  4. Zigbee Adapter bleibt rot [gelöst]
4 Beiträge 3 Kommentatoren 392 Aufrufe 3 Beobachtet
    tourer4778
    schrieb am zuletzt editiert von tourer4778
    Hallo, mein Zigbee Adapter ist heute angekommen. Leider bekomme ich Ihn nicht zum laufen.
    was mich stutzig macht, ist das der Port nicht angezeigt wird.
    pi@raspberrypi:~ $ ls -la /dev/serial/by-id/
    total 0
    drwxr-xr-x 2 root root 60 Mar 11 17:44 .
    drwxr-xr-x 4 root root 80 Mar 11 17:44 ..
    lrwxrwxrwx 1 root root 13 Mar 11 17:44 usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20231214170338-if00 -> ../../ttyACM0
    Mein COM-Anschlussname : /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20231214170338-if00
    2024-03-11 19:08:59.056 - error: zigbee.0 (938318) getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
    2024-03-11 19:08:59.198 - info: zigbee.0 (938318) List of port: [{"path":"/dev/ttyACM0","manufacturer":"ITEAD","serialNumber":"20231214170338","pnpId":"usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20231214170338-if00","vendorId":"1a86","productId":"55d4"},{"path":"/dev/ttyAMA10"}]
    2024-03-11 19:09:03.251 - info: admin.0 (1359) <== Disconnect system.user.admin from ::ffff:192.168.178.21
    2024-03-11 19:09:13.950 - info: admin.0 (1359) ==> Connected system.user.admin from ::ffff:192.168.178.21
    2024-03-11 19:09:14.006 - error: zigbee.0 (938318) getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
    2024-03-11 19:09:14.132 - info: zigbee.0 (938318) List of port: [{"path":"/dev/ttyACM0","manufacturer":"ITEAD","serialNumber":"20231214170338","pnpId":"usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20231214170338-if00","vendorId":"1a86","productId":"55d4"},{"path":"/dev/ttyAMA10"}]
    2024-03-11 19:09:19.100 - error: zigbee.0 (938318) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
    2024-03-11 19:09:19.100 - error: zigbee.0 (938318) Failed to start Zigbee
    2024-03-11 19:09:19.101 - error: zigbee.0 (938318) Error herdsman start
    2024-03-11 19:09:29.103 - info: zigbee.0 (938318) Try to reconnect. 1 attempts left
    2024-03-11 19:09:29.104 - info: zigbee.0 (938318) Starting Zigbee npm ...
    2024-03-11 19:09:29.113 - info: zigbee.0 (938318) Installed Version: iobroker.zigbee@1.10.1
    2024-03-11 19:09:29.238 - error: zigbee.0 (938318) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
    2024-03-11 19:09:29.238 - error: zigbee.0 (938318) Failed to start Zigbee
    2024-03-11 19:09:29.238 - error: zigbee.0 (938318) Error herdsman start
    2024-03-11 19:10:03.684 - info: admin.0 (1359) <== Disconnect system.user.admin from ::ffff:192.168.178.21
    2024-03-11 19:12:17.041 - info: admin.0 (1359) ==> Connected system.user.admin from ::ffff:192.168.178.21
    2024-03-11 19:12:17.085 - error: zigbee.0 (938318) getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
    2024-03-11 19:12:17.244 - info: zigbee.0 (938318) List of port: [{"path":"/dev/ttyACM0","manufacturer":"ITEAD","serialNumber":"20231214170338","pnpId":"usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20231214170338-if00","vendorId":"1a86","productId":"55d4"},{"path":"/dev/ttyAMA10"}]
    2024-03-11 19:17:20.023 - info: admin.0 (1359) <== Disconnect system.user.admin from ::ffff:192.168.178.21
    2024-03-11 19:17:23.392 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 (force=false, process=true)
    2024-03-11 19:17:23.398 - info: zigbee.0 (938318) Got terminate signal TERMINATE_YOURSELF
    2024-03-11 19:17:23.399 - info: zigbee.0 (938318) cleaned everything up...
    2024-03-11 19:17:23.400 - info: zigbee.0 (938318) Zigbee: disabling joining new devices.
    2024-03-11 19:17:23.411 - warn: zigbee.0 (938318) Failed to stop zigbee during startup
    2024-03-11 19:17:23.412 - info: zigbee.0 (938318) terminating
    2024-03-11 19:17:23.412 - info: zigbee.0 (938318) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2024-03-11 19:17:23.447 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 send kill signal
    2024-03-11 19:17:23.900 - info: zigbee.0 (938318) terminating
    2024-03-11 19:17:23.996 - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2024-03-11 19:17:26.505 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 939335
    2024-03-11 19:17:28.630 - info: zigbee.0 (939335) starting. Version 1.10.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.19.1, js-controller: 5.0.19
    2024-03-11 19:17:28.667 - info: zigbee.0 (939335) Starting Zigbee npm ...
    2024-03-11 19:17:28.775 - info: zigbee.0 (939335) Installed Version: iobroker.zigbee@1.10.1
    AsgothianA S 2 Antworten Letzte Antwort
    • T tourer4778
      total 0
      AsgothianA Offline
      AsgothianA Offline
      Asgothian
      @tourer4778 hast du einen dongle -E oder einen dongle -P ?
      Der Adapter bekommt die Schnittstelle auf, aber keine Verbindung zur Firmware
      A.
      • T tourer4778
        total 0
        stefande
        schrieb am zuletzt editiert von stefande
        @tourer4778
        Das Dongle V2 müsste den Silicon Labs EFR32MG21 Chipsatz und nicht den TI Chipsatz haben.
        Ändere mal in den Einstellungen den Typ.
        • S stefande
          @tourer4778
          tourer4778
          @stefande
          Danke, das war es ...
          Alles Grün 🤠
