restoring from recorded timestamp: Tue 2024-04-02 13:25:36 CEST
                                      -- Boot b7884cea308a45649bd71622d377e26c --
                                      Apr 02 13:18:43 raspberrypi sudo[5259]:       pi : TTY=pts/0 ; PWD=/opt/iobroker ; USER=iobroker ; COMMAND=/usr/bin/node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js update -u
                                      Apr 02 13:18:43 raspberrypi sudo[5259]: pam_unix(sudo:session): session opened for user iobroker(uid=1001) by pi(uid=1000)
                                      Apr 02 13:18:54 raspberrypi bash[560]: Send diag info: {"uuid":"ef586440-19d1-b1ec-8a78-bce70de9dfb3","language":"de","country":"Germany","hosts":[{"version":"5.0.19","platform":"Javascript/Node.js","type":"lin>
                                      Apr 02 13:18:54 raspberrypi sudo[5259]: pam_unix(sudo:session): session closed for user iobroker
                                      Apr 02 13:19:00 raspberrypi sudo[5313]:       pi : TTY=pts/0 ; PWD=/opt/iobroker ; USER=iobroker ; COMMAND=/usr/bin/node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js list instances
                                      Apr 02 13:19:00 raspberrypi sudo[5313]: pam_unix(sudo:session): session opened for user iobroker(uid=1001) by pi(uid=1000)
                                      Apr 02 13:19:06 raspberrypi sudo[5313]: pam_unix(sudo:session): session closed for user iobroker
                                      Apr 02 13:19:06 raspberrypi sudo[5324]:       pi : TTY=pts/0 ; PWD=/opt/iobroker ; USER=iobroker ; COMMAND=/usr/bin/node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js repo list
                                      Apr 02 13:19:06 raspberrypi sudo[5324]: pam_unix(sudo:session): session opened for user iobroker(uid=1001) by pi(uid=1000)
                                      Apr 02 13:19:11 raspberrypi sudo[5324]: pam_unix(sudo:session): session closed for user iobroker
                                      Apr 02 13:19:11 raspberrypi sudo[5335]:       pi : TTY=pts/0 ; PWD=/opt/iobroker ; USER=iobroker ; COMMAND=/usr/bin/node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js -v
                                      Apr 02 13:19:11 raspberrypi sudo[5335]: pam_unix(sudo:session): session opened for user iobroker(uid=1001) by pi(uid=1000)
                                      Apr 02 13:19:14 raspberrypi sudo[5335]: pam_unix(sudo:session): session closed for user iobroker
                                      Apr 02 13:19:14 raspberrypi sudo[5350]:       pi : TTY=pts/0 ; PWD=/opt/iobroker ; USER=iobroker ; COMMAND=/usr/bin/node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js version admin
                                      Apr 02 13:19:14 raspberrypi sudo[5350]: pam_unix(sudo:session): session opened for user iobroker(uid=1001) by pi(uid=1000)
                                      Apr 02 13:19:17 raspberrypi sudo[5350]: pam_unix(sudo:session): session closed for user iobroker
                                      Apr 02 13:19:17 raspberrypi sudo[5361]:       pi : TTY=pts/0 ; PWD=/opt/iobroker ; USER=iobroker ; COMMAND=/usr/bin/node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js status
                                      Apr 02 13:19:17 raspberrypi sudo[5361]: pam_unix(sudo:session): session opened for user iobroker(uid=1001) by pi(uid=1000)
                                      Apr 02 13:19:22 raspberrypi sudo[5361]: pam_unix(sudo:session): session closed for user iobroker
                                      Apr 02 13:19:22 raspberrypi sudo[5372]:       pi : TTY=pts/0 ; PWD=/opt/iobroker ; USER=iobroker ; COMMAND=/usr/bin/node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js list instances
                                      Apr 02 13:19:22 raspberrypi sudo[5372]: pam_unix(sudo:session): session opened for user iobroker(uid=1001) by pi(uid=1000)
                                      Apr 02 13:19:27 raspberrypi sudo[5372]: pam_unix(sudo:session): session closed for user iobroker
                                      Apr 02 13:19:27 raspberrypi sudo[3878]: pam_unix(sudo:session): session closed for user iobroker
                                      Apr 02 13:21:26 raspberrypi systemd[2965]: Activating special unit exit.target...
                                      Apr 02 13:21:26 raspberrypi systemd[2965]: Stopped target default.target - Main User Target.
                                      Apr 02 13:21:26 raspberrypi systemd[2965]: Stopped target basic.target - Basic System.
                                      Apr 02 13:21:26 raspberrypi systemd[2965]: Stopped target paths.target - Paths.
                                      Apr 02 13:21:26 raspberrypi systemd[2965]: Stopped target sockets.target - Sockets.
                                      Apr 02 13:21:26 raspberrypi systemd[2965]: Stopped target timers.target - Timers.
                                      Apr 02 13:21:26 raspberrypi systemd[2965]: Closed dbus.socket - D-Bus User Message Bus Socket.
                                      Apr 02 13:21:26 raspberrypi systemd[2965]: Closed dirmngr.socket - GnuPG network certificate management daemon.
                                      Apr 02 13:21:26 raspberrypi systemd[2965]: Closed gpg-agent-browser.socket - GnuPG cryptographic agent and passphrase cache (access for web browsers).
                                      Apr 02 13:21:26 raspberrypi systemd[2965]: Closed gpg-agent-extra.socket - GnuPG cryptographic agent and passphrase cache (restricted).
                                      Apr 02 13:21:26 raspberrypi systemd[2965]: Closed gpg-agent-ssh.socket - GnuPG cryptographic agent (ssh-agent emulation).
                                      Apr 02 13:21:26 raspberrypi systemd[2965]: Closed gpg-agent.socket - GnuPG cryptographic agent and passphrase cache.
                                      Apr 02 13:21:26 raspberrypi systemd[2965]: Removed slice app.slice - User Application Slice.
                                      Apr 02 13:21:26 raspberrypi systemd[2965]: Reached target shutdown.target - Shutdown.
                                      Apr 02 13:21:26 raspberrypi systemd[2965]: Finished systemd-exit.service - Exit the Session.
                                      Apr 02 13:21:26 raspberrypi systemd[2965]: Reached target exit.target - Exit the Session.
                                      Apr 02 13:21:30 raspberrypi systemd[5397]: Queued start job for default target default.target.
                                      Apr 02 13:21:30 raspberrypi systemd[5397]: Created slice app.slice - User Application Slice.
                                      Apr 02 13:21:30 raspberrypi systemd[5397]: Reached target paths.target - Paths.
                                      Apr 02 13:21:30 raspberrypi systemd[5397]: Reached target timers.target - Timers.
                                      Apr 02 13:21:30 raspberrypi systemd[5397]: Starting dbus.socket - D-Bus User Message Bus Socket...
                                      Apr 02 13:21:30 raspberrypi systemd[5397]: Listening on dirmngr.socket - GnuPG network certificate management daemon.
                                      Apr 02 13:21:30 raspberrypi systemd[5397]: Listening on gpg-agent-browser.socket - GnuPG cryptographic agent and passphrase cache (access for web browsers).
                                      Apr 02 13:21:30 raspberrypi systemd[5397]: Listening on gpg-agent-extra.socket - GnuPG cryptographic agent and passphrase cache (restricted).
                                      Apr 02 13:21:30 raspberrypi systemd[5397]: Listening on gpg-agent-ssh.socket - GnuPG cryptographic agent (ssh-agent emulation).
                                      Apr 02 13:21:30 raspberrypi systemd[5397]: Listening on gpg-agent.socket - GnuPG cryptographic agent and passphrase cache.
                                      Apr 02 13:21:30 raspberrypi systemd[5397]: Listening on dbus.socket - D-Bus User Message Bus Socket.
                                      Apr 02 13:21:30 raspberrypi systemd[5397]: Reached target sockets.target - Sockets.
                                      Apr 02 13:21:30 raspberrypi systemd[5397]: Reached target basic.target - Basic System.
                                      Apr 02 13:21:30 raspberrypi systemd[5397]: Reached target default.target - Main User Target.
                                      Apr 02 13:21:30 raspberrypi systemd[5397]: Startup finished in 639ms.
                                      Apr 02 13:23:57 raspberrypi systemd[5397]: Activating special unit exit.target...
                                      Apr 02 13:23:57 raspberrypi systemd[5397]: Stopped target default.target - Main User Target.
                                      Apr 02 13:23:57 raspberrypi systemd[5397]: Stopped target basic.target - Basic System.
                                      Apr 02 13:23:57 raspberrypi systemd[5397]: Stopped target paths.target - Paths.
                                      Apr 02 13:23:57 raspberrypi systemd[5397]: Stopped target sockets.target - Sockets.
                                      Apr 02 13:23:57 raspberrypi systemd[5397]: Stopped target timers.target - Timers.
                                      Apr 02 13:23:57 raspberrypi systemd[5397]: Closed dbus.socket - D-Bus User Message Bus Socket.
                                      Apr 02 13:23:57 raspberrypi systemd[5397]: Closed dirmngr.socket - GnuPG network certificate management daemon.
                                      Apr 02 13:23:57 raspberrypi systemd[5397]: Closed gpg-agent-browser.socket - GnuPG cryptographic agent and passphrase cache (access for web browsers).
                                      Apr 02 13:23:57 raspberrypi systemd[5397]: Closed gpg-agent-extra.socket - GnuPG cryptographic agent and passphrase cache (restricted).
                                      Apr 02 13:23:57 raspberrypi systemd[5397]: Closed gpg-agent-ssh.socket - GnuPG cryptographic agent (ssh-agent emulation).
                                      Apr 02 13:23:57 raspberrypi systemd[5397]: Closed gpg-agent.socket - GnuPG cryptographic agent and passphrase cache.
                                      Apr 02 13:23:57 raspberrypi systemd[5397]: Removed slice app.slice - User Application Slice.
                                      Apr 02 13:23:57 raspberrypi systemd[5397]: Reached target shutdown.target - Shutdown.
                                      Apr 02 13:23:57 raspberrypi systemd[5397]: Finished systemd-exit.service - Exit the Session.
                                      Apr 02 13:23:57 raspberrypi systemd[5397]: Reached target exit.target - Exit the Session.
                                      Apr 02 13:23:59 raspberrypi systemd[5439]: Queued start job for default target default.target.
                                      Apr 02 13:23:59 raspberrypi systemd[5439]: Created slice app.slice - User Application Slice.
                                      Apr 02 13:23:59 raspberrypi systemd[5439]: Reached target paths.target - Paths.
                                      Apr 02 13:23:59 raspberrypi systemd[5439]: Reached target timers.target - Timers.
                                      Apr 02 13:23:59 raspberrypi systemd[5439]: Starting dbus.socket - D-Bus User Message Bus Socket...
                                      Apr 02 13:23:59 raspberrypi systemd[5439]: Listening on dirmngr.socket - GnuPG network certificate management daemon.
                                      Apr 02 13:23:59 raspberrypi systemd[5439]: Listening on gpg-agent-browser.socket - GnuPG cryptographic agent and passphrase cache (access for web browsers).
                                      Apr 02 13:23:59 raspberrypi systemd[5439]: Listening on gpg-agent-extra.socket - GnuPG cryptographic agent and passphrase cache (restricted).
                                      Apr 02 13:23:59 raspberrypi systemd[5439]: Listening on gpg-agent-ssh.socket - GnuPG cryptographic agent (ssh-agent emulation).
                                      Apr 02 13:23:59 raspberrypi systemd[5439]: Listening on gpg-agent.socket - GnuPG cryptographic agent and passphrase cache.
                                      Apr 02 13:23:59 raspberrypi systemd[5439]: Listening on dbus.socket - D-Bus User Message Bus Socket.
                                      Apr 02 13:23:59 raspberrypi systemd[5439]: Reached target sockets.target - Sockets.
                                      Apr 02 13:23:59 raspberrypi systemd[5439]: Reached target basic.target - Basic System.
                                      Apr 02 13:23:59 raspberrypi systemd[5439]: Reached target default.target - Main User Target.
                                      Apr 02 13:23:59 raspberrypi systemd[5439]: Startup finished in 431ms.
                                      -- Boot d66f20c09a414eedbb8735a9bf7f9e31 --
                                      Apr 02 13:25:36 raspberrypi systemd[1]: Started systemd-timesyncd.service - Network Time Synchronization.
                                      Apr 02 13:25:36 raspberrypi systemd[1]: Reached target sysinit.target - System Initialization.
                                      Apr 02 13:25:36 raspberrypi systemd[1]: Started systemd-tmpfiles-clean.timer - Daily Cleanup of Temporary Directories.
                                      Apr 02 13:25:36 raspberrypi systemd[1]: Reached target time-set.target - System Time Set.
                                      Apr 02 13:25:36 raspberrypi systemd[1]: Started apt-daily.timer - Daily apt download activities.
                                      Apr 02 13:25:36 raspberrypi systemd[1]: Started apt-daily-upgrade.timer - Daily apt upgrade and clean activities.
                                      Apr 02 13:25:36 raspberrypi systemd[1]: Started dpkg-db-backup.timer - Daily dpkg database backup timer.
                                      Apr 02 13:25:36 raspberrypi systemd[1]: Started e2scrub_all.timer - Periodic ext4 Online Metadata Check for All Filesystems.
                                      Apr 02 13:25:36 raspberrypi systemd[1]: Started fstrim.timer - Discard unused blocks once a week.
                                      Apr 02 13:25:36 raspberrypi systemd[1]: Started logrotate.timer - Daily rotation of log files.
                                      Apr 02 13:25:36 raspberrypi systemd[1]: Started man-db.timer - Daily man-db regeneration.
                                      Apr 02 13:25:36 raspberrypi systemd[1]: Reached target timers.target - Timer Units.
                                      Apr 02 13:25:36 raspberrypi systemd[1]: Listening on avahi-daemon.socket - Avahi mDNS/DNS-SD Stack Activation Socket.
                                      Apr 02 13:25:36 raspberrypi systemd[1]: Listening on dbus.socket - D-Bus System Message Bus Socket.
                                      Apr 02 13:25:36 raspberrypi systemd[1]: Listening on triggerhappy.socket.
                                      Apr 02 13:25:36 raspberrypi systemd[1]: Reached target sockets.target - Socket Units.
                                      Apr 02 13:25:36 raspberrypi systemd[1]: systemd-pcrphase-sysinit.service - TPM2 PCR Barrier (Initialization) was skipped because of an unmet condition check (ConditionPathExists=/sys/firmware/efi/efivars/StubPc>
                                      Apr 02 13:25:36 raspberrypi systemd[1]: Reached target basic.target - Basic System.
                                      Apr 02 13:25:36 raspberrypi systemd[1]: Starting avahi-daemon.service - Avahi mDNS/DNS-SD Stack...
                                      Apr 02 13:25:36 raspberrypi systemd[1]: Started cron.service - Regular background program processing daemon.
                                      Apr 02 13:25:36 raspberrypi systemd[1]: Starting dbus.service - D-Bus System Message Bus...
                                      Apr 02 13:25:36 raspberrypi systemd[1]: Starting dphys-swapfile.service - dphys-swapfile - set up, mount/unmount, and delete a swap file...
                                      Apr 02 13:25:36 raspberrypi cron[425]: (CRON) INFO (pidfile fd = 3)
                                      Apr 02 13:25:36 raspberrypi systemd[1]: Starting e2scrub_reap.service - Remove Stale Online ext4 Metadata Check Snapshots...
                                      Apr 02 13:25:36 raspberrypi systemd[1]: getty-static.service - getty on tty2-tty6 if dbus and logind are not available was skipped because of an unmet condition check (ConditionPathExists=!/usr/bin/dbus-daemon).
                                      Apr 02 13:25:36 raspberrypi systemd[1]: Starting polkit.service - Authorization Manager...
                                      Apr 02 13:25:36 raspberrypi cron[425]: (CRON) INFO (Running @reboot jobs)
                                      Apr 02 13:25:36 raspberrypi systemd[1]: Starting raspi-config.service - LSB: Switch to ondemand cpu governor (unless shift key is pressed)...
                                      Apr 02 13:25:37 raspberrypi systemd[1]: Starting rpi-eeprom-update.service - Check for Raspberry Pi EEPROM updates...
                                      Apr 02 13:25:37 raspberrypi systemd[1]: Starting sshswitch.service - Turn on SSH if /boot/ssh or /boot/firmware/ssh is present...
                                      Apr 02 13:25:37 raspberrypi avahi-daemon[424]: Found user 'avahi' (UID 104) and group 'avahi' (GID 110).
                                      Apr 02 13:25:37 raspberrypi avahi-daemon[424]: Successfully dropped root privileges.
                                      Apr 02 13:25:37 raspberrypi avahi-daemon[424]: avahi-daemon 0.8 starting up.
                                      Apr 02 13:25:37 raspberrypi systemd[1]: Starting systemd-logind.service - User Login Management...
                                      Apr 02 13:25:37 raspberrypi systemd[1]: systemd-pcrphase.service - TPM2 PCR Barrier (User) was skipped because of an unmet condition check (ConditionPathExists=/sys/firmware/efi/efivars/StubPcrKernelImage-4a67b>
                                      Apr 02 13:25:37 raspberrypi kernel: Console: switching to colour dummy device 80x25
                                      Apr 02 13:25:37 raspberrypi systemd[1]: Starting triggerhappy.service - triggerhappy global hotkey daemon...
                                      Apr 02 13:25:37 raspberrypi kernel: vc4-drm soc:gpu: bound 3f400000.hvs (ops vc4_hvs_ops [vc4])
                                      Apr 02 13:25:37 raspberrypi kernel: Bluetooth: hci0: BCM: features 0x2f
                                      Apr 02 13:25:37 raspberrypi kernel: Registered IR keymap rc-cec
                                      Apr 02 13:25:37 raspberrypi kernel: Bluetooth: hci0: BCM43455 37.4MHz Raspberry Pi 3+-0190
                                      Apr 02 13:25:37 raspberrypi kernel: Bluetooth: hci0: BCM4345C0 (003.001.025) build 0382
                                      Apr 02 13:25:37 raspberrypi kernel: rc rc0: vc4-hdmi as /devices/platform/soc/3f902000.hdmi/rc/rc0
                                      Apr 02 13:25:37 raspberrypi kernel: Bluetooth: hci0: BCM: Using default device address (43:45:c0:00:1f:ac)
                                      Apr 02 13:25:37 raspberrypi kernel: input: vc4-hdmi as /devices/platform/soc/3f902000.hdmi/rc/rc0/input0
                                      Apr 02 13:25:37 raspberrypi kernel: input: vc4-hdmi HDMI Jack as /devices/platform/soc/3f902000.hdmi/sound/card1/input1
                                      Apr 02 13:25:37 raspberrypi kernel: vc4-drm soc:gpu: bound 3f902000.hdmi (ops vc4_hdmi_ops [vc4])
                                      Apr 02 13:25:37 raspberrypi kernel: vc4-drm soc:gpu: bound 3f004000.txp (ops vc4_txp_ops [vc4])
                                      Apr 02 13:25:37 raspberrypi kernel: vc4-drm soc:gpu: bound 3f206000.pixelvalve (ops vc4_crtc_ops [vc4])
                                      Apr 02 13:25:37 raspberrypi kernel: vc4-drm soc:gpu: bound 3f207000.pixelvalve (ops vc4_crtc_ops [vc4])
                                      Apr 02 13:25:37 raspberrypi kernel: vc4-drm soc:gpu: bound 3f807000.pixelvalve (ops vc4_crtc_ops [vc4])
                                      Apr 02 13:25:37 raspberrypi kernel: vc4-drm soc:gpu: bound 3fc00000.v3d (ops vc4_v3d_ops [vc4])
                                      Apr 02 13:25:37 raspberrypi kernel: [drm] Initialized vc4 0.0.0 20140616 for soc:gpu on minor 0
                                      Apr 02 13:25:37 raspberrypi kernel: vc4-drm soc:gpu: [drm] Cannot find any crtc or sizes
                                      Apr 02 13:25:37 raspberrypi rpi-eeprom-update[436]: Device does not a have a Raspberry Pi bootloader EEPROM (e.g. Pi 4 or Pi 5). Skipping bootloader update.
                                      Apr 02 13:25:37 raspberrypi systemd[1]: Finished rpi-eeprom-update.service - Check for Raspberry Pi EEPROM updates.
                                      Apr 02 13:25:37 raspberrypi thd[456]: Found socket passed from systemd
                                      Apr 02 13:25:37 raspberrypi systemd[1]: Started triggerhappy.service - triggerhappy global hotkey daemon.
                                      Apr 02 13:25:37 raspberrypi polkitd[433]: Started polkitd version 122
                                      Apr 02 13:25:37 raspberrypi systemd[1]: sshswitch.service: Deactivated successfully.
                                      Apr 02 13:25:37 raspberrypi systemd[1]: Finished sshswitch.service - Turn on SSH if /boot/ssh or /boot/firmware/ssh is present.
                                      Apr 02 13:25:37 raspberrypi dphys-swapfile[427]: want /var/swap=100MByte, checking existing: keeping it
                                      Apr 02 13:25:37 raspberrypi systemd[1]: Started dbus.service - D-Bus System Message Bus.
                                      Apr 02 13:25:37 raspberrypi avahi-daemon[424]: Successfully called chroot().
                                      Apr 02 13:25:37 raspberrypi avahi-daemon[424]: Successfully dropped remaining capabilities.
                                      Apr 02 13:25:37 raspberrypi avahi-daemon[424]: No service file found in /etc/avahi/services.
                                      Apr 02 13:25:37 raspberrypi avahi-daemon[424]: Joining mDNS multicast group on interface lo.IPv6 with address ::1.
                                      Apr 02 13:25:37 raspberrypi avahi-daemon[424]: New relevant interface lo.IPv6 for mDNS.
                                      Apr 02 13:25:37 raspberrypi avahi-daemon[424]: Joining mDNS multicast group on interface lo.IPv4 with address 127.0.0.1.
                                      Apr 02 13:25:37 raspberrypi avahi-daemon[424]: New relevant interface lo.IPv4 for mDNS.
                                      Apr 02 13:25:37 raspberrypi avahi-daemon[424]: Network interface enumeration completed.
                                      Apr 02 13:25:37 raspberrypi avahi-daemon[424]: Registering new address record for ::1 on lo.*.
                                      Apr 02 13:25:37 raspberrypi avahi-daemon[424]: Registering new address record for 127.0.0.1 on lo.IPv4.
                                      Apr 02 13:25:37 raspberrypi kernel: Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SS
                                      Apr 02 13:25:37 raspberrypi polkitd[433]: Loading rules from directory /etc/polkit-1/rules.d
                                      Apr 02 13:25:37 raspberrypi polkitd[433]: Loading rules from directory /usr/share/polkit-1/rules.d
                                      Apr 02 13:25:37 raspberrypi systemd[1]: Starting NetworkManager.service - Network Manager...
                                      Apr 02 13:25:37 raspberrypi systemd[1]: Starting wpa_supplicant.service - WPA supplicant...
                                      Apr 02 13:25:37 raspberrypi polkitd[433]: Finished loading, compiling and executing 4 rules
                                      Apr 02 13:25:37 raspberrypi polkitd[433]: Acquired the name org.freedesktop.PolicyKit1 on the system bus
                                      Apr 02 13:25:37 raspberrypi systemd[1]: Finished dphys-swapfile.service - dphys-swapfile - set up, mount/unmount, and delete a swap file.
                                      Apr 02 13:25:37 raspberrypi systemd[1]: Started avahi-daemon.service - Avahi mDNS/DNS-SD Stack.
                                      Apr 02 13:25:37 raspberrypi systemd[1]: Started polkit.service - Authorization Manager.
                                      Apr 02 13:25:37 raspberrypi systemd[1]: Starting ModemManager.service - Modem Manager...
                                      Apr 02 13:25:37 raspberrypi systemd[1]: Started wpa_supplicant.service - WPA supplicant.
                                      Apr 02 13:25:37 raspberrypi wpa_supplicant[497]: Successfully initialized wpa_supplicant
                                      Apr 02 13:25:37 raspberrypi systemd[1]: e2scrub_reap.service: Deactivated successfully.
                                      Apr 02 13:25:37 raspberrypi systemd[1]: Finished e2scrub_reap.service - Remove Stale Online ext4 Metadata Check Snapshots.
                                      Apr 02 13:25:38 raspberrypi systemd-logind[445]: New seat seat0.
                                      Apr 02 13:25:38 raspberrypi systemd[1]: Started systemd-logind.service - User Login Management.
                                      Apr 02 13:25:38 raspberrypi ModemManager[499]: <info>  ModemManager (version 1.20.4) starting in system bus...
                                      Apr 02 13:25:38 raspberrypi raspi-config[435]: Checking if shift key is held down: No. Switching to ondemand scaling governor.
                                      Apr 02 13:25:38 raspberrypi avahi-daemon[424]: Server startup complete. Host name is raspberrypi.local. Local service cookie is 490308984.
                                      Apr 02 13:25:38 raspberrypi systemd[1]: Started raspi-config.service - LSB: Switch to ondemand cpu governor (unless shift key is pressed).
                                      Apr 02 13:25:38 raspberrypi systemd[1]: Listening on systemd-rfkill.socket - Load/Save RF Kill Switch Status /dev/rfkill Watch.
                                      Apr 02 13:25:38 raspberrypi systemd[1]: Starting systemd-rfkill.service - Load/Save RF Kill Switch Status...
                                      Apr 02 13:25:38 raspberrypi NetworkManager[491]: <info>  [1712057138.6096] NetworkManager (version 1.42.4) is starting... (boot:d66f20c0-9a41-4eed-bb87-35a9bf7f9e31)
                                      Apr 02 13:25:38 raspberrypi NetworkManager[491]: <info>  [1712057138.6099] Read config: /etc/NetworkManager/NetworkManager.conf (lib: no-mac-addr-change.conf)
                                      Apr 02 13:25:38 raspberrypi NetworkManager[491]: <info>  [1712057138.6299] bus-manager: acquired D-Bus service "org.freedesktop.NetworkManager"
                                      Apr 02 13:25:38 raspberrypi systemd[1]: Started NetworkManager.service - Network Manager.
                                      Apr 02 13:25:38 raspberrypi systemd[1]: Created slice system-bthelper.slice - Slice /system/bthelper.
                                      Apr 02 13:25:38 raspberrypi systemd[1]: Reached target network.target - Network.
                                      Apr 02 13:25:38 raspberrypi systemd[1]: Starting NetworkManager-wait-online.service - Network Manager Wait Online...
                                      Apr 02 13:25:38 raspberrypi systemd[1]: Starting hciuart.service - Configure Bluetooth Modems connected by UART...
                                      Apr 02 13:25:38 raspberrypi systemd[1]: Started iobroker.service - ioBroker Server.
                                      Apr 02 13:25:38 raspberrypi NetworkManager[491]: <info>  [1712057138.7626] manager[0x55a90ef000]: monitoring kernel firmware directory '/lib/firmware'.
                                      Apr 02 13:25:38 raspberrypi NetworkManager[491]: <info>  [1712057138.7629] monitoring ifupdown state file '/run/network/ifstate'.
                                      Apr 02 13:25:38 raspberrypi systemd[1]: Starting ssh.service - OpenBSD Secure Shell server...
                                      Apr 02 13:25:38 raspberrypi systemd[1]: Starting systemd-user-sessions.service - Permit User Sessions...
                                      Apr 02 13:25:38 raspberrypi systemd[1]: Started systemd-rfkill.service - Load/Save RF Kill Switch Status.
                                      Apr 02 13:25:38 raspberrypi (udev-worker)[500]: event1: Process '/usr/sbin/th-cmd --socket /var/run/thd.socket --passfd --udev' failed with exit code 1.
                                      Apr 02 13:25:38 raspberrypi dbus-daemon[426]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.7' (uid=0 pid=491 comm="/us>
                                      Apr 02 13:25:38 raspberrypi (udev-worker)[501]: event0: Process '/usr/sbin/th-cmd --socket /var/run/thd.socket --passfd --udev' failed with exit code 1.
                                      Apr 02 13:25:38 raspberrypi systemd-logind[445]: Watching system buttons on /dev/input/event0 (vc4-hdmi)
                                      Apr 02 13:25:38 raspberrypi systemd[1]: hciuart.service: Deactivated successfully.
                                      Apr 02 13:25:38 raspberrypi systemd[1]: Started hciuart.service - Configure Bluetooth Modems connected by UART.
                                      Apr 02 13:25:38 raspberrypi systemd[1]: Finished systemd-user-sessions.service - Permit User Sessions.
                                      Apr 02 13:25:38 raspberrypi systemd[1]: alsa-state.service - Manage Sound Card State (restore and store) was skipped because of an unmet condition check (ConditionPathExists=/etc/alsa/state-daemon.conf).
                                      Apr 02 13:25:38 raspberrypi systemd[1]: Starting alsa-restore.service - Save/Restore Sound Card State...
                                      Apr 02 13:25:38 raspberrypi systemd[1]: Starting bthelper@hci0.service - Raspberry Pi bluetooth helper...
                                      Apr 02 13:25:38 raspberrypi alsactl[593]: alsa-lib main.c:1541:(snd_use_case_mgr_open) error: failed to import hw:0 use case configuration -2
                                      Apr 02 13:25:38 raspberrypi alsactl[593]: alsa-lib main.c:1541:(snd_use_case_mgr_open) error: failed to import hw:1 use case configuration -2
                                      Apr 02 13:25:38 raspberrypi systemd[1]: Starting systemd-hostnamed.service - Hostname Service...
                                      Apr 02 13:25:38 raspberrypi systemd[1]: Finished alsa-restore.service - Save/Restore Sound Card State.
                                      Apr 02 13:25:38 raspberrypi systemd[1]: Reached target sound.target - Sound Card.
                                      Apr 02 13:25:39 raspberrypi bthelper[594]: Raspberry Pi BDADDR already set
                                      Apr 02 13:25:39 raspberrypi systemd[1]: Finished bthelper@hci0.service - Raspberry Pi bluetooth helper.
                                      Apr 02 13:25:39 raspberrypi (uetoothd)[605]: ConfigurationDirectory 'bluetooth' already exists but the mode is different. (File system: 755 ConfigurationDirectoryMode: 555)
                                      Apr 02 13:25:39 raspberrypi systemd[1]: Starting bluetooth.service - Bluetooth service...
                                      Apr 02 13:25:39 raspberrypi dbus-daemon[426]: [system] Successfully activated service 'org.freedesktop.hostname1'
                                      Apr 02 13:25:39 raspberrypi systemd[1]: Started systemd-hostnamed.service - Hostname Service.
                                      Apr 02 13:25:39 raspberrypi NetworkManager[491]: <info>  [1712057139.2087] hostname: hostname: using hostnamed
                                      Apr 02 13:25:39 raspberrypi NetworkManager[491]: <info>  [1712057139.2088] hostname: static hostname changed from (none) to "raspberrypi"
                                      Apr 02 13:25:39 raspberrypi NetworkManager[491]: <info>  [1712057139.2122] dns-mgr: init: dns=default,systemd-resolved rc-manager=symlink (auto)
                                      Apr 02 13:25:39 raspberrypi NetworkManager[491]: <info>  [1712057139.2171] rfkill1: found Wi-Fi radio killswitch (at /sys/devices/platform/soc/3f300000.mmcnr/mmc_host/mmc1/mmc1:0001/mmc1:0001:1/ieee80211/phy0/r>
                                      Apr 02 13:25:39 raspberrypi NetworkManager[491]: <info>  [1712057139.2179] manager[0x55a90ef000]: rfkill: Wi-Fi hardware radio set enabled
                                      Apr 02 13:25:39 raspberrypi NetworkManager[491]: <info>  [1712057139.2180] manager[0x55a90ef000]: rfkill: WWAN hardware radio set enabled
                                      Apr 02 13:25:39 raspberrypi systemd[1]: Started ModemManager.service - Modem Manager.
                                      Apr 02 13:25:39 raspberrypi NetworkManager[491]: <info>  [1712057139.3282] Loaded device plugin: NMAtmManager (/usr/lib/aarch64-linux-gnu/NetworkManager/1.42.4/libnm-device-plugin-adsl.so)
                                      Apr 02 13:25:39 raspberrypi NetworkManager[491]: <info>  [1712057139.4188] Loaded device plugin: NMTeamFactory (/usr/lib/aarch64-linux-gnu/NetworkManager/1.42.4/libnm-device-plugin-team.so)
                                      Apr 02 13:25:39 raspberrypi bluetoothd[605]: Bluetooth daemon 5.66
                                      Apr 02 13:25:39 raspberrypi NetworkManager[491]: <info>  [1712057139.4956] Loaded device plugin: NMWwanFactory (/usr/lib/aarch64-linux-gnu/NetworkManager/1.42.4/libnm-device-plugin-wwan.so)
                                      Apr 02 13:25:39 raspberrypi systemd[1]: Started bluetooth.service - Bluetooth service.
                                      Apr 02 13:25:39 raspberrypi systemd[1]: Reached target bluetooth.target - Bluetooth Support.
                                      Apr 02 13:25:39 raspberrypi bluetoothd[605]: Starting SDP server
                                      Apr 02 13:25:39 raspberrypi NetworkManager[491]: <info>  [1712057139.5681] Loaded device plugin: NMBluezManager (/usr/lib/aarch64-linux-gnu/NetworkManager/1.42.4/libnm-device-plugin-bluetooth.so)
                                      Apr 02 13:25:39 raspberrypi bluetoothd[605]: profiles/audio/vcp.c:vcp_init() D-Bus experimental not enabled
                                      Apr 02 13:25:39 raspberrypi bluetoothd[605]: src/plugin.c:plugin_init() Failed to init vcp plugin
                                      Apr 02 13:25:39 raspberrypi bluetoothd[605]: profiles/audio/mcp.c:mcp_init() D-Bus experimental not enabled
                                      Apr 02 13:25:39 raspberrypi bluetoothd[605]: src/plugin.c:plugin_init() Failed to init mcp plugin
                                      Apr 02 13:25:39 raspberrypi bluetoothd[605]: profiles/audio/bap.c:bap_init() D-Bus experimental not enabled
                                      Apr 02 13:25:39 raspberrypi bluetoothd[605]: src/plugin.c:plugin_init() Failed to init bap plugin
                                      Apr 02 13:25:39 raspberrypi NetworkManager[491]: <info>  [1712057139.6114] Loaded device plugin: NMWifiFactory (/usr/lib/aarch64-linux-gnu/NetworkManager/1.42.4/libnm-device-plugin-wifi.so)
                                      Apr 02 13:25:39 raspberrypi NetworkManager[491]: <info>  [1712057139.6128] manager: rfkill: Wi-Fi enabled by radio killswitch; enabled by state file
                                      Apr 02 13:25:39 raspberrypi NetworkManager[491]: <info>  [1712057139.6133] manager: rfkill: WWAN enabled by radio killswitch; enabled by state file
                                      Apr 02 13:25:39 raspberrypi NetworkManager[491]: <info>  [1712057139.6136] manager: Networking is enabled by state file
                                      Apr 02 13:25:39 raspberrypi dbus-daemon[426]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.7' (uid=0 pid=491 c>
                                      Apr 02 13:25:39 raspberrypi NetworkManager[491]: <info>  [1712057139.6391] settings: Loaded settings plugin: ifupdown ("/usr/lib/aarch64-linux-gnu/NetworkManager/1.42.4/libnm-settings-plugin-ifupdown.so")
                                      Apr 02 13:25:39 raspberrypi NetworkManager[491]: <info>  [1712057139.6393] settings: Loaded settings plugin: keyfile (internal)
                                      Apr 02 13:25:39 raspberrypi NetworkManager[491]: <info>  [1712057139.6394] ifupdown: management mode: unmanaged
                                      Apr 02 13:25:39 raspberrypi NetworkManager[491]: <info>  [1712057139.6395] ifupdown:       interface-parser: parsing file /etc/network/interfaces
                                      Apr 02 13:25:39 raspberrypi NetworkManager[491]: <info>  [1712057139.6396] ifupdown:       interface-parser: source line includes interfaces file(s) /etc/network/interfaces.d/*
                                      Apr 02 13:25:39 raspberrypi NetworkManager[491]: <info>  [1712057139.6398] ifupdown: interfaces file /etc/network/interfaces.d/* doesn't exist
                                      Apr 02 13:25:39 raspberrypi NetworkManager[491]: <info>  [1712057139.6398] ifupdown:       interface-parser: finished parsing file /etc/network/interfaces
                                      Apr 02 13:25:39 raspberrypi sshd[607]: Server listening on 0.0.0.0 port 22.
                                      Apr 02 13:25:39 raspberrypi kernel: Bluetooth: BNEP (Ethernet Emulation) ver 1.3
                                      Apr 02 13:25:39 raspberrypi kernel: Bluetooth: BNEP filters: protocol multicast
                                      Apr 02 13:25:39 raspberrypi kernel: Bluetooth: BNEP socket layer initialized
                                      Apr 02 13:25:39 raspberrypi kernel: Bluetooth: MGMT ver 1.22
                                      Apr 02 13:25:39 raspberrypi sshd[607]: Server listening on :: port 22.
                                      Apr 02 13:25:39 raspberrypi systemd[1]: Starting NetworkManager-dispatcher.service - Network Manager Script Dispatcher Service...
                                      Apr 02 13:25:39 raspberrypi bluetoothd[605]: Bluetooth management interface 1.22 initialized
                                      Apr 02 13:25:39 raspberrypi systemd[1]: Started ssh.service - OpenBSD Secure Shell server.
                                      Apr 02 13:25:39 raspberrypi NetworkManager[491]: <info>  [1712057139.6756] dhcp: init: Using DHCP client 'internal'
                                      Apr 02 13:25:39 raspberrypi NetworkManager[491]: <info>  [1712057139.6781] manager: (lo): new Loopback device (/org/freedesktop/NetworkManager/Devices/1)
                                      Apr 02 13:25:39 raspberrypi kernel: NET: Registered PF_ALG protocol family
                                      Apr 02 13:25:39 raspberrypi dbus-daemon[426]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
                                      Apr 02 13:25:39 raspberrypi systemd[1]: Started NetworkManager-dispatcher.service - Network Manager Script Dispatcher Service.
                                      Apr 02 13:25:39 raspberrypi NetworkManager[491]: <info>  [1712057139.7206] device (lo): state change: unmanaged -> unavailable (reason 'connection-assumed', sys-iface-state: 'external')
                                      Apr 02 13:25:39 raspberrypi NetworkManager[491]: <info>  [1712057139.7233] device (lo): state change: unavailable -> disconnected (reason 'connection-assumed', sys-iface-state: 'external')
                                      Apr 02 13:25:39 raspberrypi NetworkManager[491]: <info>  [1712057139.7264] device (lo): Activation: starting connection 'lo' (d148a8d3-45f3-47eb-b812-67c5df29c130)
                                      Apr 02 13:25:39 raspberrypi NetworkManager[491]: <info>  [1712057139.7313] manager: (eth0): new Ethernet device (/org/freedesktop/NetworkManager/Devices/2)
                                      Apr 02 13:25:39 raspberrypi NetworkManager[491]: <info>  [1712057139.7423] settings: (eth0): created default wired connection 'Wired connection 1'
                                      Apr 02 13:25:39 raspberrypi NetworkManager[491]: <info>  [1712057139.7426] device (eth0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
                                      Apr 02 13:25:39 raspberrypi kernel: lan78xx 1-1.1.1:1.0 eth0: kevent 4 may have been dropped
                                      Apr 02 13:25:39 raspberrypi kernel: lan78xx 1-1.1.1:1.0 eth0: Link is Up - 1Gbps/Full - flow control rx/tx
                                      Apr 02 13:25:39 raspberrypi NetworkManager[491]: <info>  [1712057139.7649] device (wlan0): driver supports Access Point (AP) mode
                                      Apr 02 13:25:39 raspberrypi NetworkManager[491]: <info>  [1712057139.7690] manager: (wlan0): new 802.11 Wi-Fi device (/org/freedesktop/NetworkManager/Devices/3)
                                      Apr 02 13:25:39 raspberrypi NetworkManager[491]: <info>  [1712057139.7711] device (wlan0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
                                      Apr 02 13:25:39 raspberrypi kernel: brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
                                      Apr 02 13:25:39 raspberrypi NetworkManager[491]: <info>  [1712057139.8269] device (lo): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'external')
                                      Apr 02 13:25:39 raspberrypi NetworkManager[491]: <info>  [1712057139.8294] device (lo): state change: prepare -> config (reason 'none', sys-iface-state: 'external')
                                      Apr 02 13:25:39 raspberrypi NetworkManager[491]: <info>  [1712057139.8309] device (lo): state change: config -> ip-config (reason 'none', sys-iface-state: 'external')
                                      Apr 02 13:25:39 raspberrypi NetworkManager[491]: <info>  [1712057139.8333] device (eth0): carrier: link connected
                                      Apr 02 13:25:39 raspberrypi NetworkManager[491]: <info>  [1712057139.8356] device (lo): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'external')
                                      Apr 02 13:25:39 raspberrypi NetworkManager[491]: <info>  [1712057139.8379] device (eth0): state change: unavailable -> disconnected (reason 'carrier-changed', sys-iface-state: 'managed')
                                      Apr 02 13:25:39 raspberrypi NetworkManager[491]: <info>  [1712057139.8413] policy: auto-activating connection 'Wired connection 1' (59344465-0739-3000-9a09-2e54f413eb50)
                                      Apr 02 13:25:39 raspberrypi NetworkManager[491]: <info>  [1712057139.8439] device (eth0): Activation: starting connection 'Wired connection 1' (59344465-0739-3000-9a09-2e54f413eb50)
                                      Apr 02 13:25:39 raspberrypi NetworkManager[491]: <info>  [1712057139.8453] device (eth0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
                                      Apr 02 13:25:39 raspberrypi NetworkManager[491]: <info>  [1712057139.8475] manager: NetworkManager state is now CONNECTING
                                      Apr 02 13:25:39 raspberrypi NetworkManager[491]: <info>  [1712057139.8488] device (eth0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
                                      Apr 02 13:25:39 raspberrypi NetworkManager[491]: <info>  [1712057139.8663] modem-manager: ModemManager available
                                      Apr 02 13:25:39 raspberrypi NetworkManager[491]: <info>  [1712057139.8681] device (eth0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
                                      Apr 02 13:25:39 raspberrypi NetworkManager[491]: <info>  [1712057139.8714] dhcp4 (eth0): activation: beginning transaction (timeout in 45 seconds)
                                      Apr 02 13:25:39 raspberrypi NetworkManager[491]: <info>  [1712057139.8819] device (lo): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'external')
                                      Apr 02 13:25:39 raspberrypi NetworkManager[491]: <info>  [1712057139.8919] device (lo): state change: secondaries -> activated (reason 'none', sys-iface-state: 'external')
                                      Apr 02 13:25:39 raspberrypi NetworkManager[491]: <info>  [1712057139.8941] device (lo): Activation: successful, device activated.
                                      Apr 02 13:25:39 raspberrypi NetworkManager[491]: <info>  [1712057139.8973] dhcp4 (eth0): state changed new lease, address=192.168.178.66
                                      Apr 02 13:25:39 raspberrypi NetworkManager[491]: <info>  [1712057139.8995] policy: set 'Wired connection 1' (eth0) as default for IPv4 routing and DNS
                                      Apr 02 13:25:39 raspberrypi bluetoothd[605]: profiles/sap/server.c:sap_server_register() Sap driver initialization failed.
                                      Apr 02 13:25:39 raspberrypi bluetoothd[605]: sap-server: Operation not permitted (1)
                                      Apr 02 13:25:39 raspberrypi avahi-daemon[424]: Joining mDNS multicast group on interface eth0.IPv4 with address 192.168.178.66.
                                      Apr 02 13:25:39 raspberrypi avahi-daemon[424]: New relevant interface eth0.IPv4 for mDNS.
                                      Apr 02 13:25:39 raspberrypi avahi-daemon[424]: Registering new address record for 192.168.178.66 on eth0.IPv4.
                                      Apr 02 13:25:39 raspberrypi avahi-daemon[424]: Joining mDNS multicast group on interface eth0.IPv6 with address fe80::6d01:3670:f9db:134d.
                                      Apr 02 13:25:39 raspberrypi avahi-daemon[424]: New relevant interface eth0.IPv6 for mDNS.
                                      Apr 02 13:25:39 raspberrypi avahi-daemon[424]: Registering new address record for fe80::6d01:3670:f9db:134d on eth0.*.
                                      Apr 02 13:25:40 raspberrypi NetworkManager[491]: <info>  [1712057140.0212] device (eth0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
                                      Apr 02 13:25:40 raspberrypi bluetoothd[605]: Failed to set privacy: Rejected (0x0b)
                                      Apr 02 13:25:40 raspberrypi NetworkManager[491]: <info>  [1712057140.0763] device (eth0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
                                      Apr 02 13:25:40 raspberrypi NetworkManager[491]: <info>  [1712057140.0771] device (eth0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
                                      Apr 02 13:25:40 raspberrypi NetworkManager[491]: <info>  [1712057140.0787] manager: NetworkManager state is now CONNECTED_SITE
                                      Apr 02 13:25:40 raspberrypi NetworkManager[491]: <info>  [1712057140.0800] device (eth0): Activation: successful, device activated.
                                      Apr 02 13:25:40 raspberrypi NetworkManager[491]: <info>  [1712057140.0819] manager: NetworkManager state is now CONNECTED_GLOBAL
                                      Apr 02 13:25:40 raspberrypi NetworkManager[491]: <info>  [1712057140.1594] device (wlan0): supplicant interface state: internal-starting -> disconnected
                                      Apr 02 13:25:40 raspberrypi NetworkManager[491]: <info>  [1712057140.1598] Wi-Fi P2P device controlled by interface wlan0 created
                                      Apr 02 13:25:40 raspberrypi NetworkManager[491]: <info>  [1712057140.1612] manager: (p2p-dev-wlan0): new 802.11 Wi-Fi P2P device (/org/freedesktop/NetworkManager/Devices/4)
                                      Apr 02 13:25:40 raspberrypi NetworkManager[491]: <info>  [1712057140.1623] device (p2p-dev-wlan0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
                                      Apr 02 13:25:40 raspberrypi NetworkManager[491]: <info>  [1712057140.1645] device (wlan0): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed')
                                      Apr 02 13:25:40 raspberrypi NetworkManager[491]: <info>  [1712057140.1685] device (p2p-dev-wlan0): state change: unavailable -> disconnected (reason 'none', sys-iface-state: 'managed')
                                      Apr 02 13:25:41 raspberrypi ModemManager[499]: <info>  [base-manager] couldn't check support for device '/sys/devices/platform/soc/3f300000.mmcnr/mmc_host/mmc1/mmc1:0001/mmc1:0001:1': not supported by any plugin
                                      Apr 02 13:25:41 raspberrypi ModemManager[499]: <info>  [base-manager] couldn't check support for device '/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1/1-1.1.1': not supported by any plugin
                                      Apr 02 13:25:42 raspberrypi NetworkManager[491]: <info>  [1712057142.1511] dhcp6 (eth0): activation: beginning transaction (timeout in 45 seconds)
                                      Apr 02 13:25:42 raspberrypi NetworkManager[491]: <info>  [1712057142.1538] policy: set 'Wired connection 1' (eth0) as default for IPv6 routing and DNS
                                      Apr 02 13:25:42 raspberrypi avahi-daemon[424]: Leaving mDNS multicast group on interface eth0.IPv6 with address fe80::6d01:3670:f9db:134d.
                                      Apr 02 13:25:42 raspberrypi avahi-daemon[424]: Joining mDNS multicast group on interface eth0.IPv6 with address 2001:9e8:af9f:500:ce7b:5d25:bfe2:ac05.
                                      Apr 02 13:25:42 raspberrypi avahi-daemon[424]: Registering new address record for 2001:9e8:af9f:500:ce7b:5d25:bfe2:ac05 on eth0.*.
                                      Apr 02 13:25:42 raspberrypi avahi-daemon[424]: Withdrawing address record for fe80::6d01:3670:f9db:134d on eth0.
                                      Apr 02 13:25:42 raspberrypi NetworkManager[491]: <info>  [1712057142.1739] dhcp6 (eth0): state changed new lease
                                      Apr 02 13:25:43 raspberrypi systemd[1]: systemd-rfkill.service: Deactivated successfully.
                                      Apr 02 13:25:44 raspberrypi bluetoothd[605]: src/adv_monitor.c:btd_adv_monitor_power_down() Unexpected NULL btd_adv_monitor_manager object upon power down
                                      Apr 02 13:25:44 raspberrypi bthelper[684]: Changing power off succeeded
                                      Apr 02 13:25:44 raspberrypi bthelper[684]: [50B blob data]
                                      Apr 02 13:25:44 raspberrypi bthelper[684]: [54B blob data]
                                      Apr 02 13:25:44 raspberrypi bthelper[603]: Changing power on succeeded
                                      Apr 02 13:25:46 raspberrypi NetworkManager[491]: <info>  [1712057146.9452] manager: startup complete
                                      Apr 02 13:25:46 raspberrypi systemd[1]: Finished NetworkManager-wait-online.service - Network Manager Wait Online.
                                      Apr 02 13:25:46 raspberrypi systemd[1]: Reached target network-online.target - Network is Online.
                                      Apr 02 13:25:47 raspberrypi systemd[1]: Starting rc-local.service - /etc/rc.local Compatibility...
                                      Apr 02 13:25:47 raspberrypi systemd[1]: Starting rpc-statd-notify.service - Notify NFS peers of a restart...
                                      Apr 02 13:25:47 raspberrypi rc.local[689]: My IP address is 192.168.178.66 2001:9e8:af9f:500:ce7b:5d25:bfe2:ac05
                                      Apr 02 13:25:47 raspberrypi systemd[1]: Started rc-local.service - /etc/rc.local Compatibility.
                                      Apr 02 13:25:47 raspberrypi sm-notify[690]: Version 2.6.2 starting
                                      Apr 02 13:25:47 raspberrypi systemd[1]: Started getty@tty1.service - Getty on tty1.
                                      Apr 02 13:25:47 raspberrypi systemd[1]: Reached target getty.target - Login Prompts.
                                      Apr 02 13:25:47 raspberrypi systemd[1]: Reached target multi-user.target - Multi-User System.
                                      Apr 02 13:25:47 raspberrypi systemd[1]: Starting systemd-update-utmp-runlevel.service - Record Runlevel Change in UTMP...
                                      Apr 02 13:25:47 raspberrypi systemd[1]: Started rpc-statd-notify.service - Notify NFS peers of a restart.
                                      Apr 02 13:25:47 raspberrypi systemd[1]: systemd-update-utmp-runlevel.service: Deactivated successfully.
                                      Apr 02 13:25:47 raspberrypi systemd[1]: Finished systemd-update-utmp-runlevel.service - Record Runlevel Change in UTMP.
                                      Apr 02 13:25:47 raspberrypi systemd[1]: Startup finished in 10.848s (kernel) + 15.749s (userspace) = 26.597s.
                                      Apr 02 13:25:47 raspberrypi sshd[682]: Accepted password for pi from 192.168.178.91 port 60498 ssh2
                                      Apr 02 13:25:47 raspberrypi sshd[682]: pam_unix(sshd:session): session opened for user pi(uid=1000) by (uid=0)
                                      Apr 02 13:25:47 raspberrypi systemd[1]: Created slice user-1000.slice - User Slice of UID 1000.
                                      Apr 02 13:25:47 raspberrypi systemd[1]: Starting user-runtime-dir@1000.service - User Runtime Directory /run/user/1000...
                                      Apr 02 13:25:47 raspberrypi systemd-logind[445]: New session 1 of user pi.
                                      Apr 02 13:25:47 raspberrypi systemd[1]: Finished user-runtime-dir@1000.service - User Runtime Directory /run/user/1000.
                                      Apr 02 13:25:47 raspberrypi systemd[1]: Starting user@1000.service - User Manager for UID 1000...
                                      Apr 02 13:25:47 raspberrypi (systemd)[695]: pam_unix(systemd-user:session): session opened for user pi(uid=1000) by (uid=0)
                                      Apr 02 13:25:47 raspberrypi kernel: systemd[695]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
                                      Apr 02 13:25:48 raspberrypi systemd[695]: Queued start job for default target default.target.
                                      Apr 02 13:25:48 raspberrypi systemd-journald[228]: File /var/log/journal/cbb239608c0c466bb3f5fd6a9f701912/user-1000.journal corrupted or uncleanly shut down, renaming and replacing.
                                      Apr 02 13:25:48 raspberrypi systemd[695]: Created slice app.slice - User Application Slice.
                                      Apr 02 13:25:48 raspberrypi bash[565]: ================================== > LOG REDIRECT system.adapter.admin.0 => true [starting]
                                      Apr 02 13:25:48 raspberrypi systemd-journald[228]: File /var/log/journal/cbb239608c0c466bb3f5fd6a9f701912/user-1001.journal corrupted or uncleanly shut down, renaming and replacing.
                                      Apr 02 13:25:48 raspberrypi systemd[695]: Reached target paths.target - Paths.
                                      Apr 02 13:25:48 raspberrypi systemd[695]: Reached target timers.target - Timers.
                                      Apr 02 13:25:48 raspberrypi systemd[695]: Starting dbus.socket - D-Bus User Message Bus Socket...
                                      Apr 02 13:25:48 raspberrypi systemd[695]: Listening on dirmngr.socket - GnuPG network certificate management daemon.
                                      Apr 02 13:25:48 raspberrypi systemd[695]: Listening on gpg-agent-browser.socket - GnuPG cryptographic agent and passphrase cache (access for web browsers).
                                      Apr 02 13:25:48 raspberrypi systemd[695]: Listening on gpg-agent-extra.socket - GnuPG cryptographic agent and passphrase cache (restricted).
                                      Apr 02 13:25:48 raspberrypi systemd[695]: Listening on gpg-agent-ssh.socket - GnuPG cryptographic agent (ssh-agent emulation).
                                      Apr 02 13:25:48 raspberrypi systemd[695]: Listening on gpg-agent.socket - GnuPG cryptographic agent and passphrase cache.
                                      Apr 02 13:25:48 raspberrypi systemd[695]: Listening on dbus.socket - D-Bus User Message Bus Socket.
                                      Apr 02 13:25:48 raspberrypi systemd[695]: Reached target sockets.target - Sockets.
                                      Apr 02 13:25:48 raspberrypi systemd[695]: Reached target basic.target - Basic System.
                                      Apr 02 13:25:48 raspberrypi systemd[695]: Reached target default.target - Main User Target.
                                      Apr 02 13:25:48 raspberrypi systemd[695]: Startup finished in 535ms.
                                        @nftvirus sagte in Iobroker Absturz bei Zigbeeadapter mit Conbee2 einschalten:
                                        Pending Updates: 16
                                        Updaten...
                                        N Offline
                                        N Offline
                                        NFTVirus
                                        @thomas-braun und noch der Iobroker log:
                                        2024-04-02 08:29:06.663 - info: admin.0 (800) ==> Connected system.user.admin from ::ffff:192.168.178.91
                                        2024-04-02 13:25:45.374 - info: host.raspberrypi iobroker.js-controller version 5.0.19 js-controller starting
                                        2024-04-02 13:25:45.386 - info: host.raspberrypi Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
                                        2024-04-02 13:25:45.387 - info: host.raspberrypi hostname: raspberrypi, node: v18.20.0
                                        2024-04-02 13:25:45.390 - info: host.raspberrypi ip addresses: 192.168.178.66 2001:9e8:af9f:500:ce7b:5d25:bfe2:ac05 fe80::6d01:3670:f9db:134d
                                        2024-04-02 13:25:47.899 - info: host.raspberrypi connected to Objects and States
                                        2024-04-02 13:25:47.972 - info: host.raspberrypi added notifications configuration of host
                                        2024-04-02 13:25:49.123 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.nodeCurrent"
                                        2024-04-02 13:25:49.125 - info: host.raspberrypi 7 instances found
                                        2024-04-02 13:25:49.155 - info: host.raspberrypi starting 7 instances
                                        2024-04-02 13:25:49.252 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.nodeNewest"
                                        2024-04-02 13:25:49.274 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.nodeNewestNext"
                                        2024-04-02 13:25:49.341 - info: host.raspberrypi instance system.adapter.admin.0 started with pid 733
                                        2024-04-02 13:25:49.360 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.npmCurrent"
                                        2024-04-02 13:25:49.419 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.npmNewest"
                                        2024-04-02 13:25:49.481 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.npmNewestNext"
                                        2024-04-02 13:25:49.539 - info: host.raspberrypi Some obsolete host states deleted.
                                        2024-04-02 13:25:53.226 - info: host.raspberrypi instance system.adapter.node-red.0 started with pid 744
                                        2024-04-02 13:25:53.659 - error: admin.0 (733) admin.0 already running
                                        2024-04-02 13:25:53.668 - warn: admin.0 (733) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                        2024-04-02 13:25:54.418 - error: host.raspberrypi instance system.adapter.admin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                        2024-04-02 13:25:54.421 - info: host.raspberrypi Restart adapter system.adapter.admin.0 because enabled
                                        2024-04-02 13:25:56.262 - error: node-red.0 (744) node-red.0 already running
                                        2024-04-02 13:25:56.269 - warn: node-red.0 (744) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                        2024-04-02 13:25:56.846 - error: host.raspberrypi instance system.adapter.node-red.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                        2024-04-02 13:25:56.848 - info: host.raspberrypi Restart adapter system.adapter.node-red.0 because enabled
                                        2024-04-02 13:25:57.208 - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 755
                                        2024-04-02 13:25:59.984 - error: backitup.0 (755) backitup.0 already running
                                        2024-04-02 13:25:59.991 - warn: backitup.0 (755) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                        2024-04-02 13:26:00.581 - error: host.raspberrypi instance system.adapter.backitup.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                        2024-04-02 13:26:00.582 - info: host.raspberrypi Restart adapter system.adapter.backitup.0 because enabled
                                        2024-04-02 13:26:01.205 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 768
                                        2024-04-02 13:26:05.220 - info: host.raspberrypi instance system.adapter.mqtt.0 started with pid 775
                                        2024-04-02 13:26:08.482 - error: mqtt.0 (775) mqtt.0 already running
                                        2024-04-02 13:26:08.491 - warn: mqtt.0 (775) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                        2024-04-02 13:26:09.103 - error: host.raspberrypi instance system.adapter.mqtt.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                        2024-04-02 13:26:09.105 - info: host.raspberrypi Restart adapter system.adapter.mqtt.0 because enabled
                                        2024-04-02 13:26:09.221 - info: host.raspberrypi instance system.adapter.discovery.0 started with pid 786
                                        2024-04-02 13:26:11.457 - info: zigbee.0 (768) starting. Version 1.10.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.20.0, js-controller: 5.0.19
                                        2024-04-02 13:26:11.672 - info: zigbee.0 (768) delete old Backup files. keep only last 10
                                        2024-04-02 13:26:11.676 - info: zigbee.0 (768) Starting Zigbee npm ...
                                        2024-04-02 13:26:12.398 - error: discovery.0 (786) discovery.0 already running
                                        2024-04-02 13:26:12.406 - warn: discovery.0 (786) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                        2024-04-02 13:26:12.474 - info: zigbee.0 (768) Installed Version: iobroker.zigbee@1.10.1
                                        2024-04-02 13:26:13.029 - error: host.raspberrypi instance system.adapter.discovery.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                        2024-04-02 13:26:13.031 - info: host.raspberrypi Restart adapter system.adapter.discovery.0 because enabled
                                        2024-04-02 13:26:13.228 - info: host.raspberrypi instance system.adapter.wled.0 started with pid 809
                                        • N NFTVirus
                                          @nftvirus
                                          Das Dateisystem macht auch die Grätsche.
                                          Und wenn ich mich recht entsinne soll der ModemManager bei conbee auch ausgeschaltet werden.
                                          N 1 Antwort Letzte Antwort
