  4. Tinkerboard All-In-One mit piVCCU CPU Taktung zu hoch ?
40 Beiträge 7 Kommentatoren 5.6k Aufrufe 1 Beobachtet
  • HALH Offline
    HALH Offline
    HAL
    Reicht dir das ?
    cat /proc/interrupts
               CPU0       CPU1       CPU2       CPU3
     17:     194920     795423     141237     143056     GIC-0  29 Level     arch_ti        mer
     18:          0          0          0          0     GIC-0  30 Level     arch_ti        mer
     21:          0          0          0          0     GIC-0 104 Level     rk_time        r
     22:          0          0          0          0     GIC-0 183 Level     arm-pmu
     23:          0          0          0          0     GIC-0 184 Level     arm-pmu
     24:          0          0          0          0     GIC-0 185 Level     arm-pmu
     25:          0          0          0          0     GIC-0 186 Level     arm-pmu
     26:          0          0          0          0     GIC-0  34 Level     ff25000        0.dma-controller
     27:          0          0          0          0     GIC-0  35 Level     ff25000        0.dma-controller
     28:          0          0          0          0     GIC-0  32 Level     ffb2000        0.dma-controller
     29:          0          0          0          0     GIC-0  33 Level     ffb2000        0.dma-controller
     30:     128893          0          0          0     GIC-0  64 Level     dw-mci
     31:      82676          0          0          0     GIC-0  65 Level     dw-mci
     32:          0          0          0          0     GIC-0  68 Level     ff10000        0.saradc
     34:          0          0          0          0     GIC-0  94 Level     ff14000        0.i2c
     35:          0          0          0          0     GIC-0  95 Level     ff15000        0.i2c
     36:          0          0          0          0     GIC-0  96 Level     ff16000        0.i2c
     37:          0          0          0          0     GIC-0  97 Level     ff17000        0.i2c
     39:      13553          0          0          0     GIC-0  88 Level     ff19000        0.serial
     40:        449          0          0          0     GIC-0  89 Level     ttyS2
     43:          7          0          0          0     GIC-0  69 Level     rockchi        p_thermal
     44:          5          0          0       7288     GIC-0  59 Level     eth0
     45:          0          0          0          0     GIC-0  60 Level     eth0
     46:        295          0          0          0     GIC-0  56 Level     ehci_hc        d:usb3
     47:     102973  152101265          0          0     GIC-0  57 Level     ff54000        0.usb, dwc2_hsotg:usb1
     48:          0          0          0          0     GIC-0  55 Level     ff58000        0.usb, ff580000.usb, dwc2_hsotg:usb2
     49:       6180          0          0          0     GIC-0  92 Level     ff65000        0.i2c
     50:          0          0          0          0     GIC-0  93 Level     ff66000        0.i2c
     54:          0          0          0          0     GIC-0  50 Level     ff92000        0.rga
     57:          0          0          0          0     GIC-0  47 Level     ff93000        0.vop
     58:          0          0          0          0     GIC-0  48 Level     ff94000        0.vop
     60:          0          0          0          0     GIC-0 135 Level     ff98000        0.hdmi
     66:          0          0          0          0     GIC-0  38 Level     ffa3000        0.gpu
     67:          0          0          0          0     GIC-0  39 Level     ffa3000        0.gpu
     68:          1          0          0          0     GIC-0  40 Level     ffa3000        0.gpu
     82:          0          0          0          0  rockchip_gpio_irq   4 Level        rk808
     83:          0          0          0          0  rockchip_gpio_irq   5 Edge        GPIO Key Power
    371:          0          0          0          0     rk808   5 Edge      RTC ala        rm
    IPI0:          0          0          0          0  CPU wakeup interrupts
    IPI1:          0          0          0          0  Timer broadcast interrupts
    IPI2:     578319      16448     395298     433155  Rescheduling interrupts
    IPI3:       1697       2425       3611        281  Function call interrupts
    IPI4:          0          0          0          0  CPU stop interrupts
    IPI5:       2038       2166       1292       1332  IRQ work interrupts
    IPI6:          0          0          0          0  completion interrupts
    Err:          0
    ich sehe gerade da fehlt was, wie kann ich das komplett anzeigen ? oder fängt das wirklich mit 17: an ?
    Alle Raspberry ( 5 ) gegen NUC (N100, 16GB Ram und 500GB M2 SSD, extern 2TB SSD ) mit Proxmox 8.3.3 gewechselt. Läuft absolut super !
    (Iobroker, Grafana, Teslalogger, Nextcloud, go2rtc, PiHole, IOB-VIS2, Teslamate, homeassistant nur als test)
      deimos
      Ja, danke.
      Die Zeile hier ist die interessante:
      Irgendwas im dwc2_hsotg läuft gewaltig schief, so viele Interrupts dürfte es nicht geben.
      Viele Grüße
      Alex
      • HALH Offline
        HALH Offline
        HAL
        @deimos:
        Ja, danke.
        Viele Grüße
        Alex `
        :shock: …und damit hast du meine absolut rudimentären Linux Kenntnisse überfordert....
        scheint ja etwas mit dem CUL Adapter auf USB 1 zu tun zu haben... Funktioniert aber einwandfrei.
        Veile Grüße
        Uwe
          deimos
          Vereinfacht ausgedrückt: Ein Interrupt ist ein Signal von Hardware (hier USB Controller) zum Prozessor in Richtung: "Hallo! Hier gibt es was zu tun". Da man nicht immer prüfen muss, ob was zu tun ist, sondern einfach den Befehl "Mach was" bekommt, kann man recht resourcenschonend programmieren.
          Hier ist das Problem aber, dass diese Interrupts auftreten, obwohl die meiste Zeit nichts zu tun ist. Und das dürfte ein Bug sein. Entweder im Kernel oder in der Hardware.
          Und diese Interrupts verhinden vermutlich auch, dass die CPU runtergetacktet von ondemand runtergetacktet wird, weil es dort als Event für anstehende Arbeit interpretiert wird.
          Also ein bißchen wie im Hotel, wenn du immer auf die Glocke haust, der Portier aus der Hinterkammer kommt und dann sagst, ist doch nichts, ich wollte nur mal auf die Glocke hauen und du das in einer Endlosschleife machst. (Nur das du im dem Beispiel vermutlich irgendwann rausgeschmissen wirst. 😉)
          Ich schau mir das die Tage noch etwas genauer an und schiebe das dann Richtung Armbian oder Kernel Issue Tracker.
          Viele Grüße
          Alex
          • HALH Offline
            HALH Offline
            HAL
            Boah Alex, SUPER erklärt :D . Das verstehe sogar ich in meinem biblischen Alter :-)
            keine Ahnung ob das was damit zu tun hat aber im CuxD finde ich folgende Syslog-Messages:
            Nov 30 14:36:25 homematic-ccu2 daemon.warn cuxd[215]: use CUX2801001:11.CMD_QUERY_RET=1 to activate CUX2801001:11.CMD_RETL command!
            Nov 30 14:36:25 homematic-ccu2 daemon.warn cuxd[215]: use CUX2801001:12.CMD_QUERY_RET=1 to activate CUX2801001:12.CMD_RETS command!
            Nov 30 14:36:25 homematic-ccu2 daemon.warn cuxd[215]: use CUX2801001:12.CMD_QUERY_RET=1 to activate CUX2801001:12.CMD_RETL command!
            Nov 30 14:36:25 homematic-ccu2 daemon.warn cuxd[215]: use CUX2801001:13.CMD_QUERY_RET=1 to activate CUX2801001:13.CMD_RETS command!
            Nov 30 14:36:25 homematic-ccu2 daemon.warn cuxd[215]: use CUX2801001:13.CMD_QUERY_RET=1 to activate CUX2801001:13.CMD_RETL command!
            Nov 30 14:36:25 homematic-ccu2 daemon.warn cuxd[215]: use CUX2801001:14.CMD_QUERY_RET=1 to activate CUX2801001:14.CMD_RETS command!
            Nov 30 14:36:25 homematic-ccu2 daemon.warn cuxd[215]: use CUX2801001:14.CMD_QUERY_RET=1 to activate CUX2801001:14.CMD_RETL command!
            Nov 30 14:36:25 homematic-ccu2 daemon.warn cuxd[215]: use CUX2801001:15.CMD_QUERY_RET=1 to activate CUX2801001:15.CMD_RETS command!
            Nov 30 14:36:25 homematic-ccu2 daemon.warn cuxd[215]: use CUX2801001:15.CMD_QUERY_RET=1 to activate CUX2801001:15.CMD_RETL command!
            Nov 30 14:36:25 homematic-ccu2 daemon.warn cuxd[215]: use CUX2801001:16.CMD_QUERY_RET=1 to activate CUX2801001:16.CMD_RETS command!
            Nov 30 14:36:25 homematic-ccu2 daemon.warn cuxd[215]: use CUX2801001:16.CMD_QUERY_RET=1 to activate CUX2801001:16.CMD_RETL command!
            Nov 30 14:36:30 homematic-ccu2 daemon.info cuxd[215]: INIT 'xmlrpc_bin://127.0.0.1:12010' 'hm-rpc.1'
            Nov 30 14:38:39 homematic-ccu2 daemon.err cuxd[215]: sendbinrpc(127.0.0.1:12010) - write() Connection refused
            Nov 30 14:41:12 homematic-ccu2 daemon.err cuxd[215]: sendbinrpc(127.0.0.1:12010) - write() Connection refused
            Nov 30 14:46:17 homematic-ccu2 daemon.err cuxd[215]: sendbinrpc(127.0.0.1:12010) - write() Connection refused
            Nov 30 14:48:49 homematic-ccu2 daemon.err cuxd[215]: sendbinrpc(127.0.0.1:12010) - write() Connection refused
            Nov 30 14:53:54 homematic-ccu2 daemon.err cuxd[215]: sendbinrpc(127.0.0.1:12010) - write() Connection refused
            Nov 30 14:56:27 homematic-ccu2 daemon.err cuxd[215]: sendbinrpc(127.0.0.1:12010) - write() Connection refused
            Nov 30 14:56:27 homematic-ccu2 daemon.warn cuxd[215]: disable events to 127.0.0.1:12010
            Ich habe jetzt mal das CUX2801001 Gerät gelöscht, war eine FB / Taste mit einem Script aus dem HM Forum, was ich aber nicht benutze.
            VG Uwe
            • HALH Offline
              HALH Offline
              HAL
              Noch eine Info, jetzt steht im CuxD Syslog etwas zu ReGaHss :
              Nov 30 15:33:30 homematic-ccu2 local0.err ReGaHss: Error: IseXmlRpc::CallGetValue: CallXmlrpcMethod failed [iseXmlRpc.cpp:1455]
              Nov 30 15:33:30 homematic-ccu2 local0.err ReGaHss: Error: IseHssDP::ReadValue: CallGetValue failed; sVal = 0 [iseDOMdpHSS.cpp:130]
              Nov 30 15:33:53 homematic-ccu2 user.warn kernel: [  295.233498] RTL8723BS: nolinked power save leave
              Nov 30 15:33:54 homematic-ccu2 user.warn kernel: [  296.810863] RTL8723BS: nolinked power save enter
              Nov 30 15:34:34 homematic-ccu2 daemon.err cuxd[217]: sendbinrpc(127.0.0.1:12010) - write() Connection refused
              Nov 30 15:34:56 homematic-ccu2 user.warn kernel: [  358.247271] RTL8723BS: nolinked power save leave
              Nov 30 15:34:57 homematic-ccu2 user.warn kernel: [  359.818954] RTL8723BS: nolinked power save enter
              Nov 30 15:35:05 homematic-ccu2 user.err rfd: Parameterset MASTER not found
              Nov 30 15:35:05 homematic-ccu2 local0.err ReGaHss: Error: IseXmlRpc::CallXmlrpcMethod: execute result isFault; method =getParamsetDescription Params = {"KEQ1022655:2","MASTER"} result= [faultCode:-3,faultString:"Unknown paramset"] [iseXmlRpc.cpp:2641]
              Nov 30 15:35:05 homematic-ccu2 local0.err ReGaHss: Error: IseXmlRpc::CallGetParamsetDescription: CallXmlrpcMethod failed [iseXmlRpc.cpp:2421]
              Nov 30 15:35:59 homematic-ccu2 user.warn kernel: [  421.271161] RTL8723BS: nolinked power save leave
              Nov 30 15:36:00 homematic-ccu2 user.warn kernel: [  422.842038] RTL8723BS: nolinked power save enter
              Nov 30 15:37:02 homematic-ccu2 user.warn kernel: [  484.270581] RTL8723BS: nolinked power save leave
              Nov 30 15:37:03 homematic-ccu2 user.warn kernel: [  485.841216] RTL8723BS: nolinked power save enter
              Nov 30 15:37:07 homematic-ccu2 daemon.err cuxd[217]: sendbinrpc(127.0.0.1:12010) - write() Connection refused
              Nov 30 15:38:05 homematic-ccu2 user.warn kernel: [  547.262734] RTL8723BS: nolinked power save leave
              Nov 30 15:38:06 homematic-ccu2 user.warn kernel: [  548.832967] RTL8723BS: nolinked power save enter
              Nov 30 15:39:08 homematic-ccu2 user.warn kernel: [  610.255004] RTL8723BS: nolinked power save leave
              Nov 30 15:39:09 homematic-ccu2 user.warn kernel: [  611.832127] RTL8723BS: nolinked power save enter
              Nov 30 15:39:39 homematic-ccu2 daemon.err cuxd[217]: sendbinrpc(127.0.0.1:12010) - write() Connection refused
              Nov 30 15:40:01 homematic-ccu2 cron.info crond[77]: crond: USER root pid 772 cmd /bin/sh /usr/local/addons/hconnectvpn/checkaccount.sh >> /dev/null
              Nov 30 15:40:12 homematic-ccu2 user.warn kernel: [  674.856761] RTL8723BS: nolinked power save enter
                deimos
                @deimos:
                Ich schau mir das die Tage noch etwas genauer an und schiebe das dann Richtung Armbian oder Kernel Issue Tracker. `
                habe grade bei Armbian einen Patch dafür abgeladen: https://github.com/armbian/build/pull/847
                Damit läuft bei mir jetzt auch der ondemand Scheduler und taktet brav auf 816MHz runter, was bei mir realistisch zum Workload ist.
                Viele Grüße
                Alex
                  ist auch schon gemerged!
                  • R Offline
                    rudiraz
                    ich habe das gleiche Problem mit dem Tinkerboard.
                    Allerdings ist es bei mir so, dass die CPU nicht mehr runtertaktet, seit ich Bluetooth einsetze.
                    Hab den ebenfalls auf Schedutil gestellt und nun gehts.
                    Wie komme ich an den Patch ran?
                    Ich habe das Armbian Debian Stretch next (Kernel Linux tinkerboard 4.13.16-rockchip #19)
                    Ist eigentlich Debian Stretch mit Kernel 4.4 besser für iobroker?
                      deimos
                      gibt zwei Möglichkeiten an den Patch ranzukommen:
                      • Warten bis zum nächsten Armbian Release, dann kann man den Kernel per apt updaten.
                      • Armbian Build Umgebung aufsetzen und Kernel selber bauen und die deb Packages manuell einspielen
                      Der Kernel 4.4 ist beim Tinkerboard kritisch, zumindest wenn man piVCCU verwenden will: Bei Rockchip und/oder Asus haben sie irgendwas reingepatcht, was verhindert, dass man Kernel Module bauen kann (ich vermute mal nicht mit Absicht) und ohne Kernel Module kann piVCCU einfach nicht funktionieren wegen den Anfordungen für den Betrieb des Funkmoduls.
                      Viele Grüße
                      Alex
                      • R Offline
                        rudiraz
                        Dann bleib ich bei Debian Stretch 4.13..
                        Gibts eigentlich einen Grund, warum in dem All-In-One-Image Ubuntu statt Debian genutzt wurde?
                          deimos
                          beim piVCCU Image gibt es zwei Gründe:
                          1. Ubuntu ist bei Armbian das Default System für das Tinkerboard.
                          2. Ubuntu ist mein persönlicher Favorit und läuft auf allen meinen Servern (und ja, das ist extrem subjektiv und ich möchte damit keinen Religionskrieg anfachen 😉)
                          Als ich das Image für piVCCU rausgebracht habe, war es leider noch so, dass Armbian für das Tinkerboard keine aktuellen Kernel Header bereitgestellt hatte und der einzige gangbare Weg für die Header war, selber ein Image mit der Build Umgebung zu bauen. Seit Armbian 5.35 ist das glücklicherweise nicht mehr der Fall. Aber damals hat das dann dafür gesorgt, dass Homoran eigentlich keine andere Möglichkeit hatte, als mein Image zu nehmen und darauf aufzubauen um das All-In-One zu bauen.
                          Viele Grüße
                          Alex
                          • R Offline
                            rudiraz
                            Also Ubuntu ist eigentlich auch mein Favorit und läuft auch bei mir auf dem Server :-)
                            Nur auf dem Tinkerboard hatte ich Debain Stretch installiert.
                            Ich frage eigentlich deshalb, weil ich auf dem Tinkerboard kein Bluetooth verwenden kann siehe: http://forum.iobroker.net/viewtopic.php … 81#p104121
                            Ich musste einen BT-Dongle anschließen, um BT nutzen zu können.
                            Daher war die Frage, ob BT bei Ubuntu vielleicht funktioniert…
                            Hast du mal getestet?
                              Bei mir ist es eigentlich umgekehrt.
                              Ich mag (mochte) Ubuntu gar nicht. Mag sein, dass es daran lag, dass ich zu der Anfangszeit von ioBroker fast gar kein Linux kannte und es schon mit der Grundinstallation von nodejs immer wieder Probleme gab.
                              Es mussten Symlinks angelegt werden, die Pfade waren anders…..
                              Aber wie Alex schon schrieb. für Rock64 und Tinkerboard gibt es Armbian nur auf Basis von Ubuntu.
                              Diesmal läuft allerdings alles out of the box :P
                              Das Tinker OS (auf Debian basierend) lief auch ohne Probleme (getestet mit 1.6 und1.8), war allerdings ziemlich groß, da mit grafischer Oberfläche.
                              • R Offline
                                rudiraz
                                Nee, es gibt auch debian armbian. Unter other Downloads gibt's die images
                                  Ist das jetzt neu(er)?
                                  Sonst verwechsel ich das jetzt mit dem Rock64, da gibt es nur Ubuntu.
                                    deimos
                                    Debian für Tinkerboard gibt es imho erst seit Armbian 5.35. Vorher war aber auch Ubuntu noch als Testing gelistet.
                                    Viele Grüße
                                    Alex
                                    • R Offline
                                      rudiraz
                                      Kann gut sein. Mein Tinkerboard ist nagelneu :-)
                                      Ich wollte eigentlich nur wissen, ob es bezüglich iobroker nennenswerte Unterschiede gibt zwischen Ubuntu und Debian.
                                      iobroker läuft sowieso headless, also brauche ich mir um Desktop o.ä. keine Sorgen zu machen
                                      Ich hab nur Probleme mit BT :-(
                                      • HALH Offline
                                        HALH Offline
                                        HAL
                                        @deimos:
                                        Viele Grüße
                                        Alex `
                                        @Alex, ist Dir bekannt, ob es schon einen neuen Armbian Kernel für das Tinker Board gibt ? So langsam wächst meine Installation auf dem Pi und ich denke an einen Umzug auf Tinker. Der workaround
                                        funktioniert, aber die USB IO Interupts sind dann ja immer noch da. Keine Ahnung ob das "stört"
                                        VG Uwe
                                          deimos
                                          der Patch ist in Armbian 5.38 drin und das ist seit gut einer Woche verfügbar. Upgrade auf die neue Version kann mit apt (+ Reboot) erfolgen.
                                          Wie Rainer feststellt hat: Perfekt wird es dadurch leider immer noch nicht. Wenn ich mal eine ruhige Minute finde, will ich mir das aber auch nochmal anschauen, die Jungs von Armbian behandeln das Tinkerboard (bzw. eignetlich alles mit Rockchip) momentan leider etwas stiefmütterlich. Wobei ich klar sagen muss, ich kann da auch nur an der Oberfläche kratzen, ich habe da noch riesige Wissenslücken. Das letzte mal das ich vor piVCCU Hardware nah unterwegs war, ist bald zwei Jahrzehnte her…
                                          Viele Grüße
                                          Alex
